path: root/Documentation
2010-11-18Documentation/development-process: more staging infoAndres Salomon
Document things that I would've liked to have known when submitting a driver to gregkh for staging. Signed-off-by: Andres Salomon <dilinger@queued.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-18Documentation/development-process: use -next trees instead of stagingAndres Salomon
This is confusing, as we have "staging" trees for drivers/staging. Call them -next trees. Signed-off-by: Andres Salomon <dilinger@queued.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-18Documentation: change email address for Hans KochHans J. Koch
My old mail address doesn't exist anymore. This changes all occurrences to my new address. Signed-off-by: Hans J. Koch <hjk@hansjkoch.de> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-18Documentation/gpio.txt: explain poll/select usageBernhard Walle
Add a bit more information how to use poll(2) on GPIO value files correctly. For me it was not clear that I need to poll(2) for POLLPRI|POLLERR or select(2) for exceptfds. Signed-off-by: Bernhard Walle <walle@corscience.de> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-18Documentation: make configfs example code simpler, clearerDan Carpenter
If "p" is NULL then it will cause an oops when we pass it to simple_strtoul(). In this case "p" can not be NULL so I removed the check. I also changed the check a little to make it more explicit that we are testing whether p points to the NUL char. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-16Merge branch 'pm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM / PM QoS: Fix reversed min and max PM / OPP: Hide OPP configuration when SoCs do not provide an implementation PM: Allow devices to be removed during late suspend and early resume
2010-11-15Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c: Sanity checks on adapter registration i2c: Mark i2c_adapter.id as deprecated i2c: Drivers shouldn't include <linux/i2c-id.h> i2c: Delete unused adapter IDs i2c: Remove obsolete cleanup for clientdata
2010-11-15i2c: Mark i2c_adapter.id as deprecatedJean Delvare
It's about time to make it clear that i2c_adapter.id is deprecated. Hopefully this will remind the last user to move over to a different strategy. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Jarod Wilson <jarod@redhat.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
2010-11-15Merge branch 'fbdev-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6 * 'fbdev-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6: fsl-diu-fb: drop dead ioctl define MAINTAINERS: Add an fbdev git tree entry. OMAP: DSS: Fix documentation regarding 'vram' kernel parameter OMAP: VRAM: Fix boot-time memory allocation OMAP: VRAM: improve VRAM error prints sisfb: limit POST memory test according to PCI resource length fbdev: sh_mobile_lcdc: use correct number of modes, when using the default fbdev: sh_mobile_lcdc: use the standard CEA-861 720p timing fbdev: sh_mobile_hdmi: properly clean up modedb on monitor unplug
2010-11-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (66 commits) can-bcm: fix minor heap overflow gianfar: Do not call device_set_wakeup_enable() under a spinlock ipv6: Warn users if maximum number of routes is reached. docs: Add neigh/gc_thresh3 and route/max_size documentation. axnet_cs: fix resume problem for some Ax88790 chip ipv6: addrconf: don't remove address state on ifdown if the address is being kept tcp: Don't change unlocked socket state in tcp_v4_err(). x25: Prevent crashing when parsing bad X.25 facilities cxgb4vf: add call to Firmware to reset VF State. cxgb4vf: Fail open if link_start() fails. cxgb4vf: flesh out PCI Device ID Table ... cxgb4vf: fix some errors in Gather List to skb conversion cxgb4vf: fix bug in Generic Receive Offload cxgb4vf: don't implement trivial (and incorrect) ndo_select_queue() ixgbe: Look inside vlan when determining offload protocol. bnx2x: Look inside vlan when determining checksum proto. vlan: Add function to retrieve EtherType from vlan packets. virtio-net: init link state correctly ucc_geth: Fix deadlock ucc_geth: Do not bring the whole IF down when TX failure. ...
