init_fault_attr_dentries() is used to export fault_attr via debugfs.
But it can only export it in debugfs root directory.
Per Forlin is working on mmc_fail_request which adds support to inject
data errors after a completed host transfer in MMC subsystem.
The fault_attr for mmc_fail_request should be defined per mmc host and
export it in debugfs directory per mmc host like
/sys/kernel/debug/mmc0/mmc_fail_request.
init_fault_attr_dentries() doesn't help for mmc_fail_request. So this
introduces fault_create_debugfs_attr() which is able to create a
directory in the arbitrary directory and replace
init_fault_attr_dentries().
[akpm@linux-foundation.org: extraneous semicolon, per Randy]
Tested-by: Per Forlin <per.forlin@linaro.org>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (28 commits)
ACPI: delete stale reference in kernel-parameters.txt
ACPI: add missing _OSI strings
ACPI: remove NID_INVAL
thermal: make THERMAL_HWMON implementation fully internal
thermal: split hwmon lookup to a separate function
thermal: hide CONFIG_THERMAL_HWMON
ACPI print OSI(Linux) warning only once
ACPI: DMI workaround for Asus A8N-SLI Premium and Asus A8N-SLI DELUX
ACPI / Battery: propagate sysfs error in acpi_battery_add()
ACPI / Battery: avoid acpi_battery_add() use-after-free
ACPI: introduce "acpi_rsdp=" parameter for kdump
ACPI: constify ops structs
ACPI: fix CONFIG_X86_REROUTE_FOR_BROKEN_BOOT_IRQS
ACPI: fix 80 char overflow
ACPI / Battery: Resolve the race condition in the sysfs_remove_battery()
ACPI / Battery: Add the check before refresh sysfs in the battery_notify()
ACPI / Battery: Add the hibernation process in the battery_notify()
ACPI / Battery: Rename acpi_battery_quirks2 with acpi_battery_quirks
ACPI / Battery: Change 16-bit signed negative battery current into correct value
ACPI / Battery: Add the power unit macro
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
arch/tile/mm/init.c: trivial: use BUG_ON
arch/tile: remove useless set_fixmap_nocache() macro
arch/tile: add hypervisor-based character driver for SPI flash ROM
ioctl-number.txt: add the tile hardwall ioctl range
tile: use generic-y format for one-line asm-generic headers
clocksource: tile: convert to use clocksource_register_hz
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm: (34 commits)
dm table: set flush capability based on underlying devices
dm crypt: optionally support discard requests
dm raid: add md raid1 support
dm raid: support metadata devices
dm raid: add write_mostly parameter
dm raid: add region_size parameter
dm raid: improve table parameters documentation
dm ioctl: forbid multiple device specifiers
dm ioctl: introduce __get_dev_cell
dm ioctl: fill in device parameters in more ioctls
dm flakey: add corrupt_bio_byte feature
dm flakey: add drop_writes
dm flakey: support feature args
dm flakey: use dm_target_offset and support discards
dm table: share target argument parsing functions
dm snapshot: skip reading origin when overwriting complete chunk
dm: ignore merge_bvec for snapshots when safe
dm table: clean dm_get_device and move exports
dm raid: tidy includes
dm ioctl: prevent empty message
'from-akpm', 'kexec-param' and 'misc' into release
Documentation/kernel-parameters.txt
Signed-off-by: Len Brown <len.brown@intel.com>
Says for acpi=
See also Documentation/power/pm.txt, pci=noacpi
but this file does not exist
Reported-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-linus
It's about time to revert 16d752397301b9 ("thermal: Create
CONFIG_THERMAL_HWMON=n"). Anybody running a kernel >= 2.6.40 would also
be running a recent enough version of lm-sensors.
Actually having CONFIG_THERMAL_HWMON is pretty convenient so instead of
dropping it, we keep it but hide it.
Cc: Rene Herman <rene.herman@gmail.com>
Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
Add optional parameter field to dmcrypt table and support
"allow_discards" option.
Discard requests bypass crypt queue processing. Bio is simple remapped
to underlying device.
Note that discard will be never enabled by default because of security
consequences. It is up to the administrator to enable it for encrypted
devices.
(Note that userspace cryptsetup does not understand new optional
parameters yet. Support for this will come later. Until then, you
should use 'dmsetup' to enable and disable this.)
