path: root/Documentation/vm
2013-04-29mm: limit growth of 3% hardcoded other user reserveAndrew Shewmaker
Add user_reserve_kbytes knob. Limit the growth of the memory reserved for other user processes to min(3% current process size, user_reserve_pages). Only about 8MB is necessary to enable recovery in the default mode, and only a few hundred MB are required even when overcommit is disabled. user_reserve_pages defaults to min(3% free pages, 128MB) I arrived at 128MB by taking the max VSZ of sshd, login, bash, and top ... then adding the RSS of each. This only affects OVERCOMMIT_NEVER mode. Background 1. user reserve __vm_enough_memory reserves a hardcoded 3% of the current process size for other applications when overcommit is disabled. This was done so that a user could recover if they launched a memory hogging process. Without the reserve, a user would easily run into a message such as: bash: fork: Cannot allocate memory 2. admin reserve Additionally, a hardcoded 3% of free memory is reserved for root in both overcommit 'guess' and 'never' modes. This was intended to prevent a scenario where root-cant-log-in and perform recovery operations. Note that this reserve shrinks, and doesn't guarantee a useful reserve. Motivation The two hardcoded memory reserves should be updated to account for current memory sizes. Also, the admin reserve would be more useful if it didn't shrink too much. When the current code was originally written, 1GB was considered "enterprise". Now the 3% reserve can grow to multiple GB on large memory systems, and it only needs to be a few hundred MB at most to enable a user or admin to recover a system with an unwanted memory hogging process. I've found that reducing these reserves is especially beneficial for a specific type of application load: * single application system * one or few processes (e.g. one per core) * allocating all available memory * not initializing every page immediately * long running I've run scientific clusters with this sort of load. A long running job sometimes failed many hours (weeks of CPU time) into a calculation. They weren't initializing all of their memory immediately, and they weren't using calloc, so I put systems into overcommit 'never' mode. These clusters run diskless and have no swap. However, with the current reserves, a user wishing to allocate as much memory as possible to one process may be prevented from using, for example, almost 2GB out of 32GB. The effect is less, but still significant when a user starts a job with one process per core. I have repeatedly seen a set of processes requesting the same amount of memory fail because one of them could not allocate the amount of memory a user would expect to be able to allocate. For example, Message Passing Interfce (MPI) processes, one per core. And it is similar for other parallel programming frameworks. Changing this reserve code will make the overcommit never mode more useful by allowing applications to allocate nearly all of the available memory. Also, the new admin_reserve_kbytes will be safer than the current behavior since the hardcoded 3% of available memory reserve can shrink to something useless in the case where applications have grabbed all available memory. Risks * "bash: fork: Cannot allocate memory" The downside of the first patch-- which creates a tunable user reserve that is only used in overcommit 'never' mode--is that an admin can set it so low that a user may not be able to kill their process, even if they already have a shell prompt. Of course, a user can get in the same predicament with the current 3% reserve--they just have to launch processes until 3% becomes negligible. * root-cant-log-in problem The second patch, adding the tunable rootuser_reserve_pages, allows the admin to shoot themselves in the foot by setting it too small. They can easily get the system into a state where root-can't-log-in. However, the new admin_reserve_kbytes will be safer than the current behavior since the hardcoded 3% of available memory reserve can shrink to something useless in the case where applications have grabbed all available memory. Alternatives * Memory cgroups provide a more flexible way to limit application memory. Not everyone wants to set up cgroups or deal with their overhead. * We could create a fourth overcommit mode which provides smaller reserves. The size of useful reserves may be drastically different depending on the whether the system is embedded or enterprise. * Force users to