path: root/Documentation
2008-01-28Merge branch 'pxa-plat' into develRussell King
* pxa-plat: (53 commits) [ARM] 4762/1: Basic support for Toradex Colibri module [ARM] pxa: fix mci_init functions returning -1 [ARM] 4737/1: Refactor corgi_lcd to improve readability + bugfix [ARM] 4747/1: pcm027: support for pcm990 baseboard for phyCORE-PXA270 [ARM] 4746/1: pcm027: network support for phyCORE-PXA270 [ARM] 4745/1: pcm027: default configuration [ARM] 4744/1: pcm027: add support for phyCORE-PXA270 CPU module [NET] smc91x: Make smc91x use IRQ resource trigger flags [ARM] pxa: add default config for littleton [ARM] pxa: add basic support for Littleton (PXA3xx Form Factor Platform) [ARM] 4664/1: Add basic support for HTC Magician PDA phones [ARM] 4649/1: Base support for pxa-based Toshiba e-series PDAs. [ARM] pxa: skip registers saving/restoring if entering standby mode [ARM] pxa: fix PXA27x resume [ARM] pxa: Avoid fiddling with CKEN register on suspend [ARM] pxa: Add PXA3 standby code hooked into the IRQ wake scheme [ARM] pxa: Add zylonite MFP wakeup configurations [ARM] pxa: program MFPs for low power mode when suspending [ARM] pxa: make MFP configuration processor independent [ARM] pxa: remove un-used pxa3xx_mfp_set_xxx() functions ... Conflicts: arch/arm/mach-pxa/ssp.c Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28Merge branches 'at91', 'ep93xx', 'iop', 'kprobes', 'ks8695', 'misc', 'msm', ↵Russell King
's3c2410', 'sa1100' and 'vfp' into devel * at91: (24 commits) [ARM] 4615/4: sam926[13]ek buttons updated [ARM] 4765/1: [AT91] AT91CAP9A-DK board support [ARM] 4764/1: [AT91] AT91CAP9 core support [ARM] 4738/1: at91sam9261: Remove udc pullup enabling in board initialisation [ARM] 4761/1: [AT91] Board-support for NEW_LEDs [ARM] 4760/1: [AT91] SPI CS0 errata on AT91RM9200 [ARM] 4759/1: [AT91] Buttons on CSB300 [ARM] 4758/1: [AT91] LEDs [ARM] 4757/1: [AT91] UART initialization [ARM] 4756/1: [AT91] Makefile cleanup [ARM] 4755/1: [AT91] NAND update [ARM] 4754/1: [AT91] SSC library support [ARM] 4753/1: [AT91] Use DMA_BIT_MASK [ARM] 4752/1: [AT91] RTT, RTC and WDT peripherals on SAM9 [ARM] 4751/1: [AT91] ISI peripheral on SAM9263 [ARM] 4750/1: [AT91] STN LCD displays on SAM9261 [ARM] 4734/1: at91sam9263ek: include IRQ for Ethernet PHY [ARM] 4646/1: AT91: configurable HZ, default to 128 [ARM] 4688/1: at91: speed-up irq processing [ARM] 4657/1: AT91: Header definition update ... * ep93xx: [ARM] 4671/1: ep93xx: remove obsolete gpio_line_* operations [ARM] 4670/1: ep93xx: implement IRQT_BOTHEDGE gpio irq sense type [ARM] 4669/1: ep93xx: simplify GPIO code and cleanups [ARM] 4668/1: ep93xx: implement new GPIO API * iop: [ARM] 4770/1: GLAN Tank: correct physmap_flash_data width field [ARM] 4732/1: GLAN Tank: register rtc-rs5c372 i2c device [ARM] 4708/1: iop: update defconfigs for 2.6.24 * kprobes: ARM kprobes: let's enable it ARM kprobes: special hook for the kprobes breakpoint handler ARM kprobes: prevent some functions involved with kprobes from being probed ARM kprobes: don't let a single-stepped stmdb corrupt the exception stack ARM kprobes: add the kprobes hook to the page fault handler ARM kprobes: core code ARM kprobes: instruction single-stepping support * ks8695: [ARM] 4603/1: KS8695: debugfs interface to view pin state [ARM] 4601/1: KS8695: PCI support * misc: [ARM] remove duplicate includes [ARM] CONFIG_DEBUG_STACK_USAGE [ARM] 4689/1: small comment wrap fix [ARM] 4687/1: Trivial arch/arm/kernel/entry-common.S comment fix [ARM] 4666/1: ixp4xx: fix sparse warnings in include/asm-arm/arch-ixp4xx/io.h [ARM] remove reference to non-existent MTD_OBSOLETE_CHIPS [SERIAL] 21285: Report baud rate back via termios [ARM] Remove pointless casts from void pointers, [ARM] Misc minor interrupt handler cleanups [ARM] Remove at91_lcdc.h [ARM] ARRAY_SIZE() cleanup [ARM] Update mach-types * msm: [ARM] msm: dma support for MSM7X00A [ARM] msm: board file for MACH_HALIBUT (QCT MSM7200A) [ARM] msm: irq and timer support for ARCH_MSM7X00A [ARM] msm: core platform support for ARCH_MSM7X00A * s3c2410: (33 commits) [ARM] 4795/1: S3C244X: Add armclk and setparent call [ARM] 4794/1: S3C24XX: Comonise S3C2440 and S3C2442 clock code [ARM] 4793/1: S3C24XX: Add IRQ->GPIO pin mapping function [ARM] 4792/1: S3C24XX: Remove warnings from debug-macro.S [ARM] 4791/1: S3C2412: Make fclk a parent of msysclk [ARM] 4790/1: S3C2412: Fix parent selection for msysclk. [ARM] 4789/1: S3C2412: Add missing CLKDIVN register values [ARM] 4788/1: S3C24XX: Fix paramet to s3c2410_dma_ctrl if S3C2410_DMAF_AUTOSTART used. [ARM] 4787/1: S3C24XX: s3c2410_dma_request() should return the allocated channel number [ARM] 4786/1: S3C2412: Add SPI FIFO controll constants [ARM] 4785/1: S3C24XX: Add _SHIFT definitions for S3C2410_BANKCON registers [ARM] 4784/1: S3C24XX: Fix GPIO restore glitches [ARM] 4783/1: S3C24XX: Add s3c2410_gpio_getpull() [ARM] 4782/1: S3C24XX: Define FIQ_START for any FIQ users [ARM] 4781/1: S3C24XX: DMA suspend and resume support [ARM] 4780/1: S3C2412: Allow for seperate DMA channels for TX and RX [ARM] 4779/1: S3C2412: Add s3c2412_gpio_set_sleepcfg() call [ARM] 4778/1: S3C2412: Add armclk and init from DVS state [ARM] 4777/1: S3C24XX: Ensure clk_set_rate() checks the set_rate method for the clk [ARM] 4775/1: s3c2410: fix compilation error if only s3c2442 cpu is selected ... * sa1100: [ARM] sa1100: add clock source support * vfp: [ARM] 4584/2: ARMv7: Add Advanced SIMD (NEON) extension support [ARM] 4583/1: ARMv7: Add VFPv3 support [ARM] 4582/2: Add support for the common VFP subarchitecture
2008-01-27i2c-viapro: Add support for the VT8237SJean Delvare
Add support for another variant of the VT8237. I couldn't test I2C block support but I assume it is present as well. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c-i801: Implement I2C block read supportJean Delvare
I2C block read is supported since the ICH5. I couldn't get it to work using the block buffer, so it's using the old-style byte-by-byte mode for now. Note: I'm also updating the driver author... The i2c-i801 driver was really written by Mark Studebaker, even though he based his work on the i2c-piix4 driver which was written by Philip Edelbrock. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c: Drop redundant i2c_adapter.listJean Delvare
i2c_adapter.list is superfluous, this list duplicates the one maintained by the driver core. Drop it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net>
2008-01-27i2c: Deprecate drivers for I2C buses on video adaptersJean Delvare
The framebuffer drivers for these pieces of hardware include support for the DDC/I2C buses, so there is no need for separate drivers. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c: normal_i2c can be made const (remaining drivers)Jean Delvare
2008-01-27i2c: some overdue driver removalAdrian Bunk
This patch contains the overdue removal of three I2C drivers. [JD: In fact only i2c-ixp4xx can be removed at the moment, the other two platforms don't implement the generic GPIO layer yet.] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c: the scheduled I2C RTC driver removalAdrian Bunk
This patch contains the scheduled removal of legacy I2C RTC drivers with replacement drivers. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c-stub: Use a single array for byte and word operationsJean Delvare
