path: root/Documentation/xtensa
2014-01-15xtensa: remap io area defined in device treeBaruch Siach
Use the simple-bus node to discover the io area, and remap the cached and bypass io ranges. The parent-bus-address value of the first triplet in the "ranges" property is used. This value is rounded down to the nearest 256MB boundary. The length of the io area is fixed at 256MB; the "ranges" property length value is ignored. Other limitations: (1) only the first simple-bus node is considered, and (2) only the first triplet of the "ranges" property is considered. See ePAPR 1.1 §6.5 for the simple-bus node description, and §2.3.8 for the "ranges" property description. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2014-01-15xtensa: fix ATOMCTL register documentationBaruch Siach
Make the WT entry match table 4-52 of the Xtensa ISA RM (RD-2012.5). Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2013-05-09xtensa: document MMUv3 setup sequenceMax Filippov
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2012-12-18xtensa: initialize atomctl SRMax Filippov
In order to use S32C1I instruction on cores with ATOMCTL SR the register must be properly initialized. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
