path: root/Documentation/vm
2019-07-30Merge tag 'for-linus-hmm' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rdma/rdma Pull HMM fixes from Jason Gunthorpe: "Fix the locking around nouveau's use of the hmm_range_* APIs. It works correctly in the success case, but many of the the edge cases have missing unlocks or double unlocks. The diffstat is a bit big as Christoph did a comprehensive job to move the obsolete API from the core header and into the driver before fixing its flow, but the risk of regression from this code motion is low" * tag 'for-linus-hmm' of git://git.kernel.org/pub/scm/linux/kernel/git/rdma/rdma: nouveau: unlock mmap_sem on all errors from nouveau_range_fault nouveau: remove the block parameter to nouveau_range_fault mm/hmm: move hmm_vma_range_done and hmm_vma_fault to nouveau mm/hmm: always return EBUSY for invalid ranges in hmm_range_{fault,snapshot}
2019-07-25mm/hmm: always return EBUSY for invalid ranges in hmm_range_{fault,snapshot}Christoph Hellwig
We should not have two different error codes for the same condition. EAGAIN must be reserved for the FAULT_FLAG_ALLOW_RETRY retry case and signals to the caller that the mmap_sem has been unlocked. Use EBUSY for the !valid case so that callers can get the locking right. Link: https://lore.kernel.org/r/20190724065258.16603-2-hch@lst.de Tested-by: Ralph Campbell <rcampbell@nvidia.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Ralph Campbell <rcampbell@nvidia.com> Reviewed-by: Jason Gunthorpe <jgg@mellanox.com> Reviewed-by: Felix Kuehling <Felix.Kuehling@amd.com> [jgg: elaborated commit message] Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
2019-07-22Merge branch 'pdf_fixes_v1' of https://git.linuxtv.org/mchehab/experimental ↵Jonathan Corbet
into mauro Bring in a set of post-thrashup fixes from Mauro.
2019-07-18mm: document ZONE_DEVICE memory-model implicationsDan Williams
Explain the general mechanisms of 'ZONE_DEVICE' pages and list the users of 'devm_memremap_pages()'. [dan.j.williams@intel.com: update ZONE_DEVICE memory model documentation] Link: http://lkml.kernel.org/r/156109575458.1409767.1885676287099277666.stgit@dwillia2-desk3.amr.corp.intel.com Link: http://lkml.kernel.org/r/156092354985.979959.15763234410543451710.stgit@dwillia2-desk3.amr.corp.intel.com Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reported-by: Mike Rapoport <rppt@linux.ibm.com> Reviewed-by: Mike Rapoport <rppt@linux.ibm.com> Tested-by: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com> [ppc64] Cc: Jonathan Corbet <corbet@lwn.net> Cc: David Hildenbrand <david@redhat.com> Cc: Jane Chu <jane.chu@oracle.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Jérôme Glisse <jglisse@redhat.com> Cc: Logan Gunthorpe <logang@deltatee.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Oscar Salvador <osalvador@suse.de> Cc: Pavel Tatashin <pasha.tatashin@soleen.com> Cc: Toshi Kani <toshi.kani@hpe.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Wei Yang <richardw.yang@linux.intel.com> Cc: Jason Gunthorpe <jgg@mellanox.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-07-17docs: remove extra conf.py filesMauro Carvalho Chehab
Now that the latex_documents are handled automatically, we can remove those extra conf.py files. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-07-15docs: cgroup-v1: add it to the admin-guide bookMauro Carvalho Chehab
Those files belong to the admin guide, so add them. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-07-15docs: admin-guide: move sysctl directory to itMauro Carvalho Chehab
The stuff under sysctl describes /sys interface from userspace point of view. So, add it to the admin-guide and remove the :orphan: from its index file. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-07-15docs: sysctl: convert to ReSTMauro Carvalho Chehab
