path: root/Documentation/virtual
2013-11-04Merge branch 'kvm-ppc-queue' of git://github.com/agraf/linux-2.6 into queueGleb Natapov
Conflicts: arch/powerpc/include/asm/processor.h
2013-10-31Documentation/kvm: add a 00-INDEX fileRamkumar Ramachandra
Cc: Gleb Natapov <gleb@redhat.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> [Some editing. - Paolo] Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-10-30kvm: Add VFIO deviceAlex Williamson
So far we've succeeded at making KVM and VFIO mostly unaware of each other, but areas are cropping up where a connection beyond eventfds and irqfds needs to be made. This patch introduces a KVM-VFIO device that is meant to be a gateway for such interaction. The user creates the device and can add and remove VFIO groups to it via file descriptors. When a group is added, KVM verifies the group is valid and gets a reference to it via the VFIO external user interface. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-10-30kvm: Add KVM_GET_EMULATED_CPUIDBorislav Petkov
Add a kvm ioctl which states which system functionality kvm emulates. The format used is that of CPUID and we return the corresponding CPUID bits set for which we do emulate functionality. Make sure ->padding is being passed on clean from userspace so that we can use it for something in the future, after the ioctl gets cast in stone. s/kvm_dev_ioctl_get_supported_cpuid/kvm_dev_ioctl_get_cpuid/ while at it. Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-10-17KVM: PPC: Book3S HV: Support POWER6 compatibility mode on POWER7Paul Mackerras
This enables us to use the Processor Compatibility Register (PCR) on POWER7 to put the processor into architecture 2.05 compatibility mode when running a guest. In this mode the new instructions and registers that were introduced on POWER7 are disabled in user mode. This includes all the VSX facilities plus several other instructions such as ldbrx, stdbrx, popcntw, popcntd, etc. To select this mode, we have a new register accessible through the set/get_one_reg interface, called KVM_REG_PPC_ARCH_COMPAT. Setting this to zero gives the full set of capabilities of the processor. Setting it to one of the "logical" PVR values defined in PAPR puts the vcpu into the compatibility mode for the corresponding architecture level. The supported values are: 0x0f000002 Architecture 2.05 (POWER6) 0x0f000003 Architecture 2.06 (POWER7) 0x0f100003 Architecture 2.06+ (POWER7+) Since the PCR is per-core, the architecture compatibility level and the corresponding PCR value are stored in the struct kvmppc_vcore, and are therefore shared between all vcpus in a virtual core. Signed-off-by: Paul Mackerras <paulus@samba.org> [agraf: squash in fix to add missing break statements and documentation] Signed-off-by: Alexander Graf <agraf@suse.de>
2013-10-17KVM: PPC: Book3S HV: Add support for guest Program Priority RegisterPaul Mackerras
POWER7 and later IBM server processors have a register called the Program Priority Register (PPR), which controls the priority of each hardware CPU SMT thread, and affects how fast it runs compared to other SMT threads. This priority can be controlled by writing to the PPR or by use of a set of instructions of the form or rN,rN,rN which are otherwise no-ops but have been defined to set the priority to particular levels. This adds code to context switch the PPR when entering and exiting guests and to make the PPR value accessible through the SET/GET_ONE_REG interface. When entering the guest, we set the PPR as late as possible, because if we are setting a low thread priority it will make the code run slowly from that point on. Similarly, the first-level interrupt handlers save the PPR value in the PACA very early on, and set the thread priority to the medium level, so that the interrupt handling code runs at a reasonable speed. Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-10-17KVM: PPC: Book3S HV: Store LPCR value for each virtual corePaul Mackerras
