commit 759c01142a5d0f364a462346168a56de28a80f52 upstream.
On no-so-small systems, it is possible for a single process to cause an
OOM condition by filling large pipes with data that are never read. A
typical process filling 4000 pipes with 1 MB of data will use 4 GB of
memory. On small systems it may be tricky to set the pipe max size to
prevent this from happening.
This patch makes it possible to enforce a per-user soft limit above
which new pipes will be limited to a single page, effectively limiting
them to 4 kB each, as well as a hard limit above which no new pipes may
be created for this user. This has the effect of protecting the system
against memory abuse without hurting other users, and still allowing
pipes to work correctly though with less data at once.
The limit are controlled by two new sysctls : pipe-user-pages-soft, and
pipe-user-pages-hard. Both may be disabled by setting them to zero. The
default soft limit allows the default number of FDs per process (1024)
to create pipes of the default size (64kB), thus reaching a limit of 64MB
before starting to create only smaller pipes. With 256 processes limited
to 1024 FDs each, this results in 1024*64kB + (256*1024 - 1024) * 4kB =
1084 MB of memory allocated for a user. The hard limit is disabled by
default to avoid breaking existing applications that make intensive use
of pipes (eg: for splicing).
Reported-by: socketpair@gmail.com
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Mitigates: CVE-2013-4312 (Linux 2.0+)
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Willy Tarreau <w@1wt.eu>
Cc: Moritz Muehlenhoff <moritz@wikimedia.org>
commit 3397c2c45b1b6f54834dfeae30a73046f33ca943 upstream.
A new element got inserted into enum mx35_clks with commit 3713e3f5e927
("clk: imx35: define two clocks for rtc"). This insertion shifted most
nummerical clock assignments to a new nummerical value which in turn
rendered most hardcoded nummeric values in imx35.dtsi incorrect.
Restore the existing order by moving the newly introduced clock to the
end of the enum. Update the dts documentation accordingly.
Signed-off-by: Alexander Kurz <akurz@blala.de>
Fixes: 3713e3f5e927 ("clk: imx35: define two clocks for rtc")
commit 0f40fbbcc34e093255a2b2d70b6b0fb48c3f39aa upstream.
OpenSSH expects the (non-blocking) read() of pty master to return
EAGAIN only if it has received all of the slave-side output after
it has received SIGCHLD. This used to work on pre-3.12 kernels.
This fix effectively forces non-blocking read() and poll() to
block for parallel i/o to complete for all ttys. It also unwinds
these changes:
1) f8747d4a466ab2cafe56112c51b3379f9fdb7a12
tty: Fix pty master read() after slave closes
2) 52bce7f8d4fc633c9a9d0646eef58ba6ae9a3b73
pty, n_tty: Simplify input processing on final close
3) 1a48632ffed61352a7810ce089dc5a8bcd505a60
pty: Fix input race when closing
Inspired by analysis and patch from Marc Aurele La France <tsi@tuyoix.net>
Reported-by: Volth <openssh@volth.com>
Reported-by: Marc Aurele La France <tsi@tuyoix.net>
BugLink: https://bugzilla.mindrot.org/show_bug.cgi?id=52
BugLink: https://bugzilla.mindrot.org/show_bug.cgi?id=2492
Signed-off-by: Brian Bloniarz <brian.bloniarz@gmail.com>
Reviewed-by: Peter Hurley <peter@hurleysoftware.com>
commit 17dcc37e3e847bc0e67a5b1ec52471fcc6c18682 upstream.
On some SOCs PORTS_IMPL register value is never programmed by the
firmware and left at zero value. Which means that no sata ports are
available for software. AHCI driver used to cope up with this by
fabricating the port_map if the PORTS_IMPL register is read zero,
but recent patch broke this workaround as zero value was valid for
NVMe disks.
This patch adds ports-implemented DT bindings as workaround for this issue
in a way that DT can can override the PORTS_IMPL register in cases where
the firmware did not program it already.
Fixes: 566d1827df2e ("libata: disable forced PORTS_IMPL for >= AHCI 1.3")
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Acked-by: Tejun Heo <tj@kernel.org>
Reviewed-by: Andy Gross <andy.gross@linaro.org>
commit e9adb336d0bf391be23e820975ca5cd12c31d781 upstream.
mfio 84 to 89 are described wrongly, fix it to describe
the right pin and add them to right pin-mux group.
The correct order is:
pll1_lock => mips_pll -- MFIO_83
pll2_lock => audio_pll -- MFIO_84
pll3_lock => rpu_v_pll -- MFIO_85
pll4_lock => rpu_l_pll -- MFIO_86
pll5_lock => sys_pll -- MFIO_87
pll6_lock => wifi_pll -- MFIO_88
pll7_lock => bt_pll -- MFIO_89
Cc: linux-gpio@vger.kernel.org
Cc: devicetree@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: James Hartley <James.Hartley@imgtec.com>
Fixes: cefc03e5995e("pinctrl: Add Pistachio SoC pin control driver")
Signed-off-by: Govindraj Raja <Govindraj.Raja@imgtec.com>
Acked-by: Andrew Bresticker <abrestic@chromium.org>
Acked-by: Rob Herring <robh@kernel.org>
commit 1363074667a6b7d0507527742ccd7bbed5e3ceaa upstream.
Add a new NO_REPORT_LUNS quirk and set it for Seagate drives with
an usb-id of: 0bc2:331a, as these will fail to respond to a
REPORT_LUNS command.
Reported-and-tested-by: David Webb <djw@noc.ac.uk>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 844a5fe219cf472060315971e15cbf97674a3324 upstream.
Yes, all of these are needed. :) This is admittedly a bit odd, but
kvm-unit-tests access.flat tests this if you run it with "-cpu host"
and of course ept=0.
KVM runs the guest with CR0.WP=1, so it must handle supervisor writes
specially when pte.u=1/pte.w=0/CR0.WP=0. Such writes cause a fault
when U=1 and W=0 in the SPTE, but they must succeed because CR0.WP=0.
