commit 5de61e7aa1ba9ac3c7edbea375da2bc8eb1a89ae upstream.
The current organization of Documentation/stable_kernel_rules.txt
doesn't clearly differentiate the mutually exclusive options for
submission to the -stable review process. As I understand it, patches
are not actually required to be mailed directly to
stable@vger.kernel.org, but the instructions do not make this clear.
Also, there are some established processes that are not listed --
specifically, what I call Option 2 below.
This patch updates and reorganizes a bit, to make things clearer.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Pull networking fixes from David Miller:
1) Stretch ACKs can kill performance with Reno and CUBIC congestion
control, largely due to LRO and GRO. Fix from Neal Cardwell.
2) Fix userland breakage because we accidently emit zero length netlink
messages from the bridging code. From Roopa Prabhu.
3) Carry handling in generic csum_tcpudp_nofold is broken, fix from
Karl Beldan.
4) Remove bogus dev_set_net() calls from CAIF driver, from Nicolas
Dichtel.
5) Make sure PPP deflation never returns a length greater then the
output buffer, otherwise we overflow and trigger skb_over_panic().
Fix from Florian Westphal.
6) COSA driver needs VIRT_TO_BUS Kconfig dependencies, from Arnd
Bergmann.
7) Don't increase route cached MTU on datagram too big ICMPs. From Li
Wei.
8) Fix error path leaks in nf_tables, from Pablo Neira Ayuso.
9) Fix bitmask handling regression in netlink that broke things like
acpi userland tools. From Pablo Neira Ayuso.
10) Wrong header pointer passed to param_type2af() in SCTP code, from
Saran Maruti Ramanara.
11) Stacked vlans not handled correctly by vlan_get_protocol(), from
Toshiaki Makita.
12) Add missing DMA memory barrier to xgene driver, from Iyappan
Subramanian.
13) Fix crash in rate estimators, from Eric Dumazet.
14) We've been adding various workarounds, one after another, for the
change which added the per-net tcp_sock. It was meant to reduce
socket contention but added lots of problems.
Reduce this instead to a proper per-cpu socket and that rids us of
all the daemons.
From Eric Dumazet.
15) Fix memory corruption and OOPS in mlx4 driver, from Jack
Morgenstein.
16) When we disabled UFO in the virtio_net device, it introduces some
serious performance regressions. The orignal problem was IPV6
fragment ID generation, so fix that properly instead. From Vlad
Yasevich.
17) sr9700 driver build breaks on xtensa because it defines macros with
the same name as those used by the arch code. Use more unique
names. From Chen Gang.
18) Fix endianness in new virio 1.0 mode of the vhost net driver, from
Michael S Tsirkin.
19) Several sysctls were setting the maxlen attribute incorrectly, from
Sasha Levin.
20) Don't accept an FQ scheduler quantum of zero, that leads to crashes.
From Kenneth Klette Jonassen.
21) Fix dumping of non-existing actions in the packet scheduler
classifier. From Ignacy Gawędzki.
22) Return the write work_done value when doing TX work in the qlcnic
driver.
23) ip6gre_err accesses the info field with the wrong endianness, from
Sabrina Dubroca.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (54 commits)
sit: fix some __be16/u16 mismatches
ipv6: fix sparse errors in ip6_make_flowlabel()
net: remove some sparse warnings
flow_keys: n_proto type should be __be16
ip6_gre: fix endianness errors in ip6gre_err
qlcnic: Fix NAPI poll routine for Tx completion
amd-xgbe: Set RSS enablement based on hardware features
amd-xgbe: Adjust for zero-based traffic class count
cls_api.c: Fix dumping of non-existing actions' stats.
pkt_sched: fq: avoid hang when quantum 0
net: rds: use correct size for max unacked packets and bytes
vhost/net: fix up num_buffers endian-ness
gianfar: correct the bad expression while writing bit-pattern
net: usb: sr9700: Use 'SR_' prefix for the common register macros
Revert "drivers/net: Disable UFO through virtio"
Revert "drivers/net, ipv6: Select IPv6 fragment idents for virtio UFO packets"
ipv6: Select fragment id during UFO segmentation if not set.
xen-netback: stop the guest rx thread after a fatal error
net/mlx4_core: Fix kernel Oops (mem corruption) when working with more than 80 VFs
isdn: off by one in connect_res()
Update netlink_mmap.txt wrt. commit 4682a0358639b29cf
("netlink: Always copy on mmap TX.").
Signed-off-by: Richard Weinberger <richard@nod.at>
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c fixes from Wolfram Sang:
"i2c driver bugfixes (s3c2410, slave-eeprom, sh_mobile), size
regression "bugfix" (i2c slave), documentation bugfix (st).
Also, one documentation update (da9063), so some devicetrees can now
be verified"
* 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: sh_mobile: terminate DMA reads properly
i2c: Only include slave support if selected
i2c: s3c2410: fix ABBA deadlock by keeping clock prepared
i2c: slave-eeprom: fix boundary check when using sysfs
i2c: st: Rename clock reference to something that exists
DT: i2c: Add devices handled by the da9063 MFD driver
CLK_S_ICN_REG_0 hasn't existed for a while now. This was renamed
over a few commits, then finally removed in commit 5aa02b9 (ARM:
STi: DT: STiH415: Remove unused CLK_S_ICN_REG_0 fixed clock).
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Acked-by: Maxime Coquelin <maxime.coquelin@st.com>
Acked-by: Peter Griffin <peter.griffin@linaro.org>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86
Pull platform driver fix from Darren Hart:
"Revert keyboard backlight sysfs support and documentation.
The support for the dell-laptop keyboard backlight was flawed and the
fix:
https://lkml.org/lkml/2015/1/14/539
was more invasive that I felt comfortable sending at RC5.