Rename the /proc/sys/ documentation files to ReST, using the README file as a template for an index.rst, adding the other files there via TOC markup. Despite being written on different times with different styles, try to make them somewhat coherent with a similar look and feel, ensuring that they'll look nice as both raw text file and as via the html output produced by the Sphinx build system. At its new index.rst, let's add a :orphan: while this is not linked to the main index.rst file, in order to avoid build warnings. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-07-14Merge tag 'for-linus-hmm' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rdma/rdma Pull HMM updates from Jason Gunthorpe: "Improvements and bug fixes for the hmm interface in the kernel: - Improve clarity, locking and APIs related to the 'hmm mirror' feature merged last cycle. In linux-next we now see AMDGPU and nouveau to be using this API. - Remove old or transitional hmm APIs. These are hold overs from the past with no users, or APIs that existed only to manage cross tree conflicts. There are still a few more of these cleanups that didn't make the merge window cut off. - Improve some core mm APIs: - export alloc_pages_vma() for driver use - refactor into devm_request_free_mem_region() to manage DEVICE_PRIVATE resource reservations - refactor duplicative driver code into the core dev_pagemap struct - Remove hmm wrappers of improved core mm APIs, instead have drivers use the simplified API directly - Remove DEVICE_PUBLIC - Simplify the kconfig flow for the hmm users and core code" * tag 'for-linus-hmm' of git://git.kernel.org/pub/scm/linux/kernel/git/rdma/rdma: (42 commits) mm: don't select MIGRATE_VMA_HELPER from HMM_MIRROR mm: remove the HMM config option mm: sort out the DEVICE_PRIVATE Kconfig mess mm: simplify ZONE_DEVICE page private data mm: remove hmm_devmem_add mm: remove hmm_vma_alloc_locked_page nouveau: use devm_memremap_pages directly nouveau: use alloc_page_vma directly PCI/P2PDMA: use the dev_pagemap internal refcount device-dax: use the dev_pagemap internal refcount memremap: provide an optional internal refcount in struct dev_pagemap memremap: replace the altmap_valid field with a PGMAP_ALTMAP_VALID flag memremap: remove the data field in struct dev_pagemap memremap: add a migrate_to_ram method to struct dev_pagemap_ops memremap: lift the devmap_enable manipulation into devm_memremap_pages memremap: pass a struct dev_pagemap to ->kill and ->cleanup memremap: move dev_pagemap callbacks into a separate structure memremap: validate the pagemap type passed to devm_memremap_pages mm: factor out a devm_request_free_mem_region helper mm: export alloc_pages_vma ...
2019-07-09Merge tag 'docs-5.3' of git://git.lwn.net/linuxLinus Torvalds
Pull Documentation updates from Jonathan Corbet: "It's been a relatively busy cycle for docs: - A fair pile of RST conversions, many from Mauro. These create more than the usual number of simple but annoying merge conflicts with other trees, unfortunately. He has a lot more of these waiting on the wings that, I think, will go to you directly later on. - A new document on how to use merges and rebases in kernel repos, and one on Spectre vulnerabilities. - Various improvements to the build system, including automatic markup of function() references because some people, for reasons I will never understand, were of the opinion that :c:func:``function()`` is unattractive and not fun to type. - We now recommend using sphinx 1.7, but still support back to 1.4. - Lots of smaller improvements, warning fixes, typo fixes, etc" * tag 'docs-5.3' of git://git.lwn.net/linux: (129 commits) docs: automarkup.py: ignore exceptions when seeking for xrefs docs: Move binderfs to admin-guide Disable Sphinx SmartyPants in HTML output doc: RCU callback locks need only _bh, not necessarily _irq docs: format kernel-parameters -- as code Doc : doc-guide : Fix a typo platform: x86: get rid of a non-existent document Add the RCU docs to the core-api manual Documentation: RCU: Add TOC tree hooks Documentation: RCU: Rename txt files to rst Documentation: RCU: Convert RCU UP systems to reST Documentation: RCU: Convert RCU linked list to reST Documentation: RCU: Convert RCU basic concepts to reST docs: filesystems: Remove uneeded .rst extension on toctables scripts/sphinx-pre-install: fix out-of-tree build docs: zh_CN: submitting-drivers.rst: Remove a duplicated Documentation/ Documentation: PGP: update for newer HW devices Documentation: Add section about CPU vulnerabilities for Spectre Documentation: platform: Delete x86-laptop-drivers.txt docs: Note that :c:func: should no longer be used ...
