path: root/Documentation/virtual
2012-03-28Merge branch 'kvm-updates/3.4' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm updates from Avi Kivity: "Changes include timekeeping improvements, support for assigning host PCI devices that share interrupt lines, s390 user-controlled guests, a large ppc update, and random fixes." This is with the sign-off's fixed, hopefully next merge window we won't have rebased commits. * 'kvm-updates/3.4' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (130 commits) KVM: Convert intx_mask_lock to spin lock KVM: x86: fix kvm_write_tsc() TSC matching thinko x86: kvmclock: abstract save/restore sched_clock_state KVM: nVMX: Fix erroneous exception bitmap check KVM: Ignore the writes to MSR_K7_HWCR(3) KVM: MMU: make use of ->root_level in reset_rsvds_bits_mask KVM: PMU: add proper support for fixed counter 2 KVM: PMU: Fix raw event check KVM: PMU: warn when pin control is set in eventsel msr KVM: VMX: Fix delayed load of shared MSRs KVM: use correct tlbs dirty type in cmpxchg KVM: Allow host IRQ sharing for assigned PCI 2.3 devices KVM: Ensure all vcpus are consistent with in-kernel irqchip settings KVM: x86 emulator: Allow PM/VM86 switch during task switch KVM: SVM: Fix CPL updates KVM: x86 emulator: VM86 segments must have DPL 3 KVM: x86 emulator: Fix task switch privilege checks arch/powerpc/kvm/book3s_hv.c: included linux/sched.h twice KVM: x86 emulator: correctly mask pmc index bits in RDPMC instruction emulation KVM: mmu_notifier: Flush TLBs before releasing mmu_lock ...
2012-03-08KVM: Allow host IRQ sharing for assigned PCI 2.3 devicesJan Kiszka
PCI 2.3 allows to generically disable IRQ sources at device level. This enables us to share legacy IRQs of such devices with other host devices when passing them to a guest. The new IRQ sharing feature introduced here is optional, user space has to request it explicitly. Moreover, user space can inform us about its view of PCI_COMMAND_INTX_DISABLE so that we can avoid unmasking the interrupt and signaling it if the guest masked it via the virtualized PCI config space. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-07Documentation: Fix multiple typo in DocumentationMasanari Iida
Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-05KVM: PPC: refer to paravirt docs in header fileScott Wood
Instead of keeping separate copies of struct kvm_vcpu_arch_shared (one in the code, one in the docs) that inevitably fail to be kept in sync (already sr[] is missing from the doc version), just point to the header file as the source of documentation on the contents of the magic page. Signed-off-by: Scott Wood <scottwood@freescale.com> Acked-by: Avi Kivity <avi@redhat.com> Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: PPC: Add support for explicit HIOR settingAlexander Graf
Until now, we always set HIOR based on the PVR, but this is just wrong. Instead, we should be setting HIOR explicitly, so user space can decide what the initial HIOR value is - just like on real hardware. We keep the old PVR based way around for backwards compatibility, but once user space uses the SET_ONE_REG based method, we drop the PVR logic. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: PPC: Add generic single register ioctlsAlexander Graf
Right now we transfer a static struct every time we want to get or set registers. Unfortunately, over time we realize that there are more of these than we thought of before and the extensibility and flexibility of transferring a full struct every time is limited. So this is a new approach to the problem. With these new ioctls, we can get and set a single register that is identified by an ID. This allows for very precise and limited transmittal of data. When we later realize that it's a better idea to shove over multiple registers at once, we can reuse most of the infrastructure and simply implement a GET_MANY_REGS / SET_MANY_REGS interface. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: PPC: e500: MMU APIScott Wood
This implements a shared-memory API for giving host userspace access to the guest's TLB. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: provide synchronous registers in kvm_runChristian Borntraeger