2010-11-12docs: Add neigh/gc_thresh3 and route/max_size documentation.Ben Greear
Signed-off-by: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-12Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (27 commits) block: remove unused copy_io_context() Documentation: remove anticipatory scheduler info block: remove REQ_HARDBARRIER ioprio: rcu_read_lock/unlock protect find_task_by_vpid call (V2) ioprio: fix RCU locking around task dereference block: ioctl: fix information leak to userland block: read i_size with i_size_read() cciss: fix proc warning on attempt to remove non-existant directory bio: take care not overflow page count when mapping/copying user data block: limit vec count in bio_kmalloc() and bio_alloc_map_data() block: take care not to overflow when calculating total iov length block: check for proper length of iov entries in blk_rq_map_user_iov() cciss: remove controllers supported by hpsa cciss: use usleep_range not msleep for small sleeps cciss: limit commands allocated on reset_devices cciss: Use kernel provided PCI state save and restore functions cciss: fix board status waiting code drbd: Removed checks for REQ_HARDBARRIER on incomming BIOs drbd: REQ_HARDBARRIER -> REQ_FUA transition for meta data accesses drbd: Removed the BIO_RW_BARRIER support form the receiver/epoch code ...
2010-11-12Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: remove incorrect assert in xfs_vm_writepage xfs: use hlist_add_fake xfs: fix a few compiler warnings with CONFIG_XFS_QUOTA=n xfs: tell lockdep about parent iolock usage in filestreams xfs: move delayed write buffer trace xfs: fix per-ag reference counting in inode reclaim tree walking xfs: xfs_ioctl: fix information leak to userland xfs: remove experimental tag from the delaylog option
2010-11-12Documentation: led drivers lp5521 and lp5523Samu Onkalo
Create sub directory Documentation/leds and add short documentation for LP5521 and LP5523 drivers. Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-12led-class: always implement blinkingJohannes Berg
Currently, blinking LEDs can be awkward because it is not guaranteed that all LEDs implement blinking. The trigger that wants it to blink then needs to implement its own timer solution. Rather than require that, add led_blink_set() API that triggers can use. This function will attempt to use hw blinking, but if that fails implements a timer for it. To stop blinking again, brightness_set() also needs to be wrapped into API that will stop the software blink. As a result of this, the timer trigger becomes a very trivial one, and hopefully we can finally see triggers using blinking as well because it's always easy to use. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-12Restrict unprivileged access to kernel syslogDan Rosenberg
The kernel syslog contains debugging information that is often useful during exploitation of other vulnerabilities, such as kernel heap addresses. Rather than futilely attempt to sanitize hundreds (or thousands) of printk statements and simultaneously cripple useful debugging functionality, it is far simpler to create an option that prevents unprivileged users from reading the syslog. This patch, loosely based on grsecurity's GRKERNSEC_DMESG, creates the dmesg_restrict sysctl. When set to "0", the default, no restrictions are enforced. When set to "1", only users with CAP_SYS_ADMIN can read the kernel syslog via dmesg(8) or other mechanisms. [akpm@linux-foundation.org: explain the config option in kernel.txt] Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Eugene Teo <eugeneteo@kernel.org> Acked-by: Kees Cook <kees.cook@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-12oom: document obsolete oom_adj tunableDavid Rientjes
/proc/pid/oom_adj was deprecated in August 2010 with the introduction of the new oom killer heuristic. This patch copies the Documentation/feature-removal-schedule.txt entry for this tunable to the Documentation/ABI/obsolete directory so nobody misses it. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-11Documentation: remove anticipatory scheduler infoRandy Dunlap
Remove anticipatory block I/O scheduler info from Documentation/ since the code has been deleted. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reported-by: "Robert P. J. Day" <rpjday@crashcourse.ca> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-11PM / OPP: Hide OPP configuration when SoCs do not provide an implementationMark Brown