When KVM gets the fault, it sets U=0 and W=1 in the shadow PTE and
restarts execution. This will still cause a user write to fault, while
supervisor writes will succeed. User reads will fault spuriously now,
and KVM will then flip U and W again in the SPTE (U=1, W=0). User reads
will be enabled and supervisor writes disabled, going back to the
originary situation where supervisor writes fault spuriously.
When SMEP is in effect, however, U=0 will enable kernel execution of
this page. To avoid this, KVM also sets NX=1 in the shadow PTE together
with U=0. If the guest has not enabled NX, the result is a continuous
stream of page faults due to the NX bit being reserved.
The fix is to force EFER.NX=1 even if the CPU is taking care of the EFER
switch. (All machines with SMEP have the CPU_LOAD_IA32_EFER vm-entry
control, so they do not use user-return notifiers for EFER---if they did,
EFER.NX would be forced to the same value as the host).
There is another bug in the reserved bit check, which I've split to a
separate patch for easier application to stable kernels.
Reviewed-by: Xiao Guangrong <guangrong.xiao@linux.intel.com>
Fixes: f6577a5fa15d82217ca73c74cd2dcbc0f6c781dd
commit 2e18f5a1bc18e8af7031b3b26efde25307014837 upstream.
Introduce a dt property, ti,no-idle, that prevents an IP to idle at any
point. This is to handle Errata i877, which tells that GMAC clocks
cannot be disabled.
Acked-by: Roger Quadros <rogerq@ti.com>
Tested-by: Mugunthan V N <mugunthanvnm@ti.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
commit ed8b0de5a33d2a2557dce7f9429dca8cb5bc5879 upstream.
"rm -rf" is bricking some peoples' laptops because of variables being
used to store non-reinitializable firmware driver data that's required
to POST the hardware.
These are 100% bugs, and they need to be fixed, but in the mean time it
shouldn't be easy to *accidentally* brick machines.
We have to have delete working, and picking which variables do and don't
work for deletion is quite intractable, so instead make everything
immutable by default (except for a whitelist), and make tools that
aren't quite so broad-spectrum unset the immutable flag.
Signed-off-by: Peter Jones <pjones@redhat.com>
Tested-by: Lee, Chun-Yi <jlee@suse.com>
Acked-by: Matthew Garrett <mjg59@coreos.com>
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
commit bf5ce5bf3cc7136fd7fe5e8999a580bc93a9c8f6 upstream.
Commit 655fe4effe0f ("usbcore: add sysfs support to xHCI usb3
hardware LPM") introduced usb3_hardware_lpm sysfs node. This
doesn't show the correct status of USB3 U1 and U2 LPM status.
This patch fixes this by replacing usb3_hardware_lpm with two
nodes, usb3_hardware_lpm_u1 (for U1) and usb3_hardware_lpm_u2
(for U2), and recording the U1/U2 LPM status in right places.
This patch should be back-ported to kernels as old as 4.3,
that contains Commit 655fe4effe0f ("usbcore: add sysfs support
to xHCI usb3 hardware LPM").
Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com>
Pull networking fixes from David Miller:
1) Prevent XFRM per-cpu counter updates for one namespace from being
applied to another namespace. Fix from DanS treetman.
2) Fix RCU de-reference in iwl_mvm_get_key_sta_id(), from Johannes
Berg.
3) Remove ethernet header assumption in nft_do_chain_netdev(), from
Pablo Neira Ayuso.
4) Fix cpsw PHY ident with multiple slaves and fixed-phy, from Pascal
Speck.
5) Fix use after free in sixpack_close and mkiss_close.
6) Fix VXLAN fw assertion on bnx2x, from Yuval Mintz.
7) natsemi doesn't check for DMA mapping errors, from Alexey
Khoroshilov.
8) Fix inverted test in ip6addrlbl_get(), from ANdrey Ryabinin.
9) Missing initialization of needed_headroom in geneve tunnel driver,
from Paolo Abeni.
10) Fix conntrack template leak in openvswitch, from Joe Stringer.
11) Mission initialization of wq->flags in sock_alloc_inode(), from
Nicolai Stange.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (35 commits)
sctp: sctp should release assoc when sctp_make_abort_user return NULL in sctp_close
net, socket, socket_wq: fix missing initialization of flags
drivers: net: cpsw: fix error return code
openvswitch: Fix template leak in error cases.
sctp: label accepted/peeled off sockets
sctp: use GFP_USER for user-controlled kmalloc
qlcnic: fix a loop exit condition better
net: cdc_ncm: avoid changing RX/TX buffers on MTU changes
geneve: initialize needed_headroom
ipv6: honor ifindex in case we receive ll addresses in router advertisements
addrconf: always initialize sysctl table data
ipv6/addrlabel: fix ip6addrlbl_get()
switchdev: bridge: Pass ageing time as clock_t instead of jiffies
sh_eth: fix 16-bit descriptor field access endianness too
veth: don’t modify ip_summed; doing so treats packets with bad checksums as good.
net: usb: cdc_ncm: Adding Dell DW5813 LTE AT&T Mobile Broadband Card
net: usb: cdc_ncm: Adding Dell DW5812 LTE Verizon Mobile Broadband Card
natsemi: add checks for dma mapping errors
rhashtable: Kill harmless RCU warning in rhashtable_walk_init
openvswitch: correct encoding of set tunnel action attributes
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input fixes from Dmitry Torokhov:
"Just a few assorted driver fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: elants_i2c - fix wake-on-touch
Input: elan_i2c - set input device's vendor and product IDs
Input: sun4i-lradc-keys - fix typo in binding documentation
Input: atmel_mxt_ts - add maxtouch to I2C table for module autoload
Input: arizona-haptic - fix disabling of haptics device
Input: aiptek - fix crash on detecting device without endpoints
Input: atmel_mxt_ts - add generic platform data for Chromebooks
Input: parkbd - clear unused function pointers
Input: walkera0701 - clear unused function pointers
Input: turbografx - clear unused function pointers
Input: gamecon - clear unused function pointers
Input: db9 - clear unused function pointers
Commit 1f71e8c96fc654724723ce987e0a8b2aeb81746d ("drivers: net: cpsw: Add
support for fixed-link PHY") did not parse the "phy-mode" property in
the case of a fixed-link PHY, leaving slave_data->phy_if with its default
of PHY_INTERFACE_MODE_NA(0). This later gets passed to phy_connect() in
cpsw_slave_open(), and eventually to cpsw_phy_sel() where it hits a default
case that configures the MAC for MII mode.