On some cpus the overhead for virtualization instructions is in the same range as a system call. Having to call multiple ioctls to get set registers will make certain userspace handled exits more expensive than necessary. Lets provide a section in kvm_run that works as a shared save area for guest registers. We also provide two 64bit flags fields (architecture specific), that will specify 1. which parts of these fields are valid. 2. which registers were modified by userspace Each bit for these flag fields will define a group of registers (like general purpose) or a single register. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: ucontrol: interface to inject faults on a vcpu page tableCarsten Otte
This patch allows the user to fault in pages on a virtual cpus address space for user controlled virtual machines. Typically this is superfluous because userspace can just create a mapping and let the kernel's page fault logic take are of it. There is one exception: SIE won't start if the lowcore is not present. Normally the kernel takes care of this [handle_validity() in arch/s390/kvm/intercept.c] but since the kernel does not handle intercepts for user controlled virtual machines, userspace needs to be able to handle this condition. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: ucontrol: export SIE control block to userCarsten Otte
This patch exports the s390 SIE hardware control block to userspace via the mapping of the vcpu file descriptor. In order to do so, a new arch callback named kvm_arch_vcpu_fault is introduced for all architectures. It allows to map architecture specific pages. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: ucontrol: export page faults to userCarsten Otte
This patch introduces a new exit reason in the kvm_run structure named KVM_EXIT_S390_UCONTROL. This exit indicates, that a virtual cpu has regognized a fault on the host page table. The idea is that userspace can handle this fault by mapping memory at the fault location into the cpu's address space and then continue to run the virtual cpu. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: ucontrol: per vcpu address spacesCarsten Otte
This patch introduces two ioctls for virtual cpus, that are only valid for kernel virtual machines that are controlled by userspace. Each virtual cpu has its individual address space in this mode of operation, and each address space is backed by the gmap implementation just like the address space for regular KVM guests. KVM_S390_UCAS_MAP allows to map a part of the user's virtual address space to the vcpu. Starting offset and length in both the user and the vcpu address space need to be aligned to 1M. KVM_S390_UCAS_UNMAP can be used to unmap a range of memory from a virtual cpu in a similar way. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: add parameter for KVM_CREATE_VMCarsten Otte
This patch introduces a new config option for user controlled kernel virtual machines. It introduces a parameter to KVM_CREATE_VM that allows to set bits that alter the capabilities of the newly created virtual machine. The parameter is passed to kvm_arch_init_vm for all architectures. The only valid modifier bit for now is KVM_VM_S390_UCONTROL. This requires CAP_SYS_ADMIN privileges and creates a user controlled virtual machine on s390 architectures. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-01-28lguest: remove reference from Documentation/virtual/00-INDEXRusty Russell
We're in tools/lguest now. Reported-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-12lguest: move the lguest tool to the tools directoryDavidlohr Bueso
This is a better location instead of having it in Documentation. Signed-off-by: Davidlohr Bueso <dave@gnu.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (fixed compile)
2011-12-27KVM: Document KVM_NMIAvi Kivity
2011-12-26KVM: Don't automatically expose the TSC deadline timer in cpuidJan Kiszka