Since the OPP API is only useful with an appropraite SoC-specific implementation there is no point in offering the ability to enable the API on general systems. Provide an ARCH_HAS OPP Kconfig symbol which masks out the option unless selected by an implementation. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Nishanth Menon <nm@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-11-10xfs: remove experimental tag from the delaylog optionChristoph Hellwig
We promised to do this for 2.6.37, and the code looks stable enough to keep that promise. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-11-10OMAP: DSS: Fix documentation regarding 'vram' kernel parameterTomi Valkeinen
The DSS documentation didn't mention the option to give the VRAM start address. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-10-31Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c-i801: Add PCI idents for Patsburg 'IDF' SMBus controllers i2c-i801: Handle multiple instances instead of keeping global state i2c-i801: Add Intel Patsburg device ID i2c: Drop unused I2C_CLASS_TV flags
2010-10-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (70 commits) [SCSI] pmcraid: add support for set timestamp command and other fixes [SCSI] pmcraid: remove duplicate struct member [SCSI] qla4xxx: Fix cmd check in qla4xxx_cmd_wait [SCSI] megaraid_sas: Version and documentation update [SCSI] megaraid_sas: Add three times Online controller reset [SCSI] megaraid_sas: Add input parameter for max_sectors [SCSI] megaraid_sas: support devices update flag [SCSI] libosd: write/read_sg_kern API [SCSI] libosd: Support for scatter gather write/read commands [SCSI] libosd: Free resources in reverse order of allocation [SCSI] libosd: Fix bug in attr_page handling [SCSI] lpfc 8.3.18: Update lpfc driver version to 8.3.18 [SCSI] lpfc 8.3.18: Add new WQE support [SCSI] lpfc 8.3.18: Fix critical errors [SCSI] lpfc 8.3.18: Adapter Shutdown and Unregistration cleanup [SCSI] lpfc 8.3.18: Add logic to detect last devloss timeout [SCSI] lpfc 8.3.18: Add support of received ELS commands [SCSI] lpfc 8.3.18: FC/FCoE Discovery fixes [SCSI] ipr: add definitions for a new adapter [SCSI] bfa: fix comments for c files ...
2010-10-31i2c-i801: Add PCI idents for Patsburg 'IDF' SMBus controllersDavid Woodhouse
These are the extra 'Integrated Device Function' SMBus controllers found on the Patsburg chipset. Mention the absence of slave mode support. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-10-31i2c-i801: Add Intel Patsburg device IDSeth Heasley
Add support for the Intel Patsburg PCH SMBus Controller. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-10-31locks: remove fl_copy_lock lock_manager operationChristoph Hellwig
This one was only used for a nasty hack in nfsd, which has recently been removed. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-29Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: kgdb,ppc: Individual register get/set for ppc kgdbts: prevent re-entry to kgdbts before it unregisters debug_core,x86,blackfin: Clean up hw debug disable API kdb: Fix early debugging crash regression kgdb,arm: fix register dump kdb: fix per_cpu command to remove supress mask kdb: Add kdb kernel module sample
2010-10-29kdb: Add kdb kernel module sampleJason Wessel
Add an example of how to add a dynamic kdb shell command via a kernel module. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-10-28Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (39 commits) Revert "namespace: add source file location exceptions" Coccinelle: Add contextual message Coccinelle: Fix documentation Coccinelle: Find doubled arguments to boolean or bit operators. Coccinelle: Find nested lock+irqsave functions that use the same flags variables. namespace: add source file location exceptions scripts/extract-ikconfig: add support for bzip2, lzma and lzo kbuild: check return value of asprintf() scripts/namespace.pl: improve to get more correct results scripts/namespace.pl: some bug fixes scripts/namespace.pl: update file exclusion list scripts/namespace.pl: fix wrong source path Coccinelle: Use the -no_show_diff option for org and report mode Coccinelle: Add a new mode named 'chain' Coccinelle: Use new comment format to explain kfree.cocci Coccinelle: Improve user information with a new kind of comment Coccinelle: Update documentation MAINTAINERS: Coccinelle: Update email address Documentation/kbuild: modules.txt cleanup Documentation/kbuild: major edit of modules.txt sections 5-8 ...
