path: root/Documentation/w1
2015-05-24w1: Add support for DS28EA00 sequence to w1-thermMatt Campbell
This patch provides support for the DS28EA00 digital thermometer. The DS28EA00 provides an additional two pins for implementing a sequence detection algorithm. This feature allows you to determine the physical location of the chip in the 1-wire bus without needing pre-existing knowledge of the bus ordering. Support is provided through the sysfs w1_seq file. The file will contain a single line with an integer value representing the device index in the bus starting at 0. Signed-off-by: Matt Campbell <mattrcampbell@gmail.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-24w1: introduce an ability to specify microseconds bus scanning intervalsDmitry Khromov
Some of 1-Wire devices commonly associated with physical access control systems are attached/generate presence for as short as 100 ms - hence the tens-to-hundreds milliseconds scan intervals are required. Signed-off-by: Dmitry Khromov <dk@icelogic.net> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-19w1: new w1_ds2406 driverScott Alfter
Some preliminary work at making use of this driver led me to implement CRC-16 checks on read and write to deal with the occasional glitchiness of the 1-Wire bus. The revised driver (attached) returns an I/O error if the CRC check fails. When reading the chip's state, either you get a valid indication or you get an I/O error. When changing its state, either the change is successful or an I/O error is returned. Signed-off-by: Scott Alfter <scott@alfter.us> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-27w1: optional bundling of netlink kernel repliesDavid Fries
Applications can submit a set of commands in one packet to the kernel, and in some cases it is required such as reading the temperature sensor results. This adds an option W1_CN_BUNDLE to the flags of cn_msg to request the kernel to reply in one packet for efficiency. The cn_msg flags now check for unknown flag values and return an error if one is seen. See "Proper handling of unknown flags in system calls" http://lwn.net/Articles/588444/ This corrects the ack values returned as per the protocol standard, namely the original ack for status messages and seq + 1 for all others such as the data returned from a read. Some of the common variable names have been standardized as follows. struct cn_msg *cn struct w1_netlink_msg *msg struct w1_netlink_cmd *cmd struct w1_master *dev When an argument and a function scope variable would collide, add req_ to the argument. Signed-off-by: David Fries <David@Fries.net> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-18Merge 3.14-rc3 into char-misc-nextGreg Kroah-Hartman
We need the fixes here for future mei and other patches. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-10Documentation/: update 00-INDEX filesHenrik Austad
Some of the 00-INDEX files are somewhat outdated and some folders does not contain 00-INDEX at all. Only outdated (with the notably exception of spi) indexes are touched here, the 169 folders without 00-INDEX has not been touched. New 00-INDEX - spi/* was added in a series of commits dating back to 2006 Added files (missing in (*/)00-INDEX) - dmatest.txt was added by commit 851b7e16a07d ("dmatest: run test via debugfs") - this_cpu_ops.txt was added by commit a1b2a555d637 ("percpu: add documentation on this_cpu operations") - ww-mutex-design.txt was added by commit 040a0a371005 ("mutex: Add support for wound/wait style locks") - bcache.txt was added by commit cafe56359144 ("bcache: A block layer cache") - kernel-per-CPU-kthreads.txt was added by commit 49717cb40410 ("kthread: Document ways of reducing OS jitter due to per-CPU kthreads") - phy.txt was added by commit ff764963479a ("drivers: phy: add generic PHY framework") - block/null_blk was added by commit 12f8f4fc0314 ("null_blk: documentation") - module-signing.txt was added by commit 3cafea307642 ("Add Documentation/module-signing.txt file") - assoc_array.txt was added by commit 3cb989501c26 ("Add a generic associative array implementation.") - arm/IXP4xx was part of the initial repo - arm/cluster-pm-race-avoidance.txt was added by commit 7fe31d28e839 ("ARM: mcpm: introduce helpers for platform coherency exit/setup") - arm/firmware.txt was added by commit 7366b92a77fc ("ARM: Add interface for registering and calling firmware-specific operations") - arm/kernel_mode_neon.txt was added by commit 2afd0a05241d ("ARM: 7825/1: document the use of NEON in kernel mode") - arm/tcm.txt was added by commit bc581770cfdd ("ARM: 5580/2: ARM TCM (Tightly-Coupled Memory) support v3") - arm/vlocks.txt was added by commit 9762f12d3e05 ("ARM: mcpm: Add baremetal voting mutexes") - blackfin/gptimers-example.c, Makefile was added by commit 4b60779d5ea7 ("Blackfin: add an example showing how to use the gptimers API") - devicetree/usage-model.txt was added by commit 31134efc681a ("dt: Linux DT usage model documentation") - fb/api.txt was added by commit fb21c2f42879 ("fbdev: Add FOURCC-based format configuration API") - fb/sm501.txt was added by commit e6a049807105 ("video, sm501: add edid and commandline support") - fb/udlfb.txt was added by commit 96f8d864afd6 ("fbdev: move udlfb out of staging.") - filesystems/Makefile was added by commit 1e0051ae48a2 ("Documentation/fs/: split txt and source files") - filesystems/nfs/nfsd-admin-interfaces.txt was added by commit 8a4c6e19cfed ("nfsd: document kernel interfaces for nfsd configuration") - ide/warm-plug-howto.txt was added by commit f74c91413ec6 ("ide: add warm-plug support for IDE devices (take 2)") - laptops/Makefile was added by commit d49129accc21 ("Documentation/laptop/: split txt and source files") - leds/leds-blinkm.txt was added by commit b54cf35a7f65 ("LEDS: add BlinkM RGB LED driver, documentation and update MAINTAINERS") - leds/ledtrig-oneshot.txt was added by commit 5e417281cde2 ("leds: add oneshot trigger") - leds/ledtrig-transient.txt was added by commit 44e1e9f8e705 ("leds: add new transient trigger for one shot timer activation") - m68k/README.buddha was part of the initial repo - networking/LICENSE.(qla3xxx|qlcnic|qlge) was added by commits 40839129f779, c4e84bde1d59, 5a4faa873782 - networking/Makefile was added by commit 3794f3e812ef ("docsrc: build Documentation/ sources") - networking/i40evf.txt was added by commit 105bf2fe6b32 ("i40evf: add driver to kernel build system") - networking/ipsec.txt was added by commit b3c6efbc36e2 ("xfrm: Add file to document IPsec corner case") - networking/mac80211-auth-assoc-deauth.txt was added by commit 3cd7920a2be8 ("mac80211: add auth/assoc/deauth flow diagram") - networking/netlink_mmap.txt was added by commit 5683264c3981 ("netlink: add documentation for memory mapped I/O") - networking/nf_conntrack-sysctl.txt was added by commit c9f9e0e1597f ("netfilter: doc: add nf_conntrack sysctl api documentation") lan) - networking/team.txt was added by commit 3d249d4ca7d0 ("net: introduce ethernet teaming device") - networking/vxlan.txt was added by commit d342894c5d2f ("vxlan: virtual extensible lan") - power/runtime_pm.txt was added by commit 5e928f77a09a ("PM: Introduce core framework for run-time PM of I/O devices (rev. 17)") - power/charger-manager.txt was added by commit 3bb3dbbd56ea ("power_supply: Add initial Charger-Manager driver") - RCU/lockdep-splat.txt was added by commit d7bd2d68aa2e ("rcu: Document interpretation of RCU-lockdep splats") - s390/kvm.txt was added by 5ecee4b (KVM: s390: API documentation) - s390/qeth.txt was added by commit b4d72c08b358 ("qeth: bridgeport support - basic control") - scheduler/sched-bwc.txt was added by commit 88ebc08ea9f7 ("sched: Add documentation for bandwidth control") - scsi/advansys.txt was added by commit 4bd6d7f35661 ("[SCSI] advansys: Move documentation to Documentation/scsi") - scsi/bfa.txt was added by commit 1ec90174bdb4 ("[SCSI] bfa: add readme file") - scsi/bnx2fc.txt was added by commit 12b8fc10eaf4 ("[SCSI] bnx2fc: Add driver documentation") - scsi/cxgb3i.txt was added by commit c3673464ebc0 ("[SCSI] cxgb3i: Add cxgb3i iSCSI driver.") - scsi/hpsa.txt was added by commit 992ebcf14f3c ("[SCSI] hpsa: Add hpsa.txt to Documentation/scsi") - scsi/link_power_management_policy.txt was added by commit ca77329fb713 ("[libata] Link power management infrastructure") - scsi/osd.txt was added by commit 78e0c621deca ("[SCSI] osd: Documentation for OSD library") - scsi/scsi-parameter.txt