path: root/Documentation
2014-07-03mm:vmscan: update the trace-vmscan-postprocess.pl for event ↵Chen Yucong
vmscan/mm_vmscan_lru_isolate When using trace-vmscan-postprocess.pl for checking the file/anon rate of scanning, we can find that it can not be performed. At the same time, the following message will be reported: WARNING: Format not as expected for event vmscan/mm_vmscan_lru_isolate 'file' != 'contig_taken' Fewer fields than expected in format at ./trace-vmscan-postprocess.pl line 171, <FORMAT> line 76. In trace-vmscan-postprocess.pl, (contig_taken, contig_dirty, and contig_failed) are be associated respectively to (nr_lumpy_taken, nr_lumpy_dirty, and nr_lumpy_failed) for lumpy reclaim. Via commit c53919adc045 ("mm: vmscan: remove lumpy reclaim"), lumpy reclaim had already been removed by Mel, but the update for trace-vmscan-postprocess.pl was missed. Signed-off-by: Chen Yucong <slaoub@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-29Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "Another round of ARM fixes. The largest change here is the L2 changes to work around problems for the Armada 37x/380 devices, where most of the size comes down to comments rather than code. The other significant fix here is for the ptrace code, to ensure that rewritten syscalls work as intended. This was pointed out by Kees Cook, but Will Deacon reworked the patch to be more elegant. The remainder are fairly trivial changes" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: 8087/1: ptrace: reload syscall number after secure_computing() check ARM: 8086/1: Set memblock limit for nommu ARM: 8085/1: sa1100: collie: add top boot mtd partition ARM: 8084/1: sa1100: collie: revert back to cfi_probe ARM: 8080/1: mcpm.h: remove unused variable declaration ARM: 8076/1: mm: add support for HW coherent systems in PL310 cache
2014-06-29Documentation: add section about git to email-clients.txtDan Carpenter
These days most people use git to send patches so I have added a section about that. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-29ARM: 8076/1: mm: add support for HW coherent systems in PL310 cacheThomas Petazzoni
When a PL310 cache is used on a system that provides hardware coherency, the outer cache sync operation is useless, and can be skipped. Moreover, on some systems, it is harmful as it causes deadlocks between the Marvell coherency mechanism, the Marvell PCIe controller and the Cortex-A9. To avoid this, this commit introduces a new Device Tree property 'arm,io-coherent' for the L2 cache controller node, valid only for the PL310 cache. It identifies the usage of the PL310 cache in an I/O coherent configuration. Internally, it makes the driver disable the outer cache sync operation. Note that technically speaking, a fully coherent system wouldn't require any of the other .outer_cache operations. However, in practice, when booting secondary CPUs, these are not yet coherent, and therefore a set of cache maintenance operations are necessary at this point. This explains why we keep the other .outer_cache operations and only ->sync is disabled. While in theory any write to a PL310 register could cause the deadlock, in practice, disabling ->sync is sufficient to workaround the deadlock, since the other cache maintenance operations are only used in very specific situations. Contrary to previous versions of this patch, this new version does not simply NULL-ify the ->sync member, because the l2c_init_data structures are now 'const' and therefore cannot be modified, which is a good thing. Therefore, this patch introduces a separate l2c_init_data instance, called of_l2c310_coherent_data. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-06-28Merge tag 'spi-v3.16-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi Pull spi fixes from Mark Brown: "A few driver specific fixes, the biggest one being a fix for the newly added Qualcomm SPI controller driver to make it not use its internal chip select due to hardware bugs, replacing it with GPIOs" * tag 'spi-v3.16-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: spi: qup: Remove chip select function spi: qup: Fix order of spi_register_master spi: sh-sci: fix use-after-free in sh_sci_spi_remove() spi/pxa2xx: fix incorrect SW mode chipselect setting for BayTrail LPSS SPI
2014-06-28Merge remote-tracking branches 'spi/fix/pxa2xx', 'spi/fix/qup' and ↵Mark Brown
'spi/fix/sh-sci' into spi-linus
2014-06-27Merge tag 'sound-3.16-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Here includes a few patchset for fixing mostly HD-audio issues in addition to a patch assuring the compress API bytes alignment and a fix for the die-hard existing race condition at USB-audio disconnection. The volume looks big in Realtek HD-audio code, but it's just a translation of the fixup tables, and the actual changes are rather trivial" * tag 'sound-3.16-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - restore BCLK M/N values when resuming HSW/BDW display controller ALSA: usb-audio: Fix races at disconnection and PCM closing ALSA: hda - Adjust speaker HPF and add LED support for HP Spectre 13 ALSA: hda - Make the pin quirk tables use the SND_HDA_PIN_QUIRK macro ALSA: hda - Make a SND_HDA_PIN_QUIRK macro ALSA: hda - Add pin quirk for Dell XPS 15 ALSA: hda - hdmi: call overridden init on resume ALSA: hda - Fix usage of "model" module parameter ALSA: compress: fix the struct alignment to 4 bytes
2014-06-25Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon fixes from Guenter Roeck: "Various minor fixes" * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (gpio-fan) Change name used in hwmon_device_register_with_groups hwmon: (emc1403) Fix missing 'select REGMAP_I2C' in Kconfig hwmon: (ntc_thermistor) Use the manufacturer name properly devicetree: bindings: Document murata vendor prefix hwmon: (w83l786ng) Report correct minimum fan speed
2014-06-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix crash in ipvs tot_stats estimator, from Julian Anastasov. 2) Fix OOPS in nf_nat on netns removal, from Florian Westphal. 3) Really really really fix locking issues in slip and slcan tty write wakeups, from Tyler Hall. 4) Fix checksum offloading in fec driver, from Fugang Duan. 5) Off by one in BPF instruction limit test, from Kees Cook. 6) Need to clear all TSO capability flags when doing software TSO in tg3 driver, from Prashant Sreedharan. 7) Fix memory leak in vlan_reorder_header() error path, from Li RongQing. 8) Fix various bugs in xen-netfront and xen-netback multiqueue support, from David Vrabel and Wei Liu. 9) Fix deadlock in cxgb4 driver, from Li RongQing. 10) Prevent double free of no-cache DST entries, from Eric Dumazet. 11) Bad csum_start handling in skb_segment() leads to crashes when forwarding, from Tom Herbert. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (76 commits) net: fix setting csum_start in skb_segment() ipv4: fix dst race in sk_dst_get() net: filter: Use kcalloc/kmalloc_array to allocate arrays trivial: net: filter: Change kerneldoc parameter order trivial: net: filter: Fix typo in comment net: allwinner: emac: Add missing free_irq cxgb4: use dev_port to identify ports xen-netback: bookkeep number of active queues in our own module tg3: Change nvram command timeout value to 50ms cxgb4: Not need to hold the adap_rcu_lock lock when read adap_rcu_list be2net: fix qnq mode detection on VFs of: mdio: fixup of_phy_register_fixed_link parsing of new bindings at86rf230: fix irq setup net: phy: at803x: fix coccinelle warnings net/mlx4_core: Fix the error flow when probing with invalid VF configuration tulip: Poll link status more frequently for Comet chips net: huawei_cdc_ncm: increase command buffer size drivers: net: cpsw: fix dual EMAC stall when connected to same switch xen-netfront: recreate queues correctly when reconnecting xen-netfront: fix oops when disconnected from backend ...