initialize all of their memory or use calloc. Some users don't want/expect the system to overcommit when they malloc. Overcommit 'never' mode is for this scenario, and it should work well. The new user and admin reserve tunables are simple to use, with low overhead compared to cgroups. The patches preserve current behavior where 3% of memory is less than 128MB, except that the admin reserve doesn't shrink to an unusable size under pressure. The code allows admins to tune for embedded and enterprise usage. FAQ * How is the root-cant-login problem addressed? What happens if admin_reserve_pages is set to 0? Root is free to shoot themselves in the foot by setting admin_reserve_kbytes too low. On x86_64, the minimum useful reserve is: 8MB for overcommit 'guess' 128MB for overcommit 'never' admin_reserve_pages defaults to min(3% free memory, 8MB) So, anyone switching to 'never' mode needs to adjust admin_reserve_pages. * How do you calculate a minimum useful reserve? A user or the admin needs enough memory to login and perform recovery operations, which includes, at a minimum: sshd or login + bash (or some other shell) + top (or ps, kill, etc.) For overcommit 'guess', we can sum resident set sizes (RSS) because we only need enough memory to handle what the recovery programs will typically use. On x86_64 this is about 8MB. For overcommit 'never', we can take the max of their virtual sizes (VSZ) and add the sum of their RSS. We use VSZ instead of RSS because mode forces us to ensure we can fulfill all of the requested memory allocations-- even if the programs only use a fraction of what they ask for. On x86_64 this is about 128MB. When swap is enabled, reserves are useful even when they are as small as 10MB, regardless of overcommit mode. When both swap and overcommit are disabled, then the admin should tune the reserves higher to be absolutley safe. Over 230MB each was safest in my testing. * What happens if user_reserve_pages is set to 0? Note, this only affects overcomitt 'never' mode. Then a user will be able to allocate all available memory minus admin_reserve_kbytes. However, they will easily see a message such as: "bash: fork: Cannot allocate memory" And they won't be able to recover/kill their application. The admin should be able to recover the system if admin_reserve_kbytes is set appropriately. * What's the difference between overcommit 'guess' and 'never'? "Guess" allows an allocation if there are enough free + reclaimable pages. It has a hardcoded 3% of free pages reserved for root. "Never" allows an allocation if there is enough swap + a configurable percentage (default is 50) of physical RAM. It has a hardcoded 3% of free pages reserved for root, like "Guess" mode. It also has a hardcoded 3% of the current process size reserved for additional applications. * Why is overcommit 'guess' not suitable even when an app eventually writes to every page? It takes free pages, file pages, available swap pages, reclaimable slab pages into consideration. In other words, these are all pages available, then why isn't overcommit suitable? Because it only looks at the present state of the system. It does not take into account the memory that other applications have malloced, but haven't initialized yet. It overcommits the system. Test Summary There was little change in behavior in the default overcommit 'guess' mode with swap enabled before and after the patch. This was expected. Systems run most predictably (i.e. no oom kills) in overcommit 'never' mode with swap enabled. This also allowed the most memory to be allocated to a user application. Overcommit 'guess' mode without swap is a bad idea. It is easy to crash the system. None of the other tested combinations crashed. This matches my experience on the Roadrunner supercomputer. Without the tunable user reserve, a system in overcommit 'never' mode and without swap does not allow the admin to recover, although the admin can. With the new tunable reserves, a system in overcommit 'never' mode and without swap can be configured to: 1. maximize user-allocatable memory, running close to the edge of recoverability 2. maximize recoverability, sacrificing allocatable memory to ensure that a user cannot take down a system Test Description Fedora 18 VM - 4 x86_64 cores, 5725MB RAM, 4GB Swap System is booted into multiuser console mode, with unnecessary services turned off. Caches were dropped before each test. Hogs are user memtester processes that attempt to allocate all free memory