Unlike all of the other cpuid bits, the TSC deadline timer bit is set unconditionally, regardless of what userspace wants. This is broken in several ways: - if userspace doesn't use KVM_CREATE_IRQCHIP, and doesn't emulate the TSC deadline timer feature, a guest that uses the feature will break - live migration to older host kernels that don't support the TSC deadline timer will cause the feature to be pulled from under the guest's feet; breaking it - guests that are broken wrt the feature will fail. Fix by not enabling the feature automatically; instead report it to userspace. Because the feature depends on KVM_CREATE_IRQCHIP, which we cannot guarantee will be called, we expose it via a KVM_CAP_TSC_DEADLINE_TIMER and not KVM_GET_SUPPORTED_CPUID. Fixes the Illumos guest kernel, which uses the TSC deadline timer feature. [avi: add the KVM_CAP + documentation] Reported-by: Alexey Zaytsev <alexey.zaytsev@gmail.com> Tested-by: Alexey Zaytsev <alexey.zaytsev@gmail.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-25KVM: Device assignment permission checksAlex Williamson
Only allow KVM device assignment to attach to devices which: - Are not bridges - Have BAR resources (assume others are special devices) - The user has permissions to use Assigning a bridge is a configuration error, it's not supported, and typically doesn't result in the behavior the user is expecting anyway. Devices without BAR resources are typically chipset components that also don't have host drivers. We don't want users to hold such devices captive or cause system problems by fencing them off into an iommu domain. We determine "permission to use" by testing whether the user has access to the PCI sysfs resource files. By default a normal user will not have access to these files, so it provides a good indication that an administration agent has granted the user access to the device. [Yang Bai: add missing #include] [avi: fix comment style] Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Yang Bai <hamo.by@gmail.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-25KVM: Remove ability to assign a device without iommu supportAlex Williamson
This option has no users and it exposes a security hole that we can allow devices to be assigned without iommu protection. Make KVM_DEV_ASSIGN_ENABLE_IOMMU a mandatory option. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-11-02Merge branch 'for-linus' of git://github.com/richardweinberger/linuxLinus Torvalds
* 'for-linus' of git://github.com/richardweinberger/linux: (90 commits) um: fix ubd cow size um: Fix kmalloc argument order in um/vdso/vma.c um: switch to use of drivers/Kconfig UserModeLinux-HOWTO.txt: fix a typo UserModeLinux-HOWTO.txt: remove ^H characters um: we need sys/user.h only on i386 um: merge delay_{32,64}.c um: distribute exports to where exported stuff is defined um: kill system-um.h um: generic ftrace.h will do... um: segment.h is x86-only and needed only there um: asm/pda.h is not needed anymore um: hw_irq.h can go generic as well um: switch to generic-y um: clean Kconfig up a bit um: a couple of missing dependencies... um: kill useless argument of free_chan() and free_one_chan() um: unify ptrace_user.h um: unify KSTK_... um: fix gcov build breakage ...
2011-11-02UserModeLinux-HOWTO.txt: fix a typoJonathan Neuschäfer
Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-11-02UserModeLinux-HOWTO.txt: remove ^H charactersJonathan Neuschäfer
If you can't read this patch, please run: sed -i -e "s/[^\o10]\o10//g" \ Documentation/virtual/uml/UserModeLinux-HOWTO.txt Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-10-30Merge branch 'kvm-updates/3.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm * 'kvm-updates/3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm: (75 commits) KVM: SVM: Keep intercepting task switching with NPT enabled KVM: s390: implement sigp external call KVM: s390: fix register setting KVM: s390: fix return value of kvm_arch_init_vm KVM: s390: check cpu_id prior to using it KVM: emulate lapic tsc deadline timer for guest x86: TSC deadline definitions KVM: Fix simultaneous NMIs KVM: x86 emulator: convert push %sreg/pop %sreg to direct decode KVM: x86 emulator: switch lds/les/lss/lfs/lgs to direct decode KVM: x86 emulator: streamline decode of segment registers KVM: x86 emulator: simplify OpMem64 decode KVM: x86 emulator: switch src decode to decode_operand() KVM: x86 emulator: qualify OpReg inhibit_byte_regs hack KVM: x86 emulator: switch OpImmUByte decode to decode_imm() KVM: x86 emulator: free up some flag bits near src, dst KVM: x86 emulator: switch src2 to generic decode_operand() KVM: x86 emulator: expand decode flags to 64 bits KVM: x86 emulator: split dst decode to a generic decode_operand() KVM: x86 emulator: move memop, memopp into emulation context ...