This series reverts the support for the dell-laptop keyboard backlight
as well as the documentation for the newly created sysfs attributes.
We'll get this implemented correctly for 3.20"
* tag 'platform-drivers-x86-v3.19-2' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86:
Revert "platform: x86: dell-laptop: Add support for keyboard backlight"
Revert "Documentation: Add entry for dell-laptop sysfs interface"
git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux
Pull devicetree bug fixes and documentation updates from Grant Likely:
"A few bugfixes for the new DT overlay feature, documentation updates,
spelling corrections, and changes to MAINTAINERS. Nothing earth
shattering here"
* tag 'devicetree-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux:
of/unittest: Overlays with sub-devices tests
of/platform: Handle of_populate drivers in notifier
of/overlay: Do not generate duplicate nodes
devicetree: document the "qemu" and "virtio" vendor prefixes
devicetree: document ARM bindings for QEMU's Firmware Config interface
Documentation: of: fix typo in graph bindings
dma-mapping: fix debug print to display correct dma_pfn_offset
of: replace Asahi Kasei Corp vendor prefix
ARM: dt: GIC: Spelling s/specific/specifier/, s/flaggs/flags/
dt/bindings: arm-boards: Spelling s/pointong/pointing/
MAINTAINERS: Update DT website and git repository
MAINTAINERS: drop DT regex matching on of_get_property and of_match_table
This reverts commit 3161293ba6dfceee9c1efe75185677445def05d4.
This interface was determined to be flawed and required too invasive a
fix for the RC cycle. This will be revisited in 3.20.
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
1) Socket addresses returned in the error queue need to be fully
initialized before being passed on to userspace, fix from Willem de
Bruijn.
2) Interrupt handling fixes to davinci_emac driver from Tony Lindgren.
3) Fix races between receive packet steering and cpu hotplug, from Eric
Dumazet.
4) Allowing netlink sockets to subscribe to unknown multicast groups
leads to crashes, don't allow it. From Johannes Berg.
5) One to many socket races in SCTP fixed by Daniel Borkmann.
6) Put in a guard against the mis-use of ipv6 atomic fragments, from
Hagen Paul Pfeifer.
7) Fix promisc mode and ethtool crashes in sh_eth driver, from Ben
Hutchings.
8) NULL deref and double kfree fix in sxgbe driver from Girish K.S and
Byungho An.
9) cfg80211 deadlock fix from Arik Nemtsov.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (36 commits)
s2io: use snprintf() as a safety feature
r8152: remove sram_read
r8152: remove generic_ocp_read before writing
bgmac: activate irqs only if there is nothing to poll
bgmac: register napi before the device
sh_eth: Fix ethtool operation crash when net device is down
sh_eth: Fix promiscuous mode on chips without TSU
ipv6: stop sending PTB packets for MTU < 1280
net: sctp: fix race for one-to-many sockets in sendmsg's auto associate
genetlink: synchronize socket closing and family removal
genetlink: disallow subscribing to unknown mcast groups
genetlink: document parallel_ops
net: rps: fix cpu unplug
net: davinci_emac: Add support for emac on dm816x
net: davinci_emac: Fix ioremap for devices with MDIO within the EMAC address space
net: davinci_emac: Fix incomplete code for getting the phy from device tree
net: davinci_emac: Free clock after checking the frequency
net: davinci_emac: Fix runtime pm calls for davinci_emac
net: davinci_emac: Fix hangs with interrupts
ip: zero sockaddr returned on error queue
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input subsystem fixes from Dmitry Torokhov.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: uinput - fix ioctl nr overflow for UI_GET_SYSNAME/VERSION
Input: I8042 - add Acer Aspire 7738 to the nomux list
Input: elantech - support new ICs types for version 4
Input: i8042 - reset keyboard to fix Elantech touchpad detection
MAINTAINERS: remove Dmitry Torokhov's alternate address
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver fixes from Greg KH:
"Here are three small driver fixes for reported issues for 3.19-rc5.
All of these have been in linux-next for a while with no reported
problems"
* tag 'char-misc-3.19-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
mcb: mcb-pci: Only remap the 1st 0x200 bytes of BAR 0
mei: add ABI documentation for fw_status exported through sysfs
mei: clean reset bit before reset
On dm816x we have two emac controllers with separate memory
areas.
Cc: Brian Hutchinson <b.hutchman@gmail.com>
Cc: Felipe Balbi <balbi@ti.com>
This allows checkpatch to validate more DTSes.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Steve Twiss <stwiss.opensource@diasemi.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal fixes from Zhang Rui:
"Specifics:
- bogus type qualifier fix in OF thermal code.
- Minor fixes on imx and rcar thermal drivers.
- Update TI SoC thermal maintainer entry.
- Updated documentation of OF cpufreq cooling register"
* 'thermal-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux:
thermal: rcar: Spelling/grammar: s/drier use .../driver uses ...s/
thermal: rcar: change type of ctemp in rcar_thermal_update_temp()
thermal: rcar: fix ENR register value
Documentation: thermal: document of_cpufreq_cooling_register()
Thermal: imx: add clk disable/enable for suspend/resume
MAINTAINERS: update ti-soc-thermal status
MAINTAINERS: Add linux-omap to list of reviewers for TI Thermal
thermal: of: Remove bogus type qualifier for of_thermal_get_trip_points()
1) Don't use uninitialized data in IPVS, from Dan Carpenter.
2) conntrack race fixes from Pablo Neira Ayuso.
3) Fix TX hangs with i40e, from Jesse Brandeburg.
4) Fix budget return from poll calls in dnet and alx, from Eric
Dumazet.
5) Fix bugus "if (unlikely(x) < 0)" test in AF_PACKET, from Christoph
Jaeger.
