path: root/Documentation
2013-05-30x86,efi: Implement efi_no_storage_paranoia parameterRichard Weinberger
commit 8c58bf3eec3b8fc8162fe557e9361891c20758f2 upstream. Using this parameter one can disable the storage_size/2 check if he is really sure that the UEFI does sane gc and fulfills the spec. This parameter is useful if a devices uses more than 50% of the storage by default. The Intel DQSW67 desktop board is such a sucker for exmaple. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Matt Fleming <matt.fleming@intel.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-25drm/i915: panel: invert brightness via quirkCarsten Emde
commit 4dca20efb1a9c2efefc28ad2867e5d6c3f5e1955 upstream. A machine may need to invert the panel backlight brightness value. This patch adds the infrastructure for a quirk to do so. Signed-off-by: Carsten Emde <C.Emde@osadl.org> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-25drm/i915: panel: invert brightness via parameterCarsten Emde
commit 7bd90909bbf9ce7c40e1da3d72b97b93839c188a upstream. Following the documentation of the Legacy Backlight Brightness (LBB) Register in the configuration space of some Intel PCI graphics adapters, setting the LBB register with the value 0x0 causes the backlight to be turned off, and 0xFF causes the backlight to be set to 100% intensity (http://download.intel.com/embedded/processors/Whitepaper/324567.pdf). The Acer Aspire 5734Z, however, turns the backlight off at 0xFF and sets it to maximum intensity at 0. In consequence, the screen of this systems becomes dark at an early boot stage which makes it unusable. The same inversion applies to the BLC_PWM_CTL I915 register. This problem was introduced in kernel version 2.6.38 when the PCI device of this system was first supported by the i915 KMS module. This patch adds a parameter to the i915 module to enable inversion of the brightness variable (i915.invert_brightness). Signed-off-by: Carsten Emde <C.Emde@osadl.org> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-20tty/serial: Add support for Altera serial portLey Foon Tan
commit e06c93cacb82dd147266fd1bdb2d0a0bd45ff2c1 upstream. Add support for Altera 8250/16550 compatible serial port. Signed-off-by: Ley Foon Tan <lftan@altera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> [bwh: Backported to 3.2: adjust filenames, context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06doc, kernel-parameters: Document 'console=hvc<n>'Konrad Rzeszutek Wilk
commit a2fd6419174470f5ae6383f5037d0ee21ed9833f upstream. Both the PowerPC hypervisor and Xen hypervisor can utilize the hvc driver. Cc: Greg KH <gregkh@linuxfoundation.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Link: http://lkml.kernel.org/r/1361825650-14031-3-git-send-email-konrad.wilk@oracle.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06doc, xen: Mention 'earlyprintk=xen' in the documentation.Konrad Rzeszutek Wilk
commit 2482a92e7d17187301d7313cfe5021b13393a0b4 upstream. The earlyprintk for Xen PV guests utilizes a simple hypercall (console_io) to provide output to Xen emergency console. Note that the Xen hypervisor should be booted with 'loglevel=all' to output said information. Reported-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Link: http://lkml.kernel.org/r/1361825650-14031-2-git-send-email-konrad.wilk@oracle.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-16tcp: implement RFC 5961 3.2Eric Dumazet
[ Upstream commit 282f23c6ee343126156dd41218b22ece96d747e3 ] Implement the RFC 5691 mitigation against Blind Reset attack using RST bit. Idea is to validate incoming RST sequence, to match RCV.NXT value, instead of previouly accepted window : (RCV.NXT <= SEG.SEQ < RCV.NXT+RCV.WND) If sequence is in window but not an exact match, send a "challenge ACK", so that the other part can resend an RST with the appropriate sequence. Add a new sysctl, tcp_challenge_ack_limit, to limit number of challenge ACK sent per second. Add a new SNMP counter to count number of challenge acks sent. (netstat -s | grep TCPChallengeACK) Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Kiran Kumar Kella <kkiran@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03hwmon: (coretemp) Add support for Atom CE4110/4150/4170Guenter Roeck
