path: root/Documentation
2008-02-03move frv docs one level upAdrian Bunk
My first guess for "fujitsu" was it might be related to the fujitsu-laptop.c driver... Move the frv directory one level up since frv is the name of the architecture in the Linux kernel. Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03remove Documentation/smp.txtAdrian Bunk
After seeing the filename I'd have expected something about the implementation of SMP in the Linux kernel - not some notes on kernel configuration and building trivialities noone would search at this place. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alan Cox <alan@redhat.com>
2008-02-03Documentation: Clarify when module debugging actually works.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03Documentation: Remove references to dead "st0x" and "tmc8xx" parms.Robert P. J. Day
2008-02-03Documentation: Update to refer to correct "rcupdate" module nameRobert P. J. Day
2008-02-03Documentation: "decnet=" should read "decnet.addr=".Robert P. J. Day
2008-02-03fix typo 'the same the\>'Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03use the newc archive format as requested by initramfsUwe Kleine-König
This is a documentation followup to 2e591bbc0d563e12f5a260fbbca0df7d5810910e Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03Documentation: fix type errorDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-02ide-tape: move historical changelog to ↵Borislav Petkov
Documentation/ide/ChangeLog.ide-tape.1995-2002 Also, cleanup whitespace and update comments. Bart: - remove reference to drivers/block/ide.c - move driver documentation to Documentation/ide/ide-tape.txt Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02Merge git://git.infradead.org/battery-2.6Linus Torvalds
* git://git.infradead.org/battery-2.6: apm_power: check I.intval for zero value, we use it as the divisor MAINTAINERS: remove kernel-discuss@handhelds.org list pda_power: implement polling pda_power: various cleanups apm_power: support using VOLTAGE_* properties for apm calculations pda_power: add suspend/resume support power_supply: add few more values and props pda_power: only register available psu power: fix incorrect unregistration in power_supply_create_attrs error path power: remove POWER_SUPPLY_PROP_CAPACITY_LEVEL [BATTERY] power_supply_leds: use kasprintf [BATTERY] Every file should include the headers containing the prototypes for its global functions.
2008-02-02Merge branch 'suspend' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'suspend' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (38 commits) suspend: cleanup reference to swsusp_pg_dir[] PM: Remove obsolete /sys/devices/.../power/state docs Hibernation: Invoke suspend notifications after console switch Suspend: Invoke suspend notifications after console switch Suspend: Clean up suspend_64.c Suspend: Add config option to disable the freezer if architecture wants that ACPI: Print message before calling _PTS ACPI hibernation: Call _PTS before suspending devices Hibernation: Introduce begin() and end() callbacks ACPI suspend: Call _PTS before suspending devices ACPI: Separate disabling of GPEs from _PTS ACPI: Separate invocations of _GTS and _BFS from _PTS and _WAK Suspend: Introduce begin() and end() callbacks suspend: fix ia64 allmodconfig build ACPI: clear GPE earily in resume to avoid warning Suspend: Clean up Kconfig (V2) Hibernation: Clean up Kconfig (V2) Hibernation: Update messages Suspend: Use common prefix in messages Hibernation: Remove unnecessary variable declaration ...
2008-02-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/pci-2.6: (64 commits) PCI: make pci_bus a struct device PCI: fix codingstyle issues in include/linux/pci.h PCI: fix codingstyle issues in drivers/pci/pci.h PCI: PCIE ASPM support PCI: Fix fakephp deadlock PCI: modify SB700 SATA MSI quirk PCI: Run ACPI _OSC method on root bridges only PCI ACPI: AER driver should only register PCIe devices with _OSC PCI ACPI: Added a function to register _OSC with only PCIe devices. PCI: constify function pointer tables PCI: Convert drivers/pci/proc.c to use unlocked_ioctl pciehp: block new requests from the device before power off pciehp: workaround against Bad DLLP during power off pciehp: wait for 1000ms before LED operation after power off PCI: Remove pci_enable_device_bars() from documentation PCI: Remove pci_enable_device_bars() PCI: Remove users of pci_enable_device_bars() PCI: Add pci_enable_device_{io,mem} intefaces PCI: avoid save the same type of cap multiple times PCI: correctly initialize a structure for pcie_save_pcix_state() ...