The user visible symptom is that while kernel log messages seem to indicate
that the interface is set up, there is no network communication. Eventually
a watchdog error occurs:
NETDEV WATCHDOG: eth0 (cpsw): transmit queue 0 timed out
Fixes: 1f71e8c96fc6 ("drivers: net: cpsw: Add support for fixed-link PHY")
Signed-off-by: David Rivshin <drivshin@allworx.com>
Pull MTD fixes from Brian Norris:
"I was holding out on this pull request for a bit, since there are a
few other small issues being discussed that look like 4.4-rc
regressions. Hopefully I can get those stabilized soon, but these are
ready at any rate:
- A little bit of a last-minute change for the device tree "fixed
partition" binding. This is needed because we might want to reuse
the 'partitions' subnode for other sorts of partitioning
descriptions -- e.g., for describing which on-flash partition
format(s) might be used on the system.
- Also tone down a warning message, since it is probably going to
show up on a lot of systems where it should just be ignored"
* tag 'for-linus-20151217' of git://git.infradead.org/linux-mtd:
doc: dt: mtd: partitions: add compatible property to "partitions" node
mtd: ofpart: don't complain about missing 'partitions' node too loudly
1) Fix uninitialized variable warnings in nfnetlink_queue, a lot of
people reported this... From Arnd Bergmann.
2) Don't init mutex twice in i40e driver, from Jesse Brandeburg.
3) Fix spurious EBUSY in rhashtable, from Herbert Xu.
4) Missing DMA unmaps in mvpp2 driver, from Marcin Wojtas.
5) Fix race with work structure access in pppoe driver causing
corruptions, from Guillaume Nault.
6) Fix OOPS due to sh_eth_rx() not checking whether netdev_alloc_skb()
actually succeeded or not, from Sergei Shtylyov.
7) Don't lose flags when settifn IFA_F_OPTIMISTIC in ipv6 code, from
Bjørn Mork.
8) VXLAN_HD_RCO defined incorrectly, fix from Jiri Benc.
9) Fix clock source used for cookies in SCTP, from Marcelo Ricardo
Leitner.
10) aurora driver needs HAS_DMA dependency, from Geert Uytterhoeven.
11) ndo_fill_metadata_dst op of vxlan has to handle ipv6 tunneling
properly as well, from Jiri Benc.
12) Handle request sockets properly in xfrm layer, from Eric Dumazet.
13) Double stats update in ipv6 geneve transmit path, fix from Pravin B
Shelar.
14) sk->sk_policy[] needs RCU protection, and as a result
xfrm_policy_destroy() needs to free policies using an RCU grace
period, from Eric Dumazet.
15) SCTP needs to clone ipv6 tx options in order to avoid use after
free, from Eric Dumazet.
16) Missing kbuild export if ila.h, from Stephen Hemminger.
17) Missing mdiobus_alloc() return value checking in mdio-mux.c, from
Tobias Klauser.
18) Validate protocol value range in ->create() methods, from Hannes
Frederic Sowa.
19) Fix early socket demux races that result in illegal dst reuse, from
Eric Dumazet.
20) Validate socket address length in pptp code, from WANG Cong.
21) skb_reorder_vlan_header() uses incorrect offset and can corrupt
packets, from Vlad Yasevich.
22) Fix memory leaks in nl80211 registry code, from Ola Olsson.
23) Timeout loop count handing fixes in mISDN, xgbe, qlge, sfc, and
qlcnic. From Dan Carpenter.
24) msg.msg_iocb needs to be cleared in recvfrom() otherwise, for
example, AF_ALG will interpret it as an async call. From Tadeusz
Struk.
25) inetpeer_set_addr_v4 forgets to initialize the 'vif' field, from
Eric Dumazet.
26) rhashtable enforces the minimum table size not early enough,
breaking how we calculate the per-cpu lock allocations. From
Herbert Xu.
27) Fix FCC port lockup in 82xx driver, from Martin Roth.
28) FOU sockets need to be freed using RCU, from Hannes Frederic Sowa.
29) Fix out-of-bounds access in __skb_complete_tx_timestamp() and
sock_setsockopt() wrt. timestamp handling. From WANG Cong.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (117 commits)
net: check both type and procotol for tcp sockets
drivers: net: xgene: fix Tx flow control
tcp: restore fastopen with no data in SYN packet
af_unix: Revert 'lock_interruptible' in stream receive code
fou: clean up socket with kfree_rcu
82xx: FCC: Fixing a bug causing to FCC port lock-up
gianfar: Don't enable RX Filer if not supported
net: fix warnings in 'make htmldocs' by moving macro definition out of field declaration
rhashtable: Fix walker list corruption
rhashtable: Enforce minimum size on initial hash table
inet: tcp: fix inetpeer_set_addr_v4()
ipv6: automatically enable stable privacy mode if stable_secret set
net: fix uninitialized variable issue
bluetooth: Validate socket address length in sco_sock_bind().
net_sched: make qdisc_tree_decrease_qlen() work for non mq
ser_gigaset: remove unnecessary kfree() calls from release method
ser_gigaset: fix deallocation of platform device structure
ser_gigaset: turn nonsense checks into WARN_ON
ser_gigaset: fix up NULL checks
qlcnic: fix a timeout loop
git://git.infradead.org/users/vkoul/slave-dma
Pull dmaengine fixes from Vinod Koul:
"This has fixes spread thru driver, notably among them:
- edma fixes for recent edma DT changes which went into 4.4
- odd fixes for at_hdmac
- minor fixes on bc dma and mic dma"
* tag 'dmaengine-fix-4.4-rc6' of git://git.infradead.org/users/vkoul/slave-dma:
dmaengine: at_xdmac: fix at_xdmac_prep_dma_memcpy()
dmaengine: edma: DT: Change reserved slot array from 16bit to 32bit type
dmaengine: edma: DT: Change memcpy channel array from 16bit to 32bit type
dmaengine: mic_x100: add missing spin_unlock
dmaengine: bcm2835-dma: Convert to use DMA pool
dmaengine: at_xdmac: fix bad behavior in interleaved mode
dmaengine: at_xdmac: fix false condition for memset_sg transfers
dmaengine: at_xdmac: fix macro typo
Pull ARM SoC fixes from Arnd Bergmann:
"Here are a bunch of small bug fixes for various ARM platforms, nothing
really sticks out this week, most of either fixes bugs in code that
was just added in 4.4, or that has been broken for many years without
anyone noticing.
