commit 1be7107fbe18eed3e319a6c3e83c78254b693acb upstream.
Stack guard page is a useful feature to reduce a risk of stack smashing
into a different mapping. We have been using a single page gap which
is sufficient to prevent having stack adjacent to a different mapping.
But this seems to be insufficient in the light of the stack usage in
userspace. E.g. glibc uses as large as 64kB alloca() in many commonly
used functions. Others use constructs liks gid_t buffer[NGROUPS_MAX]
which is 256kB or stack strings with MAX_ARG_STRLEN.
This will become especially dangerous for suid binaries and the default
no limit for the stack size limit because those applications can be
tricked to consume a large portion of the stack and a single glibc call
could jump over the guard page. These attacks are not theoretical,
unfortunatelly.
Make those attacks less probable by increasing the stack guard gap
to 1MB (on systems with 4k pages; but make it depend on the page size
because systems with larger base pages might cap stack allocations in
the PAGE_SIZE units) which should cover larger alloca() and VLA stack
allocations. It is obviously not a full fix because the problem is
somehow inherent, but it should reduce attack space a lot.
One could argue that the gap size should be configurable from userspace,
but that can be done later when somebody finds that the new 1MB is wrong
for some special case applications. For now, add a kernel command line
option (stack_guard_gap) to specify the stack gap size (in page units).
Implementation wise, first delete all the old code for stack guard page:
because although we could get away with accounting one extra page in a
stack vma, accounting a larger gap can break userspace - case in point,
a program run with "ulimit -S -v 20000" failed when the 1MB gap was
counted for RLIMIT_AS; similar problems could come with RLIMIT_MLOCK
and strict non-overcommit mode.
Instead of keeping gap inside the stack vma, maintain the stack guard
gap as a gap between vmas: using vm_start_gap() in place of vm_start
(or vm_end_gap() in place of vm_end if VM_GROWSUP) in just those few
places which need to respect the gap - mainly arch_get_unmapped_area(),
and and the vma tree's subtree_gap support for that.
Original-patch-by: Oleg Nesterov <oleg@redhat.com>
Original-patch-by: Michal Hocko <mhocko@suse.com>
Tested-by: Helge Deller <deller@gmx.de> # parisc
[wt: backport to 4.11: adjust context]
[wt: backport to 4.9: adjust context ; kernel doc was not in admin-guide]
[wt: backport to 4.4: adjust context ; drop ppc hugetlb_radix changes]
Signed-off-by: Willy Tarreau <w@1wt.eu>
[gkh: minor build fixes for 4.4]
commit f0e421b1bf7af97f026e1bb8bfe4c5a7a8c08f42 upstream.
Some kernel features don't currently work if a task puts a non-zero
address tag in its stack pointer, frame pointer, or frame record entries
(FP, LR).
For example, with a tagged stack pointer, the kernel can't deliver
signals to the process, and the task is killed instead. As another
example, with a tagged frame pointer or frame records, perf fails to
generate call graphs or resolve symbols.
For now, just document these limitations, instead of finding and fixing
everything that doesn't work, as it's not known if anyone needs to use
tags in these places anyway.
In addition, as requested by Dave Martin, generalize the limitations
into a general kernel address tag policy, and refactor
tagged-pointers.txt to include it.
Fixes: d50240a5f6ce ("arm64: mm: permit use of tagged pointers at EL0")
Reviewed-by: Dave Martin <Dave.Martin@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Kristina Martsenko <kristina.martsenko@arm.com>
commit 6e17b4181603d183d20c73f4535529ddf2a2a020 upstream.
This patch adds support for APB0 in H3. It seems to be compatible with
earlier SOCs. apb0 gates controls R_ block peripherals (R_PIO, R_IR,
etc).
Since this gates behave just like any Allwinner clock gate, add a generic
compatible that can be reused if we don't have any clock to protect.
Signed-off-by: Krzysztof Adamski <k@japko.eu>
[Maxime: Removed the H3 compatible from the simple-gates driver, reworked
the commit log a bit]
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Cc: Julia Lawall <julia.lawall@lip6.fr>
commit d29216842a85c7970c536108e093963f02714498 upstream.
CAI Qian <caiqian@redhat.com> pointed out that the semantics
of shared subtrees make it possible to create an exponentially
increasing number of mounts in a mount namespace.
mkdir /tmp/1 /tmp/2
mount --make-rshared /
for i in $(seq 1 20) ; do mount --bind /tmp/1 /tmp/2 ; done
Will create create 2^20 or 1048576 mounts, which is a practical problem
as some people have managed to hit this by accident.
As such CVE-2016-6213 was assigned.
Ian Kent <raven@themaw.net> described the situation for autofs users
as follows:
> The number of mounts for direct mount maps is usually not very large because of
> the way they are implemented, large direct mount maps can have performance
> problems. There can be anywhere from a few (likely case a few hundred) to less
> than 10000, plus mounts that have been triggered and not yet expired.
> Indirect mounts have one autofs mount at the root plus the number of mounts that
> The number of autofs indirect map entries can range from a few to the common
> case of several thousand and in rare cases up to between 30000 and 50000. I've
> not heard of people with maps larger than 50000 entries.
> The larger the number of map entries the greater the possibility for a large
> number of active mounts so it's not hard to expect cases of a 1000 or somewhat
> more active mounts.
So I am setting the default number of mounts allowed per mount
namespace at 100,000. This is more than enough for any use case I
know of, but small enough to quickly stop an exponential increase
in mounts. Which should be perfect to catch misconfigurations and
malfunctioning programs.
For anyone who needs a higher limit this can be changed by writing
to the new /proc/sys/fs/mount-max sysctl.
Tested-by: CAI Qian <caiqian@redhat.com>
[bwh: Backported to 4.4: adjust context]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit d1b4c689d4130bcfd3532680b64db562300716b6 upstream.
mmapped netlink has a number of unresolved issues:
- TX zerocopy support had to be disabled more than a year ago via
commit 4682a0358639b29cf ("netlink: Always copy on mmap TX.")
because the content of the mmapped area can change after netlink
attribute validation but before message processing.
