commit e4144fe5d47c91c92d36cdbd5f31ed8d6e3a57ab upstream.
The HOWTO document needed updating for the new kernel versioning.
Signed-off-by: Mario Carrillo <mario.alfredo.c.arevalo@intel.com>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
[ Upstream commit 4cba5c2103657d43d0886e4cff8004d95a3d0def in net-next tree,
will be pushed to Linus very soon. ]
Currently the PHY management type is selected by the MAC driver arbitrary.
The decision is based on the presence of the "fixed-link" node and on a
will of the driver's authors.
This caused a regression recently, when mvneta driver suddenly started
to use the in-band status for auto-negotiation on fixed links.
It appears the auto-negotiation may not work when expected by the MAC driver.
Sebastien Rannou explains:
<< Yes, I confirm that my HW does not generate an in-band status. AFAIK, it's
a PHY that aggregates 4xSGMIIs to 1xQSGMII ; the MAC side of the PHY (with
inband status) is connected to the switch through QSGMII, and in this context
we are on the media side of the PHY. >>
https://lkml.org/lkml/2015/7/10/206
This patch introduces the new string property 'managed' that allows
the user to set the management type explicitly.
The supported values are:
"auto" - default. Uses either MDIO or nothing, depending on the presence
of the fixed-link node
"in-band-status" - use in-band status
Signed-off-by: Stas Sergeev <stsp@users.sourceforge.net>
CC: Rob Herring <robh+dt@kernel.org>
CC: Pawel Moll <pawel.moll@arm.com>
CC: Mark Rutland <mark.rutland@arm.com>
CC: Ian Campbell <ijc+devicetree@hellion.org.uk>
CC: Kumar Gala <galak@codeaurora.org>
CC: Florian Fainelli <f.fainelli@gmail.com>
CC: Grant Likely <grant.likely@linaro.org>
CC: devicetree@vger.kernel.org
CC: linux-kernel@vger.kernel.org
CC: netdev@vger.kernel.org
commit bd49784fd1e8f42c7600fbfa206361324857f373 upstream.
If the user selected the precise_timestamps or histogram options, report
it in the @stats_list message output.
If the user didn't select these options, no extra tokens are reported,
thus it is backward compatible with old software that doesn't know about
precise timestamps and histogram.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Cc: stable@vger.kernel.org # 4.2
commit 4bc58eb16bb2352854b9c664cc36c1c68d2bfbb7 upstream.
Fix the name of attribute
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 8cd50626823c00ca7472b2f61cb8c0eb9798ddc0 upstream.
commit f811a38300be3cdb603171aea5ad3fb42b71ca53 upstream.
testusb.c at http://www.linux-usb.org/usbtest/ is out of date,
using the one at the kernel source folder.
Pull ARM SoC fixes from Olof Johansson:
"A smallish batch of fixes, a little more than expected this late, but
all fixes are contained to their platforms and seem reasonably low
risk:
- a somewhat large SMP fix for ux500 that still seemed warranted to
include here
- OMAP DT fixes for pbias regulator specification that broke due to
some DT reshuffling
- PCIe IRQ routing bugfix for i.MX
- networking fixes for keystone
- runtime PM for OMAP GPMC
- a couple of error path bug fixes for exynos"
* tag 'armsoc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: dts: keystone: Fix the mdio bindings by moving it to soc specific file
ARM: dts: keystone: fix the clock node for mdio
memory: omap-gpmc: Don't try to save uninitialized GPMC context
ARM: imx6: correct i.MX6 PCIe interrupt routing
ARM: ux500: add an SMP enablement type and move cpu nodes
ARM: dts: dra7: Fix broken pbias device creation
ARM: dts: OMAP5: Fix broken pbias device creation
ARM: dts: OMAP4: Fix broken pbias device creation
ARM: dts: omap243x: Fix broken pbias device creation
ARM: EXYNOS: fix double of_node_put() on error path
ARM: EXYNOS: Fix potentian kfree() of ro memory
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input subsystem fixes from Dmitry Torokhov:
"Just small ALPS and Elan touchpads, and other driver fixups"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: elantech - add special check for fw_version 0x470f01 touchpad
Input: twl4030-vibra - fix ERROR: Bad of_node_put() warning
Input: alps - only Dell laptops have separate button bits for v2 dualpoint sticks
Input: axp20x-pek - add module alias
Input: turbografx - fix potential out of bound access
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are some USB and PHY fixes for 4.2-rc6 that resolve some reported
issues.