2019-07-08Merge branch 'for-5.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "Documentation updates and the addition of cgroup_parse_float() which will be used by new controllers including blk-iocost" * 'for-5.3' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: docs: cgroup-v1: convert docs to ReST and rename to *.rst cgroup: Move cgroup_parse_float() implementation out of CONFIG_SYSFS cgroup: add cgroup_parse_float()
2019-07-02Merge branch 'hmm-devmem-cleanup.4' into rdma.git hmmJason Gunthorpe
Christoph Hellwig says: ==================== Below is a series that cleans up the dev_pagemap interface so that it is more easily usable, which removes the need to wrap it in hmm and thus allowing to kill a lot of code Changes since v3: - pull in "mm/swap: Fix release_pages() when releasing devmap pages" and rebase the other patches on top of that - fold the hmm_devmem_add_resource into the DEVICE_PUBLIC memory removal patch - remove _vm_normal_page as it isn't needed without DEVICE_PUBLIC memory - pick up various ACKs Changes since v2: - fix nvdimm kunit build - add a new memory type for device dax - fix a few issues in intermediate patches that didn't show up in the end result - incorporate feedback from Michal Hocko, including killing of the DEVICE_PUBLIC memory type entirely Changes since v1: - rebase - also switch p2pdma to the internal refcount - add type checking for pgmap->type - rename the migrate method to migrate_to_ram - cleanup the altmap_valid flag - various tidbits from the reviews ==================== Conflicts resolved by: - Keeping Ira's version of the code in swap.c - Using the delete for the section in hmm.rst - Using the delete for the devmap code in hmm.c and .h * branch 'hmm-devmem-cleanup.4': (24 commits) mm: don't select MIGRATE_VMA_HELPER from HMM_MIRROR mm: remove the HMM config option mm: sort out the DEVICE_PRIVATE Kconfig mess mm: simplify ZONE_DEVICE page private data mm: remove hmm_devmem_add mm: remove hmm_vma_alloc_locked_page nouveau: use devm_memremap_pages directly nouveau: use alloc_page_vma directly PCI/P2PDMA: use the dev_pagemap internal refcount device-dax: use the dev_pagemap internal refcount memremap: provide an optional internal refcount in struct dev_pagemap memremap: replace the altmap_valid field with a PGMAP_ALTMAP_VALID flag memremap: remove the data field in struct dev_pagemap memremap: add a migrate_to_ram method to struct dev_pagemap_ops memremap: lift the devmap_enable manipulation into devm_memremap_pages memremap: pass a struct dev_pagemap to ->kill and ->cleanup memremap: move dev_pagemap callbacks into a separate structure memremap: validate the pagemap type passed to devm_memremap_pages mm: factor out a devm_request_free_mem_region helper mm: export alloc_pages_vma ... Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
2019-07-02mm: remove hmm_devmem_addChristoph Hellwig
There isn't really much value add in the hmm_devmem_add wrapper and more, as using devm_memremap_pages directly now is just as simple. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jason Gunthorpe <jgg@mellanox.com> Reviewed-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
2019-06-20docs/vm: hwpoison.rst: Fix quote formattingValentin Schneider
The asterisks prepended to the quoted text currently get translated to bullet points, which gets increasingly confusing the smaller your screen is (when viewing the sphinx output, that is). Convert the whole quote to a literal block. Signed-off-by: Valentin Schneider <valentin.schneider@arm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2019-06-14docs: scheduler: convert docs to ReST and rename to *.rstMauro Carvalho Chehab
In order to prepare to add them to the Kernel API book, convert the files to ReST format. The conversion is actually: - add blank lines and identation in order to identify paragraphs; - fix tables markups; - add some lists markups; - mark literal blocks; - adjust title markups. At its new index.rst, let's add a :orphan: while this is not linked to the main index.rst file, in order to avoid build warnings. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2019-06-14docs: cgroup-v1: convert docs to ReST and rename to *.rstMauro Carvalho Chehab