This adds the ability to have a separate LPCR (Logical Partitioning Control Register) value relating to a guest for each virtual core, rather than only having a single value for the whole VM. This corresponds to what real POWER hardware does, where there is a LPCR per CPU thread but most of the fields are required to have the same value on all active threads in a core. The per-virtual-core LPCR can be read and written using the GET/SET_ONE_REG interface. Userspace can can only modify the following fields of the LPCR value: DPFD Default prefetch depth ILE Interrupt little-endian TC Translation control (secondary HPT hash group search disable) We still maintain a per-VM default LPCR value in kvm->arch.lpcr, which contains bits relating to memory management, i.e. the Virtualized Partition Memory (VPM) bits and the bits relating to guest real mode. When this default value is updated, the update needs to be propagated to the per-vcore values, so we add a kvmppc_update_lpcr() helper to do that. Signed-off-by: Paul Mackerras <paulus@samba.org> [agraf: fix whitespace] Signed-off-by: Alexander Graf <agraf@suse.de>
2013-10-17KVM: PPC: Book3S: Add GET/SET_ONE_REG interface for VRSAVEPaul Mackerras
The VRSAVE register value for a vcpu is accessible through the GET/SET_SREGS interface for Book E processors, but not for Book 3S processors. In order to make this accessible for Book 3S processors, this adds a new register identifier for GET/SET_ONE_REG, and adds the code to implement it. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-10-17KVM: PPC: Book3S HV: Implement timebase offset for guestsPaul Mackerras
This allows guests to have a different timebase origin from the host. This is needed for migration, where a guest can migrate from one host to another and the two hosts might have a different timebase origin. However, the timebase seen by the guest must not go backwards, and should go forwards only by a small amount corresponding to the time taken for the migration. Therefore this provides a new per-vcpu value accessed via the one_reg interface using the new KVM_REG_PPC_TB_OFFSET identifier. This value defaults to 0 and is not modified by KVM. On entering the guest, this value is added onto the timebase, and on exiting the guest, it is subtracted from the timebase. This is only supported for recent POWER hardware which has the TBU40 (timebase upper 40 bits) register. Writing to the TBU40 register only alters the upper 40 bits of the timebase, leaving the lower 24 bits unchanged. This provides a way to modify the timebase for guest migration without disturbing the synchronization of the timebase registers across CPU cores. The kernel rounds up the value given to a multiple of 2^24. Timebase values stored in KVM structures (struct kvm_vcpu, struct kvmppc_vcore, etc.) are stored as host timebase values. The timebase values in the dispatch trace log need to be guest timebase values, however, since that is read directly by the guest. This moves the setting of vcpu->arch.dec_expires on guest exit to a point after we have restored the host timebase so that vcpu->arch.dec_expires is a host timebase value. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-10-17KVM: PPC: Book3S HV: Reserve POWER8 space in get/set_one_regMichael Neuling
This reserves space in get/set_one_reg ioctl for the extra guest state needed for POWER8. It doesn't implement these at all, it just reserves them so that the ABI is defined now. A few things to note here: - This add *a lot* state for transactional memory. TM suspend mode, this is unavoidable, you can't simply roll back all transactions and store only the checkpointed state. I've added this all to get/set_one_reg (including GPRs) rather than creating a new ioctl which returns a struct kvm_regs like KVM_GET_REGS does. This means we if we need to extract the TM state, we are going to need a bucket load of IOCTLs. Hopefully most of the time this will not be needed as we can look at the MSR to see if TM is active and only grab them when needed. If this becomes a bottle neck in future we can add another ioctl to grab all this state in one go. - The TM state is offset by 0x80000000. - For TM, I've done away with VMX and FP and created a single 64x128 bit VSX register space. - I've left a space of 1 (at 0x9c) since Paulus needs to add a value which applies to POWER7 as well. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-10-16Merge tag 'kvm-arm-for-3.13-1' of ↵Gleb Natapov
git://git.linaro.org/people/cdall/linux-kvm-arm into next Updates for KVM/ARM including cpu=host and Cortex-A7 support
2013-10-15KVM: ARM: Remove non-ASCII space charactersChristoffer Dall
