path: root/Documentation
2013-01-17rbd: kill create_snap sysfs entryAlex Elder
Josh proposed the following change, and I don't think I could explain it any better than he did: From: Josh Durgin <josh.durgin@inktank.com> Date: Tue, 24 Jul 2012 14:22:11 -0700 To: ceph-devel <ceph-devel@vger.kernel.org> Message-ID: <500F1203.9050605@inktank.com> From: Josh Durgin <josh.durgin@inktank.com> Right now the kernel still has one piece of rbd management duplicated from the rbd command line tool: snapshot creation. There's nothing special about snapshot creation that makes it advantageous to do from the kernel, so I'd like to remove the create_snap sysfs interface. That is, /sys/bus/rbd/devices/<id>/create_snap would be removed. Does anyone rely on the sysfs interface for creating rbd snapshots? If so, how hard would it be to replace with: rbd snap create pool/image@snap Is there any benefit to the sysfs interface that I'm missing? Josh This patch implements this proposal, removing the code that implements the "snap_create" sysfs interface for rbd images. As a result, quite a lot of other supporting code goes away. [elder@inktank.com: commented out rbd_req_sync_exec() to avoid warning] Suggested-by: Josh Durgin <josh.durgin@inktank.com> Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com> (based on commit 02cdb02ceab1f3dd9ac2bc899fc51f0e0e744782)
2013-01-11tcp: implement RFC 5961 3.2Eric Dumazet
[ Upstream commit 282f23c6ee343126156dd41218b22ece96d747e3 ] Implement the RFC 5691 mitigation against Blind Reset attack using RST bit. Idea is to validate incoming RST sequence, to match RCV.NXT value, instead of previouly accepted window : (RCV.NXT <= SEG.SEQ < RCV.NXT+RCV.WND) If sequence is in window but not an exact match, send a "challenge ACK", so that the other part can resend an RST with the appropriate sequence. Add a new sysctl, tcp_challenge_ack_limit, to limit number of challenge ACK sent per second. Add a new SNMP counter to count number of challenge acks sent. (netstat -s | grep TCPChallengeACK) Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Kiran Kumar Kella <kkiran@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-03get_dvb_firmware: fix download site for tda10046 firmwareMauro Carvalho Chehab
commit 25ec43d3e6306978cf66060ed18c4160ce8fc302 upstream. The previous website doesn't exist anymore. Update it to one site that actually exists. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26memcg: oom: fix totalpages calculation for memory.swappiness==0Michal Hocko
commit 9a5a8f19b43430752067ecaee62fc59e11e88fa6 upstream. oom_badness() takes a totalpages argument which says how many pages are available and it uses it as a base for the score calculation. The value is calculated by mem_cgroup_get_limit which considers both limit and total_swap_pages (resp. memsw portion of it). This is usually correct but since fe35004fbf9e ("mm: avoid swapping out with swappiness==0") we do not swap when swappiness is 0 which means that we cannot really use up all the totalpages pages. This in turn confuses oom score calculation if the memcg limit is much smaller than the available swap because the used memory (capped by the limit) is negligible comparing to totalpages so the resulting score is too small if adj!=0 (typically task with CAP_SYS_ADMIN or non zero oom_score_adj). A wrong process might be selected as result. The problem can be worked around by checking mem_cgroup_swappiness==0 and not considering swap at all in such a case. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-31ARM: at91/tc: fix typo in the DT documentJosh Wu
commit 11930c530f3edf81160e4962e363d579f5cdce7e upstream. Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02ALSA: hda - Workaround for silent output on VAIO Z with ALC889Takashi Iwai
commit e427c2375646789ecd0ccaef1a1e41458559ab2d upstream. On recent kernels, Realtek codec parser tries to optimize the routing aggressively and take the headphone output as primary at first. This caused a regression on VAIO Z with ALC889, the silent output from the speaker. The problem seems that the speaker pin must be connected to the first DAC (0x02) on this machine by some reason although the codec itself advertises the flexible routing with any DACs. This patch adds a fix-up for choosing the speaker pin as the primary so that the right DAC is assigned on this device. Reported-and-tested-by: Adam Williamson <awilliam@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-14i2c-i801: Add Device IDs for Intel Lynx Point-LP PCHJames Ralston
