path: root/Documentation/w1/masters
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-10-04ds2482: Discard obsolete detect methodJean Delvare
There is no point in implementing a detect callback for the DS2482, as this device can't be detected. It was there solely to handle "force" module parameters to instantiate devices, but now we have a better sysfs interface that can do the same. So we can get rid of the ugly module parameters and the detect callback. This shrinks the binary module size by 21%. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Ben Gardner <gardner.ben@gmail.com>
2009-01-08w1: add 1-wire master driver for i.MX27 / i.MX31Sascha Hauer
This patch adds support for the 1-wire master interface for i.MX27 and i.MX31. Signed-off-by: Luotao Fu <l.fu@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12hdq: documentation for OMAP HDQMadhusudhan Chikkature
Add a brief document about omap2430/3430 HDQ/1-wire driver. Signed-off-by: Madhusudhan Chikkature<madhu.cr@ti.com> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16W1: Documentation/w1/masters/ds2490 updateDavid Fries
Provide some additional details about the status of the driver and the ds2490 hardware. Signed-off-by: David Fries <david@fries.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06w1-gpio: add GPIO w1 bus master driverVille Syrjala
Add a GPIO 1-wire bus master driver. The driver used the GPIO API to control the wire and the GPIO pin can be specified using platform data similar to i2c-gpio. The driver was tested with AT91SAM9260 + DS2401. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Add Documentation/{w1,w1/masters}/00-INDEXRob Landley
Two 00-INDEX files under Documentation/w1 Signed-off-by: Rob Landley <rob@landley.net> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-22[PATCH] w1: Replace dscore and ds_w1_bridge with ds2490 driver.Evgeniy Polyakov
2006-03-23[PATCH] W1: Add the DS2482 I2C-to-w1 bridge driver.Evgeniy Polyakov
Signed-off-by: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