Some strange character leaped into the documentation, which makes git-send-email behave quite strangely. Get rid of this before it bites anyone else. Cc: Anup Patel <anup.patel@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-10-02KVM: Add documentation for KVM_ARM_PREFERRED_TARGET ioctlAnup Patel
To implement CPU=Host we have added KVM_ARM_PREFERRED_TARGET vm ioctl which provides information to user space required for creating VCPU matching underlying Host. This patch adds info related to this new KVM_ARM_PREFERRED_TARGET vm ioctl in the KVM API documentation. Signed-off-by: Anup Patel <anup.patel@linaro.org> Signed-off-by: Pranavkumar Sawargaonkar <pranavkumar@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-09-30KVM: Convert kvm_lock back to non-raw spinlockPaolo Bonzini
In commit e935b8372cf8 ("KVM: Convert kvm_lock to raw_spinlock"), the kvm_lock was made a raw lock. However, the kvm mmu_shrink() function tries to grab the (non-raw) mmu_lock within the scope of the raw locked kvm_lock being held. This leads to the following: BUG: sleeping function called from invalid context at kernel/rtmutex.c:659 in_atomic(): 1, irqs_disabled(): 0, pid: 55, name: kswapd0 Preemption disabled at:[<ffffffffa0376eac>] mmu_shrink+0x5c/0x1b0 [kvm] Pid: 55, comm: kswapd0 Not tainted 3.4.34_preempt-rt Call Trace: [<ffffffff8106f2ad>] __might_sleep+0xfd/0x160 [<ffffffff817d8d64>] rt_spin_lock+0x24/0x50 [<ffffffffa0376f3c>] mmu_shrink+0xec/0x1b0 [kvm] [<ffffffff8111455d>] shrink_slab+0x17d/0x3a0 [<ffffffff81151f00>] ? mem_cgroup_iter+0x130/0x260 [<ffffffff8111824a>] balance_pgdat+0x54a/0x730 [<ffffffff8111fe47>] ? set_pgdat_percpu_threshold+0xa7/0xd0 [<ffffffff811185bf>] kswapd+0x18f/0x490 [<ffffffff81070961>] ? get_parent_ip+0x11/0x50 [<ffffffff81061970>] ? __init_waitqueue_head+0x50/0x50 [<ffffffff81118430>] ? balance_pgdat+0x730/0x730 [<ffffffff81060d2b>] kthread+0xdb/0xe0 [<ffffffff8106e122>] ? finish_task_switch+0x52/0x100 [<ffffffff817e1e94>] kernel_thread_helper+0x4/0x10 [<ffffffff81060c50>] ? __init_kthread_worker+0x After the previous patch, kvm_lock need not be a raw spinlock anymore, so change it back. Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: kvm@vger.kernel.org Cc: gleb@redhat.com Cc: jan.kiszka@siemens.com Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-09-30KVM: protect kvm_usage_count with its own spinlockPaolo Bonzini
The VM list need not be protected by a raw spinlock. Separate the two so that kvm_lock can be made non-raw. Cc: kvm@vger.kernel.org Cc: gleb@redhat.com Cc: jan.kiszka@siemens.com Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-09-24Documentation/kvm: Update cpuid documentation for steal time and pv eoiRaghavendra K T
Thanks Michael S Tsirkin for rewriting the description and suggestions. Signed-off-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-09-24KVM: Add documentation for kvm->srcu lockThomas Huth
This patch documents the kvm->srcu lock (using the information from a mail which has been posted by Marcelo Tosatti to the kvm mailing list some months ago, see the following URL for details: http://www.mail-archive.com/kvm@vger.kernel.org/msg90040.html ) Signed-off-by: Thomas Huth <thuth@linux.vnet.ibm.com> Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-09-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "The usual trivial updates all over the tree -- mostly typo fixes and documentation updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (52 commits) doc: Documentation/cputopology.txt fix typo treewide: Convert retrun typos to return Fix comment typo for init_cma_reserved_pageblock Documentation/trace: Correcting and extending tracepoint documentation mm/hotplug: fix a typo in Documentation/memory-hotplug.txt power: Documentation: Update s2ram link doc: fix a typo in Documentation/00-INDEX Documentation/printk-formats.txt: No casts needed for u64/s64 doc: Fix typo "is is" in Documentations treewide: Fix printks with 0x%# zram: doc fixes Documentation/kmemcheck: update kmemcheck documentation doc: documentation/hwspinlock.txt fix typo PM / Hibernate: add section for resume options doc: filesystems : Fix typo in Documentations/filesystems scsi/megaraid fixed several typos in comments ppc: init_32: Fix error typo "CONFIG_START_KERNEL" treewide: Add __GFP_NOWARN to k.alloc calls with v.alloc fallbacks page_isolation: Fix a comment typo in test_pages_isolated() doc: fix a typo about irq affinity ...
