[ Upstream commit 844a5fe219cf472060315971e15cbf97674a3324 ]
Yes, all of these are needed. :) This is admittedly a bit odd, but
kvm-unit-tests access.flat tests this if you run it with "-cpu host"
and of course ept=0.
KVM runs the guest with CR0.WP=1, so it must handle supervisor writes
specially when pte.u=1/pte.w=0/CR0.WP=0. Such writes cause a fault
when U=1 and W=0 in the SPTE, but they must succeed because CR0.WP=0.
When KVM gets the fault, it sets U=0 and W=1 in the shadow PTE and
restarts execution. This will still cause a user write to fault, while
supervisor writes will succeed. User reads will fault spuriously now,
and KVM will then flip U and W again in the SPTE (U=1, W=0). User reads
will be enabled and supervisor writes disabled, going back to the
originary situation where supervisor writes fault spuriously.
When SMEP is in effect, however, U=0 will enable kernel execution of
this page. To avoid this, KVM also sets NX=1 in the shadow PTE together
with U=0. If the guest has not enabled NX, the result is a continuous
stream of page faults due to the NX bit being reserved.
The fix is to force EFER.NX=1 even if the CPU is taking care of the EFER
switch. (All machines with SMEP have the CPU_LOAD_IA32_EFER vm-entry
control, so they do not use user-return notifiers for EFER---if they did,
EFER.NX would be forced to the same value as the host).
There is another bug in the reserved bit check, which I've split to a
separate patch for easier application to stable kernels.
Cc: stable@vger.kernel.org
Reviewed-by: Xiao Guangrong <guangrong.xiao@linux.intel.com>
Fixes: f6577a5fa15d82217ca73c74cd2dcbc0f6c781dd
KVM may turn a user page to a kernel page when kernel writes a readonly
user page if CR0.WP = 1. This shadow page entry will be reused after
SMAP is enabled so that kernel is allowed to access this user page
Fix it by setting SMAP && !CR0.WP into shadow page's role and reset mmu
once CR4.SMAP is updated
Signed-off-by: Xiao Guangrong <guangrong.xiao@linux.intel.com>
Some PowerNV systems include a hardware random-number generator.
This HWRNG is present on POWER7+ and POWER8 chips and is capable of
generating one 64-bit random number every microsecond. The random
numbers are produced by sampling a set of 64 unstable high-frequency
oscillators and are almost completely entropic.
PAPR defines an H_RANDOM hypercall which guests can use to obtain one
64-bit random sample from the HWRNG. This adds a real-mode
implementation of the H_RANDOM hypercall. This hypercall was
implemented in real mode because the latency of reading the HWRNG is
generally small compared to the latency of a guest exit and entry for
all the threads in the same virtual core.
Userspace can detect the presence of the HWRNG and the H_RANDOM
implementation by querying the KVM_CAP_PPC_HWRNG capability. The
H_RANDOM hypercall implementation will only be invoked when the guest
does an H_RANDOM hypercall if userspace first enables the in-kernel
H_RANDOM implementation using the KVM_CAP_PPC_ENABLE_HCALL capability.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux into HEAD
Features and fixes for 4.1 (kvm/next)
1. Assorted changes
1.1 allow more feature bits for the guest
1.2 Store breaking event address on program interrupts
2. Interrupt handling rework
2.1 Fix copy_to_user while holding a spinlock (cc stable)
2.2 Rework floating interrupts to follow the priorities
2.3 Allow to inject all local interrupts via new ioctl
2.4 allow to get/set the full local irq state, e.g. for migration
and introspection
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into 'kvm-next'
KVM/ARM changes for v4.1:
- fixes for live migration
- irqfd support
- kvm-io-bus & vgic rework to enable ioeventfd
- page ageing for stage-2 translation
- various cleanups
This patch adds support to migrate vcpu interrupts. Two new vcpu ioctls
are added which get/set the complete status of pending interrupts in one
go. The ioctls are marked as available with the new capability
KVM_CAP_S390_IRQ_STATE.