at91/sama5d2:
- fix sama5de hardware setup of sd/mmc interface
- proper selection of pinctrl drivers. PIO4 is necessary for sama5d2
berlin:
- fix incorrect clock input for SDIO
exynos:
- Fix potential NULL pointer dereference in Exynos PMU driver.
imx:
- Fix vf610 SAI clock configuration bug which is discovered by the
newly added master mode support in SAI audio driver.
- Fix buggy L2 cache latency values in vf610 device trees, which may
cause system hang when cpu runs at a higher frequency.
ixp4xx:
- fix prototypes for readl/writel functions
ls2080a:
- use little-endian register access for GPIO and SDHCI
omap:
- Fix clock source for ARM TWD and global timers on am437x
- Always select REGULATOR_FIXED_VOLTAGE for omap2+ instead of when
MACH_OMAP3_PANDORA is selected
- Fix SPI DMA handles for dm816x as only some were mapped
- Fix up mbox cells for dm816x to make mailbox usable
pxa:
- use PWM lookup table for all ezx machines
s3c24xx:
- Remove incorrect __init annotation from s3c24xx cpufreq driver
structures.
versatile:
- fix PCI IRQ mapping on Versatile PB"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ls2080a/dts: Add little endian property for GPIO IP block
dt-bindings: define little-endian property for QorIQ GPIO
ARM64: dts: ls2080a: fix eSDHC endianness
ARM: dts: vf610: use reset values for L2 cache latencies
ARM: pxa: use PWM lookup table for all machines
ARM: dts: berlin: add 2nd clock for BG2Q sdhci0 and sdhci1
ARM: dts: berlin: correct BG2Q's sdhci2 2nd clock
ARM: dts: am4372: fix clock source for arm twd and global timers
ARM: at91: fix pinctrl driver selection
ARM: at91/dt: add always-on to 1.8V regulator
ARM: dts: vf610: fix clock definition for SAI2
ARM: imx: clk-vf610: fix SAI clock tree
ARM: ixp4xx: fix read{b,w,l} return types
irqchip/versatile-fpga: Fix PCI IRQ mapping on Versatile PB
ARM: OMAP2+: enable REGULATOR_FIXED_VOLTAGE
ARM: dts: add dm816x missing spi DT dma handles
ARM: dts: add dm816x missing #mbox-cells
cpufreq: s3c24xx: Do not mark s3c2410_plls_add as __init
ARM: EXYNOS: Fix potential NULL pointer access in exynos_sys_powerdown_conf
Trivial typo fix ("mut" -> "must") in the sunxi LRADC-keys binding
documentation.
Signed-off-by: Karsten Merker <merker@debian.org>
Acked-by: Chen-Yu Tsai <wens@csie.org>
The GPIO block on different QorIQ chips could have registers in different
endianess. Define the property to specify which endian is used by the
hardware.
Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
Signed-off-by: Li Yang <leoli@freescale.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
This change makes the DT file to be easier to read since the reserved slots
array does not need the '/bits/ 16' to be specified, which might confuse
some people.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
This change makes the DT file to be easier to read since the memcpy
channels array does not need the '/bits/ 16' to be specified, which might
confuse some people.
As noted here [1], there are potentially future conflicts if we try to
use MTD's "partitions" subnode to describe anything besides just the
fixed-in-the-device-tree partitions currently described in this
document. Particularly, there was a proposal to use this node for the
AFS parser too.
It can pose a (small) problem to try to differentiate the following
nodes:
// using binding as currently specified
partitions {
#address-cells = <x>;
#size-cells = <y>;
partition@0 {
and
// proposed future binding
partitions {
compatible = "arm,arm-flash-structure";
It's especially difficult if other uses of this node start having
subnodes.
So, since the "partitions" node is new in v4.4, let's fixup the binding
before release so that it requires a compatible property, so it's much
clearer to distinguish. e.g.:
// proposed
partitions {
compatible = "fixed-partitions";
#size-cells = <y>;
partition@0 {
[1] Subject: "mtd: create a partition type device tree binding"
http://lkml.kernel.org/g/20151113220039.GA74382@google.com
http://lists.infradead.org/pipermail/linux-mtd/2015-November/063355.html
http://lists.infradead.org/pipermail/linux-mtd/2015-November/063364.html
Cc: Michal Suchanek <hramrach@gmail.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jkirsher/net-queue
Jeff Kirsher says:
Intel Wired LAN Driver Updates 2015-12-03
This series contains updates to ixgbe, i40e/i40evf, MAINTAINERS and e100.txt
Alex provides a fix for ixgbe where enabling SR-IOV and then bringing the
interface up was resulting in the PF MAC addresses getting into a bad state.
The workaround for this issue is to bring up the interface first and then
enable SR-IOV as this will trigger the reset in the existing code.
I clean up legacy license stuff in the e100.txt documentation and then
update the maintainers/reviewers list for our drivers.
Jesse fixes an issue with the i40e/i40evf drivers, where if the driver were
to happen to have a mutex held while the i40e_init_adminq() call was called,
the init_adminq might inadvertently call mutex_init on a lock that was held
which is a violation of the calling semantices.
"A lot of Thanksgiving turkey leftovers accumulated, here goes:
1) Fix bluetooth l2cap_chan object leak, from Johan Hedberg.
2) IDs for some new iwlwifi chips, from Oren Givon.
3) Fix rtlwifi lockups on boot, from Larry Finger.
4) Fix memory leak in fm10k, from Stephen Hemminger.
5) We have a route leak in the ipv6 tunnel infrastructure, fix from
Paolo Abeni.
