path: root/Documentation
2016-10-15Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is the main MIPS pull request for 4.9: MIPS core arch code: - traps: 64bit kernels should read CP0_EBase 64bit - traps: Convert ebase to KSEG0 - c-r4k: Drop bc_wback_inv() from icache flush - c-r4k: Split user/kernel flush_icache_range() - cacheflush: Use __flush_icache_user_range() - uprobes: Flush icache via kernel address - KVM: Use __local_flush_icache_user_range() - c-r4k: Fix flush_icache_range() for EVA - Fix -mabi=64 build of vdso.lds - VDSO: Drop duplicated -I*/-E* aflags - tracing: move insn_has_delay_slot to a shared header - tracing: disable uprobe/kprobe on compact branch instructions - ptrace: Fix regs_return_value for kernel context - Squash lines for simple wrapper functions - Move identification of VP(E) into proc.c from smp-mt.c - Add definitions of SYNC barrierstype values - traps: Ensure full EBase is written - tlb-r4k: If there are wired entries, don't use TLBINVF - Sanitise coherentio semantics - dma-default: Don't check hw_coherentio if device is non-coherent - Support per-device DMA coherence - Adjust MIPS64 CAC_BASE to reflect Config.K0 - Support generating Flattened Image Trees (.itb) - generic: Introduce generic DT-based board support - generic: Convert SEAD-3 to a generic board - Enable hardened usercopy - Don't specify STACKPROTECTOR in defconfigs Octeon: - Delete dead code and files across the platform. - Change to use all memory into use by default. - Rename upper case variables in setup code to lowercase. - Delete legacy hack for broken bootloaders. - Leave maintaining the link state to the actual ethernet/PHY drivers. - Add DTS for D-Link DSR-500N. - Fix PCI interrupt routing on D-Link DSR-500N. Pistachio: - Remove ANDROID_TIMED_OUTPUT from defconfig TX39xx: - Move GPIO setup from .mem_setup() to .arch_init() - Convert to Common Clock Framework TX49xx: - Move GPIO setup from .mem_setup() to .arch_init() - Convert to Common Clock Framework txx9wdt: - Add missing clock (un)prepare calls for CCF BMIPS: - Add PW, GPIO SDHCI and NAND device node names - Support APPENDED_DTB - Add missing bcm97435svmb to DT_NONE - Rename bcm96358nb4ser to bcm6358-neufbox4-sercom - Add DT examples for BCM63268, BCM3368 and BCM6362 - Add support for BCM3368 and BCM6362 PCI - Reduce stack frame usage - Use struct list_head lists - Support for CONFIG_PCI_DOMAINS_GENERIC - Make pcibios_set_cache_line_size an initcall - Inline pcibios_assign_all_busses - Split pci.c into pci.c & pci-legacy.c - Introduce CONFIG_PCI_DRIVERS_LEGACY - Support generic drivers CPC - Convert bare 'unsigned' to 'unsigned int' - Avoid lock when MIPS CM >= 3 is present GIC: - Delete unused file smp-gic.c mt7620: - Delete unnecessary assignment for the field "owner" from PCI BCM63xx: - Let clk_disable() return immediately if clk is NULL pm-cps: - Change FSB workaround to CPU blacklist - Update comments on barrier instructions - Use MIPS standard lightweight ordering barrier - Use MIPS standard completion barrier - Remove selection of sync types - Add MIPSr6 CPU support - Support CM3 changes to Coherence Enable Register SMP: - Wrap call to mips_cpc_lock_other in mips_cm_lock_other - Introduce mechanism for freeing and allocating IPIs cpuidle: - cpuidle-cps: Enable use with MIPSr6 CPUs. SEAD3: - Rewrite to use DT and generic kernel feature. USB: - host: ehci-sead3: Remove SEAD-3 EHCI code FBDEV: - cobalt_lcdfb: Drop SEAD3 support dt-bindings: - Document a binding for simple ASCII LCDs auxdisplay: - img-ascii-lcd: driver for simple ASCII LCD displays irqchip i8259: - i8259: Add domain before mapping parent irq - i8259: Allow platforms to override poll function - i8259: Remove unused i8259A_irq_pending Malta: - Rewrite to use DT of/platform: - Probe "isa" busses by default CM: - Print CM error reports upon bus errors Module: - Migrate exception table users off module.h and onto extable.h - Make various drivers explicitly non-modular: - Audit and remove any unnecessary uses of module.h mailmap: - Canonicalize to Qais' current email address. Documentation: - MIPS supports HAVE_REGS_AND_STACK_ACCESS_API Loongson1C: - Add CPU support for Loongson1C - Add board support - Add defconfig - Add RTC support for Loongson1C board All this except one Documentation fix has sat in linux-next and has survived Imagination's automated build test system" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (127 commits) Documentation: MIPS supports HAVE_REGS_AND_STACK_ACCESS_API MIPS: ptrace: Fix regs_return_value for kernel context MIPS: VDSO: Drop duplicated -I*/-E* aflags MIPS: Fix -mabi=64 build of vdso.lds MIPS: Enable hardened usercopy MIPS: generic: Convert SEAD-3 to a generic board MIPS: generic: Introduce generic DT-based board support MIPS: Support generating Flattened Image Trees (.itb) MIPS: Adjust MIPS64 CAC_BASE to reflect Config.K0 MIPS: Print CM error reports upon bus errors MIPS: Support per-device DMA coherence MIPS: dma-default: Don't check hw_coherentio if device is non-coherent MIPS: Sanitise coherentio semantics MIPS: PCI: Support generic drivers MIPS: PCI: Introduce CONFIG_PCI_DRIVERS_LEGACY MIPS: PCI: Split pci.c into pci.c & pci-legacy.c MIPS: PCI: Inline pcibios_assign_all_busses MIPS: PCI: Make pcibios_set_cache_line_size an initcall MIPS: PCI: Support for CONFIG_PCI_DOMAINS_GENERIC MIPS: PCI: Use struct list_head lists ...
2016-10-14Merge tag 'linux-kselftest-4.9-rc1-update' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest Pull kselftest updates from Shuah Khan: "This update consists of: - Fixes and improvements to existing tests - Moving code from Documentation to selftests, samples, and tools: * Moves dnotify_test, prctl, ptp, vDSO, ia64, watchdog, and networking tests from Documentation to selftests. * Moves mic/mpssd, misc-devices/mei, timers, watchdog, auxdisplay, and blackfin examples from Documentation to samples. * Moves accounting, laptops/dslm, and pcmcia/crc32hash tools from Documentation to tools. * Deletes BUILD_DOCSRC and its dependencies" * tag 'linux-kselftest-4.9-rc1-update' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: (21 commits) selftests/futex: Check ANSI terminal color support Doc: update 00-INDEX files to reflect the runnable code move samples: move blackfin gptimers-example from Documentation tools: move pcmcia crc32hash tool from Documentation tools: move laptops dslm tool from Documentation tools: move accounting tool from Documentation samples: move auxdisplay example code from Documentation samples: move watchdog example code from Documentation samples: move timers example code from Documentation samples: move misc-devices/mei example code from Documentation samples: move mic/mpssd example code from Documentation selftests: Move networking/timestamping from Documentation selftests: move watchdog tests from Documentation/watchdog selftests: move ia64 tests from Documentation/ia64 selftests: move vDSO tests from Documentation/vDSO selftests: move ptp tests from Documentation/ptp selftests: move prctl tests from Documentation/prctl selftests: move dnotify_test from Documentation/filesystems selftests/timers: Add missing error code assignment before test selftests/zram: replace ZRAM_LZ4_COMPRESS ...