We can not use a ONEREG, as the number of pending local interrupts is not
constant and depends on the number of CPUs.
To retrieve the interrupt state we add an ioctl KVM_S390_GET_IRQ_STATE.
Its input parameter is a pointer to a struct kvm_s390_irq_state which
has a buffer and length. For all currently pending interrupts, we copy
a struct kvm_s390_irq into the buffer and pass it to userspace.
To store interrupt state into a buffer provided by userspace, we add an
ioctl KVM_S390_SET_IRQ_STATE. It passes a struct kvm_s390_irq_state into
the kernel and injects all interrupts contained in the buffer.
Signed-off-by: Jens Freimann <jfrei@linux.vnet.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
We have introduced struct kvm_s390_irq a while ago which allows to
inject all kinds of interrupts as defined in the Principles of
Operation.
Add ioctl to inject interrupts with the extended struct kvm_s390_irq
This fixes a bug introduced with commit c05c4186bbe4 ("KVM: s390:
add floating irq controller").
get_all_floating_irqs() does copy_to_user() while holding
a spin lock. Let's fix this by filling a temporary buffer
first and copy it to userspace after giving up the lock.
Cc: <stable@vger.kernel.org> # 3.18+: 69a8d4562638 KVM: s390: no need to hold...
Reviewed-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Now that the code is in place for KVM to support MIPS SIMD Architecutre
(MSA) in MIPS guests, wire up the new KVM_CAP_MIPS_MSA capability.
For backwards compatibility, the capability must be explicitly enabled
in order to detect or make use of MSA from the guest.
The capability is not supported if the hardware supports MSA vector
partitioning, since the extra support cannot be tested yet and it
extends the state that the userland program would have to save.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: linux-mips@linux-mips.org
Cc: kvm@vger.kernel.org
Cc: linux-api@vger.kernel.org
Cc: linux-doc@vger.kernel.org
Add KVM register numbers for the MIPS SIMD Architecture (MSA) registers,
and implement access to them with the KVM_GET_ONE_REG / KVM_SET_ONE_REG
ioctls when the MSA capability is enabled (exposed in a later patch) and
present in the guest according to its Config3.MSAP bit.
The MSA vector registers use the same register numbers as the FPU
registers except with a different size (128bits). Since MSA depends on
Status.FR=1, these registers are inaccessible when Status.FR=0. These
registers are returned as a single native endian 128bit value, rather
than least significant half first with each 64-bit half native endian as
the kernel uses internally.
Cc: Paul Burton <paul.burton@imgtec.com>
Now that the code is in place for KVM to support FPU in MIPS KVM guests,
wire up the new KVM_CAP_MIPS_FPU capability.
in order to detect or make use of the FPU from the guest.
Add KVM register numbers for the MIPS FPU registers, and implement
access to them with the KVM_GET_ONE_REG / KVM_SET_ONE_REG ioctls when
the FPU capability is enabled (exposed in a later patch) and present in
the guest according to its Config1.FP bit.
The registers are accessible in the current mode of the guest, with each
sized access showing what the guest would see with an equivalent access,
and like the architecture they may become UNPREDICTABLE if the FR mode
is changed. When FR=0, odd doubles are inaccessible as they do not exist
in that mode.
Add Config4 and Config5 co-processor 0 registers, and add capability to
write the Config1, Config3, Config4, and Config5 registers using the KVM
API.
Only supported bits can be written, to minimise the chances of the guest
being given a configuration from e.g. QEMU that is inconsistent with
that being emulated, and as such the handling is in trap_emul.c as it
may need to be different for VZ. Currently the only modification
permitted is to make Config4 and Config5 exist via the M bits, but other
bits will be added for FPU and MSA support in future patches.
Care should be taken by userland not to change bits without fully
handling the possible extra state that may then exist and which the
guest may begin to use and depend on.
