This is the 4.1.15 stable release
commit b2f73922d119686323f14fbbe46587f863852328 upstream.
So the /proc/PID/stat 'wchan' field (the 30th field, which contains
the absolute kernel address of the kernel function a task is blocked in)
leaks absolute kernel addresses to unprivileged user-space:
seq_put_decimal_ull(m, ' ', wchan);
The absolute address might also leak via /proc/PID/wchan as well, if
KALLSYMS is turned off or if the symbol lookup fails for some reason:
static int proc_pid_wchan(struct seq_file *m, struct pid_namespace *ns,
struct pid *pid, struct task_struct *task)
unsigned long wchan;
char symname[KSYM_NAME_LEN];
wchan = get_wchan(task);
if (lookup_symbol_name(wchan, symname) < 0) {
if (!ptrace_may_access(task, PTRACE_MODE_READ))
return 0;
seq_printf(m, "%lu", wchan);
} else {
seq_printf(m, "%s", symname);
return 0;
This isn't ideal, because for example it trivially leaks the KASLR offset
to any local attacker:
fomalhaut:~> printf "%016lx\n" $(cat /proc/$$/stat | cut -d' ' -f35)
ffffffff8123b380
Most real-life uses of wchan are symbolic:
ps -eo pid:10,tid:10,wchan:30,comm
and procps uses /proc/PID/wchan, not the absolute address in /proc/PID/stat:
triton:~/tip> strace -f ps -eo pid:10,tid:10,wchan:30,comm 2>&1 | grep wchan | tail -1
open("/proc/30833/wchan", O_RDONLY) = 6
There's one compatibility quirk here: procps relies on whether the
absolute value is non-zero - and we can provide that functionality
by outputing "0" or "1" depending on whether the task is blocked
(whether there's a wchan address).
These days there appears to be very little legitimate reason
user-space would be interested in the absolute address. The
absolute address is mostly historic: from the days when we
didn't have kallsyms and user-space procps had to do the
decoding itself via the System.map.
So this patch sets all numeric output to "0" or "1" and keeps only
symbolic output, in /proc/PID/wchan.
( The absolute sleep address can generally still be profiled via
perf, by tasks with sufficient privileges. )
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Alexander Potapenko <glider@google.com>
Cc: Andrey Konovalov <andreyknvl@google.com>
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Kostya Serebryany <kcc@google.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: kasan-dev <kasan-dev@googlegroups.com>
Link: http://lkml.kernel.org/r/20150930135917.GA3285@gmail.com
commit 22869a9eca4ea5b534538d160b68c7aef44e378a upstream.
This defines a new compatible option for MFD devices "simple-mfd" that will
make the OF core spawn child devices for all subnodes of that MFD device.
It is optional but handy for things like syscon and possibly other
simpler MFD devices.
Since there was no file to put the documentation in, I took this opportunity
to make a small writeup on MFD devices and add the compatible definition
there.
Suggested-by: Lee Jones <lee.jones@linaro.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Devicetree <devicetree@vger.kernel.org>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: Henrik Juul Pedersen <hjp@liab.dk>
This is the 4.1.11 stable release
commit e4144fe5d47c91c92d36cdbd5f31ed8d6e3a57ab upstream.
The HOWTO document needed updating for the new kernel versioning.
Signed-off-by: Mario Carrillo <mario.alfredo.c.arevalo@intel.com>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
[ Upstream commit 4cba5c2103657d43d0886e4cff8004d95a3d0def in net-next tree,
will be pushed to Linus very soon. ]
Currently the PHY management type is selected by the MAC driver arbitrary.
The decision is based on the presence of the "fixed-link" node and on a
will of the driver's authors.
This caused a regression recently, when mvneta driver suddenly started
to use the in-band status for auto-negotiation on fixed links.
It appears the auto-negotiation may not work when expected by the MAC driver.
Sebastien Rannou explains:
<< Yes, I confirm that my HW does not generate an in-band status. AFAIK, it's
a PHY that aggregates 4xSGMIIs to 1xQSGMII ; the MAC side of the PHY (with
inband status) is connected to the switch through QSGMII, and in this context
we are on the media side of the PHY. >>
https://lkml.org/lkml/2015/7/10/206
This patch introduces the new string property 'managed' that allows
the user to set the management type explicitly.