6) Fix bug introduced by conversion to list_head in TIPC retransmit
code, from Jon Paul Maloy.
7) Don't use GFP_NOIO under spinlock in USB kaweth driver, from Alexey
Khoroshilov.
8) Fix bridge build with INET disabled, from Arnd Bergmann.
9) Fix netlink array overrun for PROBE attributes in openvswitch, from
Thomas Graf.
10) Don't hold spinlock across synchronize_irq() in tg3 driver, from
Prashant Sreedharan.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (44 commits)
tg3: Release tp->lock before invoking synchronize_irq()
tg3: tg3_reset_task() needs to use rtnl_lock to synchronize
tg3: tg3_timer() should grab tp->lock before checking for tp->irq_sync
team: avoid possible underflow of count_pending value for notify_peers and mcast_rejoin
openvswitch: packet messages need their own probe attribtue
i40e: adds FCoE configure option
cxgb4vf: Fix queue allocation for 40G adapter
netdevice: Add missing parentheses in macro
bridge: only provide proxy ARP when CONFIG_INET is enabled
neighbour: fix base_reachable_time(_ms) not effective immediatly when changed
net: fec: fix MDIO bus assignement for dual fec SoC's
xen-netfront: use different locks for Rx and Tx stats
drivers: net: cpsw: fix multicast flush in dual emac mode
cxgb4vf: Initialize mdio_addr before using it
net: Corrected the comment describing the ndo operations to reflect the actual prototype for couple of operations
usb/kaweth: use GFP_ATOMIC under spin_lock in usb_start_wait_urb()
MAINTAINERS: add me as ibmveth maintainer
tipc: fix bug in broadcast retransmit code
update ip-sysctl.txt documentation (v2)
net/at91_ether: prepare and unprepare clock
The QEMU open source machine emulator and virtualizer presents firmware
and operating systems running in virtual machines ("guests") with purely
virtual hardware (ie. hardware that has never existed in physical form).
Since QEMU exposes some of these devices in a DTB, it makes sense to
define "qemu" and "virtio" as vendor prefixes.
The qemu definition is from [1], revision 4451 (22:24, 25 November 2014).
The virtio definition is composed from [2] and [3].
[1] http://wiki.qemu.org/Main_Page
[2] http://docs.oasis-open.org/virtio/virtio/v1.0/csprd01/virtio-v1.0-csprd01.html
[3] http://en.wikipedia.org/wiki/OASIS_%28organization%29
Suggested-by: Mark Rutland <mark.rutland@arm.com>
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Signed-off-by: Laszlo Ersek <lersek@redhat.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Rob Herring <robh@kernel.org>
Peter Maydell suggested that we describe new devices / DTB nodes in the
kernel Documentation tree that we expose to arm "virt" guests in QEMU.
Although the kernel is not required to access the fw_cfg interface,
"Documentation/devicetree/bindings/arm" is probably the best central spot
to keep the fw_cfg description in.
Suggested-by: Peter Maydell <peter.maydell@linaro.org>
Just fix a minor typo about the example path.
Signed-off-by: Kaixu Xia <xiakaixu@huawei.com>
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
Current vendor-prefixes.txt already has "ak" prefix for Asahi Kasei Corp
by ae8c4209af2c(of: Add vendor prefix for Asahi Kasei Corp.)
It went through the appropriate review process. But, almost all
Asahi Kasei chip drivers are using "asahi-kasei" prefix today.
(arch/arm/boot/dts/tegra20-seaboard.dts only is using "ak,ak8975",
but there are instances of "asahi-kasei,ak8975" in other dts files.
And drivers/iio/magnetometer/ak8975.c doesn't support "ak,ak8975" prefix)
So, we made a mistake there.
In addition, checkpatch.pl reports WARNING if it is using "asahi-kasei"
prerfix in DT file.
(DT compatible string vendor "asahi-kasei" appears un-documented)
Marking it deprecated and warning with checkpatch is certainly
preferable. So, this patch replace "ak" to "asahi-kasei" in
vendor-prefixes.txt. (and fixup tegra20-seaboard)
OTOH, Asahi Kasei is usually referred to as "AKM", but this patch
doesn't care about it. Because no DT is using that today.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Rob Herring <robh+dt@kernel.org>
Pull scsi target fixes from Nicholas Bellinger:
"Mostly minor fixes this time, including:
- Add missing virtio-scsi -> TCM attribute conversion in vhost-scsi.
- Fix persistent reservations write exclusive handling to allow
readers for all registered I_T nexuses.
- Drop arbitrary maximum I/O size limit in order to process I/Os
larger than 4 MB, required for initiators that don't honor block
limits EVPD.
- Drop the now left-over fabric_max_sectors attribute"
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
iscsi-target: Fix typos in enum cmd_flags_table
MAINTAINERS: Add entry for iSER target driver
target: Allow Write Exclusive non-reservation holders to READ
target: Drop left-over fabric_max_sectors attribute
target: Drop arbitrary maximum I/O size limit
Documentation/target: Update fabric_ops to latest code
vhost-scsi: Add missing virtio-scsi -> TCM attribute conversion
Update documentation to reflect the fact that
/proc/sys/net/ipv4/route/max_size is no longer used for ipv4.
Signed-off-by: Ani Sinha <ani@arista.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
On some laptops, keyboard needs to be reset in order to successfully detect
touchpad (e.g., some Gigabyte laptop models with Elantech touchpads).
Without resettin keyboard touchpad pretends to be completely dead.
