path: root/Documentation/video4linux
2011-07-27[media] v4l2-framework.txt: update v4l2_event sectionHans Verkuil
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] v4l2-framework.txt: updated v4l2_fh_init documentationHans Verkuil
v4l2_fh_init now returns void instead of int, updated the doc. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] Documentation: Improve cluster documentation and document the new ↵Hans Verkuil
autoclusters Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] v4l2-controls.txt: update to latest v4l2-ctrl.c changesHans Verkuil
2011-07-27[media] davinci vpbe: Readme text for Dm6446 vpbeManjunath Hadli
Please refer to this file for detailed documentation of davinci vpbe v4l2 driver. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Acked-by: Muralidharan Karicheri <m-karicheri2@ti.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] V4L1 API has been moved into "legacy" on the linuxtv.org siteBjørn Mork
Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] dib0700: add initial code for PCTV 340e by Davide FerriDavide Ferri
This is initial code written by Davide Ferri for the PCTV 340e, including a new xc4000 driver. I am checking in all the code unmodified, and making no assertions about its quality (other than confirming it compiles). [mchehab@redhat.com: rebased on the top of the current tree] Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Signed-off-by: Davide Ferri <davidef1986@gmail.com> Cc: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] Update several cardlistsMauro Carvalho Chehab
Several cardlist entries are missed. Fix them by running some script magic (about the same scripts we used to have at -hg tree). Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] uvcvideo: Add driver documentationMartin Rubli
This adds detailed documentation about the driver's extension unit control features. Part of it has been adopted from the dynctrl.txt that used to be available in the driver's previous Subversion repository. The documentation has been rewritten to match the current implementation, in particular to capture the new XU control support including UVCIOC_CTRL_QUERY. Signed-off-by: Martin Rubli <martin_rubli@logitech.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] zoran: Drop unused module parameters encoder and decoderJean Delvare
The ability to force the encoder or decoder chip was broken by commit 0ab6e1c38d80ab586e3a1ca9e71844131d9f51dc in February 2009. As nobody complained for over 2 years, I take it that these parameters were no longer used so we can simply drop them. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] gspca - jeilinj: Add SPORTSCAM_DV15 camera supportPatrice Chotard
Signed-off-by: Patrice CHOTARD <patricechotard@free.fr> Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] em28xx: include model number for PCTV 330eDevin Heitmueller
Given how PCTV has multiple products with the same model name, include the model number in the description and #define to make it a little more clear. Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-27Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (42 commits) [media] media: vb2: correct queue initialization order [media] media: vb2: fix incorrect v4l2_buffer->flags handling [media] s5p-fimc: Add support for the buffer timestamps and sequence [media] s5p-fimc: Fix bytesperline and plane payload setup [media] s5p-fimc: Do not allow changing format after REQBUFS [media] s5p-fimc: Fix FIMC3 pixel limits on Exynos4 [media] tda18271: update tda18271c2_rf_cal as per NXP's rev.04 datasheet [media] tda18271: update tda18271_rf_band as per NXP's rev.04 datasheet [media] tda18271: fix bad calculation of main post divider byte [media] tda18271: prog_cal and prog_tab variables should be s32, not u8 [media] tda18271: fix calculation bug in tda18271_rf_tracking_filters_init [media] omap3isp: queue: Don't corrupt buf->npages when get_user_pages() fails [media] v4l: Don't register media entities for subdev device nodes [media] omap3isp: Don't increment node entity use count when poweron fails [media] omap3isp: lane shifter support [media] omap3isp: ccdc: support Y10/12, 8-bit bayer fmts [media] media: add missing 8-bit bayer formats and Y12 [media] v4l: add V4L2_PIX_FMT_Y12 format cx23885: Fix stv0367 Kconfig dependency [media] omap3isp: Use isp xclk defines ... Fix up trivial conflict (spelink errurs) in drivers/media/video/omap3isp/isp.c
2011-04-13[media] V4L: sh_mobile_ceu_camera: fix typos in documentationGuennadi Liakhovetski
Fix a couple of typos and clarify a formula in sh_mobile_ceu driver documentation. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-04-04Documentation: fix minor typos/spellingSylvestre Ledru