2011-09-27doc: fix broken referencesPaul Bolle
There are numerous broken references to Documentation files (in other Documentation files, in comments, etc.). These broken references are caused by typo's in the references, and by renames or removals of the Documentation files. Some broken references are simply odd. Fix these broken references, sometimes by dropping the irrelevant text they were part of. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-09-25KVM: Update documentation to include detailed ENABLE_CAP descriptionAlexander Graf
We have an ioctl that enables capabilities individually, but no description on what exactly happens when we enable a capability using this ioctl. This patch adds documentation for capability enabling in a new section of the API documentation. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-09-25KVM: Restore missing powerpc API docsAvi Kivity
Commit 371fefd6 lost a doc hunk somehow, restore it. Signed-off-by: Avi Kivity <avi@redhat.com>
2011-09-25KVM: x86: Raise the hard VCPU count limitSasha Levin
The patch raises the hard limit of VCPU count to 254. This will allow developers to easily work on scalability and will allow users to test high VCPU setups easily without patching the kernel. To prevent possible issues with current setups, KVM_CAP_NR_VCPUS now returns the recommended VCPU limit (which is still 64) - this should be a safe value for everybody, while a new KVM_CAP_MAX_VCPUS returns the hard limit which is now 254. Cc: Avi Kivity <avi@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Pekka Enberg <penberg@kernel.org> Suggested-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-08-15lguest: allow booting guest with CONFIG_RELOCATABLE=yRusty Russell
The CONFIG_RELOCATABLE code tries to align the unpack destination to the value of 'kernel_alignment' in the setup_hdr. If that's 0, it tries to unpack to address 0, which in fact causes the gunzip code to call 'error("Out of memory while allocating output buffer")'. The bootloader (ie. the lguest Launcher in this case) should be doing setting this field; the normal bzImage is 16M, we can use the same. Reported-by: Stefanos Geraggelos <sgerag@cslab.ece.ntua.gr> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: stable@kernel.org
2011-08-15virtio: Add text copy of spec to Documentation/virtual.Rusty Russell
As suggested by Christoph Hellwig. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-24Merge branch 'kvm-updates/3.1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/3.1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (143 commits) KVM: IOMMU: Disable device assignment without interrupt remapping KVM: MMU: trace mmio page fault KVM: MMU: mmio page fault support KVM: MMU: reorganize struct kvm_shadow_walk_iterator KVM: MMU: lockless walking shadow page table KVM: MMU: do not need atomicly to set/clear spte KVM: MMU: introduce the rules to modify shadow page table KVM: MMU: abstract some functions to handle fault pfn KVM: MMU: filter out the mmio pfn from the fault pfn KVM: MMU: remove bypass_guest_pf KVM: MMU: split kvm_mmu_free_page KVM: MMU: count used shadow pages on prepareing path KVM: MMU: rename 'pt_write' to 'emulate' KVM: MMU: cleanup for FNAME(fetch) KVM: MMU: optimize to handle dirty bit KVM: MMU: cache mmio info on page fault path KVM: x86: introduce vcpu_mmio_gva_to_gpa to cleanup the code KVM: MMU: do not update slot bitmap if spte is nonpresent KVM: MMU: fix walking shadow page table KVM guest: KVM Steal time registration ...
2011-07-22lguest: update commentsRusty Russell
Also removes a long-unused #define and an extraneous semicolon. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-22lguest: Simplify device initialization.Rusty Russell
We used to notify the Host every time we updated a device's status. However, it only really needs to know when we're resetting the device, or failed to initialize it, or when we've finished our feature negotiation. In particular, we used to wait for VIRTIO_CONFIG_S_DRIVER_OK in the status byte before starting the device service threads. But this corresponds to the successful finish of device initialization, which might (like virtio_blk's partition scanning) use the device. So we had a hack, if they used the device before we expected we started the threads anyway. Now we hook into the finalize_features hook in the Guest: at that point we tell the Launcher that it can rely on the features we have acked. On the Launcher side, we look at the status at that point, and start servicing the device. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-22lguest: Do not exit on non-fatal errorsSakari Ailus