2008-02-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (128 commits) USB: fix codingstyle issues in drivers/usb/core/*.c USB: fix codingstyle issues in drivers/usb/core/message.c USB: fix codingstyle issues in drivers/usb/core/hcd-pci.c USB: fix codingstyle issues in drivers/usb/core/devio.c USB: fix codingstyle issues in drivers/usb/core/devices.c USB: fix codingstyle issues in drivers/usb/core/*.h USB: fix codingstyle issues in include/linux/usb/ USB: fix codingstyle issues in include/linux/usb.h USB: mark USB drivers as being GPL only USB: use a real vendor and product id for root hubs USB: mount options: fix usbfs USB: Fix usb_serial_driver structure for Kobil cardreader driver. usb: ehci should use u16 for isochronous intervals usb: ehci, remove false clear-reset path USB: Use menuconfig objects usb: ohci-sm501 driver usb: dma bounce buffer support USB: last abuses of intfdata in close for usb-serial drivers USB: kl5kusb105 don't flush to logically disconnected devices USB: oti6858: cleanup ...
2008-02-02power_supply: add few more values and propsDmitry Baryshkov
Add LiMn (one of the most common for small non-rechargable batteries) battery technology and voltage_min/_max properties support. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Anton Vorontsov <cbou@mail.ru>
2008-02-02power: remove POWER_SUPPLY_PROP_CAPACITY_LEVELAndres Salomon
The CAPACITY_LEVEL stuff defines various levels of charge; however, what is the difference between them? What differentiates between HIGH and NORMAL, LOW and CRITICAL, etc? As it appears that these are fairly arbitrary, we end up making such policy decisions in the kernel (or in hardware). This is the sort of decision that should be made in userspace, not in the kernel. If the hardware does not support _CAPACITY and it cannot be easily calculated, then perhaps the driver should register a custom CAPACITY_LEVEL attribute; however, userspace should not become accustomed to looking for such a thing, and we should certainly not encourage drivers to provide CAPACITY_LEVEL stubs. The following removes support for POWER_SUPPLY_PROP_CAPACITY_LEVEL. The OLPC battery driver is the only driver making use of this, so it's removed from there as well. Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-02-01PM: Remove obsolete /sys/devices/.../power/state docsDavid Brownell
The /sys/devices/.../power/state files have been gone for a while now, but I just noticed some documentation that still refers to them. (Fortunately described as DEPRECATED and WILL REMOVE). Time to remove that obsolete documentation too ... Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01ACPI suspend: Call _PTS before suspending devicesRafael J. Wysocki
The ACPI 1.0 specification wants us to put devices into low power states after executing the _PTS global control method, while ACPI 2.0 and later want us to do that in the reverse order. The current suspend code follows ACPI 2.0 in that respect which causes some ACPI 1.0x systems to hang during suspend (ref. http://bugzilla.kernel.org/show_bug.cgi?id=9528). Make the suspend code execute _PTS before putting devices into low power states (ie. in accordance with ACPI 1.0x) and provide a command line option to override the default if need be. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01PM: Suspend/hibernation debug documentation update (rev. 2)Rafael J. Wysocki
Update the suspend/hibernation debugging and testing documentation to describe the newly introduced testing facilities. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Hibernation: Add PM_RESTORE_PREPARE and PM_POST_RESTORE notifiers (rev. 2)Alan Stern
Add PM_RESTORE_PREPARE and PM_POST_RESTORE notifiers to the PM core, to be used in analogy with the existing PM_HIBERNATION_PREPARE and PM_POST_HIBERNATION notifiers. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Hibernation: Introduce exportable suspend ioctls header (rev. 2)Rafael J. Wysocki
Move the definitions of hibernation ioctls to a separate header file in include/linux, which can be exported to the user space. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Hibernation: Correct definitions of some ioctls (rev. 2)Rafael J. Wysocki
Three ioctl numbers belonging to the hibernation userland interface, SNAPSHOT_ATOMIC_SNAPSHOT, SNAPSHOT_AVAIL_SWAP, SNAPSHOT_GET_SWAP_PAGE, are defined in a wrong way (eg. not portable). Provide new ioctl numbers for these ioctls and mark the existing ones as deprecated. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Hibernation: Mark SNAPSHOT_SET_SWAP_FILE ioctl as deprecated (rev. 2)Rafael J. Wysocki
Mark the SNAPSHOT_SET_SWAP_FILE ioctl belonging to the hibernation userland interface as deprecated. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Hibernation: Rework platform support ioctls (rev. 2)Rafael J. Wysocki