- RX support was implemented mainly to speed up nfqueue dumping packet
payload to userspace. However, since commit ae08ce0021087a5d812d2
("netfilter: nfnetlink_queue: zero copy support") we avoid one copy
with the socket-based interface too (via the skb_zerocopy helper).
The other problem is that skbs attached to mmaped netlink socket
behave different from normal skbs:
- they don't have a shinfo area, so all functions that use skb_shinfo()
(e.g. skb_clone) cannot be used.
- reserving headroom prevents userspace from seeing the content as
it expects message to start at skb->head.
See for instance
commit aa3a022094fa ("netlink: not trim skb for mmaped socket when dump").
- skbs handed e.g. to netlink_ack must have non-NULL skb->sk, else we
crash because it needs the sk to check if a tx ring is attached.
Also not obvious, leads to non-intuitive bug fixes such as 7c7bdf359
("netfilter: nfnetlink: use original skbuff when acking batches").
mmaped netlink also didn't play nicely with the skb_zerocopy helper
used by nfqueue and openvswitch. Daniel Borkmann fixed this via
commit 6bb0fef489f6 ("netlink, mmap: fix edge-case leakages in nf queue
zero-copy")' but at the cost of also needing to provide remaining
length to the allocation function.
nfqueue also has problems when used with mmaped rx netlink:
- mmaped netlink doesn't allow use of nfqueue batch verdict messages.
Problem is that in the mmap case, the allocation time also determines
the ordering in which the frame will be seen by userspace (A
allocating before B means that A is located in earlier ring slot,
but this also means that B might get a lower sequence number then A
since seqno is decided later. To fix this we would need to extend the
spinlocked region to also cover the allocation and message setup which
isn't desirable.
- nfqueue can now be configured to queue large (GSO) skbs to userspace.
Queing GSO packets is faster than having to force a software segmentation
in the kernel, so this is a desirable option. However, with a mmap based
ring one has to use 64kb per ring slot element, else mmap has to fall back
to the socket path (NL_MMAP_STATUS_COPY) for all large packets.
To use the mmap interface, userspace not only has to probe for mmap netlink
support, it also has to implement a recv/socket receive path in order to
handle messages that exceed the size of an rx ring element.
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Ken-ichirou MATSUZAWA <chamaken@gmail.com>
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Shi Yuejie <shiyuejie@outlook.com>
commit 6bee835dd54e279f3d3ae2eca92a9c394b4fd028 upstream.
Move mic/mpssd examples to samples and remove it from Documentation
Makefile. Create a new Makefile to build mic/mpssd. It can be built
from top level directory or from mic/mpssd directory:
Run make -C samples/mic/mpssd or cd samples/mic/mpssd; make
Acked-by: Jonathan Corbet <corbet@lwn.net>
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
[backported to 4.4-stable as this code is broken on newer versions of
gcc and we don't want to break the build for a Documentation sample.
- gregkh]
commit 47512cfd0d7a8bd6ab71d01cd89fca19eb2093eb upstream.
The goldfish platform code registers the platform device unconditionally
which causes havoc in several ways if the goldfish_pdev_bus driver is
enabled:
- Access to the hardcoded physical memory region, which is either not
available or contains stuff which is completely unrelated.
- Prevents that the interrupt of the serial port can be requested
- In case of a spurious interrupt it goes into a infinite loop in the
interrupt handler of the pdev_bus driver (which needs to be fixed
seperately).
Add a 'goldfish' command line option to make the registration opt-in when
the platform is compiled in.
I'm seriously grumpy about this engineering trainwreck, which has seven
SOBs from Intel developers for 50 lines of code. And none of them figured
out that this is broken. Impressive fail!
Fixes: ddd70cf93d78 ("goldfish: platform device for x86")
Reported-by: Gabriel C <nix.or.die@gmail.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
commit 2e575cbc930901718cc18e084566ecbb9a4b5ebb upstream.
The type of AVIC interrupt controller found on i.MX31 is one-cell,
namely 31 for CCM DVFS and 53 for CCM, however for clock control
module its interrupts are specified as 3-cells, fix it.
Fixes: ef0e4a606fb6 ("ARM: mx31: Replace clk_register_clkdev with clock DT lookup")
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
commit 0d808df06a44200f52262b6eb72bcb6042f5a7c5 upstream.
When switching from/to a guest that has a transaction in progress,
we need to save/restore the checkpointed register state. Although
XER is part of the CPU state that gets checkpointed, the code that
does this saving and restoring doesn't save/restore XER.
This fixes it by saving and restoring the XER. To allow userspace
to read/write the checkpointed XER value, we also add a new ONE_REG
specifier.
The visible effect of this bug is that the guest may see its XER
value being corrupted when it uses transactions.
Fixes: e4e38121507a ("KVM: PPC: Book3S HV: Add transactional memory support")
Fixes: 0a8eccefcb34 ("KVM: PPC: Book3S HV: Add missing code for transaction reclaim on guest exit")
Signed-off-by: Paul Mackerras <paulus@ozlabs.org>
Reviewed-by: Thomas Huth <thuth@redhat.com>
This reverts commit fcf5e5198b447969ed2a56ec335dae3c695a6b46 which is
548acf19234dbda5a52d5a8e7e205af46e9da840 upstream.
Cc: Borislav Petkov <bp@suse.de>
commit 548acf19234dbda5a52d5a8e7e205af46e9da840 upstream.
Huge amounts of help from Andy Lutomirski and Borislav Petkov to
produce this. Andy provided the inspiration to add classes to the
exception table with a clever bit-squeezing trick, Boris pointed
out how much cleaner it would all be if we just had a new field.
Linus Torvalds blessed the expansion with:
' I'd rather not be clever in order to save just a tiny amount of space
in the exception table, which isn't really criticial for anybody. '
The third field is another relative function pointer, this one to a
handler that executes the actions.