2013-08-26Documentation/kvm : Add documentation on Hypercalls and features used for PV ↵Raghavendra K T
spinlock KVM_HC_KICK_CPU hypercall added to wakeup halted vcpu in paravirtual spinlock enabled guest. KVM_FEATURE_PV_UNHALT enables guest to check whether pv spinlock can be enabled in guest. Thanks Vatsa for rewriting KVM_HC_KICK_CPU Cc: Rob Landley <rob@landley.net> Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Acked-by: Gleb Natapov <gleb@redhat.com> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-07-25doc: Fix typo in doucmentationsMasanari Iida
Correct typo (double words) in documentations. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "The usual stuff from trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) treewide: relase -> release Documentation/cgroups/memory.txt: fix stat file documentation sysctl/net.txt: delete reference to obsolete 2.4.x kernel spinlock_api_smp.h: fix preprocessor comments treewide: Fix typo in printk doc: device tree: clarify stuff in usage-model.txt. open firmware: "/aliasas" -> "/aliases" md: bcache: Fixed a typo with the word 'arithmetic' irq/generic-chip: fix a few kernel-doc entries frv: Convert use of typedef ctl_table to struct ctl_table sgi: xpc: Convert use of typedef ctl_table to struct ctl_table doc: clk: Fix incorrect wording Documentation/arm/IXP4xx fix a typo Documentation/networking/ieee802154 fix a typo Documentation/DocBook/media/v4l fix a typo Documentation/video4linux/si476x.txt fix a typo Documentation/virtual/kvm/api.txt fix a typo Documentation/early-userspace/README fix a typo Documentation/video4linux/soc-camera.txt fix a typo lguest: fix CONFIG_PAE -> CONFIG_x86_PAE in comment ...
2013-07-03Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM fixes from Paolo Bonzini: "On the x86 side, there are some optimizations and documentation updates. The big ARM/KVM change for 3.11, support for AArch64, will come through Catalin Marinas's tree. s390 and PPC have misc cleanups and bugfixes" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (87 commits) KVM: PPC: Ignore PIR writes KVM: PPC: Book3S PR: Invalidate SLB entries properly KVM: PPC: Book3S PR: Allow guest to use 1TB segments KVM: PPC: Book3S PR: Don't keep scanning HPTEG after we find a match KVM: PPC: Book3S PR: Fix invalidation of SLB entry 0 on guest entry KVM: PPC: Book3S PR: Fix proto-VSID calculations KVM: PPC: Guard doorbell exception with CONFIG_PPC_DOORBELL KVM: Fix RTC interrupt coalescing tracking kvm: Add a tracepoint write_tsc_offset KVM: MMU: Inform users of mmio generation wraparound KVM: MMU: document fast invalidate all mmio sptes KVM: MMU: document fast invalidate all pages KVM: MMU: document fast page fault KVM: MMU: document mmio page fault KVM: MMU: document write_flooding_count KVM: MMU: document clear_spte_count KVM: MMU: drop kvm_mmu_zap_mmio_sptes KVM: MMU: init kvm generation close to mmio wrap-around value KVM: MMU: add tracepoint for check_mmio_spte KVM: MMU: fast invalidate all mmio sptes ...
