path: root/Documentation
2010-02-16Merge branch 'master' of ↵David S. Miller
2010-02-16CAPI: Schedule capifs for removalJan Kiszka
With dynamic TTY nodes and the help of udev, we no longer need this special filesystem. Schedule it for removal in one year from now. As a last duty to this feature, move its help to right option so that users can read the rationale. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-14Merge branch 'master' of ↵David S. Miller
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2010-02-12dccp: allow probing of CCID-array lengthGerrit Renker
This fixes a problem in the DCCP getsockopt() API: currently there is no way for a user to a priori know the number of built-in CCIDs, other than trying DCCP_SOCKOPT_AVAILABLE_CCIDS in a loop, incrementing the option length until EINVAL is no longer returned. This patch truncates the array to the user-provided length. No copy is made when the length is <= 0. Due to the length restriction in do_dccp_getsockopt() to sizeof(int), the minimum array length remains 4, which is a reasonable default (only 3 CCIDs, CCID-2..4, are currently defined). Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-08mac80211: remove get_tx_stats() driver opKalle Valo
get_tx_stats() driver operation is not currently used anywhere in mac80211 and there are no plans to use it in the not-so-near future. So it can go without anyone missing it. Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-08Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] Fix ondemand to not request targets outside policy limits [CPUFREQ] Fix use after free of struct powernow_k8_data [CPUFREQ] fix default value for ondemand governor
2010-02-07ima: rename PATH_CHECK to FILE_CHECKMimi Zohar
With the movement of the ima hooks functions were renamed from *path* to *file* since they always deal with struct file. This patch renames some of the ima internal flags to make them consistent with the rest of the code. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-05packet: Kill CONFIG_PACKET_MMAP.David S. Miller
Early on this was an experimental facility that few people other than Alexey Kuznetsov played with. Now it's a pretty fundamental thing and as people add more features to AF_PACKET sockets this config options creates ifdef spaghetti. So kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-04doc: document IPv6 parametersBrian Haley
Update documentation to describe IPv6 parameters. Reported by <greg@enjellic.com>. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-02fault injection: correct function names in documentationAnton Blanchard
init_fault_attr_entries() should be init_fault_attr_dentries(). cleanup_fault_attr_entries() should be cleanup_fault_attr_dentries(). Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-01Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing/documentation: Cover new frame pointer semantics tracing/documentation: Fix a typo in ftrace.txt ring-buffer: Check for end of page in iterator ring-buffer: Check if ring buffer iterator has stale data tracing: Prevent kernel oops with corrupted buffer
2010-01-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: update multi-touch protocol documentation Input: add the ABS_MT_PRESSURE event Input: winbond-cir - remove dmesg spam Input: lifebook - add another Lifebook DMI signature Input: ad7879 - support auxiliary GPIOs via gpiolib
2010-01-28Input: update multi-touch protocol documentationHenrik Rydberg
This patch documents a new ABS_MT parameter and adds further text to clarify some points around the MT protocol. Requested-by: Yoonyoung Shim <jy0922.shim@samsung.com> Requested-by: Mika Kuoppala <mika.kuoppala@nokia.com> Requested-by: Peter Hutterer <peter.hutterer@who-t.net> Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-01-26tracing/documentation: Cover new frame pointer semanticsMike Frysinger
Update the graph tracer examples to cover the new frame pointer semantics (in terms of passing it along). Move the HAVE_FUNCTION_GRAPH_FP_TEST docs out of the Kconfig, into the right place, and expand on the details. Signed-off-by: Mike Frysinger <vapier@gentoo.org> LKML-Reference: <1264165967-18938-1-git-send-email-vapier@gentoo.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-01-26tracing/documentation: Fix a typo in ftrace.txtYang Hongyang
'ftrace' is no longer the name of the function tracer, to activate the function trace 'echo function > current_tracer' is to be used instead of 'echo ftrace > current_tracer'. Update the documentation to reflect the current implementation. Signed-off-by: Yang Hongyang <yanghy@cn.fujitsu.com> LKML-Reference: <4B5D0BA8.20106@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-01-23Merge branch 'master' of ↵David S. Miller
2010-01-19Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-core.h
2010-01-19ipv4: allow warming up the ARP cache with request type gratuitous ARPOctavian Purdila
