Documentation/vm/transhuge.txt
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
We'd like to be able to oom_score_adj a process up/down as it
enters/leaves the foreground. Currently, it is not possible to oom_adj
down without CAP_SYS_RESOURCE. This patch allows a task to decrease its
oom_score_adj back to the value that a CAP_SYS_RESOURCE thread set it to
or its inherited value at fork. Assuming the thread that has forked it
has oom_score_adj of 0, each process could decrease it back from 0 upon
activation unless a CAP_SYS_RESOURCE thread elevated it to something
higher.
Alternative considered:
* a setuid binary
* a daemon with CAP_SYS_RESOURCE
Since you don't wan't all processes to be able to reduce their oom_adj, a
setuid or daemon implementation would be complex. The alternatives also
have much higher overhead.
This patch updated from original patch based on feedback from David
Rientjes.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Ying Han <yinghan@google.com>
Currently there is no way to find whether a process has locked its pages
in memory or not. And which of the memory regions are locked in memory.
Add a new field "Locked" to export this information via the smaps file.
Signed-off-by: Nikanth Karthikesan <knikanth@suse.de>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Acked-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Matt Mackall <mpm@selenic.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm: (32 commits)
dm: raid456 basic support
dm: per target unplug callback support
dm: introduce target callbacks and congestion callback
dm mpath: delay activate_path retry on SCSI_DH_RETRY
dm: remove superfluous irq disablement in dm_request_fn
dm log: use PTR_ERR value instead of ENOMEM
dm snapshot: avoid storing private suspended state
dm snapshot: persistent make metadata_wq multithreaded
dm: use non reentrant workqueues if equivalent
dm: convert workqueues to alloc_ordered
dm stripe: switch from local workqueue to system_wq
dm: dont use flush_scheduled_work
dm snapshot: remove unused dm_snapshot queued_bios_work
dm ioctl: suppress needless warning messages
dm crypt: add loop aes iv generator
dm crypt: add multi key capability
dm crypt: add post iv call to iv generator
dm crypt: use io thread for reads only if mempool exhausted
dm crypt: scale to multiple cpus
dm crypt: simplify compatible table output
This reverts commit 0fdae42d361bbb431ca0ab0efed5126a94821177, which
wasn't really supposed to go in, and causes lots of annoying warnings.
Quoth Andrew:
"Complete brainfart - I meant to drop that patch ages ago."
Quoth Greg:
"Ick, yeah, that patch isn't ok to go in as-is, all of the callers
need to be fixed up first, which is what I thought we had agreed on..."
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Acked-by: Greg KH <greg@kroah.com>
This patch is the skeleton for the DM target that will be
the bridge from DM to MD (initially RAID456 and later RAID1). It
provides a way to use device-mapper interfaces to the MD RAID456
drivers.
As with all device-mapper targets, the nominal public interfaces are the
constructor (CTR) tables and the status outputs (both STATUSTYPE_INFO
and STATUSTYPE_TABLE). The CTR table looks like the following:
1: <s> <l> raid \
2: <raid_type> <#raid_params> <raid_params> \
3: <#raid_devs> <meta_dev1> <dev1> .. <meta_devN> <devN>
Line 1 contains the standard first three arguments to any device-mapper
target - the start, length, and target type fields. The target type in
this case is "raid".
Line 2 contains the arguments that define the particular raid
type/personality/level, the required arguments for that raid type, and
any optional arguments. Possible raid types include: raid4, raid5_la,
raid5_ls, raid5_rs, raid6_zr, raid6_nr, and raid6_nc. (again, raid1 is
planned for the future.) The list of required and optional parameters
is the same for all the current raid types. The required parameters are
positional, while the optional parameters are given as key/value pairs.
The possible parameters are as follows:
<chunk_size> Chunk size in sectors.
[[no]sync] Force/Prevent RAID initialization
[rebuild <idx>] Rebuild the drive indicated by the index
[daemon_sleep <ms>] Time between bitmap daemon work to clear bits
[min_recovery_rate <kB/sec/disk>] Throttle RAID initialization
[max_recovery_rate <kB/sec/disk>] Throttle RAID initialization
[max_write_behind <value>] See '-write-behind=' (man mdadm)
[stripe_cache <sectors>] Stripe cache size for higher RAIDs
Line 3 contains the list of devices that compose the array in
metadata/data device pairs. If the metadata is stored separately, a '-'
is given for the metadata device position. If a drive has failed or is
missing at creation time, a '-' can be given for both the metadata and
data drives for a given position.