2010-10-28Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (38 commits) kbuild: convert `arch/tile' to the kconfig mainmenu upgrade README: cite nconfig Revert "kconfig: Temporarily disable dependency warnings" kconfig: Use PATH_MAX instead of 128 for path buffer sizes. kconfig: Fix realloc usage() kconfig: Propagate const kconfig: Don't go out from read config loop when you read new symbol kconfig: fix menuconfig on debian lenny kbuild: migrate all arch to the kconfig mainmenu upgrade kconfig: expand file names kconfig: use the file's name of sourced file kconfig: constify file name kconfig: don't emit warning upon rootmenu's prompt redefinition kconfig: replace KERNELVERSION usage by the mainmenu's prompt kconfig: delay gconf window initialization kconfig: expand by default the rootmenu's prompt kconfig: add a symbol string expansion helper kconfig: regen parser kconfig: implement the `mainmenu' directive kconfig: allow PACKAGE to be defined on the compiler's command-line ... Fix up trivial conflict in arch/mn10300/Kconfig
2010-10-28Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: initramfs: Fix build break on symbol-prefixed archs initramfs: fix initramfs size calculation initramfs: generalize initramfs_data.xxx.S variants scripts/kallsyms: Enable error messages while hush up unnecessary warnings scripts/setlocalversion: update comment kbuild: Use a single clean rule for kernel and external modules kbuild: Do not run make clean in $(srctree) scripts/mod/modpost.c: fix commentary accordingly to last changes kbuild: Really don't clean bounds.h and asm-offsets.h
2010-10-28Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: (68 commits) hwmon: (it87) Add support for the IT8721F/IT8758E hwmon: (it87) Move conversion functions hwmon: Remove many EXPERIMENTAL flags hwmon: (lm85) Add support for ADT7468 high-frequency PWM mode hwmon: (lm85) Document the ADT7468 as supported hwmon: (lm85) Fix ADT7468 frequency table hwmon: I2C addresses are constant Move ams driver to macintosh hwmon: (pcf8591) Don't attempt to detect devices hwmon: (pcf8591) Register as a hwmon device hwmon: (w83795) Use standard attributes for chassis intrusion hwmon: (w83795) Exclude fan control feature by default hwmon: (w83795) Add myself as co-author and maintainer hwmon: (w83795) More style cleanups hwmon: (w83795) Fix LSB reading of voltage limits hwmon: (w83795) Use dev_get_drvdata() where possible hwmon: (w83795) Delay reading pwm config registers hwmon: (w83795) Delay reading limit registers hwmon: (w83795) Move register reads to dedicated functions hwmon: (w83795) Pack similar register reads ...
2010-10-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (841 commits) Staging: brcm80211: fix usage of roundup in structures Staging: bcm: fix up network device reference counting Staging: keucr: fix up US_ macro change staging: brcm80211: brcmfmac: Removed codeversion from firmware filenames. staging: brcm80211: Remove unnecessary header files. staging: brcm80211: Remove unnecessary includes from bcmutils.c staging: brcm80211: Removed unnecessary pktsetprio() function. Staging: brcm80211: remove typedefs.h Staging: brcm80211: remove uintptr typedef usage Staging: hv: remove struct vmbus_channel_interface Staging: hv: remove Open from struct vmbus_channel_interface Staging: hv: storvsc: call vmbus_open directly Staging: hv: netvsc: call vmbus_open directly Staging: hv: channel: export vmbus_open to modules Staging: hv: remove Close from struct vmbus_channel_interface Staging: hv: netvsc: call vmbus_close directly Staging: hv: storvsc: call vmbus_close directly Staging: hv: channel: export vmbus_close to modules Staging: hv: remove SendPacket from struct vmbus_channel_interface Staging: hv: storvsc: call vmbus_sendpacket directly ... Fix up conflicts in drivers/staging/cx25821/cx25821-audio-upstream.c drivers/staging/cx25821/cx25821-audio.h due to warring whitespace cleanups (neither of which were all that great)
2010-10-28Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (27 commits) x86: allocate space within a region top-down x86: update iomem_resource end based on CPU physical address capabilities x86/PCI: allocate space from the end of a region, not the beginning PCI: allocate bus resources from the top down resources: support allocating space within a region from the top down resources: handle overflow when aligning start of available area resources: ensure callback doesn't allocate outside available space resources: factor out resource_clip() to simplify find_resource() resources: add a default alignf to simplify find_resource() x86/PCI: MMCONFIG: fix region end calculation PCI: Add support for polling PME state on suspended legacy PCI devices PCI: Export some PCI PM functionality PCI: fix message typo PCI: log vendor/device ID always PCI: update Intel chipset names and defines PCI: use new ccflags variable in Makefile PCI: add PCI_MSIX_TABLE/PBA defines PCI: add PCI vendor id for STmicroelectronics x86/PCI: irq and pci_ids patch for Intel Patsburg DeviceIDs PCI: OLPC: Only enable PCI configuration type override on XO-1 ...