All of these have been in the linux-next tree for a while, full
details on the patches are in the shortlog below"
* tag 'usb-4.2-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
ARM: dts: dra7: Add syscon-pllreset syscon to SATA PHY
drivers/usb: Delete XHCI command timer if necessary
xhci: fix off by one error in TRB DMA address boundary check
usb: udc: core: add device_del() call to error pathway
phy: ti-pipe3: i783 workaround for SATA lockup after dpll unlock/relock
phy-sun4i-usb: Add missing EXPORT_SYMBOL_GPL for sun4i_usb_phy_set_squelch_detect
USB: sierra: add 1199:68AB device ID
usb: gadget: f_printer: actually limit the number of instances
usb: gadget: f_hid: actually limit the number of instances
usb: gadget: f_uac2: fix calculation of uac2->p_interval
usb: gadget: bdc: fix a driver crash on disconnect
usb: chipidea: ehci_init_driver is intended to call one time
USB: qcserial: Add support for Dell Wireless 5809e 4G Modem
USB: qcserial/option: make AT URCs work for Sierra Wireless MC7305/MC7355
The "cpus" node cannot be inside the "soc" node, while this
works for the CoreSight blocks, the early boot code will look
for "cpus" directly under the root node, so this is a hard
convention. So move the CPU nodes.
Augment the "reg" property to match what is actually in the
hardware: 0x300 and 0x301 respectively.
Then add an SMP enablement type to be used by the SMP init
code, "ste,dbx500-smp".
git://git.kernel.org/pub/scm/linux/kernel/git/kishon/linux-phy into usb-linus
Kishon writes:
phy: for 4.2-rc6
*) Fix compiler error when sun4i usb phy driver is built as module
*) Fix SATA Lockup issue in dra7 SoC
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
sticks
It turns out that only Dell laptops have the separate button bits for
v2 dualpoint sticks and that commit 92bac83dd79e ("Input: alps - non
interleaved V2 dualpoint has separate stick button bits") causes
regressions on Toshiba laptops.
This commit adds a check for Dell laptops to the code for handling these
extra button bits, fixing this regression.
This patch has been tested on a Dell Latitude D620 to make sure that it
does not reintroduce the original problem.
Reported-and-tested-by: Douglas Christman <douglaschristman@gmail.com>
git://git.infradead.org/users/vkoul/slave-dma
Pull dmaengine fixes from Vinod Koul:
"We had a regression due to reuse of descriptor so we have reverted
that.
The rest are driver fixes:
- at_hdmac and at_xdmac for residue, trannfer width, and channel config
- pl330 final fix for dma fails and overflow issue
- xgene resouce map fix
- mv_xor big endian op fix"
* tag 'dmaengine-fix-4.2-rc5' of git://git.infradead.org/users/vkoul/slave-dma:
Revert "dmaengine: virt-dma: don't always free descriptor upon completion"
dmaengine: mv_xor: fix big endian operation in register mode
dmaengine: xgene-dma: Fix the resource map to handle overlapping
dmaengine: at_xdmac: fix transfer data width in at_xdmac_prep_slave_sg()
dmaengine: at_hdmac: fix residue computation
dmaengine: at_xdmac: fix bug about channel configuration
dmaengine: pl330: Really fix choppy sound because of wrong residue calculation
dmaengine: pl330: Fix overflow when reporting residue in memcpy
SATA_PLL_SOFT_RESET bit of CTRL_CORE_SMA_SW_0 must be toggled
between a SATA DPLL unlock and re-lock to prevent SATA lockup.
Introduce a new DT parameter 'syscon-pllreset' to provide the syscon
regmap access to this register which sits in the control module.
If the register is not provided we fallback to the old behaviour
i.e. SATA DPLL refclk will not be disabled and we prevent SoC low
power states.
