path: root/Documentation
2018-07-22arm64: Add 'ssbd' command-line optionMarc Zyngier
commit a43ae4dfe56a01f5b98ba0cb2f784b6a43bafcc6 upstream. On a system where the firmware implements ARCH_WORKAROUND_2, it may be useful to either permanently enable or disable the workaround for cases where the user decides that they'd rather not get a trap overhead, and keep the mitigation permanently on or off instead of switching it on exception entry/exit. In any case, default to the mitigation being enabled. Reviewed-by: Julien Grall <julien.grall@arm.com> Reviewed-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03lib/vsprintf: Remove atomic-unsafe support for %pCrGeert Uytterhoeven
commit 666902e42fd8344b923c02dc5b0f37948ff4f225 upstream. "%pCr" formats the current rate of a clock, and calls clk_get_rate(). The latter obtains a mutex, hence it must not be called from atomic context. Remove support for this rarely-used format, as vsprintf() (and e.g. printk()) must be callable from any context. Any remaining out-of-tree users will start seeing the clock's name printed instead of its rate. Reported-by: Jia-Ju Bai <baijiaju1990@gmail.com> Fixes: 900cca2944254edd ("lib/vsprintf: add %pC{,n,r} format specifiers for clocks") Link: http://lkml.kernel.org/r/1527845302-12159-5-git-send-email-geert+renesas@glider.be To: Jia-Ju Bai <baijiaju1990@gmail.com> To: Jonathan Corbet <corbet@lwn.net> To: Michael Turquette <mturquette@baylibre.com> To: Stephen Boyd <sboyd@kernel.org> To: Zhang Rui <rui.zhang@intel.com> To: Eduardo Valentin <edubezval@gmail.com> To: Eric Anholt <eric@anholt.net> To: Stefan Wahren <stefan.wahren@i2se.com> To: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: Petr Mladek <pmladek@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: linux-doc@vger.kernel.org Cc: linux-clk@vger.kernel.org Cc: linux-pm@vger.kernel.org Cc: linux-serial@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-renesas-soc@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: Geert Uytterhoeven <geert+renesas@glider.be> Cc: stable@vger.kernel.org # 4.1+ Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-26net: dsa: b53: Add BCM5389 supportDamien Thébault
[ Upstream commit a95691bc54af1ac4b12c354f91e9cabf1cb068df ] This patch adds support for the BCM5389 switch connected through MDIO. Signed-off-by: Damien Thébault <damien.thebault@vitec.com> Reviewed-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-13netdev-FAQ: clarify DaveM's position for stable backportsCong Wang
[ Upstream commit 75d4e704fa8d2cf33ff295e5b441317603d7f9fd ] Per discussion with David at netconf 2018, let's clarify DaveM's position of handling stable backports in netdev-FAQ. This is important for people relying on upstream -stable releases. Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30dmaengine: mv_xor_v2: Fix clock resource by adding a register clockGregory CLEMENT
[ Upstream commit 3cd2c313f1d618f92d1294addc6c685c17065761 ] On the CP110 components which are present on the Armada 7K/8K SoC we need to explicitly enable the clock for the registers. However it is not needed for the AP8xx component, that's why this clock is optional. With this patch both clock have now a name, but in order to be backward compatible, the name of the first clock is not used. It allows to still use this clock with a device tree using the old binding. Reviewed-by: Rob Herring <robh@kernel.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30dm thin: fix documentation relative to low water mark thresholdmulhern
[ Upstream commit 9b28a1102efc75d81298198166ead87d643a29ce ] Fixes: 1. The use of "exceeds" when the opposite of exceeds, falls below, was meant. 2. Properly speaking, a table can not exceed a threshold. It emphasizes the important point, which is that it is the userspace daemon's responsibility to check for low free space when a device is resumed, since it won't get a special event indicating low free space in that situation. Signed-off-by: mulhern <amulhern@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22Documentation/spec_ctrl: Do some minor cleanupsBorislav Petkov
commit dd0792699c4058e63c0715d9a7c2d40226fcdddc upstream Fix some typos, improve formulations, end sentences with a fullstop. Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/speculation: Make "seccomp" the default mode for Speculative Store BypassKees Cook