Fix some minor typos: * informations => information * there own => their own * these => this Signed-off-by: Sylvestre Ledru <sylvestre.ledru@scilab.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-24Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (442 commits) [media] videobuf2-dma-contig: make cookie() return a pointer to dma_addr_t [media] sh_mobile_ceu_camera: Do not call vb2's mem_ops directly [media] V4L: soc-camera: explicitly require V4L2_BUF_TYPE_VIDEO_CAPTURE [media] v4l: soc-camera: Store negotiated buffer settings [media] rc: interim support for 32-bit NEC-ish scancodes [media] mceusb: topseed 0x0011 needs gen3 init for tx to work [media] lirc_zilog: error out if buffer read bytes != chunk size [media] lirc: silence some compile warnings [media] hdpvr: use same polling interval as other OS [media] ir-kbd-i2c: pass device code w/key in hauppauge case [media] rc/keymaps: Remove the obsolete rc-rc5-tv keymap [media] remove the old RC_MAP_HAUPPAUGE_NEW RC map [media] rc/keymaps: Rename Hauppauge table as rc-hauppauge [media] rc-rc5-hauppauge-new: Fix Hauppauge Grey mapping [media] rc-rc5-hauppauge-new: Add support for the old Black RC [media] rc-rc5-hauppauge-new: Add the old control to the table [media] rc-winfast: Fix the keycode tables [media] a800: Fix a few wrong IR key assignments [media] opera1: Use multimedia keys instead of an app-specific mapping [media] dw2102: Use multimedia keys instead of an app-specific mapping ... Fix up trivial conflicts (remove/modify and some real conflicts) in: arch/arm/mach-omap2/devices.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/dabusb/dabusb.c drivers/staging/dabusb/dabusb.h drivers/staging/easycap/easycap_ioctl.c drivers/staging/usbvideo/usbvideo.c drivers/staging/usbvideo/vicam.c
2011-03-22[media] v4l2: use new flag to enable core priority handlingHans Verkuil
Rather than guess which driver supports core priority handling, require drivers that do to explicitly set the V4L2_FL_USE_FH_PRIO flag in video_device. Updated the core prio handling accordingly and set the flag in the three drivers that do. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l2-framework.txt: document new v4l2_device release() callbackHans Verkuil
2011-03-22[media] v4l2-framework.txt: improve v4l2_fh/priority documentationHans Verkuil
2011-03-22[media] gspca - nw80x: New subdriver for Divio based webcamsJean-François Moine
[mchehab@redhat.com: Fix a few CodingStyle issues] Tested-by: Kjell Claesson <kjell.claesson@epost.tidanet.se> Tested-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] omap3isp: Add documentationSakari Ailus
Add documentation on the OMAP 3 ISP driver. Document the subdevs, V4L2 events and private IOCTLs the driver implements Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: David Cohen <dacohen@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: subdev: Generic ioctl supportLaurent Pinchart
Instead of returning an error when receiving an ioctl call with an unsupported command, forward the call to the subdev core::ioctl handler. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: Make v4l2_subdev inherit from media_entityLaurent Pinchart
V4L2 subdevices are media entities. As such they need to inherit from (include) the media_entity structure. When registering/unregistering the subdevice, the media entity is automatically registered/unregistered. The entity is acquired on device open and released on device close. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: Make video_device inherit from media_entityLaurent Pinchart
V4L2 devices are media entities. As such they need to inherit from (include) the media_entity structure. When registering/unregistering the device, the media entity is automatically registered/unregistered. The entity is acquired on device open and released on device close. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: Add a media_device pointer to the v4l2_device structureLaurent Pinchart
The pointer will later be used to register/unregister media entities when registering/unregistering a v4l2_subdev or a video_device. With the introduction of media devices, device drivers need to store a pointer to a driver-specific structure in the device's drvdata. v4l2_device can't claim ownership of the drvdata anymore. To maintain compatibility with drivers that rely on v4l2_device storing a pointer to itself in the device's drvdata, v4l2_device_register() will keep doing so if the drvdata is NULL. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] v4l: subdev: Events supportSakari Ailus
Provide v4l2_subdevs with v4l2_event support. Subdev drivers only need very little to support events. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: David Cohen <dacohen@gmail.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] v4l: subdev: Control ioctls supportLaurent Pinchart
Pass the control-related ioctls to the subdev driver through the control framework. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] v4l: subdev: Add device node supportLaurent Pinchart
Create a device node named subdevX for every registered subdev. As the device node is registered before the subdev core::s_config function is called, return -EGAIN on open until initialization completes. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Vimarsh Zutshi <vimarsh.zutshi@gmail.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] Documentation: README.ivtv: Remove note that ivtvfb is not yet in ↵Paul Cassella
the kernel ivtvfb is now in the kernel, so stop saying it's not. Signed-off-by: Paul Cassella <fortytwo-ivtv@manetheren.bigw.org> Signed-off-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] gspca - ov534: Add the webcam 06f8:3002 and sensor ov767xJean-François Moine
2011-03-20i2c: Get rid of <linux/i2c-id.h>Jean Delvare
The last remaining ID in <linux/i2c-id.h> is no longer used anywhere, so we can finally get rid of it. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-01-19[media] v4l2-ctrls: v4l2_ctrl_handler_setup must set is_new to 1Hans Verkuil
