path: root/Documentation
2012-05-17ARM: 7376/1: clkdev: Implement managed clk_get()Mark Brown
Allow clk API users to simplify their cleanup paths by providing a managed version of clk_get() and clk_put(). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cherry-picked from mainline a8a97db984bdc5e89d42e41891543d2daaf314cb Change-Id: Ib36c0c82063928937166b6014fca92025bc83878 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/102860 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Stephen Warren <swarren@nvidia.com>
2012-04-17ARM: tegra: add several other sysfs/debugfs paramsLiang Cheng
Bug 939292 Change-Id: Ib0c849418c6c426518948785082fcceb180f3d64 Reviewed-on: http://git-master/r/96250 Tested-by: Liang Cheng (SW) <licheng@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Antti Miettinen <amiettinen@nvidia.com> Reviewed-by: Mark Peters <mpeters@nvidia.com> Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-04-05lib: devres: add convenience function to remap a resourceWolfram Sang
Almost every platform_driver does the three steps get_resource, request_mem_region, ioremap. This does not only lead to a lot of code duplication, but also a huge number of similar error strings and inconsistent error codes on failure. So, introduce a helper function which simplifies remapping a resource and make it hard to do something wrong and add documentation for it. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> (cherry picked from mainline commit 72f8c0bfa0de64c68ee59f40eb9b2683bffffbb0) Change-Id: I600c5200104e234d42ca396e50853133b3ab4b1f Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/94533 Reviewed-by: Automatic_Commit_Validation_User
2012-02-15ARM: tegra: Document sysfs/debugfs/module paramsAntti P Miettinen
Bug 894311 Change-Id: I376a03adc2088a9b1b0b19168f72dbcb770e6ad2 Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com> Reviewed-on: http://git-master/r/83497 Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-02-01Merge remote-tracking branch 'origin/dev/k3.3-rc1-iommu' into ↵Rohan Somvanshi
android-tegra-nv-3.1 Change-Id: I9001bb291779f107bbcb593d48f9f0f734074d0e
2012-01-24Merge branch 'linux-3.1.y' into android-tegra-nv-3.1Varun Wadekar
Linux 3.1.10 Change-Id: I465d184c492e8041dd0cd90f2cb70fde17ba7118 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-23iommu/amd: Put IOMMUv2 capable devices in pt_domainJoerg Roedel
If the device starts to use IOMMUv2 features the dma handles need to stay valid. The only sane way to do this is to use a identity mapping for the device and not translate it by the iommu. This is implemented with this patch. Since this lifts the device-isolation there is also a new kernel parameter which allows to disable that feature. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2012-01-23iommu: Add option to group multi-function devicesAlex Williamson
The option iommu=group_mf indicates the that the iommu driver should expose all functions of a multi-function PCI device as the same iommu_device_group. This is useful for disallowing individual functions being exposed as independent devices to userspace as there are often hidden dependencies. Virtual functions are not affected by this option. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2012-01-23x86, x2apic: Enable the bios request for x2apic optoutSuresh Siddha
On the platforms which are x2apic and interrupt-remapping capable, Linux kernel is enabling x2apic even if the BIOS doesn't. This is to take advantage of the features that x2apic brings in. Some of the OEM platforms are running into issues because of this, as their bios is not x2apic aware. For example, this was resulting in interrupt migration issues on one of the platforms. Also if the BIOS SMI handling uses APIC interface to send SMI's, then the BIOS need to be aware of x2apic mode that OS has enabled. On some of these platforms, BIOS doesn't have a HW mechanism to turnoff the x2apic feature to prevent OS from enabling it. To resolve this mess, recent changes to the VT-d2 specification: http://download.intel.com/technology/computing/vptech/Intel(r)_VT_for_Direct_IO.pdf includes a mechanism that provides BIOS a way to request system software to opt out of enabling x2apic mode. Look at the x2apic optout flag in the DMAR tables before enabling the x2apic mode in the platform. Also print a warning that we have disabled x2apic based on the BIOS request. Kernel boot parameter "intremap=no_x2apic_optout" can be used to override the BIOS x2apic optout request. Signed-off-by: Youquan Song <youquan.song@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: yinghai@kernel.org Cc: joerg.roedel@amd.com Cc: tony.luck@intel.com Cc: dwmw2@infradead.org Link: http://lkml.kernel.org/r/20110824001456.171766616@sbsiddha-desk.sc.intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-01-18KVM: Device assignment permission checksAlex Williamson