Signed-off-by: Milan Broz <mbroz@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Add the ability to parse and use metadata devices to dm-raid. Although
not strictly required, without the metadata devices, many features of
RAID are unavailable. They are used to store a superblock and bitmap.
The role, or position in the array, of each device must be recorded in
its superblock. This is to help with fault handling, array reshaping,
and sanity checks. RAID 4/5/6 devices must be loaded in a specific order:
in this way, the 'array_position' field helps validate the correctness
of the mapping when it is loaded. It can be used during reshaping to
identify which devices are added/removed. Fault handling is impossible
without this field. For example, when a device fails it is recorded in
the superblock. If this is a RAID1 device and the offending device is
removed from the array, there must be a way during subsequent array
assembly to determine that the failed device was the one removed. This
is done by correlating the 'array_position' field and the bit-field
variable 'failed_devices'.
Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
Add the write_mostly parameter to RAID1 dm-raid tables.
This allows the user to set the WriteMostly flag on a RAID1 device that
should normally be avoided for read I/O.
Allow the user to specify the region_size.
Ensures that the supplied value meets md's constraints, viz. the number of
regions does not exceed 2^21.
Add more information about some dm-raid table parameters and clarify how
parameters are printed when 'dmsetup table' is issued.
Add corrupt_bio_byte feature to simulate corruption by overwriting a byte at a
specified position with a specified value during intervals when the device is
"down".
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Add 'drop_writes' option to drop writes silently while the
device is 'down'. Reads are not touched.
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (37 commits)
Improve slave/cyclic DMA engine documentation
dmaengine: pl08x: handle the rest of enums in pl08x_width
DMA: PL08x: cleanup selection of burst size
DMA: PL08x: avoid recalculating cctl at each prepare
DMA: PL08x: cleanup selection of buswidth
DMA: PL08x: constify plchan->cd and plat->slave_channels
DMA: PL08x: separately store source/destination cctl
DMA: PL08x: separately store source/destination slave address
DMA: PL08x: clean up LLI debugging
DMA: PL08x: select LLI bus only once per LLI setup
DMA: PL08x: remove unused constants
ARM: mxs-dma: reset after disable channel
dma: intel_mid_dma: remove redundant pci_set_drvdata calls
dma: mxs-dma: fix unterminated platform_device_id table
dmaengine: pl330: make platform data optional
dmaengine: imx-sdma: return proper error if kzalloc fails
pch_dma: Fix CTL register access issue
dmaengine: mxs-dma: skip request_irq for NO_IRQ
dmaengine/coh901318: fix slave submission semantics
dmaengine/ste_dma40: allow memory buswidth/burst to be configured
Fix trivial whitespace conflict in drivers/dma/mv_xor.c
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'pstore-efi' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
efivars: Introduce PSTORE_EFI_ATTRIBUTES
efivars: Use string functions in pstore_write
efivars: introduce utf16_strncmp
efivars: String functions
efi: Add support for using efivars as a pstore backend
pstore: Allow the user to explicitly choose a backend
pstore: Make "part" unsigned
pstore: Add extra context for writes and erases
pstore: Extend API for more flexibility in new backends
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: (24 commits)
hwmon: (lm90) Refactor reading of config2 register
hwmon: (lm90) Make SA56004 detection more robust
hwmon: (lm90) Simplify handling of extended local temp register
hwmon: (pmbus) Add client driver for LM25066, LM5064, and LM5066
hwmon: (max34440) Add support for peak attributes
hwmon: (max8688) Add support for peak attributes
hwmon: (max16064) Add support for peak attributes
hwmon: (adm1275) Add support for peak attributes
hwmon: (pmbus) Add support for peak attributes
hwmon: Add new attributes to sysfs ABI
hwmon: (pmbus) Strengthen check for status register existence
hwmon: (pmbus) Add support for virtual pages
hwmon: (pmbus) Support reading and writing of word registers in device specific code
hwmon: (pmbus) Increase attribute name size
hwmon: (pmbus) Add ADP4000, NCP4200 and NCP4208 to list of supported devices
hwmon: (pmbus) Add support for VID output voltage mode
hwmon: (pmbus) Move PMBus drivers to drivers/hwmon/pmbus
hwmon: (coretemp) Add core/pkg threshold support to Coretemp
hwmon: (lm95241) Add support for LM95231
hwmon: LM95245 driver