Based on the original patch by Mateusz Jończyk this version has been
expanded to include DMI based detection & application of the fix
automatically on the affected models of laptops. This has been confirmed to
fix problem by three users already on three different models of laptops.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=81331
Cc: stable@vger.kernel.org
Signed-off-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com>
Acked-by: Mateusz Jończyk <mat.jonczyk@o2.pl>
Tested-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com>
Tested by: Zakariya Dehlawi <zdehlawi@gmail.com>
Tested-by: Guillaum Bouchard <guillaum.bouchard@gmail.com>
This patch updates tcm_mod_builder.py to add/drop a handful of
struct target_core_fabric_ops functions to sync up with the
latest requirements to function in target_fabric_tf_ops_check().
Commit 39d99cff76bf ("thermal: cpu_cooling: introduce
of_cpufreq_cooling_register") taught the cpu cooling device to register
devices that were linked to the device tree but didn't update the
cpu-cooling-api documentation. Fix it.
Cc: Amit Daniel Kachhap <amit.kachhap@linaro.org>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Eduardo Valentin <edubezval@gmail.com>
Signed-off-by: Javi Merino <javi.merino@arm.com>
Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
Pull input layer fixes from Dmitry Torokhov:
"Fixes for v7 protocol for ALPS devices and few other driver fixes.
Also users can request input events to be stamped with boot time
timestamps, in addition to real and monotonic timestamps"
Input: hil_kbd - fix incorrect use of init_completion
Input: alps - v7: document the v7 touchpad packet protocol
Input: alps - v7: fix finger counting for > 2 fingers on clickpads
Input: alps - v7: sometimes a single touch is reported in mt[1]
Input: alps - v7: ignore new packets
Input: evdev - add CLOCK_BOOTTIME support
Input: psmouse - expose drift duration for IBM trackpoints
Input: stmpe - bias keypad columns properly
Input: stmpe - enforce device tree only mode
mfd: stmpe: add pull up/down register offsets for STMPE
Input: optimize events_per_packet count calculation
Input: edt-ft5x06 - fixed a macro coding style issue
Input: gpio_keys - replace timer and workqueue with delayed workqueue
Input: gpio_keys - allow separating gpio and irq in device tree
git://git.linaro.org/people/mike.turquette/linux
Pull clk framework updates from Mike Turquette:
"This is much later than usual due to several last minute bugs that had
to be addressed. As usual the majority of changes are new drivers and
modifications to existing drivers. The core recieved many fixes along
with the groundwork for several large changes coming in the future
which will better parition clock providers from clock consumers"
* tag 'clk-for-linus-3.19' of git://git.linaro.org/people/mike.turquette/linux: (86 commits)
clk: samsung: Fix Exynos 5420 pinctrl setup and clock disable failure due to domain being gated
ARM: OMAP3: clock: fix boot breakage in legacy mode
ARM: OMAP2+: clock: fix DPLL code to use new determine rate APIs
clk: Really fix deadlock with mmap_sem
clk: mmp: fix sparse non static symbol warning
clk: Change clk_ops->determine_rate to return a clk_hw as the best parent
clk: change clk_debugfs_add_file to take a struct clk_hw
clk: Don't expose __clk_get_accuracy
clk: Don't try to use a struct clk* after it could have been freed
clk: Remove unused function __clk_get_prepare_count
clk: samsung: Fix double add of syscore ops after driver rebind
clk: samsung: exynos4: set parent of sclk_hdmiphy to hdmi
clk: samsung: exynos4415: Fix build with PM_SLEEP disabled
clk: samsung: remove unnecessary inclusion of header files from clk.h
clk: samsung: remove unnecessary CONFIG_OF from clk.c
clk: samsung: Spelling s/bwtween/between/
clk: rockchip: Add support for the mmc clock phases using the framework
clk: rockchip: add bindings for the mmc clocks
clk: rockchip: rk3288 export i2s0_clkout for use in DT
clk: rockchip: use clock ID for DMC (memory controller) on rk3288
Pull x86 MPX fixes from Thomas Gleixner:
"Three updates for the new MPX infrastructure:
- Use the proper error check in the trap handler
- Add a proper config option for it
- Bring documentation up to date"
* 'x86-mpx-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, mpx: Give MPX a real config option prompt
x86, mpx: Update documentation
x86_64/traps: Fix always true condition
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux
Pull second batch of powerpc updates from Michael Ellerman:
"The highlight is the series that reworks the idle management on
powernv, which allows us to use deeper idle states on those machines.
There's the fix from Anton for the "BUG at kernel/smpboot.c:134!"
problem.
An i2c driver for powernv. This is acked by Wolfram Sang, and he
asked that we take it through the powerpc tree.
A fix for audit from rgb at Red Hat, acked by Paul Moore who is one of
the audit maintainers.
A patch from Ben to export the symbol map of our OPAL firmware as a
sysfs file, so that tools can use it.
Also some CXL fixes, a couple of powerpc perf fixes, a fix for
smt-enabled, and the patch to add __force to get_user() so we can use
bitwise types"
* tag 'powerpc-3.19-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux:
powerpc/powernv: Ignore smt-enabled on Power8 and later
powerpc/uaccess: Allow get_user() with bitwise types
powerpc/powernv: Expose OPAL firmware symbol map
powernv/powerpc: Add winkle support for offline cpus
powernv/cpuidle: Redesign idle states management
powerpc/powernv: Enable Offline CPUs to enter deep idle states
powerpc/powernv: Switch off MMU before entering nap/sleep/rvwinkle mode
i2c: Driver to expose PowerNV platform i2c busses
powerpc: add little endian flag to syscall_get_arch()
power/perf/hv-24x7: Use kmem_cache_free() instead of kfree
powerpc/perf/hv-24x7: Use per-cpu page buffer
cxl: Unmap MMIO regions when detaching a context
cxl: Add timeout to process element commands
cxl: Change contexts_lock to a mutex to fix sleep while atomic bug
powerpc: Secondary CPUs must set cpu_callin_map after setting active and online
Pull more ACPI and power management updates from Rafael Wysocki:
"These are regression fixes (leds-gpio, ACPI backlight driver,
operating performance points library, ACPI device enumeration
messages, cpupower tool), other bug fixes (ACPI EC driver, ACPI device
PM), some cleanups in the operating performance points (OPP)
framework, continuation of CONFIG_PM_RUNTIME elimination, a couple of
minor intel_pstate driver changes, a new MAINTAINERS entry for it and
an ACPI fan driver change needed for better support of thermal
management in user space.
