The inode's i_size is not protected by the big kernel lock. Therefore it
does not make sense to recommend taking the BKL in filesystems llseek
operations. Instead it should use the inode's mutex or use just use
i_size_read() instead. Add a note that this is not protecting
file->f_pos.
Signed-off-by: Jan Blunck <jblunck@suse.de>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: John Kacur <jkacur@redhat.com>
Add ARCH_KMALLOC_MINALIGN description in "Platform Issues" section.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Matt Mackall <mpm@selenic.com>
Handing DMA mapping errors is essential. Let's put it in the more
appropriate place rather than the end of the doc.
Now we have <asm-generic/scatterlist.h>. Architectures should use it
instead of inventing the own scatterlist struct. Let's update the
description.
Add the concrete DMA mapping error handling for SCSI drivers on the
queuecommand path.
Cc: James Bottomley <James.Bottomley@suse.de>
Adds the concrete DMA mapping error handling for Networking drivers on the
transmit path.
Some information are old, and I think current document doesn't work as "a
guide for users". We need summary of all of our controls, at least.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
This patch adds support for moving charge of file pages, which include
normal file, tmpfs file and swaps of tmpfs file. It's enabled by setting
bit 1 of <target cgroup>/memory.move_charge_at_immigrate.
Unlike the case of anonymous pages, file pages(and swaps) in the range
mmapped by the task will be moved even if the task hasn't done page fault,
i.e. they might not be the task's "RSS", but other task's "RSS" that maps
the same file. And mapcount of the page is ignored(the page can be moved
even if page_mapcount(page) > 1). So, conditions that the page/swap
should be met to be moved is that it must be in the range mmapped by the
target task and it must be charged to the old cgroup.
[akpm@linux-foundation.org: fix warning]
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
This adds a feature to disable oom-killer for memcg, if disabled, of
course, tasks under memcg will stop.
But now, we have oom-notifier for memcg. And the world around memcg is
not under out-of-memory. memcg's out-of-memory just shows memcg hits
limit. Then, administrator or management daemon can recover the situation
by
- kill some process
- enlarge limit, add more swap.
- migrate some tasks
- remove file cache on tmps (difficult ?)
Unlike oom-killer, you can take enough information before killing tasks.
(by gcore, or, ps etc.)
Considering containers or other resource management softwares in userland,
event notification of OOM in memcg should be implemented. Now, memcg has
"threshold" notifier which uses eventfd, we can make use of it for oom
notification.
This patch adds oom notification eventfd callback for memcg. The usage is
very similar to threshold notifier, but control file is memory.oom_control
and no arguments other than eventfd is required.
% cgroup_event_notifier /cgroup/A/memory.oom_control dummy
(About cgroup_event_notifier, see Documentation/cgroup/)
Cc: Davide Libenzi <davidel@xmailserver.org>
Signed-off-by: Trevor Woerner <twoerner@gmail.com>
Cc: Paul Menage <menage@google.com>
- Add additional location (Git) for the kernel master tree
- Add reference to Git Project
Signed-off-by: Abraham Arce <x0066660@ti.com>
A more complete patch in the kernel-doc tree also contains this change.
* git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linus:
squashfs: update documentation to include description of xattr layout
squashfs: fix name reading in squashfs_xattr_get
squashfs: constify xattr handlers
squashfs: xattr fix sparse warnings
squashfs: xattr_lookup sparse fix
squashfs: add xattr support configure option
squashfs: add new extended inode types
squashfs: add support for xattr reading
squashfs: add xattr id support
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
Add dump_id libata.force parameter. If specified, libata dumps full
IDENTIFY data during device configuration. This is to aid debugging.
Cc: Larry Baker <baker@usgs.gov>
This adds:
alias: devname:<name>
to some common kernel modules, which will allow the on-demand loading
of the kernel module when the device node is accessed.
Ideally all these modules would be compiled-in, but distros seems too
much in love with their modularization that we need to cover the common
cases with this new facility. It will allow us to remove a bunch of pretty
useless init scripts and modprobes from init scripts.
