The noswapaccount parameter has been deprecated since 2.6.38 without any
complaints from users so we can remove it. swapaccount=0|1 can be used
instead.
As we are removing the parameter we can also clean up swapaccount because
it doesn't have to accept an empty string anymore (to match noswapaccount)
and so we can push = into __setup macro rather than checking "=1" resp.
"=0" strings
Cc: Hiroyuki Kamezawa <kamezawa.hiroyuki@gmail.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
cpumask_t is very big struct and cpu_vm_mask is placed wrong position.
It might lead to reduce cache hit ratio.
This patch has two change.
1) Move the place of cpumask into last of mm_struct. Because usually cpumask
is accessed only front bits when the system has cpu-hotplug capability
2) Convert cpu_vm_mask into cpumask_var_t. It may help to reduce memory
footprint if cpumask_size() will use nr_cpumask_bits properly in future.
In addition, this patch change the name of cpu_vm_mask with cpu_vm_mask_var.
It may help to detect out of tree cpu_vm_mask users.
This patch has no functional change.
[akpm@linux-foundation.org: build fix]
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Straightforward conversion of i_mmap_lock to a mutex.
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
i2c-parport: Various cleanups
i2c-i801: Don't depend on other kernel driver config options
i2c-i801: Check for vendor Fujitsu before probing for apanel
i2c-i801: Don't probe for slaves on IDF channels
i2c-i801: SMBus patch for Intel Panther Point DeviceIDs
i2c/writing-clients: Fix foo_driver.id_table
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
kbuild: make KBUILD_NOCMDDEP=1 handle empty built-in.o
scripts/kallsyms.c: fix potential segfault
scripts/gen_initramfs_list.sh: Convert to a /bin/sh script
kbuild: Fix GNU make v3.80 compatibility
kbuild: Fix passing -Wno-* options to gcc 4.4+
kbuild: move scripts/basic/docproc.c to scripts/docproc.c
kbuild: Fix Makefile.asm-generic for um
kbuild: Allow to combine multiple W= levels
kbuild: Disable -Wunused-but-set-variable for gcc 4.6.0
Fix handling of backlash character in LINUX_COMPILE_BY name
kbuild: asm-generic support
kbuild: implement several W= levels
kbuild: Fix build with binutils <= 2.19
initramfs: Use KBUILD_BUILD_TIMESTAMP for generated entries
kbuild: Allow to override LINUX_COMPILE_BY and LINUX_COMPILE_HOST macros
kbuild: Drop unused LINUX_COMPILE_TIME and LINUX_COMPILE_DOMAIN macros
kbuild: Use the deterministic mode of ar
kbuild: Call gzip with -n
kbuild: move KALLSYMS_EXTRA_PASS from Kconfig to Makefile
Kconfig: improve KALLSYMS_ALL documentation
Fix up trivial conflict in Makefile
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (40 commits)
Input: ADP5589 - new driver for I2C Keypad Decoder and I/O Expander
Input: tsc2007 - add X, Y and Z fuzz factors to platform data
Input: tsc2007 - add poll_period parameter to platform data
Input: tsc2007 - add poll_delay parameter to platform data
Input: tsc2007 - add max_rt parameter to platform data
Input: tsc2007 - debounce pressure measurement
Input: ad714x - fix captouch wheel option algorithm
Input: ad714x - allow platform code to specify irqflags
Input: ad714x - fix threshold and completion interrupt masks
Input: ad714x - fix up input configuration
Input: elantech - remove support for proprietary X driver
Input: elantech - report multitouch with proper ABS_MT messages
Input: elantech - export pressure and width when supported
Input: elantech - describe further the protocol
Input: atmel_tsadcc - correct call to input_free_device
Input: add driver FSL MPR121 capacitive touch sensor
Input: remove useless synchronize_rcu() calls
Input: ads7846 - fix gpio_pendown configuration
Input: ads7846 - add possibility to use external vref on ads7846
Input: rotary-encoder - add support for half-period encoders
This patch adds the SMBus controller DeviceID for the Intel Panther Point PCH.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
The i2c_device_id structure variable's name is not used in the
i2c_driver structure.