The supported values are:
"auto" - default. Uses either MDIO or nothing, depending on the presence
of the fixed-link node
"in-band-status" - use in-band status
Signed-off-by: Stas Sergeev <stsp@users.sourceforge.net>
CC: Rob Herring <robh+dt@kernel.org>
CC: Pawel Moll <pawel.moll@arm.com>
CC: Mark Rutland <mark.rutland@arm.com>
CC: Ian Campbell <ijc+devicetree@hellion.org.uk>
CC: Kumar Gala <galak@codeaurora.org>
CC: Florian Fainelli <f.fainelli@gmail.com>
CC: Grant Likely <grant.likely@linaro.org>
CC: devicetree@vger.kernel.org
CC: linux-kernel@vger.kernel.org
CC: netdev@vger.kernel.org
commit 4bc58eb16bb2352854b9c664cc36c1c68d2bfbb7 upstream.
Fix the name of attribute
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 8cd50626823c00ca7472b2f61cb8c0eb9798ddc0 upstream.
commit f811a38300be3cdb603171aea5ad3fb42b71ca53 upstream.
testusb.c at http://www.linux-usb.org/usbtest/ is out of date,
using the one at the kernel source folder.
sticks
commit 073e570d7c2caae9910a993d56f340be4548a4a8 upstream.
It turns out that only Dell laptops have the separate button bits for
v2 dualpoint sticks and that commit 92bac83dd79e ("Input: alps - non
interleaved V2 dualpoint has separate stick button bits") causes
regressions on Toshiba laptops.
This commit adds a check for Dell laptops to the code for handling these
extra button bits, fixing this regression.
This patch has been tested on a Dell Latitude D620 to make sure that it
does not reintroduce the original problem.
Reported-and-tested-by: Douglas Christman <douglaschristman@gmail.com>
commit 02fdfd708fd252a778709beb6c65d5e7360341ac upstream.
Main PLL controller has post divider bits in a separate register in
pll controller. Use the value from this register instead of fixed
divider when available.
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Michael Turquette <mturquette@baylibre.com>
This is the 4.1.5 stable release
The driver currently does not take into account the minimum sample time
as per the Figure 6-8 Chapter 9.1.1 12-bit ADC electrical characteristics.
We set a static amount of cycles instead of considering the sample time
as a given value, which depends on hardware characteristics.
Determine sampling frequencies by first reading the device tree property
node and then calculating the required Long Sample Time Adder (LSTAdder)
value, based on the ADC clock frequency and sample time value obtained
from the device tree. This LSTAdder value is then used for calculating
the sampling frequencies possible.
In case the sample time property is not specified through the device
tree, a safe default value of 1000ns is assumed.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
[moved adck_rate calculation before sample time calculation]
commit 0d6aaffc3a6db642e0a165ba4d17d6d7bbaf5201 upstream.
pwm attributes have well defined names, which should be used.
Cc: Vadim V. Vlasov <vvlasov@dev.rtsoft.ru>
commit 61754c18752ffb78145671e94f053fb202fff041 upstream.
Since commit a1c48bb1 (Makefile: Fix unrecognized cross-compiler command
line options), the arch Makefile is included earlier by the main
Makefile, preventing the arc architecture to set its -O3 compiler
option. Since there might be more use cases for an arch Makefile to
fine-tune the options, add support for ARCH_CPPFLAGS, ARCH_AFLAGS and
ARCH_CFLAGS variables that are appended to the respective kbuild
variables. The user still has the final say via the KCPPFLAGS, KAFLAGS
and KCFLAGS variables.
Reported-by: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Signed-off-by: Michal Marek <mmarek@suse.com>
This is the 4.1.4 stable release
Add device-tree bindings of Vybrids LPDDR2/DDR3 SDRAM Memory
Controller. Access to the device is required to put the memory
into self-refresh mode.
commit 24fd03c87695a76f0517df42a37e51b1597d2c8a upstream.
This patch defines a builtin measurement policy "tcb", similar to the
existing "ima_tcb", but with additional rules to also measure files
based on the effective uid and to measure files opened with the "read"
mode bit set (eg. read, read-write).
Changing the builtin "ima_tcb" policy could potentially break existing
users. Instead of defining a new separate boot command line option each
time the builtin measurement policy is modified, this patch defines a
single generic boot command line option "ima_policy=" to specify the
builtin policy and deprecates the use of the builtin ima_tcb policy.
[The "ima_policy=" boot command line option is based on Roberto Sassu's
"ima: added new policy type exec" patch.]
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Signed-off-by: Dr. Greg Wettstein <gw@idfusion.org>
commit 4351c294b8c1028077280f761e158d167b592974 upstream.