commit 4a8f1ddde942e232387e6129ce4f4c412e43802f upstream. Add the SMBus Device IDs for the Intel Lynx Point-LP PCH. Signed-off-by: James Ralston <james.d.ralston@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09stable: update references to older 2.6 versions for 3.xPaul Gortmaker
commit 2584f5212d97b664be250ad5700a2d0fee31a10d upstream. Also add information on where the respective trees are. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Rob Landley <rob@landley.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09ALSA: hda - add dock support for Thinkpad X230 TabletDavid Henningsson
commit 108cc108a3bb42fe4705df1317ff98e1e29428a6 upstream. Also add a model/fixup string "lenovo-dock", so that other Thinkpad users will be able to test this fixup easily, to see if it enables dock I/O for them as well. BugLink: https://bugs.launchpad.net/bugs/1026953 Tested-by: John McCarron <john.mccarron@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16dm: verity fix documentationMilan Broz
commit 18068bdd5f59229623b2fa518a6389e346642b0d upstream. Veritysetup is now part of cryptsetup package. Remove on-disk header description (which is not parsed in kernel) and point users to cryptsetup where it the format is documented. Mention units for block size paramaters. Fix target line specification and dmsetup parameters. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16stable: Allow merging of backports for serious user-visible performance issuesMel Gorman
commit eb3979f64d25120d60b9e761a4c58f70b1a02f86 upstream. Distribution kernel maintainers routinely backport fixes for users that were deemed important but not "something critical" as defined by the rules. To users of these kernels they are very serious and failing to fix them reduces the value of -stable. The problem is that the patches fixing these issues are often subtle and prone to regressions in other ways and need greater care and attention. To combat this, these "serious" backports should have a higher barrier to entry. This patch relaxes the rules to allow a distribution maintainer to merge to -stable a backported patch or small series that fixes a "serious" user-visible performance issue. They should include additional information on the user-visible bug affected and a link to the bugzilla entry if available. The same rules about the patch being already in mainline still apply. Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-01docs: update HOWTO for 2.6.x -> 3.x versioningKees Cook
commit 591bfc6bf9e5e25e464fd4c87d64afd5135667c4 upstream. The HOWTO document needed updating for the new kernel versioning. The git URI for -next was updated as well. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-14Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab: "For a some fix patches for v3.4, including a regression fix at DVB core" Fix up trivial conflicts in Documentation/feature-removal-schedule.txt * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: [media] gspca - sonixj: Fix a zero divide in isoc interrupt [media] media: videobuf2-dma-contig: include header for exported symbols [media] media: videobuf2-dma-contig: quiet sparse noise about plain integer as NULL pointer [media] media: vb2-memops: Export vb2_get_vma symbol [media] s5p-fimc: Correct memory allocation for VIDIOC_CREATE_BUFS [media] s5p-fimc: Fix locking in subdev set_crop op [media] dvb_frontend: fix a regression with DVB-S zig-zag [media] fintek-cir: change || to && [media] V4L: Schedule V4L2_CID_HCENTER, V4L2_CID_VCENTER controls for removal [media] rc: Postpone ISR registration [media] marvell-cam: fix an ARM build error [media] V4L: soc-camera: protect hosts during probing from overzealous user-space
2012-05-05Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound sound fixes from Takashi Iwai: "As good as nothing exciting here; just a few trivial fixes for various ASoC stuff." * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ASoC: omap-pcm: Free dma buffers in case of error. ASoC: s3c2412-i2s: Fix dai registration ASoC: wm8350: Don't use locally allocated codec struct ASoC: tlv312aic23: unbreak resume ASoC: bf5xx-ssm2602: Set DAI format ASoC: core: check of_property_count_strings failure ASoC: dt: sgtl5000.txt: Add description for 'reg' field ASoC: wm_hubs: Make sure we don't disable differential line outputs
2012-05-05Merge tag 'asoc-3.4' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Updates for 3.4 Nothing terribly exciting here, a bunch of small and simple fixes scattered around the place.
