* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
[POWERPC] Bolt in SLB entry for kernel stack on secondary cpus
[POWERPC] PS3: Update ps3_defconfig
[POWERPC] PS3: Remove unsupported wakeup sources
[POWERPC] PS3: Make ps3_virq_setup and ps3_virq_destroy static
[POWERPC] PS3: Add time include to lpm
[POWERPC] Fix slb.c compile warnings
[POWERPC] Xilinx: Fix compile warnings
[POWERPC] Squash build warning for print of resource_size_t in fsl_soc.c
[RAPIDIO] fix current kernel-doc notation
[POWERPC] 86xx: mpc8610_hpcd: add support for PCI Express x8 slot
Fix a potential issue in mpc52xx uart driver
[POWERPC] mpc5200: Allow for fixed speed MII configurations
[POWERPC] 86xx: Fix the wrong serial1 interrupt for 8610 board
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6:
[SCSI] aic94xx: fix section mismatch
[SCSI] u14-34f: Fix 32bit only problem
[SCSI] dpt_i2o: sysfs code
[SCSI] dpt_i2o: 64 bit support
[SCSI] dpt_i2o: move from virt_to_bus/bus_to_virt to dma_alloc_coherent
[SCSI] dpt_i2o: use standard __init / __exit code
[SCSI] megaraid_sas: fix suspend/resume sections
[SCSI] aacraid: Add Power Management support
[SCSI] aacraid: Fix jbod operations scan issues
[SCSI] aacraid: Fix warning about macro side-effects
[SCSI] add support for variable length extended commands
[SCSI] Let scsi_cmnd->cmnd use request->cmd buffer
[SCSI] bsg: add large command support
[SCSI] aacraid: Fix down_interruptible() to check the return value correctly
[SCSI] megaraid_sas; Update the Version and Changelog
[SCSI] ibmvscsi: Handle non SCSI error status
[SCSI] bug fix for free list handling
[SCSI] ipr: Rename ipr's state scsi host attribute to prevent collisions
[SCSI] megaraid_mbox: fix Dell CERC firmware problem
This brings us closer to Real Life, where we'd examine the device
features once it's set the DRIVER_OK status bit.
Ron Minnich points out that a struct containing a char is not always
sizeof(char); simplest to remove the structure to avoid confusion.
Cc: "ron minnich" <rminnich@gmail.com>
Add functionality to slabinfo to print out the number of fallbacks
that have occurred for each slab cache when the -D option is specified.
Also widen the allocation / free field since the numbers became
too big after a week.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
Various improvements for configuring the MPC5200 MII link from the
device tree:
* Look for 'current-speed' property for fixed speed MII links
* Look for 'fsl,7-wire-mode' property for boards using the 7 wire mode
* move definition of private data structure out of the header file
Acked-by: Wolfgang Grandegger <wg@grandegger.com>
* 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6:
hwmon: (adt7473) minor cleanup / refactoring
hwmon: (asb100) Remove some dead code
hwmon: (lm75) Fix an incorrect comment
hwmon: (w83793) VID and VRM handling cleanups
hwmon: (w83l785ts) Don't ask the user to report failures
hwmon: (smsc47b397) add a new chip id (0x8c)
The extended crashkernel syntax is a little confusing in the way it handles
ranges. eg:
crashkernel=512M-2G:64M,2G-:128M
Means if the machine has between 512M and 2G of memory the crash region should
be 64M, and if the machine has 2G of memory the region should be 64M. Only if
the machine has more than 2G memory will 128M be allocated.
Although that semantic is correct, it is somewhat baffling. Instead I propose
that the end of the range means the first address past the end of the range,
ie: 512M up to but not including 2G.