(cherry picked from commit 3d27e23b17010c668db311140b17bbbb70c78fb9) Only allow KVM device assignment to attach to devices which: - Are not bridges - Have BAR resources (assume others are special devices) - The user has permissions to use Assigning a bridge is a configuration error, it's not supported, and typically doesn't result in the behavior the user is expecting anyway. Devices without BAR resources are typically chipset components that also don't have host drivers. We don't want users to hold such devices captive or cause system problems by fencing them off into an iommu domain. We determine "permission to use" by testing whether the user has access to the PCI sysfs resource files. By default a normal user will not have access to these files, so it provides a good indication that an administration agent has granted the user access to the device. [Yang Bai: add missing #include] [avi: fix comment style] Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Yang Bai <hamo.by@gmail.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-18KVM: Remove ability to assign a device without iommu supportAlex Williamson
(cherry picked from commit 423873736b78f549fbfa2f715f2e4de7e6c5e1e9) This option has no users and it exposes a security hole that we can allow devices to be assigned without iommu protection. Make KVM_DEV_ASSIGN_ENABLE_IOMMU a mandatory option. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-16Merge branch 'linux-3.1.y' into android-tegra-nv-3.1Varun Wadekar
Linux 3.1.9 Conflicts: Makefile Change-Id: I22227ab33ba7ddaba8e6fe049393c58a83d73648 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-12USB: update documentation for usbmonAlan Stern
commit d8cae98cddd286e38db1724dda1b0e7b467f9237 upstream. The documentation for usbmon is out of date; the usbfs "devices" file now exists in /sys/kernel/debug/usb rather than /proc/bus/usb. This patch (as1505) updates the documentation accordingly, and also mentions that the necessary information can be found by running lsusb. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12Documentation: Update stable addressJoe Perches
commit 2eb7f204db51969ea558802a6601d79c2fb273b9 upstream. The Japanese/Korean/Chinese versions still need updating. Also, the stable kernel 2.6.x.y descriptions are out of date and should be updated as well. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06Revert "dm crypt: add multi key capability"Kasoju Mallikarjun
This reverts commit d1f9642381847e2b94caa34c3533211cf36ffcf4. Change-Id: If1879b331c1f0e3dea7433c5de53ac653743d9c2 Reviewed-on: http://git-master/r/72234 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Mallikarjun Kasoju <mkasoju@nvidia.com> Tested-by: Mallikarjun Kasoju <mkasoju@nvidia.com> Tested-by: Ahung Cheng <ahcheng@nvidia.com> Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
2011-12-22tracedump: Dump ftrace ring buffer dataAlon Farchy
Add a new module that will dump the contents of the ftrace ring buffer. Data is compressed and can be in ascii or binary form. Data will automatically dump on kernel panic to console. Data can be dumped by reading /proc/tracedump. See tracedump.h for details. Change-Id: I7b7afc3def0b88629dd120d17e43858306a8f357 Signed-off-by: Liang Cheng <licheng@nvidia.com> Reviewed-on: http://git-master/r/69494 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
2011-11-30Merge branch 'korg-android-tegra-3.1' into after-upstream-androidDan Willemsen
Conflicts: arch/arm/mach-tegra/Kconfig arch/arm/mach-tegra/board-ventana.c drivers/misc/Kconfig drivers/video/tegra/dc/hdmi.c Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
2011-11-30tracelevel module: Prioritize trace eventsAlon Farchy
This module lets subsystem authors prioritize ftrace events by calling tracelevel_register(...). High priority traces will be automatically enabled on boot. See tracelevel.h for more details Original-Change-Id: If03699e96c598bdcf93b9a9f73918ce7b0c750cb Reviewed-on: http://git-master/r/40290 Reviewed-by: Alon Farchy <afarchy@nvidia.com> Tested-by: Alon Farchy <afarchy@nvidia.com> Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com> Tested-by: Daniel Solomon <daniels@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com> Rebase-Id: R49f59f81d61907f66fdf892130a1b4dc6575d40e
2011-11-30Documentation: Add documentation for tegra_dc_extRobert Morell