commit 1102dcab849313bd5a340b299b5cf61b518fbc0f upstream. TjMax for the CE4100 series of Atom CPUs was previously reported to be 110 degrees C. cpuinfo logs on the web show existing CPU types CE4110, CE4150, and CE4170, reported as "model name : Intel(R) Atom(TM) CPU CE41{1|5|7}0 @ 1.{2|6}0GHz" with model 28 (0x1c) and stepping 10 (0x0a). Add the three known variants to the tjmax table. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03hwmon: (coretemp) Add support for Atom D2000 and N2000 series CPU modelsGuenter Roeck
commit 5592906f8b01282ea3c2acaf641fd067ad4bb3dc upstream. Document the Atom series D2000 and N2000 (Cedar Trail) as being supported. List and set TjMax for those series. Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: "R, Durgadoss" <durgadoss.r@intel.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03hwmon: (coretemp) Improve support of recent Atom CPU modelsJean Delvare
commit fcc14ac1a86931f38da047cf8fb634c6db7b58bc upstream. Document the new Atom series (Tunnel Creek and Medfield) as being supported, and list TjMax for the Atom E600 series. Also enable the Atom tjmax heuristic for these Atom CPU models. Signed-off-by: Jean Delvare <khali@linux-fr.org> Reviewed-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Alexander Stein <alexander.stein@systec-electronic.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: "R, Durgadoss" <durgadoss.r@intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-12-06get_dvb_firmware: fix download site for tda10046 firmwareMauro Carvalho Chehab
commit 25ec43d3e6306978cf66060ed18c4160ce8fc302 upstream. The previous website doesn't exist anymore. Update it to one site that actually exists. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-12-06memcg: oom: fix totalpages calculation for memory.swappiness==0Michal Hocko
commit 9a5a8f19b43430752067ecaee62fc59e11e88fa6 upstream. oom_badness() takes a totalpages argument which says how many pages are available and it uses it as a base for the score calculation. The value is calculated by mem_cgroup_get_limit which considers both limit and total_swap_pages (resp. memsw portion of it). This is usually correct but since fe35004fbf9e ("mm: avoid swapping out with swappiness==0") we do not swap when swappiness is 0 which means that we cannot really use up all the totalpages pages. This in turn confuses oom score calculation if the memcg limit is much smaller than the available swap because the used memory (capped by the limit) is negligible comparing to totalpages so the resulting score is too small if adj!=0 (typically task with CAP_SYS_ADMIN or non zero oom_score_adj). A wrong process might be selected as result. The problem can be worked around by checking mem_cgroup_swappiness==0 and not considering swap at all in such a case. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-11-16x86: Remove the ancient and deprecated disable_hlt() and enable_hlt() facilityLen Brown
commit f6365201d8a21fb347260f89d6e9b3e718d63c70 upstream. The X86_32-only disable_hlt/enable_hlt mechanism was used by the 32-bit floppy driver. Its effect was to replace the use of the HLT instruction inside default_idle() with cpu_relax() - essentially it turned off the use of HLT. This workaround was commented in the code as: "disable hlt during certain critical i/o operations" "This halt magic was a workaround for ancient floppy DMA wreckage. It should be safe to remove." H. Peter Anvin additionally adds: "To the best of my knowledge, no-hlt only existed because of flaky power distributions on 386/486 systems which were sold to run DOS. Since DOS did no power management of any kind, including HLT, the power draw was fairly uniform; when exposed to the much hhigher noise levels you got when Linux used HLT caused some of these systems to fail. They were by far in the minority even back then." Alan Cox further says: "Also for the Cyrix 5510 which tended to go castors up if a HLT occurred during a DMA cycle and on a few other boxes HLT during DMA tended to go astray. Do we care ? I doubt it. The 5510 was pretty obscure, the 5520 fixed it, the 5530 is probably the oldest still in any kind of use." So, let's finally drop this. Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Stephen Hemminger <shemminger@vyatta.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/n/tip-3rhk9bzf0x9rljkv488tloib@git.kernel.org [ If anyone cares then alternative instruction patching could be used to replace HLT with a one-byte NOP instruction. Much simpler. ] Signed-off-by: Ingo Molnar <mingo@kernel.org> [bwh: Backported to 3.2: adjust filename, context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-10-17lguest: fix occasional crash in example launcher.Rusty Russell