Signed-off-by: Roger Quadros <rogerq@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"This became a relative big update as it includes the collected ASoC
fixes. There are a few fixes in ASoC core side, mostly for DAPM and
the new topology API. The rest are various ASoC driver-specific
fixes, as well as the usual HD-audio and USB-audio quirks"
* tag 'sound-4.2-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (29 commits)
ALSA: hda - Fix MacBook Pro 5,2 quirk
ALSA: hda - Fix race between PM ops and HDA init/probe
ALSA: usb-audio: add dB range mapping for some devices
ALSA: hda - Apply a fixup to Dell Vostro 5480
ALSA: hda - Add pin quirk for the headset mic jack detection on Dell laptop
ALSA: hda - Apply fixup for another Toshiba Satellite S50D
ALSA: fireworks: add support for AudioFire2 quirk
ALSA: hda - Fix the headset mic that will not work on Dell desktop machine
ALSA: hda - fix cs4210_spdif_automute()
ASoC: pcm1681: Fix setting de-emphasis sampling rate selection
ASoC: ssm4567: Keep TDM_BCLKS in ssm4567_set_dai_fmt
ASoC: sgtl5000: Fix up define for SGTL5000_SMALL_POP
ASoC: dapm: Don't add prefix to widget stream name
ASoC: rt5645: Check if codec is initialized in workqueue handler
ASoC: Intel: Get correct usage_count value to load firmware
ASoC: topology: Fix to add dapm mixer info
ASoC: zx: spdif: Fix devm_ioremap_resource return value check
ASoC: zx: i2s: Fix devm_ioremap_resource return value check
ASoC: mediatek: Use platform_of_node for machine drivers
ASoC: Free card DAPM context on snd_soc_instantiate_card() error path
There is an overlap in dma ring cmd csr region due to sharing of ethernet
ring cmd csr region. This patch fix the resource overlapping by mapping
the entire dma ring cmd csr region.
Signed-off-by: Rameshwar Prasad Sahu <rsahu@apm.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon fixes from Guenter Roeck:
"Two patches headed for -stable.
nct7802: Fix integer overflow seen when writing voltage limits
nct7904: Rename pwm attributes to match hwmon ABI"
* tag 'hwmon-for-linus-v4.2-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: (nct7802) Fix integer overflow seen when writing voltage limits
hwmon: (nct7904) Rename pwm attributes to match hwmon ABI
pwm attributes have well defined names, which should be used.
Cc: Vadim V. Vlasov <vvlasov@dev.rtsoft.ru>
Cc: stable@vger.kernel.org #v4.1+
Pull SCSI target fixes from Nicholas Bellinger:
"This series is larger than what I'd normally be conformable with
sending for a -rc5 PULL request..
However, the bulk of the series is localized to qla2xxx target
specific fixes that address a number of real-world correctness issues,
that have been outstanding on the list for ~6 weeks now. They where
submitted + verified + acked by the HW LLD vendor, contributed by a
major production customer of the code, and are marked for v3.18.y
stable code.
That said, I don't see a good reason to wait another month to get
these fixes into mainline.
Beyond the qla2xx specific fixes, this series also includes:
- bugfix for a long standing use-after-free in iscsi-target during
TPG shutdown + demo-mode sessions.
- bugfix for a >= v4.0 regression OOPs in iscsi-target during a
iscsi_start_kthreads() failure.
- bugfix for a >= v4.0 regression hang in iscsi-target for iser
explicit session/connection logout.
- bugfix for a iser-target bug where a early CMA REJECTED status
during login triggers a NULL pointer dereference OOPs.
- bugfixes for a handful of v4.2-rc1 specific regressions related to
the larger set of recent backend configfs attribute changes.
A big thanks to QLogic + Pure Storage for the qla2xxx target bugfixes"
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (28 commits)
Documentation/target: Fix tcm_mod_builder.py build breakage
iser-target: Fix REJECT CM event use-after-free OOPs
iscsi-target: Fix iser explicit logout TX kthread leak
iscsi-target: Fix iscsit_start_kthreads failure OOPs
iscsi-target: Fix use-after-free during TPG session shutdown
qla2xxx: terminate exchange when command is aborted by LIO
qla2xxx: drop cmds/tmrs arrived while session is being deleted
qla2xxx: disable scsi_transport_fc registration in target mode
qla2xxx: added sess generations to detect RSCN update races
qla2xxx: Abort stale cmds on qla_tgt_wq when plogi arrives
qla2xxx: delay plogi/prli ack until existing sessions are deleted
qla2xxx: cleanup cmd in qla workqueue before processing TMR
qla2xxx: kill sessions/log out initiator on RSCN and port down events
qla2xxx: fix command initialization in target mode.
qla2xxx: Remove msleep in qlt_send_term_exchange
qla2xxx: adjust debug flags
qla2xxx: release request queue reservation.
qla2xxx: Add flush after updating ATIOQ consumer index.
qla2xxx: Enable target mode for ISP27XX
qla2xxx: Fix hardware lock/unlock issue causing kernel panic.