The current "mask" policy option matches files opened as MAY_READ,
MAY_WRITE, MAY_APPEND or MAY_EXEC. This patch extends the "mask"
option to match files opened containing one of these modes. For
example, "mask=^MAY_READ" would match files opened read-write.
commit 139069eff7388407f19794384c42a534d618ccd7 upstream.
The new "euid" policy condition measures files with the specified
effective uid (euid). In addition, for CAP_SETUID files it measures
files with the specified uid or suid.
Changelog:
- fixed checkpatch.pl warnings
- fixed avc denied {setuid} messages - based on Roberto's feedback
commit cd025f7f94108995383edddfb61fc8afea6c66a9 upstream.
Include don't appraise or measure rules for the NSFS filesystem
in the builtin ima_tcb and ima_appraise_tcb policies.
Changelog:
- Update documentation
commit 6438de9f3fb5180d78a0422695d0b88c687757d3 upstream.
This patch adds a rule in the default measurement policy to skip inodes
in the cgroupfs filesystem. Measurements for this filesystem can be
avoided, as all the digests collected have the same value of the digest of
an empty file.
Furthermore, this patch updates the documentation of IMA policies in
Documentation/ABI/testing/ima_policy to make it consistent with
the policies set in security/integrity/ima/ima_policy.c.
Signed-off-by: Roberto Sassu <rsassu@suse.de>
commit 50f0a44991516b5b9744ecb2c080c2ec6ad21b25 upstream.
To please checkpatch and the tiresome reader, add the "atmel," prefix to the
USB udc compatible string.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
commit f303074160d3401970ccae082014e1ee5a9a52c5 upstream.
Create a sysfs "trim" attribute for each ata_device that displays
whether DSM TRIM is "unsupported", "unqueued", "forced_unqueued"
(blacklisted) or "queued".
Reviewed-by: Hannes Reinecke <hare@suse.de>
commit bdc10d57f236b534fb675a4bbefd10017aeb2b26 upstream.
Current description for proximity measurement is ambiguous. While
the first part says that proximity is measured by observing
reflectivity, the second part incorrectly infers that reported values
should behave like a distance.
This is because of AS3935 lightning sensor which uses the proximity
API, while not being a true proximity sensor.
Note this is marked for stable as it accompanies a fix in ABI usage
to the sx9500 driver which would otherwise appear to be correct.
Fixes: 614e8842ddf ("iio: ABI: add clarification for proximity")
Signed-off-by: Daniel Baluta <daniel.baluta@intel.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit ea78b9511a54d0de026e04b5da86b30515072f31 upstream.
There was a mistake in the definition of the functions for MPP48 on
Marvell Armada XP. The second function is dev(clkout), and not tclk.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Fixes: 463e270f766a ("pinctrl: mvebu: add pinctrl driver for Armada XP")
commit 80b3d04feab5e69d51cb2375eb989a7165e43e3b upstream.
The latest version of the Armada XP datasheet no longer documents the
VDD cpu_pd functions, which might indicate they are not working and/or
not supported. This commit ensures the pinctrl driver matches the
datasheet.
commit bc99357f3690c11817756adfee0ece811a3db2e7 upstream.
After updating to a more recent version of the Armada XP datasheet, we
realized that some of the pins documented as having a NAND-related
functionality in fact did not have such functionality. This commit
updates the pinctrl driver accordingly.
commit 331642fbf24a1c16b2669ca0a6479b5fcd6dd5b2 upstream.
A new revision of the Marvell Armada 38x hardware datasheet unveiled
that the definition of some of the PCIe functions were not
correct. This commit fixes the pinctrl driver accordingly.
Some PCIe functions simply do not exist, some of the PCIe functions in
fact were corresponding to other functions, and some PCIe functions
have been added.
Note: the seemingly unrelated removal of spi(cs2) on MPP47 is related:
this function is in fact implemented on MPP43, instead of a PCIe
function.
Fixes: ca6d9a084b56f ("pinctrl: mvebu: add pin-muxing driver for the Marvell Armada 380/385")
commit e5447d26092c72ef3346615ee558c9112ef8063f upstream.
After updating to a more recent version of the Armada 375, we realized
Fixes: ce3ed59dcddd ("pinctrl: mvebu: add pin-muxing driver for the Marvell Armada 375")
commit 438881dfddb9107ef0eb30b49368e91e092f0b3e upstream.
Due to a mistake, the CS0 and CS1 SPI0 functions were incorrectly
named "spi0-1" instead of just "spi0". This commit fixes that.
This DT binding change does not affect any of the in-tree users.
