commit f8313ef1f448006207f12c107123522c8bc00f15 upstream.
i8042 controller present in Dell Vostro V13 errorneously signals spurious
timeouts.
Introduce i8042.notimeout parameter for ignoring i8042-signalled timeouts
and apply this quirk automatically for Dell Vostro V13, based on DMI match.
In addition to that, this machine also needs to be added to nomux blacklist.
Cc: Tim Gardner <tcanonical@tpi.com>
commit 551423748a4eba55f2eb0fc250d757986471f187 upstream.
The error message 'NMI watchdog failed to create perf event...'
does not make it clear that this is a fatal error for the
watchdog. It also currently prints the error value as a
pointer, rather than extracting the error code with PTR_ERR().
Fix that.
Add a note to the description of the 'nowatchdog' kernel
parameter to associate it with this message.
Reported-by: Cesare Leonardi <celeonar@gmail.com>
Cc: 599368@bugs.debian.org
Cc: 608138@bugs.debian.org
Cc: Don Zickus <dzickus@redhat.com>
LKML-Reference: <1294009362.3167.126.camel@localhost>
commit f08f5a0add20834d3f3d876dfe08005a5df656db upstream.
There are some situations (e.g. in __pm_generic_call()), where
pm_runtime_suspended() is used to decide whether or not to execute
a device's (system) ->suspend() callback. The callback is not
executed if pm_runtime_suspended() returns true, but it does so
for devices that don't even support runtime PM, because the
power.disable_depth device field is ignored by it. This leads to
problems (i.e. devices are not suspened when they should), so rework
pm_runtime_suspended() so that it returns false if the device's
power.disable_depth field is different from zero.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits)
net: clear heap allocation for ETHTOOL_GRXCLSRLALL
isdn: strcpy() => strlcpy()
Revert "mac80211: use netif_receive_skb in ieee80211_tx_status callpath"
mac80211: delete AddBA response timer
ath9k_hw: fix regression in ANI listen time calculation
caif: fix two caif_connect() bugs
bonding: fix WARN_ON when writing to bond_master sysfs file
skge: add quirk to limit DMA
MAINTAINERS: update Intel LAN Ethernet info
e1000e.txt: Add e1000e documentation
e1000.txt: Update e1000 documentation
ixgbevf.txt: Update ixgbevf documentation
cls_u32: signedness bug
Bluetooth: Disallow to change L2CAP_OPTIONS values when connected
sctp: Fix out-of-bounds reading in sctp_asoc_get_hmac()
sctp: prevent reading out-of-bounds memory
ipv4: correct IGMP behavior on v3 query during v2-compatibility mode
netdev: Depend on INET before selecting INET_LRO
Revert "ipv4: Make INET_LRO a bool instead of tristate."
net: Fix the condition passed to sk_wait_event()
The page-types utility still uses an out of date name for the
unpoison interface: debugfs:hwpoison/renew-pfn
This patch renames and fixes it.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Wu Fengguang <fengguang.wu@intel.com>
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Adds documentation for the e1000e networking driver.
Updated the e1000 networking driver documentation.
Update the documentation for the ixgbevf (ixgbe virtual
function driver).
The attribute reflects an interval, not a rate.
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Acked-by: Ira W. Snyder <iws@ovro.caltech.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6:
regulator: wm8350-regulator - fix the logic of checking REGULATOR_MODE_STANDBY mode
regulator: wm831x-ldo - fix the logic to set REGULATOR_MODE_IDLE and REGULATOR_MODE_STANDBY modes
regulator: ab8500 - fix off-by-one value range checking for selector
regulator: 88pm8607 - fix value range checking for accessing info->vol_table
regulator: isl6271a-regulator - fix regulator_desc parameter for regulator_register()
regulator: ad5398 - fix a memory leak
regulator: Update e-mail address for Liam Girdwood
regulator: set max8998->dev to &pdev->dev.
regulator: tps6586x-regulator - fix bit_mask parameter for tps6586x_set_bits()
regulator: tps6586x-regulator - fix value range checking for val
regulator: max8998 - set max8998->num_regulators
regulator: max8998 - fix memory allocation size for max8998->rdev
regulator: tps6507x - remove incorrect comments
regulator: max1586 - improve the logic of choosing selector
regulator: ab8500 - fix the logic to remove already registered regulators in error path
regulator: ab3100 - fix the logic to remove already registered regulators in error path
regulator/ab8500: move dereference below the check for NULL
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: add documentation
Update copyright notice and add Documentation/workqueue.txt.
