path: root/Documentation/virtual
2011-05-30lguest: remove support for VIRTIO_F_NOTIFY_ON_EMPTY.Rusty Russell
No virtio device does this any more, so no need to clutter lguest with it. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-30lguest: fix up compilation after moveRusty Russell
ed16648eb5b86917f0b90bdcdbc857202da72f90 "Move kvm, uml, and lguest subdirectories" broke the lguest example launcher. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-25um: add ucast ethernet transportNolan Leake
The ucast transport is similar to the mcast transport (and, in fact, shares most of its code), only it uses UDP unicast to move packets. Obviously this is only useful for point-to-point connections between virtual ethernet devices. Signed-off-by: Nolan Leake <nolan@cumulusnetworks.com> Signed-off-by: Richard Weinberger <richard@nod.at> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-23Merge branch 'kvm-updates/2.6.40' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.40' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (131 commits) KVM: MMU: Use ptep_user for cmpxchg_gpte() KVM: Fix kvm mmu_notifier initialization order KVM: Add documentation for KVM_CAP_NR_VCPUS KVM: make guest mode entry to be rcu quiescent state KVM: x86 emulator: Make jmp far emulation into a separate function KVM: x86 emulator: Rename emulate_grpX() to em_grpX() KVM: x86 emulator: Remove unused arg from emulate_pop() KVM: x86 emulator: Remove unused arg from writeback() KVM: x86 emulator: Remove unused arg from read_descriptor() KVM: x86 emulator: Remove unused arg from seg_override() KVM: Validate userspace_addr of memslot when registered KVM: MMU: Clean up gpte reading with copy_from_user() KVM: PPC: booke: add sregs support KVM: PPC: booke: save/restore VRSAVE (a.k.a. USPRG0) KVM: PPC: use ticks, not usecs, for exit timing KVM: PPC: fix exit accounting for SPRs, tlbwe, tlbsx KVM: PPC: e500: emulate SVR KVM: VMX: Cache vmcs segment fields KVM: x86 emulator: consolidate segment accessors KVM: VMX: Avoid reading %rip unnecessarily when handling exceptions ...
2011-05-06Correct occurrences ofRob Landley
- Documentation/kvm/ to Documentation/virtual/kvm - Documentation/uml/ to Documentation/virtual/uml - Documentation/lguest/ to Documentation/virtual/lguest throughout the kernel source tree. Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com>
2011-05-06Add a 00-INDEX file to Documentation/virtualRob Landley
Remove uml from the top level 00-INDEX file. Signed-off-by: Rob Landley <rlandley@parallels.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com>
2011-05-06Move kvm, uml, and lguest subdirectories under a common "virtual" directory, ↵Rob Landley
I.E: cd Documentation mkdir virtual git mv kvm uml lguest virtual Signed-off-by: Rob Landley <rlandley@parallels.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com>