[bwalle@suse.de: clarify inclusive/exclusive in crashkernel commandline in documentation]
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Acked-by: Bernhard Walle <bwalle@suse.de>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Simon Horman <horms@verge.net.au>
Signed-off-by: Bernhard Walle <bwalle@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (179 commits)
ACPI: Fix acpi_processor_idle and idle= boot parameters interaction
acpi: fix section mismatch warning in pnpacpi
intel_menlo: fix build warning
ACPI: Cleanup: Remove unneeded, multiple local dummy variables
ACPI: video - fix permissions on some proc entries
ACPI: video - properly handle errors when registering proc elements
ACPI: video - do not store invalid entries in attached_array list
ACPI: re-name acpi_pm_ops to acpi_suspend_ops
ACER_WMI/ASUS_LAPTOP: fix build bug
thinkpad_acpi: fix possible NULL pointer dereference if kstrdup failed
ACPI: check a return value correctly in acpi_power_get_context()
#if 0 acpi/bay.c:eject_removable_drive()
eeepc-laptop: add hwmon fan control
eeepc-laptop: add backlight
eeepc-laptop: add base driver
ACPI: thinkpad-acpi: bump up version to 0.20
ACPI: thinkpad-acpi: fix selects in Kconfig
ACPI: thinkpad-acpi: use a private workqueue
ACPI: thinkpad-acpi: fluff really minor fix
ACPI: thinkpad-acpi: use uppercase for "LED" on user documentation
Fixed conflicts in drivers/acpi/video.c and drivers/misc/intel_menlow.c
manually.
'bugzilla-9916', 'ec', 'eeepc', 'idle', 'misc', 'pm-legacy', 'sysfs-links-2.6.26', 'thermal', 'thinkpad' and 'video' into release
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
[POWERPC] Fix crashkernel= handling when no crashkernel= specified
[POWERPC] Make emergency stack safe for current_thread_info() use
[POWERPC] spufs: add .gitignore for spu_save_dump.h & spu_restore_dump.h
[POWERPC] spufs: trace spu_acquire_saved events
[POWERPC] spufs: fix marker name for find_victim
[POWERPC] spufs: add marker for destroy_spu_context
[POWERPC] spufs: add sputrace marker parameter names
[POWERPC] spufs: add context switch notification log
[POWERPC] mpc5200: defconfigs for CM5200, Lite5200B, Motion-PRO and TQM5200
[POWERPC] mpc5200: Switch mpc5200 dts files to dts-v1 format
[POWERPC] mpc5200: Fix FEC error handling on FIFO errors
[POWERPC] mpc5200: add Phytec pcm030 board support
[POWERPC] mpc5200: add gpiolib support for mpc5200
[POWERPC] mpc5200: add interrupt type function
[POWERPC] mpc5200: Fix unterminated of_device_id table
Add a DocBook for debugobjects.
Cc: Greg KH <greg@kroah.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
We can see an ever repeating problem pattern with objects of any kind in the
kernel:
1) freeing of active objects
2) reinitialization of active objects
Both problems can be hard to debug because the crash happens at a point where
we have no chance to decode the root cause anymore. One problem spot are
kernel timers, where the detection of the problem often happens in interrupt
context and usually causes the machine to panic.
While working on a timer related bug report I had to hack specialized code
into the timer subsystem to get a reasonable hint for the root cause. This
debug hack was fine for temporary use, but far from a mergeable solution due
to the intrusiveness into the timer code.
The code further lacked the ability to detect and report the root cause
instantly and keep the system operational.
Keeping the system operational is important to get hold of the debug
information without special debugging aids like serial consoles and special
knowledge of the bug reporter.
The problems described above are not restricted to timers, but timers tend to
expose it usually in a full system crash. Other objects are less explosive,
but the symptoms caused by such mistakes can be even harder to debug.
Instead of creating specialized debugging code for the timer subsystem a
generic infrastructure is created which allows developers to verify their code
and provides an easy to enable debug facility for users in case of trouble.
The debugobjects core code keeps track of operations on static and dynamic
objects by inserting them into a hashed list and sanity checking them on
object operations and provides additional checks whenever kernel memory is
freed.
The tracked object operations are:
- initializing an object
- adding an object to a subsystem list
- deleting an object from a subsystem list
Each operation is sanity checked before the operation is executed and the
subsystem specific code can provide a fixup function which allows to prevent
the damage of the operation. When the sanity check triggers a warning message
and a stack trace is printed.
The list of operations can be extended if the need arises. For now it's
limited to the requirements of the first user (timers).
