path: root/Documentation/x86
2016-10-10Merge branch 'mm-pkeys-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull protection keys syscall interface from Thomas Gleixner: "This is the final step of Protection Keys support which adds the syscalls so user space can actually allocate keys and protect memory areas with them. Details and usage examples can be found in the documentation. The mm side of this has been acked by Mel" * 'mm-pkeys-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/pkeys: Update documentation x86/mm/pkeys: Do not skip PKRU register if debug registers are not used x86/pkeys: Fix pkeys build breakage for some non-x86 arches x86/pkeys: Add self-tests x86/pkeys: Allow configuration of init_pkru x86/pkeys: Default to a restrictive init PKRU pkeys: Add details of system call use to Documentation/ generic syscalls: Wire up memory protection keys syscalls x86: Wire up protection keys system calls x86/pkeys: Allocation/free syscalls x86/pkeys: Make mprotect_key() mask off additional vm_flags mm: Implement new pkey_mprotect() system call x86/pkeys: Add fault handling for PF_PK page fault bit
2016-10-05x86/pkeys: Update documentationDave Hansen
There are a few items that have gotten stale in the protection keys documentation. The config option description only applied to the execute-only support and is not accurate for the current code. There was also a typo with the number of system calls. I also wanted to call out that pkey_set() is not a kernel-provided facility, and where to find an implementation. Signed-off-by: Dave Hansen <dave.hansen@intel.com> Cc: Dave Hansen <dave@sr71.net> Cc: linux-doc@vger.kernel.org Cc: corbet@lwn.net Link: http://lkml.kernel.org/r/20161004163857.71E0D6F6@viggo.jf.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-09-09pkeys: Add details of system call use to Documentation/Dave Hansen
This spells out all of the pkey-related system calls that we have and provides some example code fragments to demonstrate how we expect them to be used. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: linux-arch@vger.kernel.org Cc: Dave Hansen <dave@sr71.net> Cc: mgorman@techsingularity.net Cc: arnd@arndb.de Cc: linux-api@vger.kernel.org Cc: linux-mm@kvack.org Cc: luto@kernel.org Cc: akpm@linux-foundation.org Cc: torvalds@linux-foundation.org Link: http://lkml.kernel.org/r/20160729163020.59350E33@viggo.jf.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-09-06x86: fix memory ranges in mm documentationLorenzo Stoakes
This is a trivial fix to correct upper bound addresses to always be inclusive. Previously, the majority of ranges specified were inclusive with a small minority specifying an exclusive upper bound. This patch fixes this inconsistency. Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-07Merge tag 'doc-4.8-fixes' of git://git.lwn.net/linuxLinus Torvalds
Pull documentation fixes from Jonathan Corbet: "Three fixes for the docs build, including removing an annoying warning on 'make help' if sphinx isn't present" * tag 'doc-4.8-fixes' of git://git.lwn.net/linux: DocBook: use DOCBOOKS="" to ignore DocBooks instead of IGNORE_DOCBOOKS=1 Documenation: update cgroup's document path Documentation/sphinx: do not warn about missing tools in 'make help'
2016-08-03Documenation: update cgroup's document pathseokhoon.yoon
cgroup's document path is changed to "cgroup-v1". update it. Signed-off-by: seokhoon.yoon <iamyooon@gmail.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-07-27Merge branch 'linus' into x86/microcode, to pick up merge window changesIngo Molnar
2016-07-25Merge branch 'x86-boot-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 boot updates from Ingo Molnar: "The main changes: - add initial commits to randomize kernel memory section virtual addresses, enabled via a new kernel option: RANDOMIZE_MEMORY (Thomas Garnier, Kees Cook, Baoquan He, Yinghai Lu) - enhance KASLR (RANDOMIZE_BASE) physical memory randomization (Kees Cook) - EBDA/BIOS region boot quirk cleanups (Andy Lutomirski, Ingo Molnar) - misc cleanups/fixes" * 'x86-boot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/boot: Simplify EBDA-vs-BIOS reservation logic x86/boot: Clarify what x86_legacy_features.reserve_bios_regions does x86/boot: Reorganize and clean up the BIOS area reservation code x86/mm: Do not reference phys addr beyond kernel x86/mm: Add memory hotplug support for KASLR memory randomization x86/mm: Enable KASLR for vmalloc memory regions x86/mm: Enable KASLR for physical mapping memory regions x86/mm: Implement ASLR for kernel memory regions x86/mm: Separate variable for trampoline PGD x86/mm: Add PUD VA support for physical mapping x86/mm: Update physical mapping variable names x86/mm: Refactor KASLR entropy functions x86/KASLR: Fix boot crash with certain memory configurations x86/boot/64: Add forgotten end of function marker x86/KASLR: Allow randomization below the load address x86/KASLR: Extend kernel image physical address randomization to addresses larger than 4G x86/KASLR: Randomize virtual address separately x86/KASLR: Clarify identity map interface x86/boot: Refuse to build with data relocations x86/KASLR, x86/power: Remove x86 hibernation restrictions
2016-07-08x86/mm: Implement ASLR for kernel memory regionsThomas Garnier