Fix the clocks property documentation and use lower case for
hex values in the example.
Signed-off-by: Alban Bedel <albeu@free.fr>
Signed-off-by: Rob Herring <robh@kernel.org>
Fix build breakage and set the protocol identifier based on the parameter.
Fixes: 9ac8928e6a3e ("target: simplify the target template registration API")
Fixes: e4aae5af810e ("target: change core_tpg_register prototype")
Signed-off-by: Sebastian Herbszt <herbszt@gmx.de>
Pull MMC fixes from Ulf Hansson:
"Here are some mmc fixes intended for v4.2 rc4.
Note, most of the changes are for the sdhci-esdhc-imx controller,
which also required us to modify some related DTS files. Those
changes have been acked by the SoC maintainer.
MMC core:
- Fix a reference inbalance issue for power_ro_lock_show() sysfs handler
MMC host:
- omap_hsmmc: Fix IRQ errorhandling for CD, DTO, and CRC
- sdhci: Prevent a kernel panic while using DMA
- mtk-sd: Let it depend on HAS_DMA to prevent build errors
- sdhci-esdhc: Make 8BIT bus work
- sdhci-esdhc-imx: Fix some regressions for DT based platforms
- sdhci-pxav3: Fix a regression for DT based platforms"
* tag 'mmc-4.2-rc3' of git://git.linaro.org/people/ulf.hansson/mmc:
mmc: sdhci-pxav3: fix platform_data is not initialized
dts: mmc: fsl-imx-esdhc: remove fsl,cd-controller support
mmc: sdhci-esdhc-imx: clear f_max in boarddata
mmc: sdhci-esdhc-imx: remove duplicated dts parsing
mmc: sdhci: make max-frequency property in device tree work
mmc: sdhci-esdhc-imx: move all non dt probe code into one function
mmc: sdhci-esdhc-imx: fix cd regression for dt platform
dts: imx7: fix sd card gpio polarity specified in device tree
dts: imx25: fix sd card gpio polarity specified in device tree
dts: imx6: fix sd card gpio polarity specified in device tree
dts: imx53: fix sd card gpio polarity specified in device tree
dts: imx51: fix sd card gpio polarity specified in device tree
mmc: sdhci-esdhc: Make 8BIT bus work
mmc: block: Add missing mmc_blk_put() in power_ro_lock_show()
mmc: MMC_MTK should depend on HAS_DMA
mmc: sdhci check parameters before call dma_free_coherent
mmc: omap_hsmmc: Handle BADA, DEB and CEB interrupts
mmc: omap_hsmmc: Fix DTO and DCRC handling
'asoc/fix/intel-kconfig' and 'asoc/fix/mediatek' into asoc-linus
It's not supported by driver anymore after using runtime pm
and there's no user of it, so delete it now.
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
Reviewed-by: Johan Derycke <johan.derycke@barco.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull iommu fixes from Joerg Roedel:
"The fixes include:
- a couple of fixes for the new ARM-SMMUv3 driver to fix issues found
on the first real implementation of that hardware.
- a patch for the Intel VT-d driver to fix a domain-id leak"
* tag 'iommu-fixes-v4.2-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu:
iommu/vt-d: Fix VM domain ID leak
iommu/arm-smmu: Skip the execution of CMD_PREFETCH_CONFIG
iommu/arm-smmu: Enlarge STRTAB_L1_SZ_SHIFT to support larger sidsize
iommu/arm-smmu: Fix the values of ARM64_TCR_{I,O}RGN0_SHIFT
iommu/arm-smmu: Fix LOG2SIZE setting for 2-level stream tables
iommu/arm-smmu: Fix the index calculation of strtab
Merge fixes from Andrew Morton:
"25 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (25 commits)
lib/decompress: set the compressor name to NULL on error
mm/cma_debug: correct size input to bitmap function
mm/cma_debug: fix debugging alloc/free interface
mm/page_owner: set correct gfp_mask on page_owner
mm/page_owner: fix possible access violation
fsnotify: fix oops in fsnotify_clear_marks_by_group_flags()
/proc/$PID/cmdline: fixup empty ARGV case
dma-debug: skip debug_dma_assert_idle() when disabled
hexdump: fix for non-aligned buffers
checkpatch: fix long line messages about patch context
mm: clean up per architecture MM hook header files
MAINTAINERS: uclinux-h8-devel is moderated for non-subscribers
mailmap: update Sudeep Holla's email id
Update Viresh Kumar's email address
mm, meminit: suppress unused memory variable warning
configfs: fix kernel infoleak through user-controlled format string
include, lib: add __printf attributes to several function prototypes