If the per device ARP_ACCEPT option is enable, currently we only allow creating new ARP cache entries for response type gratuitous ARP. Allowing gratuitous ARP to create new ARP entries (not only to update existing ones) is useful when we want to avoid unnecessary delays for the first packet of a stream. This patch allows request type gratuitous ARP to create new ARP cache entries as well. This is useful when we want to populate the ARP cache entries for a large number of hosts on the same LAN. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17feature-removal-schedule: Add v4l1 drivers obsoleted by gspca sub driversHans de Goede
This patch adds the ov511, quickcam_messenger, w9968cf, stv680 and ovcamchip v4l1 drivers to the feature removal schedule as the devices they support are now all also supported by v4l2 gspca sub drivers. This patch also adds the v4l2 vc0301 driver for removal as it duplicates functionality of the gspca_zc3xx driver, zc0301 only supports 2 USB-ID's (because it only supports a limited set of sensors) wich are also supported by the gspca_zc3xx driver (which supports 53 USB-ID's in total). [mchehab@redhat.com: change "when" to 2.6.35] Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-01-14mac80211: fix mac80211.h documentation warningsKalle Valo
There were some warnings about missing documentation and a missing reference. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-14proc_fops: convert drivers/isdn/ to seq_fileAlexey Dobriyan
Convert code away from ->read_proc/->write_proc interfaces. Switch to proc_create()/proc_create_data() which make addition of proc entries reliable wrt NULL ->proc_fops, NULL ->data and so on. Problem with ->read_proc et al is described here commit 786d7e1612f0b0adb6046f19b906609e4fe8b1ba "Fix rmmod/read/write races in /proc entries" [akpm@linux-foundation.org: CONFIG_PROC_FS=n build fix] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Karsten Keil <keil@b1-systems.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-13[CPUFREQ] fix default value for ondemand governorMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Dave Jones <davej@redhat.com>
2010-01-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (56 commits) sky2: Fix oops in sky2_xmit_frame() after TX timeout Documentation/3c509: document ethtool support af_packet: Don't use skb after dev_queue_xmit() vxge: use pci_dma_mapping_error to test return value netfilter: ebtables: enforce CAP_NET_ADMIN e1000e: fix and commonize code for setting the receive address registers e1000e: e1000e_enable_tx_pkt_filtering() returns wrong value e1000e: perform 10/100 adaptive IFS only on parts that support it e1000e: don't accumulate PHY statistics on PHY read failure e1000e: call pci_save_state() after pci_restore_state() netxen: update version to 4.0.72 netxen: fix set mac addr netxen: fix smatch warning netxen: fix tx ring memory leak tcp: update the netstamp_needed counter when cloning sockets TI DaVinci EMAC: Handle emac module clock correctly. dmfe/tulip: Let dmfe handle DM910x except for SPARC on-board chips ixgbe: Fix compiler warning about variable being used uninitialized netfilter: nf_ct_ftp: fix out of bounds read in update_nl_seq() mv643xx_eth: don't include cache padding in rx desc buffer size ... Fix trivial conflict in drivers/scsi/cxgb3i/cxgb3i_offload.c
2010-01-11Documentation/3c509: document ethtool supportBen Hutchings
3c509 was changed to support ethtool in 2002, making the 'xcvr' module parameter obsolete in most cases. More recently 3c509 was converted to the modern driver model and this parameter was removed. Fix the documentation to refer to ethtool rather than the module parameter. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-11Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: Make PCI device ids constant hwmon: (coretemp) Fix TjMax for Atom N450/D410/D510 CPUs hwmon: (k10temp) Blacklist more family 10h processors hwmon: (asus_atk0110) Add debugfs interface hwmon: (asus_atk0110) Refactor interface probe code hwmon: (adt7462) Fix pin 28 monitoring
2010-01-11documentation: update kernel-doc-nano-HOWTO informationRandy Dunlap
Remove comments about function short descriptions not allowed to be on multiple lines (that was fixed/changed recently). Add comments that function "section header:" names need to be unique per function/struct/union/typedef/enum. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11Documentation: update ring-buffer-design.txtRandy Dunlap
Fix typos, grammos, spellos, hyphenation. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11hwmon: driver for Texas Instruments amc6821 chipTomaz Mertelj
Signed-off-by: <tomaz.mertelj@guest.arnes.si> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11proc: partially revert "procfs: provide stack information for threads"KOSAKI Motohiro