Implement access to the guest Processor Identification CP0 register
using the KVM_GET_ONE_REG and KVM_SET_ONE_REG ioctls. This allows the
owning process to modify and read back the value that is exposed to the
guest in this register.
Provide the KVM_S390_GET_SKEYS and KVM_S390_SET_SKEYS ioctl which can be used
to get/set guest storage keys. This functionality is needed for live migration
of s390 guests that use storage keys.
Signed-off-by: Jason J. Herne <jjherne@linux.vnet.ibm.com>
The Store System Information (STSI) instruction currently collects all
information it relays to the caller in the kernel. Some information,
however, is only available in user space. An example of this is the
guest name: The kernel always sets "KVMGuest", but user space knows the
actual guest name.
This patch introduces a new exit, KVM_EXIT_S390_STSI, guarded by a
capability that can be enabled by user space if it wants to be able to
insert such data. User space will be provided with the target buffer
and the requested STSI function code.
Reviewed-by: Eric Farman <farman@linux.vnet.ibm.com>
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Ekaterina Tumanova <tumanova@linux.vnet.ibm.com>
On s390, we've got to make sure to hold the IPTE lock while accessing
logical memory. So let's add an ioctl for reading and writing logical
memory to provide this feature for userspace, too.
The maximum transfer size of this call is limited to 64kB to prevent
that the guest can trigger huge copy_from/to_user transfers. QEMU
currently only requests up to one or two pages so far, so 16*4kB seems
to be a reasonable limit here.
Signed-off-by: Thomas Huth <thuth@linux.vnet.ibm.com>
To cleanly restore an SMP VM we need to ensure that the current pause
state of each vcpu is correctly recorded. Things could get confused if
the CPU starts running after migration restore completes when it was
paused before it state was captured.
We use the existing KVM_GET/SET_MP_STATE ioctl to do this. The arm/arm64
interface is a lot simpler as the only valid states are
KVM_MP_STATE_RUNNABLE and KVM_MP_STATE_STOPPED.
Signed-off-by: Alex Bennée <alex.bennee@linaro.org>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
This patch enables irqfd on arm/arm64.
Both irqfd and resamplefd are supported. Injection is implemented
in vgic.c without routing.
This patch enables CONFIG_HAVE_KVM_EVENTFD and CONFIG_HAVE_KVM_IRQFD.
KVM_CAP_IRQFD is now advertised. KVM_CAP_IRQFD_RESAMPLE capability
automatically is advertised as soon as CONFIG_HAVE_KVM_IRQFD is set.
Irqfd injection is restricted to SPI. The rationale behind not
supporting PPI irqfd injection is that any device using a PPI would
be a private-to-the-CPU device (timer for instance), so its state
would have to be context-switched along with the VCPU and would
require in-kernel wiring anyhow. It is not a relevant use case for
irqfds.
Signed-off-by: Eric Auger <eric.auger@linaro.org>
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Define and allocate space for both the host and guest views of
the vector registers for a given vcpu. The 32 vector registers
occupy 128 bits each (512 bytes total), but architecturally are
paired with 512 additional bytes of reserved space for future
expansion.
The kvm_sync_regs structs containing the registers are union'ed
with 1024 bytes of padding in the common kvm_run struct. The
addition of 1024 bytes of new register information clearly exceeds
the existing union, so an expansion of that padding is required.
When changing environments, we need to appropriately save and
restore the vector registers viewed by both the host and guest,
into and out of the sync_regs space.
The floating point registers overlay the upper half of vector
registers 0-15, so there's a bit of data duplication here that
needs to be carefully avoided.
Signed-off-by: Eric Farman <farman@linux.vnet.ibm.com>
Reviewed-by: Thomas Huth <thuth@linux.vnet.ibm.com>
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio updates from Rusty Russell:
"OK, this has the big virtio 1.0 implementation, as specified by OASIS.
On top of tht is the major rework of lguest, to use PCI and virtio
1.0, to double-check the implementation.