Examples:
# RAID4 - 4 data drives, 1 parity
# No metadata devices specified to hold superblock/bitmap info
# Chunk size of 1MiB
# (Lines separated for easy reading)
0 1960893648 raid \
raid4 1 2048 \
5 - 8:17 - 8:33 - 8:49 - 8:65 - 8:81
# RAID4 - 4 data drives, 1 parity (no metadata devices)
# Chunk size of 1MiB, force RAID initialization,
# min recovery rate at 20 kiB/sec/disk
0 1960893648 raid \
raid4 4 2048 min_recovery_rate 20 sync\
Performing a 'dmsetup table' should display the CTR table used to
construct the mapping (with possible reordering of optional
parameters).
Performing a 'dmsetup status' will yield information on the state and
health of the array. The output is as follows:
1: <s> <l> raid \
2: <raid_type> <#devices> <1 health char for each dev> <resync_ratio>
Line 1 is standard DM output. Line 2 is best shown by example:
0 1960893648 raid raid4 5 AAAAA 2/490221568
Here we can see the RAID type is raid4, there are 5 devices - all of
which are 'A'live, and the array is 2/490221568 complete with recovery.
Cc: linux-raid@vger.kernel.org
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
This patch adds generic multikey handling to be used
in following patch for Loop-AES mode compatibility.
This patch extends mapping table to optional keycount and
implements generic multi-key capability.
With more keys defined the <key> string is divided into
several <keycount> sections and these are used for tfms.
The tfm is used according to sector offset
(sector 0->tfm[0], sector 1->tfm[1], sector N->tfm[N modulo keycount])
(only power of two values supported for keycount here).
Because of tfms per-cpu allocation, this mode can be take
a lot of memory on large smp systems.
Signed-off-by: Milan Broz <mbroz@redhat.com>
Cc: Max Vozeler <max@hinterhof.net>
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits)
block: ensure that completion error gets properly traced
blktrace: add missing probe argument to block_bio_complete
block cfq: don't use atomic_t for cfq_group
block cfq: don't use atomic_t for cfq_queue
block: trace event block fix unassigned field
block: add internal hd part table references
block: fix accounting bug on cross partition merges
kref: add kref_test_and_get
bio-integrity: mark kintegrityd_wq highpri and CPU intensive
block: make kblockd_workqueue smarter
Revert "sd: implement sd_check_events()"
block: Clean up exit_io_context() source code.
Fix compile warnings due to missing removal of a 'ret' variable
fs/block: type signature of major_to_index(int) to major_to_index(unsigned)
block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p)
cfq-iosched: don't check cfqg in choose_service_tree()
fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors
cdrom: export cdrom_check_events()
sr: implement sr_check_events()
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (348 commits)
ALSA: hda - Fix NULL-derefence with a single mic in STAC auto-mic detection
ALSA: hda - Add missing NID 0x19 fixup for Sony VAIO
ALSA: hda - Fix ALC275 enable hardware EQ for SONY VAIO
ALSA: oxygen: fix Xonar DG input
ALSA: hda - Fix EAPD on Lenovo NB ALC269 to low
ALSA: hda - Fix missing EAPD for Acer 4930G
ALSA: hda: Disable 4/6 channels on some NVIDIA GPUs.