2016-10-14Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: - EXPORT_SYMBOL for asm source by Al Viro. This does bring a regression, because genksyms no longer generates checksums for these symbols (CONFIG_MODVERSIONS). Nick Piggin is working on a patch to fix this. Plus, we are talking about functions like strcpy(), which rarely change prototypes. - Fixes for PPC fallout of the above by Stephen Rothwell and Nick Piggin - fixdep speedup by Alexey Dobriyan. - preparatory work by Nick Piggin to allow architectures to build with -ffunction-sections, -fdata-sections and --gc-sections - CONFIG_THIN_ARCHIVES support by Stephen Rothwell - fix for filenames with colons in the initramfs source by me. * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: (22 commits) initramfs: Escape colons in depfile ppc: there is no clear_pages to export powerpc/64: whitelist unresolved modversions CRCs kbuild: -ffunction-sections fix for archs with conflicting sections kbuild: add arch specific post-link Makefile kbuild: allow archs to select link dead code/data elimination kbuild: allow architectures to use thin archives instead of ld -r kbuild: Regenerate genksyms lexer kbuild: genksyms fix for typeof handling fixdep: faster CONFIG_ search ia64: move exports to definitions sparc32: debride memcpy.S a bit [sparc] unify 32bit and 64bit string.h sparc: move exports to definitions ppc: move exports to definitions arm: move exports to definitions s390: move exports to definitions m68k: move exports to definitions alpha: move exports to actual definitions x86: move exports to actual definitions ...
2016-10-14Merge tag 'docs-4.9-2' of git://git.lwn.net/linuxLinus Torvalds
Pull one more documentation update from Jonathan Corbet: "A single commit converting the mac80211 DocBook template over to Sphinx. Only 32 more to go..." * tag 'docs-4.9-2' of git://git.lwn.net/linux: docs-rst: sphinxify 802.11 documentation
2016-10-14Merge tag 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull more rdma updates from Doug Ledford: "This merge window was the first where Huawei had to try and coordinate their patches between their net driver and their new roce driver (similar to mlx4 and mlx5). They didn't do horribly, but there were some issues (and we knew that because they simply didn't know what to do in the beginning). As a result, I had a set of patches that depended on some patches that normally would have come to you via Dave's tree. Those patches have been on netdev@ for a while, so I got Dave to give me his approval to send them to you. As such, the other 29 patches I had behind them are also now ready to go. This catches the hns and hns-roce drivers up to current, and for future patches we are working with them to get them up to speed on how to do joint driver development so that they don't have these sorts of cross tree dependency issues again. BTW, Dave gave me permission to add his Acked-by: to the patches against the net tree, but I've had this branch through 0day (but not linux-next since it was off by itself) and I didn't want to rebase the series just to add Dave's ack for the 8 patches in the net area. Updates to the hns drivers: - Small patch set for hns net driver that the roce patches depend on - Various fixes to the hns-roce driver - Add connection manager support to the hns-roce driver" * tag 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (36 commits) IB/hns: Fix for removal of redundant code IB/hns: Delete the redundant lines in hns_roce_v1_m_qp() IB/hns: Fix the bug when platform_get_resource() exec fail IB/hns: Update the rq head when modify qp state IB/hns: Cq has not been freed IB/hns: Validate mtu when modified qp IB/hns: Some items of qpc need to take user param IB/hns: The Ack timeout need a lower limit value IB/hns: Return bad wr while post send failed IB/hns: Fix bug of memory leakage for registering user mr IB/hns: Modify the init of iboe lock IB/hns: Optimize code of aeq and ceq interrupt handle and fix the bug of qpn IB/hns: Delete the sqp_start from the structure hns_roce_caps IB/hns: Fix bug of clear hem IB/hns: Remove unused parameter named qp_type IB/hns: Simplify function of pd alloc and qp alloc IB/hns: Fix bug of using uninit refcount and free IB/hns: Remove parameters of resize cq IB/hns: Remove unused parameters in some functions IB/hns: Add node_guid definition to the bindings document ...
2016-10-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull some more input subsystem updates from Dmitry Torokhov: "An update to the ALPS driver to support the V8 protocol with touchstick, a change for i8042 to skip selftest on many Asus laptops which helps to keep their touchpads working after resume, and a couple other driver fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: i8042 - skip selftest on ASUS laptops Input: melfas_mip4 - add ic_name sysfs attribute Input: melfas_mip4 - add maintainer information Input: melfas_mip4 - add devicetree binding documentations Input: elantech - add Fujitsu Lifebook E556 to force crc_enabled Input: synaptics-rmi4 - fix error handling in I2C transport driver Input: synaptics-rmi4 - fix error handling in SPI transport driver Input: ALPS - add V8 protocol documentation Input: ALPS - set DualPoint flag for 74 03 28 devices Input: ALPS - allow touchsticks to report pressure Input: ALPS - handle 0-pressure 1F events Input: ALPS - add touchstick support for SS5 hardware Input: elantech - force needed quirks on Fujitsu H760 Input: elantech - fix Lenovo version typo
2016-10-14Merge tag 'rtc-4.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux Pull RTC updates from Alexandre Belloni: "RTC for 4.9 Subsystem: - delete owner assignment in multiple drivers - constify rtc_class_ops structures Drivers: - ac100: support clock-output-names - cmos: properly handle ACPI alarms and quirky BIOSes and other fixes - ds1307: fix century bit support while staying comaptible with previous behaviour by default - ds1347: switch to regmap - isl12057 is now handled by ds1307 - omap: support external wakeup - rv8803: allow to disable voltage drop detection" * tag 'rtc-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (25 commits) rtc: rv8803: set VDETOFF and SWOFF via device tree dt/bindings: Add bindings for Micro Crystal rv8803 devicetree: Add Micro Crystal AG vendor id rtc: cmos: avoid unused function warning rtc: ac100: Add NULL checking for devm_kzalloc call rtc: ds1347: changed raw spi calls to register map calls rtc: cmos: Restore alarm after resume rtc: cmos: Clear ACPI-driven alarms upon resume rtc: omap: Support ext_wakeup configuration rtc: cmos: Initialize hpet timer before irq is registered rtc: asm9260: rework locking rtc: asm9260: allow COMPILE_TEST rtc: constify rtc_class_ops structures rtc: ac100: support clock-output-names in device tree binding rtc: rx6110: remove owner assignment rtc: pic32: Delete owner assignment rtc: bq32k: Fix handling of oscillator failure flag rtc: bq32k: Use correct mask name for 'minutes' register. rtc: sysfs: fix a cast removing the const attribute Documentation: dt: Intersil isl12057 is not a trivial device ...
2016-10-14Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull more i2c updates from Wolfram Sang: "A small update pull request from I2C. This adds one comment to a change we did in this merge window to handle lockdep better, and pulls in a branch which should have been in 4.8 already improving DT support for I2C" * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: gpio: pca953x: add a comment explaining the need for a lockdep subclass i2c: core: Add support for 'i2c-bus' subnode dt-bindings: i2c: Add support for 'i2c-bus' subnode
2016-10-14Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull more SCSI updates from James Bottomley: "This is just a set of minor updates and fixes which weren't quite ready in time for the first pull request. The only real thing of note is Mike Christie is stepping down as Maintainer of iscsi to be replaced by Lee Duncan and Chris Leech" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: scsi: ufs: Kconfig fix scsi: g_NCR5380: Stop using scsi_module.c scsi: g_NCR5380: Reduce overrides[] from array to struct scsi: g_NCR5380: Remove deprecated __setup scsi: ufs: Fix error return code in ufshcd_init() scsi: ufs: Data Segment only needed for WRITE DESCRIPTOR scsi: cxgb4i: Set completion bit in work request MAINTAINERS: Update open-iscsi maintainers scsi: ufs: Enable no vccq quirk for skhynix device scsi: be2iscsi: mark symbols static where possible
2016-10-13Merge tag 'nfs-for-4.9-1' of git://git.linux-nfs.org/projects/anna/linux-nfsLinus Torvalds
Pull NFS client updates from Anna Schumaker: "Highlights include: Stable bugfixes: - sunrpc: fix writ espace race causing stalls - NFS: Fix inode corruption in nfs_prime_dcache() - NFSv4: Don't report revoked delegations as valid in nfs_have_delegation() - NFSv4: nfs4_copy_delegation_stateid() must fail if the delegation is invalid - NFSv4: Open state recovery must account for file permission changes - NFSv4.2: Fix a reference leak in nfs42_proc_layoutstats_generic Features: - Add support for tracking multiple layout types with an ordered list - Add support for using multiple backchannel threads on the client - Add support for pNFS file layout session trunking - Delay xprtrdma use of DMA API (for device driver removal) - Add support for xprtrdma remote invalidation - Add support for larger xprtrdma inline thresholds - Use a scatter/gather list for sending xprtrdma RPC calls - Add support for the CB_NOTIFY_LOCK callback - Improve hashing sunrpc auth_creds by using both uid and gid Bugfixes: - Fix xprtrdma use of DMA API - Validate filenames before adding to the dcache - Fix corruption of xdr->nwords in xdr_copy_to_scratch - Fix setting buffer length in xdr_set_next_buffer() - Don't deadlock the state manager on the SEQUENCE status flags - Various delegation and stateid related fixes - Retry operations if an interrupted slot receives EREMOTEIO - Make nfs boot time y2038 safe" * tag 'nfs-for-4.9-1' of git://git.linux-nfs.org/projects/anna/linux-nfs: (100 commits) NFSv4.2: Fix a reference leak in nfs42_proc_layoutstats_generic fs: nfs: Make nfs boot time y2038 safe sunrpc: replace generic auth_cred hash with auth-specific function sunrpc: add RPCSEC_GSS hash_cred() function sunrpc: add auth_unix hash_cred() function sunrpc: add generic_auth hash_cred() function sunrpc: add hash_cred() function to rpc_authops struct Retry operation on EREMOTEIO on an interrupted slot pNFS: Fix atime updates on pNFS clients sunrpc: queue work on system_power_efficient_wq NFSv4.1: Even if the stateid is OK, we may need to recover the open modes NFSv4: If recovery failed for a specific open stateid, then don't retry NFSv4: Fix retry issues with nfs41_test/free_stateid NFSv4: Open state recovery must account for file permission changes NFSv4: Mark the lock and open stateids as invalid after freeing them NFSv4: Don't test open_stateid unless it is set NFSv4: nfs4_do_handle_exception() handle revoke/expiry of a single stateid NFS: Always call nfs_inode_find_state_and_recover() when revoking a delegation NFSv4: Fix a race when updating an open_stateid NFSv4: Fix a race in nfs_inode_reclaim_delegation() ...