Randomizes the virtual address space of kernel memory regions for x86_64. This first patch adds the infrastructure and does not randomize any region. The following patches will randomize the physical memory mapping, vmalloc and vmemmap regions. This security feature mitigates exploits relying on predictable kernel addresses. These addresses can be used to disclose the kernel modules base addresses or corrupt specific structures to elevate privileges bypassing the current implementation of KASLR. This feature can be enabled with the CONFIG_RANDOMIZE_MEMORY option. The order of each memory region is not changed. The feature looks at the available space for the regions based on different configuration options and randomizes the base and space between each. The size of the physical memory mapping is the available physical memory. No performance impact was detected while testing the feature. Entropy is generated using the KASLR early boot functions now shared in the lib directory (originally written by Kees Cook). Randomization is done on PGD & PUD page table levels to increase possible addresses. The physical memory mapping code was adapted to support PUD level virtual addresses. This implementation on the best configuration provides 30,000 possible virtual addresses in average for each memory region. An additional low memory page is used to ensure each CPU can start with a PGD aligned virtual address (for realmode). x86/dump_pagetable was updated to correctly display each region. Updated documentation on x86_64 memory layout accordingly. Performance data, after all patches in the series: Kernbench shows almost no difference (-+ less than 1%): Before: Average Optimal load -j 12 Run (std deviation): Elapsed Time 102.63 (1.2695) User Time 1034.89 (1.18115) System Time 87.056 (0.456416) Percent CPU 1092.9 (13.892) Context Switches 199805 (3455.33) Sleeps 97907.8 (900.636) After: Average Optimal load -j 12 Run (std deviation): Elapsed Time 102.489 (1.10636) User Time 1034.86 (1.36053) System Time 87.764 (0.49345) Percent CPU 1095 (12.7715) Context Switches 199036 (4298.1) Sleeps 97681.6 (1031.11) Hackbench shows 0% difference on average (hackbench 90 repeated 10 times): attemp,before,after 1,0.076,0.069 2,0.072,0.069 3,0.066,0.066 4,0.066,0.068 5,0.066,0.067 6,0.066,0.069 7,0.067,0.066 8,0.063,0.067 9,0.067,0.065 10,0.068,0.071 average,0.0677,0.0677 Signed-off-by: Thomas Garnier <thgarnie@google.com> Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Alexander Kuleshov <kuleshovmail@gmail.com> Cc: Alexander Popov <alpopov@ptsecurity.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Baoquan He <bhe@redhat.com> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bp@suse.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Dave Young <dyoung@redhat.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jan Beulich <JBeulich@suse.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Lv Zheng <lv.zheng@intel.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Toshi Kani <toshi.kani@hpe.com> Cc: Xiao Guangrong <guangrong.xiao@linux.intel.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: kernel-hardening@lists.openwall.com Cc: linux-doc@vger.kernel.org Link: http://lkml.kernel.org/r/1466556426-32664-6-git-send-email-keescook@chromium.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-07-01x86/Documentation: Fix various typos in Documentation/x86/ filesMasanari Iida
Signed-off-by: Masanari Iida <standby24x7@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: corbet@lwn.net Cc: linux-doc@vger.kernel.org Link: http://lkml.kernel.org/r/20160701034601.30308-1-standby24x7@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-06-08Documentation/microcode: Document some aspects for more clarityBorislav Petkov
Document that builtin microcode is 64-bit only. Also, improve/add comments to places. Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-doc@vger.kernel.org Link: http://lkml.kernel.org/r/1465225850-7352-10-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-05-19Merge tag 'docs-for-linus' of git://git.lwn.net/linuxLinus Torvalds
Pull Documentation updates from Jon Corbet: "A bit busier this time around. The most interesting thing (IMO) this time around is some beginning infrastructural work to allow documents to be written using restructured text. Maybe someday, in a galaxy far far away, we'll be able to eliminate the DocBook dependency and have a much better integrated set of kernel docs. Someday. Beyond that, there's a new document on security hardening from Kees, the movement of some sample code over to samples/, a number of improvements to the serial docs from Geert, and the usual collection of corrections, typo fixes, etc" * tag 'docs-for-linus' of git://git.lwn.net/linux: (55 commits) doc: self-protection: provide initial details serial: doc: Use port->state instead of info serial: doc: Always refer to tty_port->mutex Documentation: vm: Spelling s/paltform/platform/g Documentation/memcg: update kmem limit doc as codes behavior docproc: print a comment about autogeneration for rst output docproc: add support for reStructuredText format via --rst option docproc: abstract terminating lines at first space docproc: abstract docproc directive detection docproc: reduce unnecessary indentation docproc: add variables for subcommand and filename kernel-doc: use rst C domain directives and references for types kernel-doc: produce RestructuredText output kernel-doc: rewrite usage description, remove duplicated comments Doc: correct the location of sysrq.c Documentation: fix common spelling mistakes samples: v4l: from Documentation to samples directory samples: connector: from Documentation to samples directory Documentation: xillybus: fix spelling mistake Documentation: x86: fix spelling mistakes ...