as reported by /proc/meminfo In overcommit 'never' mode, memory_ratio=100 Test Results 3.9.0-rc1-mm1 Overcommit | Swap | Hogs | MB Got/Wanted | OOMs | User Recovery | Admin Recovery ---------- ---- ---- ------------- ---- ------------- -------------- guess yes 1 5432/5432 no yes yes guess yes 4 5444/5444 1 yes yes guess no 1 5302/5449 no yes yes guess no 4 - crash no no never yes 1 5460/5460 1 yes yes never yes 4 5460/5460 1 yes yes never no 1 5218/5432 no no yes never no 4 5203/5448 no no yes 3.9.0-rc1-mm1-tunablereserves User and Admin Recovery show their respective reserves, if applicable. Overcommit | Swap | Hogs | MB Got/Wanted | OOMs | User Recovery | Admin Recovery ---------- ---- ---- ------------- ---- ------------- -------------- guess yes 1 5419/5419 no - yes 8MB yes guess yes 4 5436/5436 1 - yes 8MB yes guess no 1 5440/5440 * - yes 8MB yes guess no 4 - crash - no 8MB no * process would successfully mlock, then the oom killer would pick it never yes 1 5446/5446 no 10MB yes 20MB yes never yes 4 5456/5456 no 10MB yes 20MB yes never no 1 5387/5429 no 128MB no 8MB barely never no 1 5323/5428 no 226MB barely 8MB barely never no 1 5323/5428 no 226MB barely 8MB barely never no 1 5359/5448 no 10MB no 10MB barely never no 1 5323/5428 no 0MB no 10MB barely never no 1 5332/5428 no 0MB no 50MB yes never no 1 5293/5429 no 0MB no 90MB yes never no 1 5001/5427 no 230MB yes 338MB yes never no 4* 4998/5424 no 230MB yes 338MB yes * more memtesters were launched, able to allocate approximately another 100MB Future Work - Test larger memory systems. - Test an embedded image. - Test other architectures. - Time malloc microbenchmarks. - Would it be useful to be able to set overcommit policy for each memory cgroup? - Some lines are slightly above 80 chars. Perhaps define a macro to convert between pages and kb? Other places in the kernel do this. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: make init_user_reserve() static] Signed-off-by: Andrew Shewmaker <agshew@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23ksm: add some commentsHugh Dickins
Added slightly more detail to the Documentation of merge_across_nodes, a few comments in areas indicated by review, and renamed get_ksm_page()'s argument from "locked" to "lock_it". No functional change. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Petr Holasek <pholasek@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Izik Eidus <izik.eidus@ravellosystems.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23ksm: allow trees per NUMA nodePetr Holasek
Here's a KSM series, based on mmotm 2013-01-23-17-04: starting with Petr's v7 "KSM: numa awareness sysfs knob"; then fixing the two issues we had with that, fully enabling KSM page migration on the way. (A different kind of KSM/NUMA issue which I've certainly not begun to address here: when KSM pages are unmerged, there's usually no sense in preferring to allocate the new pages local to the caller's node.) This patch: Introduces new sysfs boolean knob /sys/kernel/mm/ksm/merge_across_nodes which control merging pages across different numa nodes. When it is set to zero only pages from the same node are merged, otherwise pages from all nodes can be merged together (default behavior). Typical use-case could be a lot of KVM guests on NUMA machine and cpus from more distant nodes would have significant increase of access latency to the merged ksm page. Sysfs knob was choosen for higher variability when some users still prefers higher amount of saved physical memory regardless of access latency. Every numa node has its own stable & unstable trees because of faster searching and inserting. Changing of merge_across_nodes value is possible only when there are not any ksm shared pages in system. I've tested this patch on numa machines with 2, 4 and 8 nodes and measured speed of memory access inside of KVM guests with memory pinned to one of nodes with this benchmark: http://pholasek.fedorapeople.org/alloc_pg.c Population standard deviations of access times in percentage of average were following: merge_across_nodes=1 2 nodes 1.4% 4 nodes 1.6% 8 nodes 1.7% merge_across_nodes=0 2 nodes 1% 4 nodes 0.32% 8 nodes 0.018% RFC: https://lkml.org/lkml/2011/11/30/91 v1: https://lkml.org/lkml/2012/1/23/46 v2: https://lkml.org/lkml/2012/6/29/105 v3: https://lkml.org/lkml/2012/9/14/550 v4: https://lkml.org/lkml/2012/9/23/137 v5: https://lkml.org/lkml/2012/12/10/540 v6: https://lkml.org/lkml/2012/12/23/154 v7: https://lkml.org/lkml/2012/12/27/225 Hugh notes that this patch brings two problems, whose solution needs further support in mm/ksm.c, which follows in subsequent patches: 1) switching merge_across_nodes after running KSM is liable to oops on stale nodes still left over from the previous stable tree; 2) memory hotremove may migrate KSM pages, but there is no provision here for !merge_across_nodes to migrate nodes to the proper tree. Signed-off-by: Petr Holasek <pholasek@redhat.com> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Izik Eidus <izik.eidus@ravellosystems.