This mimics the behavior of actual SMBus chips better. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Mark M. Hoffman <mhoffman@lightlink.com>
2008-01-27i2c-stub: Mention the existence of an helper scriptJean Delvare
There's a new script named i2c-stub-from-dump that can be very helpful when working with the i2c-stub driver. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c: Add support for the PCF8575 chipBart Van Assche
Signed-off-by: Bart Van Assche <bart.vanassche@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (63 commits) ide: remove REQ_TYPE_ATA_CMD ide: switch ide_cmd_ioctl() to use REQ_TYPE_ATA_TASKFILE requests ide: switch set_xfer_rate() to use REQ_TYPE_ATA_TASKFILE requests ide: fix final status check in drive_cmd_intr() ide: check BUSY and ERROR status bits before reading data in drive_cmd_intr() ide: don't enable local IRQs for PIO-in in driver_cmd_intr() (take 2) ide: convert "empty" REQ_TYPE_ATA_CMD requests to use REQ_TYPE_ATA_TASKFILE ide: initialize rq->cmd_type in ide_init_drive_cmd() callers ide: use wait_drive_not_busy() in drive_cmd_intr() (take 2) ide: kill DATA_READY define ide: task_end_request() fix ide: use rq->nr_sectors in task_end_request() ide: remove needless ->cursg clearing from task_end_request() ide: set IDE_TFLAG_IN_* flags before queuing/executing command ide-tape: fix handling of non-special requests in ->end_request method ide: fix final status check in task_in_intr() ide: clear HOB bit for REQ_TYPE_ATA_CMD requests in ide_end_drive_cmd() ide: fix ->io_32bit race in ide_taskfile_ioctl() cmd64x: remove /proc/ide/cmd64x ide: remove broken disk byte-swapping support ...
2008-01-26ide: remove broken disk byte-swapping supportBartlomiej Zolnierkiewicz
Remove broken disk byte-swapping support: - it can cause a data corruption on SMP (or if using PREEMPT on UP) - all data coming from disk are byte-swapped by taskfile_*_data() which results in incorrect identify data being reported by /proc/ide/ and IOCTLs - "hdx=bswap/byteswap" kernel parameter has been broken on m68k host drivers (including Atari/Q40 ones) since 2.5.x days (because of 'hwif' zero-ing) - byte-swapping is limited to PIO transfers (for working with TiVo disks on x86 machines using user-space solutions or dm-byteswap should result in much better performance because DMA can be used) For previous discussions please see: http://www.ussg.iu.edu/hypermail/linux/kernel/0201.0/0768.html http://lkml.org/lkml/2004/2/28/111 [ I have dm-byteswap device mapper target if somebody is interested (patch is for 2.6.4 though but I'll dust it off if needed). ] Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: make remaining built-in only IDE host drivers modular (take 2)Bartlomiej Zolnierkiewicz
* Make remaining built-in only IDE host drivers modular, add ide-scan-pci.c file for probing PCI host drivers registered with IDE core (special case for built-in IDE and CONFIG_IDEPCI_PCIBUS_ORDER=y) and then take care of the ordering in which all IDE host drivers are probed when IDE is built-in during link time. * Move probing of gayle, falconide, macide, q40ide and buddha (m68k arch specific) host drivers, before PCI ones (no PCI on m68k), ide-cris (cris arch specific), cmd640 (x86 arch specific) and pmac (ppc arch specific). * Move probing of ide-cris (cris arch specific) host driver before cmd640 (x86 arch specific). * Move probing of mpc8xx (ppc specific) host driver before ide-pnp (depends on ISA and none of ppc platform that use mpc8xx supports ISA) and ide-h8300 (h8300 arch specific). * Add "probe_vlb" kernel parameter to cmd640 host driver and update Documentation/ide.txt accordingly. * Make IDE_ARM config option visible so it can also be disabled if needed. * Remove bogus comment from ide.c while at it. v2: * Fix two issues spotted by Sergei: - replace ENOMEM error value by ENOENT in ide-h8300 host driver - fix MODULE_PARM_DESC() in cmd640 host driver Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ARM kprobes: let's enable itNicolas Pitre
Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-01-26[ARM] pxa: add cpufreq supportRussell King
There have been patches hanging around for ages to add support for cpufreq to PXA255 processors. It's about time we applied one. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[S390] Get rid of additional_cpus kernel parameter.Heiko Carstens
It caused only a lot of confusion. From now on cpu hotplug of up to NR_CPUS will work by default. If somebody wants to limit that then the possible_cpus parameter can be used. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] cio: Extend adapter interrupt interface.Peter Oberparleiter
From: Cornelia Huck <cornelia.huck@de.ibm.com> Change the adapter interrupt interface in order to allow multiple adapter interrupt handlers to be registered. Indicators are now allocated by cio instead of the device driver. The qdio parts have been Acked-by: Ursula Braun <ubraun@linux.vnet.ibm.com> Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] cio: Dump ccw device information in case of timeout.Sebastian Ott
Information about a ccw device will be dumped in case of a ccw timeout. This can be enabled with the kernel parameter ccw_timeout_log. Signed-off-by: Sebastian Ott <sebott@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] Cleanup in Documentation/kernel-parameters.txt.Sebastian Ott
2008-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (200 commits) [SCSI] usbstorage: use last_sector_bug flag universally [SCSI] libsas: abstract STP task status into a function [SCSI] ultrastor: clean up inline asm warnings [SCSI] aic7xxx: fix firmware build [SCSI] aacraid: fib context lock for management ioctls [SCSI] ch: remove forward declarations [SCSI] ch: fix device minor number management bug [SCSI] ch: handle class_device_create failure properly [SCSI] NCR5380: fix section mismatch [SCSI] sg: fix /proc/scsi/sg/devices when no SCSI devices [SCSI] IB/iSER: add logical unit reset support [SCSI] don't use __GFP_DMA for sense buffers if not required [SCSI] use dynamically allocated sense buffer [SCSI] scsi.h: add macro for enclosure bit of inquiry data [SCSI] sd: add fix for devices with last sector access problems [SCSI] fix pcmcia compile problem [SCSI] aacraid: add Voodoo Lite class of cards. [SCSI] aacraid: add new driver features flags [SCSI] qla2xxx: Update version number to 8.02.00-k7. [SCSI] qla2xxx: Issue correct MBC_INITIALIZE_FIRMWARE command. ...
2008-01-25Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2: (31 commits) ocfs2: clean up bh null checks ocfs2: document access rules for blocked_lock_list configfs: file.c fix possible recursive locking configfs: dir.c fix possible recursive locking configfs: Remove EXPERIMENTAL ocfs2: bump version number ocfs2/dlm: Clear joining_node on hearbeat node down ocfs2: convert byte order of constant instead of variable ocfs2: Update default cluster timeouts ocfs2: printf fixes ocfs2: Use generic_file_llseek ocfs2: Safer read_inline_data() ocfs2: Silence false lockdep warnings [PATCH 2/2] ocfs2: cluster aware flock() [PATCH 1/2] ocfs2: add flock lock type ocfs2: Local alloc window size changeable via mount option ocfs2: Support commit= mount option ocfs2: Add missing permission checks [PATCH 2/2] ocfs2: Implement group add for online resize [PATCH 1/2] ocfs2: Add group extend for online resize ...