The static device node aliases will be carried in the module itself. The
program depmod will extract this information to a file in the module directory:
$ cat /lib/modules/2.6.34-00650-g537b60d-dirty/modules.devname
# Device nodes to trigger on-demand module loading.
microcode cpu/microcode c10:184
fuse fuse c10:229
ppp_generic ppp c108:0
tun net/tun c10:200
dm_mod mapper/control c10:235
Udev will pick up the depmod created file on startup and create all the
static device nodes which the kernel modules specify, so that these modules
get automatically loaded when the device node is accessed:
$ /sbin/udevd --debug
static_dev_create_from_modules: mknod '/dev/cpu/microcode' c10:184
static_dev_create_from_modules: mknod '/dev/fuse' c10:229
static_dev_create_from_modules: mknod '/dev/ppp' c108:0
static_dev_create_from_modules: mknod '/dev/net/tun' c10:200
static_dev_create_from_modules: mknod '/dev/mapper/control' c10:235
udev_rules_apply_static_dev_perms: chmod '/dev/net/tun' 0666
udev_rules_apply_static_dev_perms: chmod '/dev/fuse' 0666
A few device nodes are switched to statically allocated numbers, to allow
the static nodes to work. This might also useful for systems which still run
a plain static /dev, which is completely unsafe to use with any dynamic minor
numbers.
Note:
The devname aliases must be limited to the *common* and *single*instance*
device nodes, like the misc devices, and never be used for conceptually limited
systems like the loop devices, which should rather get fixed properly and get a
control node for losetup to talk to, instead of creating a random number of
device nodes in advance, regardless if they are ever used.
This facility is to hide the mess distros are creating with too modualized
kernels, and just to hide that these modules are not compiled-in, and not to
paper-over broken concepts. Thanks! :)
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Alasdair G Kergon <agk@redhat.com>
Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
Cc: Ian Kent <raven@themaw.net>
Signed-Off-By: Kay Sievers <kay.sievers@vrfy.org>
All application domains that are supported by the old ieee1394 driver
stack are supported by the newer firewire driver stack too. There is
now good and extensive experience with the newer stack from deployment
in Fedora since F7 as well as by enthusiast users of other
distributions.
The new drivers have consequently been recommended as the default ones
since 2.6.33, in order to fix some severe usability problems of FireWire
on Linux due to limitations of the old stack. It is now high time to
announce when the obsolete drivers will be removed.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Acked-by: Jarod Wilson <jarod@redhat.com>
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6:
spi/xilinx: Fix compile error
spi/davinci: Fix clock prescale factor computation
spi: move bitbang txrx utility functions to private header
spi/mpc5121: Add SPI master driver for MPC5121 PSC
powerpc/mpc5121: move PSC FIFO memory init to platform code
spi/ep93xx: implemented driver for Cirrus EP93xx SPI controller
Documentation/spi/* compile warning fix
spi/omap2_mcspi: Check params before dereference or use
spi/omap2_mcspi: add turbo mode support
spi/omap2_mcspi: change default DMA_MIN_BYTES value to 160
spi/pl022: fix stop queue procedure
spi/pl022: add support for the PL023 derivate
spi/pl022: fix up differences between ARM and ST versions
spi/spi_mpc8xxx: Do not use map_tx_dma to unmap rx_dma
spi/spi_mpc8xxx: Fix QE mode Litte Endian
spi/spi_mpc8xxx: fix potential memory corruption.
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog:
watchdog: Driver for the watchdog timer on Freescale IMX2 (and later) processors.
watchdog: s3c2410_wdt - Fix on handling of the request_mem_region fail
watchdog: s3c2410_wdt - Add extra option to include watchdog for Samsung SoCs
iTCO_wdt: fix TCO V1 timeout values and limits
watchdog: twl4030_wdt: Disable watchdog during probing
watchdog: update/improve/consolidate watchdog driver
watchdog: booke_wdt: fix ioctl status flags
watchdog: fix several MODULE_PARM_DESC strings
watchdog: bfin: use new common Blackfin watchdog header
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: Ensure inode allocation buffers are fully replayed
xfs: enable background pushing of the CIL
xfs: forced unmounts need to push the CIL
xfs: Introduce delayed logging core code
xfs: Delayed logging design documentation
xfs: Improve scalability of busy extent tracking
xfs: make the log ticket ID available outside the log infrastructure
xfs: clean up log ticket overrun debug output
xfs: Clean up XFS_BLI_* flag namespace
xfs: modify buffer item reference counting
xfs: allow log ticket allocation to take allocation flags
xfs: Don't reuse the same transaction ID for duplicated transactions.