commit ca16f580a5db7e60bfafe59a50bb133bd3347491 upstream. We usually got away with ->next on the final entry being NULL, but it finally bit me. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> [bwh: Backported to 3.2: adjust filename] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-09-19i2c-i801: Add Device IDs for Intel Lynx Point-LP PCHJames Ralston
commit 4a8f1ddde942e232387e6129ce4f4c412e43802f upstream. Add the SMBus Device IDs for the Intel Lynx Point-LP PCH. Signed-off-by: James Ralston <james.d.ralston@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-09-19i2c-i801: Add device IDs for Intel Lynx PointSeth Heasley
commit 062737fb6d90c632439b1f77ad6a4965cfc84a20 upstream. Add the SMBus controller device IDs for the Intel Lynx Point PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-09-19ARM: dts: imx51-babbage: fix esdhc cd/wp propertiesShawn Guo
commit a46d2619d7180bda12bad2bf15bbd0731dfc2dcf upstream. The binding doc and dts use properties "fsl,{cd,wp}-internal" while esdhc driver uses "fsl,{cd,wp}-controller". Fix binding doc and dts to get them match driver code. Reported-by: Chris Ball <cjb@laptop.org> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Chris Ball <cjb@laptop.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-08-10ALSA: hda - add dock support for Thinkpad X230 TabletDavid Henningsson
commit 108cc108a3bb42fe4705df1317ff98e1e29428a6 upstream. Also add a model/fixup string "lenovo-dock", so that other Thinkpad users will be able to test this fixup easily, to see if it enables dock I/O for them as well. BugLink: https://bugs.launchpad.net/bugs/1026953 Tested-by: John McCarron <john.mccarron@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-08-10stable: update references to older 2.6 versions for 3.xPaul Gortmaker
commit 2584f5212d97b664be250ad5700a2d0fee31a10d upstream. Also add information on where the respective trees are. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Rob Landley <rob@landley.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-07-04stable: Allow merging of backports for serious user-visible performance issuesMel Gorman
commit eb3979f64d25120d60b9e761a4c58f70b1a02f86 upstream. Distribution kernel maintainers routinely backport fixes for users that were deemed important but not "something critical" as defined by the rules. To users of these kernels they are very serious and failing to fix them reduces the value of -stable. The problem is that the patches fixing these issues are often subtle and prone to regressions in other ways and need greater care and attention. To combat this, these "serious" backports should have a higher barrier to entry. This patch relaxes the rules to allow a distribution maintainer to merge to -stable a backported patch or small series that fixes a "serious" user-visible performance issue. They should include additional information on the user-visible bug affected and a link to the bugzilla entry if available. The same rules about the patch being already in mainline still apply. Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-31docs: update HOWTO for 2.6.x -> 3.x versioningKees Cook
commit 591bfc6bf9e5e25e464fd4c87d64afd5135667c4 upstream. The HOWTO document needed updating for the new kernel versioning. The git URI for -next was updated as well. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-20tcp: change tcp_adv_win_scale and tcp_rmem[2]Eric Dumazet
[ Upstream commit b49960a05e32121d29316cfdf653894b88ac9190 ] tcp_adv_win_scale default value is 2, meaning we expect a good citizen skb to have skb->len / skb->truesize ratio of 75% (3/4) In 2.6 kernels we (mis)accounted for typical MSS=1460 frame : 1536 + 64 + 256 = 1856 'estimated truesize', and 1856 * 3/4 = 1392. So these skbs were considered as not bloated. With recent truesize fixes, a typical MSS=1460 frame truesize is now the more precise : 2048 + 256 = 2304. But 2304 * 3/4 = 1728. So these skb are not good citizen anymore, because 1460 < 1728 (GRO can escape this problem because it build skbs with a too low truesize.) This also means tcp advertises a too optimistic window for a given