This driver observes the USB ID pin connected over a GPIO and
updates the USB cable extcon states accordingly.
The existing GPIO extcon driver is not suitable for this purpose
as it needs to be taught to understand USB cable states and it
can't handle more than one cable per instance.
For the USB case we need to handle 2 cable states.
1) USB (attach/detach)
2) USB-HOST (attach/detach)
This driver can be easily updated in the future to handle VBUS
events in case it happens to be available on GPIO for any platform.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Reviewed-by: Felipe Balbi <balbi@ti.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
(cherry picked from commit e52817faae359ce95c93c2b6eb88b16d4b430181)
Device tree nodes are already treated as objects, and we already want to
expose them to userspace which is done using the /proc filesystem today.
Right now the kernel has to do a lot of work to keep the /proc view in
sync with the in-kernel representation. If device_nodes are switched to
be kobjects then the device tree code can be a whole lot simpler. It
also turns out that switching to using /sysfs from /proc results in
smaller code and data size, and the userspace ABI won't change if
/proc/device-tree symlinks to /sys/firmware/devicetree/base.
v7: Add missing sysfs_bin_attr_init()
v6: Add __of_add_property() early init fixes from Pantelis
v5: Rename firmware/ofw to firmware/devicetree
Fix updating property values in sysfs
v4: Fixed build error on Powerpc
Fixed handling of dynamic nodes on powerpc
v3: Fixed handling of duplicate attribute and child node names
v2: switch to using sysfs bin_attributes which solve the problem of
reporting incorrect property size.
Tested-by: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Nathan Fontenot <nfont@linux.vnet.ibm.com>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
(cherry picked from commit 75b57ecf9d1d1e17d099ab13b8f48e6e038676be)
With release of ACPI 5.1 and _DSD method we can finally name GPIOs (and
other things as well) returned by _CRS. Previously we were only able to
use integer index to find the corresponding GPIO, which is pretty error
prone if the order changes.
With _DSD we can now query GPIOs using name instead of an integer index,
like the below example shows:
// Bluetooth device with reset and shutdown GPIOs
Device (BTH)
Name (_HID, ...)
Name (_CRS, ResourceTemplate ()
GpioIo (Exclusive, PullUp, 0, 0, IoRestrictionInputOnly,
"\\_SB.GPO0", 0, ResourceConsumer) {15}
"\\_SB.GPO0", 0, ResourceConsumer) {27, 31}
Name (_DSD, Package ()
ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"),
Package ()
Package () {"reset-gpio", Package() {^BTH, 1, 1, 0 }},
Package () {"shutdown-gpio", Package() {^BTH, 0, 0, 0 }},
The format of the supported GPIO property is:
Package () { "name", Package () { ref, index, pin, active_low }}
ref - The device that has _CRS containing GpioIo()/GpioInt() resources,
typically this is the device itself (BTH in our case).
index - Index of the GpioIo()/GpioInt() resource in _CRS starting from zero.
pin - Pin in the GpioIo()/GpioInt() resource. Typically this is zero.
active_low - If 1 the GPIO is marked as active_low.
Since ACPI GpioIo() resource does not have field saying whether it is
active low or high, the "active_low" argument can be used here. Setting
it to 1 marks the GPIO as active low.
In our Bluetooth example the "reset-gpio" refers to the second GpioIo()
resource, second pin in that resource with the GPIO number of 31.
This patch implements necessary support to gpiolib for extracting GPIOs
using _DSD device properties.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Grant Likely <grant.likely@linaro.org>
(cherry picked from commit 0d9a693cc8619b28f0eeb689a554647d42848fde)
The huge majority of GPIOs have their direction and initial value set
right after being obtained by one of the gpiod_get() functions. The
integer GPIO API had gpio_request_one() that took a convenience flags
parameter allowing to specify an direction and value applied to the
returned GPIO. This feature greatly simplifies client code and ensures
errors are always handled properly.
A similar feature has been requested for the gpiod API. Since setting
the direction of a GPIO is so often the very next action done after
obtaining its descriptor, we prefer to extend the existing functions
instead of introducing new functions that would raise the
number of gpiod getters to 16 (!).