Signed-off-by: Vikram Narayanan <vikram186@gmail.com>
Cc: stable@kernel.org
* 'linux-next' of git://git.infradead.org/ubifs-2.6: (52 commits)
UBIFS: switch to dynamic printks
UBIFS: fix kernel-doc comments
UBIFS: fix extremely rare mount failure
UBIFS: simplify LEB recovery function further
UBIFS: always cleanup the recovered LEB
UBIFS: clean up LEB recovery function
UBIFS: fix-up free space on mount if flag is set
UBIFS: add the fixup function
UBIFS: add a superblock flag for free space fix-up
UBIFS: share the next_log_lnum helper
UBIFS: expect corruption only in last journal head LEBs
UBIFS: synchronize write-buffer before switching to the next bud
UBIFS: remove BUG statement
UBIFS: change bud replay function conventions
UBIFS: substitute the replay tree with a replay list
UBIFS: simplify replay
UBIFS: store free and dirty space in the bud replay entry
UBIFS: remove unnecessary stack variable
UBIFS: double check that buds are replied in order
UBIFS: make 2 functions static
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (247 commits)
[media] gspca - sunplus: Fix some warnings and simplify code
[media] gspca: Fix some warnings tied to 'no debug'
[media] gspca: Unset debug by default
[media] gspca - cpia1: Remove a bad conditional compilation instruction
[media] gspca - main: Remove USB traces
[media] gspca - main: Version change to 2.13
[media] gspca - stk014 / t613: Accept the index 0 in querymenu
[media] gspca - kinect: Remove __devinitdata
[media] gspca - cpia1: Fix some warnings
[media] video/Kconfig: Fix mis-classified devices
[media] support for medion dvb stick 1660:1921
[media] tm6000: fix uninitialized field, change prink to dprintk
[media] cx231xx: Add support for Iconbit U100
[media] saa7134 add new TV cards
[media] Use a more consistent value for RC repeat period
[media] cx18: Move spinlock and vb_type initialisation into stream_init
[media] tm6000: remove tm6010 sif audio start and stop
[media] tm6000: remove unused exports
[media] tm6000: add pts logging
[media] tm6000: change from ioctl to unlocked_ioctl
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (27 commits)
PCI: Don't use dmi_name_in_vendors in quirk
PCI: remove unused AER functions
PCI/sysfs: move bus cpuaffinity to class dev_attrs
PCI: add rescan to /sys/.../pci_bus/.../
PCI: update bridge resources to get more big ranges when allocating space (again)
KVM: Use pci_store/load_saved_state() around VM device usage
PCI: Add interfaces to store and load the device saved state
PCI: Track the size of each saved capability data area
PCI/e1000e: Add and use pci_disable_link_state_locked()
x86/PCI: derive pcibios_last_bus from ACPI MCFG
PCI: add latency tolerance reporting enable/disable support
PCI: add OBFF enable/disable support
PCI: add ID-based ordering enable/disable support
PCI hotplug: acpiphp: assume device is in state D0 after powering on a slot.
PCI: Set PCIE maxpayload for card during hotplug insertion
PCI/ACPI: Report _OSC control mask returned on failure to get control
x86/PCI: irq and pci_ids patch for Intel Panther Point DeviceIDs
PCI: handle positive error codes
PCI: check pci_vpd_pci22_wait() return
PCI: Use ICH6_GPIO_EN in ich6_lpc_acpi_gpio
Fix up trivial conflicts in include/linux/pci_ids.h: commit a6e5e2be4461
moved the intel SMBUS ID definitons to the i2c-i801.c driver.
Fixed the broken links in the SubmittingPatches file.
[ The old links turn out to not be broken after all, but the new links
are certainly more readable - Linus ]
Fixed typos.
v2: Incorporated changes by Randy Dunlap.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
Update LXR (Linux cross reference) web link.
Signed-off-by: Harry Wei <harryxiyou@gmail.com>
max_user_instances was removed in this commit:
commit 9df04e1f25effde823a600e755b51475d438f56b
Author: Davide Libenzi <davidel@xmailserver.org>
Date: Thu Jan 29 14:25:26 2009 -0800
epoll: drop max_user_instances and rely only on max_user_watches
but the documentation entry was not removed.
Cc: Davide Libenzi <davidel@xmailserver.org>
Signed-off-by: Lucian Adrian Grijincu <lucian.grijincu@gmail.com>
v2, updated based on comments from Joe and Paul.
Update to Documentation/dontdiff, based on many updates to
various .gitignore patches over the last 2 years.
