path: root/Documentation
2007-10-19hugetlbfs doc. updateRandy Dunlap
Fix typos, spelling, etc., in Doc/vm/hugetlbpage.txt. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-18DVB: get_dvb_firmware: update script for new location of tda10046 firmwareAndreas Arens
cherry picked from commit c545d6adbcacd296f7457bd992556feb055379de Update get_dvb_firmware script for the new location of the tda10046 firmware. The old location doesn't work anymore. Signed-off-by: Andreas Arens <ari@goron.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-18DVB: get_dvb_firmware: update script for new location of sp8870 firmwareMichael Krufky
cherry picked from commit 302170a4b47e869372974abd885dd11d5536b64a get_dvb_firmware: update script for new location of sp8870 firmware This url is no longer valid: http://www.technotrend.de/new/217g/tt_Premium_217g.zip Replace with: http://www.softwarepatch.pl/9999ccd06a4813cb827dbb0005071c71/tt_Premium_217g.zip Thanks-to: Tobias Stoeber <tobi@to-st.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-05-01[IPV6]: Disallow RH0 by default (CVE-2007-2242)Adrian Bunk
A security issue is emerging. Disallow Routing Header Type 0 by default as we have been doing for IPv4. This version already includes a fix for the original patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26hwmon: Add support for the Winbond W83687THFJean Delvare
Add support for the Winbond W83687THF chip to the w83627hf hardware monitoring driver. This new chip is almost similar to the already supported W83627THF chip, except for VID and a few other minor changes. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26w83791d: Documentation updateCharles Spirakis
The alarm bits and the beep enable bits are in different positions in the hardware. Document the problem and leave it to the user-space code to handle the situation. When this driver is updated to the standardized sysfs alarm/beep methodology, this won't be a problem. This is a documentation only change. Signed-off by: Charles Spirakis <bezaur@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26HWMON: w83791d: New hardware monitoring driver for the Winbond W83791DCharles Spirakis
Add support for the w83791d sensor chip. The w83791d hardware is somewhere between the w83781d and the w83792d and this driver code is derived from the code that supports those chips. Signed-off-by: Charles Spirakis <bezaur@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26smsc47m192: New hwmon driver for SMSC LPC47M192/997Hartmut Rick
New driver (smsc47m192) which supports voltage and temperature measurement features of SMSC LPC47M192 and LPC47M997 chips. Signed-off-by: Hartmut Rick <linux@rick.claranet.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26hwmon: New PC87427 hardware monitoring driverJean Delvare
This is a new hardware monitoring driver for the National Semiconductor PC87427 Super-I/O chip. It only supports fan speed monitoring for now, while the chip can do much more. Thanks to Amir Habibi at Candelis for setting up a test system, and to Michael Kress for testing several iterations of this driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26hwmon lm83: Add LM82 supportJordan Crouse
Add LM82 temperature sensor support (similar to the LM83, but less featureful). Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26i2c-piix4: Add ATI IXP200/300/400 supportRudolf Marek
This patch adds the ATI IXP southbridges support to i2c-piix4, as it turned out those chips are compatible with it. Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26I2C: i2c-piix4: Add Broadcom HT-1000 supportMartin Devera
Add Broadcom HT-1000 south bridge's PCI ID to i2c-piix driver. Note that at least on Supermicro H8SSL it uses non-standard SMBHSTCFG = 3 and standard values like 0 or 9 causes hangup. Signed-off-by: Martin Devera <devik@cdi.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-03hwmon: Update Rudolf Marek's e-mail addressRudolf Marek
The Silicon Hill club is not what it used to be. Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-03k8temp: Documentation updateRudolf Marek
Update the documentation for the k8temp driver. Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-03k8temp: Add documentationRudolf Marek
2007-01-30[SCSI] arcmsr: initial driver, version 1.20.00.13Erich Chen
arcmsr is a driver for the Areca Raid controller, a host based RAID subsystem that speaks SCSI at the firmware level. This patch is quite a clean up over the initial submission with contributions from: Randy Dunlap <rdunlap@xenotime.net> Christoph Hellwig <hch@lst.de> Matthew Wilcox <matthew@wil.cx> Adrian Bunk <bunk@stusta.de> Signed-off-by: Erich Chen <erich@areca.com.tw> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-09i2c-viapro: Add support for the VT8237A and VT8251Rudolf Marek
Documentation update included. Compile tested. Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-25[ALSA] Add echoaudio sound driversGiuliano Pochini pochini@shiny.it