Fixes: 5f597bb2be57 ("pinctrl: mvebu: add pinctrl driver for Armada 370")
commit 3a9ad0b4fdcd57f775d3615004c8c64c021a9e7d upstream.
David Ahern reported that d63e2e1f3df9 ("sparc/PCI: Clip bridge windows
to fit in upstream windows") fails to boot on sparc/T5-8:
pci 0000:06:00.0: reg 0x184: can't handle BAR above 4GB (bus address 0x110204000)
The problem is that sparc64 assumed that dma_addr_t only needed to hold DMA
addresses, i.e., bus addresses returned via the DMA API (dma_map_single(),
etc.), while the PCI core assumed dma_addr_t could hold *any* bus address,
including raw BAR values. On sparc64, all DMA addresses fit in 32 bits, so
dma_addr_t is a 32-bit type. However, BAR values can be 64 bits wide, so
they don't fit in a dma_addr_t. d63e2e1f3df9 added new checking that
tripped over this mismatch.
Add pci_bus_addr_t, which is wide enough to hold any PCI bus address,
including both raw BAR values and DMA addresses. This will be 64 bits
on 64-bit platforms and on platforms with a 64-bit dma_addr_t. Then
dma_addr_t only needs to be wide enough to hold addresses from the DMA API.
[bhelgaas: changelog, bugzilla, Kconfig to ensure pci_bus_addr_t is at
least as wide as dma_addr_t, documentation]
Fixes: d63e2e1f3df9 ("sparc/PCI: Clip bridge windows to fit in upstream windows")
Fixes: 23b13bc76f35 ("PCI: Fail safely if we can't handle BARs larger than 4GB")
Link: http://lkml.kernel.org/r/CAE9FiQU1gJY1LYrxs+ma5LCTEEe4xmtjRG0aXJ9K_Tsu+m9Wuw@mail.gmail.com
Link: http://lkml.kernel.org/r/1427857069-6789-1-git-send-email-yinghai@kernel.org
Link: https://bugzilla.kernel.org/show_bug.cgi?id=96231
Reported-by: David Ahern <david.ahern@oracle.com>
Tested-by: David Ahern <david.ahern@oracle.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit ea6055c46eda1e19e02209814955e13f334bbe1b upstream.
Since commit 39a6ac11df65 ("spi/pl022: Devicetree support w/o platform data")
the 'num-cs' parameter cannot be passed through platform data when probing
with devicetree. Instead, it's a required devicetree property.
Fix the binding documentation so the property is properly specified.
Fixes: 39a6ac11df65 ("spi/pl022: Devicetree support w/o platform data")
Signed-off-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
Signed-off-by: Mark Brown <broonie@kernel.org>
This is the 4.1.2 stable release
[ Upstream commit f522a975a8101895a85354b9c143f41b8248e71a ]
The mvneta driver supports the Ethernet IP found in the Armada 370, XP,
380 and 385 SoCs. Since at least one more hardware feature is available
for the Armada XP SoCs then a way to identify them is needed.
This patch introduces a new compatible string "marvell,armada-xp-neta".
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
Fixes: c5aff18204da ("net: mvneta: driver for Marvell Armada 370/XP network unit")
Cc: <stable@vger.kernel.org> # v3.8+
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
This adds device tree binding documentation for the Colibri VF50
touchscreen driver.
Support configurable conversion mode through sysfs. So far, the
mode used was low-power, which is enabled by default now. Beside
that, the modes normal and high-speed are selectable as well.
Use the new device tree property which specifies the maximum ADC
conversion clock frequencies. Depending on the mode used, the
available resulting conversion frequency are calculated
dynamically.
Acked-by: Fugang Duan <B38611@freescale.com>
Signed-off-by: Stefan Agner <stefan@agner.ch>
This patch adds the document for DCU framebuffer driver under
Documentation/devicetree/bindings/fb/.
Signed-off-by: Alison Wang <b18965@freescale.com>
Signed-off-by: Bill Pringlemeir <bpringlemeir@nbsps.com>
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux
Pull clk fixes from Michael Turquette:
"Very late clk regression fixes for the ARM-based AT91 platform.
These went unnoticed by me until recently, hence the late pull
request"
* tag 'clk-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux:
clk: at91: fix h32mx prototype inclusion in pmc header
clk: at91: trivial: typo in peripheral clock description
clk: at91: fix PERIPHERAL_MAX_SHIFT definition
clk: at91: pll: fix input range validity check
https://github.com/bbrezillon/linux-at91 into clk-fixes
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
I copied the wrong shell code into the documentation. Sorry to all who
tried to get sense out of this current example :/ Slight rewording while
we are here.