We start out with three handlers:
1: Legacy - just jumps the to fixup IP
2: Fault - provide the trap number in %ax to the fixup code
3: Cleaned up legacy for the uaccess error hack
Signed-off-by: Tony Luck <tony.luck@intel.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/f6af78fcbd348cf4939875cfda9c19689b5e50b8.1455732970.git.tony.luck@intel.com
commit 930e19248e9b61da36c967687ca79c4d5f977919 upstream.
On suspend/resume cycle, selftest is executed to reset i8042 controller.
But when this is done in Asus devices, subsequent calls to detect/init
functions to elantech driver fails. Skipping selftest fixes this problem.
An easier step to reproduce this problem is adding i8042.reset=1 as a
kernel parameter. On Asus laptops, it'll make the system to start with the
touchpad already stuck, since psmouse_probe forcibly calls the selftest
function.
This patch was inspired by John Hiesey's change[1], but, since this problem
affects a lot of models of Asus, let's avoid running selftests on them.
All models affected by this problem:
A455LD
K401LB
K501LB
K501LX
R409L
V502LX
X302LA
X450LCP
X450LD
X455LAB
X455LDB
X455LF
Z450LA
[1]: https://marc.info/?l=linux-input&m=144312209020616&w=2
Fixes: "ETPS/2 Elantech Touchpad dies after resume from suspend"
(https://bugzilla.kernel.org/show_bug.cgi?id=107971)
Signed-off-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com>
commit 93bfe79b03365f410aa91caf04263173c008ecdf upstream.
The mvs1 and mvs2 switches are actually called 5vs1 and 5vs2 on
some datasheets. Let's rename them to match the datasheets and
also match the RPM based regulator driver which calls these by
their 5vs names (see qcom_smd-regulator.c). There aren't any
users of these regulators so far, so there aren't any concerns of
DT ABI breakage here. While we're here making updates to the
switches, also mandate usage of the OCP irq for these switches
too.
Cc: Bjorn Andersson <bjorn.andersson@linaro.org>
Fixes: e92a4047419c ("regulator: Add QCOM SPMI regulator driver")
Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit c333dfe8dba7d3e47e97e1cee3c38123e19ae73c upstream.
The S4 supply is sometimes called the boost regulator because it
outputs 5V. Typically it's connected to the 5vs1 and 5vs2
switches for use in USB OTG and HDMI applications. Add support
for this regulator which was mistakenly left out from the initial
submission of this driver.
commit 7440926ed9623dceca3310c5f437d06c859dc02b upstream.
Documentation incorrectly refers to struct pinctrl_desc, where no such flag is
available. Replace the name of the struct.
Fixes: commit 8c4c2016345f ("pinctrl: move strict option to pinmux_ops")
commit 3610a2add39365a0f153154c60169a66c616d50f upstream.
The compilation emits a warning in function ‘snprintf’,
inlined from ‘set_cmdline’ at
../Documentation/mic/mpssd/mpssd.c:1541:9:
/usr/include/x86_64-linux-gnu/bits/stdio2.h:64:10:
warning: call to __builtin___snprintf_chk will always overflow
destination buffer
This was introduced in commit f4a66c204482 ("misc: mic: Update MIC host
daemon with COSM changes") and is fixed by reverting the changes to the
size argument of these snprintf statements.
Cc: Ashutosh Dixit <ashutosh.dixit@intel.com>
Signed-off-by: Mike Danese <mikedanese@google.com>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
commit 543852af8e5902aee8f7c72c89e1513663e0f696 upstream.
SARADC controller needs to be reset before programming it, otherwise
it will not function properly.
Signed-off-by: Caesar Wang <wxt@rock-chips.com>
Cc: Jonathan Cameron <jic23@kernel.org>
Cc: Heiko Stuebner <heiko@sntech.de>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: linux-iio@vger.kernel.org
Cc: linux-rockchip@lists.infradead.org
Tested-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
[ Upstream commit 65376df582174ffcec9e6471bf5b0dd79ba05e4a ]
Commit b76437579d13 ("procfs: mark thread stack correctly in
proc/<pid>/maps") added [stack:TID] annotation to /proc/<pid>/maps.
Finding the task of a stack VMA requires walking the entire thread list,
turning this into quadratic behavior: a thousand threads means a
thousand stacks, so the rendering of /proc/<pid>/maps needs to look at a
million combinations.
The cost is not in proportion to the usefulness as described in the
patch.
Drop the [stack:TID] annotation to make /proc/<pid>/maps (and
/proc/<pid>/numa_maps) usable again for higher thread counts.
The [stack] annotation inside /proc/<pid>/task/<tid>/maps is retained, as
identifying the stack VMA there is an O(1) operation.
Siddesh said:
"The end users needed a way to identify thread stacks programmatically and
there wasn't a way to do that. I'm afraid I no longer remember (or have
access to the resources that would aid my memory since I changed
employers) the details of their requirement. However, I did do this on my
own time because I thought it was an interesting project for me and nobody
really gave any feedback then as to its utility, so as far as I am
concerned you could roll back the main thread maps information since the
information is available in the thread-specific files"
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Siddhesh Poyarekar <siddhesh.poyarekar@gmail.com>
Cc: Shaohua Li <shli@fb.com>
commit b8612e517c3c9809e1200b72c474dbfd969e5a83 upstream.
Signing a module should only make it trusted by the specific kernel it
was built for, not anything else. If a module signing key is used for
multiple ABI-incompatible kernels, the modules need to include enough
version information to distinguish them.
commit b6350c21cfe8aa9d65e189509a23c0ea4b8362c2 upstream.
Update PAT documentation to describe how PAT is initialized under
various configurations.
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Luis R. Rodriguez <mcgrof@suse.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: elliott@hpe.com
Cc: konrad.wilk@oracle.com
Cc: paul.gortmaker@windriver.com
Cc: xen-devel@lists.xenproject.org
Link: http://lkml.kernel.org/r/1458769323-24491-8-git-send-email-toshi.kani@hpe.com
commit 72d8c36ec364c82bf1bf0c64dfa1041cfaf139f7 upstream.
sas_ata_strategy_handler() adds the works of the ata error handler to
system_unbound_wq. This workqueue asynchronously runs work items, so the
ata error handler will be performed concurrently on different CPUs. In
this case, ->host_failed will be decreased simultaneously in
scsi_eh_finish_cmd() on different CPUs, and become abnormal.