s390/hugetlb: add hugepages_supported define
mm: hugetlb: allow hugepages_supported to be architecture specific
revert "s390/mm: make hugepages_supported a boot time decision"
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device mapper fixes from Mike Snitzer:
- revert a request-based DM core change that caused IO latency to
increase and adversely impact both throughput and system load
- fix for a use after free bug in DM core's device cleanup
- a couple DM btree removal fixes (used by dm-thinp)
- a DM thinp fix for order-5 allocation failure
- a DM thinp fix to not degrade to read-only metadata mode when in
out-of-data-space mode for longer than the 'no_space_timeout'
- fix a long-standing oversight in both dm-thinp and dm-cache by now
exporting 'needs_check' in status if it was set in metadata
- fix an embarrassing dm-cache busy-loop that caused worker threads to
eat cpu even if no IO was actively being issued to the cache device
* tag 'dm-4.2-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm:
dm cache: avoid calls to prealloc_free_structs() if possible
dm cache: avoid preallocation if no work in writeback_some_dirty_blocks()
dm cache: do not wake_worker() in free_migration()
dm cache: display 'needs_check' in status if it is set
dm thin: display 'needs_check' in status if it is set
dm thin: stay in out-of-data-space mode once no_space_timeout expires
dm: fix use after free crash due to incorrect cleanup sequence
Revert "dm: only run the queue on completion if congested or no requests pending"
dm btree: silence lockdep lock inversion in dm_btree_del()
dm thin: allocate the cell_sort_array dynamically
dm btree remove: fix bug in redistribute3
Switch to my kernel.org alias instead of a badly named gmail address,
which I rarely use.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging and IIO driver fixes from Greg KH:
"Here's some staging and IIO driver fixes for 4.2-rc3.
Nothing major, the majority are IIO issues that were reported, with a
few other minor staging driver fixes. All have been in linux-next for
a while with no reported issues"
* tag 'staging-4.2-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (25 commits)
staging: vt6656: check ieee80211_bss_conf bssid not NULL
staging: vt6655: check ieee80211_bss_conf bssid not NULL
staging:lustre: remove irq.h from socklnd.h
staging: make board support depend on OF_IRQ and CLKDEV_LOOKUP
iio: tmp006: Check channel info on write
iio: sx9500: Add missing init in sx9500_buffer_pre{en,dis}able()
iio:light:ltr501: fix regmap dependency
iio:light:ltr501: fix variable in ltr501_init
iio: sx9500: fix bug in compensation code
iio: sx9500: rework error handling of raw readings
iio: magnetometer: mmc35240: fix available sampling frequencies
iio:light:stk3310: Fix REGMAP_I2C dependency
iio: light: STK3310: un-invert proximity values
iio:adc:cc10001_adc: fix Kconfig dependency
iio: light: tcs3414: Fix bug preventing to set integration time
iio:accel:bmc150-accel: fix counting direction
iio:light:cm3323: clear bitmask before set
iio: adc: at91_adc: allow to use full range of startup time
iio: DAC: ad5624r_spi: fix bit shift of output data value
iio: proximity: sx9500: Fix proximity value
git://git.pengutronix.de/git/pza/linux into drm-fixes
imx-drm: fixes for parallel-display, imx-tve, and ipu-common
These patches fix the parallel-display driver to use the standard OF
graph bindings for connecting a drm_panel via device tree instead of
an undocumented, driver specific device tree property, take care to
disable all IPU interrupts before setting up the irq chip to fix a
kexec lockup, and fix VGA output on i.MX53-QSB boards by correcting
the media bus format set by the imx-tve driver.
* tag 'imx-drm-fixes-2015-07-14' of git://git.pengutronix.de/git/pza/linux:
drm/imx: tve: fix media bus format for VGA output
GPU: ipu: fix lockup caused by pending chained interrupts
drm/imx: parallel-display: fix drm_panel support
git://anongit.freedesktop.org/drm-intel into drm-fixes
Ok next attempt at drm-fixes pull. Big thing really is just the compat32
one for addfb2.1.