Convert the cgroup-v1 files to ReST format, in order to allow a later addition to the admin-guide. The conversion is actually: - add blank lines and identation in order to identify paragraphs; - fix tables markups; - add some lists markups; - mark literal blocks; - adjust title markups. At its new index.rst, let's add a :orphan: while this is not linked to the main index.rst file, in order to avoid build warnings. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2019-06-06mm/hmm: update HMM documentationRalph Campbell
Update the HMM documentation to reflect the latest API and make a few minor wording changes. Cc: John Hubbard <jhubbard@nvidia.com> Cc: Ira Weiny <ira.weiny@intel.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Souptick Joarder <jrdr.linux@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ralph Campbell <rcampbell@nvidia.com> Reviewed-by: Jérôme Glisse <jglisse@redhat.com> Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
2019-06-01mm: fix Documentation/vm/hmm.rst Sphinx warningsRandy Dunlap
Fix Sphinx warnings in Documentation/vm/hmm.rst by using "::" notation and inserting a blank line. Also add a missing ';'. Documentation/vm/hmm.rst:292: WARNING: Unexpected indentation. Documentation/vm/hmm.rst:300: WARNING: Unexpected indentation. Link: http://lkml.kernel.org/r/c5995359-7c82-4e47-c7be-b58a4dda0953@infradead.org Fixes: 023a019a9b4e ("mm/hmm: add default fault flags to avoid the need to pre-fill pfns arrays") Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Reviewed-by: Jérôme Glisse <jglisse@redhat.com> Reviewed-by: Mike Rapoport <rppt@linux.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-05-14mm/hmm: add default fault flags to avoid the need to pre-fill pfns arraysJérôme Glisse
The HMM mirror API can be use in two fashions. The first one where the HMM user coalesce multiple page faults into one request and set flags per pfns for of those faults. The second one where the HMM user want to pre-fault a range with specific flags. For the latter one it is a waste to have the user pre-fill the pfn arrays with a default flags value. This patch adds a default flags value allowing user to set them for a range without having to pre-fill the pfn array. Link: http://lkml.kernel.org/r/20190403193318.16478-8-jglisse@redhat.com Signed-off-by: Jérôme Glisse <jglisse@redhat.com> Reviewed-by: Ralph Campbell <rcampbell@nvidia.com> Cc: John Hubbard <jhubbard@nvidia.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Ira Weiny <ira.weiny@intel.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Souptick Joarder <jrdr.linux@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-05-14mm/hmm: improve driver API to work and wait over a rangeJérôme Glisse
A common use case for HMM mirror is user trying to mirror a range and before they could program the hardware it get invalidated by some core mm event. Instead of having user re-try right away to mirror the range provide a completion mechanism for them to wait for any active invalidation affecting the range. This also changes how hmm_range_snapshot() and hmm_range_fault() works by not relying on vma so that we can drop the mmap_sem when waiting and lookup the vma again on retry. Link: http://lkml.kernel.org/r/20190403193318.16478-7-jglisse@redhat.com Signed-off-by: Jérôme Glisse <jglisse@redhat.com> Reviewed-by: Ralph Campbell <rcampbell@nvidia.com> Cc: John Hubbard <jhubbard@nvidia.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Ira Weiny <ira.weiny@intel.com> Cc: Souptick Joarder <jrdr.linux@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-05-14mm/hmm: improve and rename hmm_vma_fault() to hmm_range_fault()Jérôme Glisse
Minor optimization around hmm_pte_need_fault(). Rename for consistency between code, comments and documentation. Also improves the comments on all the possible returns values. Improve the function by returning the number of populated entries in pfns array. Link: http://lkml.kernel.org/r/20190403193318.16478-6-jglisse@redhat.com Signed-off-by: Jérôme Glisse <jglisse@redhat.com> Reviewed-by: Ralph Campbell <rcampbell@nvidia.com> Cc: John Hubbard <jhubbard@nvidia.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Ira Weiny <ira.weiny@intel.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Souptick Joarder <jrdr.linux@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-05-14mm/hmm: improve and rename hmm_vma_get_pfns() to hmm_range_snapshot()Jérôme Glisse