was created/moved by commit 163475fb111c ("Documentation: move SCSI parameters to their own text file") - serial/driver was part of the initial repo - serial/n_gsm.txt was added by commit 323e84122ec6 ("n_gsm: add a documentation") - timers/Makefile was added by commit 3794f3e812ef ("docsrc: build Documentation/ sources") - virt/kvm/s390.txt was added by commit d9101fca3d57 ("KVM: s390: diagnose call documentation") - vm/split_page_table_lock was added by commit 49076ec2ccaf ("mm: dynamically allocate page->ptl if it cannot be embedded to struct page") - w1/slaves/w1_ds28e04 was added by commit fbf7f7b4e2ae ("w1: Add 1-wire slave device driver for DS28E04-100") - w1/masters/omap-hdq was added by commit e0a29382c6f5 ("hdq: documentation for OMAP HDQ") - x86/early-microcode.txt was added by commit 0d91ea86a895 ("x86, doc: Documentation for early microcode loading") - x86/earlyprintk.txt was added by commit a1aade478862 ("x86/doc: mini-howto for using earlyprintk=dbgp") - x86/entry_64.txt was added by commit 8b4777a4b50c ("x86-64: Document some of entry_64.S") - x86/pat.txt was added by commit d27554d874c7 ("x86: PAT documentation") Moved files - arm/kernel_user_helpers.txt was moved out of arch/arm/kernel by commit 37b8304642c7 ("ARM: kuser: move interface documentation out of the source code") - efi-stub.txt was moved out of x86/ and down into Documentation/ in commit 4172fe2f8a47 ("EFI stub documentation updates") - laptops/hpfall.c was moved out of hwmon/ and into laptops/ in commit efcfed9bad88 ("Move hp_accel to drivers/platform/x86") - commit 5616c23ad9cd ("x86: doc: move x86-generic documentation from Doc/x86/i386"): * x86/usb-legacy-support.txt * x86/boot.txt * x86/zero_page.txt - power/video_extension.txt was moved to acpi in commit 70e66e4df191 ("ACPI / video: move video_extension.txt to Documentation/acpi") Removed files (left in 00-INDEX) - memory.txt was removed by commit 00ea8990aadf ("memory.txt: remove stray information") - gpio.txt was moved to gpio/ in commit fd8e198cfcaa ("Documentation: gpiolib: document new interface") - networking/DLINK.txt was removed by commit 168e06ae26dd ("drivers/net: delete old parallel port de600/de620 drivers") - serial/hayes-esp.txt was removed by commit f53a2ade0bb9 ("tty: esp: remove broken driver") - s390/TAPE was removed by commit 9e280f669308 ("[S390] remove tape block docu") - vm/locking was removed by commit 57ea8171d2bc ("mm: documentation: remove hopelessly out-of-date locking doc") - laptops/acer-wmi.txt was remvoed by commit 020036678e81 ("acer-wmi: Delete out-of-date documentation") Typos/misc issues - rpc-server-gss.txt was added as knfsd-rpcgss.txt in commit 030d794bf498 ("SUNRPC: Use gssproxy upcall for server RPCGSS authentication.") - commit b88cf73d9278 ("net: add missing entries to Documentation/networking/00-INDEX") * generic-hdlc.txt was added as generic_hdlc.txt * spider_net.txt was added as spider-net.txt - w1/master/mxc-w1 was added as mxc_w1 by commit a5fd9139f74c ("w1: add 1-wire master driver for i.MX27 / i.MX31") - s390/zfcpdump.txt was added as zfcpdump by commit 6920c12a407e ("[S390] Add Documentation/s390/00-INDEX.") Signed-off-by: Henrik Austad <henrik@austad.us> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> [rcu bits] Acked-by: Rob Landley <rob@landley.net> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <robh+dt@kernel.org> Cc: David S. Miller <davem@davemloft.net> Cc: Mark Brown <broonie@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Gleb Natapov <gleb@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Len Brown <len.brown@intel.com> Cc: James Bottomley <JBottomley@parallels.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-07w1: format for DocBook and fixesDavid Fries
Switch the code documentation format style to DocBook format, enable DocBook documentation generation, and fix some comments. Signed-off-by: David Fries <David@Fries.net> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-07w1: ds2490 fix and enable hardware searchDavid Fries