6) Fix buffer pointer handling in arm64 bpf JIT,f rom Zi Shen Lim.
7) Wrong lockdep annotations in tcp md5 support, fix from Eric
Dumazet.
8) Work around some middle boxes which prevent proper handling of TCP
Fast Open, from Yuchung Cheng.
9) TCP repair can do huge kmalloc() requests, build paged SKBs
instead. From Eric Dumazet.
10) Fix msg_controllen overflow in scm_detach_fds, from Daniel
Borkmann.
11) Fix device leaks on ipmr table destruction in ipv4 and ipv6, from
Nikolay Aleksandrov.
12) Fix use after free in epoll with AF_UNIX sockets, from Rainer
Weikusat.
13) Fix double free in VRF code, from Nikolay Aleksandrov.
14) Fix skb leaks on socket receive queue in tipc, from Ying Xue.
15) Fix ifup/ifdown crach in xgene driver, from Iyappan Subramanian.
16) Fix clearing of persistent array maps in bpf, from Daniel
Borkmann.
17) In TCP, for the cross-SYN case, we don't initialize tp->copied_seq
early enough. From Eric Dumazet.
18) Fix out of bounds accesses in bpf array implementation when
updating elements, from Daniel Borkmann.
19) Fill gaps in RCU protection of np->opt in ipv6 stack, from Eric
Dumazet.
20) When dumping proxy neigh entries, we have to accomodate NULL
device pointers properly, from Konstantin Khlebnikov.
21) SCTP doesn't release all ipv6 socket resources properly, fix from
Eric Dumazet.
22) Prevent underflows of sch->q.qlen for multiqueue packet
schedulers, also from Eric Dumazet.
23) Fix MAC and unicast list handling in bnxt_en driver, from Jeffrey
Huang and Michael Chan.
24) Don't actively scan radar channels, from Antonio Quartulli"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (110 commits)
net: phy: reset only targeted phy
bnxt_en: Setup uc_list mac filters after resetting the chip.
bnxt_en: enforce proper storing of MAC address
bnxt_en: Fixed incorrect implementation of ndo_set_mac_address
net: lpc_eth: remove irq > NR_IRQS check from probe()
net_sched: fix qdisc_tree_decrease_qlen() races
openvswitch: fix hangup on vxlan/gre/geneve device deletion
ipv4: igmp: Allow removing groups from a removed interface
ipv6: sctp: implement sctp_v6_destroy_sock()
arm64: bpf: add 'store immediate' instruction
ipv6: kill sk_dst_lock
ipv6: sctp: add rcu protection around np->opt
net/neighbour: fix crash at dumping device-agnostic proxy entries
sctp: convert sack_needed and sack_generation to bits
ipv6: add complete rcu protection around np->opt
bpf: fix allocation warnings in bpf maps and integer overflow
mvebu: dts: enable IP checksum with jumbo frames for Armada 38x on Port0
net: mvneta: enable setting custom TX IP checksum limit
net: mvneta: fix error path for building skb
Apparently the e100.txt document contained a "License" section left
over from days of old, which does not need to be in the kernel
documentation. So clean it up..
CC: John Ronciak <john.ronciak@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
Since Armada 38x SoC can support IP checksum for jumbo frames only on
a single port, it means that this feature should be enabled per-port,
rather than for the whole SoC.
This patch enables setting custom TX IP checksum limit by adding new
optional property to the mvneta device tree node. If not used, by
default 1600B is set for "marvell,armada-370-neta" and 9800B for other
strings, which ensures backward compatibility. Binding documentation
is updated accordingly.
Signed-off-by: Marcin Wojtas <mw@semihalf.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal management fixes from Zhang Rui:
"Specifics:
- several fixes and cleanups on Rockchip thermal drivers.
- add the missing support of RK3368 SoCs in Rockchip driver.
- small fixes on of-thermal, power_allocator, rcar driver, IMX, and
QCOM drivers, and also compilation fixes, on thermal.h, when thermal
is not selected"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux:
imx: thermal: use CPU temperature grade info for thresholds
thermal: fix thermal_zone_bind_cooling_device prototype
Revert "thermal: qcom_spmi: allow compile test"
thermal: rcar_thermal: remove redundant operation
thermal: of-thermal: Reduce log level for message when can't fine thermal zone
thermal: power_allocator: Use temperature reading from tz
thermal: rockchip: Support the RK3368 SoCs in thermal driver
thermal: rockchip: consistently use int for temperatures
thermal: rockchip: Add the sort mode for adc value increment or decrement
thermal: rockchip: improve the conversion function
thermal: rockchip: trivial: fix typo in commit
thermal: rockchip: better to compatible the driver for different SoCs
dt-bindings: rockchip-thermal: Support the RK3368 SoCs compatible
"There is a small backlog of at91 patches here, the most significant is
the addition of some sama5d2 Xplained nodes that were waiting on an
MFD include file to get merged through another tree.
We normally try to sort those out before the merge window opens, but
the maintainer wasn't aware of that here and I decided to merge the
changes this time as an exception.
On OMAP a series of audio changes for dra7 missed the merge window but
turned out to be necessary to fix a boot time imprecise external abort
error and to get audio working.
The other changes are the usual simple changes, here is a list sorted
by platform:
at91:
removal of a useless defconfig option
removal of some legacy DT pieces
use of the proper watchdog compatible string
update of the MAINTAINERS entries for some Atmel drivers
drivers/scpi:
hide get_scpi_ops in module from built-in code
imx:
add missing .irq_set_type for i.MX GPC irq_chip.
fix the wrong spi-num-chipselects settings for Vybrid DSPI devices.
fix a merge error in Vybrid dts regarding to ADC device property
keystone:
fix the optional PDSP firmware loading
fix linking RAM setup for QMs
fix crash with clk_ignore_unused
mediatek:
Enable SCPSYS power domain driver by default
mvebu:
fix QNAP TS219 power-off in dts
fix legacy get_irqnr_and_base for dove and orion5x
omap:
fix l4 related boot time errors for dm81xx
use lockless cldm/pwrdm api in omap4_boot_secondary
remove t410 abort handler to avoid hiding other critical errors
mark cpuidle tracepoints as _rcuidle
fix module alias for omap-ocp2scp
pxa:
palm: Fix typos in PWM lookup table code
renesas:
missing __initconst annotation for r8a7793_boards_compat_dt
rockchip:
disable mmc-tuning on the veyron-minnie board
adding the init state for the over-temperature-protection
zx:
only build power domain code when CONFIG_PM=y"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (31 commits)
ARM: OMAP4+: SMP: use lockless clkdm/pwrdm api in omap4_boot_secondary
arm: omap2+: add missing HWMOD_NO_IDLEST in 81xx hwmod data
ARM: orion5x: Fix legacy get_irqnr_and_base
ARM: dove: Fix legacy get_irqnr_and_base
soc: Mediatek: Enable SCPSYS power domain driver by default
ARM: dts: vfxxx: Fix dspi[01] spi-num-chipselects.