2014-06-25Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Arnd Bergmann: "A new set of bug fixes for 3.16, containing patches for seven platforms: at91: - drivers/misc fix for Kconfig PWM symbol - correction of several values in DT after conversion to CCF - fix at91sam9261/at91sam9261ek mistake in slow crystal vs. slow RC osc imx: - Use GPIO for card CD/WP on imx51-babbage and eukrea-mbimxsd51, because controller base CD/WP is not working in esdhc driver due to runtime PM support - A couple of random ventana gw5xxx board fixes - Add IMX_IPUV3_CORE back to defconfig, which gets lost when moving IPUv3 driver out of staging tree - Fix enet/fec clock selection on imx6sl - Fix display node on imx53-m53evk board - A couple of Cubox-i updates from Russell, which were omitted from the merge window due to dependency integrator: - fix an OF-related regression against 3.15 mvebu: - mvebu (v7) - Fix broken SoC ID detection - Select ARM_CPU_SUSPEND for v7 - Remove armada38x compatible string (no users yet) - Enable Dove SoC in mvebu_v7_defconfig - kirkwood - Fix phy-connection-type on GuruPlug board qcom: - enable gsbi driver in defconfig - fix section mismatch warning in serial driver samsung: - use WFI macro in platform_do_lowpower because exynos cpuhotplug includes a hardcoded WFI instruction and it causes compile error in Thumb-2 mode. - fix GIC reg sizes for exynos4 SoCs - remove reset timer counter value during boot and resume for mct to fix a big jump in printk timestamps - fix pm code to check cortex-A9 for another exynos SoCs - don't rely on firmware's secondary_cpu_start for mcpm sti: - Ethernet clocks were wrongly defined for STiH415/416 platforms - STiH416 B2020 revision E DTS file name contained uppercase, change to lowercase" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (33 commits) ARM: at91/dt: sam9261: remove slow RC osc ARM: at91/dt: define sam9261ek slow crystal frequency ARM: at91/dt: sam9261: correctly define mainck ARM: at91/dt: sam9n12: correct PLLA ICPLL and OUT values ARM: at91/dt: sam9x5: correct PLLA ICPLL and OUT values misc: atmel_pwm: fix Kconfig symbols ARM: integrator: fix OF-related regression ARM: mvebu: Fix the improper use of the compatible string armada38x using a wildcard ARM: dts: kirkwood: fix phy-connection-type for Guruplug ARM: EXYNOS: Don't rely on firmware's secondary_cpu_start for mcpm ARM: dts: imx51-eukrea-mbimxsd51-baseboard: unbreak esdhc. ARM: dts: imx51-babbage: Fix esdhc setup ARM: dts: mx5: Move the display out of soc {} node ARM: dts: mx5: Fix IPU port node placement ARM: mvebu: select ARM_CPU_SUSPEND for Marvell EBU v7 platforms ARM: mvebu: Fix broken SoC ID detection ARM: imx_v6_v7_defconfig: Enable CONFIG_IMX_IPUV3_CORE ARM: multi_v7_defconfig: Add QCOM GSBI driver ARM: stih41x: Rename stih416-b2020-revE.dts to stih416-b2020e.dts tty: serial: msm: Fix section mismatch warning ...