2010-10-28hwmon: (it87) Add support for the IT8721F/IT8758EJean Delvare
Add support for the IT8721F/IT8758E. These new chips differ from the older IT87xxF chips in the following ways: * ADC LSB is 12 mV instead of 16 mV. * PWM values are 8-bit instead of 7-bit. There are other minor changes we don't have to care about in the driver. Another change is that we will handle internal voltage scaling in the driver instead of delegating the work to user-space. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-10-28hwmon: (lm85) Add support for ADT7468 high-frequency PWM modeJean Delvare
The ADT7468 supports a high-frequency PWM output mode where all PWM outputs are driven by a 22.5 kHz clock. Add support for this mode, and document it, as it may surprise the user that setting one PWM output frequency also affects the other PWM outputs. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Darrick J. Wong <djwong@us.ibm.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-10-28hwmon: (lm85) Document the ADT7468 as supportedJean Delvare
2010-10-28hwmon: (pcf8591) Don't attempt to detect devicesJean Delvare
The PCF8591 can't be detected, don't even try. There are plenty of other means to instantiate i2c devices these days. Signed-off-by: Jean Delvare <khali@linux-fr.org> Reviewed-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Aurelien Jarno <aurelien@aurel32.net>
2010-10-28hwmon: (lm90) Add support for the W83L771W/GJean Delvare
I was wondering if that chip ever existed publicly... Apparently yes, so add support for it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Alexander Stein <alexander.stein@informatik.tu-chemnitz.de> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-10-28hwmon: (lm90) Add support for max6695 and max6696Guenter Roeck
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-10-28hwmon: (lm90) Add support for extra features of max6659Guenter Roeck
2010-10-28hwmon: (lm90) Add explicit support for max6659Guenter Roeck
2010-10-28hwmon: Add tempX_emergency attribute to sysfs ABIGuenter Roeck
2010-10-28Merge 'staging-next' to Linus's treeGreg Kroah-Hartman
This merges the staging-next tree to Linus's tree and resolves some conflicts that were present due to changes in other trees that were affected by files here. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (505 commits) [media] af9015: Fix max I2C message size when used with tda18271 [media] IR: initialize ir_raw_event in few more drivers [media] Guard a divide in v4l1 compat layer [media] imon: fix nomouse modprobe option [media] imon: remove redundant change_protocol call [media] imon: fix my egregious brown paper bag w/rdev/idev split [media] cafe_ccic: Configure ov7670 correctly [media] ov7670: allow configuration of image size, clock speed, and I/O method [media] af9015: support for DigitalNow TinyTwin v3 [1f4d:9016] [media] af9015: map DigitalNow TinyTwin v2 remote [media] DigitalNow TinyTwin remote controller [media] af9015: RC fixes and improvements videodev2.h.xml: Update to reflect the latest changes at videodev2.h [media] v4l: document new Bayer and monochrome pixel formats [media] DocBook/v4l: Add missing formats used on gspca cpia1 and sn9c2028 [media] firedtv: add parameter to fake ca_system_ids in CA_INFO [media] tm6000: fix a macro coding style issue tm6000: Remove some ugly debug code [media] Nova-S-Plus audio line input [media] [RFC,1/1] V4L2: Use new CAP bits in existing RDS capable drivers ...