2013-07-03Merge tag 'arm64-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 Pull ARM64 updates from Catalin Marinas: "Main features: - KVM and Xen ports to AArch64 - Hugetlbfs and transparent huge pages support for arm64 - Applied Micro X-Gene Kconfig entry and dts file - Cache flushing improvements For arm64 huge pages support, there are x86 changes moving part of arch/x86/mm/hugetlbpage.c into mm/hugetlb.c to be re-used by arm64" * tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64: (66 commits) arm64: Add initial DTS for APM X-Gene Storm SOC and APM Mustang board arm64: Add defines for APM ARMv8 implementation arm64: Enable APM X-Gene SOC family in the defconfig arm64: Add Kconfig option for APM X-Gene SOC family arm64/Makefile: provide vdso_install target ARM64: mm: THP support. ARM64: mm: Raise MAX_ORDER for 64KB pages and THP. ARM64: mm: HugeTLB support. ARM64: mm: Move PTE_PROT_NONE bit. ARM64: mm: Make PAGE_NONE pages read only and no-execute. ARM64: mm: Restore memblock limit when map_mem finished. mm: thp: Correct the HPAGE_PMD_ORDER check. x86: mm: Remove general hugetlb code from x86. mm: hugetlb: Copy general hugetlb code from x86 to mm. x86: mm: Remove x86 version of huge_pmd_share. mm: hugetlb: Copy huge_pmd_share from x86 to mm. arm64: KVM: document kernel object mappings in HYP arm64: KVM: MAINTAINERS update arm64: KVM: userspace API documentation arm64: KVM: enable initialization of a 32bit vcpu ...
2013-06-27KVM: MMU: document fast invalidate all mmio sptesXiao Guangrong
Document it to Documentation/virtual/kvm/mmu.txt Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-06-27KVM: MMU: document fast invalidate all pagesXiao Guangrong
2013-06-27KVM: MMU: document fast page faultXiao Guangrong
Document fast page fault to Documentation/virtual/kvm/mmu.txt Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-06-27KVM: MMU: document mmio page faultXiao Guangrong
2013-06-27KVM: MMU: document write_flooding_countXiao Guangrong
Document write_flooding_count to Documentation/virtual/kvm/mmu.txt Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-06-27KVM: MMU: document clear_spte_countXiao Guangrong
2013-06-19sched: Rename sched.c as sched/core.c in comments and DocumentationViresh Kumar
Most of the stuff from kernel/sched.c was moved to kernel/sched/core.c long time back and the comments/Documentation never got updated. I figured it out when I was going through sched-domains.txt and so thought of fixing it globally. I haven't crossed check if the stuff that is referenced in sched/core.c by all these files is still present and hasn't changed as that wasn't the motive behind this patch. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/cdff76a265326ab8d71922a1db5be599f20aad45.1370329560.git.viresh.kumar@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-06-19KVM: MMU: update the documentation for reverse mapping of parent_pteXiao Guangrong
Update the document to match the current reverse mapping of parent_pte Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-06-19kvm api doc: fix section numbersAlexey Kardashevskiy
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-06-12arm64: KVM: userspace API documentationMarc Zyngier
Unsurprisingly, the arm64 userspace API is extremely similar to the 32bit one, the only significant difference being the ONE_REG register mapping. Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2013-06-05Documentation/virtual/kvm/api.txt fix a typoStefan Huber
Corrected the word appropariate to appropriate. Signed-off-by: Stefan Huber <steffhip@googlemail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-05-28doc: fix misspellings with 'codespell' toolAnatol Pomozov