Add echoaudio sound drivers (darla20, darla24, echo3g, gina20, gina24, indigo, indigodj, indigoio, layla20, lala24, mia, mona) Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-24[SCSI] hptiop: HighPoint RocketRAID 3xxx controller driverHighPoint Linux Team
HighPoint RocketRAID 3220/3320 series 8 channel PCI-X SATA RAID Host Adapters. Fixes from original submission: Merge Andrew Morton's patches: - Provide locking for global list - Fix debug printks - uninline function with multiple callsites - coding style fixups - remove unneeded casts of void* - kfree(NULL) is legal - Don't "succeed" if register_chrdev() failed - otherwise we'll later unregister a not-registered chrdev. - Don't return from hptiop_do_ioctl() with the spinlock held. - uninline __hpt_do_ioctl() Update for Arjan van de Ven's comments: - put all asm/ includes after the linux/ ones - replace mdelay with msleep - add pci posting flush - do not set pci command reqister in map_pci_bar - do not try merging sg elements in hptiop_buildsgl() - remove unused outstandingcommands member from hba structure - remove unimplemented hptiop_abort() handler - remove typedef u32 hpt_id_t Other updates: - fix endianess Signed-off-by: HighPoint Linux Team <linux@highpoint-tech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-08remove Documentation/feature-removal-schedule.txtAdrian Bunk
The information in Documentation/feature-removal-schedule.txt doesn't apply to the 2.6.16 branch (and most dates were already in the past. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Added support for the new Lifeview hybrid cardbus modulesHartmut Hackmann
There seem to be many variants of this cards with different feature sets. This entry supports analog TV, CVBS and s-video input, FM radio and DVB-T if they are supported by the hardware. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Added PCI IDs of 2 LifeView CardsHartmut Hackmann
Added ID entries for the Genius VideoWonder DVB-T and the LifeView FlyTV Platinum Gold Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Medion 7134: Autodetect second bridge chipMichael Krufky
The device, Medion 7134, has two saa7134 chips on it, but only one of them is functional in the current saa7134 driver. This patch adds autodetection for the second, unsupported saa7134 chip, as SAA7134_BOARD_MD7134_BRIDGE_2, and displays a message to the user (in dmesg) indicating that the second chip isn't yet functional. This is useful for users, since two instances of the saa7134 driver will spawn. This patch will prevent confusion by warning the user that only one of the chips on the board are functional. There are other versions of the SAA7134_BOARD_MD7134 with only a single saa7134 bridge/decoder -- those devices will not be affected by this patch. Only devices containing the second chip will display the warning. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Saa7134: add support for AVerMedia A169 Dual Analog tuner cardRickard Osser
- Added support for AVerMedia A169 Dual Analog tuner card (dual saa7134 decoders - only 1 working right now) - Added autodetection for both parts of the card. It shows up like 2 cards, B1 and B - Enabled tuner B1, SVIDEO on B1 and composite1 through SVIDEO, FIXME: B is more or less dead at this point and I suspect the FM-radio is on the B part of the board Adrian Bunk: slightly adapted to 2.6.16 Signed-off-by: Rickard Osser <ricky@osser.se> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Saa7134: document that there's also a 220RF from KWorldAdrian Bunk
I have the same card with the same PCI id, but from KWorld. The patch documents that this is the same card. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-16V4L/DVB: ELSA EX-VISION 700TV: fix incorrect PCI subsystem IDTAMUKI Shoichi
- Corrected autodetection for saa7130 card: subsystem: 1048:226c, board: ELSA EX-VISION 700TV Signed-off-by: TAMUKI Shoichi <tamuki@linet.gr.jp> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Kworld ATSC110: cleanupsMichael Krufky
- There is no radio with this tuner card... Thanks-to: Dwaine Garden <DwaineGarden@rogers.com> - fixed capitalization in card name. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Add support for Kworld ATSC110Andrew Burri
Signed-off-by: Andrew Burri <andrew.burri@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Add saa713x card: ELSA EX-VISION 700TV (saa7130)Tamuki Shoichi
Add support for ELSA EX-VISION 700TV, which is the ELSA Japan's flagship model of the software encoding TV capture card. All inputs (Television, Composite1 and S-Video) have been tested. Signed-off-by: Tamuki Shoichi <tamuki@linet.gr.jp> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Added support for the Tevion DVB-T 220RF cardHartshorn
This is an analog / digital hybrid card. Signed-off-by: Peter Hartshorn <p3r@users.sourceforge.net> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Added support for the ADS Instant TV DUO Cardbus PTV331Hartmut Hackmann