* tag 'topic/drm-fixes-2015-07-16' of git://anongit.freedesktop.org/drm-intel:
drm: Provide compat ioctl for addfb2.1
Documentation: drm: Fix tablulation in KMS properties table
drm: add a check for x/y in drm_mode_setcrtc
drm/rockchip: use drm_gem_mmap helpers
There is currently no way to see that the needs_check flag has been set
in the metadata. Display 'needs_check' in the cache status if it is set
in the cache metadata.
Also, update cache documentation.
in the metadata. Display 'needs_check' in the thin-pool status if it is
set in the thinp metadata.
Also, update thinp documentation.
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc
Pull ARC fixes from Vineet Gupta:
- Makefile changes (top-level+ARC) reinstates -O3 builds (regression
since 3.16)
- IDU intc related fixes, IRQ affinity
- patch to make bitops safer for ARC
- perf fix from Alexey to remove signed PC braino
- Futex backend gets llock/scond support
* tag 'arc-v4.2-rc3-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc:
ARCv2: support HS38 releases
ARC: make sure instruction_pointer() returns unsigned value
ARC: slightly refactor macros for boot logging
ARC: Add llock/scond to futex backend
arc:irqchip: prepare for drivers/irqchip/irqchip.h removal
ARC: Make ARC bitops "safer" (add anti-optimization)
ARCv2: [axs103] bump CPU frequency from 75 to 90 MHZ
ARCv2: intc: IDU: Fix potential race in installing a chained IRQ handler
ARCv2: intc: IDU: support irq affinity
ARC: fix unused var wanring
ARC: Don't memzero twice in dma_alloc_coherent for __GFP_ZERO
ARC: Override toplevel default -O2 with -O3
kbuild: Allow arch Makefiles to override {cpp,ld,c}flags
ARCv2: guard SLC DMA ops with spinlock
ARC: Kconfig: better way to disable ARC_HAS_LLSC for ARC_CPU_750D
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus
Jonathan writes:
First set of IIO fixes for the 4.2 cycle.
* Fix a regression in hid sensors suspend time as a result of adding runtime
pm. The normal flow of waking up devices in order to go into suspend
(given the devices are normally suspended when not reading) to a regression
in suspend time on some laptops (reports of an additional 8 seconds).
Fix this by checking to see if a user action resulting in the wake up, and
make it a null operation if it didn't. Note that for hid sensors, there is
nothing useful to be done when moving into a full suspend from a runtime
suspend so they might as well be left alone.
* rochip_saradc: fix some missing MODULE_* data including the licence so that
the driver does not taint the kernel incorrectly and can build as a module.
* twl4030 - mark irq as oneshot as it always should have been.
* inv-mpu - write formats for attributes not specified, leading to miss
interpretation of the gyro scale channel when written.
* Proximity ABI clarification. This had snuck through as a mess. Some
drivers thought proximity went in one direction, some the other. We went
with the most common option, documented it and fixed up the drivers going
the other way. Fix for sx9500 included in this set.
* ad624r - fix a wrong shift in the output data.
* at91_adc - remove a false limit on the value of the STARTUP register
applied by too small a type for the device tree parameter.
* cm3323 - clear the bits when setting the integration time (otherwise
we can only ever set more bits in the relevant field).
* bmc150-accel - multiple triggers are registered, but on error were not being
unwound in the opposite order leading to removal of triggers that had not
yet successfully been registered (count down instead of up when unwinding).
* tcs3414 - ensure right part of val / val2 pair read so that the integration
time is not always 0.
* cc10001_adc - bug in kconfig dependency. Use of OR when AND was intended.
Pull ARM SoC fixes from Kevin Hilman:
"A fairly random colletion of fixes based on -rc1 for OMAP, sunxi and
prima2 as well as a few arm64-specific DT fixes.