2012-05-03Merge tag 'tag/upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev Pull libata fixes from Jeff Garzik: 1) Fix regression that could cause a misdiagnosis, which in turn could lead to an erroneous 3.0 Gbps -> 1.5 downshift, particularly when hotplug and suspend/resume is involved. 2) Fix a regression that led to ata%d controller ids being numbered one larger than in <= 3.4-rc3 (oh, the horror!). Controller ids should now be as expected. 3) add some DT, PCI id's 4) ata/pata_arasan_cf: minor cpp fixing/cleaning * tag 'tag/upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: ata: ahci_platform: Add synopsys ahci controller in DT's compatible list ata/pata_arasan_cf: Move arasan_cf_pm_ops out of #ifdef, #endif macros libata: init ata_print_id to 0 ahci: Detect Marvell 88SE9172 SATA controller libata: skip old error history when counting probe trials
2012-05-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Transfer padding was wrong for full-speed USB in ASIX driver, fix from Ingo van Lil. 2) Propagate the negative packet offset fix into the PowerPC BPF JIT. From Jan Seiffert. 3) dl2k driver's private ioctls were letting unprivileged tasks make MII writes and other ugly bits like that. Fix from Jeff Mahoney. 4) Fix TX VLAN and RX packet drops in ucc_geth, from Joakim Tjernlund. 5) OOPS and network namespace fixes in IPVS from Hans Schillstrom and Julian Anastasov. 6) Fix races and sleeping in locked context bugs in drop_monitor, from Neil Horman. 7) Fix link status indication in smsc95xx driver, from Paolo Pisati. 8) Fix bridge netfilter OOPS, from Peter Huang. 9) L2TP sendmsg can return on error conditions with the socket lock held, oops. Fix from Sasha Levin. 10) udp_diag should return meaningful values for socket memory usage, from Shan Wei. 11) Eric Dumazet is so awesome he gets his own section: Socket memory cgroup code (I never should have applied those patches, grumble...) made erroneous changes to sk_sockets_allocated_read_positive(). It was changed to use percpu_counter_sum_positive (which requires BH disabling) instead of percpu_counter_read_positive (which does not). Revert back to avoid crashes and lockdep warnings. Adjust the default tcp_adv_win_scale and tcp_rmem[2] values to fix throughput regressions. This is necessary as a result of our more precise skb->truesize tracking. Fix SKB leak in netem packet scheduler. 12) New device IDs for various bluetooth devices, from Manoj Iyer, AceLan Kao, and Steven Harms. 13) Fix command completion race in ipw2200, from Stanislav Yakovlev. 14) Fix rtlwifi oops on unload, from Larry Finger. 15) Fix hard_mtu when adjusting hard_header_len in smsc95xx driver. From Stephane Fillod. 16) ehea driver registers it's IRQ before all the necessary state is setup, resulting in crashes. Fix from Thadeu Lima de Souza Cascardo. 17) Fix PHY connection failures in davinci_emac driver, from Anatolij Gustschin. 18) Missing break; in switch statement in bluetooth's hci_cmd_complete_evt(). Fix from Szymon Janc. 19) Fix queue programming in iwlwifi, from Johannes Berg. 20) Interrupt throttling defaults not being actually programmed into the hardware, fix from Jeff Kirsher and Ying Cai. 21) TLAN driver SKB encoding in descriptor busted on 64-bit, fix from Benjamin Poirier. 22) Fix blind status block RX producer pointer deref in TG3 driver, from Matt Carlson. 23) Promisc and multicast are busted on ehea, fixes from Thadeu Lima de Souza Cascardo. 24) Fix crashes in 6lowpan, from Alexander Smirnov. 25) tcp_complete_cwr() needs to be careful to not rewind the CWND to ssthresh if ssthresh has the "infinite" value. Fix from Yuchung Cheng. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (81 commits) sungem: Fix WakeOnLan tcp: change tcp_adv_win_scale and tcp_rmem[2] net: l2tp: unlock socket lock before returning from l2tp_ip_sendmsg drop_monitor: prevent init path from scheduling on the wrong cpu usbnet: fix failure handling in usbnet_probe usbnet: fix leak of transfer buffer of dev->interrupt ucc_geth: Add 16 bytes to max TX frame for VLANs net: ucc_geth, increase no. of HW RX descriptors netem: fix possible skb leak sky2: fix receive length error in mixed non-VLAN/VLAN traffic sky2: propogate rx hash when packet is copied net: fix two typos in skbuff.h cxgb3: Don't call cxgb_vlan_mode until q locks are initialized ixgbe: fix calling skb_put on nonlinear skb assertion bug ixgbe: Fix a memory leak in IEEE DCB igbvf: fix the bug when initializing the igbvf smsc75xx: enable mac to detect speed/duplex from phy smsc75xx: declare smsc75xx's MII as GMII capable smsc75xx: fix phy interrupt acknowledge smsc75xx: fix phy init reset loop ...