2016-04-28Documentation: x86: fix spelling mistakesEric Engestrom
Signed-off-by: Eric Engestrom <eric@engestrom.ch> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-04-22Merge branch 'x86/urgent' into x86/asm, to fix semantic conflictIngo Molnar
'cpu_has_pse' has changed to boot_cpu_has(X86_FEATURE_PSE), fix this up in the merge commit when merging the x86/urgent tree that includes the following commit: 103f6112f253 ("x86/mm/xen: Suppress hugetlbfs in PV guests") Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-04-22x86/doc: Correct limits in Documentation/x86/x86_64/mm.txtJuergen Gross
Correct the size of the module mapping space and the maximum available physical memory size of current processors. Signed-off-by: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: corbet@lwn.net Cc: linux-doc@vger.kernel.org Link: http://lkml.kernel.org/r/1461310504-15977-1-git-send-email-jgross@suse.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-04-13Merge branch 'x86/urgent' into x86/asm to pick up dependent fixesIngo Molnar
2016-03-29x86/pat: Document the PAT initialization sequenceToshi Kani
Update PAT documentation to describe how PAT is initialized under various configurations. Signed-off-by: Toshi Kani <toshi.kani@hpe.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bp@suse.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Luis R. Rodriguez <mcgrof@suse.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Toshi Kani <toshi.kani@hp.com> Cc: elliott@hpe.com Cc: konrad.wilk@oracle.com Cc: paul.gortmaker@windriver.com Cc: xen-devel@lists.xenproject.org Link: http://lkml.kernel.org/r/1458769323-24491-8-git-send-email-toshi.kani@hpe.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-03-29x86/mm/pkeys: Add missing DocumentationDave Hansen
Stefan Richter noticed that the X86_INTEL_MEMORY_PROTECTION_KEYS option in arch/x86/Kconfig references Documentation/x86/protection-keys.txt, but the file does not exist. This is a patch merging mishap: the final (v8) version of the pkeys series did not include the documentation patch 32 and v7 included. Add it now. Reported-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave@sr71.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/20151214190634.426BEE41@viggo.jf.intel.com [ Added changelog. ] Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-03-29x86/Documentation: Start documenting x86 topologyBorislav Petkov
This should contain important aspects of how we represent the system topology on x86. If people have questions about it and this file doesn't answer it, then it must be updated. Signed-off-by: Borislav Petkov <bp@suse.de> Link: http://lkml.kernel.org/r/20160328095609.GD26651@pd.tnic Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-03-20Merge branch 'efi-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull EFI updates from Ingo Molnar: "The main changes are: - Use separate EFI page tables when executing EFI firmware code. This isolates the EFI context from the rest of the kernel, which has security and general robustness advantages. (Matt Fleming) - Run regular UEFI firmware with interrupts enabled. This is already the status quo under other OSs. (Ard Biesheuvel) - Various x86 EFI enhancements, such as the use of non-executable attributes for EFI memory mappings. (Sai Praneeth Prakhya) - Various arm64 UEFI enhancements. (Ard Biesheuvel) - ... various fixes and cleanups. The separate EFI page tables feature got delayed twice already, because it's an intrusive change and we didn't feel confident about it - third time's the charm we hope!" * 'efi-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (37 commits) x86/mm/pat: Fix boot crash when 1GB pages are not supported by the CPU x86/efi: Only map kernel text for EFI mixed mode x86/efi: Map EFI_MEMORY_{XP,RO} memory region bits to EFI page tables x86/mm/pat: Don't implicitly allow _PAGE_RW in kernel_map_pages_in_pgd() efi/arm*: Perform hardware compatibility check efi/arm64: Check for h/w support before booting a >4 KB granular kernel efi/arm: Check for LPAE support before booting a LPAE kernel efi/arm-init: Use read-only early mappings efi/efistub: Prevent __init annotations from being used arm64/vmlinux.lds.S: Handle .init.rodata.xxx and .init.bss sections efi/arm64: Drop __init annotation from handle_kernel_image() x86/mm/pat: Use _PAGE_GLOBAL bit for EFI page table mappings efi/runtime-wrappers: Run UEFI Runtime Services with interrupts enabled efi: Reformat GUID tables to follow the format in UEFI spec efi: Add Persistent Memory type name efi: Add NV memory attribute x86/efi: Show actual ending addresses in efi_print_memmap x86/efi/bgrt: Don't ignore the BGRT if the 'valid' bit is 0 efivars: Use to_efivar_entry efi: Runtime-wrapper: Get rid of the rtc_lock spinlock ...