Renamed has_new to is_new. Drivers can use the is_new field to determine if a new value was specified for a control. The v4l2_ctrl_handler_setup() must always set this to 1 since the setup has to force a full update of all controls. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] cardlist: Update lists for em28xx and saa7134Mauro Carvalho Chehab
PS.: The cardlists are auto-generated via scripts. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] saa7134: Add support for Compro VideoMate Vista M1FRamiro Morales
Signed-off-by: Pavel Osnova <pvosnova@gmail.com> Signed-off-by: Ramiro Morales <ramiro@rmorales.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] Remove the old V4L1 v4lgrab.c fileMauro Carvalho Chehab
This example file uses the old V4L1 API. It also doesn't use libv4l. So, it is completely obsolete. A good example already exists at v4l-utils (v4l2grab.c): http://git.linuxtv.org/v4l-utils.git Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] cpia, stradis: remove deprecated V4L1 driversHans Verkuil
Nobody stepped in to convert these drivers to V4L2, so they are now removed from the kernel. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] documentation: update some files to reflect the V4L1 compat removalHans Verkuil
2010-12-29[media] zoran: remove V4L1 compat code and zoran custom ioctlsHans Verkuil
All the functionality is now handled through V4L2. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] gspca - sq905c: Adds the Lego BionicleTheodore Kilgore
This patch adds the Vendor:Product number of the Lego Bionicle camera to the existing gspca/sq905c.c and also a line for the camera in gspca.txt. The camera works "out of the box" with these small changes. So this is just in time for Christmas. Think of the children. Signed-off-by: Theodore Kilgore <kilgota@auburn.edu> Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] em28xx: Add support for Leadership ISDB-TMauro Carvalho Chehab
This device uses an em2874B + Sharp 921 One Seg frontend. Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-22[media] Support for Elgato Video CaptureAdrian Taylor
This patch allows this device successfully to show video, at least from its composite input. I have no information about the true hardware contents of this device and so this patch is based solely on fiddling with things until it worked. The chip appears to be em2860, and the closest device with equivalent inputs is the Typhoon DVD Maker. Copying the settings for that device appears to do the trick. That's what this patch does. [mchehab@redhat.com: update CARDLIST.em28xx accordingly, via script] Signed-off-by: Adrian Taylor <adrian.taylor@realvnc.com> Reviewed-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-22[media] Documentation/video4linux/CARDLIST.[cx88|saa7134]Mauro Carvalho Chehab
Fix a few troubles at the card entries Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21[media] radio-mr800: fix locking orderHans Verkuil
Don't hold the lock before unregistering the device, since when the device is unregistered the datastruct containing the lock may be freed (if the refcount went to 0). Also fixed the framework documentation that erroneously suggested the wrong locking order as well. Reported-by: David Ellingsworth <david@identd.dyndns.org> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: David Ellingsworth <david@identd.dyndns.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: v4l2: add core serialization lockHans Verkuil
Drivers can optionally set a pointer to a mutex in struct video_device. The core will use that to lock before calling open, read, write, unlocked_ioctl, poll, mmap or release. Updated the documentation as well and ensure that v4l2-event knows about the lock: it will unlock it before doing a blocking wait on an event and relock it afterwards. Ensure that the 'video_is_registered' check is done when the lock is held: a typical disconnect will take the lock as well before unregistering the device nodes, so to prevent race conditions the video_is_registered check should also be done with the lock held. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: v4l2-dev: after a disconnect any ioctl call will be blockedHans Verkuil
Until now all fops except release and (unlocked_)ioctl returned an error after the device node was unregistered. Extend this as well to the ioctl fops. There is nothing useful that an application can do here and it complicates the driver code unnecessarily. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: gspca - sonixj: Add webcam 0c45:612bAlexander Goncharov
Signed-off-by: Alexander Goncharov <alexzandersss@gmail.com> Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: gspca - sonixj: Webcam 0c45:6102 addedJean-François Moine
Tested-by: Simon Danner <simon@danner-urloffen.de> Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: Documentation: update now that the vtx/videotext API has been removedHans Verkuil
Remove all references to /dev/vtx in the documentation, except for some historical comments in dev-teletext.xml. Documentation/devices.txt is not updated, this will go through Alan Cox who maintains this file. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