2012-05-03ata: ahci_platform: Add synopsys ahci controller in DT's compatible listViresh Kumar
SPEAr13xx series of SoCs contain Synopsys AHCI SATA Controller which shares ahci_platform driver with other controller versions. This patch updates DT compatible list for ahci_platform. It also updates and renames binding documentation to more generic name. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Cc: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-05-02tcp: change tcp_adv_win_scale and tcp_rmem[2]Eric Dumazet
tcp_adv_win_scale default value is 2, meaning we expect a good citizen skb to have skb->len / skb->truesize ratio of 75% (3/4) In 2.6 kernels we (mis)accounted for typical MSS=1460 frame : 1536 + 64 + 256 = 1856 'estimated truesize', and 1856 * 3/4 = 1392. So these skbs were considered as not bloated. With recent truesize fixes, a typical MSS=1460 frame truesize is now the more precise : 2048 + 256 = 2304. But 2304 * 3/4 = 1728. So these skb are not good citizen anymore, because 1460 < 1728 (GRO can escape this problem because it build skbs with a too low truesize.) This also means tcp advertises a too optimistic window for a given allocated rcvspace : When receiving frames, sk_rmem_alloc can hit sk_rcvbuf limit and we call tcp_prune_queue()/tcp_collapse() too often, especially when application is slow to drain its receive queue or in case of losses (netperf is fast, scp is slow). This is a major latency source. We should adjust the len/truesize ratio to 50% instead of 75% This patch : 1) changes tcp_adv_win_scale default to 1 instead of 2 2) increase tcp_rmem[2] limit from 4MB to 6MB to take into account better truesize tracking and to allow autotuning tcp receive window to reach same value than before. Note that same amount of kernel memory is consumed compared to 2.6 kernels. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Yuchung Cheng <ycheng@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-29Merge tag 'pm-for-3.4-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management fixes from Rafael J. Wysocki: "Fix for an issue causing hibernation to hang on systems with highmem (that practically means i386) due to broken memory management (bug introduced in 3.2, so -stable material) and PM documentation update making the freezer documentation follow the code again after some recent updates." * tag 'pm-for-3.4-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: PM / Freezer / Docs: Update documentation about freezing of tasks PM / Hibernate: fix the number of pages used for hibernate/thaw buffering
2012-04-29PM / Freezer / Docs: Update documentation about freezing of tasksMarcos Paulo de Souza
The file Documentation/power/freezing-of-tasks.txt was still referencing the TIF_FREEZE flag, that was removed by the commit d88e4cb67197d007fb778d62fe17360e970d5bfa(freezer: remove now unused TIF_FREEZE). This patch removes all the references of TIF_FREEZE that were left behind. Signed-off-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com> Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-04-26[media] V4L: Schedule V4L2_CID_HCENTER, V4L2_CID_VCENTER controls for removalSylwester Nawrocki
These controls have been marked for long time as V4L2_CID_HCENTER_DEPRECATED, V4L2_CID_VCENTER_DEPRECATED in the DocBook and are going to be removed from include/linux/videodev2.h. Signed-off-by: Sylwester Nawrocki <sylvester.nawrocki@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-25keys: update the documentation with info about "logon" keysJeff Layton
Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com>
2012-04-24ASoC: dt: sgtl5000.txt: Add description for 'reg' fieldFabio Estevam
Add description for 'reg' field. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-23HSI: Add HSI ABI documentationCarlos Chinea
Adds sysfs HSI framework documentation Signed-off-by: Carlos Chinea <carlos.chinea@nokia.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2012-04-21Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab: - Fixes a regression at DVB core when switching from DVB-S2 to DVB-S on Kaffeine (Fedora 16 Bugzilla #812895); - Fixes a mutex unlock at an error condition at drx-k; - Fix winbond-cir set mode; - mt9m032: Fix a compilation breakage with some random Kconfig; - mt9m032: fix two dead locks; - xc5000: don't require an special firmware (that won't be provided by the vendor) just because the xtal frequency is different; - V4L DocBook: fix some typos at multi-plane formats description. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: [media] xc5000: support 32MHz & 31.875MHz xtal using the 41.024.5 firmware [media] V4L: mt9m032: fix compilation breakage [media] V4L: DocBook: Fix typos in the multi-plane formats description [media] V4L: mt9m032: fix two dead-locks [media] rc-core: set mode for winbond-cir [media] drxk: Does not unlock mutex if sanity check failed in scu_command() [media] dvb_frontend: Fix a regression when switching back to DVB-S