2014-06-25ALSA: hda - Adjust speaker HPF and add LED support for HP Spectre 13Takashi Iwai
HP Spectre 13 has the IDT 92HD95 codec, and BIOS seems to set the default high-pass filter in some "safer" range, which results in the very soft tone from the built-in speakers in contrast to Windows. Also, the mute LED control is missing, since 92HD95 codec still has no HP-specific fixups for GPIO setups. This patch adds these missing features: the HPF is adjusted by the vendor-specific verb, and the LED is set up from a DMI string (but with the default polarity = 0 assumption due to the incomplete BIOS on the given machine). Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=74841 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-06-25hwmon: (ntc_thermistor) Use the manufacturer name properlyNaveen Krishna Chatradhi
Murata Manufacturing Co., Ltd is the vendor for NTC (Negative Temperature coefficient) based Thermistors. But, the driver extensively uses "NTC" as the vendor name. This patch corrects the vendor name also updates the compatibility strings according to the vendor-prefix.txt Note: Drivers continue to support the previous compatible strings but further addition of these compatible strings in device tree is deprecated. Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-06-25devicetree: bindings: Document murata vendor prefixNaveen Krishna Chatradhi
Add Murata Manufacturing Co., Ltd. to the list of device tree vendor prefixes. Murata manufactures NTC (Negative Temperature Coefficient) based Thermistors for small scale applications like Mobiles and PDAs. Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-06-24ARM: mvebu: Fix the improper use of the compatible string armada38x using a ↵Gregory CLEMENT
wildcard Wildcards in compatible strings should be avoid. "marvell,armada38x" was recently introduced but was not yet used. The armada 385 SoC is a superset of the armada 380 SoC (with more CPUs and more PCIe slots). So this patch replaces the use of "marvell,armada38x" by the "marvell,armada380" string. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Link: https://lkml.kernel.org/r/1403533011-21339-1-git-send-email-gregory.clement@free-electrons.com Acked-by: Andrew Lunn <andrew@lunn.ch> Cc: <stable@vger.kernel.org> # v3.15+ Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-23kernel/watchdog.c: print traces for all cpus on lockup detectionAaron Tomlin
A 'softlockup' is defined as a bug that causes the kernel to loop in kernel mode for more than a predefined period to time, without giving other tasks a chance to run. Currently, upon detection of this condition by the per-cpu watchdog task, debug information (including a stack trace) is sent to the system log. On some occasions, we have observed that the "victim" rather than the actual "culprit" (i.e. the owner/holder of the contended resource) is reported to the user. Often this information has proven to be insufficient to assist debugging efforts. To avoid loss of useful debug information, for architectures which support NMI, this patch makes it possible to improve soft lockup reporting. This is accomplished by issuing an NMI to each cpu to obtain a stack trace. If NMI is not supported we just revert back to the old method. A sysctl and boot-time parameter is available to toggle this feature. [dzickus@redhat.com: add CONFIG_SMP in certain areas] [akpm@linux-foundation.org: additional CONFIG_SMP=n optimisations] [mq@suse.cz: fix warning] Signed-off-by: Aaron Tomlin <atomlin@redhat.com> Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: David S. Miller <davem@davemloft.net> Cc: Mateusz Guzik <mguzik@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Jan Moskyto Matejka <mq@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-23Documentation/accounting/getdelays.c: add missing null-terminate after ↵Rickard Strandqvist
strncpy call Added a guaranteed null-terminate after call to strncpy. This was partly found using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-23mm, pcp: allow restoring percpu_pagelist_fraction defaultDavid Rientjes
Oleg reports a division by zero error on zero-length write() to the percpu_pagelist_fraction sysctl: divide error: 0000 [#1] SMP DEBUG_PAGEALLOC CPU: 1 PID: 9142 Comm: badarea_io Not tainted 3.15.0-rc2-vm-nfs+ #19 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 task: ffff8800d5aeb6e0 ti: ffff8800d87a2000 task.ti: ffff8800d87a2000 RIP: 0010: percpu_pagelist_fraction_sysctl_handler+0x84/0x120 RSP: 0018:ffff8800d87a3e78 EFLAGS: 00010246 RAX: 0000000000000f89 RBX: ffff88011f7fd000 RCX: 0000000000000000 RDX: 0000000000000000 RSI: 0000000000000001 RDI: 0000000000000010 RBP: ffff8800d87a3e98 R08: ffffffff81d002c8 R09: ffff8800d87a3f50 R10: 000000000000000b R11: 0000000000000246 R12: 0000000000000060 R13: ffffffff81c3c3e0 R14: ffffffff81cfddf8 R15: ffff8801193b0800 FS: 00007f614f1e9740(0000) GS:ffff88011f440000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00007f614f1fa000 CR3: 00000000d9291000 CR4: 00000000000006e0 Call Trace: proc_sys_call_handler+0xb3/0xc0 proc_sys_write+0x14/0x20 vfs_write+0xba/0x1e0 SyS_write+0x46/0xb0 tracesys+0xe1/0xe6 However, if the percpu_pagelist_fraction sysctl is set by the user, it is also impossible to restore it to the kernel default since the user cannot write 0 to the sysctl. This patch allows the user to write 0 to restore the default behavior. It still requires a fraction equal to or larger than 8, however, as stated by the documentation for sanity. If a value in the range [1, 7] is written, the sysctl will return EINVAL. This successfully solves the divide by zero issue at the same time. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Oleg Drokin <green@linuxhacker.ru> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-23mm, hotplug: probe interface is available on several platformsDavid Rientjes
Documentation/memory-hotplug.txt incorrectly states that the memory driver "probe" interface is only supported on powerpc and is vague about its application on x86. Clarify the platforms that make this interface available if memory hotplug is enabled. Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-22spi: qup: Remove chip select functionAndy Gross