Randy Dunlap, Dave Chinner: misc fixes.
Reviewed-By: Florian Mickler <florian@mickler.org>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Fix docbook templates that reference files that do not contain the
expected kernel-doc notation.
Fixes these warnings:
Warning(arch/x86/include/asm/unaligned.h): no structured comments found
Warning(lib/vsprintf.c): no structured comments found
These cause errors in the generated html output, like below, so drop
these lines.
Name
arch/x86/include/asm/unaligned.h - Document generation inconsistency
Oops
Warning
The template for this document tried to insert the structured comment from the file arch/x86/include/asm/unaligned.h at this point, but none was found. This dummy section is inserted to allow generation to continue.
When you don't use !E or !I but only !F, then it's very easy to miss
including some functions, structs etc. in documentation. To help
finding which ones were missed, allow printing out the unused ones as
warnings.
For example, using this on mac80211 yields a lot of warnings like this:
Warning: didn't use docs for DOC: mac80211 workqueue
Warning: didn't use docs for ieee80211_max_queues
Warning: didn't use docs for ieee80211_bss_change
Warning: didn't use docs for ieee80211_bss_conf
when generating the documentation for it.
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
block: Range check cpu in blk_cpu_to_group
scatterlist: prevent invalid free when alloc fails
writeback: Fix lost wake-up shutting down writeback thread
writeback: do not lose wakeup events when forking bdi threads
cciss: fix reporting of max queue depth since init
block: switch s390 tape_block and mg_disk to elevator_change()
block: add function call to switch the IO scheduler from a driver
fs/bio-integrity.c: return -ENOMEM on kmalloc failure
bio-integrity.c: remove dependency on __GFP_NOFAIL
BLOCK: fix bio.bi_rw handling
block: put dev->kobj in blk_register_queue fail path
cciss: handle allocation failure
cfq-iosched: Documentation help for new tunables
cfq-iosched: blktrace print per slice sector stats
cfq-iosched: Implement tunable group_idle
cfq-iosched: Do group share accounting in IOPS when slice_idle=0
cfq-iosched: Do not idle if slice_idle=0
cciss: disable doorbell reset on reset_devices
blkio: Fix return code for mkdir calls
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: rawmidi: fix the get next midi device ioctl
ALSA: hda - Fix wrong HP pin detection in snd_hda_parse_pin_def_config()
ALSA: seq/oss - Fix double-free at error path of snd_seq_oss_open()
ALSA: msnd-classic: Fix invalid cfg parameter
ALSA: hda - Enable PC-beep for EeePC with ALC269 codec
ALSA: hda - Add errata initverb sequence for CS42xx codecs
ALSA: usb - Release capture substream URBs properly
ALSA: virtuoso: fix setting of Xonar DS line-in/mic-in controls
ALSA: virtuoso: work around missing reset in the Xonar DS Windows driver
ALSA: hda - Add quirk for Lenovo T400s
ALSA: usb-audio: fix detection of vendor-specific device protocol settings
ALSA: usb-audio: Assume first control interface is for audio
ALSA: hda - Add a new hp-laptop model for Conexant 5066, tested on HP G60
There's been some recent confusion about error checking GPIO numbers.
briefly, it should be handled mostly during setup, when gpio_request() is
called, and NEVER by expectig gpio_is_valid to report more than
never-usable GPIO numbers.