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (71 commits)
[SCSI] fcoe: cleanup cpu selection for incoming requests
[SCSI] fcoe: add fip retry to avoid missing critical keep alive
[SCSI] libfc: fix warn on in lport retry
[SCSI] libfc: Remove the reference to FCP packet from scsi_cmnd in case of error
[SCSI] libfc: cleanup sending SRR request
[SCSI] libfc: two minor changes in comments
[SCSI] libfc, fcoe: ignore rx frame with wrong xid info
[SCSI] libfc: release exchg cache
[SCSI] libfc: use FC_MAX_ERROR_CNT
[SCSI] fcoe: remove unused ptype field in fcoe_rcv_info
[SCSI] bnx2fc: Update copyright and bump version to 1.0.4
[SCSI] bnx2fc: Tx BDs cache in write tasks
[SCSI] bnx2fc: Do not arm CQ when there are no CQEs
[SCSI] bnx2fc: hold tgt lock when calling cmd_release
[SCSI] bnx2fc: Enable support for sequence level error recovery
[SCSI] bnx2fc: HSI changes for tape
[SCSI] bnx2fc: Handle REC_TOV error code from firmware
[SCSI] bnx2fc: REC/SRR link service request and response handling
[SCSI] bnx2fc: Support 'sequence cleanup' task
[SCSI] dh_rdac: Associate HBA and storage in rdac_controller to support partitions in storage
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (430 commits)
[media] ir-mce_kbd-decoder: include module.h for its facilities
[media] ov5642: include module.h for its facilities
[media] em28xx: Fix DVB-C maxsize for em2884
[media] tda18271c2dd: Fix saw filter configuration for DVB-C @6MHz
[media] v4l: mt9v032: Fix Bayer pattern
[media] V4L: mt9m111: rewrite set_pixfmt
[media] V4L: mt9m111: fix missing return value check mt9m111_reg_clear
[media] V4L: initial driver for ov5642 CMOS sensor
[media] V4L: sh_mobile_ceu_camera: fix Oops when USERPTR mapping fails
[media] V4L: soc-camera: remove soc-camera bus and devices on it
[media] V4L: soc-camera: un-export the soc-camera bus
[media] V4L: sh_mobile_csi2: switch away from using the soc-camera bus notifier
[media] V4L: add media bus configuration subdev operations
[media] V4L: soc-camera: group struct field initialisations together
[media] V4L: soc-camera: remove now unused soc-camera specific PM hooks
[media] V4L: pxa-camera: switch to using standard PM hooks
[media] NetUP Dual DVB-T/C CI RF: force card hardware revision by module param
[media] Don't OOPS if videobuf_dvb_get_frontend return NULL
[media] NetUP Dual DVB-T/C CI RF: load firmware according card revision
[media] omap3isp: Support configurable HS/VS polarities
Fix up conflicts:
- arch/arm/mach-omap2/board-rx51-peripherals.c:
cleanup regulator supply definitions in mach-omap2
vs
OMAP3: RX-51: define vdds_csib regulator supply
- drivers/staging/tm6000/tm6000-alsa.c (trivial)
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (21 commits)
arm/dt: tegra devicetree support
arm/versatile: Add device tree support
dt/irq: add irq_domain_generate_simple() helper
irq: add irq_domain translation infrastructure
dmaengine: imx-sdma: add device tree probe support
dmaengine: imx-sdma: sdma_get_firmware does not need to copy fw_name
dmaengine: imx-sdma: use platform_device_id to identify sdma version
mmc: sdhci-esdhc-imx: add device tree probe support
mmc: sdhci-pltfm: dt device does not pass parent to sdhci_alloc_host
mmc: sdhci-esdhc-imx: get rid of the uses of cpu_is_mx()
mmc: sdhci-esdhc-imx: do not reference platform data after probe
mmc: sdhci-esdhc-imx: extend card_detect and write_protect support for mx5
net/fec: add device tree probe support
net: ibm_newemac: convert it to use of_get_phy_mode
dt/net: add helper function of_get_phy_mode
net/fec: gasket needs to be enabled for some i.mx
serial/imx: add device tree probe support
serial/imx: get rid of the uses of cpu_is_mx1()
arm/dt: Add dtb make rule
arm/dt: Add skeleton dtsi file
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-watchdog: (25 commits)
watchdog: WatchDog Timer Driver Core - Add minimum and max timeout
watchdog: WatchDog Timer Driver Core - Add ioctl call
watchdog: WatchDog Timer Driver Core - Add nowayout feature
watchdog: WatchDog Timer Driver Core - Add Magic Close feature
watchdog: WatchDog Timer Driver Core - Add WDIOC_SETTIMEOUT and WDIOC_GETTIMEOUT ioctl
watchdog: WatchDog Timer Driver Core - Add WDIOC_SETOPTIONS ioctl
watchdog: WatchDog Timer Driver Core - Add WDIOC_KEEPALIVE ioctl
watchdog: WatchDog Timer Driver Core - Add basic ioctl functionality
watchdog: WatchDog Timer Driver Core - Add basic framework
watchdog: hpwdt: add next gen HP servers
watchdog: it8712f_wdt.c: improve includes
watchdog: at91sam9/wdt: move register header to drivers
watchdog: Add Xilinx watchdog timer driver
watchdog: remove empty pm-functions
watchdog: sp805: Flush posted writes in enable/disable.
