path: root/Documentation
2013-10-17iio: at91: introduce touch screen support in iio adc driverJosh Wu
AT91 ADC hardware integrate touch screen support. So this patch add touch screen support for at91 adc iio driver. To enable touch screen support in adc, you need to add the dt parameters: 1. which type of touch are used? (4 or 5 wires), sample period time. 2. correct pressure detect threshold value. In the meantime, since touch screen will use a interal period trigger of adc, so it is conflict to other hardware triggers. Driver will disable the hardware trigger support if touch screen is enabled. This driver has been tested in AT91SAM9X5-EK and SAMA5D3x-EK. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> CC: devicetree@vger.kernel.org Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-10-17DT: Add documentation for cm36651 proximity/light sensorBeomho Seo
This patch adds device tree binding documentation for CM36651 proximity/light sensor. Signed-off-by: Beomho Seo <beomho.seo@samsung.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-10-12iio: Add a hysteresis event info attributeLars-Peter Clausen
For some devices it is possible to configure a hysteresis for threshold (or similar) events. This patch adds a new hysteresis event info type which allows for easy creation and read/write handling of the sysfs attribute. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-10-09iio: at91: move the num_channels from DT to driver itselfJosh Wu
CC: devicetree@vger.kernel.org Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-10-06Merge 3.12-rc4 into staging-nextGreg Kroah-Hartman
We want the staging fixes in this branch as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-02Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "We have a fairly large batch of fixes this time around, mostly just due to various platforms all having a fix or two more than usual. Worth pointing out are: - A fix for EDMA on Davinci/OMAP where channel allocation broke with the DT conversion. Due to some miscommunication we didn't understand the impact of the breakage, so we were pushing back on it for 3.12, but it sounds like it's actually breaking quite a few people out there. - A bunch of fixes for Marvell platforms, some straggling fixes for merge window fallout and some fixes for a couple of the platforms (Netgear RN102 in particular). - A fix for a race between multi-cluster power management and cpu hotplug on Versatile Express. And a bunch of other smaller fixes that all add up. We'll be switching over into stricter regressions-only mode from here on out" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (31 commits) ARM: multi_v7_defconfig: add SDHCI for i.MX bus: mvebu-mbus: Fix optional pcie-mem/io-aperture properties ARM: mvebu: add missing DT Mbus ranges and relocate PCIe DT nodes for RN102 ARM: at91: sam9g45: shutdown ddr1 too when rebooting MAINTAINERS: ARM: SIRF: use kernel.org mail box MAINTAINERS: ARM: SIRF: add missed drivers into maintain list ARM: edma: Fix clearing of unused list for DT DMA resources ARM: vexpress: tc2: fix hotplug/idle/kexec race on cluster power down ARM: dts: sirf: fix interrupt and dma prop of VIP for prima2 and atlas6 ARM: dts: sirf: fix the ranges of peri-iobrg of prima2 ARM: dts: makefile: build atlas6-evb.dtb for ARCH_ATLAS6 ARM: dts: sirf: fix fifosize, clks, dma channels for UART ARM: mvebu: Add DT entry for ReadyNAS 102 to use gpio-poweroff driver ARM: mvebu: fix ReadyNAS 102 Power button GPIO to make it active high ARM: mach-integrator: Add stub for pci_v3_early_init() for !CONFIG_PCI ARM: shmobile: Remove #gpio-ranges-cells DT property gpio: rcar: Remove #gpio-range-cells DT property usage ARM: shmobile: armadillo: fixup ether pinctrl naming ARM: shmobile: Lager: add Micrel KSZ8041 PHY fixup ARM: shmobile: update SDHI DT compatibility string to the <unit>-<soc> format ...