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-13Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge misc VM changes from Andrew Morton: "The rest of most-of-MM. The other MM bits await a slab merge. This patch includes the addition of a huge zero_page. Not a performance boost but it an save large amounts of physical memory in some situations. Also a bunch of Fujitsu engineers are working on memory hotplug. Which, as it turns out, was badly broken. About half of their patches are included here; the remainder are 3.8 material." However, this merge disables CONFIG_MOVABLE_NODE, which was totally broken. We don't add new features with "default y", nor do we add Kconfig questions that are incomprehensible to most people without any help text. Does the feature even make sense without compaction or memory hotplug? * akpm: (54 commits) mm/bootmem.c: remove unused wrapper function reserve_bootmem_generic() mm/memory.c: remove unused code from do_wp_page() asm-generic, mm: pgtable: consolidate zero page helpers mm/hugetlb.c: fix warning on freeing hwpoisoned hugepage hwpoison, hugetlbfs: fix RSS-counter warning hwpoison, hugetlbfs: fix "bad pmd" warning in unmapping hwpoisoned hugepage mm: protect against concurrent vma expansion memcg: do not check for mm in __mem_cgroup_count_vm_event tmpfs: support SEEK_DATA and SEEK_HOLE (reprise) mm: provide more accurate estimation of pages occupied by memmap fs/buffer.c: remove redundant initialization in alloc_page_buffers() fs/buffer.c: do not inline exported function writeback: fix a typo in comment mm: introduce new field "managed_pages" to struct zone mm, oom: remove statically defined arch functions of same name mm, oom: remove redundant sleep in pagefault oom handler mm, oom: cleanup pagefault oom handler memory_hotplug: allow online/offline memory to result movable node numa: add CONFIG_MOVABLE_NODE for movable-dedicated node mm, memcg: avoid unnecessary function call when memcg is disabled ...
2012-12-12thp: introduce sysfs knob to disable huge zero pageKirill A. Shutemov
By default kernel tries to use huge zero page on read page fault. It's possible to disable huge zero page by writing 0 or enable it back by writing 1: echo 0 >/sys/kernel/mm/transparent_hugepage/khugepaged/use_zero_page echo 1 >/sys/kernel/mm/transparent_hugepage/khugepaged/use_zero_page Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: "H. Peter Anvin" <hpa@linux.intel.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-12thp, vmstat: implement HZP_ALLOC and HZP_ALLOC_FAILED eventsKirill A. Shutemov
hzp_alloc is incremented every time a huge zero page is successfully allocated. It includes allocations which where dropped due race with other allocation. Note, it doesn't count every map of the huge zero page, only its allocation. hzp_alloc_failed is incremented if kernel fails to allocate huge zero page and falls back to using small pages. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: "H. Peter Anvin" <hpa@linux.intel.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-12thp: change split_huge_page_pmd() interfaceKirill A. Shutemov
Pass vma instead of mm and add address parameter. In most cases we already have vma on the stack. We provides split_huge_page_pmd_mm() for few cases when we have mm, but not vma. This change is preparation to huge zero pmd splitting implementation. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: "H. Peter Anvin" <hpa@linux.intel.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-19doc: fix quite a few typos within DocumentationMasanari Iida
Correct spelling typo in Documentations Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-10-09mm: remove vma arg from page_evictableHugh Dickins