The drawback of this approach is that all gpiod clients need to be
updated. To limit the pain, temporary macros are introduced that allow
gpiod_get*() to be called with or without the extra flags argument. They
will be removed once all consumer code has been updated.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Reviewed-by: Mark Brown <broonie@linaro.org>
(cherry picked from commit 39b2bbe3d715cf5013b5c48695ccdd25bd3bf120)
Introduce gpiod_get_optional() and gpiod_get_index_optional() helpers
that make it easier for drivers to handle optional GPIOs.
Currently in order to handle optional GPIOs, a driver needs to special
case error handling for -ENOENT, such as this:
gpio = gpiod_get(dev, "foo");
if (IS_ERR(gpio)) {
if (PTR_ERR(gpio) != -ENOENT)
return PTR_ERR(gpio);
gpio = NULL;
if (gpio) {
/* set up GPIO */
With these new helpers the above is reduced to:
gpio = gpiod_get_optional(dev, "foo");
if (IS_ERR(gpio))
if (gpio) {
/* set up GPIO */
While at it, device-managed variants of these functions are also
provided.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
(cherry picked from commit 29a1f2333e07bbbecb920cc78fd035fe8f53207a)
If the I2C is disturbed by other signals sometimes the i2c-imx bus gets stuck
with SDA being low.
This adds a recovery function to the bus driver.
When e.g. a device driver detects a stuck bus
int i2c_recover_bus(struct i2c_adapter *adap)
can be called to try to recover the bus.
(cherry picked from commit 88731dc0e8b6ba244e097b412b302acf3b9cc889)
arch/arm/boot/dts/imx6qdl-apalis.dtsi
drivers/i2c/busses/i2c-imx.c
This patch introduces generic code to perform PM domain look-up using
device tree and automatically bind devices to their PM domains.
Generic device tree bindings are introduced to specify PM domains of
devices in their device tree nodes.
Backwards compatibility with legacy Samsung-specific PM domain bindings
is provided, but for now the new code is not compiled when
CONFIG_ARCH_EXYNOS is selected to avoid collision with legacy code.
This will change as soon as the Exynos PM domain code gets converted to
use the generic framework in further patch.
This patch was originally submitted by Tomasz Figa when he was employed
by Samsung.
Link: http://marc.info/?l=linux-pm&m=139955349702152&w=2
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Acked-by: Rob Herring <robh@kernel.org>
Tested-by: Philipp Zabel <p.zabel@pengutronix.de>
Reviewed-by: Kevin Hilman <khilman@linaro.org>
(cherry picked from commit aa42240ab2544a8bcb2efb400193826f57f3175e)
(cherry picked from commit 4a2d7a846761e3b86e08b903e5a1a088686e2181)
Keep all power-domains already enabled by bootloader on, even if no
driver has claimed them. This is useful for debug and development, but
should not be needed on a platform with proper driver support.
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
(cherry picked from commit 39ac5ba51b69a77a30d2e783aed02ec73c9f6d70)
(cherry picked from commit 8507e882be1aa8363d229e6dbc8367c963e37bd3)
This reverts commit 4aa055cb0634bc8d0389070104fe6aa7cfa99b8c.
Signed-off-by: Robin Gong <b38343@freescale.com>
(cherry picked from commit e599f64de890a60a3b9884dd5838c43472f145e2)
This patch adds guide for selecting available gadget drivers for otg and EH
compliance tests.
Acked-by: Peter Chen <peter.chen@freescale.com>
Signed-off-by: Li Jun <b47624@freescale.com>
(cherry picked from commit 520cac9e4fe938887dd45b5b4df6c8e35e125a59)
Update for HSIC controller
Signed-off-by: Peter Chen <peter.chen@freescale.com>
polling support
Update HNP test procedure as HNP polling is supported.
This property is used to wakeup transceiver if it's in
sleep mode.
Signed-off-by: Dong Aisheng <b29396@freescale.com>
(cherry picked from commit 9fa3b150ae0c4249ca1b6a7aba57d844540aa383)
(cherry picked from commit b492b7ca89bf8826a3cd5b2513b3235be63101d8)
The 'big-endian-data' property is originally used to indicate whether the
LSB firstly or MSB firstly will be transmitted to the CODEC or received
from the CODEC, and there has nothing relation to the memory data.