The hardware search was failing without the COMM_RST flag. Enabled the flag and rewrote the function to handle more than one buffer of results and to continuing where the search left off. Remove hardware search note from the limitations now that it works. The "w1: ds2490 USB setup fixes" change went from 23.16 seconds to about 3 seconds, this takes the time for the search down to .307346 seconds. Signed-off-by: David Fries <David@Fries.net> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "The usual stuff from trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) treewide: relase -> release Documentation/cgroups/memory.txt: fix stat file documentation sysctl/net.txt: delete reference to obsolete 2.4.x kernel spinlock_api_smp.h: fix preprocessor comments treewide: Fix typo in printk doc: device tree: clarify stuff in usage-model.txt. open firmware: "/aliasas" -> "/aliases" md: bcache: Fixed a typo with the word 'arithmetic' irq/generic-chip: fix a few kernel-doc entries frv: Convert use of typedef ctl_table to struct ctl_table sgi: xpc: Convert use of typedef ctl_table to struct ctl_table doc: clk: Fix incorrect wording Documentation/arm/IXP4xx fix a typo Documentation/networking/ieee802154 fix a typo Documentation/DocBook/media/v4l fix a typo Documentation/video4linux/si476x.txt fix a typo Documentation/virtual/kvm/api.txt fix a typo Documentation/early-userspace/README fix a typo Documentation/video4linux/soc-camera.txt fix a typo lguest: fix CONFIG_PAE -> CONFIG_x86_PAE in comment ...
2013-06-03w1: add family based automatic module loadingAlexander Stein
This patch allows the 1-wire bus to autoload the corresponding module for each slave being attached. This works similar to bluetooth protocols. Signed-off-by: Alexander Stein <alexander.stein@informatik.tu-chemnitz.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-28doc: fix misspellings with 'codespell' toolAnatol Pomozov
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-18w1: w1_therm: Add force-pullup option for "broken" sensorsMichael Arndt
Signed-off-by: Michael Arndt <michael@scriptkiller.de> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-161-Wire: Add support for the maxim ds1825 temperature sensorRaphael Assenat
This patch adds support for maxim ds1825 based 1-wire temperature sensors. Signed-off-by: Raphael Assenat <raph@8d.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-13w1: Add 1-wire slave device driver for DS28E04-100Markus Franke
Signed-off-by: Markus Franke <franm@hrz.tu-chemnitz.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-01-13w1: DS2423 counter driver and documentationMika Laitio
This is a 1-wire/w1 DS2423 slave driver for reading the values from all 4 counters available DS2423 devices by using standard w1_slave file. In ds2423 the counters are tied to ram pages 12-15 in and each of those ram-pages. Each of these counter values (and asoociated ram page values) are represented as a own line in w1_slave file. Driver has been tested on mips and x86. usage example: cat /sys/bus/w1/devices/1d-00000009b964/w1_slave 00 02 00 00 00 00 00 00 00 6d 38 00 ff ff 00 00 fe ff 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff ff crc=YES c=2 00 02 00 00 00 00 00 00 00 e0 1f 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff ff crc=YES c=2 00 5a 0e 5f 18 00 00 00 00 0b 28 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff ff crc=YES c=408882778 00 05 00 00 00 00 00 00 00 8d 39 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff crc=YES c=5 Patch includes also the documentation. [randy.dunlap@oracle.com: fix ds2423 build, needs to select CRC16] Signed-off-by: Mika Laitio <lamikr@pilppa.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-04-23Documentation/: it's -> its where appropriateFrancis Galiegue
Fix obvious cases of "it's" being used when "its" was meant. Signed-off-by: Francis Galiegue <fgaliegue@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-10-04ds2482: Discard obsolete detect methodJean Delvare
There is no point in implementing a detect callback for the DS2482, as this device can't be detected. It was there solely to handle "force" module parameters to instantiate devices, but now we have a better sysfs interface that can do the same. So we can get rid of the ugly module parameters and the detect callback. This shrinks the binary module size by 21%. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Ben Gardner <gardner.ben@gmail.com>