Rename for consistency between code, comments and documentation. Also improves the comments on all the possible returns values. Improve the function by returning the number of populated entries in pfns array. Link: http://lkml.kernel.org/r/20190403193318.16478-5-jglisse@redhat.com Signed-off-by: Jérôme Glisse <jglisse@redhat.com> Reviewed-by: Ralph Campbell <rcampbell@nvidia.com> Reviewed-by: John Hubbard <jhubbard@nvidia.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Souptick Joarder <jrdr.linux@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-04-30docs/vm: Minor editorial changes in the THP and hugetlbfsRalph Campbell
Some minor wording changes and typo corrections. Signed-off-by: Ralph Campbell <rcampbell@nvidia.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Acked-by: Mike Kravetz <mike.kravetz@oracle.com> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2019-04-30docs/vm: add documentation of memory modelsMike Rapoport
Describe what {FLAT,DISCONTIG,SPARSE}MEM are and how they manage to maintain pfn <-> struct page correspondence. Signed-off-by: Mike Rapoport <rppt@linux.ibm.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2019-04-19doc: mm: migration doesn't use FOLL_SPLIT anymoreYang Shi
When demonstrating FOLL_SPLIT in transhuge document, migration is used as an example. But, since commit 94723aafb9e7 ("mm: unclutter THP migration"), the way of THP migration is totally changed. FOLL_SPLIT is not used by migration anymore due to the change. Remove the obsolete example to avoid confusion. Cc: Michal Hocko <mhocko@suse.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Yang Shi <yang.shi@linux.alibaba.com> Reviewed-by: Zi Yan <ziy@nvidia.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2019-04-09docs: Use reference to link to rst fileTobin C. Harding
Current document includes the path to an RST doc file. Since this is an RST file we can make this a link. Keeps the path as the link title since that what the original author wrote. Use reference to link to rst file. Signed-off-by: Tobin C. Harding <tobin@kernel.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2019-02-01docs: Use underscore not hyphen in labelTobin C. Harding
sphinx emits warning WARNING: undefined label: memory-allocation ... This seems to be caused by the use of a hyphen in the label name instead of an underscore. Using an underscore for the label name and the reference clears the warning. Use underscore not hyphen in label and reference. Signed-off-by: Tobin C. Harding <tobin@kernel.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2019-02-01docs: Add missing colonTobin C. Harding
sphinx emits warning WARNING: Inline emphasis start-string without end-string. This is caused by a missing colon. Add missing colon, clearing shpinx build warning. Signed-off-by: Tobin C. Harding <tobin@kernel.org> Acked-by: Mike Rapoport <rppt@linux.ibm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2019-02-01docs: Fix SLUB docs typoTobin C. Harding
There is a minor typo in SLUB documentation. Fix typo. Signed-off-by: Tobin C. Harding <tobin@kernel.org> Acked-by: Mike Rapoport <rppt@linux.ibm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-12-29Merge tag 'docs-5.0' of git://git.lwn.net/linuxLinus Torvalds
Pull documentation update from Jonathan Corbet: "A fairly normal cycle for documentation stuff. We have a new document on perf security, more Italian translations, more improvements to the memory-management docs, improvements to the pathname lookup documentation, and the usual array of smaller fixes. As is often the case, there are a few reaches outside of Documentation/ to adjust kerneldoc comments" * tag 'docs-5.0' of git://git.lwn.net/linux: (38 commits) docs: improve pathname-lookup document structure configfs: fix wrong name of struct in documentation docs/mm-api: link slab_common.c to "The Slab Cache" section slab: make kmem_cache_create{_usercopy} description proper kernel-doc doc:process: add links where missing docs/core-api: make mm-api.rst more structured x86, boot: documentation whitespace fixup Documentation: devres: note checking needs when converting doc:it: add some process/* translations doc:it: fixes in process/1.Intro Documentation: convert path-lookup from markdown to resturctured text Documentation/admin-guide: update admin-guide index.rst Documentation/admin-guide: introduce perf-security.rst file scripts/kernel-doc: Fix struct and struct field attribute processing Documentation: dev-tools: Fix typos in index.rst Correct gen_init_cpio tool's documentation Document /proc/pid PID reuse behavior Documentation: update path-lookup.md for parallel lookups Documentation: Use "while" instead of "whilst" dmaengine: Add mailing list address to the documentation ...