watchdog: sp805: Don't write 0 to the load value register.
watchdog: imx2_wdt: add device tree probe support
watchdog: s3c2410: Add support for device tree based probe
watchdog: mpcore_wdt: Add suspend/resume support.
watchdog: mtx1-wdt: use dev_{err,info} instead of printk()
PMBus client driver supporting National Semiconductor LM25066, LM5064, and LM5066.
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
Add support for voltage, current, and temperature peak (historic maximum)
attributes.
attributes.
Add support for voltage and temperature peak (historic maximum) attributes.
Add support for voltage and current peak (historic maximum) attributes.
Add the following attributes to the sysfs ABI.
in[0-*]_average
in[0-*]_lowest
in[0-*]_highest
in[0-*]_reset_history
in_reset_history
curr[1-*]_average
curr[1-*]_lowest
curr[1-*]_highest
curr[1-*]_reset_history
curr_reset_history
Add ADP4000, NCP4200 and NCP4208 to the list of devices supported by the generic
PMBus driver, and add device IDs to enable explicit instantiation.
Acked-by: Jean Delvare <khali@linux-fr.org>
* 'for-linus' of git://neil.brown.name/md: (75 commits)
md/raid10: handle further errors during fix_read_error better.
md/raid10: Handle read errors during recovery better.
md/raid10: simplify read error handling during recovery.
md/raid10: record bad blocks due to write errors during resync/recovery.
md/raid10: attempt to fix read errors during resync/check
md/raid10: Handle write errors by updating badblock log.
md/raid10: clear bad-block record when write succeeds.
md/raid10: avoid writing to known bad blocks on known bad drives.
md/raid10 record bad blocks as needed during recovery.
md/raid10: avoid reading known bad blocks during resync/recovery.
md/raid10 - avoid reading from known bad blocks - part 3
md/raid10: avoid reading from known bad blocks - part 2
md/raid10: avoid reading from known bad blocks - part 1
md/raid10: Split handle_read_error out from raid10d.
md/raid10: simplify/reindent some loops.
md/raid5: Clear bad blocks on successful write.
md/raid5. Don't write to known bad block on doubtful devices.
md/raid5: write errors should be recorded as bad blocks if possible.
md/raid5: use bad-block log to improve handling of uncorrectable read errors.
md/raid5: avoid reading from known bad blocks.
Add min_timeout (minimum timeout) and max_timeout
values so that the framework can check if the new
timeout value is between the minimum and maximum
timeout values. If both values are 0, then the
framework will leave the check for the watchdog
device driver itself.
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Add support for extra ioctl calls by adding a
ioctl watchdog operation. This operation will be
called before we do our own handling of ioctl
commands. This way we can override the internal
ioctl command handling and we can also add
extra ioctl commands. The ioctl watchdog operation
should return the appropriate error codes or
-ENOIOCTLCMD if the ioctl command should be handled
through the internal ioctl handling of the framework.
Add support for the nowayout feature to the
WatchDog Timer Driver Core framework.
This feature prevents the watchdog timer from being
stopped.
Add support for the Magic Close feature to the
This part add's the WDIOC_SETTIMEOUT and WDIOC_GETTIMEOUT ioctl
functionality to the WatchDog Timer Driver Core framework.
This part add's the WDIOC_SETOPTIONS ioctl functionality
This part add's the WDIOC_KEEPALIVE ioctl functionality to the
WatchDog Timer Driver Core framework. Please note that the
WDIOF_KEEPALIVEPING bit has to be set in the watchdog_info
options field.
