Signed-off-by: Michael Witten <mfwitten@gmail.com>
Acked-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
... as per Randy Dunlap's wishes :-P
Message-Id: <20110717114023.2b4cce91.rdunlap@xenotime.net>
'from-akpm', 'kexec-param' and 'misc' into release
Documentation/kernel-parameters.txt
Signed-off-by: Len Brown <len.brown@intel.com>
Says for acpi=
See also Documentation/power/pm.txt, pci=noacpi
but this file does not exist
Reported-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-linus
It's about time to revert 16d752397301b9 ("thermal: Create
CONFIG_THERMAL_HWMON=n"). Anybody running a kernel >= 2.6.40 would also
be running a recent enough version of lm-sensors.
Actually having CONFIG_THERMAL_HWMON is pretty convenient so instead of
dropping it, we keep it but hide it.
Cc: Rene Herman <rene.herman@gmail.com>
Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
Add optional parameter field to dmcrypt table and support
"allow_discards" option.
Discard requests bypass crypt queue processing. Bio is simple remapped
to underlying device.
Note that discard will be never enabled by default because of security
consequences. It is up to the administrator to enable it for encrypted
devices.
(Note that userspace cryptsetup does not understand new optional
parameters yet. Support for this will come later. Until then, you
should use 'dmsetup' to enable and disable this.)
Signed-off-by: Milan Broz <mbroz@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Add the ability to parse and use metadata devices to dm-raid. Although
not strictly required, without the metadata devices, many features of
RAID are unavailable. They are used to store a superblock and bitmap.
The role, or position in the array, of each device must be recorded in
its superblock. This is to help with fault handling, array reshaping,
and sanity checks. RAID 4/5/6 devices must be loaded in a specific order:
in this way, the 'array_position' field helps validate the correctness
of the mapping when it is loaded. It can be used during reshaping to
identify which devices are added/removed. Fault handling is impossible
without this field. For example, when a device fails it is recorded in
the superblock. If this is a RAID1 device and the offending device is
removed from the array, there must be a way during subsequent array
assembly to determine that the failed device was the one removed. This
is done by correlating the 'array_position' field and the bit-field
variable 'failed_devices'.
Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
Add the write_mostly parameter to RAID1 dm-raid tables.
This allows the user to set the WriteMostly flag on a RAID1 device that
should normally be avoided for read I/O.
Allow the user to specify the region_size.
Ensures that the supplied value meets md's constraints, viz. the number of
regions does not exceed 2^21.
Add more information about some dm-raid table parameters and clarify how
parameters are printed when 'dmsetup table' is issued.
Add corrupt_bio_byte feature to simulate corruption by overwriting a byte at a
specified position with a specified value during intervals when the device is
"down".
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Add 'drop_writes' option to drop writes silently while the
device is 'down'. Reads are not touched.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (37 commits)
Improve slave/cyclic DMA engine documentation
dmaengine: pl08x: handle the rest of enums in pl08x_width
DMA: PL08x: cleanup selection of burst size
DMA: PL08x: avoid recalculating cctl at each prepare
DMA: PL08x: cleanup selection of buswidth
DMA: PL08x: constify plchan->cd and plat->slave_channels
DMA: PL08x: separately store source/destination cctl
DMA: PL08x: separately store source/destination slave address
DMA: PL08x: clean up LLI debugging
DMA: PL08x: select LLI bus only once per LLI setup
DMA: PL08x: remove unused constants
ARM: mxs-dma: reset after disable channel
dma: intel_mid_dma: remove redundant pci_set_drvdata calls
dma: mxs-dma: fix unterminated platform_device_id table
dmaengine: pl330: make platform data optional
dmaengine: imx-sdma: return proper error if kzalloc fails
pch_dma: Fix CTL register access issue
dmaengine: mxs-dma: skip request_irq for NO_IRQ
dmaengine/coh901318: fix slave submission semantics
dmaengine/ste_dma40: allow memory buswidth/burst to be configured
Fix trivial whitespace conflict in drivers/dma/mv_xor.c
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'pstore-efi' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
efivars: Introduce PSTORE_EFI_ATTRIBUTES
efivars: Use string functions in pstore_write
efivars: introduce utf16_strncmp
efivars: String functions
efi: Add support for using efivars as a pstore backend
pstore: Allow the user to explicitly choose a backend
pstore: Make "part" unsigned
pstore: Add extra context for writes and erases
pstore: Extend API for more flexibility in new backends
It adds device tree probe support for mma8450 driver.