2016-03-15Merge branch 'x86-microcode-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 microcode updates from Ingo Molnar: "The biggest change in this cycle was the separation of the microcode loading mechanism from the initrd code plus the support of built-in microcode images. There were also lots cleanups and general restructuring (by Borislav Petkov)" * 'x86-microcode-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) x86/microcode/intel: Drop orig_sum from ext signature checksum x86/microcode/intel: Improve microcode sanity-checking error messages x86/microcode/intel: Merge two consecutive if-statements x86/microcode/intel: Get rid of DWSIZE x86/microcode/intel: Change checksum variables to u32 x86/microcode: Use kmemdup() rather than duplicating its implementation x86/microcode: Remove unnecessary paravirt_enabled check x86/microcode: Document builtin microcode loading method x86/microcode/AMD: Issue microcode updated message later x86/microcode/intel: Cleanup get_matching_model_microcode() x86/microcode/intel: Remove unused arg of get_matching_model_microcode() x86/microcode/intel: Rename mc_saved_in_initrd x86/microcode/intel: Use *wrmsrl variants x86/microcode/intel: Cleanup apply_microcode_intel() x86/microcode/intel: Move the BUG_ON up and turn it into WARN_ON x86/microcode/intel: Rename mc_intel variable to mc x86/microcode/intel: Rename mc_saved_count to num_saved x86/microcode/intel: Rename local variables of type struct mc_saved_data x86/microcode/AMD: Drop redundant printk prefix x86/microcode: Issue update message only once ...
2016-03-15Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 asm updates from Ingo Molnar: "This is another big update. Main changes are: - lots of x86 system call (and other traps/exceptions) entry code enhancements. In particular the complex parts of the 64-bit entry code have been migrated to C code as well, and a number of dusty corners have been refreshed. (Andy Lutomirski) - vDSO special mapping robustification and general cleanups (Andy Lutomirski) - cpufeature refactoring, cleanups and speedups (Borislav Petkov) - lots of other changes ..." * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (64 commits) x86/cpufeature: Enable new AVX-512 features x86/entry/traps: Show unhandled signal for i386 in do_trap() x86/entry: Call enter_from_user_mode() with IRQs off x86/entry/32: Change INT80 to be an interrupt gate x86/entry: Improve system call entry comments x86/entry: Remove TIF_SINGLESTEP entry work x86/entry/32: Add and check a stack canary for the SYSENTER stack x86/entry/32: Simplify and fix up the SYSENTER stack #DB/NMI fixup x86/entry: Only allocate space for tss_struct::SYSENTER_stack if needed x86/entry: Vastly simplify SYSENTER TF (single-step) handling x86/entry/traps: Clear DR6 early in do_debug() and improve the comment x86/entry/traps: Clear TIF_BLOCKSTEP on all debug exceptions x86/entry/32: Restore FLAGS on SYSEXIT x86/entry/32: Filter NT and speed up AC filtering in SYSENTER x86/entry/compat: In SYSENTER, sink AC clearing below the existing FLAGS test selftests/x86: In syscall_nt, test NT|TF as well x86/asm-offsets: Remove PARAVIRT_enabled x86/entry/32: Introduce and use X86_BUG_ESPFIX instead of paravirt_enabled uprobes: __create_xol_area() must nullify xol_mapping.fault x86/cpufeature: Create a new synthetic cpu capability for machine check recovery ...
2016-02-18x86/cpufeature: Create a new synthetic cpu capability for machine check recoveryTony Luck
The Intel Software Developer Manual describes bit 24 in the MCG_CAP MSR: MCG_SER_P (software error recovery support present) flag, bit 24 — Indicates (when set) that the processor supports software error recovery But only some models with this capability bit set will actually generate recoverable machine checks. Check the model name and set a synthetic capability bit. Provide a command line option to set this bit anyway in case the kernel doesn't recognise the model name. Signed-off-by: Tony Luck <tony.luck@intel.com> Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/2e5bfb23c89800a036fb8a45fa97a74bb16bc362.1455732970.git.tony.luck@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-18x86/mm: Expand the exception table logic to allow new handling optionsTony Luck
Huge amounts of help from Andy Lutomirski and Borislav Petkov to produce this. Andy provided the inspiration to add classes to the exception table with a clever bit-squeezing trick, Boris pointed out how much cleaner it would all be if we just had a new field. Linus Torvalds blessed the expansion with: ' I'd rather not be clever in order to save just a tiny amount of space in the exception table, which isn't really criticial for anybody. ' The third field is another relative function pointer, this one to a handler that executes the actions. We start out with three handlers: 1: Legacy - just jumps the to fixup IP 2: Fault - provide the trap number in %ax to the fixup code 3: Cleaned up legacy for the uaccess error hack Signed-off-by: Tony Luck <tony.luck@intel.com> Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/f6af78fcbd348cf4939875cfda9c19689b5e50b8.1455732970.git.tony.luck@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-09x86/microcode: Document builtin microcode loading methodBorislav Petkov
Add some text and an example to Documentation/x86/early-microcode.txt explaining how to build in microcode. Tested-by: Thomas Voegtle <tv@lio96.de> Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1454499225-21544-18-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-11-29Documentation/x86: Update EFI memory region descriptionMatt Fleming