Initially begun by Michael Prokop <mika@grml.org>, with lots of
Cc: Michael Prokop <mika@grml.org>
Cc: Joe Perches <joe@perches.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6
* 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (205 commits)
USB: EHCI: Remove SPARC_LEON {read,write}_be definitions from ehci.h
USB: UHCI: Support big endian GRUSBHC HC
sparc: add {read,write}*_be routines
USB: UHCI: Add support for big endian descriptors
USB: UHCI: Use ACCESS_ONCE rather than using a full compiler barrier
USB: UHCI: Add support for big endian mmio
usb-storage: Correct adjust_quirks to include latest flags
usb/isp1760: Fix possible unlink problems
usb/isp1760: Move function isp1760_endpoint_disable() within file.
USB: remove remaining usages of hcd->state from usbcore and fix regression
usb: musb: ux500: add configuration and build options for ux500 dma
usb: musb: ux500: add dma glue layer for ux500
usb: musb: ux500: add dma name for ux500
usb: musb: ux500: add ux500 specific code for gadget side
usb: musb: fix compile error
usb-storage: fix up the unusual_realtek device list
USB: gadget: f_audio: Fix invalid dereference of initdata
EHCI: don't rescan interrupt QHs needlessly
OHCI: fix regression caused by nVidia shutdown workaround
USB: OTG: msm: Free VCCCX regulator even if we can't set the voltage
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (48 commits)
serial: 8250_pci: add support for Cronyx Omega PCI multiserial board.
tty/serial: Fix break handling for PORT_TEGRA
tty/serial: Add explicit PORT_TEGRA type
n_tracerouter and n_tracesink ldisc additions.
Intel PTI implementaiton of MIPI 1149.7.
Kernel documentation for the PTI feature.
export kernel call get_task_comm().
tty: Remove to support serial for S5P6442
pch_phub: Support new device ML7223
8250_pci: Add support for the Digi/IBM PCIe 2-port Adapter
ASoC: Update cx20442 for TTY API change
pch_uart: Support new device ML7223 IOH
parport: Use request_muxed_region for IT87 probe and lock
tty/serial: add support for Xilinx PS UART
n_gsm: Use print_hex_dump_bytes
drivers/tty/moxa.c: Put correct tty value
TTY: tty_io, annotate locking functions
TTY: serial_core, remove superfluous set_task_state
TTY: serial_core, remove invalid test
Char: moxa, fix locking in moxa_write
Fix up trivial conflicts in drivers/bluetooth/hci_ldisc.c and
drivers/tty/serial/Makefile.
I did the hci_ldisc thing as an evil merge, cleaning things up.
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging:
hwmon: (coretemp) Fix checkpatch errors
hwmon: Remove pkgtemp driver
hwmon: (coretemp) Merge pkgtemp with coretemp
hwmon: (pmbus) Add support for Analog Devices ADM1275
hwmon: (pmbus) Support for TI UCD90xxx series Sequencer and System Health Controllers
hwmon: (pmbus) Add support for TI UCD9200 series of PWM System Controllers
hwmon: (pmbus) Use device specific function to read fan configuration
hwmon: (pmbus) Expand scope of device specific get_status function
hwmon: (pmbus) Introduce infrastructure to detect sensors and limit registers
hwmon: Driver for MAX16065 System Manager and compatibles
hwmon: (sht15) add support for CRC validation
hwmon: (sht15) add support for the status register
hwmon: (sht15) clean-up the probe function
hwmon: (sht15) general code clean-up
hwmon: Add support for MAX6642
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (36 commits)
HID: hid-multitouch: cosmetic changes, sort classes and devices
HID: hid-multitouch: class MT_CLS_STANTUM is redundant with MT_CLS_CONFIDENCE
HID: hid-multitouch: add support for Unitec panels
HID: hid-multitouch: add support for Touch International panels
HID: hid-multitouch: add support for GoodTouch panels
HID: hid-multitouch: add support for CVTouch panels
HID: hid-multitouch: add support for ActionStar panels
HID: hiddev: fix race between hiddev_disconnect and hiddev_release
HID: magicmouse: ignore 'ivalid report id' while switching modes
HID: fix a crash in hid_report_raw_event() function.
HID: hid-multitouch: add support for Elo TouchSystems 2515 IntelliTouch Plus
HID: assorted usage updates from hut 1.12
HID: roccat: fix actual/startup profile sysfs attribute in koneplus
HID: hid-multitouch: Add support for Lumio panels
HID: 'name' and 'phys' in 'struct hid_device' can never be NULL
HID: hid-multitouch: add support for Ilitek dual-touch panel
HID: picolcd: Avoid compile warning/error triggered by copy_from_user()
HID: add support for Logitech G27 wheel
HID: hiddev: fix error path in hiddev_read when interrupted
HID: add support for Sony Navigation Controller
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (346 commits)
ASoC: core: Don't set "(null)" as a driver name
ALSA: hda - Use LPIB for ATI/AMD chipsets as default
Revert "ALSA: hda - Use position_fix=3 as default for AMD chipsets"
ASoC: Tegra: Fix compile when debugfs not enabled
ASoC: spdif-dit: Add missing MODULE_*
SOUND: OSS: Remove Au1550 driver.