Acked-by: Eric Miao <eric.miao@linaro.org>
devices
Instead of unconditionally creating a fixed number of dead loop
devices which need to be investigated by storage handling services,
even when they are never used, we allow distros start with 0
loop devices and have losetup(8) and similar switch to the dynamic
/dev/loop-control interface instead of searching /dev/loop%i for free
devices.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: (24 commits)
hwmon: (lm90) Refactor reading of config2 register
hwmon: (lm90) Make SA56004 detection more robust
hwmon: (lm90) Simplify handling of extended local temp register
hwmon: (pmbus) Add client driver for LM25066, LM5064, and LM5066
hwmon: (max34440) Add support for peak attributes
hwmon: (max8688) Add support for peak attributes
hwmon: (max16064) Add support for peak attributes
hwmon: (adm1275) Add support for peak attributes
hwmon: (pmbus) Add support for peak attributes
hwmon: Add new attributes to sysfs ABI
hwmon: (pmbus) Strengthen check for status register existence
hwmon: (pmbus) Add support for virtual pages
hwmon: (pmbus) Support reading and writing of word registers in device specific code
hwmon: (pmbus) Increase attribute name size
hwmon: (pmbus) Add ADP4000, NCP4200 and NCP4208 to list of supported devices
hwmon: (pmbus) Add support for VID output voltage mode
hwmon: (pmbus) Move PMBus drivers to drivers/hwmon/pmbus
hwmon: (coretemp) Add core/pkg threshold support to Coretemp
hwmon: (lm95241) Add support for LM95231
hwmon: LM95245 driver
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (71 commits)
[SCSI] fcoe: cleanup cpu selection for incoming requests
[SCSI] fcoe: add fip retry to avoid missing critical keep alive
[SCSI] libfc: fix warn on in lport retry
[SCSI] libfc: Remove the reference to FCP packet from scsi_cmnd in case of error
[SCSI] libfc: cleanup sending SRR request
[SCSI] libfc: two minor changes in comments
[SCSI] libfc, fcoe: ignore rx frame with wrong xid info
[SCSI] libfc: release exchg cache
[SCSI] libfc: use FC_MAX_ERROR_CNT
[SCSI] fcoe: remove unused ptype field in fcoe_rcv_info
[SCSI] bnx2fc: Update copyright and bump version to 1.0.4
[SCSI] bnx2fc: Tx BDs cache in write tasks
[SCSI] bnx2fc: Do not arm CQ when there are no CQEs
[SCSI] bnx2fc: hold tgt lock when calling cmd_release
[SCSI] bnx2fc: Enable support for sequence level error recovery
[SCSI] bnx2fc: HSI changes for tape
[SCSI] bnx2fc: Handle REC_TOV error code from firmware
[SCSI] bnx2fc: REC/SRR link service request and response handling
[SCSI] bnx2fc: Support 'sequence cleanup' task
[SCSI] dh_rdac: Associate HBA and storage in rdac_controller to support partitions in storage
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (430 commits)
[media] ir-mce_kbd-decoder: include module.h for its facilities
[media] ov5642: include module.h for its facilities
[media] em28xx: Fix DVB-C maxsize for em2884
[media] tda18271c2dd: Fix saw filter configuration for DVB-C @6MHz
[media] v4l: mt9v032: Fix Bayer pattern
[media] V4L: mt9m111: rewrite set_pixfmt
[media] V4L: mt9m111: fix missing return value check mt9m111_reg_clear
[media] V4L: initial driver for ov5642 CMOS sensor
[media] V4L: sh_mobile_ceu_camera: fix Oops when USERPTR mapping fails
[media] V4L: soc-camera: remove soc-camera bus and devices on it
[media] V4L: soc-camera: un-export the soc-camera bus
[media] V4L: sh_mobile_csi2: switch away from using the soc-camera bus notifier
[media] V4L: add media bus configuration subdev operations
[media] V4L: soc-camera: group struct field initialisations together
[media] V4L: soc-camera: remove now unused soc-camera specific PM hooks
[media] V4L: pxa-camera: switch to using standard PM hooks
[media] NetUP Dual DVB-T/C CI RF: force card hardware revision by module param
[media] Don't OOPS if videobuf_dvb_get_frontend return NULL
[media] NetUP Dual DVB-T/C CI RF: load firmware according card revision
[media] omap3isp: Support configurable HS/VS polarities
Fix up conflicts:
- arch/arm/mach-omap2/board-rx51-peripherals.c:
cleanup regulator supply definitions in mach-omap2
vs
OMAP3: RX-51: define vdds_csib regulator supply
- drivers/staging/tm6000/tm6000-alsa.c (trivial)
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (21 commits)
arm/dt: tegra devicetree support
arm/versatile: Add device tree support
dt/irq: add irq_domain_generate_simple() helper
irq: add irq_domain translation infrastructure
dmaengine: imx-sdma: add device tree probe support
dmaengine: imx-sdma: sdma_get_firmware does not need to copy fw_name
dmaengine: imx-sdma: use platform_device_id to identify sdma version
mmc: sdhci-esdhc-imx: add device tree probe support
mmc: sdhci-pltfm: dt device does not pass parent to sdhci_alloc_host