2013-10-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking changes from David Miller: 1) Multiply in netfilter IPVS can overflow when calculating destination weight. From Simon Kirby. 2) Use after free fixes in IPVS from Julian Anastasov. 3) SFC driver bug fixes from Daniel Pieczko. 4) Memory leak in pcan_usb_core failure paths, from Alexey Khoroshilov. 5) Locking and encapsulation fixes to serial line CAN driver, from Andrew Naujoks. 6) Duplex and VF handling fixes to bnx2x driver from Yaniv Rosner, Eilon Greenstein, and Ariel Elior. 7) In lapb, if no other packets are outstanding, T1 timeouts actually stall things and no packet gets sent. Fix from Josselin Costanzi. 8) ICMP redirects should not make it to the socket error queues, from Duan Jiong. 9) Fix bugs in skge DMA mapping error handling, from Nikulas Patocka. 10) Fix setting of VLAN priority field on via-rhine driver, from Roget Luethi. 11) Fix TX stalls and VLAN promisc programming in be2net driver from Ajit Khaparde. 12) Packet padding doesn't get handled correctly in new usbnet SG support code, from Ming Lei. 13) Fix races in netdevice teardown wrt. network namespace closing. From Eric W. Biederman. 14) Fix potential missed initialization of net_secret if not TCP connections are openned. From Eric Dumazet. 15) Cinterion PLXX product ID in qmi_wwan driver is wrong, from Aleksander Morgado. 16) skb_cow_head() can change skb->data and thus packet header pointers, don't use stale ip_hdr reference in ip_tunnel code. 17) Backend state transition handling fixes in xen-netback, from Paul Durrant. 18) Packet offset for AH protocol is handled wrong in flow dissector, from Eric Dumazet. 19) Taking down an fq packet scheduler instance can leave stale packets in the queues, fix from Eric Dumazet. 20) Fix performance regressions introduced by TCP Small Queues. From Eric Dumazet. 21) IPV6 GRE tunneling code calculates max_headroom incorrectly, from Hannes Frederic Sowa. 22) Multicast timer handlers in ipv4 and ipv6 can be the last and final reference to the ipv4/ipv6 specific network device state, so use the reference put that will check and release the object if the reference hits zero. From Salam Noureddine. 23) Fix memory corruption in ip_tunnel driver, and use skb_push() instead of __skb_push() so that similar bugs are less hard to find. From Steffen Klassert. 24) Add forgotten hookup of rtnl_ops in SIT and ip6tnl drivers, from Nicolas Dichtel. 25) fq scheduler doesn't accurately rate limit in certain circumstances, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (103 commits) pkt_sched: fq: rate limiting improvements ip6tnl: allow to use rtnl ops on fb tunnel sit: allow to use rtnl ops on fb tunnel ip_tunnel: Remove double unregister of the fallback device ip_tunnel_core: Change __skb_push back to skb_push ip_tunnel: Add fallback tunnels to the hash lists ip_tunnel: Fix a memory corruption in ip_tunnel_xmit qlcnic: Fix SR-IOV configuration ll_temac: Reset dma descriptors indexes on ndo_open skbuff: size of hole is wrong in a comment ipv6 mcast: use in6_dev_put in timer handlers instead of __in6_dev_put ipv4 igmp: use in_dev_put in timer handlers instead of __in_dev_put ethernet: moxa: fix incorrect placement of __initdata tag ipv6: gre: correct calculation of max_headroom powerpc/83xx: gianfar_ptp: select 1588 clock source through dts file Revert "powerpc/83xx: gianfar_ptp: select 1588 clock source through dts file" bonding: Fix broken promiscuity reference counting issue tcp: TSQ can use a dynamic limit dm9601: fix IFF_ALLMULTI handling pkt_sched: fq: qdisc dismantle fixes ...
2013-10-01Staging/iio/adc/touchscreen/MXS: provide devicetree adaptionJuergen Beisert
This is an RFC for the new touchscreen properties. Signed-off-by: Juergen Beisert <jbe@pengutronix.de> Tested-by: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de> Tested-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org> CC: linux-arm-kernel@lists.infradead.org CC: linux-input@vger.kernel.org CC: devel@driverdev.osuosl.org CC: Marek Vasut <marex@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com> CC: devicetree@vger.kernel.org
2013-10-01iio: Update unit of the voltage scale in the documentationLars-Peter Clausen
The documentation says that the result of raw * scale should be in microvolts, but in reallity all drivers actually report the scale so that the result is in millivolts. So update the documentation to match reallity. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-30powerpc/83xx: gianfar_ptp: select 1588 clock source through dts fileAida Mynzhasova
Currently IEEE 1588 timer reference clock source is determined through hard-coded value in gianfar_ptp driver. This patch allows to select ptp clock source by means of device tree file node. For instance: fsl,cksel = <0>; for using external (TSEC_TMR_CLK input) high precision timer reference clock. Other acceptable values: <1> : eTSEC system clock <2> : eTSEC1 transmit clock <3> : RTC clock input When this attribute isn't used, eTSEC system clock will serve as IEEE 1588 timer reference clock. Signed-off-by: Aida Mynzhasova <aida.mynzhasova@skitlab.ru> Acked-by: Kumar Gala <galak@codeaurora.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-30Revert "powerpc/83xx: gianfar_ptp: select 1588 clock source through dts file"David S. Miller