ALSA: hda - add Intel Panther Point HDMI codec id
ALSA: emu10k1 - Add dB range to Bass and Treble for SB Live!
ALSA: hda - Remove PCM mixer elements from Virtual Master of realtek
ALSA: hda - Fix input-src parse in patch_analog.c
ASoC: davinci-mcasp: enable ping-pong SRAM buffers
ASoC: add iPAQ hx4700 machine driver
ASoC: Asahi Kasei AK4641 codec driver
ALSA: hda - Enable Realtek ALC269 codec input layer beep
ALSA: intel8x0m: enable AMD8111 modem
ALSA: HDA: Add jack detection for HDMI
ALSA: sound, core, pcm_lib: fix xrun_log
ASoC: Max98095: Move existing NULL check before pointer dereference.
ALSA: sound, core, pcm_lib: xrun_log: log also in_interrupt
ALSA: usb-audio - Add support for USB X-Fi S51 Pro
* 'kvm-updates/2.6.40' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (131 commits)
KVM: MMU: Use ptep_user for cmpxchg_gpte()
KVM: Fix kvm mmu_notifier initialization order
KVM: Add documentation for KVM_CAP_NR_VCPUS
KVM: make guest mode entry to be rcu quiescent state
KVM: x86 emulator: Make jmp far emulation into a separate function
KVM: x86 emulator: Rename emulate_grpX() to em_grpX()
KVM: x86 emulator: Remove unused arg from emulate_pop()
KVM: x86 emulator: Remove unused arg from writeback()
KVM: x86 emulator: Remove unused arg from read_descriptor()
KVM: x86 emulator: Remove unused arg from seg_override()
KVM: Validate userspace_addr of memslot when registered
KVM: MMU: Clean up gpte reading with copy_from_user()
KVM: PPC: booke: add sregs support
KVM: PPC: booke: save/restore VRSAVE (a.k.a. USPRG0)
KVM: PPC: use ticks, not usecs, for exit timing
KVM: PPC: fix exit accounting for SPRs, tlbwe, tlbsx
KVM: PPC: e500: emulate SVR
KVM: VMX: Cache vmcs segment fields
KVM: x86 emulator: consolidate segment accessors
KVM: VMX: Avoid reading %rip unnecessarily when handling exceptions
for-linus
Switch to debugging using dynamic printk (pr_debug()). There is no good reason
to carry custom debugging prints if there is so cool and powerful generic
dynamic printk infrastructure, see Documentation/dynamic-debug-howto.txt. With
dynamic printks we can switch on/of individual prints, per-file, per-function
and per format messages. This means that instead of doing old-fashioned
echo 1 > /sys/module/ubifs/parameters/debug_msgs
to enable general messages, we can do:
echo 'format "UBIFS DBG gen" +ptlf' > control
to enable general messages and additionally ask the dynamic printk
infrastructure to print process ID, line number and function name. So there is
no reason to keep UBIFS-specific crud if there is more powerful generic thing.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Document KVM_CAP_NR_VCPUS that can be used by the userspace to determine
maximum number of VCPUs it can create with the KVM_CREATE_VCPU ioctl.
Cc: Avi Kivity <avi@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Jan Kiszka <jan.kiszka@web.de>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
Signed-off-by: Avi Kivity <avi@redhat.com>
* commit '29ce831000081dd757d3116bf774aafffc4b6b20': (34 commits)
rcu: provide rcu_virt_note_context_switch() function.
rcu: get rid of signed overflow in check_cpu_stall()
rcu: optimize rcutiny
rcu: prevent call_rcu() from diving into rcu core if irqs disabled
rcu: further lower priority in rcu_yield()
rcu: introduce kfree_rcu()
rcu: fix spelling
rcu: call __rcu_read_unlock() in exit_rcu for tree RCU
rcu: Converge TINY_RCU expedited and normal boosting
rcu: remove useless ->boosted_this_gp field
rcu: code cleanups in TINY_RCU priority boosting.