This patch removes the chip select function. Chip select should instead be supported using GPIOs, defining the DT entry "cs-gpios", and letting the SPI core assert/deassert the chip select as it sees fit. The chip select control inside the controller is buggy. It is supposed to automatically assert the chip select based on the activity in the controller, but it is buggy and doesn't work at all. So instead we elect to use GPIOs. Signed-off-by: Andy Gross <agross@codeaurora.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-21Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c new drivers from Wolfram Sang: "Here is a pull request from i2c hoping for the "new driver" rule. Originally, I wanted to send this request during the merge window, but code checkers with very recent additions complained, so a few fixups were needed. So, some more time went by and I merged rc1 to get a stable base" So the "new driver" rule is really about drivers that people absolutely need for the kernel to work on new hardware, which is not so much the case for i2c. So I considered not pulling this, but eventually relented. Just for FYI: the whole (and only) point of "new drivers" is not that new drivers cannot regress things (they can, and they have - by triggering badly tested code on machines that never triggered that code before), but because they can bring to life machines that otherwise wouldn't be useful at all without the drivers. So the new driver rule is for essential things that actual consumers would care about, ie devices like networking or disk drivers that matter to normal people (not server people - they run old kernels anyway, so mainlining new drivers is irrelevant for them). * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: sun6-p2wi: fix call to snprintf i2c: rk3x: add NULL entry to the end of_device_id array i2c: sun6i-p2wi: use proper return value in probe i2c: sunxi: add P2WI (Push/Pull 2 Wire Interface) controller support i2c: sunxi: add P2WI DT bindings documentation i2c: rk3x: add driver for Rockchip RK3xxx SoC I2C adapter
2014-06-21Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild fixes from Michal Marek: "There are three fixes for regressions caused by the relative paths series: deb-pkg, tar-pkg and *docs did not work with O=. Plus, there is a fix for the linux-headers deb package and a fixed typo. These are not regression fixes but are safe enough" * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: fix a typo in a kbuild document builddeb: fix missing headers in linux-headers package Documentation: Fix DocBook build with relative $(srctree) kbuild: Fix tar-pkg with relative $(objtree) deb-pkg: Fix for relative paths
2014-06-19Merge tag 'pm+acpi-3.16-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: "These are fixes mostly (ia64 regression related to the ACPI enumeration of devices, cpufreq regressions, fix for I2C controllers included in Intel SoCs, mvebu cpuidle driver fix related to sysfs) plus additional kernel command line arguments from Kees to make it possible to build kernel images with hibernation and the kernel address space randomization included simultaneously, a new ACPI battery driver quirk for a system with a broken BIOS and a couple of ACPI core cleanups. Specifics: - Fix for an ia64 regression introduced during the 3.11 cycle by a commit that modified the hardware initialization ordering and made device discovery fail on some systems. - Fix for a build problem on systems where the cpufreq-cpu0 driver is built-in and the cpu-thermal driver is modular from Arnd Bergmann. - Fix for a recently introduced computational mistake in the intel_pstate driver that leads to excessive rounding errors from Doug Smythies. - Fix for a failure code path in cpufreq_update_policy() that fails to unlock the locks acquired previously from Aaron Plattner. - Fix for the cpuidle mvebu driver to use shorter state names which will prevent the sysfs interface from returning mangled strings. From Gregory Clement. - ACPI LPSS driver fix to make sure that the I2C controllers included in BayTrail SoCs are not held in the reset state while they are being probed from Mika Westerberg. - New kernel command line arguments making it possible to build kernel images with hibernation and kASLR included at the same time and to select which of them will be used via the command line (they are still functionally mutually exclusive, though). From Kees Cook. - ACPI battery driver quirk for Acer Aspire V5-573G that fails to send battery status change notifications timely from Alexander Mezin. - Two ACPI core cleanups from Christoph Jaeger and Fabian Frederick" * tag 'pm+acpi-3.16-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: cpuidle: mvebu: Fix the name of the states cpufreq: unlock when failing cpufreq_update_policy() intel_pstate: Correct rounding in busy calculation ACPI: use kstrto*() instead of simple_strto*() ACPI / processor replace __attribute__((packed)) by __packed ACPI / battery: add quirk for Acer Aspire V5-573G ACPI / battery: use callback for setting up quirks ACPI / LPSS: Take I2C host controllers out of reset x86, kaslr: boot-time selectable with hibernation PM / hibernate: introduce "nohibernate" boot parameter cpufreq: cpufreq-cpu0: fix CPU_THERMAL dependency ACPI / ia64 / sba_iommu: Restore the working initialization ordering
2014-06-18kbuild: fix a typo in a kbuild documentMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-06-18Documentation: Fix DocBook build with relative $(srctree)Michal Marek
After commits 890676c6 (kbuild: Use relative path when building in the source tree) and 9da0763b (kbuild: Use relative path when building in a subdir of the source tree), the $(srctree) variable can be a relative path. This breaks Documentation/DocBook/media/Makefile, because it tries to create symlinks from a subdirectory of the object tree to the source tree. Fix this by using a full path in this case. Reported-by: Randy Dunlap <rdunlap@infradead.org> Acked-by: Randy Dunlap <rdunlap@infradead.org> Tested-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-06-17Merge tag 'v3.16-rc1' into i2c/for-nextWolfram Sang
Merge a stable base (Linux 3.16-rc1) Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-06-17Merge branch 'drm-nouveau-next' of ↵Dave Airlie
git://anongit.freedesktop.org/git/nouveau/linux-2.6 into drm-next This is bigger because it regenerates the internal firmwares after a fix. * 'drm-nouveau-next' of git://anongit.freedesktop.org/git/nouveau/linux-2.6: drm/nouveau/doc: update the thermal documentation drm/nouveau/pwr: fix typo in fifo wrap handling drm/nv50/disp: fix a potential oops in supervisor handling drm/nouveau/disp/dp: don't touch link config after success drm/nouveau/kms: reference vblank for crtc during pageflip. drm/gk104/fb/ram: fixups from an earlier search+replace drm/nv50/gr: remove an unneeded write while initialising PGRAPH drm/nv50/gr: fix overlap while zeroing zcull regions drm/gf100-/gr: report class data to host on fwmthd failure drm/gk104/ibus: increase various random timeouts drm/gk104/clk: only touch divider for mode we'll be using
2014-06-17drm/nouveau/doc: update the thermal documentationMartin Peres
Changes: - Change the maintainer's address (the labri address will expire soon); - Drop the note about not all families supporting all fan modes; - Add a note about the reported RPM not being accurate when driven outside the vbios-defined PWM range. Signed-off-by: Martin Peres <martin.peres@free.fr> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2014-06-16ptp: In the testptp utility, use clock_adjtime from glibc when availableChristian Riesch
clock_adjtime was included in glibc 2.14. _GNU_SOURCE must be defined to make it available. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Richard Cochran <richardcochran@gmail.com> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-16x86, kaslr: boot-time selectable with hibernationKees Cook