This reverts commit 894116bd0e9b7749a0c4b6c62dec13c2a0ccef68. I applied the wrong version of this patch, correct version coming up. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-30block: change config option name for cmdline partition parsingPaul Gortmaker
Recently commit bab55417b10c ("block: support embedded device command line partition") introduced CONFIG_CMDLINE_PARSER. However, that name is too generic and sounds like it enables/disables generic kernel boot arg processing, when it really is block specific. Before this option becomes a part of a full/final release, add the BLK_ prefix to it so that it is clear in absence of any other context that it is block specific. In addition, fix up the following less critical items: - help text was not really at all helpful. - index file for Documentation was not updated - add the new arg to Documentation/kernel-parameters.txt - clarify wording in source comments Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Cai Zhiyong <caizhiyong@huawei.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-30Documentation/kernel-parameters.txt: replace kernelcore with MovableWeiping Pan
Han Pingtian found a typo in Documentation/kernel-parameters.txt about "kernelcore=", that "kernelcore" should be replaced with "Movable" here. Signed-off-by: Weiping Pan <wpan@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
Currently IEEE 1588 timer reference clock source is determined through hard-coded value in gianfar_ptp driver. This patch allows to select ptp clock source by means of device tree file node. For instance: fsl,cksel = <0>; for using external (TSEC_TMR_CLK input) high precision timer reference clock. Other acceptable values: <1> : eTSEC system clock <2> : eTSEC1 transmit clock <3> : RTC clock input When this attribute isn't used, eTSEC system clock will serve as IEEE 1588 timer reference clock. Signed-off-by: Aida Mynzhasova <aida.mynzhasova@skitlab.ru> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-29Merge 3.12-rc3 into staging-nextGreg Kroah-Hartman
We want the staging fixes in here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-29Merge tag 'tty-3.12-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial fixes from Greg KH: "Here are some serial at tty driver fixes for 3.12-rc3 The serial driver fixes some kref leaks, documentation is moved to the proper places, and the tty and n_tty fixes resolve some reported regressions. There is still one outstanding tty regression fix that isn't in here yet, as I want to test it out some more, it will be sent for 3.12-rc4 if it checks out" * tag 'tty-3.12-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: tty: ar933x_uart: move devicetree binding documentation tty: Fix SIGTTOU not sent with tcflush() n_tty: Fix EOF push index when termios changes serial: pch_uart: remove unnecessary tty_port_tty_get serial: pch_uart: fix tty-kref leak in dma-rx path serial: pch_uart: fix tty-kref leak in rx-error path serial: tegra: fix tty-kref leak
2013-09-28Merge tag 'devicetree-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree fixes from Rob Herring: "Clean-up to fix some warnings for !OF builds and spelling fixes in docs: - Clean-up openrisc prom.h - Fix warnings caused by of_irq.h ifdefs - Spelling fix for Synopsys" * tag 'devicetree-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: dts: Fix misspelling of Synopsys of: clean-up ifdefs in of_irq.h openrisc: clean-up prom.h
2013-09-27Merge tag 'sound-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Nothing too serious here: a couple of compress-offload core fixes, Haswell HDMI audio fix, a fixup for new MacBook Airs and a few COEF setups for ALC283 mic problems" * tag 'sound-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Enable internal mic on a Thinkpad machine with ALC283 ALSA: hda - Fix Internal Mic boost can't control with ALC283 ALSA: hda - Add documentation for CS4208 fixups ALSA: hda - Add fixup for MacBook Air 6,1 and 6,2 with CS4208 codec ALSA : hda - not use assigned converters for all unused pins ALSA: compress: Make sure we trigger STOP before closing the stream. ALSA: compress: Fix compress device unregister.
2013-09-27ALSA: hda - Add documentation for CS4208 fixupsTakashi Iwai
2013-09-26tty: ar933x_uart: move devicetree binding documentationGabor Juhos
Commit 'tty: ar933x_uart: add device tree support and binding documentation' introduced a new doc in bindins/tty/serial. According to a recent thread [1] on the linux-serial list, the binding documentation of serial drivers should be added into bindings/serial. Move the documentation of qca,ar9330-uart to the correct place. 1. http://marc.info/?l=linux-serial&m=137771295411517 Cc: devicetree@vger.kernel.org Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-25Merge tag 'stable/for-linus-3.12-rc2-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen fixes from Konrad Rzeszutek Wilk: "Bug-fixes and one update to the kernel-paramters.txt documentation. - Fix PV spinlocks triggering jump_label code bug - Remove extraneous code in the tpm front driver - Fix ballooning out of pages when non-preemptible - Fix deadlock when using a 32-bit initial domain with large amount of memory - Add xen_nopvpsin parameter to the documentation" * tag 'stable/for-linus-3.12-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/spinlock: Document the xen_nopvspin parameter. xen/p2m: check MFN is in range before using the m2p table xen/balloon: don't alloc page while non-preemptible xen: Do not enable spinlocks before jump_label_init() has executed tpm: xen-tpmfront: Remove the locality sysfs attribute tpm: xen-tpmfront: Fix default durations