Specifics:
- Fix a regression in leds-gpio introduced by a recent commit that
inadvertently changed the name of one of the properties used by the
driver (Fabio Estevam).
- Fix a regression in the ACPI backlight driver introduced by a
recent fix that missed one special case that had to be taken into
account (Aaron Lu).
- Drop the level of some new kernel messages from the ACPI core
introduced by a recent commit to KERN_DEBUG which they should have
used from the start and drop some other unuseful KERN_ERR messages
printed by ACPI (Rafael J Wysocki).
- Revert an incorrect commit modifying the cpupower tool (Prarit
Bhargava).
- Fix two regressions introduced by recent commits in the OPP library
and clean up some existing minor issues in that code (Viresh
Kumar).
- Continue to replace CONFIG_PM_RUNTIME with CONFIG_PM throughout the
tree (or drop it where that can be done) in order to make it
possible to eliminate CONFIG_PM_RUNTIME (Rafael J Wysocki, Ulf
Hansson, Ludovic Desroches).
There will be one more "CONFIG_PM_RUNTIME removal" batch after this
one, because some new uses of it have been introduced during the
current merge window, but that should be sufficient to finally get
rid of it.
- Make the ACPI EC driver more robust against race conditions related
to GPE handler installation failures (Lv Zheng).
- Prevent the ACPI device PM core code from attempting to disable
GPEs that it has not enabled which confuses ACPICA and makes it
report errors unnecessarily (Rafael J Wysocki).
- Add a "force" command line switch to the intel_pstate driver to
make it possible to override the blacklisting of some systems in
that driver if needed (Ethan Zhao).
- Improve intel_pstate code documentation and add a MAINTAINERS entry
for it (Kristen Carlson Accardi).
- Make the ACPI fan driver create cooling device interfaces witn
names that reflect the IDs of the ACPI device objects they are
associated with, except for "generic" ACPI fans (PNP ID "PNP0C0B").
That's necessary for user space thermal management tools to be able
to connect the fans with the parts of the system they are supposed
to be cooling properly. From Srinivas Pandruvada"
* tag 'pm+acpi-3.19-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (32 commits)
MAINTAINERS: add entry for intel_pstate
ACPI / video: update the skip case for acpi_video_device_in_dod()
power / PM: Eliminate CONFIG_PM_RUNTIME
NFC / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
SCSI / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
ACPI / EC: Fix unexpected ec_remove_handlers() invocations
Revert "tools: cpupower: fix return checks for sysfs_get_idlestate_count()"
tracing / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
x86 / PM: Replace CONFIG_PM_RUNTIME in io_apic.c
PM: Remove the SET_PM_RUNTIME_PM_OPS() macro
mmc: atmel-mci: use SET_RUNTIME_PM_OPS() macro
PM / Kconfig: Replace PM_RUNTIME with PM in dependencies
ARM / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
sound / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
phy / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
video / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
tty / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
spi: Replace CONFIG_PM_RUNTIME with CONFIG_PM
ACPI / PM: Do not disable wakeup GPEs that have not been enabled
ACPI / utils: Drop error messages from acpi_evaluate_reference()
Pull x86 platform driver update from Darren Hart:
- thinkpad-acpi: Switch to software mute, cleanups
- acerhdf: Bang-bang thermal governor, new models, cleanups
- dell-laptop: New keyboard backlight support and documentation
- toshiba_acpi: Keyboard backlight updates, hotkey handling
- dell-wmi: Keypress filtering, WMI event processing
- eeepc-laptop: Multiple cleanups, improved error handling, documentation
- hp_wireless: Inform the user if hp_wireless_input_setup()/add() fails
- misc: Code cleanups, quirks, various new IDs
* tag 'platform-drivers-x86-v3.19-1' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: (33 commits)
platform/x86/acerhdf: Still depends on THERMAL
acpi: Remove _OSI(Linux) for ThinkPads
thinkpad-acpi: Try to use full software mute control
acerhdf: minor clean up
acerhdf: added critical trip point
acerhdf: Use bang-bang thermal governor
acerhdf: Adding support for new models
acerhdf: Adding support for "manual mode"
dell-smo8800: Add more ACPI ids and change description of driver
toshiba_acpi: Add keyboard backlight mode change event
toshiba_acpi: Change notify funtion to handle more events
toshiba_acpi: Move hotkey enabling code to its own function
dell-wmi: Don't report keypresses on keybord illumination change
dell-wmi: Don't report keypresses for radio state changes
toshiba-acpi: Add missing ID (TOS6207)
Sony-laptop: Deletion of an unnecessary check before the function call "pci_dev_put"
platform: x86: Deletion of checks before backlight_device_unregister()
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull second set of media updates from Mauro Carvalho Chehab:
- Move drivers for really old legacy hardware to staging. Those are
using obsolete media kAPIs and are for hardware that nobody uses for
years. Simply not worth porting them to the new kAPIs. Of course,
if anyone pops up to fix, we can move them back from there
- While not too late, do some API fixups at the new colorspace API,
added for v3.19
- Some improvements for rcar_vin driver
- Some fixups at cx88 and vivid drivers
- Some Documentation fixups
* tag 'media/v3.19-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
[media] bq/c-qcam, w9966, pms: move to staging in preparation for removal
[media] tlg2300: move to staging in preparation for removal
[media] vino/saa7191: move to staging in preparation for removal
[media] MAINTAINERS: vivi -> vivid
[media] cx88: remove leftover start_video_dma() call
[media] cx88: add missing alloc_ctx support
[media] v4l2-ioctl: WARN_ON if querycap didn't fill device_caps
[media] vivid: fix CROP_BOUNDS typo for video output
[media] DocBook media: update version number and document changes
[media] vivid.txt: document new controls
[media] DocBook media: add missing ycbcr_enc and quantization fields
[media] v4l2-mediabus.h: use two __u16 instead of two __u32
[media] rcar_vin: Fix interrupt enable in progressive
[media] rcar_vin: Enable VSYNC field toggle mode
[media] rcar_vin: Add scaling support
[media] rcar_vin: Add DT support for r8a7793 and r8a7794 SoCs
[media] rcar_vin: Add YUYV capture format support
1) Fix NBMA tunnel mac header handling in GRE, from Timo Teräs.