Make it clear that the EFI page tables are only available during EFI runtime calls since that subject has come up a fair numbers of times in the past. Additionally, add the EFI region start and end addresses to the table so that it's possible to see at a glance where they fall in relation to other regions. Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk> Reviewed-by: Borislav Petkov <bp@suse.de> Acked-by: Borislav Petkov <bp@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sai Praneeth Prakhya <sai.praneeth.prakhya@intel.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Toshi Kani <toshi.kani@hp.com> Cc: linux-efi@vger.kernel.org Link: http://lkml.kernel.org/r/1448658575-17029-7-git-send-email-matt@codeblueprint.co.uk Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-01Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm updates from Ingo Molnar: "The dominant change in this cycle was the continued work to isolate kernel drivers from MTRR legacies: this tree gets rid of all kernel internal driver interfaces to MTRRs (mostly by rewriting it to proper PAT interfaces), the only access left is the /proc/mtrr ABI. This work was done by Luis R Rodriguez. There's also some related PCI interface additions for which I've Cc:-ed Bjorn" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits) x86/mm/mtrr: Remove kernel internal MTRR interfaces: unexport mtrr_add() and mtrr_del() s390/io: Add pci_iomap_wc() and pci_iomap_wc_range() drivers/dma/iop-adma: Use dma_alloc_writecombine() kernel-style drivers/video/fbdev/vt8623fb: Use arch_phys_wc_add() and pci_iomap_wc() drivers/video/fbdev/s3fb: Use arch_phys_wc_add() and pci_iomap_wc() drivers/video/fbdev/arkfb.c: Use arch_phys_wc_add() and pci_iomap_wc() PCI: Add pci_iomap_wc() variants drivers/video/fbdev/gxt4500: Use pci_ioremap_wc_bar() to map framebuffer drivers/video/fbdev/kyrofb: Use arch_phys_wc_add() and pci_ioremap_wc_bar() drivers/video/fbdev/i740fb: Use arch_phys_wc_add() and pci_ioremap_wc_bar() PCI: Add pci_ioremap_wc_bar() x86/mm: Make kernel/check.c explicitly non-modular x86/mm/pat: Make mm/pageattr[-test].c explicitly non-modular x86/mm/pat: Add comments to cachemode translation tables arch/*/io.h: Add ioremap_uc() to all architectures drivers/video/fbdev/atyfb: Use arch_phys_wc_add() and ioremap_wc() drivers/video/fbdev/atyfb: Replace MTRR UC hole with strong UC drivers/video/fbdev/atyfb: Clarify ioremap() base and length used drivers/video/fbdev/atyfb: Carve out framebuffer length fudging into a helper x86/mm, asm-generic: Add IOMMU ioremap_uc() variant default ...
2015-09-01Merge branch 'x86-boot-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 boot updates from Ingo Molnar: "The main x86 bootup related changes in this cycle were: - more boot time optimizations. (Len Brown) - implement hex output to allow the debugging of early bootup parameters. (Kees Cook) - remove obsolete MCA leftovers. (Paolo Pisati)" * 'x86-boot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/smpboot: Remove APIC.wait_for_init_deassert and atomic init_deasserted x86/smpboot: Remove SIPI delays from cpu_up() x86/smpboot: Remove udelay(100) when polling cpu_callin_map x86/smpboot: Remove udelay(100) when polling cpu_initialized_map x86/boot: Obsolete the MCA sys_desc_table x86/boot: Add hex output for debugging
2015-08-28x86/mm/mtrr: Remove kernel internal MTRR interfaces: unexport mtrr_add() and ↵Luis R. Rodriguez
mtrr_del() The effort to replace mtrr_add() with architecture agnostic arch_phys_wc_add() is complete, this will ensure write-combining implementations (PAT on x86) is taken advantage instead of using MTRR. With the effort done now, hide direct MTRR access for drivers. The legacy user-space /proc/mtrr ABI is not affected. Update x86 documentation on MTRR to reflect the completion of the phasing out of direct access to MTRR, also add a note on platform firmware code use of MTRRs based on the obituary discussion of MTRRs on Linux [0]. [0] http://lkml.kernel.org/r/1438991330.3109.196.camel@hp.com Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com> Cc: <syrjala@sci.fi> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Walls <awalls@md.metrocast.net> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Borislav Petkov <bp@suse.de> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Dave Airlie <airlied@redhat.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Davidlohr Bueso <dbueso@suse.de> Cc: Doug Ledford <dledford@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Suresh Siddha <sbsiddha@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Toshi Kani <toshi.kani@hp.com> Cc: Ville Syrjälä <syrjala@sci.fi> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: airlied@linux.ie Cc: benh@kernel.crashing.org Cc: bhelgaas@google.com Cc: dan.j.williams@intel.com Cc: konrad.wilk@oracle.com Cc: linux-fbdev@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: linux-media@vger.kernel.org Cc: mst@redhat.com Cc: netdev@vger.kernel.org Cc: vinod.koul@intel.com Cc: xen-devel@lists.xensource.com Link: http://lkml.kernel.org/r/1440443613-13696-12-git-send-email-mcgrof@do-not-panic.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-24Documentation/x86: Rename IRQSTACKSIZE to IRQ_STACK_SIZEAlexander Kuleshov
The IRQSTACKSIZE was renamed to the IRQ_STACK_SIZE in the (26f80bd6a9 x86-64: Convert irqstacks to per-cpu) commit, but it still named IRQSTACKSIZE in the documentation. This patch fixes this. Signed-off-by: Alexander Kuleshov <kuleshovmail@gmail.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2015-07-21x86/boot: Obsolete the MCA sys_desc_tablePaolo Pisati