ALSA: hda - Add static_hdmi_pcm option to HDMI codec parser
ALSA: hda - Don't refer ELD when unplugged
ASoC: tpa6130a2: Fix compiler warning
ASoC: tlv320dac33: Add DAPM selection for LOM invert
ASoC: DMIC codec: Adding a generic DMIC codec
ALSA: snd-usb-us122l: Fix missing NULL checks
ALSA: snd-usb-us122l: Fix MIDI output
ASoC: soc-cache: Fix invalid memory access during snd_soc_lzo_cache_sync()
ASoC: Fix section mismatch in wm8995.c
ALSA: oxygen: add S/PDIF source selection for Claro cards
ALSA: oxygen: fix CD/MIDI for X-Meridian (2G)
ASoC: fix migor audio build
ALSA: include delay.h for msleep in Xonar DG support
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (41 commits)
fs: add documentation on fallocate hole punching
Gfs2: fail if we try to use hole punch
Btrfs: fail if we try to use hole punch
Ext4: fail if we try to use hole punch
Ocfs2: handle hole punching via fallocate properly
XFS: handle hole punching via fallocate properly
fs: add hole punching to fallocate
vfs: pass struct file to do_truncate on O_TRUNC opens (try #2)
fix signedness mess in rw_verify_area() on 64bit architectures
fs: fix kernel-doc for dcache::prepend_path
fs: fix kernel-doc for dcache::d_validate
sanitize ecryptfs ->mount()
switch afs
move internal-only parts of ncpfs headers to fs/ncpfs
switch ncpfs
switch 9p
pass default dentry_operations to mount_pseudo()
switch hostfs
switch affs
switch configfs
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
hwmon: (dme1737) Minor cleanups
hwmon: (dme1737) Add support for in7 for SCH5127
hwmon: (emc1403) Add EMC1423 support
hwmon: (w83627hf) Document W83627THF voltage pin mapping
hwmon: (w83793) Drop useless mutex
hwmon: (fschmd) Drop useless mutex
hwmon: (w83781d) Use pr_fmt and pr_<level>
hwmon: (pc87427) Use pr_fmt and pr_<level>
hwmon: (pc87360) Use pr_fmt and pr_<level>
hwmon: (lm78) Use pr_fmt and pr_<level>
hwmon: (it87) Use pr_fmt and pr_<level>
hwmon: Schedule the removal of the old intrusion detection interfaces
hwmon: (w83793) Implement the standard intrusion detection interface
hwmon: (w83792d) Implement the standard intrusion detection interface
hwmon: (adm9240) Implement the standard intrusion detection interface
hwmon: (via686a) Initialize fan_div values
hwmon: (w83795) Silent false warning from gcc
hwmon: (ads7828) Update email contact details
* 'kvm-updates/2.6.38' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (142 commits)
KVM: Initialize fpu state in preemptible context
KVM: VMX: when entering real mode align segment base to 16 bytes
KVM: MMU: handle 'map_writable' in set_spte() function
KVM: MMU: audit: allow audit more guests at the same time
KVM: Fetch guest cr3 from hardware on demand
KVM: Replace reads of vcpu->arch.cr3 by an accessor
KVM: MMU: only write protect mappings at pagetable level
KVM: VMX: Correct asm constraint in vmcs_load()/vmcs_clear()
KVM: MMU: Initialize base_role for tdp mmus
KVM: VMX: Optimize atomic EFER load
KVM: VMX: Add definitions for more vm entry/exit control bits
KVM: SVM: copy instruction bytes from VMCB
KVM: SVM: implement enhanced INVLPG intercept
KVM: SVM: enhance mov DR intercept handler
KVM: SVM: enhance MOV CR intercept handler
KVM: SVM: add new SVM feature bit names
KVM: cleanup emulate_instruction
KVM: move complete_insn_gp() into x86.c
KVM: x86: fix CR8 handling
KVM guest: Fix kvm clock initialization when it's configured out
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: add SW_ROTATE_LOCK switch type
Input: fix force feedback capability query example
Input: wacom_w8001 - add single-touch support
Input: add Austria Microsystem AS5011 joystick driver
Input: remove aaed2000 keyboard driver
Input: i8042 - introduce 'notimeout' blacklist for Dell Vostro V13
Input: cy8ctmg110_ts - Convert to dev_pm_ops
Input: migor_ts - convert to dev_pm_ops
Input: mcs5000_ts - convert to dev_pm_ops
Input: eeti_ts - convert to dev_pm_ops
Input: ad7879 - convert I2C to dev_pm_ops
This integrates the XZ decompression code to the x86 pre-boot code.
mkpiggy.c is updated to reserve about 32 KiB more buffer safety margin for
kernel decompression. It is done unconditionally for all decompressors to
keep the code simpler.
The XZ decompressor needs around 30 KiB of heap, so the heap size is
increased to 32 KiB on both x86-32 and x86-64.
Documentation/x86/boot.txt is updated to list the XZ magic number.