Analog and DVB-T are working, Remote not yet. This card is based on the new LifeView design, there should be many variants. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Added support for the LifeView FlyDVB-T LR301 cardGiampiero Giancipoli
Additionally to the card support, this changeset adds the option tda10046lifeview to get_dvb_firmware to download tda10046 firmware from LifeView's site. Signed-off-by: Giampiero Giancipoli <gianci@libero.it> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-16V4L/DVB: Add support for the Avermedia 777 DVB-T cardJose Alberto Reguero
Signed-off-by: Jose Alberto Reguero <jareguero@telefonica.net> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-05-01[PATCH] get_dvb_firmware: download nxt2002 firmware from new driver locationMichael Krufky
BBTI has updated their driver, and removed the old one from their website. This patch updates the get_dvb_firmware script to download the firmware from the new driver location. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-14[PATCH] Page migration documentation updateChristoph Lameter
Update the documentation for page migration. - Fix up bits and pieces in cpusets.txt - Rework text in vm/page-migration to be clearer and reflect the final version of page migration in 2.6.16. Mention Andi Kleen's numactl package that contains user space tools for page migration via libnuma. Add reference to numa_maps and to the manpage in numactl. - Add todo list for outstanding issues Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-09[MIPS] Threaten removal of code for NEC DDB5074 and DDB5476 evaluation boards.Ralf Baechle
What: Support for NEC DDB5074 and DDB5476 evaluation boards. When: June 2006 Why: Board specific code doesn't build anymore since ~2.6.0 and no users have complained indicating there is no more need for these boards. This should really be considered a last call. Who: Ralf Baechle <ralf@linux-mips.org>
2006-03-08[PATCH] i386: port ATI timer fix from x86_64 to i386 IIAndi Kleen
ATI chipsets tend to generate double timer interrupts for the local APIC timer when both the 8254 and the IO-APIC timer pins are enabled. This is because they route it to both and the result is anded together and the CPU ends up processing it twice. This patch changes check_timer to disable the 8254 routing for interrupt 0. I think it would be safe on all chipsets actually (i tested it on a couple and it worked everywhere) and Windows seems to do it in a similar way, but to be conservative this patch only enables this mode on ATI (and adds options to enable/disable too) Ported over from a similar x86-64 change. I reused the ACPI earlyquirk infrastructure for the ATI bridge check, but tweaked it a bit to work even without ACPI. Inspired by a patch from Chuck Ebbert, but redone. Cc: Chuck Ebbert <76306.1226@compuserve.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-08Merge master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvbLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvb: Merge branch 'work-fixes' V4L/DVB (3413): Typos grab bag of the month V4L/DVB (3403): Workaround to fix initialization for Nexus CA Merge branch 'work-fixes' V4L/DVB (3395): Fixed Pinnacle 300i DVB-T support V4L/DVB (3399): ELSA EX-VISION 500TV: fix incorrect PCI subsystem ID V4L/DVB (3382): Fix stv0297 for qam128 on tt c1500 (saa7146) V4L/DVB (3300a): Removing personal email from DVB maintainers V4L/DVB (3385): Dvb: fix __init/__exit section references in av7110 driver V4L/DVB (3378): Restore power on defaults of tda9887 after tda8290 probe V4L/DVB (3354): Fix maximum for the saturation and contrast controls. V4L/DVB (3352): Cxusb: fix lgdt3303 naming V4L/DVB (3348): Fixed saa7134 ALSA initialization with multiple cards V4L/DVB (3347): Pinnacle PCTV 40i: add filtered Composite2 input V4L/DVB (3341): Upstream sync - make 2 structs static V4L/DVB (3340): Make a struct static V4L/DVB (3337): Drivers/media/dvb/frontends/mt312.c: cleanups V4L/DVB (3336): Bt8xx documentation authors fix
2006-03-08[PATCH] rcu batch tuningDipankar Sarma
This patch adds new tunables for RCU queue and finished batches. There are two types of controls - number of completed RCU updates invoked in a batch (blimit) and monitoring for high rate of incoming RCUs on a cpu (qhimark, qlowmark). By default, the per-cpu batch limit is set to a small value. If the input RCU rate exceeds the high watermark, we do two things - force quiescent state on all cpus and set the batch limit of the CPU to INTMAX. Setting batch limit to INTMAX forces all finished RCUs to be processed in one shot. If we have more than INTMAX RCUs queued up, then we have bigger problems anyway. Once the incoming queued RCUs fall below the low watermark, the batch limit is set to the default. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-03Merge branch 'work-fixes'Mauro Carvalho Chehab
2006-03-03V4L/DVB (3399): ELSA EX-VISION 500TV: fix incorrect PCI subsystem IDMichael Krufky