The core code enqueues the objects into hash buckets. The hash index is
generated from the address of the object to simplify the lookup for the check
on kfree/vfree. Each bucket has it's own spinlock to avoid contention on a
global lock.
The debug code can be compiled in without being active. The runtime overhead
is minimal and could be optimized by asm alternatives. A kernel command line
option enables the debugging code.
Thanks to Ingo Molnar for review, suggestions and cleanup patches.
This adds a minimalistic braille screen reader support. This is meant to
be used by blind people e.g. on boot failures or when / cannot be mounted
etc and thus the userland screen readers can not work.
[akpm@linux-foundation.org: fix exports]
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
Cc: Jiri Kosina <jikos@jikos.cz>
Cc: Dmitry Torokhov <dtor@mail.ru>
Acked-by: Alan Cox <alan@redhat.com>
A few fields in /proc/meminfo were not documented. Fix.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Move BDI statistics to debugfs:
/sys/kernel/debug/bdi/<bdi>/stats
Use postcore_initcall() to initialize the sysfs class and debugfs,
because debugfs is initialized in core_initcall().
Update descriptions in ABI documentation.
Add "max_ratio" to /sys/class/bdi. This indicates the maximum percentage of
the global dirty threshold allocated to this bdi.
[mszeredi@suse.cz]
- fix parsing in max_ratio_store().
- export bdi_set_max_ratio() to modules
- limit bdi_dirty with bdi->max_ratio
- document new sysfs attribute
Under normal circumstances each device is given a part of the total write-back
cache that relates to its current avg writeout speed in relation to the other
devices.
min_ratio - allows one to assign a minimum portion of the write-back cache to
a particular device. This is useful in situations where you might want to
provide a minimum QoS. (One request for this feature came from flash based
storage people who wanted to avoid writing out at all costs - they of course
needed some pdflush hacks as well)
max_ratio - allows one to assign a maximum portion of the dirty limit to a
particular device. This is useful in situations where you want to avoid one
device taking all or most of the write-back cache. Eg. an NFS mount that is
prone to get stuck, or a FUSE mount which you don't trust to play fair.
Add "min_ratio" to /sys/class/bdi. This indicates the minimum percentage of
[mszeredi@suse.cz]
- fix parsing in min_ratio_store()
Provide a place in sysfs (/sys/class/bdi) for the backing_dev_info object.
This allows us to see and set the various BDI specific variables.
In particular this properly exposes the read-ahead window for all relevant
users and /sys/block/<block>/queue/read_ahead_kb should be deprecated.
With patient help from Kay Sievers and Greg KH
[mszeredi@suse.cz]
- split off NFS and FUSE changes into separate patches
- document new sysfs attributes under Documentation/ABI
- do bdi_class_init as a core_initcall, otherwise the "default" BDI
won't be initialized
- remove bdi_init_fmt macro, it's not used very much
[akpm@linux-foundation.org: fix ia64 warning]
Acked-by: Greg KH <greg@kroah.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
There are some places that are known to operate on tasks'
global pids only:
* the rest_init() call (called on boot)
* the kgdb's getthread
* the create_kthread() (since the kthread is run in init ns)
So use the find_task_by_pid_ns(..., &init_pid_ns) there
and schedule the find_task_by_pid for removal.