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-05-05Merge tag 'kvm-3.10-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm updates from Gleb Natapov: "Highlights of the updates are: general: - new emulated device API - legacy device assignment is now optional - irqfd interface is more generic and can be shared between arches x86: - VMCS shadow support and other nested VMX improvements - APIC virtualization and Posted Interrupt hardware support - Optimize mmio spte zapping ppc: - BookE: in-kernel MPIC emulation with irqfd support - Book3S: in-kernel XICS emulation (incomplete) - Book3S: HV: migration fixes - BookE: more debug support preparation - BookE: e6500 support ARM: - reworking of Hyp idmaps s390: - ioeventfd for virtio-ccw And many other bug fixes, cleanups and improvements" * tag 'kvm-3.10-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (204 commits) kvm: Add compat_ioctl for device control API KVM: x86: Account for failing enable_irq_window for NMI window request KVM: PPC: Book3S: Add API for in-kernel XICS emulation kvm/ppc/mpic: fix missing unlock in set_base_addr() kvm/ppc: Hold srcu lock when calling kvm_io_bus_read/write kvm/ppc/mpic: remove users kvm/ppc/mpic: fix mmio region lists when multiple guests used kvm/ppc/mpic: remove default routes from documentation kvm: KVM_CAP_IOMMU only available with device assignment ARM: KVM: iterate over all CPUs for CPU compatibility check KVM: ARM: Fix spelling in error message ARM: KVM: define KVM_ARM_MAX_VCPUS unconditionally KVM: ARM: Fix API documentation for ONE_REG encoding ARM: KVM: promote vfp_host pointer to generic host cpu context ARM: KVM: add architecture specific hook for capabilities ARM: KVM: perform HYP initilization for hotplugged CPUs ARM: KVM: switch to a dual-step HYP init code ARM: KVM: rework HYP page table freeing ARM: KVM: enforce maximum size for identity mapped code ARM: KVM: move to a KVM provided HYP idmap ...
2013-05-03Merge branch 'kvm-arm-for-3.10' of git://github.com/columbia/linux-kvm-arm ↵Marcelo Tosatti
into queue * 'kvm-arm-for-3.10' of git://github.com/columbia/linux-kvm-arm: ARM: KVM: iterate over all CPUs for CPU compatibility check KVM: ARM: Fix spelling in error message ARM: KVM: define KVM_ARM_MAX_VCPUS unconditionally KVM: ARM: Fix API documentation for ONE_REG encoding ARM: KVM: promote vfp_host pointer to generic host cpu context ARM: KVM: add architecture specific hook for capabilities ARM: KVM: perform HYP initilization for hotplugged CPUs ARM: KVM: switch to a dual-step HYP init code ARM: KVM: rework HYP page table freeing ARM: KVM: enforce maximum size for identity mapped code ARM: KVM: move to a KVM provided HYP idmap ARM: KVM: fix HYP mapping limitations around zero ARM: KVM: simplify HYP mapping population ARM: KVM: arch_timer: use symbolic constants ARM: KVM: add support for minimal host vs guest profiling
2013-05-02KVM: PPC: Book3S: Add API for in-kernel XICS emulationPaul Mackerras
This adds the API for userspace to instantiate an XICS device in a VM and connect VCPUs to it. The API consists of a new device type for the KVM_CREATE_DEVICE ioctl, a new capability KVM_CAP_IRQ_XICS, which functions similarly to KVM_CAP_IRQ_MPIC, and the KVM_IRQ_LINE ioctl, which is used to assert and deassert interrupt inputs of the XICS. The XICS device has one attribute group, KVM_DEV_XICS_GRP_SOURCES. Each attribute within this group corresponds to the state of one interrupt source. The attribute number is the same as the interrupt source number. This does not support irq routing or irqfd yet. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-30kvm/ppc/mpic: remove default routes from documentationScott Wood
The default routes were removed from the code during patchset respinning, but were not removed from the documentation. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-28KVM: ARM: Fix API documentation for ONE_REG encodingChristoffer Dall
Unless I'm mistaken, the size field was encoded 4 bits off and a wrong value was used for 64-bit FP registers. Signed-off-by: Christoffer Dall <cdall@cs.columbia.edu>
2013-04-26KVM: PPC: Book3S: Facilities to save/restore XICS presentation ctrler statePaul Mackerras
This adds the ability for userspace to save and restore the state of the XICS interrupt presentation controllers (ICPs) via the KVM_GET/SET_ONE_REG interface. Since there is one ICP per vcpu, we simply define a new 64-bit register in the ONE_REG space for the ICP state. The state includes the CPU priority setting, the pending IPI priority, and the priority and source number of any pending external interrupt. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: Book3S: Add infrastructure to implement kernel-side RTAS callsMichael Ellerman