commit f21b53b20c754021935ea43364dbf53778eeba32 upstream Unless explicitly opted out of, anything running under seccomp will have SSB mitigations enabled. Choosing the "prctl" mode will disable this. [ tglx: Adjusted it to the new arch_seccomp_spec_mitigate() mechanism ] Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22prctl: Add force disable speculationThomas Gleixner
commit 356e4bfff2c5489e016fdb925adbf12a1e3950ee upstream For certain use cases it is desired to enforce mitigations so they cannot be undone afterwards. That's important for loader stubs which want to prevent a child from disabling the mitigation again. Will also be used for seccomp(). The extra state preserving of the prctl state for SSB is a preparatory step for EBPF dymanic speculation control. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/speculation: Add prctl for Speculative Store Bypass mitigationThomas Gleixner
commit a73ec77ee17ec556fe7f165d00314cb7c047b1ac upstream Add prctl based control for Speculative Store Bypass mitigation and make it the default mitigation for Intel and AMD. Andi Kleen provided the following rationale (slightly redacted): There are multiple levels of impact of Speculative Store Bypass: 1) JITed sandbox. It cannot invoke system calls, but can do PRIME+PROBE and may have call interfaces to other code 2) Native code process. No protection inside the process at this level. 3) Kernel. 4) Between processes. The prctl tries to protect against case (1) doing attacks. If the untrusted code can do random system calls then control is already lost in a much worse way. So there needs to be system call protection in some way (using a JIT not allowing them or seccomp). Or rather if the process can subvert its environment somehow to do the prctl it can already execute arbitrary code, which is much worse than SSB. To put it differently, the point of the prctl is to not allow JITed code to read data it shouldn't read from its JITed sandbox. If it already has escaped its sandbox then it can already read everything it wants in its address space, and do much worse. The ability to control Speculative Store Bypass allows to enable the protection selectively without affecting overall system performance. Based on an initial patch from Tim Chen. Completely rewritten. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22prctl: Add speculation control prctlsThomas Gleixner
commit b617cfc858161140d69cc0b5cc211996b557a1c7 upstream Add two new prctls to control aspects of speculation related vulnerabilites and their mitigations to provide finer grained control over performance impacting mitigations. PR_GET_SPECULATION_CTRL returns the state of the speculation misfeature which is selected with arg2 of prctl(2). The return value uses bit 0-2 with the following meaning: Bit Define Description 0 PR_SPEC_PRCTL Mitigation can be controlled per task by PR_SET_SPECULATION_CTRL 1 PR_SPEC_ENABLE The speculation feature is enabled, mitigation is disabled 2 PR_SPEC_DISABLE The speculation feature is disabled, mitigation is enabled If all bits are 0 the CPU is not affected by the speculation misfeature. If PR_SPEC_PRCTL is set, then the per task control of the mitigation is available. If not set, prctl(PR_SET_SPECULATION_CTRL) for the speculation misfeature will fail. PR_SET_SPECULATION_CTRL allows to control the speculation misfeature, which is selected by arg2 of prctl(2) per task. arg3 is used to hand in the control value, i.e. either PR_SPEC_ENABLE or PR_SPEC_DISABLE. The common return values are: EINVAL prctl is not implemented by the architecture or the unused prctl() arguments are not 0 ENODEV arg2 is selecting a not supported speculation misfeature PR_SET_SPECULATION_CTRL has these additional return values: ERANGE arg3 is incorrect, i.e. it's not either PR_SPEC_ENABLE or PR_SPEC_DISABLE ENXIO prctl control of the selected speculation misfeature is disabled The first supported controlable speculation misfeature is PR_SPEC_STORE_BYPASS. Add the define so this can be shared between architectures. Based on an initial patch from Tim Chen and mostly rewritten. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/bugs: Provide boot parameters for the spec_store_bypass_disable mitigationKonrad Rzeszutek Wilk