rcu: Switch to this_cpu() primitives
rcu: Use WARN_ON_ONCE for DEBUG_OBJECTS_RCU_HEAD warnings
rcu: mark rcutorture boosting callback as being on-stack
rcu: add DEBUG_OBJECTS_RCU_HEAD check for alignment
rcu: Enable DEBUG_OBJECTS_RCU_HEAD from !PREEMPT
rcu: Add forward-progress diagnostic for per-CPU kthreads
rcu: add grace-period age and more kthread state to tracing
rcu: fix tracing bug thinko on boost-balk attribution
rcu: update tracing documentation for new rcutorture and rcuboost
Pulling in rcu_virt_note_context_switch().
rcu: fix spelling
After remove the device from /sys, we have to rescan all or
find out the bridge and access /sys../device/rescan there.
this patch add /sys/.../pci_bus/.../rescan. So user can rescan more easy.
that is more clean and easy to understand.
like after remove 0000:c4:00.0, you can rescan 0000:c4 directly.
-v2: According to Jesse, use function instead of exposing attr, so could hide
#ifdef in header file.
also add code to remove rescan file in remove path.
-v3: GregKH pointed out that we should use dev_attrs to avoid racing.
So add pcibus_attrs and make it to be member of pcibus_attrs.
-v4: Change name to pcibus_dev_attrs according to GregKH
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
After the merge of pkgtemp functionality into the coretemp driver,
the pkgtemp driver is no longer necessary. Remove it.
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (45 commits)
crypto: caam - add support for sha512 variants of existing AEAD algorithms
crypto: caam - remove unused authkeylen from caam_ctx
crypto: caam - fix decryption shared vs. non-shared key setting
crypto: caam - platform_bus_type migration
crypto: aesni-intel - fix aesni build on i386
crypto: aesni-intel - Merge with fpu.ko
crypto: mv_cesa - make count_sgs() null-pointer proof
crypto: mv_cesa - copy remaining bytes to SRAM only when needed
crypto: mv_cesa - move digest state initialisation to a better place
crypto: mv_cesa - fill inner/outer IV fields only in HMAC case
crypto: mv_cesa - refactor copy_src_to_buf()
crypto: mv_cesa - no need to save digest state after the last chunk
crypto: mv_cesa - print a warning when registration of AES algos fail
crypto: mv_cesa - drop this call to mv_hash_final from mv_hash_finup
crypto: mv_cesa - the descriptor pointer register needs to be set just once
crypto: mv_cesa - use ablkcipher_request_cast instead of the manual container_of
crypto: caam - fix printk recursion for long error texts
crypto: caam - remove unused keylen from session context
hwrng: amd - enable AMD hw rnd driver for Maple PPC boards
hwrng: amd - manage resource allocation
A few new capabilities added to frontend.h for DVB-T2. Added these
to the documentation plus some notes explaining that they are
used by the T2 delivery system.
Signed-off-by: Steve Kerrison <steve@stevekerrison.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits)
macvlan: fix panic if lowerdev in a bond
tg3: Add braces around 5906 workaround.
tg3: Fix NETIF_F_LOOPBACK error
macvlan: remove one synchronize_rcu() call
networking: NET_CLS_ROUTE4 depends on INET
irda: Fix error propagation in ircomm_lmp_connect_response()
irda: Kill set but unused variable 'bytes' in irlan_check_command_param()
irda: Kill set but unused variable 'clen' in ircomm_connect_indication()
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport()
be2net: Kill set but unused variable 'req' in lancer_fw_download()
irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication()
atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined.
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer().
rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()
rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection()
rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window()
pkt_sched: Kill set but unused variable 'protocol' in tc_classify()
isdn: capi: Use pr_debug() instead of ifdefs.
tg3: Update version to 3.119
tg3: Apply rx_discards fix to 5719/5720
Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c
as per Davem.
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (110 commits)
[SCSI] qla2xxx: Refactor call to qla2xxx_read_sfp for thermal temperature.
[SCSI] qla2xxx: Unify the read/write sfp mailbox command routines.
[SCSI] qla2xxx: Clear complete initialization control block.
[SCSI] qla2xxx: Allow an override of the registered maximum LUN.
[SCSI] qla2xxx: Add host number in reset and quiescent message logs.
[SCSI] qla2xxx: Correctly read sfp single byte mailbox register.
[SCSI] qla2xxx: Add qla82xx_rom_unlock() function.
[SCSI] qla2xxx: Log if qla82xx firmware fails to load from flash.