page_evictable(page, vma) is an irritant: almost all its callers pass NULL for vma. Remove the vma arg and use mlocked_vma_newpage(vma, page) explicitly in the couple of places it's needed. But in those places we don't even need page_evictable() itself! They're dealing with a freshly allocated anonymous page, which has no "mapping" and cannot be mlocked yet. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michel Lespinasse <walken@google.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: kill vma flag VM_RESERVED and mm->reserved_vm counterKonstantin Khlebnikov
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA, currently it lost original meaning but still has some effects: | effect | alternative flags -+------------------------+--------------------------------------------- 1| account as reserved_vm | VM_IO 2| skip in core dump | VM_IO, VM_DONTDUMP 3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP 4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP This patch removes reserved_vm counter from mm_struct. Seems like nobody cares about it, it does not exported into userspace directly, it only reduces total_vm showed in proc. Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP. remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP. remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP. [akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup] Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-21hugetlb: update hugetlbpage.txtZhouping Liu
Commit f0f57b2b1488 ("mm: move hugepage test examples to tools/testing/selftests/vm") moved map_hugetlb.c, hugepage-shm.c and hugepage-mmap.c tests into tools/testing/selftests/vm/ directory, but it didn't update hugetlbpage.txt Signed-off-by: Zhouping Liu <sanweidaying@gmail.com> Acked-by: Dave Young <dyoung@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-23mm/frontswap: cleanup doc and comment errorWanpeng Li
Signed-off-by: Wanpeng Li <liwp.linux@gmail.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-06-04Merge tag 'stable/frontswap.v16-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm Pull frontswap feature from Konrad Rzeszutek Wilk: "Frontswap provides a "transcendent memory" interface for swap pages. In some environments, dramatic performance savings may be obtained because swapped pages are saved in RAM (or a RAM-like device) instead of a swap disk. This tag provides the basic infrastructure along with some changes to the existing backends." Fix up trivial conflict in mm/Makefile due to removal of swap token code changing a line next to the new frontswap entry. This pull request came in before the merge window even opened, it got delayed to after the merge window by me just wanting to make sure it had actual users. Apparently IBM is using this on their embedded side, and Jan Beulich says that it's already made available for SLES and OpenSUSE users. Also acked by Rik van Riel, and Konrad points to other people liking it too. So in it goes. By Dan Magenheimer (4) and Konrad Rzeszutek Wilk (2) via Konrad Rzeszutek Wilk * tag 'stable/frontswap.v16-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm: frontswap: s/put_page/store/g s/get_page/load MAINTAINER: Add myself for the frontswap API mm: frontswap: config and doc files mm: frontswap: core frontswap functionality mm: frontswap: core swap subsystem hooks and headers mm: frontswap: add frontswap header file
2012-06-01Merge branch 'slab/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux Pull slab updates from Pekka Enberg: "Mainly a bunch of SLUB fixes from Joonsoo Kim" * 'slab/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux: slub: use __SetPageSlab function to set PG_slab flag slub: fix a memory leak in get_partial_node() slub: remove unused argument of init_kmem_cache_node() slub: fix a possible memory leak Documentations: Fix slabinfo.c directory in vm/slub.txt slub: fix incorrect return type of get_any_partial()
2012-05-31proc: report file/anon bit in /proc/pid/pagemapKonstantin Khlebnikov
This is an implementation of Andrew's proposal to extend the pagemap file bits to report what is missing about tasks' working set. The problem with the working set detection is multilateral. In the criu (checkpoint/restore) project we dump the tasks' memory into image files and to do it properly we need to detect which pages inside mappings are really in use. The mincore syscall I though could help with this did not. First, it doesn't report swapped pages, thus we cannot find out which parts of anonymous mappings to dump. Next, it does report pages from page cache as present even if they are not mapped, and it doesn't make that has not been cow-ed. Note, that issue with swap pages is