Do not exit on some non-fatal errors: - writev() fails in net_output(). The result is a lost packet or packets. - writev() fails in console_output(). The result is partially lost console output. - readv() fails in net_input(). The result is a lost packet or packets. Rather than bringing the guest down, this patch ignores e.g. an allocation failure on the host side. Example: lguest: page allocation failure. order:4, mode:0x4d0 Pid: 4045, comm: lguest Tainted: G W 2.6.36 #1 Call Trace: [<c138d614>] ? printk+0x18/0x1c [<c106a4e2>] __alloc_pages_nodemask+0x4d2/0x570 [<c1087954>] cache_alloc_refill+0x2a4/0x4d0 [<c1305149>] ? __netif_receive_skb+0x189/0x270 [<c1087c5a>] __kmalloc+0xda/0xf0 [<c12fffa5>] __alloc_skb+0x55/0x100 [<c1305519>] ? net_rx_action+0x79/0x100 [<c12fafed>] sock_alloc_send_pskb+0x18d/0x280 [<c11fda25>] ? _copy_from_user+0x35/0x130 [<c13010b6>] ? memcpy_fromiovecend+0x56/0x80 [<c12a74dc>] tun_chr_aio_write+0x1cc/0x500 [<c108a125>] do_sync_readv_writev+0x95/0xd0 [<c11fda25>] ? _copy_from_user+0x35/0x130 [<c1089fa8>] ? rw_copy_check_uvector+0x58/0x100 [<c108a7bc>] do_readv_writev+0x9c/0x1d0 [<c12a7310>] ? tun_chr_aio_write+0x0/0x500 [<c108a93a>] vfs_writev+0x4a/0x60 [<c108aa21>] sys_writev+0x41/0x80 [<c138f061>] syscall_call+0x7/0xb Mem-Info: DMA per-cpu: CPU 0: hi: 0, btch: 1 usd: 0 Normal per-cpu: CPU 0: hi: 186, btch: 31 usd: 0 HighMem per-cpu: CPU 0: hi: 186, btch: 31 usd: 0 active_anon:134651 inactive_anon:50543 isolated_anon:0 active_file:96881 inactive_file:132007 isolated_file:0 unevictable:0 dirty:3 writeback:0 unstable:0 free:91374 slab_reclaimable:6300 slab_unreclaimable:2802 mapped:2281 shmem:9 pagetables:330 bounce:0 DMA free:3524kB min:64kB low:80kB high:96kB active_anon:0kB inactive_anon:8kB active_file:8760kB inactive_file:2760kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15868kB mlocked:0kB dirty:0kB writeback:0kB mapped:16kB shmem:0kB slab_reclaimable:88kB slab_unreclaimable:148kB kernel_stack:40kB pagetables:0kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no lowmem_reserve[]: 0 865 2016 2016 Normal free:150100kB min:3728kB low:4660kB high:5592kB active_anon:6224kB inactive_anon:15772kB active_file:324084kB inactive_file:325944kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:885944kB mlocked:0kB dirty:12kB writeback:0kB mapped:1520kB shmem:0kB slab_reclaimable:25112kB slab_unreclaimable:11060kB kernel_stack:1888kB pagetables:1320kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no lowmem_reserve[]: 0 0 9207 9207 HighMem free:211872kB min:512kB low:1752kB high:2992kB active_anon:532380kB inactive_anon:186392kB active_file:54680kB inactive_file:199324kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:1178504kB mlocked:0kB dirty:0kB writeback:0kB mapped:7588kB shmem:36kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no lowmem_reserve[]: 0 0 0 0 DMA: 3*4kB 65*8kB 35*16kB 18*32kB 11*64kB 9*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 3524kB Normal: 35981*4kB 344*8kB 158*16kB 28*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 150100kB HighMem: 5732*4kB 5462*8kB 2826*16kB 1598*32kB 84*64kB 10*128kB 7*256kB 1*512kB 1*1024kB 1*2048kB 9*4096kB = 211872kB 231237 total pagecache pages 2340 pages in swap cache Swap cache stats: add 160060, delete 157720, find 189017/194106 Free swap = 4179840kB Total swap = 4194300kB 524271 pages RAM 296946 pages HighMem 5668 pages reserved 867664 pages shared 82155 pages non-shared Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-12KVM: KVM Steal time guest/host interfaceGlauber Costa
To implement steal time, we need the hypervisor to pass the guest information about how much time was spent running other processes outside the VM. This is per-vcpu, and using the kvmclock structure for that is an abuse we decided not to make. In this patchset, I am introducing a new msr, KVM_MSR_STEAL_TIME, that holds the memory area address containing information about steal time This patch contains the headers for it. I am keeping it separate to facilitate backports to people who wants to backport the kernel part but not the hypervisor, or the other way around. Signed-off-by: Glauber Costa <glommer@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Tested-by: Eric B Munson <emunson@mgebm.net> CC: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> CC: Peter Zijlstra <peterz@infradead.org> CC: Anthony Liguori <aliguori@us.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-12KVM: PPC: Allocate RMAs (Real Mode Areas) at boot for use by guestsPaul Mackerras