ARM: dts: keystone: k2l: fix kernel crash when clk_ignore_unused is not in bootargs
soc: ti: knav_qmss_queue: Fix linking RAM setup for queue managers
soc: ti: use request_firmware_direct() as acc firmware is optional
ARM: imx: add platform irq type setting in gpc
ARM: dts: vfxxx: Fix erroneous property in esdhc0 node
ARM: shmobile: r8a7793: proper constness with __initconst
scpi: hide get_scpi_ops in module from built-in code
ARM: zx: only build power domain code when CONFIG_PM=y
ARM: pxa: palm: Fix typos in PWM lookup table code
ARM: dts: Kirkwood: Fix QNAP TS219 power-off
ARM: dts: rockchip: Add OTP gpio pinctrl to rk3288 tsadc node
ARM: dts: rockchip: temporarily remove emmc hs200 speed from rk3288 minnie
MAINTAINERS: Atmel drivers: change NAND and ISI entries
ARM: at91/dt: sama5d2 Xplained: add several devices
Pull block layer fixes from Jens Axboe:
"A round of fixes/updates for the current series.
This looks a little bigger than it is, but that's mainly because we
pushed the lightnvm enabled null_blk change out of the merge window so
it could be updated a bit. The rest of the volume is also mostly
lightnvm. In particular:
- Lightnvm. Various fixes, additions, updates from Matias and
Javier, as well as from Wenwei Tao.
- NVMe:
- Fix for potential arithmetic overflow from Keith.
- Also from Keith, ensure that we reap pending completions from
a completion queue before deleting it. Fixes kernel crashes
when resetting a device with IO pending.
- Various little lightnvm related tweaks from Matias.
- Fixup flushes to go through the IO scheduler, for the cases where a
flush is not required. Fixes a case in CFQ where we would be
idling and not see this request, hence not break the idling. From
Jan Kara.
- Use list_{first,prev,next} in elevator.c for cleaner code. From
Gelian Tang.
- Fix for a warning trigger on btrfs and raid on single queue blk-mq
devices, where we would flush plug callbacks with preemption
disabled. From me.
- A mac partition validation fix from Kees Cook.
- Two merge fixes from Ming, marked stable. A third part is adding a
new warning so we'll notice this quicker in the future, if we screw
up the accounting.
- Cleanup of thread name/creation in mtip32xx from Rasmus Villemoes"
* 'for-linus' of git://git.kernel.dk/linux-block: (32 commits)
blk-merge: warn if figured out segment number is bigger than nr_phys_segments
blk-merge: fix blk_bio_segment_split
block: fix segment split
blk-mq: fix calling unplug callbacks with preempt disabled
mac: validate mac_partition is within sector
mtip32xx: use formatting capability of kthread_create_on_node
NVMe: reap completion entries when deleting queue
lightnvm: add free and bad lun info to show luns
lightnvm: keep track of block counts
nvme: lightnvm: use admin queues for admin cmds
lightnvm: missing free on init error
lightnvm: wrong return value and redundant free
null_blk: do not del gendisk with lightnvm
null_blk: use device addressing mode
null_blk: use ppa_cache pool
NVMe: Fix possible arithmetic overflow for max segments
blk-flush: Queue through IO scheduler when flush not required
null_blk: register as a LightNVM device
elevator: use list_{first,prev,next}_entry
lightnvm: cleanup queue before target removal
bootargs
Currently kernel crash randomly when K2L EVM is booted without
clk_ignore_unused in the bootargs. This workaround is not needed
on other K2 devices such as K2HK and K2E and with this fix, we can
remove the workaround altogether. netcp driver on K2L uses linked
ram on OSR (On chip Static RAM) and requires the clock to this peripheral
enabled for proper functioning. This is the reason for the kernel crash.
So add the clock node to fix this issue.
While at it, remove the workaround documentation as well.
With the fix applied, clk_summary dump shows the clock to OSR enabled.
cat /sys/kernel/debug/clk/clk_summary
------cut--------------
tcp3d-1 0 0 399360000 0 0
tcp3d-0 0 0 399360000 0 0
osr 1 1 399360000 0 0
fftc-0 0 0 399360000 0 0
-----cut----------------
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c fixes from Wolfram Sang:
"A few bugfixes and one PCI ID addition from I2C"
* 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: i801: add Intel Lewisburg device IDs
i2c: fix wakeup irq parsing
i2c: xiic: Prevent concurrent running of the IRQ handler and __xiic_start_xfer()
i2c: Revert "i2c: xiic: Do not reset controller before every transfer"
i2c: imx: fix a compiling error
Pull more power management and ACPI updates from Rafael Wysocki:
"These are mostly fixes and cleanups (ACPI core, PM core, cpufreq, ACPI
EC driver, device properties) including three reverts of recent
intel_pstate driver commits due to a regression introduced by one of
them plus support for Atom Airmont cores in intel_pstate (which really
boils down to adding new frequency tables for Airmont) and additional
turbostat updates.
Specifics:
- Revert three recent intel_pstate driver commits one of which
introduced a regression and the remaining two depend on the
problematic one (Rafael Wysocki).
- Fix breakage related to the recently introduced ACPI _CCA object
support in the PCI DMA setup code (Suravee Suthikulpanit).