Changes kASLR from being compile-time selectable (blocked by CONFIG_HIBERNATION), to being boot-time selectable (with hibernation available by default) via the "kaslr" kernel command line. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-06-16PM / hibernate: introduce "nohibernate" boot parameterKees Cook
To support using kernel features that are not compatible with hibernation, this creates the "nohibernate" kernel boot parameter to disable both hibernation and resume. This allows hibernation support to be a boot-time choice instead of only a compile-time choice. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-06-15Merge tag 'clk-for-linus-3.16-part2' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull more clock framework updates from Mike Turquette: "This contains the second half the of the clk changes for 3.16. They are simply fixes and code refactoring for the OMAP clock drivers. The sunxi clock driver changes include splitting out the one mega-driver into several smaller pieces and adding support for the A31 SoC clocks" * tag 'clk-for-linus-3.16-part2' of git://git.linaro.org/people/mike.turquette/linux: (25 commits) clk: sunxi: document PRCM clock compatible strings clk: sunxi: add PRCM (Power/Reset/Clock Management) clks support clk: sun6i: Protect SDRAM gating bit clk: sun6i: Protect CPU clock clk: sunxi: Rework clock protection code clk: sunxi: Move the GMAC clock to a file of its own clk: sunxi: Move the 24M oscillator to a file of its own clk: sunxi: Remove calls to clk_put clk: sunxi: document new A31 USB clock compatible clk: sunxi: Implement A31 USB clock ARM: dts: OMAP5/DRA7: use omap5-mpu-dpll-clock capable of dealing with higher frequencies CLK: TI: dpll: support OMAP5 MPU DPLL that need special handling for higher frequencies ARM: OMAP5+: dpll: support Duty Cycle Correction(DCC) CLK: TI: clk-54xx: Set the rate for dpll_abe_m2x2_ck CLK: TI: Driver for DRA7 ATL (Audio Tracking Logic) dt:/bindings: DRA7 ATL (Audio Tracking Logic) clock bindings ARM: dts: dra7xx-clocks: Correct name for atl clkin3 clock CLK: TI: gate: add composite interface clock to OMAP2 only build ARM: OMAP2: clock: add DT boot support for cpufreq_ck CLK: TI: OMAP2: add clock init support ...
2014-06-14Merge branch 'x86-vdso-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 vdso fixes from Peter Anvin: "Fixes for x86/vdso. One is a simple build fix for bigendian hosts, one is to make "make vdso_install" work again, and the rest is about working around a bug in Google's Go language -- two are documentation patches that improves the sample code that the Go coders took, modified, and broke; the other two implements a workaround that keeps existing Go binaries from segfaulting at least" * 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/vdso: Fix vdso_install x86/vdso: Hack to keep 64-bit Go programs working x86/vdso: Add PUT_LE to store little-endian values x86/vdso/doc: Make vDSO examples more portable x86/vdso/doc: Rename vdso_test.c to vdso_standalone_test_x86.c x86, vdso: Remove one final use of htole16()
2014-06-14Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon updates from Guenter Roeck: - new driver for Sensirion SHTC1 humidity / temperature sensor - convert ltc4151 and vexpress drivers to use devm functions - drop generic chip detection from lm85 driver - avoid forward declarations in atxp1 driver - fix sign extensions in ina2xx driver * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: vexpress: Use devm helper for hwmon device registration hwmon: (atxp1) Avoid forward declaration hwmon: add support for Sensirion SHTC1 sensor hwmon: (ltc4151) Convert to devm_hwmon_device_register_with_groups hwmon: (lm85) Drop generic detection hwmon: (ina2xx) Cast to s16 on shunt and current regs
2014-06-12Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild misc updates from Michal Marek: "This is the non-critical part of kbuild for v3.16-rc1: - make deb-pkg can do s390x and arm64 - new patterns in scripts/tags.sh - scripts/tags.sh skips userspace tools' sources (which sometimes have copies of kernel structures) and symlinks - improvements to the objdiff tool - two new coccinelle patches - other minor fixes" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts: objdiff: support directories for the augument of record command scripts: objdiff: fix a comment scripts: objdiff: change the extension of disassembly from .o to .dis scripts: objdiff: improve path flexibility for record command scripts: objdiff: remove unnecessary code scripts: objdiff: direct error messages to stderr scripts: objdiff: get the path to .tmp_objdiff more simply deb-pkg: Add automatic support for s390x architecture coccicheck: Add unneeded return variable test kbuild: Fix a typo in documentation kbuild: trivial - use tabs for code indent where possible kbuild: trivial - remove trailing empty lines coccinelle: Check for missing NULL terminators in of_device_id tables scripts/tags.sh: ignore symlink'ed source files scripts/tags.sh: add regular expression replacement pattern for memcg builddeb: add arm64 in the supported architectures builddeb: use $OBJCOPY variable instead of objcopy scripts/tags.sh: ignore code of user space tools scripts/tags.sh: add pattern for DEFINE_HASHTABLE .gitignore: ignore Module.symvers in all directories
2014-06-12Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull more perf updates from Ingo Molnar: "A second round of perf updates: - wide reaching kprobes sanitization and robustization, with the hope of fixing all 'probe this function crashes the kernel' bugs, by Masami Hiramatsu. - uprobes updates from Oleg Nesterov: tmpfs support, corner case fixes and robustization work. - perf tooling updates and fixes from Jiri Olsa, Namhyung Ki, Arnaldo et al: * Add support to accumulate hist periods (Namhyung Kim) * various fixes, refactorings and enhancements" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (101 commits) perf: Differentiate exec() and non-exec() comm events perf: Fix perf_event_comm() vs. exec() assumption uprobes/x86: Rename arch_uprobe->def to ->defparam, minor comment updates perf/documentation: Add description for conditional branch filter perf/x86: Add conditional branch filtering support perf/tool: Add conditional branch filter 'cond' to perf record perf: Add new conditional branch filter 'PERF_SAMPLE_BRANCH_COND' uprobes: Teach copy_insn() to support tmpfs uprobes: Shift ->readpage check from __copy_insn() to uprobe_register() perf/x86: Use common PMU interrupt disabled code perf/ARM: Use common PMU interrupt disabled code perf: Disable sampled events if no PMU interrupt perf: Fix use after free in perf_remove_from_context() perf tools: Fix 'make help' message error perf record: Fix poll return value propagation perf tools: Move elide bool into perf_hpp_fmt struct perf tools: Remove elide setup for SORT_MODE__MEMORY mode perf tools: Fix "==" into "=" in ui_browser__warning assignment perf tools: Allow overriding sysfs and proc finding with env var perf tools: Consider header files outside perf directory in tags target ...