This adds infrastructure which will be needed to allow book3s_hv KVM to run on older POWER processors, including PPC970, which don't support the Virtual Real Mode Area (VRMA) facility, but only the Real Mode Offset (RMO) facility. These processors require a physically contiguous, aligned area of memory for each guest. When the guest does an access in real mode (MMU off), the address is compared against a limit value, and if it is lower, the address is ORed with an offset value (from the Real Mode Offset Register (RMOR)) and the result becomes the real address for the access. The size of the RMA has to be one of a set of supported values, which usually includes 64MB, 128MB, 256MB and some larger powers of 2. Since we are unlikely to be able to allocate 64MB or more of physically contiguous memory after the kernel has been running for a while, we allocate a pool of RMAs at boot time using the bootmem allocator. The size and number of the RMAs can be set using the kvm_rma_size=xx and kvm_rma_count=xx kernel command line options. KVM exports a new capability, KVM_CAP_PPC_RMA, to signal the availability of the pool of preallocated RMAs. The capability value is 1 if the processor can use an RMA but doesn't require one (because it supports the VRMA facility), or 2 if the processor requires an RMA for each guest. This adds a new ioctl, KVM_ALLOCATE_RMA, which allocates an RMA from the pool and returns a file descriptor which can be used to map the RMA. It also returns the size of the RMA in the argument structure. Having an RMA means we will get multiple KMV_SET_USER_MEMORY_REGION ioctl calls from userspace. To cope with this, we now preallocate the kvm->arch.ram_pginfo array when the VM is created with a size sufficient for up to 64GB of guest memory. Subsequently we will get rid of this array and use memory associated with each memslot instead. This moves most of the code that translates the user addresses into host pfns (page frame numbers) out of kvmppc_prepare_vrma up one level to kvmppc_core_prepare_memory_region. Also, instead of having to look up the VMA for each page in order to check the page size, we now check that the pages we get are compound pages of 16MB. However, if we are adding memory that is mapped to an RMA, we don't bother with calling get_user_pages_fast and instead just offset from the base pfn for the RMA. Typically the RMA gets added after vcpus are created, which makes it inconvenient to have the LPCR (logical partition control register) value in the vcpu->arch struct, since the LPCR controls whether the processor uses RMA or VRMA for the guest. This moves the LPCR value into the kvm->arch struct and arranges for the MER (mediated external request) bit, which is the only bit that varies between vcpus, to be set in assembly code when going into the guest if there is a pending external interrupt request. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: PPC: Allow book3s_hv guests to use SMT processor modesPaul Mackerras
This lifts the restriction that book3s_hv guests can only run one hardware thread per core, and allows them to use up to 4 threads per core on POWER7. The host still has to run single-threaded. This capability is advertised to qemu through a new KVM_CAP_PPC_SMT capability. The return value of the ioctl querying this capability is the number of vcpus per virtual CPU core (vcore), currently 4. To use this, the host kernel should be booted with all threads active, and then all the secondary threads should be offlined. This will put the secondary threads into nap mode. KVM will then wake them from nap mode and use them for running guest code (while they are still offline). To wake the secondary threads, we send them an IPI using a new xics_wake_cpu() function, implemented in arch/powerpc/sysdev/xics/icp-native.c. In other words, at this stage we assume that the platform has a XICS interrupt controller and we are using icp-native.c to drive it. Since the woken thread will need to acknowledge and clear the IPI, we also export the base physical address of the XICS registers using kvmppc_set_xics_phys() for use in the low-level KVM book3s code. When a vcpu is created, it is assigned to a virtual CPU core. The vcore number is obtained by dividing the vcpu number by the number of threads per core in the host. This number is exported to userspace via the KVM_CAP_PPC_SMT capability. If qemu wishes to run the guest in single-threaded mode, it should make all vcpu numbers be multiples of the number of threads per core. We distinguish three states of a vcpu: runnable (i.e., ready to execute the guest), blocked (that is, idle), and busy in host. We currently implement a policy that the vcore can run only when all its threads are runnable or blocked. This way, if a vcpu needs to execute elsewhere in the kernel or in qemu, it can do so without being starved of CPU by the other vcpus. When a vcore starts to run, it executes in the context of one of the vcpu threads. The other vcpu threads all go to sleep and stay asleep until something happens requiring the vcpu thread to return to qemu, or to wake up to run the vcore (this can happen when another vcpu thread goes from busy in host state to