tegra_dc_ext is the extended interface that exposes unique features for the NVIDIA Tegra display controller. Original-Change-Id: Ic18087a8fd8a60a6bc1b244361c15a1ed44cced4 Signed-off-by: Robert Morell <rmorell@nvidia.com> Reviewed-on: http://git-master/r/41348 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com> Rebase-Id: Red37e229b1606096c47f6ff0dfb3106ea43b2d69
2011-11-30PM: runtime: add might_sleep to PM runtime functionsColin Cross
The list of functions that can be called in atomic context is non-intuitive (pm_runtime_put_sync can not, but pm_runtime_put_sync_suspend can, if pm_runtime_irq_safe has been called?). The code is actively misleading - the entry points all start with spin_lock_irqsave, suggesting they are safe to call in atomic context, but may later enable interrupts. Add might_sleep_if to all the __pm_runtime_* entry points to enforce correct usage. Also add pm_runtime_put_sync_autosuspend to the list of functions that can be called in atomic context. Change-Id: Icac17a10d77c64d44bd2761a91a588dfd1d0c6f0 Signed-off-by: Colin Cross <ccross@android.com>
2011-11-30Documentation: cpufreq: add description of timer_rateAllen Martin
Add description of timer_rate tunable and clean up some typos. Change-Id: I4b96a36aad51eed3bef0ee5f571dc6e0a94c8dd9 Signed-off-by: Allen Martin <amartin@nvidia.com>
2011-11-30Documentation: remove trailing whitespace in governors.txtAllen Martin
Fixes a checkpatch warning Change-Id: I2962b7c32f336188de0d2fe4f0f13f1199cb68e2 Signed-off-by: Allen Martin <amartin@nvidia.com>
2011-11-30cgroup: Add generic cgroup subsystem permission checksColin Cross
Rather than using explicit euid == 0 checks when trying to move tasks into a cgroup via CFS, move permission checks into each specific cgroup subsystem. If a subsystem does not specify a 'allow_attach' handler, then we fall back to doing our checks the old way. Use the 'allow_attach' handler for the 'cpu' cgroup to allow non-root processes to add arbitrary processes to a 'cpu' cgroup if it has the CAP_SYS_NICE capability set. This version of the patch adds a 'allow_attach' handler instead of reusing the 'can_attach' handler. If the 'can_attach' handler is reused, a new cgroup that implements 'can_attach' but not the permission checks could end up with no permission checks at all. Change-Id: Icfa950aa9321d1ceba362061d32dc7dfa2c64f0c Original-Author: San Mehat <san@google.com> Signed-off-by: Colin Cross <ccross@android.com>
2011-11-30cpufreq: interactive: New 'interactive' governorMike Chan
This governor is designed for latency-sensitive workloads, such as interactive user interfaces. The interactive governor aims to be significantly more responsive to ramp CPU quickly up when CPU-intensive activity begins. Existing governors sample CPU load at a particular rate, typically every X ms. This can lead to under-powering UI threads for the period of time during which the user begins interacting with a previously-idle system until the next sample period happens. The 'interactive' governor uses a different approach. Instead of sampling the CPU at a specified rate, the governor will check whether to scale the CPU frequency up soon after coming out of idle. When the CPU comes out of idle, a timer is configured to fire within 1-2 ticks. If the CPU is very busy from exiting idle to when the timer fires then we assume the CPU is underpowered and ramp to MAX speed. If the CPU was not sufficiently busy to immediately ramp to MAX speed, then the governor evaluates the CPU load since the last speed adjustment, choosing the highest value between that longer-term load or the short-term load since idle exit to determine the CPU speed to ramp to. A realtime thread is used for scaling up, giving the remaining tasks the CPU performance benefit, unlike existing governors which are more likely to schedule rampup work to occur after your performance starved tasks have completed. The tuneables for this governor are: /sys/devices/system/cpu/cpufreq/interactive/min_sample_time: The minimum amount of time to spend at the current frequency before ramping down. This is to ensure that the governor has seen enough historic CPU load data to determine the appropriate workload. Default is 80000 uS. /sys/devices/system/cpu/cpufreq/interactive/go_maxspeed_load The CPU load at which to ramp to max speed. Default is 85. Change-Id: Ib2b362607c62f7c56d35f44a9ef3280f98c17585 Signed-off-by: Mike Chan <mike@android.com> Signed-off-by: Todd Poynor <toddpoynor@google.com> Bug: 3152864
2011-11-30scheduler: cpuacct: Enable platform callbacks for cpuacct power trackingMike Chan
Platform must register cpu power function that return power in milliWatt seconds. Change-Id: I1caa0335e316c352eee3b1ddf326fcd4942bcbe8 Signed-off-by: Mike Chan <mike@android.com>