allocated rcvspace : When receiving frames, sk_rmem_alloc can hit sk_rcvbuf limit and we call tcp_prune_queue()/tcp_collapse() too often, especially when application is slow to drain its receive queue or in case of losses (netperf is fast, scp is slow). This is a major latency source. We should adjust the len/truesize ratio to 50% instead of 75% This patch : 1) changes tcp_adv_win_scale default to 1 instead of 2 2) increase tcp_rmem[2] limit from 4MB to 6MB to take into account better truesize tracking and to allow autotuning tcp receive window to reach same value than before. Note that same amount of kernel memory is consumed compared to 2.6 kernels. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Yuchung Cheng <ycheng@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-03-19hwmon: (zl6100) Enable interval between chip accesses for all chipsGuenter Roeck
commit fecfb64422d91a9621a3f96ab75c3a5f13e80b58 upstream. Intersil reports that all chips supported by the zl6100 driver require an interval between chip accesses, even ZL2004 and ZL6105 which were thought to be safe. Reported-by: Vivek Gani <vgani@intersil.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19hwmon: (w83627ehf) Fix temp2 source for W83627UHGJean Delvare
commit aacb6b0052692c72fe0cb94c6b547202def6ef46 upstream. Properly set the source of temp2 for the W83627UHG. Also fix a comment right before that, and document the W83627UHG as reporting up to 3 temperatures. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12hwmon: (jc42) Add support for AT30TS00, TS3000GB2, TSE2002GB2, and MCP9804Guenter Roeck
commit 1bd612a25855f4cc9345052b53d7da697dba6358 upstream. Also update IDT datasheet locations. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12hwmon: (jc42) Add support for ST Microelectronics STTS2002 and STTS3000Jean Delvare
commit 4de86126a712ba83fa038d277c8282f7ed466a4b upstream. These are fully compatible with Jedec JC 42.4 as far as I can see. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-12USB: update documentation for usbmonAlan Stern
commit d8cae98cddd286e38db1724dda1b0e7b467f9237 upstream. The documentation for usbmon is out of date; the usbfs "devices" file now exists in /sys/kernel/debug/usb rather than /proc/bus/usb. This patch (as1505) updates the documentation accordingly, and also mentions that the necessary information can be found by running lsusb. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12Documentation: Update stable addressJoe Perches
commit 2eb7f204db51969ea558802a6601d79c2fb273b9 upstream. The Japanese/Korean/Chinese versions still need updating. Also, the stable kernel 2.6.x.y descriptions are out of date and should be updated as well. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-26KVM: Don't automatically expose the TSC deadline timer in cpuidJan Kiszka
Unlike all of the other cpuid bits, the TSC deadline timer bit is set unconditionally, regardless of what userspace wants. This is broken in several ways: - if userspace doesn't use KVM_CREATE_IRQCHIP, and doesn't emulate the TSC deadline timer feature, a guest that uses the feature will break - live migration to older host kernels that don't support the TSC deadline timer will cause the feature to be pulled from under the guest's feet; breaking it - guests that are broken wrt the feature will fail. Fix by not enabling the feature automatically; instead report it to userspace. Because the feature depends on KVM_CREATE_IRQCHIP, which we cannot guarantee will be called, we expose it via a KVM_CAP_TSC_DEADLINE_TIMER and not KVM_GET_SUPPORTED_CPUID. Fixes the Illumos guest kernel, which uses the TSC deadline timer feature. [avi: add the KVM_CAP + documentation] Reported-by: Alexey Zaytsev <alexey.zaytsev@gmail.com> Tested-by: Alexey Zaytsev <alexey.zaytsev@gmail.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-25KVM: Device assignment permission checksAlex Williamson