blocked). It can happen that a vcpu goes from blocked to runnable state (e.g. because of an interrupt), and the vcore it belongs to is already running. In that case it can start to run immediately as long as the none of the vcpus in the vcore have started to exit the guest. We send the next free thread in the vcore an IPI to get it to start to execute the guest. It synchronizes with the other threads via the vcore->entry_exit_count field to make sure that it doesn't go into the guest if the other vcpus are exiting by the time that it is ready to actually enter the guest. Note that there is no fixed relationship between the hardware thread number and the vcpu number. Hardware threads are assigned to vcpus as they become runnable, so we will always use the lower-numbered hardware threads in preference to higher-numbered threads if not all the vcpus in the vcore are runnable, regardless of which vcpus are runnable. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: PPC: Accelerate H_PUT_TCE by implementing it in real modeDavid Gibson
This improves I/O performance for guests using the PAPR paravirtualization interface by making the H_PUT_TCE hcall faster, by implementing it in real mode. H_PUT_TCE is used for updating virtual IOMMU tables, and is used both for virtual I/O and for real I/O in the PAPR interface. Since this moves the IOMMU tables into the kernel, we define a new KVM_CREATE_SPAPR_TCE ioctl to allow qemu to create the tables. The ioctl returns a file descriptor which can be used to mmap the newly created table. The qemu driver models use them in the same way as userspace managed tables, but they can be updated directly by the guest with a real-mode H_PUT_TCE implementation, reducing the number of host/guest context switches during guest IO. There are certain circumstances where it is useful for userland qemu to write to the TCE table even if the kernel H_PUT_TCE path is used most of the time. Specifically, allowing this will avoid awkwardness when we need to reset the table. More importantly, we will in the future need to write the table in order to restore its state after a checkpoint resume or migration. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: PPC: Add support for Book3S processors in hypervisor modePaul Mackerras
This adds support for KVM running on 64-bit Book 3S processors, specifically POWER7, in hypervisor mode. Using hypervisor mode means that the guest can use the processor's supervisor mode. That means that the guest can execute privileged instructions and access privileged registers itself without trapping to the host. This gives excellent performance, but does mean that KVM cannot emulate a processor architecture other than the one that the hardware implements. This code assumes that the guest is running paravirtualized using the PAPR (Power Architecture Platform Requirements) interface, which is the interface that IBM's PowerVM hypervisor uses. That means that existing Linux distributions that run on IBM pSeries machines will also run under KVM without modification. In order to communicate the PAPR hypercalls to qemu, this adds a new KVM_EXIT_PAPR_HCALL exit code to include/linux/kvm.h. Currently the choice between book3s_hv support and book3s_pr support (i.e. the existing code, which runs the guest in user mode) has to be made at kernel configuration time, so a given kernel binary can only do one or the other. This new book3s_hv code doesn't support MMIO emulation at present. Since we are running paravirtualized guests, this isn't a serious restriction. With the guest running in supervisor mode, most exceptions go straight to the guest. We will never get data or instruction storage or segment interrupts, alignment interrupts, decrementer interrupts, program interrupts, single-step interrupts, etc., coming to the hypervisor from the guest. Therefore this introduces a new KVMTEST_NONHV macro for the exception entry path so that we don't have to do the KVM test on entry to those exception handlers. We do however get hypervisor decrementer, hypervisor data storage, hypervisor instruction storage, and hypervisor emulation assist interrupts, so we have to handle those. In hypervisor mode, real-mode accesses can access all of RAM, not just a limited amount. Therefore we put all the guest state in the vcpu.arch and use the shadow_vcpu in the PACA only for temporary scratch space. We allocate the vcpu with kzalloc rather than vzalloc, and we don't use anything in the kvmppc_vcpu_book3s struct, so we don't allocate it. We don't have a shared page with the guest, but we still need a kvm_vcpu_arch_shared struct to store the values of various registers, so we include one in the vcpu_arch struct. The POWER7 processor has a restriction that all threads in a core have to be in the same partition. MMU-on kernel code counts as a partition (partition 0), so we have to do a partition switch on every entry to and exit from the guest. At present we require the host and guest to run in single-thread mode because of this hardware restriction. This code allocates a hashed page table for the guest and initializes it with HPTEs for the guest's Virtual Real Memory Area (VRMA). We require that the guest memory is allocated using 16MB huge pages, in order to simplify the low-level memory management. This also means that we can get away without tracking paging activity in the host for now, since huge pages can't be paged or swapped. This also adds a few new exports needed by the book3s_hv code. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: PPC: e500: enable magic pageScott Wood
This is a shared page used for paravirtualization. It is always present in the guest kernel's effective address space at the address indicated by the hypercall that enables it. The physical address specified by the hypercall is not used, as e500 does not have real mode. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: MMU: Adjust shadow paging to work when SMEP=1 and CR0.WP=0Avi Kivity
When CR0.WP=0, we sometimes map user pages as kernel pages (to allow the kernel to write to them). Unfortunately this also allows the kernel to fetch from these pages, even if CR4.SMEP is set. Adjust for this by also setting NX on the spte in these circumstances. Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-12KVM: Fix KVM_ASSIGN_SET_MSIX_ENTRY documentationJan Kiszka
The documented behavior did not match the implemented one (which also never changed). Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-12KVM: Clarify KVM_ASSIGN_PCI_DEVICE documentationJan Kiszka
Neither host_irq nor the guest_msi struct are used anymore today. Tag the former, drop the latter to avoid confusion. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-12KVM: Fixup documentation section numberingJan Kiszka
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-07-12KVM: Document KVM_IOEVENTFDSasha Levin
Document KVM_IOEVENTFD that can be used to receive notifications of PIO/MMIO events without triggering an exit. Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-07-12KVM: nVMX: DocumentationNadav Har'El
This patch includes a brief introduction to the nested vmx feature in the Documentation/kvm directory. The document also includes a copy of the vmcs12 structure, as requested by Avi Kivity. [marcelo: move to Documentation/virtual/kvm] Signed-off-by: Nadav Har'El <nyh@il.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-07-12KVM: Document KVM_GET_LAPIC, KVM_SET_LAPIC ioctlAvi Kivity
Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-05-30lguest: remove support for VIRTIO_F_NOTIFY_ON_EMPTY.Rusty Russell
No virtio device does this any more, so no need to clutter lguest with it. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-30lguest: fix up compilation after moveRusty Russell
ed16648eb5b86917f0b90bdcdbc857202da72f90 "Move kvm, uml, and lguest subdirectories" broke the lguest example launcher. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-25um: add ucast ethernet transportNolan Leake
The ucast transport is similar to the mcast transport (and, in fact, shares most of its code), only it uses UDP unicast to move packets. Obviously this is only useful for point-to-point connections between virtual ethernet devices. Signed-off-by: Nolan Leake <nolan@cumulusnetworks.com> Signed-off-by: Richard Weinberger <richard@nod.at> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-23Merge branch 'kvm-updates/2.6.40' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.40' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (131 commits) KVM: MMU: Use ptep_user for cmpxchg_gpte() KVM: Fix kvm mmu_notifier initialization order KVM: Add documentation for KVM_CAP_NR_VCPUS KVM: make guest mode entry to be rcu quiescent state KVM: x86 emulator: Make jmp far emulation into a separate function KVM: x86 emulator: Rename emulate_grpX() to em_grpX() KVM: x86 emulator: Remove unused arg from emulate_pop() KVM: x86 emulator: Remove unused arg from writeback() KVM: x86 emulator: Remove unused arg from read_descriptor() KVM: x86 emulator: Remove unused arg from seg_override() KVM: Validate userspace_addr of memslot when registered KVM: MMU: Clean up gpte reading with copy_from_user() KVM: PPC: booke: add sregs support KVM: PPC: booke: save/restore VRSAVE (a.k.a. USPRG0) KVM: PPC: use ticks, not usecs, for exit timing KVM: PPC: fix exit accounting for SPRs, tlbwe, tlbsx KVM: PPC: e500: emulate SVR KVM: VMX: Cache vmcs segment fields KVM: x86 emulator: consolidate segment accessors KVM: VMX: Avoid reading %rip unnecessarily when handling exceptions ...