commit 24f7fc83b9204d20f878c57cb77d261ae825e033 upstream Contemporary high performance processors use a common industry-wide optimization known as "Speculative Store Bypass" in which loads from addresses to which a recent store has occurred may (speculatively) see an older value. Intel refers to this feature as "Memory Disambiguation" which is part of their "Smart Memory Access" capability. Memory Disambiguation can expose a cache side-channel attack against such speculatively read values. An attacker can create exploit code that allows them to read memory outside of a sandbox environment (for example, malicious JavaScript in a web page), or to perform more complex attacks against code running within the same privilege level, e.g. via the stack. As a first step to mitigate against such attacks, provide two boot command line control knobs: nospec_store_bypass_disable spec_store_bypass_disable=[off,auto,on] By default affected x86 processors will power on with Speculative Store Bypass enabled. Hence the provided kernel parameters are written from the point of view of whether to enable a mitigation or not. The parameters are as follows: - auto - Kernel detects whether your CPU model contains an implementation of Speculative Store Bypass and picks the most appropriate mitigation. - on - disable Speculative Store Bypass - off - enable Speculative Store Bypass [ tglx: Reordered the checks so that the whole evaluation is not done when the CPU does not support RDS ] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@suse.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/bugs: Expose /sys/../spec_store_bypassKonrad Rzeszutek Wilk
commit c456442cd3a59eeb1d60293c26cbe2ff2c4e42cf upstream Add the sysfs file for the new vulerability. It does not do much except show the words 'Vulnerable' for recent x86 cores. Intel cores prior to family 6 are known not to be vulnerable, and so are some Atoms and some Xeon Phi. It assumes that older Cyrix, Centaur, etc. cores are immune. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@suse.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-16arm64: Add work around for Arm Cortex-A55 Erratum 1024718Suzuki K Poulose
commit ece1397cbc89c51914fae1aec729539cfd8bd62b upstream. Some variants of the Arm Cortex-55 cores (r0p0, r0p1, r1p0) suffer from an erratum 1024718, which causes incorrect updates when DBM/AP bits in a page table entry is modified without a break-before-make sequence. The work around is to skip enabling the hardware DBM feature on the affected cores. The hardware Access Flag management features is not affected. There are some other cores suffering from this errata, which could be added to the midr_list to trigger the work around. Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: ckadabi@codeaurora.org Reviewed-by: Dave Martin <dave.martin@arm.com> Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-09arm/arm64: KVM: Add PSCI version selection APIMarc Zyngier
commit 85bd0ba1ff9875798fad94218b627ea9f768f3c3 upstream. Although we've implemented PSCI 0.1, 0.2 and 1.0, we expose either 0.1 or 1.0 to a guest, defaulting to the latest version of the PSCI implementation that is compatible with the requested version. This is no different from doing a firmware upgrade on KVM. But in order to give a chance to hypothetical badly implemented guests that would have a fit by discovering something other than PSCI 0.2, let's provide a new API that allows userspace to pick one particular version of the API. This is implemented as a new class of "firmware" registers, where we expose the PSCI version. This allows the PSCI version to be save/restored as part of a guest migration, and also set to any supported version if the guest requires it. Cc: stable@vger.kernel.org #4.16 Reviewed-by: Christoffer Dall <cdall@kernel.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-29s390: introduce CPU alternativesVasily Gorbik