Then comes the inevitable fixes and cleanups from that work"
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (80 commits)
virtio: don't set VIRTIO_CONFIG_S_DRIVER_OK twice.
virtio_net: unconditionally define struct virtio_net_hdr_v1.
tools/lguest: don't use legacy definitions for net device in example launcher.
virtio: Don't expose legacy net features when VIRTIO_NET_NO_LEGACY defined.
tools/lguest: use common error macros in the example launcher.
tools/lguest: give virtqueues names for better error messages
tools/lguest: more documentation and checking of virtio 1.0 compliance.
lguest: don't look in console features to find emerg_wr.
tools/lguest: don't start devices until DRIVER_OK status set.
tools/lguest: handle indirect partway through chain.
tools/lguest: insert driver references from the 1.0 spec (4.1 Virtio Over PCI)
tools/lguest: insert device references from the 1.0 spec (4.1 Virtio Over PCI)
tools/lguest: rename virtio_pci_cfg_cap field to match spec.
tools/lguest: fix features_accepted logic in example launcher.
tools/lguest: handle device reset correctly in example launcher.
virtual: Documentation: simplify and generalize paravirt_ops.txt
lguest: remove NOTIFY call and eventfd facility.
lguest: remove NOTIFY facility from demonstration launcher.
lguest: use the PCI console device's emerg_wr for early boot messages.
lguest: always put console in PCI slot #1.
The general documentation we have for pv_ops is currenty present
on the IA64 docs, but since this documentation covers IA64 xen
enablement and IA64 Xen support got ripped out a while ago
through commit d52eefb47 present since v3.14-rc1 lets just
simplify, generalize and move the pv_ops documentation to a
shared place.
Cc: Isaku Yamahata <yamahata@valinux.co.jp>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Alok Kataria <akataria@vmware.com>
Cc: virtualization@lists.linux-foundation.org
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: xen-devel@lists.xenproject.org
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
This patch enables cpu model support in kvm/s390 via the vm attribute
interface.
During KVM initialization, the host properties cpuid, IBC value and the
facility list are stored in the architecture specific cpu model structure.
During vcpu setup, these properties are taken to initialize the related SIE
state. This mechanism allows to adjust the properties from user space and thus
to implement different selectable cpu models.
This patch uses the IBC functionality to block instructions that have not
been implemented at the requested CPU type and GA level compared to the
full host capability.
Userspace has to initialize the cpu model before vcpu creation. A cpu model
change of running vcpus is not possible.
Signed-off-by: Michael Mueller <mimu@linux.vnet.ibm.com>
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux into kvm-next
KVM: s390: fixes and features for kvm/next (3.20)
1. Generic
- sparse warning (make function static)
- optimize locking
- bugfixes for interrupt injection
- fix MVPG addressing modes
2. hrtimer/wakeup fun
A recent change can cause KVM hangs if adjtime is used in the host.
The hrtimer might wake up too early or too late. Too early is fatal
as vcpu_block will see that the wakeup condition is not met and
sleep again. This CPU might never wake up again.
This series addresses this problem. adjclock slowing down the host
clock will result in too late wakeups. This will require more work.
In addition to that we also change the hrtimer from REALTIME to
MONOTONIC to avoid similar problems with timedatectl set-time.
3. sigp rework
We will move all "slow" sigps to QEMU (protected with a capability that
can be enabled) to avoid several races between concurrent SIGP orders.
4. Optimize the shadow page table
Provide an interface to announce the maximum guest size. The kernel
will use that to make the pagetable 2,3,4 (or theoretically) 5 levels.
5. Provide an interface to set the guest TOD
We now use two vm attributes instead of two oneregs, as oneregs are
vcpu ioctl and we don't want to call them from other threads.
6. Protected key functions
The real HMC allows to enable/disable protected key CPACF functions.
Lets provide an implementation + an interface for QEMU to activate
this the protected key instructions.