2009-01-08w1: send status messages after command processingEvgeniy Polyakov
Send completion status of the commands to the userspace. Message and protocol are described in the documentation. Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: Paul Alfille <paul.alfille@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08w1: added w1 reset commandEvgeniy Polyakov
Command which allows to reset the bus. Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: Paul Alfille <paul.alfille@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08w1: documentation updateEvgeniy Polyakov
Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08w1: add 1-wire master driver for i.MX27 / i.MX31Sascha Hauer
This patch adds support for the 1-wire master interface for i.MX27 and i.MX31. Signed-off-by: Luotao Fu <l.fu@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12hdq: documentation for OMAP HDQMadhusudhan Chikkature
Add a brief document about omap2430/3430 HDQ/1-wire driver. Signed-off-by: Madhusudhan Chikkature<madhu.cr@ti.com> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16W1: Documentation/w1/masters/ds2490 updateDavid Fries
Provide some additional details about the status of the driver and the ds2490 hardware. Signed-off-by: David Fries <david@fries.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16W1: Document add, remove, search_count, and pullup.David Fries
Document w1_master_add, w1_master_remove, search_count, and pullup. Signed-off-by: David Fries <david@fries.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16W1: feature, w1_therm.c use strong pullup and documentationDavid Fries
Added strong pullup to thermal sensor driver and general documentation on the sensor. Signed-off-by: David Fries <david@fries.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06w1-gpio: add GPIO w1 bus master driverVille Syrjala
Add a GPIO 1-wire bus master driver. The driver used the GPIO API to control the wire and the GPIO pin can be specified using platform data similar to i2c-gpio. The driver was tested with AT91SAM9260 + DS2401. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Add Documentation/{w1,w1/masters}/00-INDEXRob Landley
Two 00-INDEX files under Documentation/w1 Signed-off-by: Rob Landley <rob@landley.net> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-22[PATCH] w1: Userspace communication protocol over connector.Evgeniy Polyakov
There are three types of messages between w1 core and userspace: 1. Events. They are generated each time new master or slave device found either due to automatic or requested search. 2. Userspace commands. Includes read/write and search/alarm search comamnds. 3. Replies to userspace commands. From: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] w1: Replace dscore and ds_w1_bridge with ds2490 driver.Evgeniy Polyakov
2006-06-22[PATCH] w1: Added default generic read/write operations.Evgeniy Polyakov
Special file in each w1 slave device's directory called "rw" is created each time new slave and no appropriate w1 family is registered. "rw" file supports read and write operations, which allows to perform almost any kind of operations. Each logical operation is a transaction in nature, which can contain several (two or one) low-level operations. Let's see how one can read EEPROM context: 1. one must write control buffer, i.e. buffer containing command byte and two byte address. At this step bus is reset and appropriate device is selected using either W1_SKIP_ROM or W1_MATCH_ROM command. Then provided control buffer is being written to the wire. 2. reading. This will issue reading eeprom response. It is possible that between 1. and 2. w1 master thread will reset bus for searching and slave device will be even removed, but in this case 0xff will be read, since no device was selected. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] W1: Add the DS2482 I2C-to-w1 bridge driver.Evgeniy Polyakov
Signed-off-by: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] w1: Updates the w1 documentation (w1.generic)Evgeniy Polyakov
Updates the w1 documentation (w1.generic) Signed-off-by: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