Commit d899bf7b (procfs: provide stack information for threads) introduced to show stack information in /proc/{pid}/status. But it cause large performance regression. Unfortunately /proc/{pid}/status is used ps command too and ps is one of most important component. Because both to take mmap_sem and page table walk are heavily operation. If many process run, the ps performance is, [before d899bf7b] % perf stat ps >/dev/null Performance counter stats for 'ps': 4090.435806 task-clock-msecs # 0.032 CPUs 229 context-switches # 0.000 M/sec 0 CPU-migrations # 0.000 M/sec 234 page-faults # 0.000 M/sec 8587565207 cycles # 2099.425 M/sec 9866662403 instructions # 1.149 IPC 3789415411 cache-references # 926.409 M/sec 30419509 cache-misses # 7.437 M/sec 128.859521955 seconds time elapsed [after d899bf7b] % perf stat ps > /dev/null Performance counter stats for 'ps': 4305.081146 task-clock-msecs # 0.028 CPUs 480 context-switches # 0.000 M/sec 2 CPU-migrations # 0.000 M/sec 237 page-faults # 0.000 M/sec 9021211334 cycles # 2095.480 M/sec 10605887536 instructions # 1.176 IPC 3612650999 cache-references # 839.160 M/sec 23917502 cache-misses # 5.556 M/sec 152.277819582 seconds time elapsed Thus, this patch revert it. Fortunately /proc/{pid}/task/{tid}/smaps provide almost same information. we can use it. Commit d899bf7b introduced two features: 1) Add the annotattion of [thread stack: xxxx] mark to /proc/{pid}/task/{tid}/maps. 2) Add StackUsage field to /proc/{pid}/status. I only revert (2), because I haven't seen (1) cause regression. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Stefani Seibold <stefani@seibold.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11docs: large update to ioctl-number.txtRandy Dunlap
Add many ioctl definitions to ioctl-number.txt. Fix some whitespace/formatting. Correct some filenames/paths. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-10ixgbevf: Kconfig, Makefile and DocumentationGreg Rose
Modifications for the Kconfig and network device Makefile to add the ixgbevf driver module to the kernel plus basic driver documentation. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-10hwmon: (k10temp) Blacklist more family 10h processorsClemens Ladisch
The latest version of the Revision Guide for AMD Family 10h Processors lists two more processor revisions which may be affected by erratum 319. Change the blacklisting code to correctly detect those processors, by implementing AMD's recommended algorithm. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Andreas Herrmann <herrmann.der.user@googlemail.com>
2010-01-08powerpc/mpc5xxx: add OF platform binding doc for FSL MSCAN devicesWolfgang Grandegger
This patch adds documentation for the MSCAN OF device bindings for the MPC512x and moves the one for the MPC5200 to the new common file "Documentation/powerpc/dts-bindings/fsl/can.txt". Signed-off-by: Wolfgang Grandegger <wg@denx.de> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07net: RFC3069, private VLAN proxy arp supportJesper Dangaard Brouer
This is to be used together with switch technologies, like RFC3069, that where the individual ports are not allowed to communicate with each other, but they are allowed to talk to the upstream router. As described in RFC 3069, it is possible to allow these hosts to communicate through the upstream router by proxy_arp'ing. This patch basically allow proxy arp replies back to the same interface (from which the ARP request/solicitation was received). Tunable per device via proc "proxy_arp_pvlan": /proc/sys/net/ipv4/conf/*/proxy_arp_pvlan This switch technology is known by different vendor names: - In RFC 3069 it is called VLAN Aggregation. - Cisco and Allied Telesyn call it Private VLAN. - Hewlett-Packard call it Source-Port filtering or port-isolation. - Ericsson call it MAC-Forced Forwarding (RFC Draft). Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: nilfs2: update mailing list address nilfs2: Storage class should be before const qualifier nilfs2: trivial coding style fix
2010-01-02Documentation: Rename Documentation/DMA-mapping.txtKusanagi Kouichi
It seems that Documentation/DMA-mapping.txt was supposed to be renamed to Documentation/PCI/PCI-DMA-mapping.txt. Signed-off-by: Kusanagi Kouichi <slash@ac.auone-net.jp> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-02DocBook: fix ioremap return typeH Hartley Sweeten
ioremap() returns a void __iomem * not an unsigned long. Update the Documentation file to reflect this. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-02Documentation: fix ioremap return typeH Hartley Sweeten
ioremap() returns a void __iomem * not a char *. Update the documentation file to reflect this. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-02nilfs2: update mailing list addressRyusuke Konishi
This replaces the list address for nilfs discussion to linux-nilfs at vger.kernel.org from users at nilfs.org. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-12-31Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing: Fix sign fields in ftrace_define_fields_##call() tracing/syscalls: Fix typo in SYSCALL_DEFINE0 tracing/kprobe: Show sign of fields in trace_kprobe format files ksym_tracer: Remove trace_stat ksym_tracer: Fix race when incrementing count ksym_tracer: Fix to allow writing newline to ksym_trace_filter ksym_tracer: Fix to make the tracer work tracing: Kconfig spelling fixes and cleanups tracing: Fix setting tracer specific options Documentation: Update ftrace-design.txt Documentation: Update tracepoint-analysis.txt Documentation: Update mmiotrace.txt