2014-06-12x86/vdso/doc: Make vDSO examples more portableAndy Lutomirski
This adds a new vdso_test.c that's written entirely in C. It also makes all of the vDSO examples work on 32-bit x86. Cc: Stefani Seibold <stefani@seibold.net> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Link: http://lkml.kernel.org/r/62b701fc44b79f118ac2b2d64d19965fc5c291fb.1402620737.git.luto@amacapital.net Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-06-12x86/vdso/doc: Rename vdso_test.c to vdso_standalone_test_x86.cAndy Lutomirski
This thing is hopelessly x86_64-specific: it's an example of how to access the vDSO without any runtime support at all. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Link: http://lkml.kernel.org/r/3efc170e0e166e15f0150c9fdb37d52488b9c0a4.1402620737.git.luto@amacapital.net Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-06-12Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull more locking changes from Ingo Molnar: "This is the second round of locking tree updates for v3.16, offering large system scalability improvements: - optimistic spinning for rwsems, from Davidlohr Bueso. - 'qrwlocks' core code and x86 enablement, from Waiman Long and PeterZ" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, locking/rwlocks: Enable qrwlocks on x86 locking/rwlocks: Introduce 'qrwlocks' - fair, queued rwlocks locking/mutexes: Documentation update/rewrite locking/rwsem: Fix checkpatch.pl warnings locking/rwsem: Fix warnings for CONFIG_RWSEM_GENERIC_SPINLOCK locking/rwsem: Support optimistic spinning
2014-06-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov. 2) Multiqueue support in xen-netback and xen-netfront, from Andrew J Benniston. 3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn Mork. 4) BPF now has a "random" opcode, from Chema Gonzalez. 5) Add more BPF documentation and improve test framework, from Daniel Borkmann. 6) Support TCP fastopen over ipv6, from Daniel Lee. 7) Add software TSO helper functions and use them to support software TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia. 8) Support software TSO in fec driver too, from Nimrod Andy. 9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli. 10) Handle broadcasts more gracefully over macvlan when there are large numbers of interfaces configured, from Herbert Xu. 11) Allow more control over fwmark used for non-socket based responses, from Lorenzo Colitti. 12) Do TCP congestion window limiting based upon measurements, from Neal Cardwell. 13) Support busy polling in SCTP, from Neal Horman. 14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru. 15) Bridge promisc mode handling improvements from Vlad Yasevich. 16) Don't use inetpeer entries to implement ID generation any more, it performs poorly, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits) rtnetlink: fix userspace API breakage for iproute2 < v3.9.0 tcp: fixing TLP's FIN recovery net: fec: Add software TSO support net: fec: Add Scatter/gather support net: fec: Increase buffer descriptor entry number net: fec: Factorize feature setting net: fec: Enable IP header hardware checksum net: fec: Factorize the .xmit transmit function bridge: fix compile error when compiling without IPv6 support bridge: fix smatch warning / potential null pointer dereference via-rhine: fix full-duplex with autoneg disable bnx2x: Enlarge the dorq threshold for VFs bnx2x: Check for UNDI in uncommon branch bnx2x: Fix 1G-baseT link bnx2x: Fix link for KR with swapped polarity lane sctp: Fix sk_ack_backlog wrap-around problem net/core: Add VF link state control policy net/fsl: xgmac_mdio is dependent on OF_MDIO net/fsl: Make xgmac_mdio read error message useful net_sched: drr: warn when qdisc is not work conserving ...
2014-06-12Merge tag 'pci-v3.16-changes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull more PCI updates from Bjorn Helgaas: "Here are some more things I'd like to see in v3.16-rc1: - DMA alias iterator, part of some work to fix IOMMU issues - MVEBU, Tegra, DesignWare changes that I forgot to include before - Some whitespace code cleanup Details: IOMMU - Add DMA alias iterator (Alex Williamson) - Add DMA alias quirks for ASMedia, ITE, Tundra bridges (Alex Williamson) - Add DMA alias quirks for Marvell, Ricoh devices (Alex Williamson) - Add DMA alias quirk for HighPoint devices (Jérôme Carretero) MSI - Fix leak in free_msi_irqs() (Alexei Starovoitov) Marvell MVEBU - Remove unnecessary use of 'conf_lock' spinlock (Andrew Murray) - Avoid setting an undefined window size (Jason Gunthorpe) - Allow several windows with the same target/attribute (Thomas Petazzoni) - Split PCIe BARs into multiple MBus windows when needed (Thomas Petazzoni) - Fix off-by-one in the computed size of the mbus windows (Willy Tarreau) NVIDIA Tegra - Use new OF interrupt mapping when possible (Lucas Stach) Synopsys DesignWare - Remove unnecessary use of 'conf_lock' spinlock (Andrew Murray) - Use new OF interrupt mapping when possible (Lucas Stach) - Split Exynos and i.MX bindings (Lucas Stach) - Fix comment for setting number of lanes (Mohit Kumar) - Fix iATU programming for cfg1, io and mem viewport (Mohit Kumar) Miscellaneous - EXPORT_SYMBOL cleanup (Ryan Desfosses) - Whitespace cleanup (Ryan Desfosses) - Merge multi-line quoted strings (Ryan Desfosses)" * tag 'pci-v3.16-changes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (21 commits) PCI: Add function 1 DMA alias quirk for HighPoint RocketRaid 642L PCI/MSI: Fix memory leak in free_msi_irqs() PCI: Merge multi-line quoted strings PCI: Whitespace cleanup PCI: Move EXPORT_SYMBOL so it immediately follows function/variable PCI: Add bridge DMA alias quirk for ITE bridge PCI: designware: Split Exynos and i.MX bindings PCI: Add bridge DMA alias quirk for ASMedia and Tundra bridges PCI: Add support for PCIe-to-PCI bridge DMA alias quirks PCI: Add function 1 DMA alias quirk for Marvell devices PCI: Add function 0 DMA alias quirk for Ricoh devices PCI: Add support for DMA alias quirks PCI: Convert pci_dev_flags definitions to bit shifts PCI: Add DMA alias iterator PCI: mvebu: Use '%pa' for printing 'phys_addr_t' type PCI: mvebu: Remove unnecessary use of 'conf_lock' spinlock PCI: designware: Remove unnecessary use of 'conf_lock' spinlock PCI: designware: Use new OF interrupt mapping when possible PCI: designware: Fix iATU programming for cfg1, io and mem viewport PCI: designware: Fix comment for setting number of lanes ...