This part add's the basic ioctl functionality to the
WatchDog Timer Driver Core framework. The supported
ioctl call's are:
WDIOC_GETSUPPORT
WDIOC_GETSTATUS
WDIOC_GETBOOTSTATUS
The WatchDog Timer Driver Core is a framework
that contains the common code for all watchdog-driver's.
It also introduces a watchdog device structure and the
operations that go with it.
This is the introduction of this framework. This part
supports the minimal watchdog userspace API (or with
other words: the functionality to use /dev/watchdog's
open, release and write functionality as defined in
the simplest watchdog API). Extra functionality will
follow in the next set of patches.
For testing the dt work, define a dt-enabled versatile platform.
This patch adds a new versatile platform for when using the device
tree. Add platform and amba devices are discovered and registered by
parsing the device tree. Clocks and initial io mappings are still
configured statically.
This patch still depends on some static platform_data for a few devices
which is passed via the auxdata structure to of_platform_populate(),
but it is a viable starting point until the drivers can get all
configuration data out of the device tree.
This patch adds the core and pkg support to coretemp.
These thresholds can be configured via the sysfs interfaces tempX_max
and tempX_max_hyst. An interrupt is generated when CPU temperature reaches
or crosses above tempX_max OR drops below tempX_max_hyst.
This patch is based on the documentation in IA Manual vol 3A, that can be
downloaded from here:
http://download.intel.com/design/processor/manuals/253668.pdf
Signed-off-by: Durgadoss R <durgadoss.r@intel.com>
A hwmon driver for the National Semiconductor LM95245 dual temperature
sensors chip.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
Add support for Philips SA56004, an LM86 compatible temperature sensor.
Signed-off-by: Stijn Devriendt <sdevrien@cisco.com>
Add support for NTC Thermistor series. In this release, the
following thermistors are supported: NCP15WB473, NCP18WB473, NCP03WB473,
and NCP15WL333. This driver is based on the datasheet of MURATA.
The driver in the patch does conversion from the raw ADC value
(either voltage or resistence) to temperature. In order to use
voltage values as input, the circuit schematics should be provided
with the platform data. A compensation table for each type of thermistor
is provided for the conversion.
Signed-off-by: Donggeun Kim <dg77.kim@samsung.com>
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
Signed-off-by: KyungMin Park <kyungmin.park@samsung.com>
Reviewed-by: Shubhrajyoti D <shubhrajyoti@ti.com>
This patch adds support for MAX1668 and compatible temperature sensors.
Signed-off-by: David George <david.george@ska.ac.za>
[guenter.roeck@ericsson.com: minor cleanup of probe error path]
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (54 commits)
tpm_nsc: Fix bug when loading multiple TPM drivers
tpm: Move tpm_tis_reenable_interrupts out of CONFIG_PNP block
tpm: Fix compilation warning when CONFIG_PNP is not defined
TOMOYO: Update kernel-doc.
tpm: Fix a typo
tpm_tis: Probing function for Intel iTPM bug
tpm_tis: Fix the probing for interrupts
tpm_tis: Delay ACPI S3 suspend while the TPM is busy
tpm_tis: Re-enable interrupts upon (S3) resume
tpm: Fix display of data in pubek sysfs entry
tpm_tis: Add timeouts sysfs entry
tpm: Adjust interface timeouts if they are too small
tpm: Use interface timeouts returned from the TPM
tpm_tis: Introduce durations sysfs entry
tpm: Adjust the durations if they are too small
tpm: Use durations returned from TPM
TOMOYO: Enable conditional ACL.
TOMOYO: Allow using argv[]/envp[] of execve() as conditions.
TOMOYO: Allow using executable's realpath and symlink's target as conditions.
TOMOYO: Allow using owner/group etc. of file objects as conditions.
Fix up trivial conflict in security/tomoyo/realpath.c
Previous patches in the bad block series extended behavior of
rdev's 'state' interface but lacked documentation update.
Fix it.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Signed-off-by: NeilBrown <neilb@suse.de>
Previous patch in the bad block series added new sysfs interfaces
([unacknowledged_]bad_blocks) for each rdev without documentation.
Add it.
Use a name convention for the firmware file that matches on the
current firmware namespacing. Also, add it to the firmware
download script.