2018-11-20Link the memory allocation guide from the MM docsMatthew Wilcox
I just went looking for the memory allocation guide in the MM docs instead of in the core API. For the benefit of the next person who makes that mistake, link to it from the MM docs. Signed-off-by: Matthew Wilcox <willy@infradead.org> Acked-by: Mike Rapoport <rppt@linux.ibm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-11-20Merge drm/drm-next into drm-intel-next-queuedJani Nikula
Pull in v4.20-rc3 via drm-next. Signed-off-by: Jani Nikula <jani.nikula@intel.com>
2018-11-07mm, drm/i915: mark pinned shmemfs pages as unevictableKuo-Hsin Yang
The i915 driver uses shmemfs to allocate backing storage for gem objects. These shmemfs pages can be pinned (increased ref count) by shmem_read_mapping_page_gfp(). When a lot of pages are pinned, vmscan wastes a lot of time scanning these pinned pages. In some extreme case, all pages in the inactive anon lru are pinned, and only the inactive anon lru is scanned due to inactive_ratio, the system cannot swap and invokes the oom-killer. Mark these pinned pages as unevictable to speed up vmscan. Export pagevec API check_move_unevictable_pages(). This patch was inspired by Chris Wilson's change [1]. [1]: https://patchwork.kernel.org/patch/9768741/ Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Dave Hansen <dave.hansen@intel.com> Signed-off-by: Kuo-Hsin Yang <vovoy@chromium.org> Acked-by: Michal Hocko <mhocko@suse.com> # mm part Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Acked-by: Dave Hansen <dave.hansen@intel.com> Acked-by: Andrew Morton <akpm@linux-foundation.org> Link: https://patchwork.freedesktop.org/patch/msgid/20181106132324.17390-1-chris@chris-wilson.co.uk Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2018-10-26slub: extend slub debug to handle multiple slabsAaron Tomlin
Extend the slub_debug syntax to "slub_debug=<flags>[,<slub>]*", where <slub> may contain an asterisk at the end. For example, the following would poison all kmalloc slabs: slub_debug=P,kmalloc* and the following would apply the default flags to all kmalloc and all block IO slabs: slub_debug=,bio*,kmalloc* Please note that a similar patch was posted by Iliyan Malchev some time ago but was never merged: https://marc.info/?l=linux-mm&m=131283905330474&w=2 Link: http://lkml.kernel.org/r/20180928111139.27962-1-atomlin@redhat.com Signed-off-by: Aaron Tomlin <atomlin@redhat.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Iliyan Malchev <malchev@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-09-09Drop all 00-INDEX files from Documentation/Henrik Austad
This is a respin with a wider audience (all that get_maintainer returned) and I know this spams a *lot* of people. Not sure what would be the correct way, so my apologies for ruining your inbox. The 00-INDEX files are supposed to give a summary of all files present in a directory, but these files are horribly out of date and their usefulness is brought into question. Often a simple "ls" would reveal the same information as the filenames are generally quite descriptive as a short introduction to what the file covers (it should not surprise anyone what Documentation/sched/sched-design-CFS.txt covers) A few years back it was mentioned that these files were no longer really needed, and they have since then grown further out of date, so perhaps it is time to just throw them out. A short status yields the following _outdated_ 00-INDEX files, first counter is files listed in 00-INDEX but missing in the directory, last is files present but not listed in 00-INDEX. List of outdated 00-INDEX: Documentation: (4/10) Documentation/sysctl: (0/1) Documentation/timers: (1/0) Documentation/blockdev: (3/1) Documentation/w1/slaves: (0/1) Documentation/locking: (0/1) Documentation/devicetree: (0/5) Documentation/power: (1/1) Documentation/powerpc: (0/5) Documentation/arm: (1/0) Documentation/x86: (0/9) Documentation/x86/x86_64: (1/1) Documentation/scsi: (4/4) Documentation/filesystems: (2/9) Documentation/filesystems/nfs: (0/2) Documentation/cgroup-v1: (0/2) Documentation/kbuild: (0/4) Documentation/spi: (1/0) Documentation/virtual/kvm: (1/0) Documentation/scheduler: (0/2) Documentation/fb: (0/1) Documentation/block: (0/1) Documentation/networking: (6/37) Documentation/vm: (1/3) Then there are 364 subdirectories in Documentation/ with several files that are missing 00-INDEX alltogether (and another 120 with a single file and no 00-INDEX). I don't really have an opinion to whether or not we /should/ have 00-INDEX, but the above 00-INDEX should either be removed or be kept up to date. If we should keep the files, I can try to keep them updated, but I rather not if we just want to delete them anyway. As a starting point, remove all index-files and references to 00-INDEX and see where the discussion is going. Signed-off-by: Henrik Austad <henrik@austad.us> Acked-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Just-do-it-by: Steven Rostedt <rostedt@goodmis.org> Reviewed-by: Jens Axboe <axboe@kernel.dk> Acked-by: Paul Moore <paul@paul-moore.