path: root/Documentation
2005-12-12Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-12-12[PATCH] V4L/DVB: (3086c) Whitespaces cleanups part 4Mauro Carvalho Chehab
Clean up whitespaces at v4l/dvb files Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[PATCH] ext3: fix mount options documentationAndreas Gruenbacher
Reported by Jacques de Mer and Daniel Drake <dsd@gentoo.org>. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-04[ARM] Add memory.txt to 00-INDEXRussell King
2005-11-29[PATCH] USB: documentation updateAlan Stern
This patch (as611) fixes a minor mistake and misspelling in the USB documentation. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-22[NET]: Fix ifenslave to not fail on lack of IP informationNeil Horman
Patch to ifenslave so that under older ABI versions, a failure to propogate ip information from master to slave does not result in a filure to enslave the slave device. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-22[PATCH] kernel Doc/ URL correctionsRandy Dunlap
Correct lots of URLs in Documentation/ Also a few minor whitespace cleanups and typo/spello fixes. Sadly there are still a lot of bad URLs remaining. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-20[NET]: kernel-doc fixesRandy Dunlap
Fix kernel-doc warnings in network files. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-19Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-11-18[PATCH] update Documentation/00-INDEXGreg Kroah-Hartman
Update the index file with descriptions of the stable_api_nonsense.txt and stable_kernel_rules.txt files. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-18[PATCH] Add HOWTO do kernel development document to the Documentation directoryGreg Kroah-Hartman
Here's a document that describes the process and procedures of how to do Linux kernel development. It has gone through a number of rounds of review on the linux-kernel mailing list, and contains contributions and help from Paolo Ciarrocchi, Randy Dunlap, Gerrit Huizenga, Pat Mochel, Hanna Linder, Kay Sievers, Vojtech Pavlik, Jan Kara, Josh Boyer, Kees Cook, Andrew Morton, Andi Kleen, Vadim Lobanov, Jesper Juhl, Adrian Bunk, Keri Harris, Frans Pop, David A. Wheeler, Junio Hamano, Michael Kerrisk, and Alex Shepard. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-17[ARM] Fix some corner cases in new mm initialisationRussell King
Document that the VMALLOC_END address must be aligned to 2MB since it must align with a PGD boundary. Allocate the vectors page early so that the flush_cache_all() later will cause any dirty cache lines in the direct mapping will be safely written back. Move the flush_cache_all() to the second local_flush_cache_tlb() and remove the now redundant first local_flush_cache_tlb(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-17[PATCH] USB: Delete leftovers from bluetty driverMarcel Holtmann
This patch deletes the bluetooth.txt help file of the bluetty driver and hands over its major device nodes for character devices to the RFCOMM TTY implementation of the Bluetooth subsystem. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-17[MIPS] feature-removal-schedule.txt: Schedule au1x00_uart for removal.Ralf Baechle
The 8250 serial driver now has the ability to deal with the differences between the standard 8250 family of UARTs and their slightly strange brother on Alchemy SOCs. The loss of features is not considered an issue. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-11-15[PATCH] oops-tracing: mention extended VGADave Jones
Something I've found handy countless times when users do this.. Signed-off-by: Dave Jones <davej@redhat.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-15[PATCH] Update location of ll_rw_blk.c in docsBen Collins
Picked from the ubuntu-2.6 tree The change in location for ll_rw_blk.c from drivers/block/ to block/ caused failure to generate documentation. Signed-off-by: Ben Collins <bcollins@ubuntu.com> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-15[PATCH] md: mark START_ARRAY deprecated with a dateNeilBrown
This was marked deprecated "after 2.6" back in the 2.5 days. But now it seems there isn't going to be any "after 2.6", and we deprecate by date now. So set a date. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-14Merge x86-64 update from AndiLinus Torvalds
2005-11-14[PATCH] x86_64: Remove CONFIG_CHECKING and add command line option for ↵Andi Kleen
pagefault tracing CONFIG_CHECKING covered some debugging code used in the early times of the port. But it wasn't even SMP safe for quite some time and the bugs it checked for seem to be gone. This patch removes all the code to verify GS at kernel entry. There haven't been any new bugs in this area for a long time. Previously it also covered the sysctl for the page fault tracing. That didn't make much sense because that code was unconditionally compiled in. I made that a boot option now because it is typically only useful at boot. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-14[PATCH] x86_64: Log machine checks from boot on Intel systemsAndi Kleen
The logging for boot errors was turned off because it was broken on some AMD systems. But give Intel EM64T systems a chance because they are supposed to be correct there. The advantage is that there is a chance to actually log uncorrected machine checks after the reset. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-14[PATCH] x86_64: New heuristics to find out hotpluggable CPUs.Andi Kleen
With a NR_CPUS==128 kernel with CPU hotplug enabled we would waste 4MB on per CPU data of all possible CPUs. The reason was that HOTPLUG always set up possible map to NR_CPUS cpus and then we need to allocate that much (each per CPU data is roughly ~32k now) The underlying problem is that ACPI didn't tell us how many hotplug CPUs the platform supports. So the old code just assumed all, which would lead to this memory wastage. This implements some new heuristics: - If the BIOS specified disabled CPUs in the ACPI/mptables assume they can be enabled later (this is bending the ACPI specification a bit, but seems like a obvious extension) - The user can overwrite it with a new additionals_cpus=NUM option - Otherwise use half of the available CPUs or 2, whatever is more. Cc: ashok.raj@intel.com Cc: len.brown@intel.com Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-14[PATCH] x86_64: Some clarifications for Documention/x86_64/mm.txtAndi Kleen
I got some questions on this, so just fix up the documentation. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] DocBook: revert xmlto use for .ps and .pdf documentationMartin Waitz