[akpm@linux-foundation.org: terminate unterminated comment]
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Eric Miao" <eric.y.miao@gmail.com>
Cc: "Ryan Mallon" <ryan@bluewatersys.com>
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
gcc-4.6: kernel/*: Fix unused but set warnings
mutex: Fix annotations to include it in kernel-locking docbook
pid: make setpgid() system call use RCU read-side critical section
MAINTAINERS: Add RCU's public git tree
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: bus speed strings should be const
PCI hotplug: Fix build with CONFIG_ACPI unset
PCI: PCIe: Remove the port driver module exit routine
PCI: PCIe: Move PCIe PME code to the pcie directory
PCI: PCIe: Disable PCIe port services during port initialization
PCI: PCIe: Ask BIOS for control of all native services at once
ACPI/PCI: Negotiate _OSC control bits before requesting them
ACPI/PCI: Do not preserve _OSC control bits returned by a query
ACPI/PCI: Make acpi_pci_query_osc() return control bits
ACPI/PCI: Reorder checks in acpi_pci_osc_control_set()
PCI: PCIe: Introduce commad line switch for disabling port services
PCI: PCIe AER: Introduce pci_aer_available()
x86/PCI: only define pci_domain_nr if PCI and PCI_DOMAINS are set
PCI: provide stub pci_domain_nr function for !CONFIG_PCI configs
workqueue: use zalloc_cpumask_var() for gcwq->mayday_mask
workqueue: fix GCWQ_DISASSOCIATED initialization
workqueue: Add a workqueue chapter to the tracepoint docbook
workqueue: fix cwq->nr_active underflow
workqueue: improve destroy_workqueue() debuggability
workqueue: mark lock acquisition on worker_maybe_bind_and_lock()
workqueue: annotate lock context change
workqueue: free rescuer on destroy_workqueue
Fix kernel-doc notation in linux/mutex.h and kernel/mutex.c,
then add these 2 files to the kernel-locking docbook as the
Mutex API reference chapter.
Add one API function to mutex-design.txt and correct a typo in
that file.
LKML-Reference: <20100902154816.6cc2f9ad.randy.dunlap@oracle.com>
This new model adds the following functionality to HP G60:
- Automute of internal speakers
- Autoswitch of internal/external mics
- Remove SPDIF not physically present
BugLink: http://launchpad.net/bugs/587388
Cc: stable@kernel.org
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Add a workqueue chapter to the traceopint docbook.
Current book is at: http://www.kernel.org/doc/htmldocs/tracepoint/
Signed-off-by: Jason Baron <jbaron@redhat.com>
These days the headers we use are in glibc. If those are too old, you can
add the -I lines to get the kernel headers.
In file included from ../../include/linux/if_tun.h:19,
from lguest.c:33:
../../include/linux/types.h:13:2: warning: #warning "Attempt to use kernel headers from user space, see http://kernelnewbies.org/KernelHeaders"
lguest.c: In function ‘setup_tun_net’:
lguest.c:1456: warning: dereferencing pointer ‘sin’ does break strict-aliasing rules
lguest.c:1457: warning: dereferencing pointer ‘sin’ does break strict-aliasing rules
lguest.c:1450: note: initialized from here
After commit 852972acff8f10f3a15679be2059bb94916cba5d (ACPI: Disable
ASPM if the platform won't provide _OSC control for PCIe) control of
the PCIe Capability Structure is unconditionally requested by
acpi_pci_root_add(), which in principle may cause problems to
happen in two ways. First, the BIOS may refuse to give control of
the PCIe Capability Structure if it is not asked for any of the
_OSC features depending on it at the same time. Second, the BIOS may
assume that control of the _OSC features depending on the PCIe
Capability Structure will be requested in the future and may behave
incorrectly if that doesn't happen. For this reason, control of
the PCIe Capability Structure should always be requested along with
control of any other _OSC features that may depend on it (ie. PCIe
native PME, PCIe native hot-plug, PCIe AER).