Most SIGP orders are handled partially in kernel and partially in
user space. In order to:
- Get a correct SIGP SET PREFIX handler that informs user space
- Avoid race conditions between concurrently executed SIGP orders
- Serialize SIGP orders per VCPU
We need to handle all "slow" SIGP orders in user space. The remaining
ones to be handled completely in kernel are:
- SENSE
- SENSE RUNNING
- EXTERNAL CALL
- EMERGENCY SIGNAL
- CONDITIONAL EMERGENCY SIGNAL
According to the PoP, they have to be fast. They can be executed
without conflicting to the actions of other pending/concurrently
executing orders (e.g. STOP vs. START).
This patch introduces a new capability that will - when enabled -
forward all but the mentioned SIGP orders to user space. The
instruction counters in the kernel are still updated.
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
In order to get rid of the action_flags and to properly migrate pending SIGP
STOP irqs triggered e.g. by SIGP STOP AND STORE STATUS, we need to remember
whether to store the status when stopping.
For this reason, a new parameter (flags) for the SIGP STOP irq is introduced.
These flags further define details of the requested STOP and can be easily
migrated.
With commit c6c956b80bdf ("KVM: s390/mm: support gmap page tables with less
than 5 levels") we are able to define a limit for the guest memory size.
As we round up the guest size in respect to the levels of page tables
we get to guest limits of: 2048 MB, 4096 GB, 8192 TB and 16384 PB.
We currently limit the guest size to 16 TB, which means we end up
creating a page table structure supporting guest sizes up to 8192 TB.
This patch introduces an interface that allows userspace to tune
this limit. This may bring performance improvements for small guests.
Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
Although the GIC architecture requires us to map the MMIO regions
only at page aligned addresses, we currently do not enforce this from
the kernel side.
Restrict any vGICv2 regions to be 4K aligned and any GICv3 regions
to be 64K aligned. Document this requirement.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
With all of the GICv3 code in place now we allow userland to ask the
kernel for using a virtual GICv3 in the guest.
Also we provide the necessary support for guests setting the memory
addresses for the virtual distributor and redistributors.
This requires some userland code to make use of that feature and
explicitly ask for a virtual GICv3.
Document that KVM_CREATE_IRQCHIP only works for GICv2, but is
considered legacy and using KVM_CREATE_DEVICE is preferred.
Since the advent of VGIC dynamic initialization, this latter is
initialized quite late on the first vcpu run or "on-demand", when
injecting an IRQ or when the guest sets its registers.
This initialization could be initiated explicitly much earlier
by the users-space, as soon as it has provided the requested
dimensioning parameters.
This patch adds a new entry to the VGIC KVM device that allows
the user to manually request the VGIC init:
- a new KVM_DEV_ARM_VGIC_GRP_CTRL group is introduced.
- Its first attribute is KVM_DEV_ARM_VGIC_CTRL_INIT
The rationale behind introducing a group is to be able to add other
controls later on, if needed.
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into HEAD
Second round of changes for KVM for arm/arm64 for v3.19; fixes reboot
problems, clarifies VCPU init, and fixes a regression concerning the
VGIC init flow.
arch/ia64/kvm/kvm-ia64.c [deleted in HEAD and modified in kvmarm]
When a vcpu calls SYSTEM_OFF or SYSTEM_RESET with PSCI v0.2, the vcpus
should really be turned off for the VM adhering to the suggestions in
the PSCI spec, and it's the sane thing to do.
Also, clarify the behavior and expectations for exits to user space with
the KVM_EXIT_SYSTEM_EVENT case.
It is not clear that this ioctl can be called multiple times for a given
vcpu. Userspace already does this, so clarify the ABI.
Also specify that userspace is expected to always make secondary and
subsequent calls to the ioctl with the same parameters for the VCPU as
the initial call (which userspace also already does).
Add code to check that userspace doesn't violate that ABI in the future,
and move the kvm_vcpu_set_target() function which is currently
duplicated between the 32-bit and 64-bit versions in guest.c to a common
static function in arm.c, shared between both architectures.