2012-04-19[media] V4L: DocBook: Fix typos in the multi-plane formats descriptionSylwester Nawrocki
2012-04-15Merge tag 'sound-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull another round of sound fixes from Takashi Iwai: "A few regression fixes for Realtek HD-audio codecs, mainly specific to some laptop models." * tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda/realtek - Fix mem leak (and rid us of trailing whitespace). ALSA: hda/realtek - Add quirk for Mac Pro 5,1 machines ALSA: hda/realtek - Add a fixup entry for Acer Aspire 8940G ALSA: hda/realtek - Fix GPIO1 setup for Acer Aspire 4930 & co ALSA: hda/realtek - Add a few ALC882 model strings back
2012-04-13Merge branch 'for-3.4/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver bits from Jens Axboe: - A series of fixes for mtip32xx. Most from Asai at Micron, but also one from Greg, getting rid of the dependency on PCIE_HOTPLUG. - A few bug fixes for xen-blkfront, and blkback. - A virtio-blk fix for Vivek, making resize actually work. - Two fixes from Stephen, making larger transfers possible on cciss. This is needed for tape drive support. * 'for-3.4/drivers' of git://git.kernel.dk/linux-block: block: mtip32xx: remove HOTPLUG_PCI_PCIE dependancy mtip32xx: dump tagmap on failure mtip32xx: fix handling of commands in various scenarios mtip32xx: Shorten macro names mtip32xx: misc changes mtip32xx: Add new sysfs entry 'status' mtip32xx: make setting comp_time as common mtip32xx: Add new bitwise flag 'dd_flag' mtip32xx: fix error handling in mtip_init() virtio-blk: Call revalidate_disk() upon online disk resize xen/blkback: Make optional features be really optional. xen/blkback: Squash the discard support for 'file' and 'phy' type. mtip32xx: fix incorrect value set for drv_cleanup_done, and re-initialize and start port in mtip_restart_port() cciss: Fix scsi tape io with more than 255 scatter gather elements cciss: Initialize scsi host max_sectors for tape drive support xen-blkfront: make blkif_io_lock spinlock per-device xen/blkfront: don't put bdev right after getting it xen-blkfront: use bitmap_set() and bitmap_clear() xen/blkback: Enable blkback on HVM guests xen/blkback: use grant-table.c hypercall wrappers
2012-04-13Merge branch 'for-3.4/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block core bits from Jens Axboe: "It's a nice and quiet round this time, since most of the tricky stuff has been pushed to 3.5 to give it more time to mature. After a few hectic block IO core changes for 3.3 and 3.2, I'm quite happy with a slow round. Really minor stuff in here, the only real functional change is making the auto-unplug threshold a per-queue entity. The threshold is set so that it's low enough that we don't hold off IO for too long, but still big enough to get a nice benefit from the batched insert (and hence queue lock cost reduction). For raid configurations, this currently breaks down." * 'for-3.4/core' of git://git.kernel.dk/linux-block: block: make auto block plug flush threshold per-disk based Documentation: Add sysfs ABI change for cfq's target latency. block: Make cfq_target_latency tunable through sysfs. block: use lockdep_assert_held for queue locking block: blk_alloc_queue_node(): use caller's GFP flags instead of GFP_KERNEL
2012-04-12Merge tag 'usb-3.4-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg KH: "Here are a number of fixes for the USB core and drivers for 3.4-rc2 Lots of tiny xhci fixes here, a few usb-serial driver fixes and new device ids, and a smattering of other minor fixes in different USB drivers. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'usb-3.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (30 commits) USB: update usbtmc api documentation xHCI: Correct the #define XHCI_LEGACY_DISABLE_SMI xHCI: use gfp flags from caller instead of GFP_ATOMIC xHCI: add XHCI_RESET_ON_RESUME quirk for VIA xHCI host USB: fix bug of device descriptor got from superspeed device xhci: Fix register save/restore order. xhci: Restore event ring dequeue pointer on resume. xhci: Don't write zeroed pointers to xHC registers. xhci: Warn when hosts don't halt. xhci: don't re-enable IE constantly usb: xhci: fix section mismatch in linux-next xHCI: correct to print the true HSEE of USBCMD USB: serial: fix race between probe and open UHCI: hub_status_data should indicate if ports are resuming EHCI: keep track of ports being resumed and indicate in hub_status_data USB: fix race between root-hub suspend and remote wakeup USB: sierra: add support for Sierra Wireless MC7710 USB: ftdi_sio: fix race condition in TIOCMIWAIT, and abort of TIOCMIWAIT when the device is removed USB: ftdi_sio: fix status line change handling for TIOCMIWAIT and TIOCGICOUNT USB: don't ignore suspend errors for root hubs ...