2008-01-25[PATCH 2/2] ocfs2: cluster aware flock()Mark Fasheh
Hook up ocfs2_flock(), using the new flock lock type in dlmglue.c. A new mount option, "localflocks" is added so that users can revert to old functionality as need be. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Local alloc window size changeable via mount optionSunil Mushran
Local alloc is a performance optimization in ocfs2 in which a node takes a window of bits from the global bitmap and then uses that for all small local allocations. This window size is fixed to 8MB currently. This patch allows users to specify the window size in MB including disabling it by passing in 0. If the number specified is too large, the fs will use the default value of 8MB. mount -o localalloc=X /dev/sdX /mntpoint Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Support commit= mount optionMark Fasheh
Mostly taken from ext3. This allows the user to set the jbd commit interval, in seconds. The default of 5 seconds stays the same, but now users can easily increase the commit interval. Typically, this would be increased in order to benefit performance at the expense of data-safety. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Reserve ioctl rangeTao Ma
We need to reserve at least two ioctls for online-resize. Reserve a small range of ioctls for Ocfs2 use in Documentation/ioctl-number.txt. This should give us enough room for future growth. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Documentation updateMark Fasheh
Remove 'readpages' from the list in ocfs2.txt. Instead of having two identical lists, I just removed the list in the OCFS2 section of fs/Kconfig and added a pointer to Documentation/filesystems/ocfs2.txt. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (81 commits) RDMA/cxgb3: Fix the T3A workaround checks IB/ipath: Remove unnecessary cast IPoIB: Constify seq_operations function pointer tables RDMA/cxgb3: Mark QP as privileged based on user capabilities RDMA/cxgb3: Fix page shift calculation in build_phys_page_list() RDMA/cxgb3: Flush the receive queue when closing IB/ipath: Trivial simplification of ipath_make_ud_req() IB/mthca: Update latest "native Arbel" firmware revision IPoIB: Remove redundant check of netif_queue_stopped() in xmit handler IB/ipath: Add mappings from HW register to PortInfo port physical state IB/ipath: Changes to support PIO bandwidth check on IBA7220 IB/ipath: Minor cleanup of unused fields and chip-specific errors IB/ipath: New sysfs entries to control 7220 features IB/ipath: Add new chip-specific functions to older chips, consistent init IB/ipath: Remove unused MDIO interface code IB/ehca: Prevent RDMA-related connection failures on some eHCA2 hardware IB/ehca: Add "port connection autodetect mode" IB/ehca: Define array to store SMI/GSI QPs IB/ehca: Remove CQ-QP-link before destroying QP in error path of create_qp() IB/iser: Add change_queue_depth method ...
2008-01-25IB/mthca: Remove MSI support as scheduledAdrian Bunk
Remove MSI support from the mthca driver, as scheduled. There is no reason to use MSI instead of MSI-X, since MSI-X performs better. No one has spoken up since MSI support was deprecated in commit f6be6fbe ("IB/mthca: Schedule MSI support for removal"), so apparently the MSI support is unused. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvbLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (509 commits) V4L/DVB (7078): radio: fix sf16fmi section mismatch V4L/DVB (7077): bt878: remove handcrafted PCI subsystem ID check V4L/DVB (7075): Make a local function static V4L/DVB (7074): DiB7000P: correct tuning problem for 7MHz channel V4L/DVB (7073): DiB7070: Reception quality improved V4L/DVB (7072): sets the MT2060 IF1 frequency according to EEPROM V4L/DVB (7071): DiB0700: Start streaming the right way V4L/DVB (7070): Fix some tuning problems V4L/DVB (7069): Support for myTV.t V4L/DVB (7068): Add support for WinTV Nova-T-CE driver V4L/DVB (7067): fix autoserach in the Hauppauge NOVA-T 500 V4L/DVB (7066): ASUS My Cinema U3000 Mini DVBT Tuner V4L/DVB (7065): Artec T14BR patches V4L/DVB (7063): xc5000: Fix OOPS caused by missing firmware V4L/DVB (7062): radio-si570x: Some fixes and new USB ID addition V4L/DVB (7061): radio-si470x: Some cleanups V4L/DVB (7060): em28xx: remove has_tuner V4L/DVB (7059): cx88: Ensure the tuner is reset correctly V4L/DVB (7058): IR corrections for the Pinnacle 800i V4L/DVB (7056): tuner: suppress obsolete tuner i2c address warning for XC5000 tuners ...