The kernel does not support the MCA bus anymroe, so mark sys_desc_table as obsolete: remove any reference from the code together with the remaining of MCA logic. bloat-o-meter output: add/remove: 0/0 grow/shrink: 0/2 up/down: 0/-55 (-55) function old new delta i386_start_kernel 128 119 -9 setup_arch 1421 1375 -46 Signed-off-by: Paolo Pisati <p.pisati@gmail.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1437409430-8491-1-git-send-email-p.pisati@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-02x86/asm/entry/64: Update path namesJames C Boyd
The paths mentioned in this file weren't updated through some file rename commits. Fix them to refer to the correct path. Signed-off-by: James C Boyd <jcboyd.dev@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: corbet@lwn.net Cc: trivial@kernel.org Link: http://lkml.kernel.org/r/1435781606-3037-1-git-send-email-jcboyd.dev@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-30Merge branch 'x86/boot' into x86/urgentIngo Molnar
Merge branch that got ready. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-22Merge branch 'x86-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 core updates from Ingo Molnar: "There were so many changes in the x86/asm, x86/apic and x86/mm topics in this cycle that the topical separation of -tip broke down somewhat - so the result is a more traditional architecture pull request, collected into the 'x86/core' topic. The topics were still maintained separately as far as possible, so bisectability and conceptual separation should still be pretty good - but there were a handful of merge points to avoid excessive dependencies (and conflicts) that would have been poorly tested in the end. The next cycle will hopefully be much more quiet (or at least will have fewer dependencies). The main changes in this cycle were: * x86/apic changes, with related IRQ core changes: (Jiang Liu, Thomas Gleixner) - This is the second and most intrusive part of changes to the x86 interrupt handling - full conversion to hierarchical interrupt domains: [IOAPIC domain] ----- | [MSI domain] --------[Remapping domain] ----- [ Vector domain ] | (optional) | [HPET MSI domain] ----- | | [DMAR domain] ----------------------------- | [Legacy domain] ----------------------------- This now reflects the actual hardware and allowed us to distangle the domain specific code from the underlying parent domain, which can be optional in the case of interrupt remapping. It's a clear separation of functionality and removes quite some duct tape constructs which plugged the remap code between ioapic/msi/hpet and the vector management. - Intel IOMMU IRQ remapping enhancements, to allow direct interrupt injection into guests (Feng Wu) * x86/asm changes: - Tons of cleanups and small speedups, micro-optimizations. This is in preparation to move a good chunk of the low level entry code from assembly to C code (Denys Vlasenko, Andy Lutomirski, Brian Gerst) - Moved all system entry related code to a new home under arch/x86/entry/ (Ingo Molnar) - Removal of the fragile and ugly CFI dwarf debuginfo annotations. Conversion to C will reintroduce many of them - but meanwhile they are only getting in the way, and the upstream kernel does not rely on them (Ingo Molnar) - NOP handling refinements. (Borislav Petkov) * x86/mm changes: - Big PAT and MTRR rework: making the code more robust and preparing to phase out exposing direct MTRR interfaces to drivers - in favor of using PAT driven interfaces (Toshi Kani, Luis R Rodriguez, Borislav Petkov) - New ioremap_wt()/set_memory_wt() interfaces to support Write-Through cached memory mappings. This is especially important for good performance on NVDIMM hardware (Toshi Kani) * x86/ras changes: - Add support for deferred errors on AMD (Aravind Gopalakrishnan) This is an important RAS feature which adds hardware support for poisoned data. That means roughly that the hardware marks data which it has detected as corrupted but wasn't able to correct, as poisoned data and raises an APIC interrupt to signal that in the form of a deferred error. It is the OS's responsibility then to take proper recovery action and thus prolonge system lifetime as far as possible. - Add support for Intel "Local MCE"s: upcoming CPUs will support CPU-local MCE interrupts, as opposed to the traditional system- wide broadcasted MCE interrupts (Ashok Raj) - Misc cleanups (Borislav Petkov) * x86/platform changes: - Intel Atom SoC updates ... and lots of other cleanups, fixlets and other changes - see the shortlog and the Git log for details" * 'x86-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (222 commits) x86/hpet: Use proper hpet device number for MSI allocation x86/hpet: Check for irq==0 when allocating hpet MSI interrupts x86/mm/pat, drivers/infiniband/ipath: Use arch_phys_wc_add() and require PAT disabled x86/mm/pat, drivers/media/ivtv: Use arch_phys_wc_add() and require PAT disabled x86/platform/intel/baytrail: Add comments about why we disabled HPET on Baytrail genirq: Prevent crash in irq_move_irq() genirq: Enhance irq_data_to_desc() to support hierarchy irqdomain iommu, x86: Properly handle posted interrupts for IOMMU hotplug iommu, x86: Provide irq_remapping_cap() interface iommu, x86: Setup Posted-Interrupts capability for Intel iommu iommu, x86: Add cap_pi_support() to detect VT-d PI capability iommu, x86: Avoid migrating VT-d posted interrupts iommu, x86: Save the mode (posted or remapped) of an IRTE iommu, x86: Implement irq_set_vcpu_affinity for intel_ir_chip iommu: dmar: Provide helper to copy shared irte fields iommu: dmar: Extend struct irte for VT-d Posted-Interrupts iommu: Add new member capability to struct irq_remap_ops x86/asm/entry/64: Disentangle error_entry/exit gsbase/ebx/usermode code x86/asm/entry/32: Shorten __audit_syscall_entry() args preparation x86/asm/entry/32: Explain reloading of registers after __audit_syscall_entry() ...