Modify the hibernation userland interface by adding two new ioctls to it, SNAPSHOT_PLATFORM_SUPPORT and SNAPSHOT_POWER_OFF, that can be used, respectively, to switch the hibernation platform support on/off and to make the kernel transition the system to the hibernation state (eg. ACPI S4) using the platform (eg. ACPI) driver. These ioctls are intended to replace the misdesigned SNAPSHOT_PMOPS ioctl, which from now is regarded as obsolete and will be removed in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Hibernation: Introduce SNAPSHOT_GET_IMAGE_SIZE ioctlRafael J. Wysocki
Add a new ioctl, SNAPSHOT_GET_IMAGE_SIZE, returning the size of the (just created) hibernation image, to the hibernation userland interface. This ioctl is necessary so that the userland utilities using the interface need not access the hibernation image header, owned by the kernel, in order to obtain the size of the image. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01PCI: Remove pci_enable_device_bars() from documentationGrant Grundler
Patch below removes pci_enable_device_bars() from Documentation/pci.txt . Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (100 commits) ide: move hwif_register() call out of ide_probe_port() ide: factor out code for tuning devices from ide_probe_port() ide: move handling of I/O resources out of ide_probe_port() ide: make probe_hwif() return an error value ide: use ide_remove_port_from_hwgroup in init_irq() ide: prepare init_irq() for using ide_remove_port_from_hwgroup() ide: factor out code removing port from hwgroup from ide_unregister() ide: I/O resources are released too early in ide_unregister() ide: cleanup ide_system_bus_speed() ide: remove needless zeroing of hwgroup fields from init_irq() ide: remove unused ide_hwgroup_t fields ide_platform: remove struct hwif_prop ide: remove hwif->present manipulations from hwif_init() ide: move wait_hwif_ready() documentation in the right place ide: fix handling of busy I/O resources in probe_hwif() <linux/hdsmart.h> is not used by kernel code ide: don't include <linux/hdsmart.h> ide-floppy: cleanup header ide: update/add my Copyrights ide: delete filenames/versions from comments ...
2008-02-01USB: mark USB drivers as being GPL onlyGreg Kroah-Hartman
Over two years ago, the Linux USB developers stated that they believed there was no way to create a USB kernel driver that was not under the GPL. This patch moves the USB apis to enforce that decision. There are no known closed source USB drivers in the wild, so this patch should cause no problems. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: Add documentation for USB suspend statistics.Sarah Sharp
This documents two newly created files: /sys/bus/usb/device/.../power/connected_duration /sys/bus/usb/device/.../power/active_duration Documentation was placed in Documentation/ABI/testing, since that's where the documentation is for the other USB sysfs power files. Signed-off-by: Sarah Sharp <sarah.a.sharp@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: add Printer Gadget DriverCraig W. Nadler
G_PRINTER: Adds a USB printer gadget driver for use in printer firmware. This adds a USB printer gadget driver for use in printer firmware. The printer gadget channels data between the USB host and a userspace program driving the print engine. The user space program reads and writes the device file /dev/g_printer to receive or send printer data. It can use ioctl calls to the device file to get or set printer status. Signed-off-by: Craig W. Nadler <craig@nadler.us> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: add iuu_phoenix driverAlain Degreffe
Signed-off-by: Alain Degreffe <eczema@ecze.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01ide-floppy: cleanup headerBorislav Petkov
Move ide-floppy historical changelog to Documentation/ide/ChangeLog.ide-floppy.1996-2002 Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: move historical changelog to ↵Bartlomiej Zolnierkiewicz
Documentation/ide/ChangeLog.ide-cd.1994-2004 Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01[AUDIT] break large execve argument logging into smaller messagesEric Paris
execve arguments can be quite large. There is no limit on the number of arguments and a 4G limit on the size of an argument. this patch prints those aruguments in bite sized pieces. a userspace size limitation of 8k was discovered so this keeps messages around 7.5k single arguments larger than 7.5k in length are split into multiple records and can be identified as aX[Y]= Signed-off-by: Eric Paris <eparis@redhat.com>
2008-02-01docbook: rapidio: fix fatal filename errorRandy Dunlap
Fix docbook fatal error (files were renamed): docproc: linux-2.6.24-git9/arch/ppc/kernel/rio.c: No such file or directory Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31[XFRM]: Fix statistics.Masahide NAKAMURA