It will lead to permanently inequality between ->host_failed and
->host_busy, and scsi error handler thread won't start running. IO
errors after that won't be handled.
Since all scmds must have been handled in the strategy handler, just
remove the decrement in scsi_eh_finish_cmd() and zero ->host_busy after
the strategy handler to fix this race.
Fixes: 50824d6c5657 ("[SCSI] libsas: async ata-eh")
Signed-off-by: Wei Fang <fangwei1@huawei.com>
Reviewed-by: James Bottomley <jejb@linux.vnet.ibm.com>
commit 5138806f16c74c7cb8ac3e408a859c79eb7c9567 upstream.
IIO_CHAN_INFO_RAW was returning processed data which was incorrect.
This also adds the IIO_CHAN_INFO_SCALE value to convert to a processed value.
Signed-off-by: Matt Ranostay <mranostay@gmail.com>
commit 759c01142a5d0f364a462346168a56de28a80f52 upstream.
On no-so-small systems, it is possible for a single process to cause an
OOM condition by filling large pipes with data that are never read. A
typical process filling 4000 pipes with 1 MB of data will use 4 GB of
memory. On small systems it may be tricky to set the pipe max size to
prevent this from happening.
This patch makes it possible to enforce a per-user soft limit above
which new pipes will be limited to a single page, effectively limiting
them to 4 kB each, as well as a hard limit above which no new pipes may
be created for this user. This has the effect of protecting the system
against memory abuse without hurting other users, and still allowing
pipes to work correctly though with less data at once.
The limit are controlled by two new sysctls : pipe-user-pages-soft, and
pipe-user-pages-hard. Both may be disabled by setting them to zero. The
default soft limit allows the default number of FDs per process (1024)
to create pipes of the default size (64kB), thus reaching a limit of 64MB
before starting to create only smaller pipes. With 256 processes limited
to 1024 FDs each, this results in 1024*64kB + (256*1024 - 1024) * 4kB =
1084 MB of memory allocated for a user. The hard limit is disabled by
default to avoid breaking existing applications that make intensive use
of pipes (eg: for splicing).
Reported-by: socketpair@gmail.com
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Mitigates: CVE-2013-4312 (Linux 2.0+)
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Moritz Muehlenhoff <moritz@wikimedia.org>
commit 3397c2c45b1b6f54834dfeae30a73046f33ca943 upstream.
A new element got inserted into enum mx35_clks with commit 3713e3f5e927
("clk: imx35: define two clocks for rtc"). This insertion shifted most
nummerical clock assignments to a new nummerical value which in turn
rendered most hardcoded nummeric values in imx35.dtsi incorrect.
Restore the existing order by moving the newly introduced clock to the
end of the enum. Update the dts documentation accordingly.
Signed-off-by: Alexander Kurz <akurz@blala.de>
Fixes: 3713e3f5e927 ("clk: imx35: define two clocks for rtc")
commit 0f40fbbcc34e093255a2b2d70b6b0fb48c3f39aa upstream.
OpenSSH expects the (non-blocking) read() of pty master to return
EAGAIN only if it has received all of the slave-side output after
it has received SIGCHLD. This used to work on pre-3.12 kernels.
This fix effectively forces non-blocking read() and poll() to
block for parallel i/o to complete for all ttys. It also unwinds
these changes:
1) f8747d4a466ab2cafe56112c51b3379f9fdb7a12
tty: Fix pty master read() after slave closes
2) 52bce7f8d4fc633c9a9d0646eef58ba6ae9a3b73
pty, n_tty: Simplify input processing on final close
3) 1a48632ffed61352a7810ce089dc5a8bcd505a60
pty: Fix input race when closing
Inspired by analysis and patch from Marc Aurele La France <tsi@tuyoix.net>
Reported-by: Volth <openssh@volth.com>
Reported-by: Marc Aurele La France <tsi@tuyoix.net>
BugLink: https://bugzilla.mindrot.org/show_bug.cgi?id=52
BugLink: https://bugzilla.mindrot.org/show_bug.cgi?id=2492
Signed-off-by: Brian Bloniarz <brian.bloniarz@gmail.com>
Reviewed-by: Peter Hurley <peter@hurleysoftware.com>
commit 17dcc37e3e847bc0e67a5b1ec52471fcc6c18682 upstream.
On some SOCs PORTS_IMPL register value is never programmed by the
firmware and left at zero value. Which means that no sata ports are
available for software. AHCI driver used to cope up with this by
fabricating the port_map if the PORTS_IMPL register is read zero,
but recent patch broke this workaround as zero value was valid for
NVMe disks.
This patch adds ports-implemented DT bindings as workaround for this issue
in a way that DT can can override the PORTS_IMPL register in cases where
the firmware did not program it already.
Fixes: 566d1827df2e ("libata: disable forced PORTS_IMPL for >= AHCI 1.3")
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Acked-by: Tejun Heo <tj@kernel.org>
Reviewed-by: Andy Gross <andy.gross@linaro.org>
commit e9adb336d0bf391be23e820975ca5cd12c31d781 upstream.
mfio 84 to 89 are described wrongly, fix it to describe
the right pin and add them to right pin-mux group.
The correct order is:
pll1_lock => mips_pll -- MFIO_83
pll2_lock => audio_pll -- MFIO_84
pll3_lock => rpu_v_pll -- MFIO_85
pll4_lock => rpu_l_pll -- MFIO_86
pll5_lock => sys_pll -- MFIO_87
pll6_lock => wifi_pll -- MFIO_88
pll7_lock => bt_pll -- MFIO_89
Cc: linux-gpio@vger.kernel.org
Cc: devicetree@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: James Hartley <James.Hartley@imgtec.com>
Fixes: cefc03e5995e("pinctrl: Add Pistachio SoC pin control driver")
Signed-off-by: Govindraj Raja <Govindraj.Raja@imgtec.com>
Acked-by: Andrew Bresticker <abrestic@chromium.org>
commit 1363074667a6b7d0507527742ccd7bbed5e3ceaa upstream.