2016-10-13Merge branch 'next' into for-linusDmitry Torokhov
Prepare second round of input updates for 4.9 merge window.
2016-10-13Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: - a new watchdog pretimeout governor framework - support to upload the firmware on the ziirave_wdt - several fixes and cleanups * git://www.linux-watchdog.org/linux-watchdog: (26 commits) watchdog: imx2_wdt: add pretimeout function support watchdog: softdog: implement pretimeout support watchdog: pretimeout: add pretimeout_available_governors attribute watchdog: pretimeout: add option to select a pretimeout governor in runtime watchdog: pretimeout: add panic pretimeout governor watchdog: pretimeout: add noop pretimeout governor watchdog: add watchdog pretimeout governor framework watchdog: hpwdt: add support for iLO5 fs: compat_ioctl: add pretimeout functions for watchdogs watchdog: add pretimeout support to the core watchdog: imx2_wdt: use preferred BIT macro instead of open coded values watchdog: st_wdt: Remove support for obsolete platforms watchdog: bindings: Remove obsolete platforms from dt doc. watchdog: mt7621_wdt: Remove assignment of dev pointer watchdog: rt2880_wdt: Remove assignment of dev pointer watchdog: constify watchdog_ops structures watchdog: tegra: constify watchdog_ops structures watchdog: iTCO_wdt: constify iTCO_wdt_pm structure watchdog: cadence_wdt: Fix the suspend resume watchdog: txx9wdt: Add missing clock (un)prepare calls for CCF ...
2016-10-13Documentation: MIPS supports HAVE_REGS_AND_STACK_ACCESS_APIRalf Baechle
This should have been part of 40e084a506eb ('MIPS: Add uprobes support.'). Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Fixes: 40e084a506eb ("MIPS: Add uprobes support.") Acked-by: Jonathan Corbet <corbet@lwn.net> Cc: linux-mips@linux-mips.org Cc: linux-doc@vger.kernel.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14392/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-10-12Merge tag 'pwm/for-4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm Pull pwm updates from Thierry Reding: "This set of changes contains support for PWM signal capture in the STi driver as well as support for the PWM controller found on Meson SoCs. There's also support added for the MediaTek MT2701 and SunXi H3 to the existing drivers. Other than that there's a fair set of miscellaneous cleanups and fixes across the board" * tag 'pwm/for-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: (24 commits) pwm: meson: Handle unknown ID values pwm: sti: Take the opportunity to conduct a little house keeping pwm: sti: It's now valid for number of PWM channels to be zero pwm: sti: Add PWM capture callback pwm: sti: Add support for PWM capture interrupts pwm: sti: Initialise PWM capture device data pwm: sti: Supply PWM Capture clock handling pwm: sti: Supply PWM capture register addresses and bit locations pwm: sti: Only request clock rate when needed pwm: sti: Reorganise register names in preparation for new functionality pwm: sti: Rename channel => device dt-bindings: pwm: sti: Update DT bindings for capture support pwm: lpc-18xx: use pwm_set_chip_data pwm: sunxi: Add H3 support pwm: Add support for Meson PWM Controller dt-bindings: pwm: Add bindings for Meson PWM Controller pwm: samsung: Fix to use lowest div for large enough modulation bits pwm: pwm-tipwmss: Remove all runtime PM gets/puts pwm: cros-ec: Add __packed to prevent padding pwm: Add MediaTek MT2701 display PWM driver support ...
2016-10-12Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal managament updates from Zhang Rui: - Enhance thermal "userspace" governor to export the reason when a thermal event is triggered and delivered to user space. From Srinivas Pandruvada - Introduce a single TSENS thermal driver for the different versions of the TSENS IP that exist, on different qcom msm/apq SoCs'. Support for msm8916, msm8960, msm8974 and msm8996 families is also added. From Rajendra Nayak - Introduce hardware-tracked trip points support to the device tree thermal sensor framework. The framework supports an arbitrary number of trip points. Whenever the current temperature is changed, the trip points immediately below and above the current temperature are found, driver callback is invoked to program the hardware to get notified when either of the two trip points are triggered. Hardware-tracked trip points support for rockchip thermal driver is also added at the same time. From Sascha Hauer, Caesar Wang - Introduce a new thermal driver, which enables TMU (Thermal Monitor Unit) on QorIQ platform. From Jia Hongtao - Introduce a new thermal driver for Maxim MAX77620. From Laxman Dewangan - Introduce a new thermal driver for Intel platforms using WhiskeyCove PMIC. From Bin Gao - Add mt2701 chip support to MTK thermal driver. From Dawei Chien - Enhance Tegra thermal driver to enable soctherm node and set "critical", "hot" trips, for Tegra124, Tegra132, Tegra210. From Wei Ni - Add resume support for tango thermal driver. From Marc Gonzalez - several small fixes and improvements for rockchip, qcom, imx, rcar, mtk thermal drivers and thermal core code. From Caesar Wang, Keerthy, Rocky Hao, Wei Yongjun, Peter Robinson, Bui Duc Phuc, Axel Lin, Hugh Kang * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (48 commits) thermal: int3403: Process trip change notification thermal: int340x: New Interface to read trip and notify thermal: user_space gov: Add additional information in uevent thermal: Enhance thermal_zone_device_update for events arm64: tegra: set hot trips for Tegra210 arm64: tegra: set critical trips for Tegra210 arm64: tegra: add soctherm node for Tegra210 arm64: tegra: set hot trips for Tegra132 arm64: tegra: set critical trips for Tegra132 arm64: tegra: use tegra132-soctherm for Tegra132 arm: tegra: set hot trips for Tegra124 arm: tegra: set critical trips for Tegra124 thermal: tegra: add hw-throttle for Tegra132 thermal: tegra: add hw-throttle function of: Add bindings of hw throttle for Tegra soctherm thermal: mtk_thermal: Check return value of devm_thermal_zone_of_sensor_register thermal: Add Mediatek thermal driver for mt2701. dt-bindings: thermal: Add binding document for Mediatek thermal controller thermal: max77620: Add thermal driver for reporting junction temp thermal: max77620: Add DT binding doc for thermal driver ...