The implementation of KVM_ARM_VCPU_INIT is currently not doing what
userspace expects, namely making sure that a vcpu which may have been
turned off using PSCI is returned to its initial state, which would be
powered on if userspace does not set the KVM_ARM_VCPU_POWER_OFF flag.
Implement the expected functionality and clarify the ABI.
kvm/ia64 is gone, clean up Documentation too.
KVM: s390: Fixes for kvm/next (3.19) and stable
1. We should flush TLBs for load control instruction emulation (stable)
2. A workaround for a compiler bug that renders ACCESS_ONCE broken (stable)
3. Fix program check handling for load control
4. Documentation Fix
Documentation uses incorrect attribute names for some vm device
attributes: fix this.
No kernel ever reported KVM_CAP_DEVICE_MSIX, KVM_CAP_DEVICE_MSI,
KVM_CAP_DEVICE_ASSIGNMENT, KVM_CAP_DEVICE_DEASSIGNMENT.
This makes the documentation wrong, and no application ever
written to use these capabilities has a chance to work correctly.
The only way to detect support is to try, and test errno for ENOTTY.
That's unfortunate, but we can't fix the past.
Document the actual semantics, and drop the definitions from
the exported header to make it easier for application
developers to note and fix the bug.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
When commit 6adba5274206 (KVM: Let host know whether the guest can
handle async PF in non-userspace context.) is introduced, actually
bit 2 still is reserved and should be zero. Instead, bit 1 is 1 to
indicate if asynchronous page faults can be injected when vcpu is
in cpl == 0, and also please see this,
in the file kvm_para.h, #define KVM_ASYNC_PF_SEND_ALWAYS (1 << 1).
Signed-off-by: Tiejun Chen <tiejun.chen@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into kvm-next
Changes for KVM for arm/arm64 for 3.18
This includes a bunch of changes:
- Support read-only memory slots on arm/arm64
- Various changes to fix Sparse warnings
- Correctly detect write vs. read Stage-2 faults
- Various VGIC cleanups and fixes
- Dynamic VGIC data strcuture sizing
- Fix SGI set_clear_pend offset bug
- Fix VTTBR_BADDR Mask
- Correctly report the FSC on Stage-2 faults
virt/kvm/eventfd.c
[duplicate, different patch where the kvm-arm version broke x86.
The kvm tree instead has the right one]
This was missed in respective one_reg implementation patch.
Signed-off-by: Bharat Bhushan <Bharat.Bhushan@freescale.com>
In order to make the number of interrupts configurable, use the new
fancy device management API to add KVM_DEV_ARM_VGIC_GRP_NR_IRQS as
a VGIC configurable attribute.
Userspace can now specify the exact size of the GIC (by increments
of 32 interrupts).
It looks like when this was initially merged it got accidentally included
in the following section. I've just moved it back in the correct section
and re-numbered it as other ioctls have been added since.
Acked-by: Borislav Petkov <bp@suse.de>
In preparation for working on the ARM implementation I noticed the debug
interface was missing from the API document. I've pieced together the
expected behaviour from the code and commit messages written it up as
best I can.
vcpu exits and memslot mutations can run concurrently as long as the
vcpu does not aquire the slots mutex. Thus it is theoretically possible
for memslots to change underneath a vcpu that is handling an exit.
If we increment the memslot generation number again after
synchronize_srcu_expedited(), vcpus can safely cache memslot generation
without maintaining a single rcu_dereference through an entire vm exit.
And much of the x86/kvm code does not maintain a single rcu_dereference
of the current memslots during each exit.