This series also includes a late to support a new Allwinner (sunxi)
SoC, but since it's rather simple and isolated to the
platform-specific code, it's included it for this -rc"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
arm64: dts: add device tree for ARM SMM-A53x2 on LogicTile Express 20MG
arm: dts: vexpress: add missing CCI PMU device node to TC2
arm: dts: vexpress: describe all PMUs in TC2 dts
GICv3: Add ITS entry to THUNDER dts
arm64: dts: Add poweroff button device node for APM X-Gene platform
ARM: dts: am4372.dtsi: disable rfbi
ARM: dts: am57xx-beagle-x15: Provide supply for usb2_phy2
ARM: dts: am4372: Add emif node
Revert "ARM: dts: am335x-boneblack: disable RTC-only sleep"
ARM: sunxi: Enable simplefb in the defconfig
ARM: Remove deprecated symbol from defconfig files
ARM: sunxi: Add Machine support for A33
ARM: sunxi: Introduce Allwinner H3 support
Documentation: sunxi: Update Allwinner SoC documentation
ARM: prima2: move to use REGMAP APIs for rtciobrg
ARM: dts: atlas7: add pinctrl and gpio descriptions
ARM: OMAP2+: Remove unnessary return statement from the void function, omap2_show_dma_caps
memory: omap-gpmc: Fix parsing of devices
The parallel-display driver used an undocumented, non-standard property
"fsl,panel" to optionally associate with a drm_panel device. This patch
fixes the driver to use the same OF graph bindings as the LDB driver
instead:
parallel-display {
compatible = "fsl,imx-parallel-display";
port@1 {
reg = <1>;
parallel_out: endpoint {
remote_endpoint = <&panel_in>;
panel {
port {
panel_in: endpoint {
remote-endpoint = <¶llel_out>;
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Tested-by: Gary Bisson <gary.bisson@boundarydevices.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
Merge "omap fixes against v4.2-rc1" from Tony Lindgren:
Minor fixes for omaps against v4.2-rc1. Mostly just minor dts changes
except for a GPMC fix to not use names for probing devices. Also a
one liner clean-up to remove unecessary return from a void function.
The summary for the changes being:
- Fix probe for GPMC devices by reoving limitations based on device
name
- Remove unnecessary return from a void function
- Revert beaglebone RTC sleep fix, we now have a better fix merged
- Add am4372 EMIF node to fix a warning
- Add am57xx-beagle-x15 power supply to fix USB2 if USB1 is disabled
- Disable rfbi for am4372 as it does not have a driver
* tag 'omap-for-v4.2/fixes-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux into fixes
Merge "Allwinner late changes for 4.2" from Maxime Ripard:
A bunch of defconfig changes, and some patches to make the Allwinner H3 and
A33 boot properly.
* tag 'sunxi-late-for-4.2' of https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux:
This replaces the platform_name in snd_soc_dai_link by device tree node.
Signed-off-by: Koro Chen <koro.chen@mediatek.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Hisilicon SMMUv3 devices treat CMD_PREFETCH_CONFIG as a illegal command,
execute it will trigger GERROR interrupt. Although the gerror code manage
to turn the prefetch into a SYNC, and the system can continue to run
normally, but it's ugly to print error information.
Signed-off-by: Zhen Lei <thunder.leizhen@huawei.com>
[will: extended binding documentation]
Commit 712a0dd91c4a ("Documentation/drm: Update rotation property")
left an extra 'rowspan' for the row omap, which pushed the following qxl
rows columns out to column 8 and broke the tabulation.
Remove the errant rowspan.
Signed-off-by: Graham Whaley <graham.whaley@linux.intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
it was not the whole truth that kernel mode cannot be used with swap on LVM
Signed-off-by: Uwe Geuder <linuxkernel2015-ugeuder@snkmail.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
Add node for TI AM4372 EMIF. Without this we get a warning with the
recent commit fabbe6df (ARM: OMAP: AM43xx hwmod: Add data for am43xx
emif hwmod).
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
Tested-by: Felipe Balbi <balbi@ti.com>
Acked-by: Felipe Balbi <balbi@ti.com>
[tony@atomide.com: updated comments]
Since commit a1c48bb1 (Makefile: Fix unrecognized cross-compiler command
line options), the arch Makefile is included earlier by the main
Makefile, preventing the arc architecture to set its -O3 compiler
option. Since there might be more use cases for an arch Makefile to
fine-tune the options, add support for ARCH_CPPFLAGS, ARCH_AFLAGS and
ARCH_CFLAGS variables that are appended to the respective kbuild
variables. The user still has the final say via the KCPPFLAGS, KAFLAGS
and KCFLAGS variables.
Reported-by: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Cc: stable@vger.kernel.org # 3.16+
Signed-off-by: Michal Marek <mmarek@suse.com>
Add machine support for the Allwinner A33 quad core cortex-a7 based SoC,
which is similar to the A23 SoC.
Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Tested-by: Chen-Yu Tsai <wens@csie.org>
The Allwinner H3 is a quad-core Cortex-A7-based SoC. It is very similar
to other sun8i family SoCs like the A23.
Signed-off-by: Jens Kuske <jenskuske@gmail.com>
There are some new Allwinner SoCs available, namely A33, A83T and H3.
Update the documentation to mention those and the related documents.