2014-06-12Merge tag 'pm+acpi-3.16-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more ACPI and power management updates from Rafael Wysocki: "These are fixups on top of the previous PM+ACPI pull request, regression fixes (ACPI hotplug, cpufreq ppc-corenet), other bug fixes (ACPI reset, cpufreq), new PM trace points for system suspend profiling and a copyright notice update. Specifics: - I didn't remember correctly that the Hans de Goede's ACPI video patches actually didn't flip the video.use_native_backlight default, although we had discussed that and decided to do that. Since I said we would do that in the previous PM+ACPI pull request, make that change for real now. - ACPI bus check notifications for PCI host bridges don't cause the bus below the host bridge to be checked for changes as they should because of a mistake in the ACPI-based PCI hotplug (ACPIPHP) subsystem that forgets to add hotplug contexts to PCI host bridge ACPI device objects. Create hotplug contexts for PCI host bridges too as appropriate. - Revert recent cpufreq commit related to the big.LITTLE cpufreq driver that breaks arm64 builds. - Fix for a regression in the ppc-corenet cpufreq driver introduced during the 3.15 cycle and causing the driver to use the remainder from do_div instead of the quotient. From Ed Swarthout. - Resets triggered by panic activate a BUG_ON() in vmalloc.c on systems where the ACPI reset register is located in memory address space. Fix from Randy Wright. - Fix for a problem with cpufreq governors that decisions made by them may be suboptimal due to the fact that deferrable timers are used by them for CPU load sampling. From Srivatsa S Bhat. - Fix for a problem with the Tegra cpufreq driver where the CPU frequency is temporarily switched to a "stable" level that is different from both the initial and target frequencies during transitions which causes udelay() to expire earlier than it should sometimes. From Viresh Kumar. - New trace points and rework of some existing trace points for system suspend/resume profiling from Todd Brandt. - Assorted cpufreq fixes and cleanups from Stratos Karafotis and Viresh Kumar. - Copyright notice update for suspend-and-cpuhotplug.txt from Srivatsa S Bhat" * tag 'pm+acpi-3.16-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / hotplug / PCI: Add hotplug contexts to PCI host bridges PM / sleep: trace events for device PM callbacks cpufreq: cpufreq-cpu0: remove dependency on THERMAL and REGULATOR cpufreq: tegra: update comment for clarity cpufreq: intel_pstate: Remove duplicate CPU ID check cpufreq: Mark CPU0 driver with CPUFREQ_NEED_INITIAL_FREQ_CHECK flag PM / Documentation: Update copyright in suspend-and-cpuhotplug.txt cpufreq: governor: remove copy_prev_load from 'struct cpu_dbs_common_info' cpufreq: governor: Be friendly towards latency-sensitive bursty workloads PM / sleep: trace events for suspend/resume cpufreq: ppc-corenet-cpu-freq: do_div use quotient Revert "cpufreq: Enable big.LITTLE cpufreq driver on arm64" cpufreq: Tegra: implement intermediate frequency callbacks cpufreq: add support for intermediate (stable) frequencies ACPI / video: Change the default for video.use_native_backlight to 1 ACPI: Fix bug when ACPI reset register is implemented in system memory
2014-06-12Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull LED updates from Bryan Wu: "I just found merge window is open and I'm quite busy and almost forget to send out this pull request. Thanks Russell and Alexandre ping me about this. So basically we got some clean up and leds-pwm fixing patches from Russell" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: leds: Remove duplicated OOM message for individual driver drivers/leds: Replace __get_cpu_var use through this_cpu_ptr leds: lp55xx: add DT bindings for LP55231 leds: 88pm860x: Fix missing refcount decrement for parent of_node leds: 88pm860x: Use of_get_child_by_name leds: leds-pwm: add DT support for LEDs wired to supply leds: leds-pwm: implement PWM inversion leds: leds-pwm: convert OF parsing code to use led_pwm_add() leds: leds-pwm: provide a common function to setup a single led-pwm device leds: pca9685: Remove leds-pca9685 driver dell-led: add mic mute led interface
2014-06-12Merge tag 'mfd-for-linus-3.16-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull more MFD updates from Lee Jones: "I missed collecting these patches due to a branch/tag naming ambiguity. Completely my own fault, as I mindlessly named a branch and tag identically. Sorry for the fuss. This pull-request contains some misplaced patches from Tony Lindgren that should have been part of the initial one" * tag 'mfd-for-linus-3.16-1' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: mfd: twl4030-power: Add a configuration to turn off oscillator during off-idle mfd: twl4030-power: Add support for board specific configuration mfd: twl4030-power: Add recommended idle configuration mfd: twl4030-power: Add generic reset configuration mfd: twl4030-power: Fix some defines for SW_EVENTS mfd: twl4030-power: Fix hang on reboot if sleep configuration was loaded earlier