With the x86 BCJ filter in XZ, XZ-compressed x86 kernel tends to be a few
percent smaller than the equivalent LZMA-compressed kernel.
Signed-off-by: Lasse Collin <lasse.collin@tukaani.org>
Cc: Alain Knaff <alain@knaff.lu>
Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Cc: Phillip Lougher <phillip@lougher.demon.co.uk>
In userspace, the .lzma format has become mostly a legacy file format that
got superseded by the .xz format. Similarly, LZMA Utils was superseded by
XZ Utils.
These patches add support for XZ decompression into the kernel. Most of
the code is as is from XZ Embedded <http://tukaani.org/xz/embedded.html>.
It was written for the Linux kernel but is usable in other projects too.
Advantages of XZ over the current LZMA code in the kernel:
- Nice API that can be used by other kernel modules; it's
not limited to kernel, initramfs, and initrd decompression.
- Integrity check support (CRC32)
- BCJ filters improve compression of executable code on
certain architectures. These together with LZMA2 can
produce a few percent smaller kernel or Squashfs images
than plain LZMA without making the decompression slower.
This patch: Add the main decompression code (xz_dec), testing module
(xz_dec_test), wrapper script (xz_wrap.sh) for the xz command line tool,
and documentation. The xz_dec module is enough to have a usable XZ
decompressor e.g. for Squashfs.
This is a 1-wire/w1 DS2423 slave driver for reading the values from all 4
counters available DS2423 devices by using standard w1_slave file. In
ds2423 the counters are tied to ram pages 12-15 in and each of those
ram-pages. Each of these counter values (and asoociated ram page values)
are represented as a own line in w1_slave file. Driver has been tested on
mips and x86.
usage example:
cat /sys/bus/w1/devices/1d-00000009b964/w1_slave
00 02 00 00 00 00 00 00 00 6d 38 00 ff ff 00 00 fe ff 00 00 ff ff 00 00 ff
ff 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff ff crc=YES c=2
00 02 00 00 00 00 00 00 00 e0 1f 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff
00 5a 0e 5f 18 00 00 00 00 0b 28 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff
ff 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 ff ff crc=YES c=408882778
00 05 00 00 00 00 00 00 00 8d 39 ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff crc=YES c=5
Patch includes also the documentation.
[randy.dunlap@oracle.com: fix ds2423 build, needs to select CRC16]
Signed-off-by: Mika Laitio <lamikr@pilppa.org>
Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
Add PPS signal generator which utilizes STROBE pin of a parallel port to
send PPS signals. It uses parport abstraction layer and hrtimers to
precisely control the signal.
[akpm@linux-foundation.org: fix build]
Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su>
Acked-by: Rodolfo Giometti <giometti@linux.it>
Cc: john stultz <johnstul@us.ibm.com>
Add an optional feature of PPSAPI, kernel consumer support, which uses the
added hardpps() function.
Remove the code that gatheres timestamp in pps_tty_dcd_change() in case
passed ts parameter is NULL because it never happens in the current code.
Fix comments as well.
Creates a new "Near Field Communication" subsystem in drivers/nfc.
http://en.wikipedia.org/wiki/Near_Field_Communication is useful ;)
This is a driver for the pn544 NFC device. The driver transfers
ETSI messages between the device and the user space.
Signed-off-by: Matti J. Aaltonen <matti.j.aaltonen@nokia.com>
ctl_unnumbered.txt have been removed in Documentation directory so just
also remove this invalid comments
[akpm@linux-foundation.org: fix Documentation/sysctl/00-INDEX, per Dave]
Signed-off-by: Jovi Zhang <bookjovi@gmail.com>
Cc: Dave Young <hidave.darkstar@gmail.com>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
The 'ns' cgroup is considered deprecated. Change the cgroup subsystem
used in the examples of the cgroup documentation from 'ns' to 'blkio'.
Signed-off-by: Trevor Woerner <twoerner@gmail.com>
Acked-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Paul Menage <menage@google.com>
Show how to install the "toggle wordwrap" extension in thunderbird.