We can prevent the following case:
vcpu (CPU 0) | thread (CPU 1)
1 vm exit |
2 srcu_read_unlock(&kvm->srcu) |
3 decide to cache something based on |
old memslots |
4 | change memslots
| (increments generation)
5 | synchronize_srcu(&kvm->srcu);
6 retrieve generation # from new memslots |
7 tag cache with new memslot generation |
8 srcu_read_unlock(&kvm->srcu) |
<action based on cache occurs even |
though the caching decision was based |
on the old memslots> |
<action *continues* to occur until next |
memslot generation change, which may |
be never> |
By incrementing the generation after synchronizing with kvm->srcu readers,
we ensure that the generation retrieved in (6) will become invalid soon
after (8).
Keeping the existing increment is not strictly necessary, but we
do keep it and just move it for consistency from update_memslots to
install_new_memslots. It invalidates old cached MMIOs immediately,
instead of having to wait for the end of synchronize_srcu_expedited,
which makes the code more clearly correct in case CPU 1 is preempted
right after synchronize_srcu() returns.
To avoid halving the generation space in SPTEs, always presume that the
low bit of the generation is zero when reconstructing a generation number
out of an SPTE. This effectively disables MMIO caching in SPTEs during
the call to synchronize_srcu_expedited. Using the low bit this way is
somewhat like a seqcount---where the protected thing is a cache, and
instead of retrying we can simply punt if we observe the low bit to be 1.
Signed-off-by: David Matlack <dmatlack@google.com>
Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Reviewed-by: David Matlack <dmatlack@google.com>
This patch clarifies that kvm_dirty_regs are just a hint to the kernel and
that the kernel might just ignore some flags and sync the values (like done for
acrs and gprs now).
Patch queue for ppc - 2014-08-01
Highlights in this release include:
- BookE: Rework instruction fetch, not racy anymore now
- BookE HV: Fix ONE_REG accessors for some in-hardware registers
- Book3S: Good number of LE host fixes, enable HV on LE
- Book3S: Some misc bug fixes
- Book3S HV: Add in-guest debug support
- Book3S HV: Preload cache lines on context switch
- Remove 440 support
Alexander Graf (31):
KVM: PPC: Book3s PR: Disable AIL mode with OPAL
KVM: PPC: Book3s HV: Fix tlbie compile error
KVM: PPC: Book3S PR: Handle hyp doorbell exits
KVM: PPC: Book3S PR: Fix ABIv2 on LE
KVM: PPC: Book3S PR: Fix sparse endian checks
PPC: Add asm helpers for BE 32bit load/store
KVM: PPC: Book3S HV: Make HTAB code LE host aware
KVM: PPC: Book3S HV: Access guest VPA in BE
KVM: PPC: Book3S HV: Access host lppaca and shadow slb in BE
KVM: PPC: Book3S HV: Access XICS in BE
KVM: PPC: Book3S HV: Fix ABIv2 on LE
KVM: PPC: Book3S HV: Enable for little endian hosts
KVM: PPC: Book3S: Move vcore definition to end of kvm_arch struct
KVM: PPC: Deflect page write faults properly in kvmppc_st
KVM: PPC: Book3S: Stop PTE lookup on write errors
KVM: PPC: Book3S: Add hack for split real mode
KVM: PPC: Book3S: Make magic page properly 4k mappable
KVM: PPC: Remove 440 support
KVM: Rename and add argument to check_extension
KVM: Allow KVM_CHECK_EXTENSION on the vm fd
KVM: PPC: Book3S: Provide different CAPs based on HV or PR mode
KVM: PPC: Implement kvmppc_xlate for all targets
KVM: PPC: Move kvmppc_ld/st to common code
KVM: PPC: Remove kvmppc_bad_hva()
KVM: PPC: Use kvm_read_guest in kvmppc_ld
KVM: PPC: Handle magic page in kvmppc_ld/st