Only allow KVM device assignment to attach to devices which: - Are not bridges - Have BAR resources (assume others are special devices) - The user has permissions to use Assigning a bridge is a configuration error, it's not supported, and typically doesn't result in the behavior the user is expecting anyway. Devices without BAR resources are typically chipset components that also don't have host drivers. We don't want users to hold such devices captive or cause system problems by fencing them off into an iommu domain. We determine "permission to use" by testing whether the user has access to the PCI sysfs resource files. By default a normal user will not have access to these files, so it provides a good indication that an administration agent has granted the user access to the device. [Yang Bai: add missing #include] [avi: fix comment style] Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Yang Bai <hamo.by@gmail.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-25KVM: Remove ability to assign a device without iommu supportAlex Williamson
This option has no users and it exposes a security hole that we can allow devices to be assigned without iommu protection. Make KVM_DEV_ASSIGN_ENABLE_IOMMU a mandatory option. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: add missing spin_unlock at ceph_mdsc_build_path() ceph: fix SEEK_CUR, SEEK_SET regression crush: fix mapping calculation when force argument doesn't exist ceph: use i_ceph_lock instead of i_lock rbd: remove buggy rollback functionality rbd: return an error when an invalid header is read ceph: fix rasize reporting by ceph_show_options
2011-12-09Merge branch 'iommu/fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu * 'iommu/fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: MAINTAINERS: Update amd-iommu F: patterns iommu/amd: Fix typo in kernel-parameters.txt iommu/msm: Fix compile error in mach-msm/devices-iommu.c Fix comparison using wrong pointer variable in dma debug code
2011-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda/realtek - Fix lost speaker volume controls ALSA: hda/realtek - Create "Bass Speaker" for two speaker pins ALSA: hda/realtek - Don't create extra controls with channel suffix ALSA: hda - Fix remaining VREF mute-LED NID check in post-3.1 changes ALSA: hda - Fix GPIO LED setup for IDT 92HD75 codecs ASoC: Provide a more complete DMA driver stub ASoC: Remove references to corgi and spitz from machine driver document ASoC: Make SND_SOC_MX27VIS_AIC32X4 depend on I2C ASoC: Fix dependency for SND_SOC_RAUMFELD and SND_PXA2XX_SOC_HX4700 ASoC: uda1380: Return proper error in uda1380_modinit failure path ASoC: kirkwood: Make SND_KIRKWOOD_SOC_OPENRD and SND_KIRKWOOD_SOC_T5325 depend on I2C ASoC: Mark WM8994 ADC muxes as virtual ALSA: hda/realtek - Fix Oops in alc_mux_select() ALSA: sis7019 - give slow codecs more time to reset
2011-12-07rbd: remove buggy rollback functionalityJosh Durgin
This doesn't interact with resizing well, since it doesn't set the size of the device to the size at the snapshot. It's also an expensive operation to be synchronous. Rollback can still be done with the userspace rbd tool. Signed-off-by: Josh Durgin <josh.durgin@dreamhost.com>
2011-12-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: net: Silence seq_scale() unused warning ipv4:correct description for tcp_max_syn_backlog pasemi_mac: Fix building as module netback: Fix alert message. r8169: fix Rx index race between FIFO overflow recovery and NAPI handler. r8169: Rx FIFO overflow fixes. ipv4: Fix peer validation on cached lookup. ipv4: make sure RTO_ONLINK is saved in routing cache iwlwifi: change the default behavior of watchdog timer iwlwifi: do not re-configure HT40 after associated iwlagn: fix HW crypto for TX-only keys Revert "mac80211: clear sta.drv_priv on reconfiguration" mac80211: fill rate filter for internal scan requests cfg80211: amend regulatory NULL dereference fix cfg80211: fix race on init and driver registration
2011-12-06ipv4:correct description for tcp_max_syn_backlogPeter Pan(潘卫平)
Since commit c5ed63d66f24(tcp: fix three tcp sysctls tuning), sysctl_max_syn_backlog is determined by tcp_hashinfo->ehash_mask, and the minimal value is 128, and it will increase in proportion to the memory of machine. The original description for tcp_max_syn_backlog and sysctl_max_syn_backlog are out of date. Changelog: V2: update description for sysctl_max_syn_backlog Signed-off-by: Weiping Pan <panweiping3@gmail.com> Reviewed-by: Shan Wei <shanwei88@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-06iommu/amd: Fix typo in kernel-parameters.txtSedat Dilek
Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2011-12-06Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-12-05ASoC: Remove references to corgi and spitz from machine driver documentMark Brown