2015-06-22Merge branch 'x86-efi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 EFI updates from Ingo Molnar: "EFI changes: - Use idiomatic negative error values in efivar_create_sysfs_entry() instead of returning '1' to indicate error (Dan Carpenter) - Implement new support to expose the EFI System Resource Tables in sysfs, which provides information for performing firmware updates (Peter Jones) - Documentation cleanup in the EFI handover protocol section which falsely claimed that 'cmdline_size' needed to be filled out by the boot loader (Alex Smith) - Align the order of SMBIOS tables in /sys/firmware/efi/systab to match the way that we do things for ACPI and add documentation to Documentation/ABI (Jean Delvare)" * 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: efi: Work around ia64 build problem with ESRT driver efi: Add 'systab' information to Documentation/ABI efi: dmi: List SMBIOS3 table before SMBIOS table efi/esrt: Fix some compiler warnings x86, doc: Remove cmdline_size from list of fields to be filled in for EFI handover efi: Add esrt support efi: efivar_create_sysfs_entry() should return negative error codes
2015-06-22Merge branches 'x86/apic', 'x86/asm', 'x86/mm' and 'x86/platform' into ↵Ingo Molnar
x86/core, to merge last updates Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-08Merge branch 'x86/asm' into x86/core, to prepare for new patchIngo Molnar
Collect all changes to arch/x86/entry/entry_64.S, before applying patch that changes most of the file. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-08x86/asm/entry: Rename compat syscall entry pointsIngo Molnar
Rename the following system call entry points: ia32_cstar_target -> entry_SYSCALL_compat ia32_syscall -> entry_INT80_compat The generic naming scheme for x86 system call entry points is: entry_MNEMONIC_qualifier where 'qualifier' is one of _32, _64 or _compat. Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-07Merge branch 'x86/ras' into x86/core, to fix conflictsIngo Molnar
Conflicts: arch/x86/include/asm/irq_vectors.h Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-07x86/mce: Add infrastructure to support Local MCEAshok Raj
Initialize and prepare for handling LMCEs. Add a boot-time option to disable LMCEs. Signed-off-by: Ashok Raj <ashok.raj@intel.com> [ Simplify stuff, align statements for better readability, reflow comments; kill unused lmce_clear(); save us an MSR write if LMCE is already enabled. ] Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: linux-edac <linux-edac@vger.kernel.org> Link: http://lkml.kernel.org/r/1433436928-31903-16-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-07x86/mm/pat: Add set_memory_wt() for Write-Through typeToshi Kani
Now that reserve_ram_pages_type() accepts the WT type, add set_memory_wt(), set_memory_array_wt() and set_pages_array_wt() in order to be able to set memory to Write-Through page cache mode. Also, extend ioremap_change_attr() to accept the WT type. Signed-off-by: Toshi Kani <toshi.kani@hp.com> Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Elliott@hp.com Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Luis R. Rodriguez <mcgrof@suse.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: arnd@arndb.de Cc: hch@lst.de Cc: hmh@hmh.eng.br Cc: jgross@suse.com Cc: konrad.wilk@oracle.com Cc: linux-mm <linux-mm@kvack.org> Cc: linux-nvdimm@lists.01.org Cc: stefan.bader@canonical.com Cc: yigal@plexistor.com Link: http://lkml.kernel.org/r/1433436928-31903-13-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-07x86/mm, asm-generic: Add ioremap_wt() for creating Write-Through mappingsToshi Kani
Add ioremap_wt() for creating Write-Through mappings on x86. It follows the same model as ioremap_wc() for multi-arch support. Define ARCH_HAS_IOREMAP_WT in the x86 version of io.h to indicate that ioremap_wt() is implemented on x86. Also update the PAT documentation file to cover ioremap_wt(). Signed-off-by: Toshi Kani <toshi.kani@hp.com> Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Elliott@hp.com Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Luis R. Rodriguez <mcgrof@suse.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: arnd@arndb.de Cc: hch@lst.de Cc: hmh@hmh.eng.br Cc: jgross@suse.com Cc: konrad.wilk@oracle.com Cc: linux-mm <linux-mm@kvack.org> Cc: linux-nvdimm@lists.01.org Cc: stefan.bader@canonical.com Cc: yigal@plexistor.com Link: http://lkml.kernel.org/r/1433436928-31903-8-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-27x86/mm/mtrr, pat: Document Write Combining MTRR type effects on PAT / ↵Luis R. Rodriguez