Generally, if the audio data in big endian format, which will be using the
bytes reversion, Here this can only be used to bits reversion.
So using the 'lsb-first' instead of 'big-endian-data' can make the code
to be readable easier and more easy to understand what this property is
used to do.
This property used for configuring whether the LSB or the MSB is transmitted
first for the fifo data.
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com>
Acked-by: Nicolin Chen <nicoleotsuka@gmail.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
(cherry picked from commit eadb0019d206591e34e864b62059b292e157d8fc)
Signed-off-by: Mark Brown <broonie@linaro.org>
(cherry picked from commit 014fd22ef9c6a7e9536b7e16635714a1a34810a8)
It is used to indicate whether we use SoC's usb charger
detection or not. Besides, we add anatop phandle since
we need to use anatop register to do most of charger detect operations.
The new property "ddrsmp" was added into device tree. Update the doc
accordingly.
Signed-off-by: Ye.Li <B37916@freescale.com>
(cherry picked from commit 4239df12c5d6c3ac19a25e120ffe17df93c358a3)
Add compatible string for imx6sx-usbmisc.
Add the example for how to enable USB as system wakeup source.
Enable DMA support on i.mx6. The read speed can increase from 600KB/s
to 1.2MB/s on i.mx6q. You can disable or enable dma function in dts.
If not set "dma-names" in dts, spi will use PIO mode. This patch only
validate on i.mx6, not i.mx5, but encourage ones to apply this patch
on i.mx5 since they share the same IP.
Note:
Sometime, there is a weid data in rxfifo after one full tx/rx
transfer finish by DMA on i.mx6dl, so we disable dma functhion on
i.mx6dl.
Signed-off-by: Frank Li <Frank.Li@freescale.com>
(cherry picked from commit f62caccd12c17e4cb516d43a6e4dd8a3abc1f7e0)
(cherry picked from commit b87c98a8944c76840ed1375ed4792ef608de5c01)
add optional property devicetree for SPI slave nodes
into devicetree so that LSB mode can be enabled by devicetree.
Signed-off-by: Zhao Qiang <B45475@freescale.com>
(cherry picked from commit cd6339e6ced387ad67b5551dd2931cfd7e8b970b)
(cherry picked from commit 09623c20b3e6b11a914343d4b0f15b63e683f0d8)
Support for Wake-on-LAN using Magic Packet. ENET IP supports sleep mode
in low power status, when system enter suspend status, Magic packet can
wake up system even if all SOC clocks are gate. The patch doing below things:
- flagging the device as a wakeup source for the system, as well as
its Wake-on-LAN interrupt
- prepare the hardware for entering WoL mode
- add standard ethtool WOL interface
- enable the ENET interrupt to wake us
Tested on i.MX6q/dl sabresd, sabreauto boards, i.MX6SX arm2 boards.
Signed-off-by: Fugang Duan <B38611@freescale.com>
Document the device tree binding for the WM8960 codec, and modify the
driver to extract the platform data from device tree, if present.
Signed-off-by: Zidan Wang <b50113@freescale.com>
(cherry picked from commit e2280c9040d8bc5039617af35ccf7b8ac4abb428)
- imx6sx pcie phy has its own power regulator. Add the
pcie phy power suppy into im6sx pcie dts and binding.
- in order to align with imx6qdl's pcie dts, re-format
imx6sx pcie dts.
- in order to align with imx6qdl pcie dts format and
keep clean of imx6 pcie driver, keep the pcie phy clock
in imx6sx pcie dts, although it's the parent clk of the
pcie bus clock now, and would be enabled automatically
when pcie bus clock is enabled. secondly, it's
possible that the external osc maybe used as source
of the pcie_bus clk in board design in future.
- disp_axi clock is required by pcie inbound axi port.
Add one more clock named pcie_inbound_axi for imx6sx pcie.
Signed-off-by: Richard Zhu <richard.zhu@freescale.com>
This allows to explicitly specify the covered bus numbers in the
devicetree, which will come in handy once we see a SoC with more than one
PCIe host controller instance.