2) Fix a NAPI race in the fec driver, from Nimrod Andy.
3) The new IFF_VNET_LE bit is outside the size of the flags member it
is stored in (which is 16-bits), store the state locally in the
drivers. From Michael S Tsirkin.
4) We are kicking the tires with the new wireless maintainership
situation. Bluetooth fixes via Johan Hedberg, and mac80211 fixes
from Johannes Berg.
5) Fix locking and leaks in geneve driver, from Jesse Gross.
6) Make netlink TX mmap code always copy, so we don't have to be
potentially exposed to the user changing the underlying contents
from underneath us.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (63 commits)
be2net: Fix incorrect setting of tunnel offload flag in netdev features
bnx2x: fix typos in "configure"
xen-netback: support frontends without feature-rx-notify again
MAINTAINERS: changes for wireless
cxgb4: Fix decoding QSA module for ethtool get settings
geneve: Fix races between socket add and release.
geneve: Remove socket and offload handlers at destruction.
netlink: Don't reorder loads/stores before marking mmap netlink frame as available
Bluetooth: Fix bug with filter in service discovery optimization
mac80211: free management frame keys when removing station
net: Disallow providing non zero VLAN ID for NIC drivers FDB add flow
net/mlx4: Cache line CQE/EQE stride fixes
net: fec: Fix NAPI race
xen-netfront: use napi_complete() correctly to prevent Rx stalling
ip_tunnel: Add missing validation of encap type to ip_tunnel_encap_setup()
ip_tunnel: Add sanity checks to ip_tunnel_encap_add_ops()
net: Allow FIXED_PHY to be modular.
if_tun: drop broken IFF_VNET_LE
macvtap: drop broken IFF_VNET_LE
Pull KVM update from Paolo Bonzini:
"3.19 changes for KVM:
- spring cleaning: removed support for IA64, and for hardware-
assisted virtualization on the PPC970
- ARM, PPC, s390 all had only small fixes
For x86:
- small performance improvements (though only on weird guests)
- usual round of hardware-compliancy fixes from Nadav
- APICv fixes
- XSAVES support for hosts and guests. XSAVES hosts were broken
because the (non-KVM) XSAVES patches inadvertently changed the KVM
userspace ABI whenever XSAVES was enabled; hence, this part is
going to stable. Guest support is just a matter of exposing the
feature and CPUID leaves support"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (179 commits)
KVM: move APIC types to arch/x86/
KVM: PPC: Book3S: Enable in-kernel XICS emulation by default
KVM: PPC: Book3S HV: Improve H_CONFER implementation
KVM: PPC: Book3S HV: Fix endianness of instruction obtained from HEIR register
KVM: PPC: Book3S HV: Remove code for PPC970 processors
KVM: PPC: Book3S HV: Tracepoints for KVM HV guest interactions
KVM: PPC: Book3S HV: Simplify locking around stolen time calculations
arch: powerpc: kvm: book3s_paired_singles.c: Remove unused function
arch: powerpc: kvm: book3s_pr.c: Remove unused function
arch: powerpc: kvm: book3s.c: Remove some unused functions
arch: powerpc: kvm: book3s_32_mmu.c: Remove unused function
KVM: PPC: Book3S HV: Check wait conditions before sleeping in kvmppc_vcore_blocked
KVM: PPC: Book3S HV: ptes are big endian
KVM: PPC: Book3S HV: Fix inaccuracies in ICP emulation for H_IPI
KVM: PPC: Book3S HV: Fix KSM memory corruption
KVM: PPC: Book3S HV: Fix an issue where guest is paused on receiving HMI
KVM: PPC: Book3S HV: Fix computation of tlbie operand
KVM: PPC: Book3S HV: Add missing HPTE unlock
KVM: PPC: BookE: Improve irq inject tracepoint
arm/arm64: KVM: Require in-kernel vgic for the arch timers
Second round of input updates for 3.19.
* pm-opp:
PM / OPP: do error handling at the bottom of dev_pm_opp_add_dynamic()
PM / OPP: handle allocation of device_opp in a separate routine
PM / OPP: reuse find_device_opp() instead of duplicating code
PM / OPP: Staticize __dev_pm_opp_remove()
PM / OPP: replace kfree with kfree_rcu while freeing 'struct device_opp'
* pm-cpufreq:
intel_pstate: Add a few comments
intel_pstate: add kernel parameter to force loading
* pm-tools:
Pull thermal management update from Zhang Rui:
"Summary:
- of-thermal extension to allow drivers to register and use its
functionality in a better way, without exploiting thermal core.
From Lukasz Majewski.
- Fix a bug in intel_soc_dts_thermal driver which calls a sleep
function in interrupt handler. From Maurice Petallo.
- add a thermal UAPI header file for exporting the thermal generic
netlink information to user-space. From Florian Fainelli.