2014-06-12Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "This is the main drm merge window pull request, changes all over the place, mostly normal levels of churn. Highlights: Core drm: More cleanups, fix race on connector/encoder naming, docs updates, object locking rework in prep for atomic modeset i915: mipi DSI support, valleyview power fixes, cursor size fixes, execlist refactoring, vblank improvements, userptr support, OOM handling improvements radeon: GPUVM tuning and large page size support, gart fixes, deep color HDMI support, HDMI audio cleanups nouveau: - displayport rework should fix lots of issues - initial gk20a support - gk110b support - gk208 fixes exynos: probe order fixes, HDMI changes, IPP consolidation msm: debugfs updates, misc fixes ast: ast2400 support, sync with UMS driver tegra: cleanups, hdmi + hw cursor for Tegra 124. panel: fixes existing panels add some new ones. ipuv3: moved from staging to drivers/gpu" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (761 commits) drm/nouveau/disp/dp: fix tmds passthrough on dp connector drm/nouveau/dp: probe dpcd to determine connectedness drm/nv50-: trigger update after all connectors disabled drm/nv50-: prepare for attaching a SOR to multiple heads drm/gf119-/disp: fix debug output on update failure drm/nouveau/disp/dp: make use of postcursor when its available drm/g94-/disp/dp: take max pullup value across all lanes drm/nouveau/bios/dp: parse lane postcursor data drm/nouveau/dp: fix support for dpms drm/nouveau: register a drm_dp_aux channel for each dp connector drm/g94-/disp: add method to power-off dp lanes drm/nouveau/disp/dp: maintain link in response to hpd signal drm/g94-/disp: bash and wait for something after changing lane power regs drm/nouveau/disp/dp: split link config/power into two steps drm/nv50/disp: train PIOR-attached DP from second supervisor drm/nouveau/disp/dp: make use of existing output data for link training drm/gf119/disp: start removing direct vbios parsing from supervisor drm/nv50/disp: start removing direct vbios parsing from supervisor drm/nouveau/disp/dp: maintain receiver caps in response to hpd signal drm/nouveau/disp/dp: create subclass for dp outputs ...
2014-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "This the bunch that sat in -next + lock_parent() fix. This is the minimal set; there's more pending stuff. In particular, I really hope to get acct.c fixes merged this cycle - we need that to deal sanely with delayed-mntput stuff. In the next pile, hopefully - that series is fairly short and localized (kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more iov_iter work. Most of prereqs for ->splice_write with sane locking order are there and Kent's dio rewrite would also fit nicely on top of this pile" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits) lock_parent: don't step on stale ->d_parent of all-but-freed one kill generic_file_splice_write() ceph: switch to iter_file_splice_write() shmem: switch to iter_file_splice_write() nfs: switch to iter_splice_write_file() fs/splice.c: remove unneeded exports ocfs2: switch to iter_file_splice_write() ->splice_write() via ->write_iter() bio_vec-backed iov_iter optimize copy_page_{to,from}_iter() bury generic_file_aio_{read,write} lustre: get rid of messing with iovecs ceph: switch to ->write_iter() ceph_sync_direct_write: stop poking into iov_iter guts ceph_sync_read: stop poking into iov_iter guts new helper: copy_page_from_iter() fuse: switch to ->write_iter() btrfs: switch to ->write_iter() ocfs2: switch to ->write_iter() xfs: switch to ->write_iter() ...
2014-06-12hwmon: add support for Sensirion SHTC1 sensorTomas Pop
Add support for Sensirion SHTC1 and compatible temperature and humidity sensors. Signed-off-by: Tomas Pop <tomas.pop@sensirion.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-06-12Merge branch 'pm-cpufreq'Rafael J. Wysocki
* pm-cpufreq: cpufreq: cpufreq-cpu0: remove dependency on THERMAL and REGULATOR cpufreq: tegra: update comment for clarity cpufreq: intel_pstate: Remove duplicate CPU ID check cpufreq: Mark CPU0 driver with CPUFREQ_NEED_INITIAL_FREQ_CHECK flag cpufreq: governor: remove copy_prev_load from 'struct cpu_dbs_common_info' cpufreq: governor: Be friendly towards latency-sensitive bursty workloads cpufreq: ppc-corenet-cpu-freq: do_div use quotient Revert "cpufreq: Enable big.LITTLE cpufreq driver on arm64" cpufreq: Tegra: implement intermediate frequency callbacks cpufreq: add support for intermediate (stable) frequencies
2014-06-12Merge commit '9f12600fe425bc28f0ccba034a77783c09c15af4' into for-linusAl Viro
Backmerge of dcache.c changes from mainline. It's that, or complete rebase... Conflicts: fs/splice.c Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-06-11Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Most of this is cleaning up various driver sysfs permissions so we can re-add the perm check (we unified the module param and sysfs checks, but the module ones were stronger so we weakened them temporarily). Param parsing gets documented, and also "--" now forces args to be handed to init (and ignored by the kernel). Module NX/RO protections get tightened: we now set them before calling parse_args()" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: module: set nx before marking module MODULE_STATE_COMING. samples/kobject/: avoid world-writable sysfs files. drivers/hid/hid-picolcd_fb: avoid world-writable sysfs files. drivers/staging/speakup/: avoid world-writable sysfs files. drivers/regulator/virtual: avoid world-writable sysfs files. drivers/scsi/pm8001/pm8001_ctl.c: avoid world-writable sysfs files. drivers/hid/hid-lg4ff.c: avoid world-writable sysfs files. drivers/video/fbdev/sm501fb.c: avoid world-writable sysfs files. drivers/mtd/devices/docg3.c: avoid world-writable sysfs files. speakup: fix incorrect perms on speakup_acntsa.c cpumask.h: silence warning with -Wsign-compare Documentation: Update kernel-parameters.tx param: hand arguments after -- straight to init modpost: Fix resource leak in read_dump()
2014-06-11net: filter: document internal instruction encodingAlexei Starovoitov
This patch adds a description of eBPFs instruction encoding in order to bring the documentation in line with the implementation. Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