and when it should be reclaimed
The kernel applies some heuristics when deciding if memory should be
compacted or reclaimed to satisfy a high-order allocation. One of these
is based on the fragmentation. If the index is below 500, memory will not
be compacted. This choice is arbitrary and not based on data. To help
optimise the system and set a sensible default for this value, this patch
adds a sysctl extfrag_threshold. The kernel will only compact memory if
the fragmentation index is above the extfrag_threshold.
[randy.dunlap@oracle.com: Fix build errors when proc fs is not configured]
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Minchan Kim <minchan.kim@gmail.com>
Add a per-node sysfs file called compact. When the file is written to,
each zone in that node is compacted. The intention that this would be
used by something like a job scheduler in a batch system before a job
starts so that the job can allocate the maximum number of hugepages
without significant start-up cost.
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Add a proc file /proc/sys/vm/compact_memory. When an arbitrary value is
written to the file, all zones are compacted. The expected user of such a
trigger is a job scheduler that prepares the system before the target
application runs.
Update Documentation/filesystems/tmpfs.txt to describe the interaction of
tmpfs mount option memory policy with tasks' cpuset mems_allowed.
Note: the mount(8) man page [in the util-linux-ng package] requires
similiar updates.
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Ravikiran Thirumalai <kiran@scalex86.org>
Move the limited watchdog driver help from kernel-parameters.txt
to Documentation/watchdog/watchdog-parameters.txt and add info to it
for all watchdog drivers except the ones that have driver-specific
files already.
Correct minor comments and MODULE_PARM_DESC() text in 2 places.
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
This patch adds an SPI master driver for the Cirrus EP93xx SPI controller found
in EP93xx chips.
Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Fix this warning:
Documentation/spi/spidev_fdx.c: In function `do_msg':
Documentation/spi/spidev_fdx.c:61: warning: cast from pointer to integer of different size
Documentation/spi/spidev_fdx.c:64: warning: cast from pointer to integer of different size
buf should be unsigned long to match native arch on 32-bit x86 compile.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Document the design of the delayed logging implementation. This
includes assumptions made, dead ends followed, the reasoning behind
the structuring of the code, the layout of various structures, how
things fit together, traps and pit-falls avoided, etc. This is all
too much to document in the code itself, so do it in a separate
file.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Alex Elder <aelder@sgi.com>
* git://git.infradead.org/battery-2.6:
ds2760_battery: Document ABI change
ds2760_battery: Make charge_now and charge_full writeable
power_supply: Add support for writeable properties
power_supply: Use attribute groups
power_supply: Add test_power driver
tosa_battery: Fix build error due to direct driver_data usage
wm97xx_battery: Quieten sparse warning (bat_set_pdata not declared)
ds2782_battery: Get rid of magic numbers in driver_data
ds2782_battery: Add support for ds2786 battery gas gauge
pda_power: Add function callbacks for suspend and resume
wm831x_power: Use genirq
Driver for Zipit Z2 battery chip
ds2782_battery: Fix clientdata on removal
Add build testing using 'O=builddir'.
Add build testing with various kconfig symbols disabled, listing
common ones that are known to cause build problems.
documentation: slightly more correct value for MAP_HUGETLB in map_hugetlb.c
still not correct for alpha, mips, parisc or xtensa but working out of
the box in the most common architectures without having to deal with
complicated macros or including architecture specific headers.
Signed-off-by: Carlo Marcelo Arenas Belon <carenas@sajinet.com.pe>
Documentation/timers/hpet_example.c: fcntl.h is included more than once.
Documentation/timers/hpet_example.c: signal.h is included more than once.
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
Update explanation of mmotm.
Add explanation of drivers/staging/.