They're not currently actively worked on, the hardware being rather obsolete by now. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-05x86, AMD: Correct align_va_addr documentationBorislav Petkov
Commit dfb09f9b7ab0 ("x86, amd: Avoid cache aliasing penalties on AMD family 15h") introduced a kernel command line parameter called 'align_va_addr' which still refers to arguments used in an earlier version of the patch and which got changed without updating the documentation. Correct that omission. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Frank Arnold <frank.arnold@amd.com> Link: http://lkml.kernel.org/r/1321873819-29541-1-git-send-email-bp@amd64.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-02Merge branch 'usb-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb * 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (21 commits) usb: ftdi_sio: add PID for Propox ISPcable III Revert "xHCI: reset-on-resume quirk for NEC uPD720200" xHCI: fix bug in xhci_clear_command_ring() usb: gadget: fsl_udc: fix dequeuing a request in progress usb: fsl_mxc_udc.c: Remove compile-time dependency of MX35 SoC type usb: fsl_mxc_udc.c: Fix build issue by including missing header file USB: fsl_udc_core: use usb_endpoint_xfer_isoc to judge ISO XFER usb: udc: Fix gadget driver's speed check in various UDC drivers usb: gadget: fix g_serial regression usb: renesas_usbhs: fixup driver speed usb: renesas_usbhs: fixup gadget.dev.driver when udc_stop. usb: renesas_usbhs: fixup signal the driver that cable was disconnected usb: renesas_usbhs: fixup device_register timing usb: musb: PM: fix context save/restore in suspend/resume path USB: linux-cdc-acm.inf: add support for the acm_ms gadget EHCI : Fix a regression in the ISO scheduler xHCI: reset-on-resume quirk for NEC uPD720200 USB: whci-hcd: fix endian conversion in qset_clear() USB: usb-storage: unusual_devs entry for Kingston DT 101 G2 usb: option: add SIMCom SIM5218 ...
2011-12-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: fix meta data raid-repair merge problem Btrfs: skip allocation attempt from empty cluster Btrfs: skip block groups without enough space for a cluster Btrfs: start search for new cluster at the beginning Btrfs: reset cluster's max_size when creating bitmap Btrfs: initialize new bitmaps' list Btrfs: fix oops when calling statfs on readonly device Btrfs: Don't error on resizing FS to same size Btrfs: fix deadlock on metadata reservation when evicting a inode Fix URL of btrfs-progs git repository in docs btrfs scrub: handle -ENOMEM from init_ipath()
2011-11-30Merge branch 'dt-for-linus' of git://sources.calxeda.com/kernel/linuxLinus Torvalds
* 'dt-for-linus' of git://sources.calxeda.com/kernel/linux: of: Add Silicon Image vendor prefix of/irq: of_irq_init: add check for parent equal to child node
2011-11-30Fix URL of btrfs-progs git repository in docsArnd Hannemann
The location of the btrfs-progs repository has been changed. This patch updates the documentation accordingly. Signed-off-by: Arnd Hannemann <arnd@arndnet.de>
2011-11-29of: Add Silicon Image vendor prefixPawel Moll
"sil" is the most commonly used abbreviation for Silicon Image products. Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2011-11-29USB: linux-cdc-acm.inf: add support for the acm_ms gadgetKlaus Schwarzkopf
Support for the acm_ms usb gadget on windows. Signed-off-by: Klaus Schwarzkopf <schwarzkopf@sensortherm.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-28PM / Sleep: Update documentation related to system wakeupRafael J. Wysocki
The system wakeup section of Documentation/power/devices.txt is outdated, so make it agree with the current code. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-11-28PM / Runtime: Make documentation follow the new behavior of irq_safeRafael J. Wysocki
The runtime PM core code behavior related to the power.irq_safe device flag has changed recently and the documentation should be modified to reflect it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-11-28PM / Sleep: Correct inaccurate information in devices.txtRafael J. Wysocki
The documentation file Documentation/power/devices.txt contains some information that isn't correct any more due to code modifications made after that file had been created (or updated last time). Fix this. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