[sukadev@us.ibm.com: Fix warning in kernel/pid.c]
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Don't refer to file that no longer exists:
docproc: linux-2.6.25-git14/arch/powerpc/kernel/rio.c: No such file or directory
Update the Version and Changelog for megaraid_sas Driver
Signed-off-by: Bo Yang<bo.yang@lsi.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (28 commits)
V4L-DVB(7789a): cx18: fix symbol conflict with ivtv driver
V4L/DVB (7789): tuner: remove static dependencies on analog tuner sub-modules
V4L/DVB (7785): [2.6 patch] make mt9{m001,v022}_controls[] static
V4L/DVB (7786): cx18: new driver for the Conexant CX23418 MPEG encoder chip
V4L/DVB (7783): drivers/media/dvb/frontends/s5h1420.c: printk fix
V4L/DVB (7782): pvrusb2: Driver is no longer experimental
V4L/DVB (7781): pvrusb2-dvb: include dvb support by default and update Kconfig help text
V4L/DVB (7780): pvrusb2: always enable support for OnAir Creator / HDTV USB2
V4L/DVB (7779): pvrusb2-dvb: quiet down noise in kernel log for feed debug
Rename common tuner Kconfig names to use the same
Fix V4L/DVB core help messages
V4L/DVB (7769): Move other terrestrial tuners to common/tuners
V4L/DVB (7768): reorganize some DVB-S Kconfig items
V4L/DVB(7767): Move tuners to common/tuners
V4L/DVB (7766): saa7134: add another PCI ID for Beholder M6
V4L/DVB (7765): Add support for Beholder BeholdTV H6
V4L/DVB (7763): ivtv: add tuner support for the AverMedia M116
V4L/DVB (7762): ivtv: fix tuner detection for PAL-N/Nc
V4L/DVB (7761): ivtv: increase the DMA timeout from 100 to 300 ms
V4L/DVB (7759): ivtv: increase version number to 1.2.1
Many thanks to Steve Toth from Hauppauge and Nattu Dakshinamurthy from
Conexant for their support. I am in particular thankful to Hauppauge
since without their help this driver would not exist. It should also
be noted that Steve did the work to get the DVB part up and running.
Thank you!
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Steven Toth <stoth@hauppauge.com>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Signed-off-by: G. Andrew Walls <awalls@radix.net>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Signed-off-by: Igor Kuznetsov <igk@igk.ru>
Based on earlier work by Jon Smirl and Jochen Friedrich.
This patch allows new-style i2c chip drivers to have alias names using
the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this
point, the old i2c driver binding scheme (driver_name/type) is still
supported.
Cc: Jochen Friedrich <jochen@scram.de>
Cc: Jon Smirl <jonsmirl@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (21 commits)
pciehp: fix error message about getting hotplug control
pci/irq: let pci_device_shutdown to call pci_msi_shutdown v2
pci/irq: restore mask_bits in msi shutdown -v3
doc: replace yet another dev with pdev for consistency in DMA-mapping.txt
PCI: don't expose struct pci_vpd to userspace
doc: fix an incorrect suggestion to pass NULL for PCI like buses
Consistently use pdev as the variable of type struct pci_dev *.
pciehp: Fix command write
shpchp: fix slot name
make pciehp_acpi_get_hp_hw_control_from_firmware()
pciehp: Clean up pcie_init()
pciehp: Mask hotplug interrupt at controller release
pciehp: Remove useless hotplug interrupt enabling
pciehp: Fix wrong slot capability check
pciehp: Fix wrong slot control register access
pciehp: Add missing memory barrier
pciehp: Fix interrupt event handlig
pciehp: fix slot name
Update MAINTAINERS with location of PCI tree
PCI: Add Intel SCH PCI IDs
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
[ALSA] soc - wm9712 - checkpatch fixes
[ALSA] pcsp - Fix more dependency
[ALSA] hda - Add support of Medion RIM 2150
[ALSA] ASoC: Add drivers for the Texas Instruments OMAP processors
[ALSA] ice1724 - Enable watermarks
[ALSA] Add MPU401_INFO_NO_ACK bitflag
Added the support of Medion RIM 2150 laptop with ALC880 codec.
ALSA bug#3708:
https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3708
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-fixes
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-fixes:
x86: fix PCI MSI breaks when booting with nosmp
x86: vget_cycles() __always_inline
x86: add more boot protocol documentation
bootprotocol: cleanup
x86: fix warning in "x86: clean up vSMP detection"
x86: !x & y typo in mtrr code
Replace "dev" with "pdev" for consistency in DMA-mapping.txt.
Signed-off-by: Matti Linnanvuori <mattilinnanvuori@yahoo.com>
Signed-off-by: Jesse Barnes <jbarnes@hobbes.lan>
* git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq:
[CPUFREQ] state info wrong after resume
[CPUFREQ] allow use of the powersave governor as the default one
[CPUFREQ] document the currently undocumented parts of the sysfs interface
[CPUFREQ] expose cpufreq coordination requirements regardless of coordination mechanism
Add a kernel parameter option to 'edd' to enable/disable BIOS Enhanced Disk
Drive Services. CONFIG_EDD_OFF disables EDD while still compiling EDD into
the kernel. Default behavior can be forced using 'edd=on' or 'edd=off' as
a kernel parameter.