[ Upstream commit 686140a1a9c41d85a4212a1c26d671139b76404b ] Implement CPU alternatives, which allows to optionally patch newer instructions at runtime, based on CPU facilities availability. A new kernel boot parameter "noaltinstr" disables patching. Current implementation is derived from x86 alternatives. Although ideal instructions padding (when altinstr is longer then oldinstr) is added at compile time, and no oldinstr nops optimization has to be done at runtime. Also couple of compile time sanity checks are done: 1. oldinstr and altinstr must be <= 254 bytes long, 2. oldinstr and altinstr must not have an odd length. alternative(oldinstr, altinstr, facility); alternative_2(oldinstr, altinstr1, facility1, altinstr2, facility2); Both compile time and runtime padding consists of either 6/4/2 bytes nop or a jump (brcl) + 2 bytes nop filler if padding is longer then 6 bytes. .altinstructions and .altinstr_replacement sections are part of __init_begin : __init_end region and are freed after initialization. Signed-off-by: Vasily Gorbik <gor@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-13clk: meson: meson8b: add compatibles for Meson8 and Meson8m2Martin Blumenstingl
[ Upstream commit 855f06a1009faabb0c6a3e9b49d115496d325856 ] The clock controller on Meson8, Meson8b and Meson8m2 is very similar based on the code from the Amlogic GPL kernel sources. Add separate compatibles for each SoC to make sure that we can easily implement all the small differences for each SoC later on. In general the Meson8 and Meson8m2 seem to be almost identical as they even share the same mach-meson8 directory in Amlogic's GPL kernel sources. The main clocks on Meson8, Meson8b and Meson8m2 are very similar, because they are all using the same PLL values, 90% of the clock gates are the same (the actual diffstat of the mach-meson8/clock.c and mach-meson8b/clock.c files is around 30 to 40 lines, when excluding all commented out code). The difference between the Meson8 and Meson8b clock gates seem to be: - Meson8 has AIU_PCLK, HDMI_RX, VCLK2_ENCT, VCLK2_ENCL, UART3, CSI_DIG_CLKIN gates which don't seem to be available on Meson8b - the gate on Meson8 for bit 7 seems to be named "_1200XXX" instead of "PERIPHS_TOP" (on Meson8b) - Meson8b has a SANA gate which doesn't seem to exist on Meson8 (or on Meson8 the same bit is used by the UART3 gate in Amlogic's GPL kernel sources) None of these gates is added for now, since it's unclear whether these definitions are actually correct (the VCLK2_ENCT gate for example is defined, but only used in some commented block). The main difference between all three SoCs seem to be the video (VPU) clocks. Apart from different supported clock rates (according to vpu.c in mach-meson8 and mach-meson8b from Amlogic's GPL kernel sources) the most notable difference is that Meson8m2 has a GP_PLL clock and a mux (probably the same as on the Meson GX SoCs) to support glitch-free (clock rate) switching. None of these VPU clocks are not supported by our mainline meson8b clock driver yet though. Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com> Acked-by: Rob Herring <robh@kernel.org> Acked-by: Kevin Hilman <khilman@baylibre.com> Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-13dt-bindings: display: sun4i: Add allwinner,tcon-channel propertyMaxime Ripard
[ Upstream commit 22662f12768f971809b478386d9cc4947d00497a ] The Allwinner Timings Controller has two, mutually exclusive, channels. When the binding has been introduced, it was assumed that there would be only a single user per channel in the system. While this is likely for the channel 0 which only connects to LCD displays, it turns out that the channel 1 can be connected to multiple controllers in the SoC (HDMI and TV encoders for example). And while the simultaneous use of HDMI and TV outputs cannot be achieved, switching from one to the other at runtime definitely sounds plausible. Add an extra property, allwinner,tcon-channel, to specify for a given endpoint which TCON channel it is connected to, while falling back to the previous mechanism if that property is missing. Acked-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08Documentation: pinctrl: palmas: Add ti,palmas-powerhold-override property ↵Keerthy
definition commit 0ea66f76ba17a4b229caaadd77de694111b21769 upstream. GPIO7 is configured in POWERHOLD mode which has higher priority over DEV_ON bit and keeps the PMIC supplies on even after the DEV_ON bit is turned off. This property enables driver to over ride the POWERHOLD value to GPIO7 so as to turn off the PMIC in power off scenarios. Signed-off-by: Keerthy <j-keerthy@ti.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Cc: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-28iio: ABI: Fix name of timestamp sysfs fileLinus Walleij