For pseries machine emulation, in order to move the interrupt controller code to the kernel, we need to intercept some RTAS calls in the kernel itself. This adds an infrastructure to allow in-kernel handlers to be registered for RTAS services by name. A new ioctl, KVM_PPC_RTAS_DEFINE_TOKEN, then allows userspace to associate token values with those service names. Then, when the guest requests an RTAS service with one of those token values, it will be handled by the relevant in-kernel handler rather than being passed up to userspace as at present. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org> [agraf: fix warning] Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: Support irq routing and irqfd for in-kernel MPICAlexander Graf
Now that all the irq routing and irqfd pieces are generic, we can expose real irqchip support to all of KVM's internal helpers. This allows us to use irqfd with the in-kernel MPIC. Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26kvm/ppc/mpic: add KVM_CAP_IRQ_MPICScott Wood
Enabling this capability connects the vcpu to the designated in-kernel MPIC. Using explicit connections between vcpus and irqchips allows for flexibility, but the main benefit at the moment is that it simplifies the code -- KVM doesn't need vm-global state to remember which MPIC object is associated with this vm, and it doesn't need to care about ordering between irqchip creation and vcpu creation. Signed-off-by: Scott Wood <scottwood@freescale.com> [agraf: add stub functions for kvmppc_mpic_{dis,}connect_vcpu] Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26kvm/ppc/mpic: in-kernel MPIC emulationScott Wood
Hook the MPIC code up to the KVM interfaces, add locking, etc. Signed-off-by: Scott Wood <scottwood@freescale.com> [agraf: add stub function for kvmppc_mpic_set_epr, non-booke, 64bit] Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26kvm: add device control APIScott Wood
Currently, devices that are emulated inside KVM are configured in a hardcoded manner based on an assumption that any given architecture only has one way to do it. If there's any need to access device state, it is done through inflexible one-purpose-only IOCTLs (e.g. KVM_GET/SET_LAPIC). Defining new IOCTLs for every little thing is cumbersome and depletes a limited numberspace. This API provides a mechanism to instantiate a device of a certain type, returning an ID that can be used to set/get attributes of the device. Attributes may include configuration parameters (e.g. register base address), device state, operational commands, etc. It is similar to the ONE_REG API, except that it acts on devices rather than vcpus. Both device types and individual attributes can be tested without having to create the device or get/set the attribute, without the need for separately managing enumerated capabilities. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: e500: Add support for EPTCFG registerMihai Caraman
EPTCFG register defined by E.PT is accessed unconditionally by Linux guests in the presence of MAV 2.0. Emulate it now. Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: e500: Add support for TLBnPS registersMihai Caraman
Add support for TLBnPS registers available in MMU Architecture Version (MAV) 2.0. Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: e500: Expose MMU registers via ONE_REGMihai Caraman
MMU registers were exposed to user-space using sregs interface. Add them to ONE_REG interface using kvmppc_get_one_reg/kvmppc_set_one_reg delegation mechanism. Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-03-22KVM: PPC: Added one_reg interface for timer registersBharat Bhushan
If userspace wants to change some specific bits of TSR (timer status register) then it uses GET/SET_SREGS ioctl interface. So the steps will be: i) user-space will make get ioctl, ii) change TSR in userspace iii) then make set ioctl. It can happen that TSR gets changed by kernel after step i) and before step iii). To avoid this we have added below one_reg ioctls for oring and clearing specific bits in TSR. This patch adds one registerface for: 1) setting specific bit in TSR (timer status register) 2) clearing specific bit in TSR (timer status register) 3) setting/getting the TCR register. There are cases where we want to only change TCR and not TSR. Although we can uses SREGS without KVM_SREGS_E_UPDATE_TSR flag but I think one reg is better. I am open if someone feels we should use SREGS only here. 4) getting/setting TSR register Signed-off-by: Bharat Bhushan <bharat.bhushan@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