critical -- we must dump swap pages to image file. But the issues with file pages are optimization -- we can take all file pages to image, this would be correct, but if we know that a page is not mapped or not cow-ed, we can remove them from dump file. The dump would still be self-consistent, though significantly smaller in size (up to 10 times smaller on real apps). Andrew noticed, that the proc pagemap file solved 2 of 3 above issues -- it reports whether a page is present or swapped and it doesn't report not mapped page cache pages. But, it doesn't distinguish cow-ed file pages from not cow-ed. I would like to make the last unused bit in this file to report whether the page mapped into respective pte is PageAnon or not. [comment stolen from Pavel Emelyanov's v1 patch] Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: document the meminfo and vmstat fields of relevance to transparent hugepagesMel Gorman
Update Documentation/vm/transhuge.txt and Documentation/filesystems/proc.txt with some information on monitoring transparent huge page usage and the associated overhead. Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-15frontswap: s/put_page/store/g s/get_page/loadKonrad Rzeszutek Wilk
Sounds so much more natural. Suggested-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-05-15mm: frontswap: config and doc filesDan Magenheimer
This patch 4of4 adds configuration and documentation files including a FAQ. [v14: updated docs/FAQ to use zcache and RAMster as examples] [v10: no change] [v9: akpm@linux-foundation.org: sysfs->debugfs; no longer need Doc/ABI file] [v8: rebase to 3.0-rc4] [v7: rebase to 3.0-rc3] [v6: rebase to 3.0-rc1] [v5: change config default to n] [v4: rebase to 2.6.39] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Acked-by: Jan Beulich <JBeulich@novell.com> Acked-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Chris Mason <chris.mason@oracle.com> Cc: Rik Riel <riel@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-05-10Documentations: Fix slabinfo.c directory in vm/slub.txtmajianpeng
Because the place of slabinfo.c changed.So update in slub.txt. Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: majianpeng <majianpeng@gmail.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-03-28mm: move hugepage test examples to tools/testing/selftests/vmDave Young
hugepage-mmap.c, hugepage-shm.c and map_hugetlb.c in Documentation/vm are simple pass/fail tests, It's better to promote them to tools/testing/selftests. Thanks suggestion of Andrew Morton about this. They all need firstly setting up proper nr_hugepages and hugepage-mmap need to mount hugetlbfs. So I add a shell script run_vmtests to do such work which will call the three test programs and check the return value of them. Changes to original code including below: a. add run_vmtests script b. return error when read_bytes mismatch with writed bytes. c. coding style fixes: do not use assignment in if condition [akpm@linux-foundation.org: build the targets before trying to execute them] [akpm@linux-foundation.org: Documentation/vm/ no longer has a Makefile. Fixes "make clean"] Signed-off-by: Dave Young <dyoung@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28mm: move page-types.c from Documentation to tools/vmDave Young
tools/ is the better place for vm tools which are used by many people. Moving them to tools also make them open to more users instead of hide in Documentation folder. This patch moves page-types.c to tools/vm/page-types.c. Also add a Makefile in tools/vm and fix two coding style problems: a) change const arrary to 'const char * const', b) change a space to tab for indent. Signed-off-by: Dave Young <dyoung@redhat.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-22Merge tag 'stable/for-linus-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm Pull cleancache changes from Konrad Rzeszutek Wilk: "This has some patches for the cleancache API that should have been submitted a _long_ time ago. They are basically cleanups: - rename of flush to invalidate - moving reporting of statistics into debugfs - use __read_mostly as necessary. Oh, and also the MAINTAINERS file change. The files (except the MAINTAINERS file) have been in #linux-next for months now. The late addition of MAINTAINERS file is a brain-fart on my side - didn't realize I needed that just until I was typing this up - and I based that patch on v3.3 - so the tree is on top of v3.3." * tag 'stable/for-linus-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm: MAINTAINERS: Adding cleancache API to the list. mm: cleancache: Use __read_mostly as appropiate. mm: cleancache: report statistics via debugfs instead of sysfs. mm: zcache/tmem/cleancache: s/flush/invalidate/ mm: cleancache: s/flush/invalidate/