2016-10-12dt/bindings: Add bindings for Micro Crystal rv8803Oleksij Rempel
... and Epson RX8900 real time clock Signed-off-by: Oleksij Rempel <fixed-term.Oleksij.Rempel@de.bosch.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-10-12devicetree: Add Micro Crystal AG vendor idOleksij Rempel
Add Micro Crystal AG vendor id Signed-off-by: Oleksij Rempel <fixed-term.Oleksij.Rempel@de.bosch.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-10-11Merge branch 'work.uaccess2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull uaccess.h prepwork from Al Viro: "Preparations to tree-wide switch to use of linux/uaccess.h (which, obviously, will allow to start unifying stuff for real). The last step there, ie PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ `git grep -l "$PATT"|grep -v ^include/linux/uaccess.h` is not taken here - I would prefer to do it once just before or just after -rc1. However, everything should be ready for it" * 'work.uaccess2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: remove a stray reference to asm/uaccess.h in docs sparc64: separate extable_64.h, switch elf_64.h to it score: separate extable.h, switch module.h to it mips: separate extable.h, switch module.h to it x86: separate extable.h, switch sections.h to it remove stray include of asm/uaccess.h from cacheflush.h mn10300: remove a bogus processor.h->uaccess.h include xtensa: split uaccess.h into C and asm sides bonding: quit messing with IOCTL kill __kernel_ds_p off mn10300: finish verify_area() off frv: move HAVE_ARCH_UNMAPPED_AREA to pgtable.h exceptions: detritus removal
2016-10-11Merge tag 'drm-for-v4.9' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "Core: - Fence destaging work - DRIVER_LEGACY to split off legacy drm drivers - drm_mm refactoring - Splitting drm_crtc.c into chunks and documenting better - Display info fixes - rbtree support for prime buffer lookup - Simple VGA DAC driver Panel: - Add Nexus 7 panel - More simple panels i915: - Refactoring GEM naming - Refactored vma/active tracking - Lockless request lookups - Better stolen memory support - FBC fixes - SKL watermark fixes - VGPU improvements - dma-buf fencing support - Better DP dongle support amdgpu: - Powerplay for Iceland asics - Improved GPU reset support - UVD/VEC powergating support for CZ/ST - Preinitialised VRAM buffer support - Virtual display support - Initial SI support - GTT rework - PCI shutdown callback support - HPD IRQ storm fixes amdkfd: - bugfixes tilcdc: - Atomic modesetting support mediatek: - AAL + GAMMA engine support - Hook up gamma LUT - Temporal dithering support imx: - Pixel clock from devicetree - drm bridge support for LVDS bridges - active plane reconfiguration - VDIC deinterlacer support - Frame synchronisation unit support - Color space conversion support analogix: - PSR support - Better panel on/off support rockchip: - rk3399 vop/crtc support - PSR support vc4: - Interlaced vblank timing - 3D rendering CPU overhead reduction - HDMI output fixes tda998x: - HDMI audio ASoC support sunxi: - Allwinner A33 support - better TCON support msm: - DT binding cleanups - Explicit fence-fd support sti: - remove sti415/416 support etnaviv: - MMUv2 refactoring - GC3000 support exynos: - Refactoring HDMI DCC/PHY - G2D pm regression fix - Page fault issues with wait for vblank There is no nouveau work in this tree, as Ben didn't get a pull request in, and he was fighting moving to atomic and adding mst support, so maybe best it waits for a cycle" * tag 'drm-for-v4.9' of git://people.freedesktop.org/~airlied/linux: (1412 commits) drm/crtc: constify drm_crtc_index parameter drm/i915: Fix conflict resolution from backmerge of v4.8-rc8 to drm-next drm/i915/guc: Unwind GuC workqueue reservation if request construction fails drm/i915: Reset the breadcrumbs IRQ more carefully drm/i915: Force relocations via cpu if we run out of idle aperture drm/i915: Distinguish last emitted request from last submitted request drm/i915: Allow DP to work w/o EDID drm/i915: Move long hpd handling into the hotplug work drm/i915/execlists: Reinitialise context image after GPU hang drm/i915: Use correct index for backtracking HUNG semaphores drm/i915: Unalias obj->phys_handle and obj->userptr drm/i915: Just clear the mmiodebug before a register access drm/i915/gen9: only add the planes actually affected by ddb changes drm/i915: Allow PCH DPLL sharing regardless of DPLL_SDVO_HIGH_SPEED drm/i915/bxt: Fix HDMI DPLL configuration drm/i915/gen9: fix the watermark res_blocks value drm/i915/gen9: fix plane_blocks_per_line on watermarks calculations drm/i915/gen9: minimum scanlines for Y tile is not always 4 drm/i915/gen9: fix the WaWmMemoryReadLatency implementation drm/i915/kbl: KBL also needs to run the SAGV code ...
2016-10-11Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge more updates from Andrew Morton: - a few block updates that fell in my lap - lib/ updates - checkpatch - autofs - ipc - a ton of misc other things * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (100 commits) mm: split gfp_mask and mapping flags into separate fields fs: use mapping_set_error instead of opencoded set_bit treewide: remove redundant #include <linux/kconfig.h> hung_task: allow hung_task_panic when hung_task_warnings is 0 kthread: add kerneldoc for kthread_create() kthread: better support freezable kthread workers kthread: allow to modify delayed kthread work kthread: allow to cancel kthread work kthread: initial support for delayed kthread work kthread: detect when a kthread work is used by more workers kthread: add kthread_destroy_worker() kthread: add kthread_create_worker*() kthread: allow to call __kthread_create_on_node() with va_list args kthread/smpboot: do not park in kthread_create_on_cpu() kthread: kthread worker API cleanup kthread: rename probe_kthread_data() to kthread_probe_data() scripts/tags.sh: enable code completion in VIM mm: kmemleak: avoid using __va() on addresses that don't have a lowmem mapping kdump, vmcoreinfo: report memory sections virtual addresses ipc/sem.c: add cond_resched in exit_sme ...
2016-10-11Input: i8042 - skip selftest on ASUS laptopsMarcos Paulo de Souza
On suspend/resume cycle, selftest is executed to reset i8042 controller. But when this is done in Asus devices, subsequent calls to detect/init functions to elantech driver fails. Skipping selftest fixes this problem. An easier step to reproduce this problem is adding i8042.reset=1 as a kernel parameter. On Asus laptops, it'll make the system to start with the touchpad already stuck, since psmouse_probe forcibly calls the selftest function. This patch was inspired by John Hiesey's change[1], but, since this problem affects a lot of models of Asus, let's avoid running selftests on them. All models affected by this problem: A455LD K401LB K501LB K501LX R409L V502LX X302LA X450LCP X450LD X455LAB X455LDB X455LF Z450LA [1]: https://marc.info/?l=linux-input&m=144312209020616&w=2 Fixes: "ETPS/2 Elantech Touchpad dies after resume from suspend" (https://bugzilla.kernel.org/show_bug.cgi?id=107971) Signed-off-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2016-10-11docs-rst: sphinxify 802.11 documentationJohannes Berg
This is just a very basic conversion, I've split up the original multi-book template, and also split up the multi-part mac80211 part in the original book; neither of those were handled by the automatic pandoc conversion. Fix errors that showed up, resulting in a much nicer rendering, at least for the interface combinations documentation. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-10-11kthread: kthread worker API cleanupPetr Mladek
A good practice is to prefix the names of functions by the name of the subsystem. The kthread worker API is a mix of classic kthreads and workqueues. Each worker has a dedicated kthread. It runs a generic function that process queued works. It is implemented as part of the kthread subsystem. This patch renames the existing kthread worker API to use the corresponding name from the workqueues API prefixed by kthread_: __init_kthread_worker() -> __kthread_init_worker() init_kthread_worker() -> kthread_init_worker() init_kthread_work() -> kthread_init_work() insert_kthread_work() -> kthread_insert_work() queue_kthread_work() -> kthread_queue_work() flush_kthread_work() -> kthread_flush_work() flush_kthread_worker() -> kthread_flush_worker() Note that the names of DEFINE_KTHREAD_WORK*() macros stay as they are. It is common that the "DEFINE_" prefix has precedence over the subsystem names. Note that INIT() macros and init() functions use different naming scheme. There is no good solution. There are several reasons for this solution: + "init" in the function names stands for the verb "initialize" aka "initialize worker". While "INIT" in the macro names stands for the noun "INITIALIZER" aka "worker initializer". + INIT() macros are used only in DEFINE() macros + init() functions are used close to the other kthread() functions. It looks much better if all the functions use the same scheme. + There will be also kthread_destroy_worker() that will be used close to kthread_cancel_work(). It is related to the init() function. Again it looks better if all functions use the same naming scheme. + there are several precedents for such init() function names, e.g. amd_iommu_init_device(), free_area_init_node(), jump_label_init_type(), regmap_init_mmio_clk(), + It is not an argument but it was inconsistent even before. [arnd@arndb.de: fix linux-next merge conflict] Link: http://lkml.kernel.org/r/20160908135724.1311726-1-arnd@arndb.de Link: http://lkml.kernel.org/r/1470754545-17632-3-git-send-email-pmladek@suse.com Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Petr Mladek <pmladek@suse.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Borislav Petkov <bp@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11mm: kmemleak: avoid using __va() on addresses that don't have a lowmem mappingCatalin Marinas