- First round of refactoring in Exynos driver. Bartlomiej and Lukasz
are attempting to make it lean and easier to understand.
- New thermal driver for Rockchip (rk3288), with support for DT
thermal. From Caesar Wang.
- New thermal driver for Nvidia, Tegra124 SOCTHERM driver, with
support for DT thermal. From Mikko Perttunen.
- New cooling device, based on common clock framework. From Eduardo
Valentin.
- a couple of small fixes in thermal core framework. From Srinivas
Pandruvada, Javi Merino, Luis Henriques.
- Dropping Armada A375-Z1 SoC thermal support as the chip is not in
the market, armada folks decided to drop its support.
- a couple of small fixes and cleanups in int340x thermal driver"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (58 commits)
thermal: provide an UAPI header file
Thermal/int340x: Clear the error value of the last acpi_bus_get_device() call
thermal/powerclamp: add id for braswell cpu
thermal: Intel SoC DTS: Don't do thermal zone update inside spin_lock
Thermal: fix platform_no_drv_owner.cocci warnings
Thermal/int340x: avoid unnecessary pointer casting
thermal: int3403: Delete a check before thermal_zone_device_unregister()
thermal/int3400: export uuids
thermal: of: Extend current of-thermal.c code to allow setting emulated temp
thermal: of: Extend of-thermal to export table of trip points
thermal: of: Rename struct __thermal_trip to struct thermal_trip
thermal: of: Extend of-thermal.c to provide check if trip point is valid
thermal: of: Extend of-thermal.c to provide number of trip points
thermal: Fix error path in thermal_init()
thermal: lock the thermal zone when switching governors
thermal: core: ignore invalid trip temperature
thermal: armada: Remove support for A375-Z1 SoC
thermal: rockchip: add driver for thermal
dt-bindings: document Rockchip thermal
thermal: exynos: remove exynos_tmu_data.h include
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm
Pull pwm updates from Thierry Reding:
"There are two new drivers, one for the BCM2835 (Raspberry Pi) and one
used in conjunction with the LCD controller on various Atmel SoCs.
The Samsung PWM driver can now be built for 64-bit ARM (Exynos7).
A couple of fixes have been applied to the FTM PWM driver and system
sleep support was added"
* tag 'pwm/for-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm:
pwm: atmel-hlcdc: add at91sam9x5 and sama5d3 errata handling
pwm: ftm: Add Power Management support for FTM PWM
pwm: ftm: Add regmap rbtree type cache support
pwm: ftm: Correctly track usage count
pwm: samsung: Allow Samsung PWM driver to be enabled on Exynos7
pwm: add DT bindings documentation for atmel-hlcdc-pwm driver
pwm: add support for atmel-hlcdc-pwm device
pwm: Add BCM2835 PWM driver
Pull input subsystem updates from Dmitry Torokhov:
"Two new drivers for Elan hardware (for I2C touchpad and touchscreen
found in several Chromebooks and other devices), a driver for Goodix
touch panel, and small fixes to Cypress I2C trackpad and other input
drivers.
Also we switched to use __maybe_unused instead of gating suspend/
resume code with #ifdef guards to get better compile coverage"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (27 commits)
Input: gpio_keys - fix warning regarding uninitialized 'button' variable
Input: add support for Elan eKTH I2C touchscreens
Input: gpio_keys - fix warning regarding uninitialized 'irq' variable
Input: cyapa - use 'error' for error codes
Input: cyapa - fix resuming the device
Input: gpio_keys - add device tree support for interrupt only keys
Input: amikbd - allocate temporary keymap buffer on the stack
Input: amikbd - fix build if !CONFIG_HW_CONSOLE
Input: lm8323 - missing error check in lm8323_set_disable()
Input: initialize device counter variables with -1
Input: initialize input_no to -1 to avoid subtraction
Input: i8042 - do not try to load on Intel NUC D54250WYK
Input: atkbd - correct MSC_SCAN events for force_release keys
Input: cyapa - switch to using managed resources
Input: lifebook - use "static inline" instead of "inline" in lifebook.h
Input: touchscreen - use __maybe_unused instead of ifdef around suspend/resume
Input: mouse - use __maybe_unused instead of ifdef around suspend/resume
Input: misc - use __maybe_unused instead of ifdef around suspend/resume
Input: cap11xx - support for irq-active-high option
Input: cap11xx - add support for various cap11xx devices
Pull MTD updates from Brian Norris:
"Summary:
- Add device tree support for DoC3
- SPI NOR:
Refactoring, for better layering between spi-nor.c and its
driver users (e.g., m25p80.c)
New flash device support
Support 6-byte ID strings
- NAND:
New NAND driver for Allwinner SoC's (sunxi)
GPMI NAND: add support for raw (no ECC) access, for testing
purposes
Add ATO manufacturer ID
A few odd driver fixes
- MTD tests:
Allow testers to compensate for OOB bitflips in oobtest
Fix a torturetest regression
- nandsim: Support longer ID byte strings
And more"
* tag 'for-linus-20141215' of git://git.infradead.org/linux-mtd: (63 commits)
mtd: tests: abort torturetest on erase errors
mtd: physmap_of: fix potential NULL dereference
mtd: spi-nor: allow NULL as chip name and try to auto detect it
mtd: nand: gpmi: add raw oob access functions
mtd: nand: gpmi: add proper raw access support
mtd: nand: gpmi: add gpmi_copy_bits function
mtd: spi-nor: factor out write_enable() for erase commands
mtd: spi-nor: add support for s25fl128s
mtd: spi-nor: remove the jedec_id/ext_id
mtd: spi-nor: add id/id_len for flash_info{}
mtd: nand: correct the comment of function nand_block_isreserved()
jffs2: Drop bogus if in comment
mtd: atmel_nand: replace memcpy32_toio/memcpy32_fromio with memcpy
mtd: cafe_nand: drop duplicate .write_page implementation
mtd: m25p80: Add support for serial flash Spansion S25FL132K
MTD: m25p80: fix inconsistency in m25p_ids compared to spi_nor_ids
mtd: spi-nor: improve wait-till-ready timeout loop
mtd: delete unnecessary checks before two function calls
mtd: nand: omap: Fix NAND enumeration on 3430 LDP
mtd: nand: add ATO manufacturer info
Update the version to 3.19.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Document the new 'Y'CbCr Encoding' and 'Quantization' controls.