- Fix up the recently introduced ACPI CPPC support to only use the
hardware-reduced version of the PCCT structure as the only
architecture to support it (ARM64) will only use hardware-reduced
ACPI anyway (Ashwin Chaugule).
- Fix a cpufreq mediatek driver build problem (Arnd Bergmann).
- Fix the SMBus transaction handling implementation in the ACPI core
to avoid re-entrant calls to wait_event_timeout() which makes
intermittent boot stalls related to the Smart Battery Subsystem
initialization go away and revert a workaround of another problem
with the same underlying root cause (Chris Bainbridge).
- Fix the generic wakeup interrupts framework to avoid using invalid
IRQ numbers (Dmitry Torokhov).
- Remove a redundant check from the ACPI EC driver (Markus Elfring).
- Modify the intel_pstate driver so it can support more Atom flavors
than just one (Baytrail) and add support for Atom Airmont cores
(which require new freqnency tables) to it (Philippe Longepe).
- Clean up MSR-related symbols in turbostat (Len Brown)"
* tag 'pm+acpi-4.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
PCI: Fix OF logic in pci_dma_configure()
Revert "Documentation: kernel_parameters for Intel P state driver"
cpufreq: mediatek: fix build error
cpufreq: intel_pstate: Add separate support for Airmont cores
cpufreq: intel_pstate: Replace BYT with ATOM
Revert "cpufreq: intel_pstate: Use ACPI perf configuration"
Revert "cpufreq: intel_pstate: Avoid calculation for max/min"
ACPI-EC: Drop unnecessary check made before calling acpi_ec_delete_query()
Revert "ACPI / SBS: Add 5 us delay to fix SBS hangs on MacBook"
ACPI / SMBus: Fix boot stalls / high CPU caused by reentrant code
PM / wakeirq: check that wake IRQ is valid before accepting it
ACPI / CPPC: Use h/w reduced version of the PCCT structure
x86: remove unused definition of MSR_NHM_PLATFORM_INFO
tools/power turbostat: use new name for MSR_PLATFORM_INFO
Adding Intel codename Lewisburg platform device IDs for SMBus.
Signed-off-by: Alexandra Yates <alexandra.yates@linux.intel.com>
Reviewed-by: Jean Delvare <jdelvare@suse.de>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
* pm-cpufreq:
* acpi-cppc:
Revert commit 053f56def57b (Documentation: kernel_parameters for Intel P
state driver) as the code documented by it has been reverted already.
Add support for registering as a LightNVM device. This allows us to
evaluate the performance of the LightNVM subsystem.
In /drivers/Makefile, LightNVM is moved above block device drivers
to make sure that the LightNVM media managers have been initialized
before drivers under /drivers/block are initialized.
Signed-off-by: Matias Bjørling <m@bjorling.me>
Fix by Jens Axboe to remove unneeded slab cache and the following
memory leak.
Signed-off-by: Jens Axboe <axboe@fb.com>
In order to allow panic actions to be processed, the ipmi watchdog
driver sets a new timeout value on panic. The 255s timeout
was designed to allow kdump and others actions on panic, as in
http://lkml.iu.edu/hypermail/linux/kernel/0711.3/0258.html
This is counter-intuitive for a end-user who sets watchdog timeout
value to something like 30s and who expects BMC to reset the system
within 30s of a panic.
This commit allows user to configure the timeout on panic.
Signed-off-by: Jean-Yves Faye <jean-yves.faye@c-s.fr>
Signed-off-by: Corey Minyard <cminyard@mvista.com>
Pull MIPS updates from Ralf Baechle:
"These are the highlists of the main MIPS pull request for 4.4:
- Add latencytop support
- Support appended DTBs
- VDSO support and initially use it for gettimeofday.
- Drop the .MIPS.abiflags and ELF NOTE sections from vmlinux
- Support for the 5KE, an internal test core.
- Switch all MIPS platfroms to libata drivers.
- Improved support, cleanups for ralink and Lantiq platforms.
- Support for the new xilfpga platform.
- A number of DTB improvments for BMIPS.
- Improved support for CM and CPS.
- Minor JZ4740 and BCM47xx enhancements"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (120 commits)
MIPS: idle: add case for CPU_5KE
MIPS: Octeon: Support APPENDED_DTB
MIPS: vmlinux: create a section for appended DTB
MIPS: Clean up compat_siginfo_t
MIPS: Fix PAGE_MASK definition
MIPS: BMIPS: Enable GZIP ramdisk and timed printks
MIPS: Add xilfpga defconfig
MIPS: xilfpga: Add mipsfpga platform code
MIPS: xilfpga: Add xilfpga device tree files.
dt-bindings: MIPS: Document xilfpga bindings and boot style
MIPS: Make MIPS_CMDLINE_DTB default
MIPS: Make the kernel arguments from dtb available
MIPS: Use USE_OF as the guard for appended dtb
MIPS: BCM63XX: Use pr_* instead of printk
MIPS: Loongson: Cleanup CONFIG_LOONGSON_SUSPEND.
MIPS: lantiq: Disable xbar fpi burst mode
MIPS: lantiq: Force the crossbar to big endian
MIPS: lantiq: Initialize the USB core on boot
MIPS: lantiq: Return correct value for fpi clock on ar9
MIPS: ralink: Add missing clock on rt305x
Pull more input updates from Dmitry Torokhov:
"An update to the tsc2005 driver that allows it to also support tsc2004
(basically the same controller, but uses i2c instead of spi bus), and
a couple of bug fixes"
Input: parkbd - drop bogus __init from parkbd_allocate_serio()
Input: elantech - add Fujitsu Lifebook U745 to force crc_enabled
Input: tsc2004 - add support for tsc2004
Input: tsc200x-core - rename functions and variables
Input: tsc2005 - separate SPI and core functions
Pull final round of SCSI updates from James Bottomley:
"Sorry for the delay in this patch which was mostly caused by getting
the merger of the mpt2/mpt3sas driver, which was seen as an essential
item of maintenance work to do before the drivers diverge too much.
Unfortunately, this caused a compile failure (detected by linux-next),
which then had to be fixed up and incubated.