2012-03-21pagemap: document KPF_THP and make page-types aware of itNaoya Horiguchi
page-types, which is a common user of pagemap, gets aware of thp with this patch. This helps system admins and kernel hackers know about how thp works. Here is a sample output of page-types over a thp: $ page-types -p <pid> --raw --list voffset offset len flags ... 7f9d40200 3f8400 1 ___U_lA____Ma_bH______t____________ 7f9d40201 3f8401 1ff ________________T_____t____________ flags page-count MB symbolic-flags long-symbolic-flags 0x0000000000410000 511 1 ________________T_____t____________ compound_tail,thp 0x000000000040d868 1 0 ___U_lA____Ma_bH______t____________ uptodate,lru,active,mmap,anonymous,swapbacked,compound_head,thp Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-19Merge branch 'stable/cleancache.v13' into linux-nextKonrad Rzeszutek Wilk
* stable/cleancache.v13: mm: cleancache: Use __read_mostly as appropiate. mm: cleancache: report statistics via debugfs instead of sysfs. mm: zcache/tmem/cleancache: s/flush/invalidate/ mm: cleancache: s/flush/invalidate/
2012-03-07Documentation: Fix multiple typo in DocumentationMasanari Iida
Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-02-10mm: Fix typo in cleancache.txtMasanari Iida
Correct spelling "implementatation" to "implementation" in Documentation/vm/cleancache.txt Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-02-09mm: Fix typo in unevictable-lru.txtMasanari Iida
Correct spelling "semphore" to "semaphore" in Documentation/vm/unevictable-lru.txt Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-01-23mm: cleancache: report statistics via debugfs instead of sysfs.Dan Magenheimer
[v9: akpm@linux-foundation.org: sysfs->debugfs; no longer need Doc/ABI file] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Signed-off-by: Konrad Wilk <konrad.wilk@oracle.com> Cc: Jan Beulich <JBeulich@novell.com> Acked-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Chris Mason <chris.mason@oracle.com> Cc: Rik Riel <riel@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org>
2012-01-23mm: cleancache: s/flush/invalidate/Dan Magenheimer
Per akpm suggestions alter the use of the term flush to be invalidate. The next patch will do this across all MM. This change is completely cosmetic. [v9: akpm@linux-foundation.org: change "flush" to "invalidate", part 3] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Jan Beulich <JBeulich@novell.com> Reviewed-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Chris Mason <chris.mason@oracle.com> Cc: Rik Riel <riel@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> [v10: Fixed fs: move code out of buffer.c conflict change] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-01-12slub: document setting min order with debug_guardpage_minorder > 0Stanislaw Gruszka
Acked-by: David Rientjes <rientjes@google.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-27slub: fix slub_max_order DocumentationEric Dumazet
slub_max_order default is 3 (aka PAGE_ALLOC_COSTLY_ORDER), not 1 Acked-by: David Rientjes <rientjes@google.com> Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2011-10-26Merge branches 'slab/next' and 'slub/partial' into slab/for-linusPekka Enberg
2011-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (59 commits) MAINTAINERS: linux-m32r is moderated for non-subscribers linux@lists.openrisc.net is moderated for non-subscribers Drop default from "DM365 codec select" choice parisc: Kconfig: cleanup Kernel page size default Kconfig: remove redundant CONFIG_ prefix on two symbols cris: remove arch/cris/arch-v32/lib/nand_init.S microblaze: add missing CONFIG_ prefixes h8300: drop puzzling Kconfig dependencies MAINTAINERS: microblaze-uclinux@itee.uq.edu.au is moderated for non-subscribers tty: drop superfluous dependency in Kconfig ARM: mxc: fix Kconfig typo 'i.MX51' Fix file references in Kconfig files aic7xxx: fix Kconfig references to READMEs Fix file references in drivers/ide/ thinkpad_acpi: Fix printk typo 'bluestooth' bcmring: drop commented out line in Kconfig btmrvl_sdio: fix typo 'btmrvl_sdio_sd6888' doc: raw1394: Trivial typo fix CIFS: Don't free volume_info->UNC until we are entirely done with it. treewide: Correct spelling of successfully in comments ...