KVM: PPC: Separate loadstore emulation from priv emulation
KVM: PPC: Expose helper functions for data/inst faults
KVM: PPC: Remove DCR handling
KVM: PPC: HV: Remove generic instruction emulation
KVM: PPC: PR: Handle FSCR feature deselects
Alexey Kardashevskiy (1):
KVM: PPC: Book3S: Fix LPCR one_reg interface
Aneesh Kumar K.V (4):
KVM: PPC: BOOK3S: PR: Fix PURR and SPURR emulation
KVM: PPC: BOOK3S: PR: Emulate virtual timebase register
KVM: PPC: BOOK3S: PR: Emulate instruction counter
KVM: PPC: BOOK3S: HV: Update compute_tlbie_rb to handle 16MB base page
Anton Blanchard (2):
KVM: PPC: Book3S HV: Fix ABIv2 indirect branch issue
KVM: PPC: Assembly functions exported to modules need _GLOBAL_TOC()
Bharat Bhushan (10):
kvm: ppc: bookehv: Added wrapper macros for shadow registers
kvm: ppc: booke: Use the shared struct helpers of SRR0 and SRR1
kvm: ppc: booke: Use the shared struct helpers of SPRN_DEAR
kvm: ppc: booke: Add shared struct helpers of SPRN_ESR
kvm: ppc: booke: Use the shared struct helpers for SPRN_SPRG0-7
kvm: ppc: Add SPRN_EPR get helper function
kvm: ppc: bookehv: Save restore SPRN_SPRG9 on guest entry exit
KVM: PPC: Booke-hv: Add one reg interface for SPRG9
KVM: PPC: Remove comment saying SPRG1 is used for vcpu pointer
KVM: PPC: BOOKEHV: rename e500hv_spr to bookehv_spr
Michael Neuling (1):
KVM: PPC: Book3S HV: Add H_SET_MODE hcall handling
Mihai Caraman (8):
KVM: PPC: e500mc: Enhance tlb invalidation condition on vcpu schedule
KVM: PPC: e500: Fix default tlb for victim hint
KVM: PPC: e500: Emulate power management control SPR
KVM: PPC: e500mc: Revert "add load inst fixup"
KVM: PPC: Book3e: Add TLBSEL/TSIZE defines for MAS0/1
KVM: PPC: Book3s: Remove kvmppc_read_inst() function
KVM: PPC: Allow kvmppc_get_last_inst() to fail
KVM: PPC: Bookehv: Get vcpu's last instruction for emulation
Paul Mackerras (4):
KVM: PPC: Book3S: Controls for in-kernel sPAPR hypercall handling
KVM: PPC: Book3S: Allow only implemented hcalls to be enabled or disabled
KVM: PPC: Book3S PR: Take SRCU read lock around RTAS kvm_read_guest() call
KVM: PPC: Book3S: Make kvmppc_ld return a more accurate error indication
Stewart Smith (2):
Split out struct kvmppc_vcore creation to separate function
Use the POWER8 Micro Partition Prefetch Engine in KVM HV on POWER8
Documentation/virtual/kvm/api.txt
DCR handling was only needed for 440 KVM. Since we removed it, we can also
remove handling of DCR accesses.
The KVM_CHECK_EXTENSION is only available on the kvm fd today. Unfortunately
on PPC some of the capabilities change depending on the way a VM was created.
So instead we need a way to expose capabilities as VM ioctl, so that we can
see which VM type we're using (HV or PR). To enable this, add the
KVM_CHECK_EXTENSION ioctl to our vm ioctl portfolio.
Unfortunately, the LPCR got defined as a 32-bit register in the
one_reg interface. This is unfortunate because KVM allows userspace
to control the DPFD (default prefetch depth) field, which is in the
upper 32 bits. The result is that DPFD always get set to 0, which
reduces performance in the guest.
We can't just change KVM_REG_PPC_LPCR to be a 64-bit register ID,
since that would break existing userspace binaries. Instead we define
a new KVM_REG_PPC_LPCR_64 id which is 64-bit. Userspace can still use
the old KVM_REG_PPC_LPCR id, but it now only modifies those fields in
the bottom 32 bits that userspace can modify (ILE, TC and AIL).
If userspace uses the new KVM_REG_PPC_LPCR_64 id, it can modify DPFD
as well.
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