2013-09-25Merge 3.12-rc2 into staging-next.Greg Kroah-Hartman
This resolves the merge problem with two iio drivers that Stephen Rothwell pointed out. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-25xen/spinlock: Document the xen_nopvspin parameter.Konrad Rzeszutek Wilk
Which disables in the ticketlock slowpath the Xen PV optimization's. Useful for diagnosing issues and comparing benchmarks in over-commit CPU scenarios. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-09-24dts: Fix misspelling of Synopsysdevicetree-fixesDinh Nguyen
s/Synopsis/Synopsys s/synopsis/synopsys Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Cc: Pavel Machek <pavel@denx.de> CC: Arnd Bergmann <arnd@arndb.de> CC: Olof Johansson <olof@lixom.net> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Chris Ball <cjb@laptop.org> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Seungwon Jeon <tgih.jun@samsung.com> Cc: Tomasz Figa <tomasz.figa@gmail.com> Cc: devicetree@vger.kernel.org Cc: linux-mmc@vger.kernel.org CC: linux-arm-kernel@lists.infradead.org Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-09-22Merge tag 'iio-for-3.13a' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next Jonathan writes: First round of new drivers, functionality and cleanups for IIO in the 3.13 cycle A number of new drivers and some new functionality + a lot of cleanups all over IIO. New Core Elements 1) New INT_TIME info_mask element for integration time, which may have different effects on measurement noise and similar, than an amplifier and hence is different from existing SCALE. Already existed in some drivers as a custom attribute. 2) Introduce a iio_push_buffers_with_timestamp helper to cover the common case of filling the last 64 bits of data to be passed to the buffer with a timestamp. Applied to lots of drivers. Cuts down on repeated code and moves a slightly fiddly bit of logic into a single location. 3) Introduce info_mask_[shared_by_dir/shared_by_all] elements to allow support of elements such as sampling_frequency which is typically shared by all input channels on a device. This reduces code and makes these controls available from in kernel consumers of IIO devices. New drivers 1) MCP3422/3/4 ADC 2) TSL4531 ambient light sensor 3) TCS3472/5 color light sensor 4) GP2AP020A00F ambient light / proximity sensor 5) LPS001WP support added to ST pressure sensor driver. New driver functionality 1) ti_am335x_adc Add buffered sampling support. This device has a hardware fifo that is fed directly into an IIO kfifo buffer based on a watershed interrupt. Note this will act as an example of how to handle this increasingly common type of device. The only previous example - sca3000 - take a less than optimal approach which is largely why it is still in staging. A couple of little cleanups for that new functionality followed later. Core cleanups: 1) MAINTAINERS - Sachin actually brought my email address up to date because I said I'd do it and never got around to it :) 2) Assign buffer list elements as single element lists to simplify the iio_buffer_is_active logic. 3) wake_up_interruptible_poll instead of wake_up_interruptible to only wake up threads waiting for poll notifications. 4) Add O_CLOEXEC flag to anon_inode_get_fd call for IIO event interface. 5) Change iio_push_to_buffers to take a void * pointer so as to avoid some annoying and unnecessary type casts. 6) iio_compute_scan_bytes incorrectly took a long rather than unsigned long. 7) Various minor tidy ups. Driver cleanups (in no particular order) 1) Another set of devm_ allocations patches from Sachin Kamat. 2) tsl2x7x - 0 to NULL cleanup. 3) hmc5843 - fix missing > in MODULE_AUTHOR 4) Set of strict_strto* to kstrto* conversions. 5) mxs-lradc - fix ordering of resource removal to match creation 6) mxs-lradc - add MODULE_ALIAS 7) adc7606 - drop a work pending test duplicated in core functions. 8) hmc5843 - devm_ allocation patch 9) Series of redundant breaks removed. 10) ad2s1200 - pr_err -> dev_err 11) adjd_s311 - use INT_TIME 12) ST sensors - large set of cleanups from Lee Jones and removed restriction to using only triggers provided by the st_sensors themselves from Dennis Ciocca. 13) dummy and tmp006 provide sampling_frequency via info_mask_shared_by_all. 14) tcs3472 - fix incorrect buffer size and wrong device pointer used in suspend / resume functions. 15) max1363 - use defaults for buffer setup ops as provided by the triggered buffer helpers as they are the same as were specified in max1363 driver. 16) Trivial tidy ups in a number of other drivers.