Some of the kmemleak_*() callbacks in memblock, bootmem, CMA convert a physical address to a virtual one using __va(). However, such physical addresses may sometimes be located in highmem and using __va() is incorrect, leading to inconsistent object tracking in kmemleak. The following functions have been added to the kmemleak API and they take a physical address as the object pointer. They only perform the corresponding action if the address has a lowmem mapping: kmemleak_alloc_phys kmemleak_free_part_phys kmemleak_not_leak_phys kmemleak_ignore_phys The affected calling places have been updated to use the new kmemleak API. Link: http://lkml.kernel.org/r/1471531432-16503-1-git-send-email-catalin.marinas@arm.com Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Reported-by: Vignesh R <vigneshr@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11dma-mapping: introduce the DMA_ATTR_NO_WARN attributeMauricio Faria de Oliveira
Introduce the DMA_ATTR_NO_WARN attribute, and document it. Link: http://lkml.kernel.org/r/1470092390-25451-2-git-send-email-mauricfo@linux.vnet.ibm.com Signed-off-by: Mauricio Faria de Oliveira <mauricfo@linux.vnet.ibm.com> Cc: Keith Busch <keith.busch@intel.com> Cc: Jens Axboe <axboe@fb.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11autofs: update struct autofs_dev_ioctl in DocumentationTomohiro Kusumi
Sync with changes made by commit 730c9eeca980 ("autofs4: improve parameter usage") which introduced an union for various ioctl commands instead of having statically named arg1,2. This commit simply replaces arg1,2 with the corresponding fields without changing semantics. Link: http://lkml.kernel.org/r/20160812024831.12352.24667.stgit@pluto.themaw.net Signed-off-by: Tomohiro Kusumi <kusumi.tomohiro@gmail.com> Signed-off-by: Ian Kent <ikent@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11autofs: fix Documentation regarding devid on ioctlTomohiro Kusumi
The explanation on how ioctl handles devid seems incorrect. Userspace who calls this ioctl has no input regarding devid, and ioctl implementation retrieves devid via superblock. Link: http://lkml.kernel.org/r/20160812024825.12352.13486.stgit@pluto.themaw.net Signed-off-by: Tomohiro Kusumi <kusumi.tomohiro@gmail.com> Signed-off-by: Ian Kent <ikent@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11autofs: fix typos in Documentation/filesystems/autofs4.txtTomohiro Kusumi
plus minor whitespace fixes. Link: http://lkml.kernel.org/r/20160812024734.12352.17122.stgit@pluto.themaw.net Signed-off-by: Tomohiro Kusumi <kusumi.tomohiro@gmail.com> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11lib/bitmap.c: enhance bitmap syntaxNoam Camus
Today there are platforms with many CPUs (up to 4K). Trying to boot only part of the CPUs may result in too long string. For example lets take NPS platform that is part of arch/arc. This platform have SMP system with 256 cores each with 16 HW threads (SMT machine) where HW thread appears as CPU to the kernel. In this example there is total of 4K CPUs. When one tries to boot only part of the HW threads from each core the string representing the map may be long... For example if for sake of performance we decided to boot only first half of HW threads of each core the map will look like: 0-7,16-23,32-39,...,4080-4087 This patch introduce new syntax to accommodate with such use case. I added an optional postfix to a range of CPUs which will choose according to given modulo the desired range of reminders i.e.: <cpus range>:sed_size/group_size For example, above map can be described in new syntax like this: 0-4095:8/16 Note that this patch is backward compatible with current syntax. [akpm@linux-foundation.org: rework documentation] Link: http://lkml.kernel.org/r/1473579629-4283-1-git-send-email-noamca@mellanox.com Signed-off-by: Noam Camus <noamca@mellanox.com> Cc: David Decotigny <decot@googlers.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: David S. Miller <davem@davemloft.net> Cc: Pan Xinhui <xinhui@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11Merge tag 'tegra-for-4.8-i2c' of ↵Wolfram Sang
git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into i2c/for-next [wsa: fell through the cracks, applied to 4.9 now] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> i2c: 'i2c-bus' node support for v4.8-rc1 This includes the device tree binding and I2C core changes to support the i2c-bus subnode that I2C masters can use to describe their slaves in a separate namespace and therefore avoid clashing with potentially other subnodes.
2016-10-11Merge tag 'media/v4.9-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - Documentation improvements: conversion of all non-DocBook documents to Sphinx and lots of fixes to the uAPI media book - New PCI driver for Techwell TW5864 media grabber boards - New SoC driver for ATMEL Image Sensor Controller - Removal of some obsolete SoC drivers (s5p-tv driver and soc_camera drivers) - Addition of ST CEC driver - Lots of drivers fixes, improvements and additions * tag 'media/v4.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (464 commits) [media] ttusb_dec: avoid the risk of go past buffer [media] cx23885: Fix some smatch warnings [media] si2165: switch to regmap [media] si2165: use i2c_client->dev instead of i2c_adapter->dev for logging [media] si2165: Remove legacy attach [media] cx231xx: attach si2165 driver via i2c_client [media] cx231xx: Prepare for attaching new style i2c_client DVB demod drivers [media] cx23885: attach si2165 driver via i2c_client [media] si2165: support i2c_client attach [media] si2165: avoid division by zero [media] rcar-vin: add R-Car gen2 fallback compatibility string [media] lgdt3306a: remove 20*50 msec unnecessary timeout [media] cx25821: Remove deprecated create_singlethread_workqueue [media] cx25821: Drop Freeing of Workqueue [media] cxd2841er: force 8MHz bandwidth for DVB-C if specified bw not supported [media] redrat3: hardware-specific parameters [media] redrat3: remove hw_timeout member [media] cxd2841er: BER and SNR reading for ISDB-T [media] dvb-usb: avoid link error with dib3000m{b,c| [media] dvb-usb: split out common parts of dibusb ...
2016-10-11Merge tag 'iommu-updates-v4.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: - support for interrupt virtualization in the AMD IOMMU driver. These patches were shared with the KVM tree and are already merged through that tree. - generic DT-binding support for the ARM-SMMU driver. With this the driver now makes use of the generic DMA-API code. This also required some changes outside of the IOMMU code, but these are acked by the respective maintainers. - more cleanups and fixes all over the place. * tag 'iommu-updates-v4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (40 commits) iommu/amd: No need to wait iommu completion if no dte irq entry change iommu/amd: Free domain id when free a domain of struct dma_ops_domain iommu/amd: Use standard bitmap operation to set bitmap iommu/amd: Clean up the cmpxchg64 invocation iommu/io-pgtable-arm: Check for v7s-incapable systems iommu/dma: Avoid PCI host bridge windows iommu/dma: Add support for mapping MSIs iommu/arm-smmu: Set domain geometry iommu/arm-smmu: Wire up generic configuration support Docs: dt: document ARM SMMU generic binding usage iommu/arm-smmu: Convert to iommu_fwspec iommu/arm-smmu: Intelligent SMR allocation iommu/arm-smmu: Add a stream map entry iterator iommu/arm-smmu: Streamline SMMU data lookups iommu/arm-smmu: Refactor mmu-masters handling iommu/arm-smmu: Keep track of S2CR state iommu/arm-smmu: Consolidate stream map entry state iommu/arm-smmu: Handle stream IDs more dynamically iommu/arm-smmu: Set PRIVCFG in stage 1 STEs iommu/arm-smmu: Support non-PCI devices with SMMUv3 ...