[akpm@linux-foundation.org: fix kernel-parameters.txt]
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Signed-off-by: Matt Domsch <Matt_Domsch@dell.com>
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
Make the keyring quotas controllable through /proc/sys files:
(*) /proc/sys/kernel/keys/root_maxkeys
/proc/sys/kernel/keys/root_maxbytes
Maximum number of keys that root may have and the maximum total number of
bytes of data that root may have stored in those keys.
(*) /proc/sys/kernel/keys/maxkeys
/proc/sys/kernel/keys/maxbytes
Maximum number of keys that each non-root user may have and the maximum
total number of bytes of data that each of those users may have stored in
their keys.
Also increase the quotas as a number of people have been complaining that it's
not big enough. I'm not sure that it's big enough now either, but on the
other hand, it can now be set in /etc/sysctl.conf.
Cc: <kwc@citi.umich.edu>
Cc: <arunsr@cse.iitk.ac.in>
Cc: <dwalsh@redhat.com>
Add a keyctl() function to get the security label of a key.
The following is added to Documentation/keys.txt:
(*) Get the LSM security context attached to a key.
long keyctl(KEYCTL_GET_SECURITY, key_serial_t key, char *buffer,
size_t buflen)
This function returns a string that represents the LSM security context
attached to a key in the buffer provided.
Unless there's an error, it always returns the amount of data it could
produce, even if that's too big for the buffer, but it won't copy more
than requested to userspace. If the buffer pointer is NULL then no copy
will take place.
A NUL character is included at the end of the string if the buffer is
sufficiently big. This is included in the returned count. If no LSM is
in force then an empty string will be returned.
A process must have view permission on the key for this function to be
successful.
[akpm@linux-foundation.org: declare keyctl_get_security()]
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Paul Moore <paul.moore@hp.com>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Kevin Coffman <kwc@citi.umich.edu>
Allow the callout data to be passed as a blob rather than a string for
internal kernel services that call any request_key_*() interface other than
request_key(). request_key() itself still takes a NUL-terminated string.
The functions that change are:
request_key_with_auxdata()
request_key_async()
request_key_async_with_auxdata()
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Fix kernel bugzilla #10388.
DMA-API.txt has wrong argument type for some functions. It uses struct device
but should use struct pci_dev.
Acked-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Document the new dma_*map*_attrs() functions.
[markn@au1.ibm.com: fix up for dma-add-dma_map_attrs-interfaces and update docs]
Signed-off-by: Arthur Kepner <akepner@sgi.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Jes Sorensen <jes@sgi.com>
Cc: Roland Dreier <rdreier@cisco.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Grant Grundler <grundler@parisc-linux.org>
Cc: Michael Ellerman <michael@ellerman.id.au>
Signed-off-by: Mark Nelson <markn@au1.ibm.com>
This flag provides the hardwalling properties of mem_exclusive, without
enforcing the exclusivity. Either mem_hardwall or mem_exclusive is sufficient
to prevent GFP_KERNEL allocations from passing outside the cpuset's assigned
nodes.
Signed-off-by: Paul Menage <menage@google.com>
Acked-by: Paul Jackson <pj@sgi.com>
The resource counter is supposed to facilitate the resource accounting of
arbitrary resource (and it already does this for memory controller).
However, it is about to be used in other resources controllers (swap, kernel
memory, networking, etc), so provide a doc describing how to work with it.
This will eliminate all the possible future duplications in the appropriate
controllers' docs.
Fixed errors pointed out by Randy.
[akpm@linux-foundation.org: fix documentation tpyo]
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
We are at system boot and there is only 1 cgroup group (i,e, init_css_set), so
we don't need to run through the css_set linked list. Neither do we need to
run through the task list, since no processes have been created yet.