2011-11-30scheduler: cpuacct: Enable platform hooks to track cpuusage for CPU frequenciesMike Chan
Introduce new platform callback hooks for cpuacct for tracking CPU frequencies Not all platforms / architectures have a set CPU_FREQ_TABLE defined for CPU transition speeds. In order to track time spent in at various CPU frequencies, we enable platform callbacks from cpuacct for this accounting. Architectures that support overclock boosting, or don't have pre-defined frequency tables can implement their own bucketing system that makes sense given their cpufreq scaling abilities. New file: cpuacct.cpufreq reports the CPU time (in nanoseconds) spent at each CPU frequency. Change-Id: I10a80b3162e6fff3a8a2f74dd6bb37e88b12ba96 Signed-off-by: Mike Chan <mike@android.com>
2011-11-30[docs] android: Add android config documentation to boot framework.Mike Chan
2011-11-21ALSA: hda - fix internal mic on Dell Vostro 3500 laptopJulian Wollrath
commit f7f9bdfadfda07afb904a9767468e38c2d1a6033 upstream. Fix the not working internal mic on Dell Vostro 3500 laptop by introducing the new model dell-vostro-3500. Signed-off-by: Julian Wollrath <jwollrath@web.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11PM / Runtime: Automatically retry failed autosuspendsAlan Stern
commit 886486b792e4f6f96d4fbe8ec5bf20811cab7d6a upstream. Originally, the runtime PM core would send an idle notification whenever a suspend attempt failed. The idle callback routine could then schedule a delayed suspend for some time later. However this behavior was changed by commit f71648d73c1650b8b4aceb3856bebbde6daa3b86 (PM / Runtime: Remove idle notification after failing suspend). No notifications were sent, and there was no clear mechanism to retry failed suspends. This caused problems for the usbhid driver, because it fails autosuspend attempts as long as a key is being held down. Therefore this patch (as1492) adds a mechanism for retrying failed autosuspends. If the callback routine updates the last_busy field so that the next autosuspend expiration time is in the future, the autosuspend will automatically be rescheduled. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11hwspinlock/core: use a mutex to protect the radix treeJuan Gutierrez
commit 93b465c2e186d96fb90012ba0f9372eb9952e732 upstream. Since we're using non-atomic radix tree allocations, we should be protecting the tree using a mutex and not a spinlock. Non-atomic allocations and process context locking is good enough, as the tree is manipulated only when locks are registered/ unregistered/requested/freed. The locks themselves are still protected by spinlocks of course, and mutexes are not involved in the locking/unlocking paths. Signed-off-by: Juan Gutierrez <jgutierrez@ti.com> [ohad@wizery.com: rewrite the commit log, #include mutex.h, add minor commentary] [ohad@wizery.com: update register/unregister parts in hwspinlock.txt] Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11Update email address for stable patch submissionJosh Boyer
commit 5fa224295f0e0358c8bc0e5390702338df889def upstream. The stable@kernel.org email address has been replaced with the stable@vger.kernel.org mailing list. Change the stable kernel rules to reference the new list instead of the semi-defunct email alias. Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-11x86: Default to vsyscall=native for nowAdrian Bunk
This UML breakage: linux-2.6.30.1[3800] vsyscall fault (exploit attempt?) ip:ffffffffff600000 cs:33 sp:7fbfb9c498 ax:ffffffffff600000 si:0 di:606790 linux-2.6.30.1[3856] vsyscall fault (exploit attempt?) ip:ffffffffff600000 cs:33 sp:7fbfb13168 ax:ffffffffff600000 si:0 di:606790 Is caused by commit 3ae36655 ("x86-64: Rework vsyscall emulation and add vsyscall= parameter") - the vsyscall emulation code is not fully cooked yet as UML relies on some rather fragile SIGSEGV semantics. Linus suggested in https://lkml.org/lkml/2011/8/9/376 to default to vsyscall=native for now, this patch implements that. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Andrew Lutomirski <luto@mit.edu> Cc: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/20111005214047.GE14406@localhost.pp.htv.fi Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-06net: fix typos in Documentation/networking/scaling.txtBenjamin Poirier
The second hunk fixes rps_sock_flow_table but has to re-wrap the paragraph. Signed-off-by: Benjamin Poirier <benjamin.poirier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-29net: Documentation: Fix type of variablesRoy.Li
Signed-off-by: Roy.Li <rongqing.li@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-28Merge git://github.com/davem330/netLinus Torvalds