Add a new NO_REPORT_LUNS quirk and set it for Seagate drives with
an usb-id of: 0bc2:331a, as these will fail to respond to a
REPORT_LUNS command.
Reported-and-tested-by: David Webb <djw@noc.ac.uk>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 844a5fe219cf472060315971e15cbf97674a3324 upstream.
Yes, all of these are needed. :) This is admittedly a bit odd, but
kvm-unit-tests access.flat tests this if you run it with "-cpu host"
and of course ept=0.
KVM runs the guest with CR0.WP=1, so it must handle supervisor writes
specially when pte.u=1/pte.w=0/CR0.WP=0. Such writes cause a fault
when U=1 and W=0 in the SPTE, but they must succeed because CR0.WP=0.
When KVM gets the fault, it sets U=0 and W=1 in the shadow PTE and
restarts execution. This will still cause a user write to fault, while
supervisor writes will succeed. User reads will fault spuriously now,
and KVM will then flip U and W again in the SPTE (U=1, W=0). User reads
will be enabled and supervisor writes disabled, going back to the
originary situation where supervisor writes fault spuriously.
When SMEP is in effect, however, U=0 will enable kernel execution of
this page. To avoid this, KVM also sets NX=1 in the shadow PTE together
with U=0. If the guest has not enabled NX, the result is a continuous
stream of page faults due to the NX bit being reserved.
The fix is to force EFER.NX=1 even if the CPU is taking care of the EFER
switch. (All machines with SMEP have the CPU_LOAD_IA32_EFER vm-entry
control, so they do not use user-return notifiers for EFER---if they did,
EFER.NX would be forced to the same value as the host).
There is another bug in the reserved bit check, which I've split to a
separate patch for easier application to stable kernels.
Reviewed-by: Xiao Guangrong <guangrong.xiao@linux.intel.com>
Fixes: f6577a5fa15d82217ca73c74cd2dcbc0f6c781dd
commit 2e18f5a1bc18e8af7031b3b26efde25307014837 upstream.
Introduce a dt property, ti,no-idle, that prevents an IP to idle at any
point. This is to handle Errata i877, which tells that GMAC clocks
cannot be disabled.
Acked-by: Roger Quadros <rogerq@ti.com>
Tested-by: Mugunthan V N <mugunthanvnm@ti.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
commit ed8b0de5a33d2a2557dce7f9429dca8cb5bc5879 upstream.
"rm -rf" is bricking some peoples' laptops because of variables being
used to store non-reinitializable firmware driver data that's required
to POST the hardware.
These are 100% bugs, and they need to be fixed, but in the mean time it
shouldn't be easy to *accidentally* brick machines.
We have to have delete working, and picking which variables do and don't
work for deletion is quite intractable, so instead make everything
immutable by default (except for a whitelist), and make tools that
aren't quite so broad-spectrum unset the immutable flag.
Signed-off-by: Peter Jones <pjones@redhat.com>
Tested-by: Lee, Chun-Yi <jlee@suse.com>
Acked-by: Matthew Garrett <mjg59@coreos.com>
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
commit bf5ce5bf3cc7136fd7fe5e8999a580bc93a9c8f6 upstream.
Commit 655fe4effe0f ("usbcore: add sysfs support to xHCI usb3
hardware LPM") introduced usb3_hardware_lpm sysfs node. This
doesn't show the correct status of USB3 U1 and U2 LPM status.
This patch fixes this by replacing usb3_hardware_lpm with two
nodes, usb3_hardware_lpm_u1 (for U1) and usb3_hardware_lpm_u2
(for U2), and recording the U1/U2 LPM status in right places.
This patch should be back-ported to kernels as old as 4.3,
that contains Commit 655fe4effe0f ("usbcore: add sysfs support
to xHCI usb3 hardware LPM").
Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com>
Pull networking fixes from David Miller:
1) Prevent XFRM per-cpu counter updates for one namespace from being
applied to another namespace. Fix from DanS treetman.
2) Fix RCU de-reference in iwl_mvm_get_key_sta_id(), from Johannes
Berg.
3) Remove ethernet header assumption in nft_do_chain_netdev(), from
Pablo Neira Ayuso.
4) Fix cpsw PHY ident with multiple slaves and fixed-phy, from Pascal
Speck.
5) Fix use after free in sixpack_close and mkiss_close.
6) Fix VXLAN fw assertion on bnx2x, from Yuval Mintz.
7) natsemi doesn't check for DMA mapping errors, from Alexey
Khoroshilov.
8) Fix inverted test in ip6addrlbl_get(), from ANdrey Ryabinin.
9) Missing initialization of needed_headroom in geneve tunnel driver,
from Paolo Abeni.
10) Fix conntrack template leak in openvswitch, from Joe Stringer.
11) Mission initialization of wq->flags in sock_alloc_inode(), from
Nicolai Stange.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (35 commits)
sctp: sctp should release assoc when sctp_make_abort_user return NULL in sctp_close
net, socket, socket_wq: fix missing initialization of flags
drivers: net: cpsw: fix error return code
openvswitch: Fix template leak in error cases.
sctp: label accepted/peeled off sockets
sctp: use GFP_USER for user-controlled kmalloc
qlcnic: fix a loop exit condition better
net: cdc_ncm: avoid changing RX/TX buffers on MTU changes
geneve: initialize needed_headroom
ipv6: honor ifindex in case we receive ll addresses in router advertisements
addrconf: always initialize sysctl table data
ipv6/addrlabel: fix ip6addrlbl_get()
switchdev: bridge: Pass ageing time as clock_t instead of jiffies
sh_eth: fix 16-bit descriptor field access endianness too
veth: don’t modify ip_summed; doing so treats packets with bad checksums as good.