2012-04-12Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Thomas Gleixner: "The itimer removal one is not strictly a fix, but I really wanted to avoid a rebase of the urgent ones." * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: Revert "clocksource: Load the ACPI PM clocksource asynchronously" clockevents: tTack broadcast device mode change in tick_broadcast_switch_to_oneshot() itimer: Use printk_once instead of WARN_ONCE nohz: Fix stale jiffies update in tick_nohz_restart() tick: Document TICK_ONESHOT config option proc: stats: Use arch_idle_time for idle and iowait times if available itimer: Schedule silent NULL pointer fixup in setitimer() for removal
2012-04-12Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge fixes from Andrew Morton. * emailed from Andrew Morton <akpm@linux-foundation.org>: (14 patches) panic: fix stack dump print on direct call to panic() drivers/rtc/rtc-pl031.c: enable clock on all ST variants Revert "mm: vmscan: fix misused nr_reclaimed in shrink_mem_cgroup_zone()" hugetlb: fix race condition in hugetlb_fault() drivers/rtc/rtc-twl.c: use static register while reading time drivers/rtc/rtc-s3c.c: add placeholder for driver private data drivers/rtc/rtc-s3c.c: fix compilation error MAINTAINERS: add PCDP console maintainer memcg: do not open code accesses to res_counter members drivers/rtc/rtc-efi.c: fix section mismatch warning drivers/rtc/rtc-r9701.c: reset registers if invalid values are detected drivers/char/random.c: fix boot id uniqueness race memcg: fix broken boolen expression memcg: fix up documentation on global LRU
2012-04-12memcg: fix up documentation on global LRUYing Han
In v3.3-rc1, the global LRU was removed in commit 925b7673cce3 ("mm: make per-memcg LRU lists exclusive"). The patch fixes up the memcg docs. I left the swap session to someone who has better understanding of 'memory+swap'. Signed-off-by: Ying Han <yinghan@google.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-12USB: update usbtmc api documentationStephen Lewis
Correct path names in API documentation for usbtmc Signed-off-by: Stephen Lewis <lewis@sdf.lonestar.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-11ALSA: hda/realtek - Add a few ALC882 model strings backTakashi Iwai
Since there are still many Acer models that might not be covered by the current fixup table, let's add back a few typical model names so that user can test the fixup without recompiling. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-09mtip32xx: Add new sysfs entry 'status'Asai Thambi S P
* Add support for detecting the following device status - write protect - over temp (thermal shutdown) * Add new sysfs entry 'status', possible values - online, write_protect, thermal_shutdown * Add new file 'sysfs-block-rssd' to document ABI (Reported-by: Greg Kroah-Hartman) Signed-off-by: Asai Thambi S P <asamymuthupa@micron.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-04-09typo fix in Documentation/filesystems/vfs.txtAl Viro
2012-04-08Merge 3.2-rc1 into usb-linusGreg Kroah-Hartman
This is needed to catch the resume bug that was bothering lots of us from testing some XHCI bug fixes in the suspend/resume path. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-06USB documentation: explain lifetime rules for unlinking URBsAlan Stern
This patch (as1534c) updates the documentation for usb_unlink_urb and related functions. It explains that the caller must prevent the URB being unlinked from getting deallocated while the unlink is taking place. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-06usb/usbmon: correct the data interpretation of usbmon's outputSebastian Andrzej Siewior
The doc says that the data | 55534243 5e000000 00000000 00000600 00000000 00000000 00000000 000000 is the SCSI command 0x5e. According to the usbmon source, it dumps one byte after the other. The first 4 bytes are US_BULK_CB_SIGN which is correct. After that we see the TAG which is 0x5e. The cdb is 0x00 in this example. In order to correct this, I change the example to a READ_10 command which is 0x28 so it is not just a zero somewhere in the stream. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking updates from David Miller: 1) Fix inaccuracies in network driver interface documentation, from Ben Hutchings. 2) Fix handling of negative offsets in BPF JITs, from Jan Seiffert. 3) Compile warning, locking, and refcounting fixes in netfilter's xt_CT, from Pablo Neira Ayuso. 4) phonet sendmsg needs to validate user length just like any other datagram protocol, fix from Sasha Levin. 5) Ipv6 multicast code uses wrong loop index, from RongQing Li. 6) Link handling and firmware fixes in bnx2x driver from Yaniv Rosner and Yuval Mintz. 7) mlx4 erroneously allocates 4 pages at a time, regardless of page size, fix from Thadeu Lima de Souza Cascardo. 8) SCTP socket option wasn't extended in a backwards compatible way, fix from Thomas Graf. 9) Add missing address change event emissions to bonding, from Shlomo Pongratz. 10) /proc/net/dev regressed because it uses a private offset to track where we are in the hash table, but this doesn't track the offset pullback that the seq_file code does resulting in some entries being missed in large dumps. Fix from Eric Dumazet. 11) do_tcp_sendpage() unloads the send queue way too fast, because it invokes tcp_push() when it shouldn't. Let the natural sequence generated by the splice paths, and the assosciated MSG_MORE settings, guide the tcp_push() calls. Otherwise what goes out of TCP is spaghetti and doesn't batch effectively into GSO/TSO clusters. From Eric Dumazet. 12) Once we put a SKB into either the netlink receiver's queue or a socket error queue, it can be consumed and freed up, therefore we cannot touch it after queueing it like that. Fixes from Eric Dumazet. 