* git://github.com/davem330/net: ipv6-multicast: Fix memory leak in IPv6 multicast. ipv6: check return value for dst_alloc net: check return value for dst_alloc ipv6-multicast: Fix memory leak in input path. bnx2x: add missing break in bnx2x_dcbnl_get_cap bnx2x: fix WOL by enablement PME in config space bnx2x: fix hw attention handling net: fix a typo in Documentation/networking/scaling.txt ath9k: Fix a dma warning/memory leak rtlwifi: rtl8192cu: Fix unitialized struct iwlagn: fix dangling scan request batman-adv: do_bcast has to be true for broadcast packets only cfg80211: Fix validation of AKM suites iwlegacy: do not use interruptible waits iwlegacy: fix command queue timeout ath9k_hw: Fix Rx DMA stuck for AR9003 chips
2011-09-27net: fix a typo in Documentation/networking/scaling.txtJason Wang
Signed-off-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-26Merge branch 'hwmon-for-linus' of git://github.com/groeck/linuxLinus Torvalds
* 'hwmon-for-linus' of git://github.com/groeck/linux: hwmon: (coretemp) remove struct platform_data * parameter from create_core_data() hwmon: (coretemp) constify static data hwmon: (coretemp) don't use kernel assigned CPU number as platform device ID hwmon: (ds620) Fix handling of negative temperatures hwmon: (w83791d) rename prototype parameter from 'register' to 'reg' hwmon: (coretemp) Don't use threshold registers for tempX_max hwmon: (coretemp) Let the user force TjMax hwmon: (coretemp) Drop duplicate function get_pkg_tjmax
2011-09-22thp: fix khugepaged defrag tunable documentationDavid Rientjes
Commit e27e6151b154 ("mm/thp: use conventional format for boolean attributes") changed /sys/kernel/mm/transparent_hugepage/khugepaged/defrag to be tuned by using 1 (enabled) or 0 (disabled) instead of "yes" and "no", respectively. Update the documentation. Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-21hwmon: (coretemp) Don't use threshold registers for tempX_maxGuenter Roeck
With commit c814a4c7c4aad795835583344353963a0a673eb0, the meaning of tempX_max was changed. It no longer returns the value of bits 8:15 of MSR_IA32_TEMPERATURE_TARGET, but instead returns the value of CPU threshold register T1. tempX_max_hyst was added to reflect the value of temperature threshold register T0. As it turns out, T0 and T1 are used on some systems, presumably by the BIOS. Also, T0 and T1 don't have a well defined meaning. The thresholds may be used as upper or lower limits, and it is not guaranteed that T0 <= T1. Thus, the new attribute mapping does not reflect the actual usage of the threshold registers. Also, register contents are changed during runtime by an entity other than the hwmon driver, meaning the values cached by the driver do not reflect actual register contents. Revert most of c814a4c7c4aad795835583344353963a0a673eb0 to address the problem. Support for T0 and T1 will be added back in with a separate commit, using new attribute names. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Durgadoss R <durgadoss.r@intel.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-09-21hwmon: (coretemp) Let the user force TjMaxJean Delvare
On old CPUs (and even some recent Atom CPUs) TjMax can't be read from the CPU registers, so it is guessed by the driver using a complex heuristic which isn't reliable. So let users who know their CPU's TjMax pass it as a module parameter. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: "R, Durgadoss" <durgadoss.r@intel.com> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Alexander Stein <alexander.stein@systec-electronic.com> Acked-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-09-18Merge git://github.com/davem330/netLinus Torvalds
* git://github.com/davem330/net: (62 commits) ipv6: don't use inetpeer to store metrics for routes. can: ti_hecc: include linux/io.h IRDA: Fix global type conflicts in net/irda/irsysctl.c v2 net: Handle different key sizes between address families in flow cache net: Align AF-specific flowi structs to long ipv4: Fix fib_info->fib_metrics leak caif: fix a potential NULL dereference sctp: deal with multiple COOKIE_ECHO chunks ibmveth: Fix checksum offload failure handling ibmveth: Checksum offload is always disabled ibmveth: Fix issue with DMA mapping failure ibmveth: Fix DMA unmap error pch_gbe: support ML7831 IOH pch_gbe: added the process of FIFO over run error pch_gbe: fixed the issue which receives an unnecessary packet. sfc: Use 64-bit writes for TX push where possible Revert "sfc: Use write-combining to reduce TX latency" and follow-ups bnx2x: Fix ethtool advertisement bnx2x: Fix 578xx link LED bnx2x: Fix XMAC loopback test ...