As xmlto doesn't work for print documentation, we need docbook-utils again for these targets. This patch allows the user to choose the method he wants to use. (I'm still hoping that someone will fix passivetex ;-) Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] DocBook: comment about paper typeMartin Waitz
Add a comment showing how to change paper type. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] DocBook: include printk documentationMartin Waitz
Add printk documentation to kernel-api. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (962) Added new saa7134 card (MSI TV@anywhere plus)Ricardo Cerqueira
Added new saa7134 card (MSI TV@anywhere plus) Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l:: (936) Support for sabrent bt848 versionBill Pechter
Support for Sabrent bt848 version. Signed-off-by: Bill Pechter <pechter@gmail.com> Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] oops-tracing: mention digital photosDiego Calleja
2005-11-13[PATCH] atomic: inc_not_zeroNick Piggin
Introduce an atomic_inc_not_zero operation. Make this a special case of atomic_add_unless because lockless pagecache actually wants atomic_inc_not_negativeone due to its offset refcount. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] atomic: cmpxchgNick Piggin
Introduce an atomic_cmpxchg operation. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
2005-11-11Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-for-linus-2.6Linus Torvalds
2005-11-10[TCP]: Appropriate Byte Count supportStephen Hemminger
This is an updated version of the RFC3465 ABC patch originally for Linux 2.6.11-rc4 by Yee-Ting Li. ABC is a way of counting bytes ack'd rather than packets when updating congestion control. The orignal ABC described in the RFC applied to a Reno style algorithm. For advanced congestion control there is little change after leaving slow start. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[DCCP]: Create Documentation/networking/dccp.txtIan McDonald
This patch is a first go at some documentation. Please advise if gmail has mangled patch and I will revert to an attachment: Signed-off-by: Ian McDonald <imcdnzl@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10Merge by hand (whitespace conflicts in libata.h)James Bottomley
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-09Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/i2c-2.6Linus Torvalds
2005-11-09[SCSI] remove Scsi_Device typedefChristoph Hellwig
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
2005-11-09Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2005-11-09[PATCH] md: document sysfs usage of md, and make a couple of small refinementsNeilBrown
Document in Documentation/md.txt the files that now appear in sysfs, and make a couple of small refinements to exactly when 'level' and 'raid_disks' are empty, to make it match the documentation. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] fbcon: Console Rotation - Add framebuffer console documentationAntonino A. Daplas
Add documentation as Documentation/fb/fbcon.txt describing the framebuffer console and its boot options. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] sched: resched and cpu_idle reworkNick Piggin
Make some changes to the NEED_RESCHED and POLLING_NRFLAG to reduce confusion, and make their semantics rigid. Improves efficiency of resched_task and some cpu_idle routines. * In resched_task: - TIF_NEED_RESCHED is only cleared with the task's runqueue lock held, and as we hold it during resched_task, then there is no need for an atomic test and set there. The only other time this should be set is when the task's quantum expires, in the timer interrupt - this is protected against because the rq lock is irq-safe. - If TIF_NEED_RESCHED is set, then we don't need to do anything. It won't get unset until the task get's schedule()d off. - If we are running on the same CPU as the task we resched, then set TIF_NEED_RESCHED and no further action is required. - If we are running on another CPU, and TIF_POLLING_NRFLAG is *not* set after TIF_NEED_RESCHED has been set, then we need to send an IPI. Using these rules, we are able to remove the test and set operation in resched_task, and make clear the previously vague semantics of POLLING_NRFLAG. * In idle routines: - Enter cpu_idle with preempt disabled. When the need_resched() condition becomes true, explicitly call schedule(). This makes things a bit clearer (IMO), but haven't updated all architectures yet. - Many do a test and clear of TIF_NEED_RESCHED for some reason. According to the resched_task rules, this isn't needed (and actually breaks the assumption that TIF_NEED_RESCHED is only cleared with the runqueue lock held). So remove that. Generally one less locked memory op when switching to the idle thread. - Many idle routines clear TIF_POLLING_NRFLAG, and only set it in the inner most polling idle loops. The above resched_task semantics allow it to be set until before the last time need_resched() is checked before going into a halt requiring interrupt wakeup. Many idle routines simply never enter such a halt, and so POLLING_NRFLAG can be always left set, completely eliminating resched IPIs when rescheduling the idle task. POLLING_NRFLAG width can be increased, to reduce the chance of resched IPIs. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Con Kolivas <kernel@kolivas.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] V4L: removal schedule for V4L1 APIMauro Carvalho Chehab
States a date for removing V4L1 API Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] V4L: 915: fixes compilation problems due removal of media/id.h and ↵Hans Verkuil
i2c-algo-bit Fixes compilation problems due removal of media/id.h and I2C_ALGO_BIT Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] V4L: 909: updated cardlist and strip trailing whitespaceMichael Krufky
Updated CARDLIST and strip trailing whitespace. Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] V4L: 906: remote and more info for pctv cardbus whitespace cleanupPavel Mihaylov
Remote and more info for PCTV Cardbus. Whitespace cleanup. Signed-off-by: Pavel Mihaylov <bin@bash.info> Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 895: new avermedia 303 card without radioLubomir Bulej
- New Avermedia 303 card (without radio). Signed-off-by: Lubomir Bulej <bulej@nenya.ms.mff.cuni.cz> Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 863: added pinnacle dazzle dvc 90Mauro Carvalho Chehab
- Added Pinnacle Dazzle DVC 90 Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 851: fixed broken api link and indentationNickolay V. Shmyrev
- Fixed broken API link and indentation. Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 847: fix bug 5484 asus digimatrix card doesnt work with pal tunerMichael Krufky
- Fix bug 5484: ASUS digimatrix card doesnt work with PAL tuner Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