Rework the PCIe port driver so that (1) it checks which native PCIe
port services can be enabled, according to the BIOS, and (2) it
requests control of all these services simultaneously. In
particular, this causes pcie_portdrv_probe() to fail if the BIOS
refuses to grant control of the PCIe Capability Structure, which
means that no native PCIe port services can be enabled for the PCIe
Root Complex the given port belongs to. If that happens, ASPM is
disabled to avoid problems with mishandling it by the part of the
PCIe hierarchy for which control of the PCIe Capability Structure
has not been received.
Make it possible to override this behavior using 'pcie_ports=native'
(use the PCIe native services regardless of the BIOS response to the
control request), or 'pcie_ports=compat' (do not use the PCIe native
services at all).
Accordingly, rework the existing PCIe port service drivers so that
they don't request control of the services directly.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Introduce kernel command line switch pcie_ports= allowing one to
disable all of the native PCIe port services, so that PCIe ports
are treated like PCI-to-PCI bridges.
git://xenbits.xensource.com/people/ianc/linux-2.6
* 'for-upstream/pvhvm' of git://xenbits.xensource.com/people/ianc/linux-2.6:
xen: pvhvm: make it clearer that XEN_UNPLUG_* define bits in a bitfield
xen: pvhvm: rename xen_emul_unplug=ignore to =unnnecessary
xen: pvhvm: allow user to request no emulated device unplug
It is not immediately clear what this option causes to become
ignored. The actual meaning is that it is not necessary to unplug the
emulated devices to safely use the PV ones, even if the platform does
not support the unplug protocol. (pressumably the user will only add
this option if they have ensured that their domain configuration is
safe).
I think xen_emul_unplug=unnecessary better captures this.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Acked-by: Stefano Stabellini <Stefano.Stabellini@eu.citrix.com>
this allows the user to disable pvhvm and revert to emulated devices
in case of a system misconfiguration (e.g. initramfs with only
emulated drivers in it).
Some documentation to provide help with tunables.
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
This list moved to lists.ozlabs.org quite some time ago.
Chapter 6 is right about mutex_trylock, but chapter 10 wasn't. This error
was introduced during semaphore-to-mutex conversion of the Unreliable
guide. :-)
If user context which performs mutex_lock() or mutex_trylock() is
preempted by interrupt context which performs mutex_trylock() on the same
mutex instance, a deadlock occurs. This is because these functions do not
disable local IRQs when they operate on mutex->wait_lock.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Revert commit 7721fea3d0fd93fb4d000eb737b444369358d6d3 ("hwmon:
f71882fg: add support for the Fintek F71808E").
Hans said:
: A second review after I've received a data sheet for this device from
: Fintek has turned up a few bugs.
: Unfortunately Giel (nor I) have time to fix this in time for the 2.6.36
: cycle. Therefor I would like to see this patch reverted as not having any
: support for the hwmon function of this superio chip is better then having
: unreliable support.
Cc: Giel van Schijndel <me@mortis.eu>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Jonathan Cameron <jic23@cam.ac.uk>
* 'merge-devicetree' of git://git.secretlab.ca/git/linux-2.6:
spi.h: missing kernel-doc notation, please fix
of: fix missing headers for of_address_to_resource() in MTD and SysACE drivers
of: Fix missing includes
ata: update for of_device to platform_device replacement
microblaze: Fix of: eliminate of_device->node and dev_archdata->{of,prom}_node
microblaze: Fix of/address: Merge all of the bus translation code
booting-without-of: Remove nonexistent chapters from TOC, fix numbering
Marvell and GPIO bindings live in their own files, so the TOC should not
mention them.
Also fix chapters numbering.
Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
acpi_video_backlight_support() already tells us if ACPI is handling
backlight control through the generic ACPI handle. It is better to just
trust it.
While at it, adjust down a printk priority, and test earlier for
brightness_enable=0.
Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
gcc-4.6: ACPI: fix unused but set variables in ACPI
ACPI thermal: make procfs I/F depend on CONFIG_ACPI_PROCFS
ACPI video: make procfs I/F depend on CONFIG_ACPI_PROCFS
ACPI processor: remove deprecated ACPI procfs I/F
ACPI power_resource: remove unused procfs I/F
ACPI: remove deprecated ACPI procfs I/F
ACPI: introduce drivers/acpi/sysfs.c
ACPI: introduce module parameter acpi.aml_debug_output
ACPI: introduce drivers/acpi/debugfs.c
ACPI, APEI, ERST debug support
ACPI, APEI, Manage GHES as platform devices
ACPI, APEI, Rename CPER and GHES severity constants
ACPI, APEI, Fix a typo of error path of apei_resources_request
ACPI / ACPICA: Fix reference counting problems with GPE handlers
ACPI: Add the check of ADR flag in course of finding ACPI handle for PCI device
ACPI / Sleep: Drop acpi_suspend_finish()
ACPI / Sleep: Consolidate suspend and hibernation routines
ACPI / Wakeup: Simplify enabling of wakeup devices
ACPI / Sleep: Rework enabling wakeup devices
ACPI / Sleep: Free NVS copy if suspending of devices fails
Fixed up totally buggered "ACPI: fix unused but set variables in ACPI"
patch that doesn't even compile in the merge.
Thanks to Sedat Dilek <sedat.dilek@googlemail.com> for noticing the
breakage before I even pulled. And a big "Grrr.." at Len for not even
bothering to compile the tree before asking me to pull.
* git://git.infradead.org/iommu-2.6:
intel-iommu: Fix 32-bit build warning with __cmpxchg()
intr-remap: allow disabling source id checking
drivers/acpi/debug.c
Signed-off-by: Len Brown <len.brown@intel.com>
Introduce module parameter acpi.aml_debug_output.
With acpi.aml_debug_output set, we can get AML debug object output
(Store (AAA, Debug)), even with CONFIG_ACPI_DEBUG cleared.
Together with the runtime custom method mechanism,
we can debug AML code problems without rebuilding the kernel.
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/cleanup:
defconfig reduction
kbuild: drop unifdef-y support
archs: replace unifdef-y with header-y
include: replace unifdef-y with header-y
Move SCSI parameters from kernel-parameters.txt to their own text file.
This continues a trend of moving non-core parameters out of
kernel-parameters.txt.
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: (22 commits)
hwmon: (via-cputemp) Remove bogus "SHOW" global variable
hwmon: jc42 depends on I2C
hwmon: (pc87427) Add a maintainer
hwmon: (pc87427) Move sysfs file removal to a separate function
hwmon: (pc87427) Add temperature monitoring support
hwmon: (pc87427) Add support for the second logical device
hwmon: (pc87427) Add support for manual fan speed control
hwmon: (pc87427) Minor style cleanups
hwmon: (pc87427) Handle disabled fan inputs properly
hwmon: (w83627ehf) Add support for W83667HG-B
hwmon: (w83627ehf) Driver cleanup
hwmon: Add driver for SMSC EMC2103 temperature monitor and fan controller
hwmon: Remove in[0-*]_fault from sysfs-interface
hwmon: Add 4 current alarm/beep attributes to sysfs-interface
hwmon: Add 3 critical limit attributes to sysfs-interface
hwmon: (asc7621) Clean up and improve detect function
hwmon: (it87) Export labels for internal sensors
hwmon: (lm75) Add suspend/resume feature
hwmon: (emc1403) Add power support
hwmon: (ltc4245) Expose all GPIO pins as analog voltages
unifdef-y is not used anymore - drop remaining references
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Add support for the 6 temperature monitoring channels of the PC87427.
Note that the sensors resolution can vary, and I couldn't find a way
to figure it out, so we might have to compensate in user-space.
Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
Add initial support for PWM outputs of the PC87427 Super-I/O chip.
Only mode change and manual fan speed control are supported. Automatic
mode configuration isn't supported, and won't be until at least one
board is known, which makes uses of the PWM outputs.
Add support for W83667HG-B (very similar to the W83667HG).
SMSC's EMC2103 family of temperature/fan controllers have 1
onboard and up to 3 external temperature sensors, and allow
closed-loop control of one fan. This patch adds support for
them.
Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com>