net: usb: cdc_ncm: Adding Dell DW5813 LTE AT&T Mobile Broadband Card
net: usb: cdc_ncm: Adding Dell DW5812 LTE Verizon Mobile Broadband Card
natsemi: add checks for dma mapping errors
rhashtable: Kill harmless RCU warning in rhashtable_walk_init
openvswitch: correct encoding of set tunnel action attributes
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input fixes from Dmitry Torokhov:
"Just a few assorted driver fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: elants_i2c - fix wake-on-touch
Input: elan_i2c - set input device's vendor and product IDs
Input: sun4i-lradc-keys - fix typo in binding documentation
Input: atmel_mxt_ts - add maxtouch to I2C table for module autoload
Input: arizona-haptic - fix disabling of haptics device
Input: aiptek - fix crash on detecting device without endpoints
Input: atmel_mxt_ts - add generic platform data for Chromebooks
Input: parkbd - clear unused function pointers
Input: walkera0701 - clear unused function pointers
Input: turbografx - clear unused function pointers
Input: gamecon - clear unused function pointers
Input: db9 - clear unused function pointers
Commit 1f71e8c96fc654724723ce987e0a8b2aeb81746d ("drivers: net: cpsw: Add
support for fixed-link PHY") did not parse the "phy-mode" property in
the case of a fixed-link PHY, leaving slave_data->phy_if with its default
of PHY_INTERFACE_MODE_NA(0). This later gets passed to phy_connect() in
cpsw_slave_open(), and eventually to cpsw_phy_sel() where it hits a default
case that configures the MAC for MII mode.
The user visible symptom is that while kernel log messages seem to indicate
that the interface is set up, there is no network communication. Eventually
a watchdog error occurs:
NETDEV WATCHDOG: eth0 (cpsw): transmit queue 0 timed out
Fixes: 1f71e8c96fc6 ("drivers: net: cpsw: Add support for fixed-link PHY")
Signed-off-by: David Rivshin <drivshin@allworx.com>
Pull MTD fixes from Brian Norris:
"I was holding out on this pull request for a bit, since there are a
few other small issues being discussed that look like 4.4-rc
regressions. Hopefully I can get those stabilized soon, but these are
ready at any rate:
- A little bit of a last-minute change for the device tree "fixed
partition" binding. This is needed because we might want to reuse
the 'partitions' subnode for other sorts of partitioning
descriptions -- e.g., for describing which on-flash partition
format(s) might be used on the system.
- Also tone down a warning message, since it is probably going to
show up on a lot of systems where it should just be ignored"
* tag 'for-linus-20151217' of git://git.infradead.org/linux-mtd:
doc: dt: mtd: partitions: add compatible property to "partitions" node
mtd: ofpart: don't complain about missing 'partitions' node too loudly
1) Fix uninitialized variable warnings in nfnetlink_queue, a lot of
people reported this... From Arnd Bergmann.
2) Don't init mutex twice in i40e driver, from Jesse Brandeburg.
3) Fix spurious EBUSY in rhashtable, from Herbert Xu.
4) Missing DMA unmaps in mvpp2 driver, from Marcin Wojtas.
5) Fix race with work structure access in pppoe driver causing
corruptions, from Guillaume Nault.
6) Fix OOPS due to sh_eth_rx() not checking whether netdev_alloc_skb()
actually succeeded or not, from Sergei Shtylyov.
7) Don't lose flags when settifn IFA_F_OPTIMISTIC in ipv6 code, from
Bjørn Mork.
8) VXLAN_HD_RCO defined incorrectly, fix from Jiri Benc.
9) Fix clock source used for cookies in SCTP, from Marcelo Ricardo
Leitner.
10) aurora driver needs HAS_DMA dependency, from Geert Uytterhoeven.
11) ndo_fill_metadata_dst op of vxlan has to handle ipv6 tunneling
properly as well, from Jiri Benc.
12) Handle request sockets properly in xfrm layer, from Eric Dumazet.
13) Double stats update in ipv6 geneve transmit path, fix from Pravin B
Shelar.
14) sk->sk_policy[] needs RCU protection, and as a result
xfrm_policy_destroy() needs to free policies using an RCU grace
period, from Eric Dumazet.
15) SCTP needs to clone ipv6 tx options in order to avoid use after
free, from Eric Dumazet.
16) Missing kbuild export if ila.h, from Stephen Hemminger.
17) Missing mdiobus_alloc() return value checking in mdio-mux.c, from
Tobias Klauser.
18) Validate protocol value range in ->create() methods, from Hannes
Frederic Sowa.
19) Fix early socket demux races that result in illegal dst reuse, from
Eric Dumazet.
20) Validate socket address length in pptp code, from WANG Cong.
21) skb_reorder_vlan_header() uses incorrect offset and can corrupt
packets, from Vlad Yasevich.
22) Fix memory leaks in nl80211 registry code, from Ola Olsson.
23) Timeout loop count handing fixes in mISDN, xgbe, qlge, sfc, and
qlcnic. From Dan Carpenter.
24) msg.msg_iocb needs to be cleared in recvfrom() otherwise, for
example, AF_ALG will interpret it as an async call. From Tadeusz
Struk.
25) inetpeer_set_addr_v4 forgets to initialize the 'vif' field, from
Eric Dumazet.
26) rhashtable enforces the minimum table size not early enough,
breaking how we calculate the per-cpu lock allocations. From
Herbert Xu.
27) Fix FCC port lockup in 82xx driver, from Martin Roth.
28) FOU sockets need to be freed using RCU, from Hannes Frederic Sowa.