Acked-by: Jonathan Corbet <corbet@lwn.net>
Add info on maintainers and persistent posting.
Update git home page.
In the example the module_init function should be static.
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (36 commits)
PCI: hotplug: pciehp: Removed check for hotplug of display devices
PCI: read memory ranges out of Broadcom CNB20LE host bridge
PCI: Allow manual resource allocation for PCI hotplug bridges
x86/PCI: make ACPI MCFG reserved error messages ACPI specific
PCI hotplug: Use kmemdup
PM/PCI: Update PCI power management documentation
PCI: output FW warning in pci_read/write_vpd
PCI: fix typos pci_device_dis/enable to pci_dis/enable_device in comments
PCI quirks: disable msi on AMD rs4xx internal gfx bridges
PCI: Disable MSI for MCP55 on P5N32-E SLI
x86/PCI: irq and pci_ids patch for additional Intel Cougar Point DeviceIDs
PCI: aerdrv: trivial cleanup for aerdrv_core.c
PCI: aerdrv: trivial cleanup for aerdrv.c
PCI: aerdrv: introduce default_downstream_reset_link
PCI: aerdrv: rework find_aer_service
PCI: aerdrv: remove is_downstream
PCI: aerdrv: remove magical ROOT_ERR_STATUS_MASKS
PCI: aerdrv: redefine PCI_ERR_ROOT_*_SRC
PCI: aerdrv: rework do_recovery
PCI: aerdrv: rework get_e_source()
* git://git.infradead.org/iommu-2.6:
intel-iommu: Set a more specific taint flag for invalid BIOS DMAR tables
intel-iommu: Combine the BIOS DMAR table warning messages
panic: Add taint flag TAINT_FIRMWARE_WORKAROUND ('I')
panic: Allow warnings to set different taint flags
intel-iommu: intel_iommu_map_range failed at very end of address space
intel-iommu: errors with smaller iommu widths
intel-iommu: Fix boot inside 64bit virtualbox with io-apic disabled
intel-iommu: use physfn to search drhd for VF
intel-iommu: Print out iommu seq_id
intel-iommu: Don't complain that ACPI_DMAR_SCOPE_TYPE_IOAPIC is not supported
intel-iommu: Avoid global flushes with caching mode.
intel-iommu: Use correct domain ID when caching mode is enabled
intel-iommu mistakenly uses offset_pfn when caching mode is enabled
intel-iommu: use for_each_set_bit()
intel-iommu: Fix section mismatch dmar_ir_support() uses dmar_tbl.
* 'kvm-updates/2.6.35' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (269 commits)
KVM: x86: Add missing locking to arch specific vcpu ioctls
KVM: PPC: Add missing vcpu_load()/vcpu_put() in vcpu ioctls
KVM: MMU: Segregate shadow pages with different cr0.wp
KVM: x86: Check LMA bit before set_efer
KVM: Don't allow lmsw to clear cr0.pe
KVM: Add cpuid.txt file
KVM: x86: Tell the guest we'll warn it about tsc stability
x86, paravirt: don't compute pvclock adjustments if we trust the tsc
x86: KVM guest: Try using new kvm clock msrs
KVM: x86: export paravirtual cpuid flags in KVM_GET_SUPPORTED_CPUID
KVM: x86: add new KVMCLOCK cpuid feature
KVM: x86: change msr numbers for kvmclock
x86, paravirt: Add a global synchronization point for pvclock
x86, paravirt: Enable pvclock flags in vcpu_time_info structure
KVM: x86: Inject #GP with the right rip on efer writes
KVM: SVM: Don't allow nested guest to VMMCALL into host
KVM: x86: Fix exception reinjection forced to true
KVM: Fix wallclock version writing race
KVM: MMU: Don't read pdptrs with mmu spinlock held in mmu_alloc_roots
KVM: VMX: enable VMXON check with SMX enabled (Intel TXT)
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86: (32 commits)
Move N014, N051 and CR620 dmi information to load scm dmi table
drivers/platform/x86/eeepc-wmi.c: fix build warning
X86 platfrom wmi: Add debug facility to dump WMI data in a readable way
X86 platform wmi: Also log GUID string when an event happens and debug is set
X86 platform wmi: Introduce debug param to log all WMI events
Clean up all objects used by scm model when driver initial fail or exit
msi-laptop: fix up some coding style issues found by checkpatch
msi-laptop: Add i8042 filter to sync sw state with BIOS when function key pressed
msi-laptop: Set rfkill init state when msi-laptop intiial
msi-laptop: Add MSI CR620 notebook dmi information to scm models table
msi-laptop: Add N014 N051 dmi information to scm models table
drivers/platform/x86: Use kmemdup
drivers/platform/x86: Use kzalloc
drivers/platform/x86: Clarify the MRST IPC driver description slightly
eeepc-wmi: depends on BACKLIGHT_CLASS_DEVICE
IPC driver for Intel Mobile Internet Device (MID) platforms
classmate-laptop: Add RFKILL support.