commit b9a3589332c2a25fb7edad25a26fcaada3209126 upstream. The name of the file is "current_timetamp_clock" not "timestamp_clock". Fixes: bc2b7dab629a ("iio:core: timestamping clock selection support") Cc: Gregor Boirie <gregor.boirie@parrot.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-24omapdrm: panel: fix compatible vendor string for td028ttec1H. Nikolaus Schaller
[ Upstream commit c1b9d4c75cd549e08bd0596d7f9dcc20f7f6e8fa ] The vendor name was "toppoly" but other panels and the vendor list have defined it as "tpo". So let's fix it in driver and bindings. We keep the old definition in parallel to stay compatible with potential older DTB setup. Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-24dt-bindings: mfd: axp20x: Add "xpowers,master-mode" property for AXP806 PMICsRask Ingemann Lambertsen
[ Upstream commit 8461cf20d17e0090e9236b73d25b31be4f7fadc5 ] commit b101829a029a ("mfd: axp20x: Fix AXP806 access errors on cold boot") was intended to fix the case where a board uses an AXP806 in slave mode, but the boot loader leaves it in master mode for lack of AXP806 support. But now the driver breaks on boards where the PMIC is operating in master mode. To let the device tree describe which mode of operation is needed, this patch introduces a new property "xpowers,master-mode". Fixes: 204ae2963e10 ("mfd: axp20x: Add bindings for AXP806 PMIC") Signed-off-by: Rask Ingemann Lambertsen <rask@formelder.dk> Acked-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22arm: spear13xx: Fix dmas cellsViresh Kumar
commit cdd10409914184c7eee5ae3e11beb890c9c16c61 upstream. The "dmas" cells for the designware DMA controller need to have only 3 properties apart from the phandle: request line, src master and destination master. But the commit 6e8887f60f60 updated it incorrectly while moving from platform code to DT. Fix it. Cc: stable@vger.kernel.org # v3.10+ Fixes: 6e8887f60f60 ("ARM: SPEAr13xx: Pass generic DW DMAC platform data from DT") Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22ext4: correct documentation for grpid mount optionErnesto A. Fernández
commit 9f0372488cc9243018a812e8cfbf27de650b187b upstream. The grpid option is currently described as being the same as nogrpid. Signed-off-by: Ernesto A. Fernández <ernesto.mnd.fernandez@gmail.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-13x86/paravirt: Remove 'noreplace-paravirt' cmdline optionJosh Poimboeuf
(cherry picked from commit 12c69f1e94c89d40696e83804dd2f0965b5250cd) The 'noreplace-paravirt' option disables paravirt patching, leaving the original pv indirect calls in place. That's highly incompatible with retpolines, unless we want to uglify paravirt even further and convert the paravirt calls to retpolines. As far as I can tell, the option doesn't seem to be useful for much other than introducing surprising corner cases and making the kernel vulnerable to Spectre v2. It was probably a debug option from the early paravirt days. So just remove it. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Juergen Gross <jgross@suse.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Ashok Raj <ashok.raj@intel.com> Cc: Greg KH <gregkh@linuxfoundation.org> Cc: Jun Nakajima <jun.nakajima@intel.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Asit Mallick <asit.k.mallick@intel.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jason Baron <jbaron@akamai.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Alok Kataria <akataria@vmware.com> Cc: Arjan Van De Ven <arjan.van.de.ven@intel.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Dan Williams <dan.j.williams@intel.com> Link: https://lkml.kernel.org/r/20180131041333.2x6blhxirc2kclrq@treble Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-13Documentation: Document array_index_nospecMark Rutland
(cherry picked from commit f84a56f73dddaeac1dba8045b007f742f61cd2da) Document the rationale and usage of the new array_index_nospec() helper. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Kees Cook <keescook@chromium.org> Cc: linux-arch@vger.kernel.org Cc: Jonathan Corbet <corbet@lwn.net> Cc: Peter Zijlstra <peterz@infradead.org> Cc: gregkh@linuxfoundation.org Cc: kernel-hardening@lists.openwall.com Cc: torvalds@linux-foundation.org Cc: alan@linux.intel.com Link: https://lkml.kernel.org/r/151727413645.33451.15878817161436755393.stgit@dwillia2-desk3.amr.corp.intel.com Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23x86/pti: Document fix wrong indexzhenwei.pi