13) PPP has this annoying behavior in that for every transmit call it immediately stops the TX queue, then calls down into the next layer to transmit the PPP frame. But if that next layer can take it immediately, it just un-stops the TX queue right before returning from the transmit method. Besides being useless work, it makes several facilities unusable, in particular things like the equalizers. Well behaved devices should only stop the TX queue when they really are full, and in PPP's case when it gets backlogged to the downstream device. David Woodhouse therefore fixed PPP to not stop the TX queue until it's downstream can't take data any more. 14) IFF_UNICAST_FLT got accidently lost in some recent stmmac driver changes, re-add. From Marc Kleine-Budde. 15) Fix link flaps in ixgbe, from Eric W. Multanen. 16) Descriptor writeback fixes in e1000e from Matthew Vick. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits) net: fix a race in sock_queue_err_skb() netlink: fix races after skb queueing doc, net: Update ndo_start_xmit return type and values doc, net: Remove instruction to set net_device::trans_start doc, net: Update netdev operation names doc, net: Update documentation of synchronisation for TX multiqueue doc, net: Remove obsolete reference to dev->poll ethtool: Remove exception to the requirement of holding RTNL lock MAINTAINERS: update for Marvell Ethernet drivers bonding: properly unset current_arp_slave on slave link up phonet: Check input from user before allocating tcp: tcp_sendpages() should call tcp_push() once ipv6: fix array index in ip6_mc_add_src() mlx4: allocate just enough pages instead of always 4 pages stmmac: re-add IFF_UNICAST_FLT for dwmac1000 bnx2x: Clear MDC/MDIO warning message bnx2x: Fix BCM57711+BCM84823 link issue bnx2x: Clear BCM84833 LED after fan failure bnx2x: Fix BCM84833 PHY FW version presentation bnx2x: Fix link issue for BCM8727 boards. ...
2012-04-06doc, net: Update ndo_start_xmit return type and valuesBen Hutchings
Commit dc1f8bf68b311b1537cb65893430b6796118498a ('netdev: change transmit to limited range type') changed the required return type and 9a1654ba0b50402a6bd03c7b0fe9b0200a5ea7b1 ('net: Optimize hard_start_xmit() return checking') changed the valid numerical return values. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-06doc, net: Remove instruction to set net_device::trans_startBen Hutchings
Commit 08baf561083bc27a953aa087dd8a664bb2b88e8e ('net: txq_trans_update() helper') made it unnecessary for most drivers to set net_device::trans_start (or netdev_queue::trans_start). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-06doc, net: Update netdev operation namesBen Hutchings
Commits d314774cf2cd5dfeb39a00d37deee65d4c627927 ('netdev: network device operations infrastructure') and 008298231abbeb91bc7be9e8b078607b816d1a4a ('netdev: add more functions to netdevice ops') moved and renamed net device operation pointers. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-06doc, net: Update documentation of synchronisation for TX multiqueueBen Hutchings
Commits e308a5d806c852f56590ffdd3834d0df0cbed8d7 ('netdev: Add netdev->addr_list_lock protection.') and e8a0464cc950972824e2e128028ae3db666ec1ed ('netdev: Allocate multiple queues for TX.') introduced more fine-grained locks. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-06doc, net: Remove obsolete reference to dev->pollBen Hutchings
Commit bea3348eef27e6044b6161fd04c3152215f96411 ('[NET]: Make NAPI polling independent of struct net_device objects.') removed the automatic disabling of NAPI polling by dev_close(), and drivers must now do this themselves. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-05Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: SoC fixes: from Olof Johansson: "A bunch of fixes for regressions (and a few other problems) in 3.4-rc1: - Fix for regression of mach/io.h cleanup on platforms with PCI or PCMCIA (adding back the include file on those for now) - AT91 fixes for usb and spi - smsc911x ethernet fixes for i.MX - smsc911x fixes for OMAP - gpio fixes for Tegra - A handful of build error and warning fixes for various platforms - cpufreq kconfig dependencies, build and lowlevel debug fixes for Samsung platforms In other words, more or less the regular collection of -rc1/2 type material. A few of them, in particular the smsc911x for OMAP series, aren't technically regressions for 3.4, but they're valid fixes and we're still relatively early in the rc cycle so it seems appropriate to include them." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (60 commits) ARM: fix __io macro for PCMCIA ARM: EXYNOS: Fix compiler warning in dma.c file ARM: EXYNOS: fix ISO C90 warning ARM: OMAP2+: hwmod: Fix wrong SYSC_TYPE1_XXX_MASK bit definitions ARM: OMAP2+: hwmod: Make omap_hwmod_softreset wait for reset status ARM: OMAP2+: hwmod: Restore sysc after a reset ARM: OMAP2+: omap_hwmod: Allow io_ring wakeup configuration for all modules ARM: OMAP3: clock data: fill in some missing clockdomains ARM: OMAP4: clock data: Force a DPLL clkdm/pwrdm ON before a relock ARM: OMAP4: clock data: fix mult and div mask for USB_DPLL ARM: OMAP2+: powerdomain: Wait for powerdomain transition in pwrdm_state_switch() gpio: tegra: Iterate over the correct number of banks gpio: tegra: fix register address calculations for Tegra30 EXYNOS: fix dependency for EXYNOS_CPUFREQ ARM: at91: dt: remove unit-address part for memory nodes ARM: at91: fix check of valid GPIO for SPI and USB USB: ehci-atmel: add needed of.h header file ARM: at91/NAND DT bindings: add comments ARM: at91/at91sam9x5.dtsi: fix NAND ale/cle in DT file USB: ohci-at91: trivial return code name change ...