thinkpad-acpi: document backlight level writeback at driver init
thinkpad-acpi: clean up ACPI handles handling
thinkpad-acpi: don't depend on led_path for led firmware type (v2)
fs/ext3/fsync.c
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (92 commits)
powerpc: Remove unused 'protect4gb' boot parameter
powerpc: Build-in e1000e for pseries & ppc64_defconfig
powerpc/pseries: Make request_ras_irqs() available to other pseries code
powerpc/numa: Use ibm,architecture-vec-5 to detect form 1 affinity
powerpc/numa: Set a smaller value for RECLAIM_DISTANCE to enable zone reclaim
powerpc: Use smt_snooze_delay=-1 to always busy loop
powerpc: Remove check of ibm,smt-snooze-delay OF property
powerpc/kdump: Fix race in kdump shutdown
powerpc/kexec: Fix race in kexec shutdown
powerpc/kexec: Speedup kexec hash PTE tear down
powerpc/pseries: Add hcall to read 4 ptes at a time in real mode
powerpc: Use more accurate limit for first segment memory allocations
powerpc/kdump: Use chip->shutdown to disable IRQs
powerpc/kdump: CPUs assume the context of the oopsing CPU
powerpc/crashdump: Do not fail on NULL pointer dereferencing
powerpc/eeh: Fix oops when probing in early boot
powerpc/pci: Check devices status property when scanning OF tree
powerpc/vio: Switch VIO Bus PM to use generic helpers
powerpc: Avoid bad relocations in iSeries code
powerpc: Use common cpu_die (fixes SMP+SUSPEND build)
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-for-2.6.35' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (207 commits)
drm/radeon/kms/pm/r600: select the mid clock mode for single head low profile
drm/radeon: fix power supply kconfig interaction.
drm/radeon/kms: record object that have been list reserved
drm/radeon: AGP memory is only I/O if the aperture can be mapped by the CPU.
drm/radeon/kms: don't default display priority to high on rs4xx
drm/edid: fix typo in 1600x1200@75 mode
drm/nouveau: fix i2c-related init table handlers
drm/nouveau: support init table i2c device identifier 0x81
drm/nouveau: ensure we've parsed i2c table entry for INIT_*I2C* handlers
drm/nouveau: display error message for any failed init table opcode
drm/nouveau: fix init table handlers to return proper error codes
drm/nv50: support fractional feedback divider on newer chips
drm/nv50: fix monitor detection on certain chipsets
drm/nv50: store full dcb i2c entry from vbios
drm/nv50: fix suspend/resume with DP outputs
drm/nv50: output calculated crtc pll when debugging on
drm/nouveau: dump pll limits entries when debugging is on
drm/nouveau: bios parser fixes for eDP boards
drm/nouveau: fix a nouveau_bo dereference after it's been destroyed
drm/nv40: remove some completed ctxprog TODOs
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb
* 'dbg-early-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb:
echi-dbgp: Add kernel debugger support for the usb debug port
earlyprintk,vga,kdb: Fix \b and \r for earlyprintk=vga with kdb
kgdboc: Add ekgdboc for early use of the kernel debugger
x86,early dr regs,kgdb: Allow kernel debugger early dr register access
x86,kgdb: Implement early hardware breakpoint debugging
x86, kgdb, init: Add early and late debug states
x86, kgdb: early trap init for early debug
* 'kdb-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: (25 commits)
kdb,debug_core: Allow the debug core to receive a panic notification
MAINTAINERS: update kgdb, kdb, and debug_core info
debug_core,kdb: Allow the debug core to process a recursive debug entry
printk,kdb: capture printk() when in kdb shell