Also referring to a comment in cgroup.h:
struct css_set
* Set of subsystem states, one for each subsystem. This array
* is immutable after creation apart from the init_css_set
* during subsystem registration (at boot time).
struct cgroup_subsys_state *subsys[CGROUP_SUBSYS_COUNT];
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Reviewed-by: Paul Menage <menage@google.com>
Cc: Pavel Emelyanov <xemul@openvz.org>
Implement a cgroup to track and enforce open and mknod restrictions on device
files. A device cgroup associates a device access whitelist with each cgroup.
A whitelist entry has 4 fields. 'type' is a (all), c (char), or b (block).
'all' means it applies to all types and all major and minor numbers. Major
and minor are either an integer or * for all. Access is a composition of r
(read), w (write), and m (mknod).
The root device cgroup starts with rwm to 'all'. A child devcg gets a copy of
the parent. Admins can then remove devices from the whitelist or add new
entries. A child cgroup can never receive a device access which is denied its
parent. However when a device access is removed from a parent it will not
also be removed from the child(ren).
An entry is added using devices.allow, and removed using
devices.deny. For instance
echo 'c 1:3 mr' > /cgroups/1/devices.allow
allows cgroup 1 to read and mknod the device usually known as
/dev/null. Doing
echo a > /cgroups/1/devices.deny
will remove the default 'a *:* mrw' entry.
CAP_SYS_ADMIN is needed to change permissions or move another task to a new
cgroup. A cgroup may not be granted more permissions than the cgroup's parent
has. Any task can move itself between cgroups. This won't be sufficient, but
we can decide the best way to adequately restrict movement later.
[akpm@linux-foundation.org: fix may-be-used-uninitialized warning]
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Acked-by: James Morris <jmorris@namei.org>
Looks-good-to: Pavel Emelyanov <xemul@openvz.org>
Cc: Daniel Hokka Zakrisson <daniel@hozac.com>
Cc: Paul Menage <menage@google.com>
Cc: Balbir Singh <balbir@in.ibm.com>
This adds support for OLPC XO hardware. Open Firmware on XOs don't contain
the VSA, so it is necessary to emulate the PCI BARs in the kernel. This also
adds functionality for running EC commands, and a CONFIG_OLPC.
A number of OLPC drivers depend upon CONFIG_OLPC.
olpc_ec_timeout is a hack to work around Embedded Controller bugs.
[akpm@linux-foundation.org: build fix]
[akpm@linux-foundation.org: geode_has_vsa build fix]
[akpm@linux-foundation.org: olpc_register_battery_callback doesn't exist]
Signed-off-by: Andres Salomon <dilinger@debian.org>
Cc: Andi Kleen <ak@suse.de>
Cc: Jordan Crouse <jordan.crouse@amd.com>
SysRQ-P is not always useful on SMP systems, since it usually ends up showing
the backtrace of a CPU that is doing just fine, instead of the backtrace of
the CPU that is having problems.
This patch adds SysRQ show-all-cpus(L), which shows the backtrace of every
active CPU in the system. It skips idle CPUs because some SMP systems are
just too large and we already know what the backtrace of the idle task looks
like.
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: <lwoodman@redhat.com>
The kernel is sent to tainted within the warn_on_slowpath() function, and
whenever a warning occurs the new taint flag 'W' is set. This is useful to
know if a warning occurred before a BUG by preserving the warning as a flag
in the taint state.
This does not work on architectures where WARN_ON has its own definition.
These archs are:
1. s390
2. superh
3. avr32
4. parisc
The maintainers of these architectures have been added in the Cc: list
in this email to alert them to the situation.
The documentation in oops-tracing.txt has been updated to include the
new flag.
Signed-off-by: Nur Hussein <nurhussein@gmail.com>
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Full LED sysfs support, and the rest of the assorted minor fixes and
enhancements are a good reason to checkpoint a new version...
Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Signed-off-by: Len Brown <len.brown@intel.com>
Change all occourences of the "led" word to full uppercase in user
documentation.
Add a sysfs led class interface to the led subdriver.
Cc: Richard Purdie <rpurdie@rpsys.net>
Add a sysfs led class interface to the thinklight (light subdriver).