2013-09-21ARM: shmobile: update SDHI DT compatibility string to the <unit>-<soc> formatGuennadi Liakhovetski
Currently DT compatibility strings of both types can be found in the kernel sources: <unit>-<soc> and <soc>-<unit>, whereas a unique format should be followed and the former one is preferred. This patch converts the SDHI MMC driver and its users to the common standard. This is safe for now, since ATM no real products are using this driver with DT. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski+renesas@gmail.com> Acked-by: Chris Ball <cjb@laptop.org> [Removed r8a7740.dtsi portion as it is not applicable] Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2013-09-20Merge tag 'arm64-stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 Pull ARM64 fixes from Catalin Marinas: - Compat register fault reporting fix - Documentation clarification on tagged pointers - hwcap widened to 64-bit (user space already reading it as 64-bit) * tag 'arm64-stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64: arm64: Widen hwcap to be 64 bit arm64: Correctly report LR and SP for compat tasks arm64: documentation: tighten up tagged pointer documentation arm64: Make do_bad_area() function static
2013-09-20arm64: documentation: tighten up tagged pointer documentationWill Deacon
Commit d50240a5f6ce ("arm64: mm: permit use of tagged pointers at EL0") added support for tagged pointers in userspace, but the corresponding update to Documentation/ contained some imprecise statements. This patch fixes up some minor ambiguities in the text, hopefully making it more clear about exactly what the kernel expects from user virtual addresses. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-09-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) If the local_df boolean is set on an SKB we have to allocate a unique ID even if IP_DF is set in the ipv4 headers, from Ansis Atteka. 2) Some fixups for the new chipset support that went into the sfc driver, from Ben Hutchings. 3) Because SCTP bypasses a good chunk of, and actually duplicates, the logic of the ipv6 output path, some IPSEC things don't get done properly. Integrate SCTP better into the ipv6 output path so that these problems are fixed and such issues don't get missed in the future either. From Daniel Borkmann. 4) Fix skge regressions added by the DMA mapping error return checking added in v3.10, from Mikulas Patocka. 5) Kill some more IRQF_DISABLED references, from Michael Opdenacker. 6) Fix races and deadlocks in the bridging code, from Hong Zhiguo. 7) Fix error handling in tun_set_iff(), in particular don't leak resources. From Jason Wang. 8) Prevent format-string injection into xen-netback driver, from Kees Cook. 9) Fix regression added to netpoll ARP packet handling, in particular check for the right ETH_P_ARP protocol code. From Sonic Zhang. 10) Try to deal with AMD IOMMU errors when using r8169 chips, from Francois Romieu. 11) Cure freezes due to recent changes in the rt2x00 wireless driver, from Stanislaw Gruszka. 12) Don't do SPI transfers (which can sleep) in interrupt context in cw1200 driver, from Solomon Peachy. 13) Fix LEDs handling bug in 5720 tg3 chips already handled for 5719. From Nithin Sujir. 14) Make xen_netbk_count_skb_slots() count the actual number of slots that will be used, taking into consideration packing and other issues that the transmit path will run into. From David Vrabel. 15) Use the correct maximum age when calculating the bridge message_age_timer, from Chris Healy. 16) Get rid of memory leaks in mcs7780 IRDA driver, from Alexey Khoroshilov. 17) Netfilter conntrack extensions were converted to RCU but are not always freed properly using kfree_rcu(). Fix from Michal Kubecek. 18) VF reset recovery not being done correctly in qlcnic driver, from Manish Chopra. 19) Fix inverted test in ATM nicstar driver, from Andy Shevchenko. 20) Missing workqueue destroy in cxgb4 error handling, from Wei Yang. 21) Internal switch not initialized properly in bgmac driver, from Rafał Miłecki. 22) Netlink messages report wrong local and remote addresses in IPv6 tunneling, from Ding Zhi. 23) ICMP redirects should not generate socket errors in DCCP and SCTP. We're still working out how this should be handled for RAW and UDP sockets. From Daniel Borkmann and Duan Jiong. 24) We've had several bugs wherein the network namespace's loopback device gets accessed after it is free'd, NULL it out so that we can catch these problems more readily. From Eric W Biederman. 25) Fix regression in TCP RTO calculations, from Neal Cardwell. 26) Fix too early free of xen-netback network device when VIFs still exist. From Paul Durrant. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (87 commits) netconsole: fix a deadlock with rtnl and netconsole's mutex netpoll: fix NULL pointer dereference in netpoll_cleanup skge: fix broken driver ip: generate unique IP identificator if local fragmentation is allowed ip: use ip_hdr() in __ip_make_skb() to retrieve IP header xen-netback: Don't destroy the netdev until the vif is shut down net:dccp: do not report ICMP redirects to user space cnic: Fix crash in cnic_bnx2x_service_kcq() bnx2x, cnic, bnx2i, bnx2fc: Fix bnx2i and bnx2fc regressions. vxlan: Avoid creating fdb entry with NULL destination tcp: fix RTO calculated from cached RTT drivers: net: phy: cicada.c: clears warning Use #include <linux/io.h> instead of <asm/io.h> net loopback: Set loopback_dev to NULL when freed batman-adv: set the TAG flag for the vid passed to BLA netfilter: nfnetlink_queue: use network skb for sequence adjustment net: sctp: rfc4443: do not report ICMP redirects to user space net: usb: cdc_ether: use usb.h macros whenever possible net: usb: cdc_ether: fix checkpatch errors and warnings net: usb: cdc_ether: Use wwan interface for Telit modules ip6_tunnels: raddr and laddr are inverted in nl msg ...