Signed-off-by: Rob Landley <rlandley@parallels.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Because GPIOs can have crucial functions especially in embedded systems,
we are better safe than sorry regarding their configuration. For
gpio_request, the documentation is simply enforced: <quote>"The return
value of gpio_request() must be checked."</quote> For gpio_direction_* and
gpio_request_*, we now act accordingly.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Greg KH <gregkh@suse.de>
The newer drivers/gpio/cs5535-gpio.c replaces drivers/misc/cs5535_gpio.c.
The new driver has been in the tree for a little while, and has received
some testing; it's time to mark the old one as deprecated. I'm thinking
removal around 2.6.40 would be good, provided we're not missing critical
functionality in the newer driver.
Signed-off-by: Andres Salomon <dilinger@queued.net>
Cc: Daniel Drake <dsd@laptop.org>
Acked-by: Ben Gardner <bgardner@wabtec.com>
Cc: Greg KH <greg@kroah.com>
Add the %pK printk format specifier and the /proc/sys/kernel/kptr_restrict
sysctl.
The %pK format specifier is designed to hide exposed kernel pointers,
specifically via /proc interfaces. Exposing these pointers provides an
easy target for kernel write vulnerabilities, since they reveal the
locations of writable structures containing easily triggerable function
pointers. The behavior of %pK depends on the kptr_restrict sysctl.
If kptr_restrict is set to 0, no deviation from the standard %p behavior
occurs. If kptr_restrict is set to 1, the default, if the current user
(intended to be a reader via seq_printf(), etc.) does not have CAP_SYSLOG
(currently in the LSM tree), kernel pointers using %pK are printed as 0's.
If kptr_restrict is set to 2, kernel pointers using %pK are printed as
0's regardless of privileges. Replacing with 0's was chosen over the
default "(null)", which cannot be parsed by userland %p, which expects
"(nil)".
[akpm@linux-foundation.org: check for IRQ context when !kptr_restrict, save an indent level, s/WARN/WARN_ONCE/]
[akpm@linux-foundation.org: coding-style fixup]
[randy.dunlap@oracle.com: fix kernel/sysctl.c warning]
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Cc: Thomas Graf <tgraf@infradead.org>
Cc: Eugene Teo <eugeneteo@kernel.org>
Cc: Kees Cook <kees.cook@canonical.com>
Cc: Eric Paris <eparis@parisplace.org>
Extend the LED backlight tirgger driver with an option that allows for
inverting the trigger output polarity.
With the invertion option provided, I (ab)use the backlight trigger for
driving a LED that indicates LCD display blank condtition on my Amstrad
Delta videophone. Since the machine has no dedicated power LED, it was
not possible to distinguish if the display was blanked, or the machine was
turned off, without touching it.
The invert sysfs control is patterned after a similiar function of the GPIO
trigger driver.
[akpm@linux-foundation.org: make output match input, tighten input checking]
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org>
This patch simply adds documentation on how to handle the hole punching mode of
fallocate for any filesystem wishing to use it.
Signed-off-by: Josef Bacik <josef@redhat.com>
Add support for the 1.5V voltage monitoring input (in7) of the
SMSC SCH5127 chip.
Signed-off-by: Juerg Haefliger <juergh@gmail.com>
I had to look it up for one user, so we might as well store it in the
driver documentation.
Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
We have a standard intrusion detection interface now, drivers should
implement it. I've left the old interface in place for the time being,
with a deprecation warning, it will be removed later.
Trivial patch updating my email contact details due to change of
employer, and because I no longer have access to the previously used
domain.
Unfortunately I also no longer have access to any ads7828 hardware, but
am happy to support/maintain the driver if others are able to test
changes.
Signed-off-by: Steve Hardy <shardy@redhat.com>
Fix writev() to not keep writing the first segment over and over again
instead of moving onto subsequent segments and update the NTFS entry in
MAINTAINERS to reflect that Tuxera Inc. now supports the NTFS driver.
Signed-off-by: Anton Altaparmakov <anton@tuxera.com>
Adds API documentation for KVM_[DE]ASSIGN_PCI_DEVICE,
KVM_[DE]ASSIGN_DEV_IRQ, KVM_SET_GSI_ROUTING, KVM_ASSIGN_SET_MSIX_NR, and
KVM_ASSIGN_SET_MSIX_ENTRY.
Acked-by: Alex Williamson <alex.williamson@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
context.