2010-10-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (66 commits) mmc: add new sdhci-pxa driver for Marvell SoCs mmc: make number of mmcblk minors configurable mmc_spi: Recover from CRC errors for r/w operation over SPI. mmc: sdhci-pltfm: add -pltfm driver for imx35/51 mmc: sdhci-of-esdhc: factor out common stuff mmc: sdhci_pltfm: pass more data on custom init call mmc: sdhci: introduce get_ro private write-protect hook mmc: sdhci-pltfm: move .h file into appropriate subdir mmc: sdhci-pltfm: Add structure for host-specific data mmc: fix cb710 kconfig dependency warning mmc: cb710: remove debugging printk (info duplicated from mmc-core) mmc: cb710: clear irq handler on init() error path mmc: cb710: remove unnecessary msleep() mmc: cb710: implement get_cd() callback mmc: cb710: partially demystify clock selection mmc: add a file to debugfs for changing host clock at runtime mmc: sdhci: allow for eMMC 74 clock generation by controller mmc: sdhci: highspeed: check for mmc as well as sd cards mmc: sdhci: Add Moorestown device support mmc: sdhci: Intel Medfield support ...
2010-10-28fs/9p: Add access = client option to opt in acl evaluation.Aneesh Kumar K.V
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-27Merge branch 'next' into upstream-mergeTheodore Ts'o
Conflicts: fs/ext4/inode.c fs/ext4/mballoc.c include/trace/events/ext4.h
2010-10-27Merge branch 'viafb-next' of git://github.com/schandinat/linux-2.6Linus Torvalds
* 'viafb-next' of git://github.com/schandinat/linux-2.6: (29 commits) viafb: add initial VX900 support viafb: fix hardware acceleration for suspend & resume viafb: make suspend and resume work (on all machines?) viafb: restore display on resume Minimal support for viafb suspend/resume viafb: use proper register for colour when doing fill ops viafb: add documentation for proc interface viafb: rename output devices viafb: add a mapping of supported output devices viafb: set sync polarity for all output devices viafb: add function to change sync polarity per device viafb: reduce I2C timeout and delay viafb: enable I2C for CRT viafb: fix i2c_transfer error handling viafb: vt1636 cleanup viafb: introduce per output device power management viafb: limit LCD code impact viafb: add interface for output device configuration viafb: merge the remaining output path with enable functions viafb: use new device routing ...
2010-10-27Merge branch 'akpm-incoming-2'Linus Torvalds
* akpm-incoming-2: (139 commits) epoll: make epoll_wait() use the hrtimer range feature select: rename estimate_accuracy() to select_estimate_accuracy() Remove duplicate includes from many files ramoops: use the platform data structure instead of module params kernel/resource.c: handle reinsertion of an already-inserted resource kfifo: fix kfifo_alloc() to return a signed int value w1: don't allow arbitrary users to remove w1 devices alpha: remove dma64_addr_t usage mips: remove dma64_addr_t usage sparc: remove dma64_addr_t usage fuse: use release_pages() taskstats: use real microsecond granularity for CPU times taskstats: split fill_pid function taskstats: separate taskstats commands delayacct: align to 8 byte boundary on 64-bit systems delay-accounting: reimplement -c for getdelays.c to report information on a target command namespaces Kconfig: move namespace menu location after the cgroup namespaces Kconfig: remove the cgroup device whitelist experimental tag namespaces Kconfig: remove pointless cgroup dependency namespaces Kconfig: make namespace a submenu ...