2013-09-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "atomic_open-related fixes (Miklos' series, with EEXIST-related parts replaced with fix in fs/namei.c:atomic_open() instead of messing with the instances) + race fix in autofs + leak on failure exit in 9p" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: 9p: don't forget to destroy inode cache if fscache registration fails atomic_open: take care of EEXIST in no-open case with O_CREAT|O_EXCL in fs/namei.c vfs: don't set FILE_CREATED before calling ->atomic_open() nfs: set FILE_CREATED gfs2: set FILE_CREATED cifs: fix filp leak in cifs_atomic_open() vfs: improve i_op->atomic_open() documentation autofs4: close the races around autofs4_notify_daemon()
2013-09-18Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Misc fixes" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Fix comment for sched_info_depart sched/Documentation: Update sched-design-CFS.txt documentation sched/debug: Take PID namespace into account sched/fair: Fix small race where child->se.parent,cfs_rq might point to invalid ones
2013-09-16vfs: improve i_op->atomic_open() documentationMiklos Szeredi
Fix documentation of ->atomic_open() and related functions: finish_open() and finish_no_open(). Also add details that seem to be unclear and a source of bugs (some of which are fixed in the following series). Cc-ing maintainers of all filesystems implementing ->atomic_open(). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Sage Weil <sage@inktank.com> Cc: Steve French <sfrench@samba.org> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-09-16Merge branch 'timers/core' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer code update from Thomas Gleixner: - armada SoC clocksource overhaul with a trivial merge conflict - Minor improvements to various SoC clocksource drivers * 'timers/core' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: clocksource: armada-370-xp: Add detailed clock requirements in devicetree binding clocksource: armada-370-xp: Get reference fixed-clock by name clocksource: armada-370-xp: Replace WARN_ON with BUG_ON clocksource: armada-370-xp: Fix device-tree binding clocksource: armada-370-xp: Introduce new compatibles clocksource: armada-370-xp: Use CLOCKSOURCE_OF_DECLARE clocksource: armada-370-xp: Simplify TIMER_CTRL register access clocksource: armada-370-xp: Use BIT() ARM: timer-sp: Set dynamic irq affinity ARM: nomadik: add dynamic irq flag to the timer clocksource: sh_cmt: 32-bit control register support clocksource: em_sti: Convert to devm_* managed helpers
2013-09-16Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "Two minor cifs fixes and a minor documentation cleanup for cifs.txt" * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: cifs: update cifs.txt and remove some outdated infos cifs: Avoid calling unlock_page() twice in cifs_readpage() when using fscache cifs: Do not take a reference to the page in cifs_readpage_worker()
2013-09-15bonding: Make alb learning packet interval configurableNeil Horman
running bonding in ALB mode requires that learning packets be sent periodically, so that the switch knows where to send responding traffic. However, depending on switch configuration, there may not be any need to send traffic at the default rate of 3 packets per second, which represents little more than wasted data. Allow the ALB learning packet interval to be made configurable via sysfs Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Acked-by: Veaceslav Falico <vfalico@redhat.com> CC: Jay Vosburgh <fubar@us.ibm.com> CC: Andy Gospodarek <andy@greyhouse.net> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-15Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull misc SCSI driver updates from James Bottomley: "This patch set is a set of driver updates (megaraid_sas, fnic, lpfc, ufs, hpsa) we also have a couple of bug fixes (sd out of bounds and ibmvfc error handling) and the first round of esas2r checker fixes and finally the much anticipated big endian additions for megaraid_sas" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (47 commits) [SCSI] fnic: fnic Driver Tuneables Exposed through CLI [SCSI] fnic: Kernel panic while running sh/nosh with max lun cfg [SCSI] fnic: Hitting BUG_ON(io_req->abts_done) in fnic_rport_exch_reset [SCSI] fnic: Remove QUEUE_FULL handling code [SCSI] fnic: On system with >1.1TB RAM, VIC fails multipath after boot up [SCSI] fnic: FC stat param seconds_since_last_reset not getting updated [SCSI] sd: Fix potential out-of-bounds access [SCSI] lpfc 8.3.42: Update lpfc version to driver version 8.3.42 [SCSI] lpfc 8.3.42: Fixed issue of task management commands having a fixed timeout [SCSI] lpfc 8.3.42: Fixed inconsistent spin lock usage. [SCSI] lpfc 8.3.42: Fix driver's abort loop functionality to skip IOs already getting aborted [SCSI] lpfc 8.3.42: Fixed failure to allocate SCSI buffer on PPC64 platform for SLI4 devices [SCSI] lpfc 8.3.42: Fix WARN_ON when driver unloads [SCSI] lpfc 8.3.42: Avoided making pci bar ioremap call during dual-chute WQ/RQ pci bar selection [SCSI] lpfc 8.3.42: Fixed driver iocbq structure's iocb_flag field running out of space [SCSI] lpfc 8.3.42: Fix crash on driver load due to cpu affinity logic [SCSI] lpfc 8.3.42: Fixed logging format of setting driver sysfs attributes hard to interpret [SCSI] lpfc 8.3.42: Fixed back to back RSCNs discovery failure. [SCSI] lpfc 8.3.42: Fixed race condition between BSG I/O dispatch and timeout handling [SCSI] lpfc 8.3.42: Fixed function mode field defined too small for not recognizing dual-chute mode ...