Reported-by: Tim Bakker <bakkert@mymail.vcu.edu>
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Cc: stable@kernel.org
Pull networking fixes from David Miller:
1) Fix uninitialized struct station_info in cfg80211_wireless_stats(),
from Johannes Berg.
2) Revert commit attempt to fix ipv6 protocol resubmission, it adds
regressions.
3) Endless loops can be created in bridge port lists, fix from Nikolay
Aleksandrov.
4) Don't WARN_ON() if sk->sk_forward_alloc is non-zero in
sk_clear_memalloc, it is a legal situation during swap deactivation.
Fix from Mel Gorman.
5) Fix order of disabling interrupts and unlocking NAPI in enic driver
to avoid a race. From Govindarajulu Varadarajan.
6) High and low register writes are swapped when programming the start
of periodic output in igb driver. From Richard Cochran.
7) Fix device rename handling in mpls stack, from Robert Shearman.
8) Do not trigger compaction synchronously when optimistically trying
to allocate an order 3 page in alloc_skb_with_frags() and
skb_page_frag_refill(). From Shaohua Li.
9) Authentication with COOKIE_ECHO is not handled properly in SCTP, fix
from Marcelo Ricardo Leitner.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
Doc: networking: Fix URL for wiki.wireshark.org in udplite.txt
sctp: allow authenticating DATA chunks that are bundled with COOKIE_ECHO
net: don't wait for order-3 page allocation
mpls: handle device renames for per-device sysctls
net: igb: fix the start time for periodic output signals
enic: fix memory leak in rq_clean
enic: check return value for stat dump
enic: unlock napi busy poll before unmasking intr
net, swap: Remove a warning and clarify why sk_mem_reclaim is required when deactivating swap
bridge: fix multicast router rlist endless loop
tipc: disconnect socket directly after probe failure
Revert "ipv6: Fix protocol resubmission"
cfg80211: wext: clear sinfo struct before calling driver
This patch fix URL (http to https) for wiki.wireshark.org.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Pull VT-d hardware workarounds from David Woodhouse:
"This contains a workaround for hardware issues which I *thought* were
never going to be seen on production hardware. I'm glad I checked
that before the 4.1 release...
Firstly, PASID support is so broken on existing chips that we're just
going to declare the old capability bit 28 as 'reserved' and change
the VT-d spec to move PASID support to another bit. So any existing
hardware doesn't support SVM; it only sets that (now) meaningless bit
28.
That patch *wasn't* imperative for 4.1 because we don't have PASID
support yet. But *even* the extended context tables are broken — if
you just enable the wider tables and use none of the new bits in them,
which is precisely what 4.1 does, you find that translations don't
work. It's this problem which I thought was caught in time to be
fixed before production, but wasn't.
To avoid triggering this issue, we now *only* enable the extended
context tables on hardware which also advertises "we have PASID
support and we actually tested it this time" with the new PASID
feature bit.
In addition, I've added an 'intel_iommu=ecs_off' command line
parameter to allow us to disable it manually if we need to"
* git://git.infradead.org/intel-iommu:
iommu/vt-d: Only enable extended context tables if PASID is supported
iommu/vt-d: Change PASID support to bit 40 of Extended Capability Register
Although the extended tables are theoretically a completely orthogonal
feature to PASID and anything else that *uses* the newly-available bits,
some of the early hardware has problems even when all we do is enable
them and use only the same bits that were in the old context tables.
For now, there's no motivation to support extended tables unless we're
going to use PASID support to do SVM. So just don't use them unless
PASID support is advertised too. Also add a command-line bailout just in
case later chips also have issues.
The equivalent problem for PASID support has already been fixed with the
upcoming VT-d spec update and commit bd00c606a ("iommu/vt-d: Change
PASID support to bit 40 of Extended Capability Register"), because the
problematic platforms use the old definition of the PASID-capable bit,
which is now marked as reserved and meaningless.
So with this change, we'll magically start using ECS again only when we
see the new hardware advertising "hey, we have PASID support and we
actually tested it this time" on bit 40.
The VT-d hardware architect has promised that we are not going to have
any reason to support ECS *without* PASID any time soon, and he'll make
sure he checks with us before changing that.
In the future, if hypothetical new features also use new bits in the
context tables and can be seen on implementations *without* PASID support,
we might need to add their feature bits to the ecs_enabled() macro.