2008-01-25V4L/DVB (7077): bt878: remove handcrafted PCI subsystem ID checkAkinobu Mita
This patch moves the subsystem ID and subsystem vendor ID check from probing function to the PCI generic function by describing subsystem IDs in pci_device_id table. This enables to add new PCI IDs to a device driver pci_ids table at runtime by new_id file in sysfs pci driver tree. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (7043): New card supported(partially): Pinnacle 800iSteven Toth
From Zhang: This patch continues the support for the Pinnacle HD 800i. Patch committed as-is, cleanups to follow ... Steve Signed-off-by: Chaogui Zhang <czhang1974@gmail.com> Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (7042): xc5000: Tuner analog supportSteven Toth
From Zhang: This an updated patch that adds analog support for the xc5000 tuner driver. it was tested on a Pinnacle PCTV HD 800i card (patches to follow). Patch commited as-is, cleanup to follow ... Steve. Signed-off-by: Chaogui Zhang <czhang1974@gmail.com> Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (7020): Add USB ID for a newer variant of Hauppauge WinTV USB2Mauro Carvalho Chehab
Thanks to Jeroen Janssen <Jeroen.Janssen@vub.ac.be> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (7017): saa7134: add MSI TV@nywhere Plus with the older tda8275 tunerHermann Pitton
Thanks go to Mark Schultz for the initial contribution and to Dean Hilkewich for testing it again. Signed-off-by: Hermann Pitton <hermann-pitton@arcor.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6994): usbvision: add Pinnacle Studio PCTV USB (NTSC) FM V3Thierry MERLE
Add the "Pinnacle Studio PCTV USB (NTSC) FM" device. This is the third occurrence of the same device designation... Signed-off-by: Thierry MERLE <thierry.merle@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6993): Fix CARDLIST.saa7134Mauro Carvalho Chehab
2008-01-25V4L/DVB (6975): Add missing entry for Beholder BeholdTV 407Mauro Carvalho Chehab
Acked-by: Andrey J. Melnikov <temnota@kmv.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6973): Add Beholder TV 401/405/407/409/505/507/609/M6 supportAndrey J. Melnikoff (TEMHOTA)
This patch updates cardlist for Beholder TV tuners: old models (with GPIO ir) 401, 403, 405, 407, 409, 505, 507 and add support for 607, 609, M6 cards with new i2c-ir. Signed-off-by: Igor Kuznetsov <igk72@yandex.ru> Signed-off-by: Andrey J. Melnikov <temnota@kmv.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6938): Add a tool for extracting xc3028 version 2.7 firmwareMauro Carvalho Chehab
This tool allows the extraction of xc3028 v2.7 firmware from HVR 12x0 file. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6935): cx23885: add missing subsystem IDs for Hauppauge HVR1500 RetailMichael Krufky
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6932): cx23885: add missing subsystem ID for Hauppauge HVR1800 RetailMichael Krufky
2008-01-25V4L/DVB (6898): cx23885: add support for Hauppauge WinTV HVR-1500Michael Krufky
2008-01-25V4L/DVB (6885): Add support for the Hauppauge HVR1500QSteven Toth
The express card ATSC/QAM tuner. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (em28xx): Add support for Pinnacle Dazzle DVC 100Aurelien Jarno
The patch below adds the "Pinnacle Dazzle DVC 100" to the list of cards supported by the em28xx driver. As the configuration is the same as the DVC 90 one, it simply adds a new USB ID to the list of devices supported by the DVC 90 configuration. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6763): ivtv: add AVerMedia EZMaker PCI Deluxe supportHans Verkuil
Add support for the AVerMedia EZMaker PCI Deluxe and update the ivtv cardlist. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6665a): finish the VID_HARDWARE_* removalAdrian Bunk
This patch removes a few remainders of the VID_HARDWARE_* removal. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> 643d01fb38b6f376cced035549f4e193018776e7
2008-01-25V4L/DVB (6664): Add missing USB ID's at CARDLIST.em28xxMauro Carvalho Chehab
2008-01-25V4L/DVB (6619): Use MTS firmware for the HVR-900Aidan Thornton
The HVR-900 requires the MTS version of the xc3028 firmware in order to get any sound. The below patch selects this firmware variant on HVR-900 cards, as well as splitting the HVR-950 into its own entry (since I don't know if it uses the MTS variant and it will have to be split off eventually anyway). Signed-off-by: Aidan Thornton <makosoft@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