non-PAT pages As part of the effort to phase out MTRR use document write-combining MTRR effects on pages with different non-PAT page attributes flags and different PAT entry values. Extend arch_phys_wc_add() documentation to clarify power of two sizes / boundary requirements as we phase out mtrr_add() use. Lastly hint towards ioremap_uc() for corner cases on device drivers working with devices with mixed regions where MTRR size requirements would otherwise not enable write-combining effective memory types. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com> Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Dave Airlie <airlied@redhat.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Davidlohr Bueso <dbueso@suse.de> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Suresh Siddha <sbsiddha@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Ville Syrjälä <syrjala@sci.fi> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: linux-fbdev@vger.kernel.org Link: http://lkml.kernel.org/r/1430343851-967-3-git-send-email-mcgrof@do-not-panic.com Link: http://lkml.kernel.org/r/1432628901-18044-10-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-27x86/Documentation: Adapt Ingo's explanation on printing backtracesBorislav Petkov
Hold it down for future reference, as the question about the question mark in stack traces keeps popping up. Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: live-patching@vger.kernel.org Link: http://lkml.kernel.org/r/1432628901-18044-18-git-send-email-bp@alien8.de Link: http://lkml.kernel.org/r/20150521101614.GA10889@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-27x86/Documentation: Remove STACKFAULT_STACK bulletpointBorislav Petkov
Update the documentation after 6f442be2fb22 ("x86_64, traps: Stop using IST for #SS"). Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: live-patching@vger.kernel.org Link: http://lkml.kernel.org/r/1432628901-18044-17-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-27x86/Documentation: Move kernel-stacks doc one level upBorislav Petkov
... to Documentation/x86/ as it is going to collect more and not only 64-bit specific info. Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: live-patching@vger.kernel.org Link: http://lkml.kernel.org/r/1432628901-18044-16-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-11x86/kaslr: Fix typo in the KASLR_FLAG documentationMiroslav Benes
Documentation/x86/boot.txt labels the bit in boot_params.hdr.loadflags as ALSR_FLAG while it should be KASLR_FLAG. Signed-off-by: Miroslav Benes <mbenes@suse.cz> Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1429011324-7170-1-git-send-email-mbenes@suse.cz Link: http://lkml.kernel.org/r/1431332153-18566-4-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-04-30x86, doc: Remove cmdline_size from list of fields to be filled in for EFI ↵Alex Smith
handover The cmdline_size field in setup_header is listed as read-only, and is never read by the kernel. Therefore, there is no need for it to be set by a boot loader implementing the EFI handover protocol, so remove it from the list of fields required to be set by a boot loader. Signed-off-by: Alex Smith <alex@alex-smith.me.uk> Cc: H. Peter Anvin <hpa@linux.intel.com> Cc: x86@kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2015-04-03x86/mm/KASLR: Propagate KASLR status to kernel properBorislav Petkov
Commit: e2b32e678513 ("x86, kaslr: randomize module base load address") made module base address randomization unconditional and didn't regard disabled KKASLR due to CONFIG_HIBERNATION and command line option "nokaslr". For more info see (now reverted) commit: f47233c2d34f ("x86/mm/ASLR: Propagate base load address calculation") In order to propagate KASLR status to kernel proper, we need a single bit in boot_params.hdr.loadflags and we've chosen bit 1 thus leaving the top-down allocated bits for bits supposed to be used by the bootloader. Originally-From: Jiri Kosina <jkosina@suse.cz> Suggested-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Kees Cook <keescook@chromium.org> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-02-21Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull misc x86 fixes from Ingo Molnar: "This contains: - EFI fixes - a boot printout fix - ASLR/kASLR fixes - intel microcode driver fixes - other misc fixes Most of the linecount comes from an EFI revert" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mm/ASLR: Avoid PAGE_SIZE redefinition for UML subarch x86/microcode/intel: Handle truncated microcode images more robustly x86/microcode/intel: Guard against stack overflow in the loader x86, mm/ASLR: Fix stack randomization on 64-bit systems x86/mm/init: Fix incorrect page size in init_memory_mapping() printks x86/mm/ASLR: Propagate base load address calculation Documentation/x86: Fix path in zero-page.txt x86/apic: Fix the devicetree build in certain configs Revert "efi/libstub: Call get_memory_map() to obtain map and desc sizes" x86/efi: Avoid triple faults during EFI mixed mode calls