Pull more vfs updates from Al Viro:
"Assorted VFS fixes and related cleanups (IMO the most interesting in
that part are f_path-related things and Eric's descriptor-related
stuff). UFS regression fixes (it got broken last cycle). 9P fixes.
fs-cache series, DAX patches, Jan's file_remove_suid() work"
[ I'd say this is much more than "fixes and related cleanups". The
file_table locking rule change by Eric Dumazet is a rather big and
fundamental update even if the patch isn't huge. - Linus ]
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits)
9p: cope with bogus responses from server in p9_client_{read,write}
p9_client_write(): avoid double p9_free_req()
9p: forgetting to cancel request on interrupted zero-copy RPC
dax: bdev_direct_access() may sleep
block: Add support for DAX reads/writes to block devices
dax: Use copy_from_iter_nocache
dax: Add block size note to documentation
fs/file.c: __fget() and dup2() atomicity rules
fs/file.c: don't acquire files->file_lock in fd_install()
fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation
vfs: avoid creation of inode number 0 in get_next_ino
namei: make set_root_rcu() return void
make simple_positive() public
ufs: use dir_pages instead of ufs_dir_pages()
pagemap.h: move dir_pages() over there
remove the pointless include of lglock.h
fs: cleanup slight list_entry abuse
xfs: Correctly lock inode when removing suid and file capabilities
fs: Call security_ops->inode_killpriv on truncate
fs: Provide function telling whether file_remove_privs() will do anything
Pull SCSI target updates from Nicholas Bellinger:
"It's been a busy development cycle for target-core in a number of
different areas.
The fabric API usage for se_node_acl allocation is now within
target-core code, dropping the external API callers for all fabric
drivers tree-wide.
There is a new conversion to RCU hlists for se_node_acl and
se_portal_group LUN mappings, that turns fast-past LUN lookup into a
completely lockless code-path. It also removes the original
hard-coded limitation of 256 LUNs per fabric endpoint.
The configfs attributes for backends can now be shared between core
and driver code, allowing existing drivers to use common code while
still allowing flexibility for new backend provided attributes.
The highlights include:
- Merge sbc_verify_dif_* into common code (sagi)
- Remove iscsi-target support for obsolete IFMarker/OFMarker
(Christophe Vu-Brugier)
- Add bidi support in target/user backend (ilias + vangelis + agover)
- Move se_node_acl allocation into target-core code (hch)
- Add crc_t10dif_update common helper (akinobu + mkp)
- Handle target-core odd SGL mapping for data transfer memory
(akinobu)
- Move transport ID handling into target-core (hch)
- Move task tag into struct se_cmd + support 64-bit tags (bart)
- Convert se_node_acl->device_list[] to RCU hlist (nab + hch +
paulmck)
- Convert se_portal_group->tpg_lun_list[] to RCU hlist (nab + hch +
paulmck)
- Simplify target backend driver registration (hch)
- Consolidate + simplify target backend attribute implementations
(hch + nab)
- Subsume se_port + t10_alua_tg_pt_gp_member into se_lun (hch)
- Drop lun_sep_lock for se_lun->lun_se_dev RCU usage (hch + nab)
- Drop unnecessary core_tpg_register TFO parameter (nab)
- Use 64-bit LUNs tree-wide (hannes)
- Drop left-over TARGET_MAX_LUNS_PER_TRANSPORT limit (hannes)"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (76 commits)
target: Bump core version to v5.0
target: remove target_core_configfs.h
target: remove unused TARGET_CORE_CONFIG_ROOT define
target: consolidate version defines
target: implement WRITE_SAME with UNMAP bit using ->execute_unmap
target: simplify UNMAP handling
target: replace se_cmd->execute_rw with a protocol_data field
target/user: Fix inconsistent kmap_atomic/kunmap_atomic
target: Send UA when changing LUN inventory
target: Send UA upon LUN RESET tmr completion
target: Send UA on ALUA target port group change
target: Convert se_lun->lun_deve_lock to normal spinlock
target: use 'se_dev_entry' when allocating UAs
target: Remove 'ua_nacl' pointer from se_ua structure
target_core_alua: Correct UA handling when switching states
xen-scsiback: Fix compile warning for 64-bit LUN
target: Remove TARGET_MAX_LUNS_PER_TRANSPORT
target: use 64-bit LUNs
target: Drop duplicate + unused se_dev_check_wce
target: Drop unnecessary core_tpg_register TFO parameter