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Mark Brown <broonie@kernel.org> Acked-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: [Almost everybody else] Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-08-31docs/vm/hmm.rst: Add missed spaceBaoquan He
This space missing caused the colour scheme in vim editor messy after that line. Add it to fix. Signed-off-by: Baoquan He <bhe@redhat.com> [ jc: fixed alignment after the changed line ] Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-05-29docs/vm: move ksm and transhuge from "user" to "internals" section.Mike Rapoport
After the userspace interface description for KSM and THP was split to Documentation/admin-guide/mm, the remaining parts belong to the section describing MM internals. Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-05-21docs/vm: transhuge: split userspace bits to admin-guide/mm/transhugeMike Rapoport
Now that the administrative information for transparent huge pages is nicely separated, move it to its own page under the admin guide. Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-05-21docs/vm: transhuge: minor updatesMike Rapoport
Some formatting changes and addition of a sentence introducing khugepaged Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-05-21docs/vm: transhuge: change sections orderMike Rapoport
so that userspace interface and implementation description will be grouped together Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-05-10mm, THP, doc: Add document for thp_swpout/thp_swpout_fallbackHuang Ying
Add document for newly added thp_swpout, thp_swpout_fallback fields in /proc/vmstat. Signed-off-by: "Huang, Ying" <ying.huang@intel.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-05-08docs/vm: move numa_memory_policy.rst to Documentation/admin-guide/mmMike Rapoport
The document describes userspace API and as such it belongs to Documentation/admin-guide/mm Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-05-08docs/vm: numa_memory_policy: s/Linux memory policy/NUMA memory policy/Mike Rapoport
The document describes NUMA memory policy and as it is a part of the Linux documentation it's obvious that this is Linux memory policy. Besides, "Linux memory policy" may refer to other policies, e.g. memory hotplug policy, and using term NUMA makes the documentation less ambiguous. Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-05-08docs/vm: numa_memory_policy: formatting and spelling updatesMike Rapoport
2018-04-27docs/vm: ksm: split userspace interface to admin-guide/mm/ksm.rstMike Rapoport
2018-04-27docs/vm: ksm: udpate description of stable_node_{dups,chains}Mike Rapoport
Remove implementation details from sysfs parameter descriptions. Also move the paragraph discussing fragmentation issues and their possible solution to the "Design" section. Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-04-27docs/vm: ksm: update stable_node_chains_prune_millisecs descriptionMike Rapoport
Make the description of stable_node_chains_prune_millisecs sysfs parameter less implementation aware and add a few words about this parameter in the "Design" section. Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-04-27docs/vm: ksm: reshuffle text between "sysfs" and "design" sectionsMike Rapoport
The description of "max_page_sharing" sysfs attribute includes lots of implementation details that more naturally belong in the "Design" section. Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-04-27docs/vm: ksm: add "Design" sectionMike Rapoport
Include the KSM description from the source code comment, add a subsection about reverse mapping and include kernel-doc references for KSM data structures. Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2018-04-27docs/vm: ksm: (mostly) formatting updatesMike Rapoport
Aside from the formatting: * fixed typos * added section and sub-section headers * moved ksmd overview after the description of KSM origins Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