2011-09-27doc: fix broken referencesPaul Bolle
There are numerous broken references to Documentation files (in other Documentation files, in comments, etc.). These broken references are caused by typo's in the references, and by renames or removals of the Documentation files. Some broken references are simply odd. Fix these broken references, sometimes by dropping the irrelevant text they were part of. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-09-22thp: fix khugepaged defrag tunable documentationDavid Rientjes
Commit e27e6151b154 ("mm/thp: use conventional format for boolean attributes") changed /sys/kernel/mm/transparent_hugepage/khugepaged/defrag to be tuned by using 1 (enabled) or 0 (disabled) instead of "yes" and "no", respectively. Update the documentation. Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-31slub: doc: update the slabinfo.c file pathJason Liu
slabinfo.c has been moved from Documentaion/vm/ to tools/slub/ by commit:0d24db337e6d81c0c620ab65cc6947bd6553f742 Update the slub.txt doc to reflect this change too. Signed-off-by: Jason Liu <jason.hui@linaro.org> Acked-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2011-06-15Documentation: update cgroupfs mount pointJörg Sommer
According to commit 676db4af0430 ("cgroupfs: create /sys/fs/cgroup to mount cgroupfs on") the canonical mountpoint for the cgroup filesystem is /sys/fs/cgroup. Hence, this should be used in the documentation. Signed-off-by: Jörg Sommer <joerg@alea.gnuu.de> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem: xen: cleancache shim to Xen Transcendent Memory ocfs2: add cleancache support ext4: add cleancache support btrfs: add cleancache support ext3: add cleancache support mm/fs: add hooks to support cleancache mm: cleancache core ops functions and config fs: add field to superblock to support cleancache mm/fs: cleancache documentation Fix up trivial conflict in fs/btrfs/extent_io.c due to includes
2011-05-26mm/fs: cleancache documentationDan Magenheimer
This patchset introduces cleancache, an optional new feature exposed by the VFS layer that potentially dramatically increases page cache effectiveness for many workloads in many environments at a negligible cost. It does this by providing an interface to transcendent memory, which is memory/storage that is not otherwise visible to and/or directly addressable by the kernel. Instead of being discarded, hooks in the reclaim code "put" clean pages to cleancache. Filesystems that "opt-in" may "get" pages from cleancache that were previously put, but pages in cleancache are "ephemeral", meaning they may disappear at any time. And the size of cleancache is entirely dynamic and unknowable to the kernel. Filesystems currently supported by this patchset include ext3, ext4, btrfs, and ocfs2. Other filesystems (especially those built entirely on VFS) should be easy to add, but should first be thoroughly tested to ensure coherency. Details and a FAQ are provided in Documentation/vm/cleancache.txt This first patch of eight in this cleancache series only adds two new documentation files. [v8: minor documentation changes by author] [v3: akpm@linux-foundation.org: document sysfs API] [v3: hch@infradead.org: move detailed description to Documentation/vm] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik Van Riel <riel@redhat.com> Cc: Jan Beulich <JBeulich@novell.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Andreas Dilger <adilger@sun.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Nitin Gupta <ngupta@vflare.org>
2011-05-25mm: Convert i_mmap_lock to a mutexPeter Zijlstra
Straightforward conversion of i_mmap_lock to a mutex. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22Documentation/vm/page-types.c: auto debugfs mount for hwpoison operationChen Gong
page-types.c doesn't supply a way to specify the debugfs path and the original debugfs path is not usual on most machines. This patch supplies a way to auto mount debugfs if needed. This patch is heavily inspired by tools/perf/utils/debugfs.c [akpm@linux-foundation.org: make functions static] [akpm@linux-foundation.org: fix debugfs_mount() signature] Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-17doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymoreMichal Hocko
commit 6837765963 ("mm: remove CONFIG_UNEVICTABLE_LRU config option") has removed the configoption so we should sync up the doc as well. Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-13thp: transparent hugepage support documentationAndrea Arcangeli
Documentation/vm/transhuge.txt Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-06slub: Fix build breakage in Documentation/vmPekka Enberg
This patch fixes a build breakage introduced by commit f5ac4916e9840292edd33c7a52b10364526547f3 ("slub: move slabinfo.c to tools/slub/slabinfo.c") that was repoted by Stephen: After merging the slab tree, today's linux-next build (x86_64 allmodconfig) failed like this: gcc: /scratch/sfr/next/Documentation/vm/slabinfo.c: No such file or directory gcc: no input files Caused by commit f5ac4916e9840292edd33c7a52b10364526547f3 ("slub: move slabinfo.c to tools/slub/slabinfo.c"). Missing update to Documentation/vm/Makefile? Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2010-11-06slub: move slabinfo.c to tools/slub/slabinfo.cChristoph Lameter
We now have a tools directory for these things. Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2010-10-26mm: highmem documentationPeter Zijlstra
Document outlining some of the highmem issues, started by me, edited by David. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-07page-types.c: fix name of unpoison interfaceNaoya Horiguchi
The page-types utility still uses an out of date name for the unpoison interface: debugfs:hwpoison/renew-pfn This patch renames and fixes it. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-09-21Doc: Fix typo s/packages/packagedNikanth Karthikesan
Fix typo s/packages/packaged in Documentation/vm/numa_memory_policy.txt. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