2016-10-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Netfilter list handling fix, from Linus. 2) RXRPC/AFS bug fixes from David Howells (oops on call to serviceless endpoints, build warnings, missing notifications, etc.) From David Howells. 3) Kernel log message missing newlines, from Colin Ian King. 4) Don't enter direct reclaim in netlink dumps, the idea is to use a high order allocation first and fallback quickly to a 0-order allocation if such a high-order one cannot be done cheaply and without reclaim. From Eric Dumazet. 5) Fix firmware download errors in btusb bluetooth driver, from Ethan Hsieh. 6) Missing Kconfig deps for QCOM_EMAC, from Geert Uytterhoeven. 7) Fix MDIO_XGENE dup Kconfig entry. From Laura Abbott. 8) Constrain ipv6 rtr_solicits sysctl values properly, from Maciej Żenczykowski. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (65 commits) netfilter: Fix slab corruption. be2net: Enable VF link state setting for BE3 be2net: Fix TX stats for TSO packets be2net: Update Copyright string in be_hw.h be2net: NCSI FW section should be properly updated with ethtool for BE3 be2net: Provide an alternate way to read pf_num for BEx chips wan/fsl_ucc_hdlc: Fix size used in dma_free_coherent() net: macb: NULL out phydev after removing mdio bus xen-netback: make sure that hashes are not send to unaware frontends Fixing a bug in team driver due to incorrect 'unsigned int' to 'int' conversion MAINTAINERS: add myself as a maintainer of xen-netback ipv6 addrconf: disallow rtr_solicits < -1 Bluetooth: btusb: Fix atheros firmware download error drivers: net: phy: Correct duplicate MDIO_XGENE entry ethernet: qualcomm: QCOM_EMAC should depend on HAS_DMA and HAS_IOMEM net: ethernet: mediatek: remove hwlro property in the device tree net: ethernet: mediatek: get hw lro capability by the chip id instead of by the dtsi net: ethernet: mediatek: get the chip id by ETHDMASYS registers net: bgmac: Fix errant feature flag check netlink: do not enter direct reclaim from netlink_dump() ...
2016-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: ">rename2() work from Miklos + current_time() from Deepa" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fs: Replace current_fs_time() with current_time() fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps fs: Replace CURRENT_TIME with current_time() for inode timestamps fs: proc: Delete inode time initializations in proc_alloc_inode() vfs: Add current_time() api vfs: add note about i_op->rename changes to porting fs: rename "rename2" i_op to "rename" vfs: remove unused i_op->rename fs: make remaining filesystems use .rename2 libfs: support RENAME_NOREPLACE in simple_rename() fs: support RENAME_NOREPLACE for local filesystems ncpfs: fix unused variable warning
2016-10-10Merge tag 'for-linus-20161008' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD updates from Brian Norris: "I've not been very active this cycle, so these are mostly from Boris, for the NAND flash subsystem. NAND: - Add the infrastructure to automate NAND timings configuration - Provide a generic DT property to maximize ECC strength - Some refactoring in the core bad block table handling, to help with improving some of the logic in error cases. - Minor cleanups and fixes MTD: - Add APIs for handling page pairing; this is necessary for reliably supporting MLC and TLC NAND flash, where paired-page disturbance affects reliability. Upper layers (e.g., UBI) should make use of these in the near future" * tag 'for-linus-20161008' of git://git.infradead.org/linux-mtd: (35 commits) mtd: nand: fix trivial spelling error mtdpart: Propagate _get/put_device() mtd: nand: Provide nand_cleanup() function to free NAND related resources mtd: Kill the OF_MTD Kconfig option mtd: nand: mxc: Test CONFIG_OF instead of CONFIG_OF_MTD mtd: nand: Fix nand_command_lp() for 8bits opcodes mtd: nand: sunxi: Support ECC maximization mtd: nand: Support maximizing ECC when using software BCH mtd: nand: Add an option to maximize the ECC strength mtd: nand: mxc: Add timing setup for v2 controllers mtd: nand: mxc: implement onfi get/set features mtd: nand: sunxi: switch from manual to automated timing config mtd: nand: automate NAND timings selection mtd: nand: Expose data interface for ONFI mode 0 mtd: nand: Add function to convert ONFI mode to data_interface mtd: nand: convert ONFI mode into data interface mtd: nand: Introduce nand_data_interface mtd: nand: Create a NAND reset function mtd: nand: remove unnecessary 'extern' from function declarations MAINTAINERS: Add maintainer entry for Ingenic JZ4780 NAND driver ...
2016-10-10Merge branch 'work.xattr' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs xattr updates from Al Viro: "xattr stuff from Andreas This completes the switch to xattr_handler ->get()/->set() from ->getxattr/->setxattr/->removexattr" * 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: vfs: Remove {get,set,remove}xattr inode operations xattr: Stop calling {get,set,remove}xattr inode operations vfs: Check for the IOP_XATTR flag in listxattr xattr: Add __vfs_{get,set,remove}xattr helpers libfs: Use IOP_XATTR flag for empty directory handling vfs: Use IOP_XATTR flag for bad-inode handling vfs: Add IOP_XATTR inode operations flag vfs: Move xattr_resolve_name to the front of fs/xattr.c ecryptfs: Switch to generic xattr handlers sockfs: Get rid of getxattr iop sockfs: getxattr: Fail with -EOPNOTSUPP for invalid attribute names kernfs: Switch to generic xattr handlers hfs: Switch to generic xattr handlers jffs2: Remove jffs2_{get,set,remove}xattr macros xattr: Remove unnecessary NULL attribute name check
2016-10-10Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto updates from Herbert Xu: "Here is the crypto update for 4.9: API: - The crypto engine code now supports hashes. Algorithms: - Allow keys >= 2048 bits in FIPS mode for RSA. Drivers: - Memory overwrite fix for vmx ghash. - Add support for building ARM sha1-neon in Thumb2 mode. - Reenable ARM ghash-ce code by adding import/export. - Reenable img-hash by adding import/export. - Add support for multiple cores in omap-aes. - Add little-endian support for sha1-powerpc. - Add Cavium HWRNG driver for ThunderX SoC" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (137 commits) crypto: caam - treat SGT address pointer as u64 crypto: ccp - Make syslog errors human-readable crypto: ccp - clean up data structure crypto: vmx - Ensure ghash-generic is enabled crypto: testmgr - add guard to dst buffer for ahash_export crypto: caam - Unmap region obtained by of_iomap crypto: sha1-powerpc - little-endian support crypto: gcm - Fix IV buffer size in crypto_gcm_setkey crypto: vmx - Fix memory corruption caused by p8_ghash crypto: ghash-generic - move common definitions to a new header file crypto: caam - fix sg dump hwrng: omap - Only fail if pm_runtime_get_sync returns < 0 crypto: omap-sham - shrink the internal buffer size crypto: omap-sham - add support for export/import crypto: omap-sham - convert driver logic to use sgs for data xmit crypto: omap-sham - change the DMA threshold value to a define crypto: omap-sham - add support functions for sg based data handling crypto: omap-sham - rename sgl to sgl_tmp for deprecation crypto: omap-sham - align algorithms on word offset crypto: omap-sham - add context export/import stubs ...
2016-10-10Merge tag 'ceph-for-4.9-rc1' of git://github.com/ceph/ceph-clientLinus Torvalds
Pull Ceph updates from Ilya Dryomov: "The big ticket item here is support for rbd exclusive-lock feature, with maintenance operations offloaded to userspace (Douglas Fuller, Mike Christie and myself). Another block device bullet is a series fixing up layering error paths (myself). On the filesystem side, we've got patches that improve our handling of buffered vs dio write races (Neil Brown) and a few assorted fixes from Zheng. Also included a couple of random cleanups and a minor CRUSH update" * tag 'ceph-for-4.9-rc1' of git://github.com/ceph/ceph-client: (39 commits) crush: remove redundant local variable crush: don't normalize input of crush_ln iteratively libceph: ceph_build_auth() doesn't need ceph_auth_build_hello() libceph: use CEPH_AUTH_UNKNOWN in ceph_auth_build_hello() ceph: fix description for rsize and rasize mount options rbd: use kmalloc_array() in rbd_header_from_disk() ceph: use list_move instead of list_del/list_add ceph: handle CEPH_SESSION_REJECT message ceph: avoid accessing / when mounting a subpath ceph: fix mandatory flock check ceph: remove warning when ceph_releasepage() is called on dirty page ceph: ignore error from invalidate_inode_pages2_range() in direct write ceph: fix error handling of start_read() rbd: add rbd_obj_request_error() helper rbd: img_data requests don't own their page array rbd: don't call rbd_osd_req_format_read() for !img_data requests rbd: rework rbd_img_obj_exists_submit() error paths rbd: don't crash or leak on errors in rbd_img_obj_parent_read_full_callback() rbd: move bumping img_request refcount into rbd_obj_request_submit() rbd: mark the original request as done if stat request fails ...