29) Fix out-of-bounds access in __skb_complete_tx_timestamp() and
sock_setsockopt() wrt. timestamp handling. From WANG Cong.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (117 commits)
net: check both type and procotol for tcp sockets
drivers: net: xgene: fix Tx flow control
tcp: restore fastopen with no data in SYN packet
af_unix: Revert 'lock_interruptible' in stream receive code
fou: clean up socket with kfree_rcu
82xx: FCC: Fixing a bug causing to FCC port lock-up
gianfar: Don't enable RX Filer if not supported
net: fix warnings in 'make htmldocs' by moving macro definition out of field declaration
rhashtable: Fix walker list corruption
rhashtable: Enforce minimum size on initial hash table
inet: tcp: fix inetpeer_set_addr_v4()
ipv6: automatically enable stable privacy mode if stable_secret set
net: fix uninitialized variable issue
bluetooth: Validate socket address length in sco_sock_bind().
net_sched: make qdisc_tree_decrease_qlen() work for non mq
ser_gigaset: remove unnecessary kfree() calls from release method
ser_gigaset: fix deallocation of platform device structure
ser_gigaset: turn nonsense checks into WARN_ON
ser_gigaset: fix up NULL checks
qlcnic: fix a timeout loop
git://git.infradead.org/users/vkoul/slave-dma
Pull dmaengine fixes from Vinod Koul:
"This has fixes spread thru driver, notably among them:
- edma fixes for recent edma DT changes which went into 4.4
- odd fixes for at_hdmac
- minor fixes on bc dma and mic dma"
* tag 'dmaengine-fix-4.4-rc6' of git://git.infradead.org/users/vkoul/slave-dma:
dmaengine: at_xdmac: fix at_xdmac_prep_dma_memcpy()
dmaengine: edma: DT: Change reserved slot array from 16bit to 32bit type
dmaengine: edma: DT: Change memcpy channel array from 16bit to 32bit type
dmaengine: mic_x100: add missing spin_unlock
dmaengine: bcm2835-dma: Convert to use DMA pool
dmaengine: at_xdmac: fix bad behavior in interleaved mode
dmaengine: at_xdmac: fix false condition for memset_sg transfers
dmaengine: at_xdmac: fix macro typo
Pull ARM SoC fixes from Arnd Bergmann:
"Here are a bunch of small bug fixes for various ARM platforms, nothing
really sticks out this week, most of either fixes bugs in code that
was just added in 4.4, or that has been broken for many years without
anyone noticing.
at91/sama5d2:
- fix sama5de hardware setup of sd/mmc interface
- proper selection of pinctrl drivers. PIO4 is necessary for sama5d2
berlin:
- fix incorrect clock input for SDIO
exynos:
- Fix potential NULL pointer dereference in Exynos PMU driver.
imx:
- Fix vf610 SAI clock configuration bug which is discovered by the
newly added master mode support in SAI audio driver.
- Fix buggy L2 cache latency values in vf610 device trees, which may
cause system hang when cpu runs at a higher frequency.
ixp4xx:
- fix prototypes for readl/writel functions
ls2080a:
- use little-endian register access for GPIO and SDHCI
omap:
- Fix clock source for ARM TWD and global timers on am437x
- Always select REGULATOR_FIXED_VOLTAGE for omap2+ instead of when
MACH_OMAP3_PANDORA is selected
- Fix SPI DMA handles for dm816x as only some were mapped
- Fix up mbox cells for dm816x to make mailbox usable
pxa:
- use PWM lookup table for all ezx machines
s3c24xx:
- Remove incorrect __init annotation from s3c24xx cpufreq driver
structures.
versatile:
- fix PCI IRQ mapping on Versatile PB"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ls2080a/dts: Add little endian property for GPIO IP block
dt-bindings: define little-endian property for QorIQ GPIO
ARM64: dts: ls2080a: fix eSDHC endianness
ARM: dts: vf610: use reset values for L2 cache latencies
ARM: pxa: use PWM lookup table for all machines
ARM: dts: berlin: add 2nd clock for BG2Q sdhci0 and sdhci1
ARM: dts: berlin: correct BG2Q's sdhci2 2nd clock
ARM: dts: am4372: fix clock source for arm twd and global timers
ARM: at91: fix pinctrl driver selection
ARM: at91/dt: add always-on to 1.8V regulator
ARM: dts: vf610: fix clock definition for SAI2
ARM: imx: clk-vf610: fix SAI clock tree
ARM: ixp4xx: fix read{b,w,l} return types
irqchip/versatile-fpga: Fix PCI IRQ mapping on Versatile PB
ARM: OMAP2+: enable REGULATOR_FIXED_VOLTAGE
ARM: dts: add dm816x missing spi DT dma handles
ARM: dts: add dm816x missing #mbox-cells
cpufreq: s3c24xx: Do not mark s3c2410_plls_add as __init
ARM: EXYNOS: Fix potential NULL pointer access in exynos_sys_powerdown_conf
Trivial typo fix ("mut" -> "must") in the sunxi LRADC-keys binding
documentation.
Signed-off-by: Karsten Merker <merker@debian.org>
Acked-by: Chen-Yu Tsai <wens@csie.org>
The GPIO block on different QorIQ chips could have registers in different
endianess. Define the property to specify which endian is used by the
hardware.
Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
Signed-off-by: Li Yang <leoli@freescale.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
This change makes the DT file to be easier to read since the reserved slots
array does not need the '/bits/ 16' to be specified, which might confuse
some people.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
This change makes the DT file to be easier to read since the memcpy
channels array does not need the '/bits/ 16' to be specified, which might
confuse some people.
As noted here [1], there are potentially future conflicts if we try to
use MTD's "partitions" subnode to describe anything besides just the
fixed-in-the-device-tree partitions currently described in this
document. Particularly, there was a proposal to use this node for the
AFS parser too.
It can pose a (small) problem to try to differentiate the following
nodes:
// using binding as currently specified
partitions {
#address-cells = <x>;
#size-cells = <y>;
partition@0 {
and
// proposed future binding
partitions {
compatible = "arm,arm-flash-structure";
It's especially difficult if other uses of this node start having
subnodes.
So, since the "partitions" node is new in v4.4, let's fixup the binding
before release so that it requires a compatible property, so it's much
clearer to distinguish. e.g.:
// proposed
partitions {
compatible = "fixed-partitions";
#size-cells = <y>;
partition@0 {
[1] Subject: "mtd: create a partition type device tree binding"
http://lkml.kernel.org/g/20151113220039.GA74382@google.com
http://lists.infradead.org/pipermail/linux-mtd/2015-November/063355.html
http://lists.infradead.org/pipermail/linux-mtd/2015-November/063364.html
Cc: Michal Suchanek <hramrach@gmail.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jkirsher/net-queue
Jeff Kirsher says:
Intel Wired LAN Driver Updates 2015-12-03
This series contains updates to ixgbe, i40e/i40evf, MAINTAINERS and e100.txt
Alex provides a fix for ixgbe where enabling SR-IOV and then bringing the
interface up was resulting in the PF MAC addresses getting into a bad state.