kgdboc,kdb: Allow kdb to work on a non open console port
kgdb: Add the ability to schedule a breakpoint via a tasklet
mips,kgdb: kdb low level trap catch and stack trace
powerpc,kgdb: Introduce low level trap catching
x86,kgdb: Add low level debug hook
kgdb: remove post_primary_code references
kgdb,docs: Update the kgdb docs to include kdb
kgdboc,keyboard: Keyboard driver for kdb with kgdb
kgdb: gdb "monitor" -> kdb passthrough
sparc,sunzilog: Add console polling support for sunzilog serial driver
sh,sh-sci: Use NO_POLL_CHAR in the SCIF polled console code
kgdb,8250,pl011: Return immediately from console poll
kgdb: core changes to support kdb
kdb: core for kgdb back end (2 of 2)
kdb: core for kgdb back end (1 of 2)
kgdb,blackfin: Add in kgdb_arch_set_pc for blackfin
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (59 commits)
HID: fix up 'EMBEDDED' mess in Kconfig
HID: roccat: cleanup preprocessor macros
HID: roccat: refactor special event handling
HID: roccat: fix special button support
HID: roccat: Correctly mark init and exit functions
HID: hidraw: Use Interrupt Endpoint for OUT Transfers if Available
HID: hid-samsung: remove redundant key mappings
HID: add omitted hid-zydacron.c file
HID: hid-samsung: add support for Creative Desktop Wireless 6000
HID: picolcd: Eliminate use after free
HID: Zydacron Remote Control driver
HID: Use kmemdup
HID: magicmouse: fix input registration
HID: make Prodikeys driver standalone config option
HID: Prodikeys PC-MIDI HID Driver
HID: hidraw: fix indentation
HID: ntrig: add filtering module parameters
HID: ntrig: add sysfs access to filter parameters
HID: ntrig: add sensitivity and responsiveness support
HID: add multi-input quirk for eGalax Touchcontroller
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (31 commits)
dquot: Detect partial write error to quota file in write_blk() and add printk_ratelimit for quota error messages
ocfs2: Fix lock inversion in quotas during umount
ocfs2: Use __dquot_transfer to avoid lock inversion
ocfs2: Fix NULL pointer deref when writing local dquot
ocfs2: Fix estimate of credits needed for quota allocation
ocfs2: Fix quota locking
ocfs2: Avoid unnecessary block mapping when refreshing quota info
ocfs2: Do not map blocks from local quota file on each write
quota: Refactor dquot_transfer code so that OCFS2 can pass in its references
quota: unify quota init condition in setattr
quota: remove sb_has_quota_active in get/set_info
quota: unify ->set_dqblk
quota: unify ->get_dqblk
ext3: make barrier options consistent with ext4
quota: Make quota stat accounting lockless.
suppress warning: "quotatypes" defined but not used
ext3: Fix waiting on transaction during fsync
jbd: Provide function to check whether transaction will issue data barrier
ufs: add ufs speciffic ->setattr call
BKL: Remove BKL from ext2 filesystem
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
i2c-nforce2: Remove redundant error messages on ACPI conflict
i2c: Use <linux/io.h> instead of <asm/io.h>
i2c-algo-pca: Fix coding style issues
i2c-dev: Fix all coding style issues
i2c-core: Fix some coding style issues
i2c-gpio: Move initialization code to subsys_initcall()
i2c-parport: Make template structure const
i2c-dev: Remove unnecessary casts
at24: Fall back to byte or word reads if needed
i2c-stub: Expose the default functionality flags
i2c/scx200_acb: Make PCI device ids constant
i2c-i801: Fix all checkpatch warnings
i2c-i801: All newer devices have all the optional features
i2c-i801: Let the user disable selected driver features