If guest can detect that it runs in non-preemptable context it can
handle async PFs at any time, so let host know that it can send async
PF even if guest cpu is not in userspace.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
Enable async PF in a guest if async PF capability is discovered.
Guest enables async PF vcpu functionality using this MSR.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (67 commits)
cxgb4vf: recover from failure in cxgb4vf_open()
netfilter: ebtables: make broute table work again
netfilter: fix race in conntrack between dump_table and destroy
ah: reload pointers to skb data after calling skb_cow_data()
ah: update maximum truncated ICV length
xfrm: check trunc_len in XFRMA_ALG_AUTH_TRUNC
ehea: Increase the skb array usage
net/fec: remove config FEC2 as it's used nowhere
pcnet_cs: add new_id
tcp: disallow bind() to reuse addr/port
net/r8169: Update the function of parsing firmware
net: ppp: use {get,put}_unaligned_be{16,32}
CAIF: Fix IPv6 support in receive path for GPRS/3G
arp: allow to invalidate specific ARP entries
net_sched: factorize qdisc stats handling
mlx4: Call alloc_etherdev to allocate RX and TX queues
net: Add alloc_netdev_mqs function
caif: don't set connection request param size before copying data
cxgb4vf: fix mailbox data/control coherency domain race
qlcnic: change module parameter permissions
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (72 commits)
powerpc/pseries: Fix build of topology stuff without CONFIG_NUMA
powerpc/pseries: Fix VPHN build errors on non-SMP systems
powerpc/83xx: add mpc8308_p1m DMA controller device-tree node
powerpc/83xx: add DMA controller to mpc8308 device-tree node
powerpc/512x: try to free dma descriptors in case of allocation failure
powerpc/512x: add MPC8308 dma support
powerpc/512x: fix the hanged dma transfer issue
powerpc/512x: scatter/gather dma fix
powerpc/powermac: Make auto-loading of therm_pm72 possible
of/address: Use propper endianess in get_flags
powerpc/pci: Use printf extension %pR for struct resource
powerpc: Remove unnecessary casts of void ptr
powerpc: Disable VPHN polling during a suspend operation
powerpc/pseries: Poll VPA for topology changes and update NUMA maps
powerpc: iommu: Add device name to iommu error printks
powerpc: Record vma->phys_addr in ioremap()
powerpc: Update compat_arch_ptrace
powerpc: Fix PPC_PTRACE_SETHWDEBUG on PPC_BOOK3S
powerpc/time: printk time stamp init not correct
powerpc: Minor cleanups for machdep.h
'features' is a bit array, not byte array
Signed-off-by: Alexander Stein <alexander.stein@informatik.tu-chemnitz.de>
Acked-by: Anssi Hannula <anssi.hannula@iki.fi>
* 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
i2c: Constify i2c_client where possible
i2c-algo-bit: Complain about masters which can't read SCL
i2c-algo-bit: Refactor adapter registration
i2c: Add generic I2C multiplexer using GPIO API
i2c-nforce2: Remove unnecessary cast of pci_get_drvdata
i2c-i801: Include <linux/slab.h>
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86: (36 commits)
sony-laptop: support new hotkeys on the P, Z and EC series
platform/x86: Consistently select LEDS Kconfig options
sony-laptop: fix sparse non-ANSI function warning
intel_ips: fix sparse non-ANSI function warning
Support KHLB2 in the compal laptop driver
acer-wmi: Enabled Acer Launch Manager mode
[PATCH] intel_pmic_gpio: modify EOI handling following change of kernel irq subsystem
ACPI Thinkpad: We must always call va_end() after va_start() but do not do so in thinkpad_acpi.c::acpi_evalf()
acer-wmi: Initialize wlan/bluetooth/wwan rfkill software block state
acer-wmi: Detect the WiFi/Bluetooth/3G devices available
acer-wmi: Add 3G rfkill sysfs file
acer-wmi: Add acer wmi hotkey events support
platform/x86: Kconfig: Replace select by depends on ACPI_WMI
ideapad: pass ideapad_priv as argument (part 2)
ideapad: pass ideapad_priv as argument (part 1)
ideapad: add markups, unify comments and return result when init
ideapad: add hotkey support
ideapad: let camera power control entry under platform driver
ideapad: add platform driver for ideapad
fujitsu-laptop: fix compiler warning on pnp_ids