2009-12-30Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI: introduce kernel parameter acpi_sleep=sci_force_enable ACPI: WMI: Survive BIOS with duplicate GUIDs dell-wmi - fix condition to abort driver loading wmi: check find_guid() return value to prevent oops dell-wmi, hp-wmi, msi-wmi: check wmi_get_event_data() return value ACPI: hp-wmi, msi-wmi: clarify that wmi_install_notify_handler() returns an acpi_status dell-wmi: sys_init_module: 'dell_wmi'->init suspiciously returned 21, it should ACPI video: correct error-handling code ACPI video: no warning message if "acpi_backlight=vendor" is used ACPI: fix ACPI=n allmodconfig build thinkpad-acpi: improve Kconfig help text thinkpad-acpi: update volume subdriver documentation thinkpad-acpi: make volume subdriver optional thinkpad-acpi: don't fail to load the entire module due to ALSA problems thinkpad-acpi: don't take the first ALSA slot by default
2009-12-30Merge branch 'resume-sci-force-bootparam' into releaseLen Brown
2009-12-30ACPI: introduce kernel parameter acpi_sleep=sci_force_enableZhang Rui
Introduce kernel parameter acpi_sleep=sci_force_enable some laptop requires SCI_EN being set directly on resume, or else they hung somewhere in the resume code path. We already have a blacklist for these laptops but we still need this option, especially when debugging some suspend/resume problems, in case there are systems that need this workaround and are not yet in the blacklist. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-30Merge branch 'master' of ↵David S. Miller
2009-12-30Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: Patch up how we claim metadata blocks for quota purposes ext4: Ensure zeroout blocks have no dirty metadata ext4: return correct wbc.nr_to_write in ext4_da_writepages ext4: Update documentation to correct the inode_readahead_blks option name jbd2: don't use __GFP_NOFAIL in journal_init_common() ext4: flush delalloc blocks when space is low fs-writeback: Add helper function to start writeback if idle ext4: Eliminate potential double free on error path ext4: fix unsigned long long printk warning in super.c ext4, jbd2: Add barriers for file systems with exernal journals ext4: replace BUG() with return -EIO in ext4_ext_get_blocks ext4: add module aliases for ext2 and ext3 ext4: Don't ask about supporting ext2/3 in ext4 if ext4 is not configured ext4: remove unused #include <linux/version.h>
2009-12-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI/cardbus: Add a fixup hook and fix powerpc PCI: change PCI nomenclature in drivers/pci/ (non-comment changes) PCI: change PCI nomenclature in drivers/pci/ (comment changes) PCI: fix section mismatch on update_res() PCI: add Intel 82599 Virtual Function specific reset method PCI: add Intel USB specific reset method PCI: support device-specific reset methods PCI: Handle case when no pci device can provide cache line size hint PCI/PM: Propagate wake-up enable for PCIe devices too vgaarbiter: fix a typo in the vgaarbiter Documentation
2009-12-30Merge branch 'kvm-updates/2.6.33' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.33' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: get rid of kvm_create_vm() unused label warning on s390 KVM: powerpc: Fix mtsrin in book3s_64 mmu KVM: ia64: fix build breakage due to host spinlock change KVM: x86: Extend KVM_SET_VCPU_EVENTS with selective updates KVM: LAPIC: make sure IRR bitmap is scanned after vm load KVM: Fix possible circular locking in kvm_vm_ioctl_assign_device() KVM: MMU: remove prefault from invlpg handler
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda - Fix Oops at reloading beep devices ALSA: hda - Don't cache beep controls ALSA: Fix a typo in Procfile.txt ALSA: sound/arm: Fix build failure caused by missing struct aaci definition ALSA: hda - use snd_hda_jack_detect() again in patch_sigmatel.c ALSA: hda - Disable tigger at pin-sensing on AD codecs ALSA: hda - HDMI sticky stream tag support ALSA: Fix indentation in pcm_native.c
2009-12-30Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: blk_rq_err_sectors cleanup block: Honor the gfp_mask for alloc_page() in blkdev_issue_discard() block: Fix incorrect alignment offset reporting and update documentation cfq-iosched: don't regard requests with long distance as close aoe: switch to the new bio_flush_dcache_pages() interface drivers/block/mg_disk.c: use resource_size() drivers/block/DAC960.c: use DAC960_V2_Controller block: Fix topology stacking for data and discard alignment drbd: remove unused #include <linux/version.h> drbd: remove duplicated #include drbd: Fix test of unsigned in _drbd_fault_random() drbd: Constify struct file_operations cfq-iosched: Remove prio_change logic for workload selection cfq-iosched: Get rid of nr_groups cfq-iosched: Remove the check for same cfq group from allow_merge drbd: fix test of unsigned in _drbd_fault_random() block: remove Documentation/block/as-iosched.txt
2009-12-28wireless: remove CONFIG_WIRELESS_OLD_REGULATORYJohn W. Linville
This is no longer needed with the availability of CONFIG_CFG80211_INTERNAL_REGDB. Signed-off-by: John W. Linville <linville@tuxdriver.com>