2013-09-15DT: Add documentation for gp2ap020a00f sensorJacek Anaszewski
This patch adds device tree binding documentation for the gp2ap020a00f proximity/als sensor. Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-14iio: Add INT_TIME (integration time) channel info attributePeter Meerwald
Integration time is in seconds; it controls the measurement time and influences the gain of a sensor. There are two typical ways that scaling is implemented in a device: 1) input amplifier, 2) reference to the ADC is changed. These both result in the accuracy of the ADC varying (by applying its sampling over a more relevant range). Integration time is a way of dealing with noise inherent in the analog sensor itself. In the case of a light sensor, a mixture of photon noise and device specific noise. Photon noise is dealt with by either improving the efficiency of the sensor, (more photons actually captured) which is not easily varied dynamically, or by integrating the measurement over a longer time period. Note that this can also be thought of as an averaging of a number of individual samples and is infact sometimes implemented this way. Altering integration time implies that the duration of a measurement changes, a fact the device's user may be interested in. Hence it makes sense to distinguish between integration time and simple scale. In some devices both types of control are present and whilst they will have similar effects on the amplitude of the reading, their effect on the noise of the measurements will differ considerably. Used by adjd_s311, tsl4531, tcs3472 The following drivers have similar controls (and could be adapted): * tsl2563 (integration time is controlled via CALIBSCALE among other things) * tsl2583 (has integration_time device_attr, but driver doesn't use channels yet) * tsl2x7x (has integration_time attr) Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Cc: Jon Brenner <jon.brenner@ams.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-13cifs: update cifs.txt and remove some outdated infosBjörn Jacke
Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Björn JACKE <bj@sernet.de> Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-12Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This has been sitting in -next for a while with no objections and all MIPS defconfigs except one are building fine; that one platform got broken by another patch in your tree and I'm going to submit a patch separately. - a handful of fixes that didn't make 3.11 - a few bits of Octeon 3 support with more to come for a later release - platform enhancements for Octeon, ath79, Lantiq, Netlogic and Ralink SOCs - a GPIO driver for the Octeon - some dusting off of the DECstation code - the usual dose of cleanups" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (65 commits) MIPS: DMA: Fix BUG due to smp_processor_id() in preemptible code MIPS: kexec: Fix random crashes while loading crashkernel MIPS: kdump: Skip walking indirection page for crashkernels MIPS: DECstation HRT calibration bug fixes MIPS: Export copy_from_user_page() (needed by lustre) MIPS: Add driver for the built-in PCI controller of the RT3883 SoC MIPS: DMA: For BMIPS5000 cores flush region just like non-coherent R10000 MIPS: ralink: Add support for reset-controller API MIPS: ralink: mt7620: Add cpu-feature-override header MIPS: ralink: mt7620: Add spi clock definition MIPS: ralink: mt7620: Add wdt clock definition MIPS: ralink: mt7620: Improve clock frequency detection MIPS: ralink: mt7620: This SoC has EHCI and OHCI hosts MIPS: ralink: mt7620: Add verbose ram info MIPS: ralink: Probe clocksources from OF MIPS: ralink: Add support for systick timer found on newer ralink SoC MIPS: ralink: Add support for periodic timer irq MIPS: Netlogic: Built-in DTB for XLP2xx SoC boards MIPS: Netlogic: Add support for USB on XLP2xx MIPS: Netlogic: XLP2xx update for I2C controller ...
2013-09-12Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge more patches from Andrew Morton: "The rest of MM. Plus one misc cleanup" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (35 commits) mm/Kconfig: add MMU dependency for MIGRATION. kernel: replace strict_strto*() with kstrto*() mm, thp: count thp_fault_fallback anytime thp fault fails thp: consolidate code between handle_mm_fault() and do_huge_pmd_anonymous_page() thp: do_huge_pmd_anonymous_page() cleanup thp: move maybe_pmd_mkwrite() out of mk_huge_pmd() mm: cleanup add_to_page_cache_locked() thp: account anon transparent huge pages into NR_ANON_PAGES truncate: drop 'oldsize' truncate_pagecache() parameter mm: make lru_add_drain_all() selective memcg: document cgroup dirty/writeback memory statistics memcg: add per cgroup writeback pages accounting memcg: check for proper lock held in mem_cgroup_update_page_stat memcg: remove MEMCG_NR_FILE_MAPPED memcg: reduce function dereference memcg: avoid overflow caused by PAGE_ALIGN memcg: rename RESOURCE_MAX to RES_COUNTER_MAX memcg: correct RESOURCE_MAX to ULLONG_MAX mm: memcg: do not trap chargers with full callstack on OOM mm: memcg: rework and document OOM waiting and wakeup ...