o Outbound sequence number overflow error status is counted as XfrmOutStateSeqError. o Additionaly, it changes inbound sequence number replay error name from XfrmInSeqOutOfWindow to XfrmInStateSeqError to apply name scheme above. o Inbound IPv4 UDP encapsuling type mismatch error is wrongly mapped to XfrmInStateInvalid then this patch fiex the error to XfrmInStateMismatch. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[IPV4] route cache: Introduce rt_genid for smooth cache invalidationEric Dumazet
Current ip route cache implementation is not suited to large caches. We can consume a lot of CPU when cache must be invalidated, since we currently need to evict all cache entries, and this eviction is sometimes asynchronous. min_delay & max_delay can somewhat control this asynchronism behavior, but whole thing is a kludge, regularly triggering infamous soft lockup messages. When entries are still in use, this also consumes a lot of ram, filling dst_garbage.list. A better scheme is to use a generation identifier on each entry, so that cache invalidation can be performed by changing the table identifier, without having to scan all entries. No more delayed flushing, no more stalling when secret_interval expires. Invalidated entries will then be freed at GC time (controled by ip_rt_gc_timeout or stress), or when an invalidated entry is found in a chain when an insert is done. Thus we keep a normal equilibrium. This patch : - renames rt_hash_rnd to rt_genid (and makes it an atomic_t) - Adds a new rt_genid field to 'struct rtable' (filling a hole on 64bit) - Checks entry->rt_genid at appropriate places :
2008-01-31[ALSA] hda-codec - Add Dell T3400 supportDouglas Kosovic
Added the support for Dell T3400 with AD1984 codec chip. ALSA bug#3699: https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3699 Signed-off-by: Douglas Kosovic <douglask@itee.uq.edu.au> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] hda-codec - Add Conexant 5051 codec supportTakashi Iwai
Added the support for Conexant 5051 audio codec. Right now there are two preset models, laptop and hp. The whole patch is based on the information from the base patch by Linuxant. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] add TempoTec HiFier driverClemens Ladisch
Add a driver for the MediaTek/TempoTec HiFier Fantasia sound card. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] ASoC documentation updatesMark Brown
Update the ASoC documentation. Along with minor formatting and grammar cleanups it moves the ASoC overview into the present tense to reflect the fact that it has now been merged. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] hda-codec - Fix laptop models for Cxt5045Marc Boucher
Change laptop models to three different models, laptop-hpsense, laptop-micsense and laptop-hpmicsense. The first two correspond to the old 'laptop' and 'fujitsu' models. Reassigned the quirk table for the new models. Signed-off-by: Marc Boucher <marc@linuxant.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] oxygen: TempoTec HiFier is probably not supportedClemens Ladisch
The TempoTec HiFier has a somwhat different architecture; remove it from the list of cards that are known to be supported. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] oxygen: update ALSA-Configuration.txtClemens Ladisch
Add documentation entries for snd-oxygen and snd-virtuoso. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] hda-codec - New model for conexant 5045 codec to support benq r55eJiang Zhe
The benq r55e laptop have 3 jacks on the front panel. One for HP, one for Line In and one for Mic In. This patch implemented a new model to support it. Signed-off-by: Jiang Zhe <zhe.jiang@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Add missing model for HD-audio Cx5045 codecTakashi Iwai
Added the description of the model fujitsu for Cx5045 codec chip. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] hda-codec - Add the support of Dell OEM laptops with ALC268Takashi Iwai
Added the support of Dell OEM laptops (Vostro 1200) with ALC268 codec. The new model=dell is provided. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] hda: Fix 5.1 sound in Dell 6stack ALC888 HDAClaudio Matsuoka
This patch fixes 5.1 surround output and headphone detection in the Dell Inspiron 530 and possibly other Dell systems using the ALC888 codec (mode 6stack-dell). Signed-off-by: Claudio Matsuoka <cmatsuoka@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] hda-codec - Update realtek codec supportKailang Yang
1. Support HP rp5700 2. Fixed alc_subsystem_id function (Bug fixed and support Desktop) 3. Support ASUS EP20 Signed-off-by: Kailang Yang <kailang@realtek.com.tw> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