[SCSI] qla2xxx: Use passed in host to initialize local scsi_qla_host in queuecommand function
[SCSI] qla2xxx: Correct buffer start in edc sysfs debug print.
[SCSI] qla2xxx: Update firmware version after flash update for ISP82xx.
[SCSI] qla2xxx: Fix hang during driver unload when vport is active.
[SCSI] qla2xxx: Properly set the dsd_list_len for dsd_chaining in cmd type 6.
[SCSI] qla2xxx: Fix virtual port failing to login after chip reset.
[SCSI] qla2xxx: Fix vport delete hang when logins are outstanding.
[SCSI] hpsa: Change memset using sizeof(ptr) to sizeof(*ptr)
[SCSI] ipr: Rate limit DMA mapping errors
[SCSI] hpsa: add P2000 to list of shared SAS devices
[SCSI] hpsa: do not attempt PCI power management reset method if we know it won't work.
[SCSI] hpsa: remove superfluous sleeps around reset code
M420 is a hybrid YUV 4:2:0 packet/planar format. Two Y lines are
followed by an interleaved U/V line.
[laurent.pinchart@ideasonboard.com: split into v4l/uvcvideo patches]
[laurent.pinchart@ideasonboard.com: add documentation]
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Add V4L2_MBUS_FMT_JPEG_1X8 format and the corresponding Docbook
documentation.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
This patch merges the pkgtemp with coretemp driver.
The sysfs interfaces for all cores in the same pkg
are shown under one directory, in hwmon. It also
supports CONFIG_HOTPLUG_CPU. So, the sysfs interfaces
are created when each core comes online and are
removed when it goes offline.
Signed-off-by: Durgadoss R <durgadoss.r@intel.com>
[guenter.roeck@ericsson.com: Fixed section reference errors]
Move the public API definitions to include/linux/uvcvideo.h and bump the
version number to 1.1.0. Compatibility with the old API is kept,
application can still be compiled against the private header and will
not break.
This adds detailed documentation about the driver's extension unit control
features. Part of it has been adopted from the dynctrl.txt that used to be
available in the driver's previous Subversion repository.
The documentation has been rewritten to match the current implementation, in
particular to capture the new XU control support including UVCIOC_CTRL_QUERY.
Signed-off-by: Martin Rubli <martin_rubli@logitech.com>
Those ioctls are deprecated, list them in the features removal schedule
for 2.6.42.
The ability to force the encoder or decoder chip was broken by commit
0ab6e1c38d80ab586e3a1ca9e71844131d9f51dc in February 2009. As nobody
complained for over 2 years, I take it that these parameters were no
longer used so we can simply drop them.
Cc: Hans Verkuil <hverkuil@xs4all.nl>
It only contains generated files
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
Add a 10 bits per pixel greyscale format in a bit-packed array representation,
naming it Y10B. Such pixel format is supplied for instance by the Kinect
sensor device.
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
Signed-off-by: Jean-François Moine <moinejf@free.fr>
Signed-off-by: Patrice CHOTARD <patricechotard@free.fr>
Given how PCTV has multiple products with the same model name, include the
model number in the description and #define to make it a little more clear.
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
Manual merge of arch/powerpc/kernel/smp.c and add missing scheduler_ipi()
call to arch/powerpc/platforms/cell/interrupt.c
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (44 commits)
debugfs: Silence DEBUG_STRICT_USER_COPY_CHECKS=y warning
sysfs: remove "last sysfs file:" line from the oops messages
drivers/base/memory.c: fix warning due to "memory hotplug: Speed up add/remove when blocks are larger than PAGES_PER_SECTION"
SYSFS: Fix erroneous comments for sysfs_update_group().
driver core: remove the driver-model structures from the documentation
driver core: Add the device driver-model structures to kerneldoc
Translated Documentation/email-clients.txt
RAW driver: Remove call to kobject_put().
reboot: disable usermodehelper to prevent fs access
efivars: prevent oops on unload when efi is not enabled
Allow setting of number of raw devices as a module parameter
Introduce CONFIG_GOOGLE_FIRMWARE
driver: Google Memory Console
driver: Google EFI SMI
x86: Better comments for get_bios_ebda()
x86: get_bios_ebda_length()
misc: fix ti-st build issues
params.c: Use new strtobool function to process boolean inputs
debugfs: move to new strtobool
Fix up trivial conflicts in fs/debugfs/file.c due to the same patch
being applied twice, and an unrelated cleanup nearby.