commit 98f0fceec7f84d80bc053e49e596088573086421 upstream. In section <2. Runtime Cost>, fix wrong index. Signed-off-by: zhenwei.pi <zhenwei.pi@youruncloud.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: dave.hansen@linux.intel.com Link: https://lkml.kernel.org/r/1516237492-27739-1-git-send-email-zhenwei.pi@youruncloud.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/spectre: Add boot time option to select Spectre v2 mitigationDavid Woodhouse
commit da285121560e769cc31797bba6422eea71d473e0 upstream. Add a spectre_v2= option to select the mitigation used for the indirect branch speculation vulnerability. Currently, the only option available is retpoline, in its various forms. This will be expanded to cover the new IBRS/IBPB microcode features. The RETPOLINE_AMD feature relies on a serializing LFENCE for speculation control. For AMD hardware, only set RETPOLINE_AMD if LFENCE is a serializing instruction, which is indicated by the LFENCE_RDTSC feature. [ tglx: Folded back the LFENCE/AMD fixes and reworked it so IBRS integration becomes simple ] Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515707194-20531-5-git-send-email-dwmw@amazon.co.uk Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17sysfs/cpu: Fix typos in vulnerability documentationDavid Woodhouse
commit 9ecccfaa7cb5249bd31bdceb93fcf5bedb8a24d8 upstream. Fixes: 87590ce6e ("sysfs/cpu: Add vulnerability folder") Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17sysfs/cpu: Add vulnerability folderThomas Gleixner
commit 87590ce6e373d1a5401f6539f0c59ef92dd924a9 upstream. As the meltdown/spectre problem affects several CPU architectures, it makes sense to have common way to express whether a system is affected by a particular vulnerability or not. If affected the way to express the mitigation should be common as well. Create /sys/devices/system/cpu/vulnerabilities folder and files for meltdown, spectre_v1 and spectre_v2. Allow architectures to override the show function. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Linus Torvalds <torvalds@linuxfoundation.org> Cc: Borislav Petkov <bp@alien8.de> Cc: David Woodhouse <dwmw@amazon.co.uk> Link: https://lkml.kernel.org/r/20180107214913.096657732@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/Documentation: Add PTI descriptionDave Hansen
commit 01c9b17bf673b05bb401b76ec763e9730ccf1376 upstream. Add some details about how PTI works, what some of the downsides are, and how to debug it when things go wrong. Also document the kernel parameter: 'pti/nopti'. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Randy Dunlap <rdunlap@infradead.org> Reviewed-by: Kees Cook <keescook@chromium.org> Cc: Moritz Lipp <moritz.lipp@iaik.tugraz.at> Cc: Daniel Gruss <daniel.gruss@iaik.tugraz.at> Cc: Michael Schwarz <michael.schwarz@iaik.tugraz.at> Cc: Richard Fellner <richard.fellner@student.tugraz.at> Cc: Andy Lutomirski <luto@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com> Cc: Andi Lutomirsky <luto@kernel.org> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20180105174436.1BC6FA2B@viggo.jf.intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05x86/kaiser: Check boottime cmdline paramsBorislav Petkov
AMD (and possibly other vendors) are not affected by the leak KAISER is protecting against. Keep the "nopti" for traditional reasons and add pti=<on|off|auto> like upstream. Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05x86/kaiser: Rename and simplify X86_FEATURE_KAISER handlingBorislav Petkov
Concentrate it in arch/x86/mm/kaiser.c and use the upstream string "nopti". Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: add "nokaiser" boot option, using ALTERNATIVEHugh Dickins