Previously the driver relied on the behavior of pci_scan_root_bus() to fill
in a range of 0x00-0xff if no valid range was found. We fall back to the
same range if no valid DT entry was found to keep backwards compatibility,
but now do it explicitly.
[bhelgaas: use %pR in error message to avoid duplication]
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Pratyush Anand <pratyush.anand@st.com>
Acked-by: Mohit Kumar <mohit.kumar@st.com>
(cherry picked from commit 4f2ebe00597c44f7dc6f88a052a2981ddcf6a0b6)
Add support for PCIe controller in DRA7xx. This driver re-uses the
designware core code that is already present in kernel.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Acked-by: Jingoo Han <jg1.han@samsung.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Cc: Mohit Kumar <mohit.kumar@st.com>
(cherry picked from commit 47ff3de911a728cdf9ecc6ad777131902cff62b4)
The configuration address space has so far been specified in *ranges*,
however it should be specified in *reg* making it a platform MEM resource.
Hence used 'platform_get_resource_*' API to get configuration address space
in the designware driver.
(cherry picked from commit 4dd964df36d0e548e1806ec2ec275b62d4dc46e8)
The glue around the core designware IP is significantly different between
the Exynos and i.MX implementation, which is reflected in the DT bindings.
This changes the i.MX6 binding to reuse as much as possible from the common
designware binding and removes old cruft.
I removed the optional GPIOs with the following reasoning:
- disable-gpio: endpoint specific GPIO, not currently wired up in any code.
Should be handled by the PCI device driver, not the host controller
driver.
- wake-up-gpio: same as above.
- power-on-gpio: No user in any upstream DT. This should be handled by a
regulator which shouldn't be controlled by the host driver, but rather by
the PCI device driver.
[bhelgaas: whitespace fixes]
(cherry picked from commit 1db823ee9f677e1a863cd04fda391a7520fcd0e8)
ARM based ST Microelectronics's SPEAr1310 and SPEAr1340 SOCs have onchip
designware PCIe controller. To make that usable, this patch adds a wrapper
driver based on existing designware driver.
Adds bindings for this new driver and update MAINTAINERS as well.
Cc: linux-pci@vger.kernel.org
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Pratyush Anand <pratyush.anand@st.com>
Signed-off-by: Mohit Kumar <mohit.kumar@st.com>
[viresh: fixed logs/cclist/checkpatch warnings, broken into smaller patches]
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
(cherry picked from commit 51b66a6ce12570e5ee1a249c811f7f2d74814a43)
MAINTAINERS
Add support for a generic PCI host controller, such as a
firmware-initialised device with static windows or an emulation by
something such as kvmtool.
The controller itself has no configuration registers and has its address
spaces described entirely by the device-tree (using the bindings from
ePAPR). Both CAM and ECAM are supported for Config Space accesses.
Add corresponding documentation for the DT binding.
[bhelgaas: currently uses the ARM-specific pci_common_init_dev() interface]
Reviewed-by: Liviu Dudau <liviu.dudau@arm.com>
(cherry picked from commit ce292991d88b77160f348fb8a3a2cf6e78f4b456)
drivers/pci/host/Kconfig
drivers/pci/host/Makefile
Implement machine driver for mqs, which use the sai as cpu dai.
sai work on master mode.
Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com>
(cherry picked from commit cac9eb41debc6444d753dc936cdf76874260b9e4)
Implement codec driver for mqs. mqs is a very simple IP. which support:
Word length: 16bit.
DAI format: Left-Justified, slave mode.
(cherry picked from commit 9da6bdd2072b850e9bb910512123eff7d80a0e2f)
The previous patch (ASoC: fsl_sai: Add asynchronous mode support) added
new Device Tree bindings for Asynchronous and Synchronous modes support.
However, these two shall not be present at the same time.
So this patch just simply makes them exclusive so as to avoid incorrect
Device Tree binding usage.
Signed-off-by: Nicolin Chen <nicoleotsuka@gmail.com>
(cherry picked from commit ce7344a4ebabe90e064d3e087727f45624cdc942)
SAI supports these operation modes:
1) asynchronous mode
Both Tx and Rx are set to be asynchronous.