In addition to the mpt2/3sas rework, there are updates from pm80xx,
lpfc, bnx2fc, hpsa, ipr, aacraid, megaraid_sas, storvsc and ufs plus
an assortment of changes including some year 2038 issues, a fix for a
remove before detach issue in some drivers and a couple of other minor
issues"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (141 commits)
mpt3sas: fix inline markers on non inline function declarations
sd: Clear PS bit before Mode Select.
ibmvscsi: set max_lun to 32
ibmvscsi: display default value for max_id, max_lun and max_channel.
mptfusion: don't allow negative bytes in kbuf_alloc_2_sgl()
scsi: pmcraid: replace struct timeval with ktime_get_real_seconds()
mvumi: 64bit value for seconds_since1970
be2iscsi: Fix bogus WARN_ON length check
scsi_scan: don't dump trace when scsi_prep_async_scan() is called twice
mpt3sas: Bump mpt3sas driver version to 09.102.00.00
mpt3sas: Single driver module which supports both SAS 2.0 & SAS 3.0 HBAs
mpt2sas, mpt3sas: Update the driver versions
mpt3sas: setpci reset kernel oops fix
mpt3sas: Added OEM Gen2 PnP ID branding names
mpt3sas: Refcount fw_events and fix unsafe list usage
mpt3sas: Refcount sas_device objects and fix unsafe list usage
mpt3sas: sysfs attribute to report Backup Rail Monitor Status
mpt3sas: Ported WarpDrive product SSS6200 support
mpt3sas: fix for driver fails EEH, recovery from injected pci bus error
mpt3sas: Manage MSI-X vectors according to HBA device type
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"This series contains HCH's changes to absorb configfs attribute
->show() + ->store() function pointer usage from it's original
tree-wide consumers, into common configfs code.
It includes usb-gadget, target w/ drivers, netconsole and ocfs2
changes to realize the improved simplicity, that now renders the
original include/target/configfs_macros.h CPP magic for fabric drivers
and others, unnecessary and obsolete.
And with common code in place, new configfs attributes can be added
easier than ever before.
Note, there are further improvements in-flight from other folks for
v4.5 code in configfs land, plus number of target fixes for post -rc1
code"
In the meantime, a new user of the now-removed old configfs API came in
through the char/misc tree in commit 7bd1d4093c2f ("stm class: Introduce
an abstraction for System Trace Module devices").
This merge resolution comes from Alexander Shishkin, who updated his stm
class tracing abstraction to account for the removal of the old
show_attribute and store_attribute methods in commit 517982229f78
("configfs: remove old API") from this pull. As Alexander says about
that patch:
"There's no need to keep an extra wrapper structure per item and the
awkward show_attribute/store_attribute item ops are no longer needed.
This patch converts policy code to the new api, all the while making
the code quite a bit smaller and easier on the eyes.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>"
That patch was folded into the merge so that the tree should be fully
bisectable.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (23 commits)
ocfs2/cluster: use per-attribute show and store methods
ocfs2/cluster: move locking into attribute store methods
netconsole: use per-attribute show and store methods
target: use per-attribute show and store methods
spear13xx_pcie_gadget: use per-attribute show and store methods
dlm: use per-attribute show and store methods
usb-gadget/f_serial: use per-attribute show and store methods
usb-gadget/f_phonet: use per-attribute show and store methods
usb-gadget/f_obex: use per-attribute show and store methods
usb-gadget/f_uac2: use per-attribute show and store methods
usb-gadget/f_uac1: use per-attribute show and store methods
usb-gadget/f_mass_storage: use per-attribute show and store methods
usb-gadget/f_sourcesink: use per-attribute show and store methods
usb-gadget/f_printer: use per-attribute show and store methods
usb-gadget/f_midi: use per-attribute show and store methods
usb-gadget/f_loopback: use per-attribute show and store methods
usb-gadget/ether: use per-attribute show and store methods
usb-gadget/f_acm: use per-attribute show and store methods
usb-gadget/f_hid: use per-attribute show and store methods
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm fixes from Dan Williams:
- three fixes tagged for -stable including a crash fix, simple
performance tweak, and an invalid i/o error.
- build regression fix for the nvdimm unit tests
- nvdimm documentation update
* 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
dax: fix __dax_pmd_fault crash
libnvdimm: documentation clarifications
libnvdimm, pmem: fix size trim in pmem_direct_access()
libnvdimm, e820: fix numa node for e820-type-12 pmem ranges
tools/testing/nvdimm, acpica: fix flag rename build breakage
Pull more documentation updates from Jon Corbet:
"A few more documentation patches that wandered in and have no reason
to wait; these include some improvements to the suggestions for email
clients and patch submission"
* tag '4.4-additional' of git://git.lwn.net/linux:
Documentation: Add minimal Mutt config for using Gmail
Documentation: Add note on sending files directly with Mutt
Documentation: dontdiff: remove media from dontdiff
Documentation/SubmittingPatches: discuss In-Reply-To
Remove email address from Documentation/filesystems/overlayfs.txt
can-doc: Add missing semicolon to example
This patchset attempts to new compatible for thermal founding
on RK3368 SoCs.
Signed-off-by: Caesar Wang <wxt@rock-chips.com>
Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
A bunch of changes that I hope will help in understanding it
better for first-time readers.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
SCSI queue for 4.4.
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree fixes from Rob Herring:
- Add empty of_translate_address needed for HiSilicon network driver.
- Fix alignment requirements for CMA regions in DT.
- Fix booting on PPC systems which can't do WARN() early.
- Rename ak4554 binding doc from .c to .txt.
* tag 'devicetree-fixes-for-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
of: Provide static inline function for of_translate_address if needed
drivers: of: of_reserved_mem: fixup the alignment with CMA setup
of: Print rather than WARN'ing when overlap check fails
dt-bindings: ak4554: extension should be .txt
This patch provides a minimal configuration to set up Mutt for
submitting plain text patches using Gmail.
Signed-off-by: Eddie Kovsky <ewk@edkovsky.org>
Reviewed-by: Darren Hart <dvhart@infradead.org>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Like 'git send-email', Mutt can also be used to send patches generated
with 'git format-patch'. This works regardless of the editor the
contributor has set up to use with Mutt.