2012-04-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull DMA mapping branch from Marek Szyprowski: "Short summary for the whole series: A few limitations have been identified in the current dma-mapping design and its implementations for various architectures. There exist more than one function for allocating and freeing the buffers: currently these 3 are used dma_{alloc, free}_coherent, dma_{alloc,free}_writecombine, dma_{alloc,free}_noncoherent. For most of the systems these calls are almost equivalent and can be interchanged. For others, especially the truly non-coherent ones (like ARM), the difference can be easily noticed in overall driver performance. Sadly not all architectures provide implementations for all of them, so the drivers might need to be adapted and cannot be easily shared between different architectures. The provided patches unify all these functions and hide the differences under the already existing dma attributes concept. The thread with more references is available here: http://www.spinics.net/lists/linux-sh/msg09777.html These patches are also a prerequisite for unifying DMA-mapping implementation on ARM architecture with the common one provided by dma_map_ops structure and extending it with IOMMU support. More information is available in the following thread: http://thread.gmane.org/gmane.linux.kernel.cross-arch/12819 More works on dma-mapping framework are planned, especially in the area of buffer sharing and managing the shared mappings (together with the recently introduced dma_buf interface: commit d15bd7ee445d "dma-buf: Introduce dma buffer sharing mechanism"). The patches in the current set introduce a new alloc/free methods (with support for memory attributes) in dma_map_ops structure, which will later replace dma_alloc_coherent and dma_alloc_writecombine functions." People finally started piping up with support for merging this, so I'm merging it as the last of the pending stuff from the merge window. Looks like pohmelfs is going to wait for 3.5 and more external support for merging. * 'for-linus' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: common: DMA-mapping: add NON-CONSISTENT attribute common: DMA-mapping: add WRITE_COMBINE attribute common: dma-mapping: introduce mmap method common: dma-mapping: remove old alloc_coherent and free_coherent methods Hexagon: adapt for dma_map_ops changes Unicore32: adapt for dma_map_ops changes Microblaze: adapt for dma_map_ops changes SH: adapt for dma_map_ops changes Alpha: adapt for dma_map_ops changes SPARC: adapt for dma_map_ops changes PowerPC: adapt for dma_map_ops changes MIPS: adapt for dma_map_ops changes X86 & IA64: adapt for dma_map_ops changes common: dma-mapping: introduce generic alloc() and free() methods
2012-04-04Merge tag 'regulator-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator fixes from Mark Brown: "A bunch of smallish fixes that came up during the merge window as things got more testing - even more fixes from Axel, a fix for error handling in more complex systems using -EPROBE_DEFER and a couple of small fixes for the new dummy regulators." * tag 'regulator-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: regulator: Remove non-existent parameter from fixed-helper.c kernel doc regulator: Fix setting new voltage in s5m8767_set_voltage regulator: fix sysfs name collision between dummy and fixed dummy regulator regulator: Fix deadlock on removal of regulators with supplies regulator: Fix comments in include/linux/regulator/machine.h regulator: Only update [LDOx|DCx]_HIB_MODE bits in wm8350_[ldo|dcdc]_set_suspend_disable regulator: Fix setting low power mode for wm831x aldo regulator: Return microamps in wm8350_isink_get_current regulator: wm8350: Fix the logic to choose best current limit setting regulator: wm831x-isink: Fix the logic to choose best current limit setting regulator: wm831x-dcdc: Fix the logic to choose best current limit setting regulator: anatop: patching to device-tree property "reg". regulator: Do proper shift to set correct bit for DC[2|5]_HIB_MODE setting regulator: Fix restoring pmic.dcdcx_hib_mode settings in wm8350_dcdc_set_suspend_enable regulator: Fix unbalanced lock/unlock in mc13892_regulator_probe error path regulator: Fix set and get current limit for wm831x_buckv regulator: tps6586x: Fix list minimal voltage setting for LDO0