- ELSA EX-VISION 500TV was incorrectly programmed to have the same subsystem ID as ELSA EX-VISION 300TV, (1048:226b) - This changeset replaces the incorrect subsystem ID (1048:226b) with the correct one (1048:226a) for the ELSA EX-VISION 500TV. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-03V4L/DVB (3347): Pinnacle PCTV 40i: add filtered Composite2 inputKarsten Suehring
This patch adds another composite input to the Pinnacle PCTV 100i definition which filters the chrominace signal from the luma input. This improves video quality for Composite signals on the S-Video connector of the card. In addition the name string of the card is changed to include PCTV 40i and 50i since these cards are identical. Signed-off-by: Karsten Suehring <ksuehring@gmx.net> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-03V4L/DVB (3336): Bt8xx documentation authors fixMichael Krufky
- use one Author per line, which allows us to add more authors later without creating a mess. - Add Michael Krufky due to -git commit 2cbeddc976645262dbe036d6ec0825f96af70da3 Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-02-27[IA64] Document the "nomca" boot parameterHorms
"nomca" can be used to disable machine check handling Signed-Off-By: Horms <horms@verge.net.au> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-26[PATCH] x86_64: Better ATI timer fixAndi Kleen
The previous experiment for using apicmaintimer on ATI systems didn't work out very well. In particular laptops with C2/C3 support often don't let it tick during idle, which makes it useless. There were also some other bugs that made the apicmaintimer often not used at all. I tried some other experiments - running timer over RTC and some other things but they didn't really work well neither. I rechecked the specs now and it turns out this simple change is actually enough to avoid the double ticks on the ATI systems. We just turn off IRQ 0 in the 8254 and only route it directly using the IO-APIC. I tested it on a few ATI systems and it worked there. In fact it worked on all chipsets (NVidia, Intel, AMD, ATI) I tried it on. According to the ACPI spec routing should always work through the IO-APIC so I think it's the correct thing to do anyways (and most of the old gunk in check_timer should be thrown away for x86-64). But for 2.6.16 it's best to do a fairly minimal change: - Use the known to be working everywhere-but-ATI IRQ0 both over 8254 and IO-APIC setup everywhere - Except on ATI disable IRQ0 in the 8254 - Remove the code to select apicmaintimer on ATI chipsets - Add some boot options to allow to override this (just paranoia) In 2.6.17 I hope to switch the default over to this for everybody. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/aia21/ntfs-2.6Linus Torvalds
2006-02-24[PATCH] tmpfs: recommend remount for mpolHugh Dickins
akpm points out that switching to a non-NUMA kernel could be irritating if mounting tmpfs fails on an mpol option: tmpfs.txt recommend remount. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24NTFS: Do more detailed reporting of why we cannot mount read-write byAnton Altaparmakov
special casing the VOLUME_MODIFIED_BY_CHKDSK flag. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2006-02-22Revert mount/umount uevent removalGreg Kroah-Hartman
This change reverts the 033b96fd30db52a710d97b06f87d16fc59fee0f1 commit from Kay Sievers that removed the mount/umount uevents from the kernel. Some older versions of HAL still depend on these events to detect when a new device has been mounted. These events are not correctly emitted, and are broken by design, and so, should not be relied upon by any future program. Instead, the /proc/mounts file should be polled to properly detect this kind of event. A feature-removal-schedule.txt entry has been added, noting when this interface will be removed from the kernel. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-21[PATCH] tmpfs: fix mount mpol nodelist parsingHugh Dickins
I've been dissatisfied with the mpol_nodelist mount option which was added to tmpfs earlier in -rc. Replace it by mpol=policy:nodelist. And it was broken: a nodelist is a comma-separated list of numbers and ranges; the mount options are a comma-separated list of token=values. Whoops, blindly strsep'ing on commas doesn't work so well: since we've no numeric tokens, and unlikely to add them, use that to distinguish. Move the mpol= parsing to shmem_parse_mpol under CONFIG_NUMA, reject all its options as invalid if not NUMA. /proc shows MPOL_PREFERRED as "prefer", so use that name for the policy instead of "preferred". Enforce that mpol=default has no nodelist; that mpol=prefer has one node only; that mpol=bind has a nodelist; but let mpol=interleave use node_online_map if no nodelist given. Describe this in tmpfs.txt. Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Robin Holt <holt@sgi.com> Acked-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