2011-09-16Merge branch 'master' of ../netdev/David S. Miller
2011-09-15Documentation: networking: dmfe.txt: Remove the maintainer of orphan ↵Marcos Paulo de Souza
networking driver The dmfe module is a orphan driver, and with this was removed the maintainer of the documentation. Signed-off-by: Marcos Paulo de Souza <marcos.mage@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-14memcg: Revert "memcg: add memory.vmscan_stat"Johannes Weiner
Revert the post-3.0 commit 82f9d486e59f5 ("memcg: add memory.vmscan_stat"). The implementation of per-memcg reclaim statistics violates how memcg hierarchies usually behave: hierarchically. The reclaim statistics are accounted to child memcgs and the parent hitting the limit, but not to hierarchy levels in between. Usually, hierarchical statistics are perfectly recursive, with each level representing the sum of itself and all its children. Since this exports statistics to userspace, this may lead to confusion and problems with changing things after the release, so revert it now, we can try again later. Signed-off-by: Johannes Weiner <jweiner@redhat.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Cc: Balbir Singh <bsingharora@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-14Merge git://bedivere.hansenpartnership.com/git/scsi-rc-fixes-2.6Linus Torvalds
* git://bedivere.hansenpartnership.com/git/scsi-rc-fixes-2.6: (25 commits) [SCSI] bnx2i: Fixed the endian on TTT for NOP out transmission [SCSI] libfc: fix referencing to fc_fcp_pkt from the frame pointer via fr_fsp() [SCSI] libfc: block SCSI eh thread for blocked rports [SCSI] libfc: fix fc_eh_host_reset [SCSI] fcoe: Fix deadlock between fip's recv_work and rtnl [SCSI] qla2xxx: Update version number to 8.03.07.07-k. [SCSI] qla2xxx: Set the task attributes after memsetting fcp cmnd. [SCSI] qla2xxx: Correct inadvertent loop state transitions during port-update handling. [SCSI] qla2xxx: Save and restore irq in the response queue interrupt handler. [SCSI] qla2xxx: Double check for command completion if abort mailbox command fails. [SCSI] qla2xxx: Acquire hardware lock while manipulating dsd list. [SCSI] qla2xxx: Fix qla24xx revision check while enabling interrupts. [SCSI] qla2xxx: T10 DIF - Fix incorrect error reporting. [SCSI] qla2xxx: T10 DIF - Handle uninitalized sectors. [SCSI] hpsa: fix physical device lun and target numbering problem [SCSI] hpsa: fix problem that OBDR devices are not detected [SCSI] isci: add version number [SCSI] isci: fix event-get pointer increment [SCSI] isci: dynamic interrupt coalescing [SCSI] isci: Leave requests alone if already terminating. ...
2011-09-12Merge branches 'apei', 'bz-13195' and 'doc' into acpiLen Brown
2011-09-12ioctl: register LTTng ioctlMathieu Desnoyers
The LTTng 2.0 kernel tracer (stand-alone module package, available at http://lttng.org) uses the 0xF6 ioctl range for tracer control and transport operations. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-11Merge branch 'v4l_for_linus' of git://linuxtv.org/mchehab/for_linusLinus Torvalds
* 'v4l_for_linus' of git://linuxtv.org/mchehab/for_linus: [media] vp7045: fix buffer setup [media] nuvoton-cir: simplify raw IR sample handling [media] [Resend] viacam: Don't explode if pci_find_bus() returns NULL [media] v4l2: Fix documentation of the codec device controls [media] gspca - sonixj: Fix the darkness of sensor om6802 in 320x240 [media] gspca - sonixj: Fix wrong register mask for sensor om6802 [media] gspca - ov519: Fix LED inversion of some ov519 webcams [media] pwc: precedence bug in pwc_init_controls()
2011-09-11[media] v4l2: Fix documentation of the codec device controlsKamil Debski
Fixed missing ids of the codec controls description in the controls.xml file. Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reported-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-06hwmon: (max16065) Add chip access warning to documentationGuenter Roeck
The chips supported by the max16065 driver should not be accessed using direct i2ctools commands. Add warning to driver documentation to alert users. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Jean Delvare <khali@linux-fr.org>