2) synchronous mode (Rx sync with Tx)
Tx is set to be asynchronous, Rx is set to be synchronous.
3) synchronous mode (Tx sync with Rx)
Rx is set to be asynchronous, Tx is set to be synchronous.
4) synchronous mode (Tx/Rx sync with another SAI's Tx)
5) synchronous mode (Tx/Rx sync with another SAI's Rx)
* 4) and 5) are beyond this patch because they are related with another SAI.
As the initial version of this SAI driver, it supported 2) as default while
the others were totally missing.
So this patch just adds supports for 1) and 3).
(cherry picked from commit 08fdf65e37d560581233e06a659f73deeb3766f9)
add snvs power key driver since ic team has fix some issues of SNVS on i.mx6sx
(cherry picked from commit 3d259d1673fe9d14251f65871b77f80b0d779a22)
Adds chipidea to the list of DT vendor prefixes.
TPL (Targeted Peripheral List) is needed for targets host
(OTG and Embedded Hosts) for usb certification and other
vendor specific requirements.
fsl,usbphy is no optional property. This patch moves it to the list of
required properties.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
This adds Vybrid VF610 SoC support. The IP is very similar to i.MX6,
however, the non-core registers are spread in two different register
areas. Hence we support multiple instances of the USB misc driver
and add the driver instance to the imx_usbmisc_data structure.
Signed-off-by: Stefan Agner <stefan@agner.ch>
When tried to enable OTG FSM, we need to rebuild both kernel Image
and modules, since there are some codes at gadget modules which are
controlled by related configurations.
This patch adds a file chipidea.txt for how to demo chipidea usb OTG HNP and SRP
functions via sysfs input files, any other possible information should be
documented for chipidea usb driver in future can be added into this file.
This patch adds sysfs interface description for chipidea USB OTG HNP and SRP.
This patch makes it possible to set the chipidea udc into full-speed only mode.
It is set by the oftree property "maximum-speed = full-speed".
Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Add compatible string for imx6sx-usbphy.
Signed-off-by: Felipe Balbi <balbi@ti.com>
Documentation/devicetree/bindings/usb/mxs-phy.txt
This adds support for the USB PHY in Vybrid VF610. We assume that
the disconnection without VBUS is also needed for Vybrid.
Tests showed, without MXS_PHY_NEED_IP_FIX, enumeration of devices
behind a USB Hub fails with errors:
[ 215.163507] usb usb1-port1: cannot reset (err = -32)
[ 215.170498] usb usb1-port1: cannot reset (err = -32)
[ 215.185120] usb usb1-port1: cannot reset (err = -32)
[ 215.191345] usb usb1-port1: cannot reset (err = -32)
[ 215.202487] usb usb1-port1: cannot reset (err = -32)
[ 215.207718] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 215.219317] usb usb1-port1: unable to enumerate USB device
Hence we also enable the MXS_PHY_NEED_IP_FIX flag.
The current imx-sgtl5000 driver always attaches the cpu-dai to ssi while
in fact it could be attached to other cpu-dais like SAI. Thus this patch
use a general code to support another cpu-dai. And meanwhile update the
devicetree for i.MX6 Series.
Acked-by: Wang Shengjiu <b02247@freescale.com>
Signed-off-by: Nicolin Chen <Guangyu.Chen@freescale.com>
(cherry picked from commit cb5dfaf44d2fdbce4329c2e4762e8450c8cd3b3c)
The current imx-wm8962 machine driver is designed for SSI as CPU DAI only
while as its name we should make the driver more generic to any other CPU
DAI on i.MX serires -- ESAI, SAI for example.
So this patch makes the driver more general so as to support those non-SSI
cases.
(cherry picked from commit b6fca438dde1b4c0bbdee31729871d601f287dc9)
There're two GPIOs connected to the headphone jack and microphone jack,
thus add the states detection.
Reviewed-by: Wang Shengjiu <b02247@freescale.com>
Signed-off-by: Nicolin Chen <b42378@freescale.com>
(cherry picked from commit f85ca1dd664178328bd813651e91d612787b6926)
This patch adds SAI script support to imx-sdma.