The workaround for this issue is to bring up the interface first and then
enable SR-IOV as this will trigger the reset in the existing code.
I clean up legacy license stuff in the e100.txt documentation and then
update the maintainers/reviewers list for our drivers.
Jesse fixes an issue with the i40e/i40evf drivers, where if the driver were
to happen to have a mutex held while the i40e_init_adminq() call was called,
the init_adminq might inadvertently call mutex_init on a lock that was held
which is a violation of the calling semantices.
"A lot of Thanksgiving turkey leftovers accumulated, here goes:
1) Fix bluetooth l2cap_chan object leak, from Johan Hedberg.
2) IDs for some new iwlwifi chips, from Oren Givon.
3) Fix rtlwifi lockups on boot, from Larry Finger.
4) Fix memory leak in fm10k, from Stephen Hemminger.
5) We have a route leak in the ipv6 tunnel infrastructure, fix from
Paolo Abeni.
6) Fix buffer pointer handling in arm64 bpf JIT,f rom Zi Shen Lim.
7) Wrong lockdep annotations in tcp md5 support, fix from Eric
Dumazet.
8) Work around some middle boxes which prevent proper handling of TCP
Fast Open, from Yuchung Cheng.
9) TCP repair can do huge kmalloc() requests, build paged SKBs
instead. From Eric Dumazet.
10) Fix msg_controllen overflow in scm_detach_fds, from Daniel
Borkmann.
11) Fix device leaks on ipmr table destruction in ipv4 and ipv6, from
Nikolay Aleksandrov.
12) Fix use after free in epoll with AF_UNIX sockets, from Rainer
Weikusat.
13) Fix double free in VRF code, from Nikolay Aleksandrov.
14) Fix skb leaks on socket receive queue in tipc, from Ying Xue.
15) Fix ifup/ifdown crach in xgene driver, from Iyappan Subramanian.
16) Fix clearing of persistent array maps in bpf, from Daniel
Borkmann.
17) In TCP, for the cross-SYN case, we don't initialize tp->copied_seq
early enough. From Eric Dumazet.
18) Fix out of bounds accesses in bpf array implementation when
updating elements, from Daniel Borkmann.
19) Fill gaps in RCU protection of np->opt in ipv6 stack, from Eric
Dumazet.
20) When dumping proxy neigh entries, we have to accomodate NULL
device pointers properly, from Konstantin Khlebnikov.
21) SCTP doesn't release all ipv6 socket resources properly, fix from
Eric Dumazet.
22) Prevent underflows of sch->q.qlen for multiqueue packet
schedulers, also from Eric Dumazet.
23) Fix MAC and unicast list handling in bnxt_en driver, from Jeffrey
Huang and Michael Chan.
24) Don't actively scan radar channels, from Antonio Quartulli"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (110 commits)
net: phy: reset only targeted phy
bnxt_en: Setup uc_list mac filters after resetting the chip.
bnxt_en: enforce proper storing of MAC address
bnxt_en: Fixed incorrect implementation of ndo_set_mac_address
net: lpc_eth: remove irq > NR_IRQS check from probe()
net_sched: fix qdisc_tree_decrease_qlen() races
openvswitch: fix hangup on vxlan/gre/geneve device deletion
ipv4: igmp: Allow removing groups from a removed interface
ipv6: sctp: implement sctp_v6_destroy_sock()
arm64: bpf: add 'store immediate' instruction
ipv6: kill sk_dst_lock
ipv6: sctp: add rcu protection around np->opt
net/neighbour: fix crash at dumping device-agnostic proxy entries
sctp: convert sack_needed and sack_generation to bits
ipv6: add complete rcu protection around np->opt
bpf: fix allocation warnings in bpf maps and integer overflow
mvebu: dts: enable IP checksum with jumbo frames for Armada 38x on Port0
net: mvneta: enable setting custom TX IP checksum limit
net: mvneta: fix error path for building skb
Apparently the e100.txt document contained a "License" section left
over from days of old, which does not need to be in the kernel
documentation. So clean it up..
CC: John Ronciak <john.ronciak@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
Since Armada 38x SoC can support IP checksum for jumbo frames only on
a single port, it means that this feature should be enabled per-port,
rather than for the whole SoC.
This patch enables setting custom TX IP checksum limit by adding new
optional property to the mvneta device tree node. If not used, by
default 1600B is set for "marvell,armada-370-neta" and 9800B for other
strings, which ensures backward compatibility. Binding documentation
is updated accordingly.
Signed-off-by: Marcin Wojtas <mw@semihalf.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal management fixes from Zhang Rui:
"Specifics:
- several fixes and cleanups on Rockchip thermal drivers.
- add the missing support of RK3368 SoCs in Rockchip driver.
- small fixes on of-thermal, power_allocator, rcar driver, IMX, and
QCOM drivers, and also compilation fixes, on thermal.h, when thermal
is not selected"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux:
imx: thermal: use CPU temperature grade info for thresholds
thermal: fix thermal_zone_bind_cooling_device prototype
Revert "thermal: qcom_spmi: allow compile test"
thermal: rcar_thermal: remove redundant operation
thermal: of-thermal: Reduce log level for message when can't fine thermal zone
thermal: power_allocator: Use temperature reading from tz
thermal: rockchip: Support the RK3368 SoCs in thermal driver
thermal: rockchip: consistently use int for temperatures
thermal: rockchip: Add the sort mode for adc value increment or decrement
thermal: rockchip: improve the conversion function
thermal: rockchip: trivial: fix typo in commit
thermal: rockchip: better to compatible the driver for different SoCs
dt-bindings: rockchip-thermal: Support the RK3368 SoCs compatible