I forgot to add these fields to the relevant structs.
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing updates from Steven Rostedt:
"As the merge window is still open, and this code was not as complex as
I thought it might be. I'm pushing this in now.
This will allow Thomas to debug his irq work for 3.20.
This adds two new features:
1) Allow traceopoints to be enabled right after mm_init().
By passing in the trace_event= kernel command line parameter,
tracepoints can be enabled at boot up. For debugging things like
the initialization of interrupts, it is needed to have tracepoints
enabled very early. People have asked about this before and this
has been on my todo list. As it can be helpful for Thomas to debug
his upcoming 3.20 IRQ work, I'm pushing this now. This way he can
add tracepoints into the IRQ set up and have users enable them when
things go wrong.
2) Have the tracepoints printed via printk() (the console) when they
are triggered.
If the irq code locks up or reboots the box, having the tracepoint
output go into the kernel ring buffer is useless for debugging.
But being able to add the tp_printk kernel command line option
along with the trace_event= option will have these tracepoints
printed as they occur, and that can be really useful for debugging
early lock up or reboot problems.
This code is not that intrusive and it passed all my tests. Thomas
tried them out too and it works for his needs.
Link: http://lkml.kernel.org/r/20141214201609.126831471@goodmis.org"
* tag 'trace-3.19-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Add tp_printk cmdline to have tracepoints go to printk()
tracing: Move enabling tracepoints to just after rcu_init()
The STMPE keypad controller is only used with device tree configured
systems, so force the configuration to come from device tree only, and now
actually get the rows and cols from the device tree too.
Acked-by: Lee Jones <lee.jones@linaro.org>
This change allows specify interrupt for buttons separately form gpio,
potentially allowing to form several "clusters" of buttons on
different interrupts.
Button defined without both gpio and irq in device tree is a hared error
instead of a warning now.
Tested-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Prepare input updates for 3.19.
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds
Pull LED subsystem update from Bryan Wu:
"We got some cleanup and driver for LP8860 as well as some patches for
LED Flash Class"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds:
leds: lp8860: Fix module dependency
leds: lp8860: Introduce TI lp8860 4 channel LED driver
leds: Add support for setting brightness in a synchronous way
leds: implement sysfs interface locking mechanism
leds: syscon: handle multiple syscon instances
leds: delete copy/paste mistake
leds: regulator: Convert to devm_regulator_get_exclusive
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver updates from Greg KH:
"Here's the big staging tree pull request for 3.19-rc1.
We continued to delete more lines than were added, always a good
thing, but not at a huge rate this release, only about 70k lines
removed overall mostly from removing the horrid bcm driver.
Lots of normal staging driver cleanups and fixes all over the place,
well over a thousand of them, the shortlog shows all the horrid
details.
The "contentious" thing here is the movement of the Android binder
code out of staging into the "real" part of the kernel. This is code
that has been stable for a few years now and is working as-is in the
tens of millions of devices with no issues. Yes, the code is horrid,
and the userspace api leaves a lot to be desired, but it's not going
to change due to legacy issues that we have no control over. Because
so many devices and companies rely on this, and the code is stable,
might as well promote it out of staging.
This was all discussed at the Linux Plumbers conference, and everyone
participating agreed that this was the best way forward.
There is work happening to replace the binder code with something new
that is happening right now, but I don't expect to see the results of
that work for another year at the earliest. If that ever happens, and
Android switches over to it, I'll gladly remove this version.
As for maintainers, I'll be glad to maintain this code, I've been
doing it for the past few years with no problems. I'll send a
MAINTAINERS entry for it before 3.19-final is out, still need to talk
to the Google developers about if they are willing to help with it or
not, last I checked they were, which was good.
All of these patches have been in linux-next for a while with no
reported issues"
* tag 'staging-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1382 commits)
Staging: slicoss: Fix long line issues in slicoss.c
staging: rtl8712: remove unnecessary else after return
staging: comedi: change some printk calls to pr_err
staging: rtl8723au: hal: Removed the extra semicolon
lustre: Deletion of unnecessary checks before three function calls
staging: lustre: fix sparse warnings: static function declaration
staging: lustre: fixed sparse warnings related to static declarations
staging: unisys: remove duplicate header
staging: unisys: remove unneeded structure
staging: ft1000 : replace __attribute ((__packed__) with __packed
drivers: staging: rtl8192e: Include "asm/unaligned.h" instead of "access_ok.h" in "rtl819x_BAProc.c"
Drivers:staging:rtl8192e: Fixed checkpatch warning
Drivers:staging:clocking-wizard: Added a newline
staging: clocking-wizard: check for a valid clk_name pointer
staging: rtl8723au: Hal_InitPGData() avoid unnecessary typecasts
staging: rtl8723au: _DisableAnalog(): Avoid zero-init variables unnecessarily
staging: rtl8723au: Remove unnecessary wrapper _ResetDigitalProcedure1()
staging: rtl8723au: _ResetDigitalProcedure1_92C() reduce code obfuscation
staging: rtl8723au: Remove unnecessary wrapper _DisableRFAFEAndResetBB()
staging: rtl8723au: _DisableRFAFEAndResetBB8192C(): Reduce code obfuscation