2016-10-10Merge branch 'work.misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc vfs updates from Al Viro: "Assorted misc bits and pieces. There are several single-topic branches left after this (rename2 series from Miklos, current_time series from Deepa Dinamani, xattr series from Andreas, uaccess stuff from from me) and I'd prefer to send those separately" * 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (39 commits) proc: switch auxv to use of __mem_open() hpfs: support FIEMAP cifs: get rid of unused arguments of CIFSSMBWrite() posix_acl: uapi header split posix_acl: xattr representation cleanups fs/aio.c: eliminate redundant loads in put_aio_ring_file fs/internal.h: add const to ns_dentry_operations declaration compat: remove compat_printk() fs/buffer.c: make __getblk_slow() static proc: unsigned file descriptors fs/file: more unsigned file descriptors fs: compat: remove redundant check of nr_segs cachefiles: Fix attempt to read i_blocks after deleting file [ver #2] cifs: don't use memcpy() to copy struct iov_iter get rid of separate multipage fault-in primitives fs: Avoid premature clearing of capabilities fs: Give dentry to inode_change_ok() instead of inode fuse: Propagate dentry down to inode_change_ok() ceph: Propagate dentry down to inode_change_ok() xfs: Propagate dentry down to inode_change_ok() ...
2016-10-10Merge branch 'mm-pkeys-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull protection keys syscall interface from Thomas Gleixner: "This is the final step of Protection Keys support which adds the syscalls so user space can actually allocate keys and protect memory areas with them. Details and usage examples can be found in the documentation. The mm side of this has been acked by Mel" * 'mm-pkeys-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/pkeys: Update documentation x86/mm/pkeys: Do not skip PKRU register if debug registers are not used x86/pkeys: Fix pkeys build breakage for some non-x86 arches x86/pkeys: Add self-tests x86/pkeys: Allow configuration of init_pkru x86/pkeys: Default to a restrictive init PKRU pkeys: Add details of system call use to Documentation/ generic syscalls: Wire up memory protection keys syscalls x86: Wire up protection keys system calls x86/pkeys: Allocation/free syscalls x86/pkeys: Make mprotect_key() mask off additional vm_flags mm: Implement new pkey_mprotect() system call x86/pkeys: Add fault handling for PF_PK page fault bit
2016-10-10Doc: update 00-INDEX files to reflect the runnable code moveShuah Khan
Update 00-INDEX files with the current file list to reflect the runnable code move. Acked-by: Michal Marek <mmarek@suse.com> Acked-by: Jonathan Corbet <corbet@lwn.net> Reviewed-by: Kees Cook <keescook@chromium.org> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2016-10-10samples: move blackfin gptimers-example from DocumentationShuah Khan
Move blackfin gptimers-example to samples and remove it from Documentation Makefile. Update samples Kconfig and Makefile to build gptimers-example. blackfin is the last CONFIG_BUILD_DOCSRC target in Documentation/Makefile. Hence this patch also includes changes to remove CONFIG_BUILD_DOCSRC from Makefile and lib/Kconfig.debug and updates VIDEO_PCI_SKELETON dependency on BUILD_DOCSRC. Documentation/Makefile is not deleted to avoid braking make htmldocs and make distclean. Acked-by: Michal Marek <mmarek@suse.com> Acked-by: Jonathan Corbet <corbet@lwn.net> Reviewed-by: Kees Cook <keescook@chromium.org> Reported-by: Valentin Rothberg <valentinrothberg@gmail.com> Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2016-10-10drm/bridge: Add RGB to VGA bridge supportMaxime Ripard
Some boards have an entirely passive RGB to VGA bridge, based on DACs implemented by resistor ladders. Those might or might not have an i2c bus routed to the VGA connector in order to access the screen EDIDs. Add a bridge that doesn't do anything but expose the modes available on the screen, either based on the EDIDs if available, or based on the XGA standards. Acked-by: Rob Herring <robh@kernel.org> Reviewed-by: Sean Paul <seanpaul@chromium.org> Tested-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Archit Taneja <architt@codeaurora.org> Link: http://patchwork.freedesktop.org/patch/msgid/20160930143709.1388-3-maxime.ripard@free-electrons.com
2016-10-09Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull main rdma updates from Doug Ledford: "This is the main pull request for the rdma stack this release. The code has been through 0day and I had it tagged for linux-next testing for a couple days. Summary: - updates to mlx5 - updates to mlx4 (two conflicts, both minor and easily resolved) - updates to iw_cxgb4 (one conflict, not so obvious to resolve, proper resolution is to keep the code in cxgb4_main.c as it is in Linus' tree as attach_uld was refactored and moved into cxgb4_uld.c) - improvements to uAPI (moved vendor specific API elements to uAPI area) - add hns-roce driver and hns and hns-roce ACPI reset support - conversion of all rdma code away from deprecated create_singlethread_workqueue - security improvement: remove unsafe ib_get_dma_mr (breaks lustre in staging)" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (75 commits) staging/lustre: Disable InfiniBand support iw_cxgb4: add fast-path for small REG_MR operations cxgb4: advertise support for FR_NSMR_TPTE_WR IB/core: correctly handle rdma_rw_init_mrs() failure IB/srp: Fix infinite loop when FMR sg[0].offset != 0 IB/srp: Remove an unused argument IB/core: Improve ib_map_mr_sg() documentation IB/mlx4: Fix possible vl/sl field mismatch in LRH header in QP1 packets IB/mthca: Move user vendor structures IB/nes: Move user vendor structures IB/ocrdma: Move user vendor structures IB/mlx4: Move user vendor structures IB/cxgb4: Move user vendor structures IB/cxgb3: Move user vendor structures IB/mlx5: Move and decouple user vendor structures IB/{core,hw}: Add constant for node_desc ipoib: Make ipoib_warn ratelimited IB/mlx4/alias_GUID: Remove deprecated create_singlethread_workqueue IB/ipoib_verbs: Remove deprecated create_singlethread_workqueue IB/ipoib: Remove deprecated create_singlethread_workqueue ...
2016-10-08Merge remote-tracking branch 'jk/vfs' into work.miscAl Viro
2016-10-08watchdog: add watchdog pretimeout governor frameworkVladimir Zapolskiy
The change adds a simple watchdog pretimeout framework infrastructure, its purpose is to allow users to select a desired handling of watchdog pretimeout events, which may be generated by some watchdog devices. A user selects a default watchdog pretimeout governor during compilation stage. Watchdogs with WDIOF_PRETIMEOUT capability now have one more device attribute in sysfs, pretimeout_governor attribute is intended to display the selected watchdog pretimeout governor. The framework has no impact at runtime on watchdog devices with no WDIOF_PRETIMEOUT capability set. Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Reviewed-by: Wolfram Sang <wsa+renesas@sang-engineering.com> Tested-by: Wolfram Sang <wsa+renesas@sang-engineering.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2016-10-07Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge updates from Andrew Morton: - fsnotify updates - ocfs2 updates - all of MM * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (127 commits) console: don't prefer first registered if DT specifies stdout-path cred: simpler, 1D supplementary groups CREDITS: update Pavel's information, add GPG key, remove snail mail address mailmap: add Johan Hovold .gitattributes: set git diff driver for C source code files uprobes: remove function declarations from arch/{mips,s390} spelling.txt: "modeled" is spelt correctly nmi_backtrace: generate one-line reports for idle cpus arch/tile: adopt the new nmi_backtrace framework nmi_backtrace: do a local dump_stack() instead of a self-NMI nmi_backtrace: add more trigger_*_cpu_backtrace() methods min/max: remove sparse warnings when they're nested Documentation/filesystems/proc.txt: add more description for maps/smaps mm, proc: fix region lost in /proc/self/smaps proc: fix timerslack_ns CAP_SYS_NICE check when adjusting self proc: add LSM hook checks to /proc/<tid>/timerslack_ns proc: relax /proc/<tid>/timerslack_ns capability requirements meminfo: break apart a very long seq_printf with #ifdefs seq/proc: modify seq_put_decimal_[u]ll to take a const char *, not char proc: faster /proc/*/status ...