Added "nokaiser" boot option: an early param like "noinvpcid". Most places now check int kaiser_enabled (#defined 0 when not CONFIG_KAISER) instead of #ifdef CONFIG_KAISER; but entry_64.S and entry_64_compat.S are using the ALTERNATIVE technique, which patches in the preferred instructions at runtime. That technique is tied to x86 cpu features, so X86_FEATURE_KAISER is fabricated. Prior to "nokaiser", Kaiser #defined _PAGE_GLOBAL 0: revert that, but be careful with both _PAGE_GLOBAL and CR4.PGE: setting them when nokaiser like when !CONFIG_KAISER, but not setting either when kaiser - neither matters on its own, but it's hard to be sure that _PAGE_GLOBAL won't get set in some obscure corner, or something add PGE into CR4. By omitting _PAGE_GLOBAL from __supported_pte_mask when kaiser_enabled, all page table setup which uses pte_pfn() masks it out of the ptes. It's slightly shameful that the same declaration versus definition of kaiser_enabled appears in not one, not two, but in three header files (asm/kaiser.h, asm/pgtable.h, asm/tlbflush.h). I felt safer that way, than with #including any of those in any of the others; and did not feel it worth an asm/kaiser_enabled.h - kernel/cpu/common.c includes them all, so we shall hear about it if they get out of synch. Cleanups while in the area: removed the silly #ifdef CONFIG_KAISER from kaiser.c; removed the unused native_get_normal_pgd(); removed the spurious reg clutter from SWITCH_*_CR3 macro stubs; corrected some comments. But more interestingly, set CR4.PSE in secondary_startup_64: the manual is clear that it does not matter whether it's 0 or 1 when 4-level-pts are enabled, but I was distracted to find cr4 different on BSP and auxiliaries - BSP alone was adding PSE, in probe_page_size_mask(). Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02x86/mm: Add the 'nopcid' boot option to turn off PCIDAndy Lutomirski
commit 0790c9aad84901ca1bdc14746175549c8b5da215 upstream. The parameter is only present on x86_64 systems to save a few bytes, as PCID is always disabled on x86_32. Signed-off-by: Andy Lutomirski <luto@kernel.org> Reviewed-by: Nadav Amit <nadav.amit@gmail.com> Reviewed-by: Borislav Petkov <bp@suse.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/8bbb2e65bcd249a5f18bfb8128b4689f08ac2b60.1498751203.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14dt-bindings: usb: fix reg-property port-number rangeJohan Hovold
[ Upstream commit f42ae7b0540937e00fe005812997f126aaac4bc2 ] The USB hub port-number range for USB 2.0 is 1-255 and not 1-31 which reflects an arbitrary limit set by the current Linux implementation. Note that for USB 3.1 hubs the valid range is 1-15. Increase the documented valid range in the binding to 255, which is the maximum allowed by the specifications. Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-05hwmon: (jc42) optionally try to disable the SMBUS timeoutPeter Rosin
commit 68615eb01f82256c19e41967bfb3eef902f77033 upstream. With a nxp,se97 chip on an atmel sama5d31 board, the I2C adapter driver is not always capable of avoiding the 25-35 ms timeout as specified by the SMBUS protocol. This may cause silent corruption of the last bit of any transfer, e.g. a one is read instead of a zero if the sensor chip times out. This also affects the eeprom half of the nxp-se97 chip, where this silent corruption was originally noticed. Other I2C adapters probably suffer similar issues, e.g. bit-banging comes to mind as risky... The SMBUS register in the nxp chip is not a standard Jedec register, but it is not special to the nxp chips either, at least the atmel chips have the same mechanism. Therefore, do not special case this on the manufacturer, it is opt-in via the device property anyway. Signed-off-by: Peter Rosin <peda@axentia.se> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-21Revert "dt-bindings: Add LEGO MINDSTORMS EV3 compatible specification"Sasha Levin
This reverts commit 852bf68b7a62195c3c0c63f3b11f3f30958fc220. As Ben pointed out, these drivers don't exist in <=4.9. Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-21Revert "dt-bindings: Add vendor prefix for LEGO"Sasha Levin
This reverts commit 04e13a5ec96db94c1cc8ce7b0b1e1b626e0c00c7. As Ben pointed out, these drivers don't exist in <=4.9. Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15dt-bindings: Add vendor prefix for LEGODavid Lechner
[ Upstream commit 7dcc31e2e68a386a29070384b51683ece80982bf ] Add a vendor prefix for LEGO Systems A/S Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: David Lechner <david@lechnology.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15dt-bindings: Add LEGO MINDSTORMS EV3 compatible specificationDavid Lechner