mmc: sdhci-esdhc-imx: get rid of the uses of cpu_is_mx()
mmc: sdhci-esdhc-imx: do not reference platform data after probe
mmc: sdhci-esdhc-imx: extend card_detect and write_protect support for mx5
net/fec: add device tree probe support
net: ibm_newemac: convert it to use of_get_phy_mode
dt/net: add helper function of_get_phy_mode
net/fec: gasket needs to be enabled for some i.mx
serial/imx: add device tree probe support
serial/imx: get rid of the uses of cpu_is_mx1()
arm/dt: Add dtb make rule
arm/dt: Add skeleton dtsi file
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-watchdog: (25 commits)
watchdog: WatchDog Timer Driver Core - Add minimum and max timeout
watchdog: WatchDog Timer Driver Core - Add ioctl call
watchdog: WatchDog Timer Driver Core - Add nowayout feature
watchdog: WatchDog Timer Driver Core - Add Magic Close feature
watchdog: WatchDog Timer Driver Core - Add WDIOC_SETTIMEOUT and WDIOC_GETTIMEOUT ioctl
watchdog: WatchDog Timer Driver Core - Add WDIOC_SETOPTIONS ioctl
watchdog: WatchDog Timer Driver Core - Add WDIOC_KEEPALIVE ioctl
watchdog: WatchDog Timer Driver Core - Add basic ioctl functionality
watchdog: WatchDog Timer Driver Core - Add basic framework
watchdog: hpwdt: add next gen HP servers
watchdog: it8712f_wdt.c: improve includes
watchdog: at91sam9/wdt: move register header to drivers
watchdog: Add Xilinx watchdog timer driver
watchdog: remove empty pm-functions
watchdog: sp805: Flush posted writes in enable/disable.
watchdog: sp805: Don't write 0 to the load value register.
watchdog: imx2_wdt: add device tree probe support
watchdog: s3c2410: Add support for device tree based probe
watchdog: mpcore_wdt: Add suspend/resume support.
watchdog: mtx1-wdt: use dev_{err,info} instead of printk()
PMBus client driver supporting National Semiconductor LM25066, LM5064, and LM5066.
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
Add support for voltage, current, and temperature peak (historic maximum)
attributes.
attributes.
Add support for voltage and temperature peak (historic maximum) attributes.
Add support for voltage and current peak (historic maximum) attributes.
Add the following attributes to the sysfs ABI.
in[0-*]_average
in[0-*]_lowest
in[0-*]_highest
in[0-*]_reset_history
in_reset_history
curr[1-*]_average
curr[1-*]_lowest
curr[1-*]_highest
curr[1-*]_reset_history
curr_reset_history
Add ADP4000, NCP4200 and NCP4208 to the list of devices supported by the generic
PMBus driver, and add device IDs to enable explicit instantiation.
Acked-by: Jean Delvare <khali@linux-fr.org>
* 'for-linus' of git://neil.brown.name/md: (75 commits)
md/raid10: handle further errors during fix_read_error better.
md/raid10: Handle read errors during recovery better.
md/raid10: simplify read error handling during recovery.
md/raid10: record bad blocks due to write errors during resync/recovery.
md/raid10: attempt to fix read errors during resync/check
md/raid10: Handle write errors by updating badblock log.
md/raid10: clear bad-block record when write succeeds.
md/raid10: avoid writing to known bad blocks on known bad drives.
md/raid10 record bad blocks as needed during recovery.
md/raid10: avoid reading known bad blocks during resync/recovery.
md/raid10 - avoid reading from known bad blocks - part 3
md/raid10: avoid reading from known bad blocks - part 2
md/raid10: avoid reading from known bad blocks - part 1
md/raid10: Split handle_read_error out from raid10d.
md/raid10: simplify/reindent some loops.
md/raid5: Clear bad blocks on successful write.
md/raid5. Don't write to known bad block on doubtful devices.
md/raid5: write errors should be recorded as bad blocks if possible.
md/raid5: use bad-block log to improve handling of uncorrectable read errors.
md/raid5: avoid reading from known bad blocks.
Add min_timeout (minimum timeout) and max_timeout
values so that the framework can check if the new
timeout value is between the minimum and maximum
timeout values. If both values are 0, then the
framework will leave the check for the watchdog
device driver itself.
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Add support for extra ioctl calls by adding a
ioctl watchdog operation. This operation will be
called before we do our own handling of ioctl
commands. This way we can override the internal
ioctl command handling and we can also add
extra ioctl commands. The ioctl watchdog operation
should return the appropriate error codes or
-ENOIOCTLCMD if the ioctl command should be handled
through the internal ioctl handling of the framework.
Add support for the nowayout feature to the
WatchDog Timer Driver Core framework.
This feature prevents the watchdog timer from being
stopped.
Add support for the Magic Close feature to the