2016-10-07Merge tag 'armsoc-late' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC late DT updates from Arnd Bergmann: "These updates have been kept in a separate branch mostly because they rely on updates to the respective clk drivers to keep the shared header files in sync. - The Renesas r8a7796 (R-Car M3-W) platform gets added, this is an automotive SoC similar to the ⅹ8a7795 chip we already support, but the dts changes rely on a clock driver change that has been merged for v4.9 through the clk tree. - The Amlogic meson-gxbb (S905) platform gains support for a few drivers merged through our tree, in particular the network and usb driver changes are required and included here, and also the clk tree changes. - The Allwinner platforms have seen a large-scale change to their clk drivers and the dts file updates must come after that. This includes the newly added Nextthing GR8 platform, which is derived from sun5i/A13. - Some integrator (arm32) changes rely on clk driver changes. - A single patch for lpc32xx has no such dependency but wasn't added until just before the merge window" * tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (99 commits) ARM: dts: lpc32xx: add device node for IRAM on-chip memory ARM: dts: sun8i: Add accelerometer to polaroid-mid2407pxe03 ARM: dts: sun8i: enable UART1 for iNet D978 Rev2 board ARM: dts: sun8i: add pinmux for UART1 at PG dts: sun8i-h3: add I2C0-2 peripherals to H3 SOC dts: sun8i-h3: add pinmux definitions for I2C0-2 dts: sun8i-h3: associate exposed UARTs on Orange Pi Boards dts: sun8i-h3: split off RTS/CTS for UART1 in seperate pinmux dts: sun8i-h3: add pinmux definitions for UART2-3 ARM: dts: sun9i: a80-optimus: Disable EHCI1 ARM: dts: sun9i: cubieboard4: Add AXP806 PMIC device node and regulators ARM: dts: sun9i: a80-optimus: Add AXP806 PMIC device node and regulators ARM: dts: sun9i: cubieboard4: Declare AXP809 SW regulator as unused ARM: dts: sun9i: a80-optimus: Declare AXP809 SW regulator as unused ARM: dts: sun8i: Add touchscreen node for sun8i-a33-ga10h ARM: dts: sun8i: Add touchscreen node for sun8i-a23-polaroid-mid2809pxe04 ARM: dts: sun8i: Add touchscreen node for sun8i-a23-polaroid-mid2407pxe03 ARM: dts: sun8i: Add touchscreen node for sun8i-a23-inet86dz ARM: dts: sun8i: Add touchscreen node for sun8i-a23-gt90h ARM64: dts: meson-gxbb-vega-s95: Enable USB Nodes ...
2016-10-07Merge tag 'armsoc-dt64' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM 64-bit DT updates from Arnd Bergmann: "The 64-bit DT changes are surprisingly small this time, we only add two SoC platforms: the ZTE ZX296718 Set-top-box SoC and the SocioNext UniPhier LD11 TV SoC, each with their reference boards. There are three new machines added for existing SoC platforms: - The Marvell Armada 8040 development board is an impressive quad-core Cortex-A72 machine with three 10gbit ethernet interfaces - Qualcomms DragonBoard 820c single-board computer is their current high-end phone platform in the 96boards form factor - Rockchip: Tronsmart Orion r86 set-top-box is a popular mid-range Android box based on the 8-core rk3368 SoC" * tag 'armsoc-dt64' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (91 commits) arm64: dts: berlin4ct: Add L2 cache topology arm64: dts: berlin4ct: enable all wdt nodes unconditionally arm64: dts: berlin4ct: switch to Cortex-A53 specific pmu nodes arm64: dts: Add ZTE ZX296718 SoC dts and Makefile arm64: dts: apm: Add DT node for APM X-Gene 2 CPU clocks arm64: dts: apm: Add X-Gene SoC hwmon to device tree arm64: dts: apm: Fix interrupt polarity for X-Gene PCIe legacy interrupts arm64: dts: apm: Add APM X-Gene v2 SoC PMU DTS entries arm64: dts: apm: Add APM X-Gene SoC PMU DTS entries arm64: dts: marvell: enable MSI for PCIe on Armada 7K/8K arm64: dts: ls2080a: Add 'dma-coherent' for ls2080a PCI nodes arm64: dts: rockchip: add Type-C phy for RK3399 arm64: dts: rockchip: enable the gmac for rk3399 evb board arm64: dts: rockchip: add the gmac needed node for rk3399 arm64: dts: rockchip: support the pmu node for rk3399 arm64: dts: rockchip: change all interrupts cells to 4 on rk3399 SoCs arm64: dts: rockchip: add the tcpc for rk3399 power domain arm64: dts: rockchip: add efuse0 device node for rk3399 arm64: dts: rockchip: configure PCIe support for rk3399-evb arm64: dts: rockchip: add the PCIe controller support for RK3399 ...
2016-10-07Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Arnd Bergmann: "These are as usual a very large number of mostly boring updates to enable devices in existing machines, or to fix minor bugs. Notably, an ongoing treewide effort to fix warnings caused by an update to the device tree compiler. These are enabled with "make W=1" at the moment but can hopefully become the default once all issues have been addressed. No new SoC platform is added this time around (Armada 395 and Orion mv88f5181 are slight variations of existing ones), but a significant number of new dts files are added, which I list by platform: - Allwinner: Empire Electronix M712 and iNet d978 Rev2 tablets, Orange Pi PC Plus, Orange Pi 2, Orange Pi Plus 2E, Orange Pi Lite, Olimex A33-Olinuxino, and Nano Pi Neo single-board computers - ARM Realview: all supported machines (ported from board files) - Broadcom: BCM958525er, BCM958522er, BCM988312hr, BCM958623hr and BCM958622hr reference boards for Northstar platform, Raspberry Pi Zero single-board computer - Marvell EBU: Netgear WNR854T router (ported from board file), Armada 395 SoC platform and GP board Armada 390 DB development board - NXP i.MX: imx7s Warp7 reference board, Gateworks Ventana GW553x single-board computer, Technologic Systems TS-4900 and Engicam IMX6UL GEA M6UL computer-on-module, Inverse Path USB armory board - Qualcomm: LG Nexus 5 Phone - Renesas: r8a7792/wheat and r7s72100/rskrza1 development boards - Rockchip: Rockchip RK3288 Fennec reference board, Firefly RK3288 Reload platform - ST Microelectronics STi: B2260 (96boards) single-board computer - TI Davinci: OMAP-L138 LCDK Development kit - TI OMAP: beagleboard-x15 rev B1 single-board computer" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (390 commits) ARM: dts: sony-nsz-gs7: add missing unit name to /memory node ARM: dts: chromecast: add missing unit name to /memory node ARM: dts: berlin2q-marvell-dmp: add missing unit name to /memory node ARM: dts: berlin2: Add missing unit name to /soc node ARM: dts: berlin2cd: Add missing unit name to /soc node ARM: dts: berlin2q: Add missing unit name to /soc node ARM: dts: berlin2: Remove skeleton.dtsi inclusion ARM: dts: berlin2cd: Remove skeleton.dtsi inclusion ARM: dts: berlin2q: Remove skeleton.dtsi inclusion arm: dts: berlin2q: enable all wdt nodes unconditionally arm: dts: berlin2: enable all wdt nodes unconditionally ARM: dts: omap5-igep0050.dts: Use tabs for indentation ARM: dts: Fix igepv5 power button GPIO direction ARM: dts: am335x-evmsk: Add blue-and-red-wiring -property to lcdc node ARM: dts: am335x-evmsk: Whitespace cleanup of lcdc related nodes ARM: dts: am335x-evm: Add blue-and-red-wiring -property to lcdc node ARM: dts: s3c64xx: Use macros for pinctrl configuration ARM: dts: s3c2416: Use macros for pinctrl configuration ARM: dts: s5pv210: Use macros for pinctrl configuration ARM: dts: s3c64xx: Use common macros for pinctrl configuration ...