[ Upstream commit 21078ab174c99885ca83a5c32db0d33b1617745e ] This adds the board level device tree specification for LEGO MINDSTORMS EV3 Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: David Lechner <david@lechnology.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15dt-bindings: clockgen: Add compatible string for LS1012AHarninder Rai
[ Upstream commit 73447f68d7b2bc1df870da88b0e21d2bc1afc025 ] Signed-off-by: Harninder Rai <harninder.rai@nxp.com> Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-08clocksource/drivers/arm_arch_timer: Add dt binding for hisilicon-161010101 ↵Ding Tianhong
erratum [ Upstream commit 729e55225b1f6225ee7a2a358d5141a3264627c4 ] This erratum describes a bug in logic outside the core, so MIDR can't be used to identify its presence, and reading an SoC-specific revision register from common arch timer code would be awkward. So, describe it in the device tree. Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-08iio: adc: hx711: Add DT binding for avia,hx711Andreas Klinger
[ Upstream commit ff1293f67734da68e23fecb6ecdae7112b8c43f9 ] Add DT bindings for avia,hx711 Add vendor avia to vendor list Signed-off-by: Andreas Klinger <ak@it-klinger.de> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-08drm: bridge: add DT bindings for TI ths8135Bartosz Golaszewski
[ Upstream commit 2e644be30fcc08c736f66b60f4898d274d4873ab ] THS8135 is a configurable video DAC. Add DT bindings for this chip. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Archit Taneja <architt@codeaurora.org> Link: http://patchwork.freedesktop.org/patch/msgid/1481623759-12786-3-git-send-email-bgolaszewski@baylibre.com Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06dt-bindings: input: Specify the interrupt number of TPS65217 power buttonMilo Kim
[ Upstream commit 820381572fc015baa4f5744f5d4583ec0c0f1b82 ] Specify the power button interrupt number which is from the datasheet. Signed-off-by: Milo Kim <woogyom.kim@gmail.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06dt-bindings: power/supply: Update TPS65217 propertiesMilo Kim
[ Upstream commit 81d7358d7038dd1001547950087e5b0641732f3f ] Add interrupt specifiers for USB and AC charger input. Interrupt numbers are from the datasheet. Fix wrong property for compatible string. Signed-off-by: Milo Kim <woogyom.kim@gmail.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05net: phy: dp83867: allow RGMII_TXID/RGMII_RXID interface typesKaricheri, Muralidharan
[ Upstream commit 34c55cf2fc75f8bf6ba87df321038c064cf2d426 ] Currently dp83867 driver returns error if phy interface type PHY_INTERFACE_MODE_RGMII_RXID is used to set the rx only internal delay. Similarly issue happens for PHY_INTERFACE_MODE_RGMII_TXID. Fix this by checking also the interface type if a particular delay value is missing in the phy dt bindings. Also update the DT document accordingly. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05Documentation: devicetree: change the mediatek ethernet compatible stringJohn Crispin
[ Upstream commit 61976fff20f92aceecc3670f6168bfc57a79e047 ] When the binding was defined, I was not aware that mt2701 was an earlier version of the SoC. For sake of consistency, the ethernet driver should use mt2701 inside the compat string as this is the earliest SoC with the ethernet core. The ethernet driver is currently of no real use until we finish and upstream the DSA driver. There are no users of this binding yet. It should be safe to fix this now before it is too late and we need to provide backward compatibility for the mt7623-eth compat string. Reported-by: Sean Wang <sean.wang@mediatek.com> Signed-off-by: John Crispin <john@phrozen.org> Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05dt: bindings: net: use boolean dt properties for eee broken modesjbrunet
[ Upstream commit 308d3165d8b2b98d3dc3d97d6662062735daea67 ] The patches regarding eee-broken-modes was merged before all people involved could find an agreement on the best way to move forward. While we agreed on having a DT property to mark particular modes as broken, the value used for eee-broken-modes mapped the phy register in very direct way. Because of this, the concern is that it could be used to implement configuration policies instead of describing a broken HW. In the end, having a boolean property for each mode seems to be preferred over one bit field value mapping the register (too) directly. Cc: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