2013-09-12memcg: document cgroup dirty/writeback memory statisticsSha Zhengju
Signed-off-by: Sha Zhengju <handai.szj@taobao.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Greg Thelen <gthelen@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 4 from Al Viro: "list_lru pile, mostly" This came out of Andrew's pile, Al ended up doing the merge work so that Andrew didn't have to. Additionally, a few fixes. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (42 commits) super: fix for destroy lrus list_lru: dynamically adjust node arrays shrinker: Kill old ->shrink API. shrinker: convert remaining shrinkers to count/scan API staging/lustre/libcfs: cleanup linux-mem.h staging/lustre/ptlrpc: convert to new shrinker API staging/lustre/obdclass: convert lu_object shrinker to count/scan API staging/lustre/ldlm: convert to shrinkers to count/scan API hugepage: convert huge zero page shrinker to new shrinker API i915: bail out earlier when shrinker cannot acquire mutex drivers: convert shrinkers to new count/scan API fs: convert fs shrinkers to new scan/count API xfs: fix dquot isolation hang xfs-convert-dquot-cache-lru-to-list_lru-fix xfs: convert dquot cache lru to list_lru xfs: rework buffer dispose list tracking xfs-convert-buftarg-lru-to-generic-code-fix xfs: convert buftarg LRU to generic code fs: convert inode and dentry shrinking to be node aware vmscan: per-node deferred work ...
2013-09-12Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull led updates from Bryan Wu: "Sorry for the late pull request, since I'm just back from vacation. LED subsystem updates for 3.12: - pca9633 driver DT supporting and pca9634 chip supporting - restore legacy device attributes for lp5521 - other fixing and updates" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: (28 commits) leds: wm831x-status: Request a REG resource leds: trigger: ledtrig-backlight: Fix invalid memory access in fb_event notification callback leds-pca963x: Fix device tree parsing leds-pca9633: Rename to leds-pca963x leds-pca9633: Add mutex to the ledout register leds-pca9633: Unique naming of the LEDs leds-pca9633: Add support for PCA9634 leds: lp5562: use LP55xx common macros for device attributes Documentation: leds-lp5521,lp5523: update device attribute information leds: lp5523: remove unnecessary writing commands leds: lp5523: restore legacy device attributes leds: lp5523: LED MUX configuration on initializing leds: lp5523: make separate API for loading engine leds: lp5521: remove unnecessary writing commands leds: lp5521: restore legacy device attributes leds: lp55xx: add common macros for device attributes leds: lp55xx: add common data structure for program Documentation: leds: Fix a typo leds: ss4200: Fix incorrect placement of __initdata leds: clevo-mail: Fix incorrect placement of __initdata ...
2013-09-12sched/Documentation: Update sched-design-CFS.txt documentationLi Bin
2bd2d6f2dc ("sched: Replace use of entity_key()") had remove the entity_key() which function is to subtract a tasks vruntime by its groups minvruntime as the rbtree key. The phrase "there is a subtraction using rq->cfs.min_vruntime to account for possible wraparounds" in documentation feels strange and meaningless. So remove it. Signed-off-by: Li Bin <huawei.libin@huawei.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1378706740-7500-1-git-send-email-huawei.libin@huawei.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-12Merge tag 'sound-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "A few last-minute fixes for 3.12-rc1. All patches are driver specific. - HD-audio fixes: MacBook 6,1/6,2 speaker fix, ASUS TX300 dock speaker fix, Toshiba Satellite irq fix, Haswell HDMI audio cleanups) - ASoC fixes: atmel irq fix, fsl DT fix, mc13783 spi fix, kirkwood compatible string change, etc" * tag 'sound-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ASoC: mc13783: add spi errata fix ASoC: rsnd: fixup flag name of rsnd_scu_platform_info ALSA: hda - Add CS4208 codec support for MacBook 6,1 and 6,2 ALSA: hda - Add Toshiba Satellite C870 to MSI blacklist ASoC: fsl_spdif: Select regmap-mmio ALSA: hda - unmute pin amplifier in infoframe setup for Haswell ALSA: hda - define is_haswell() to check if a display audio codec is Haswell ALSA: hda - Add dock speaker support for ASUS TX300 ASoC: kirkwood: change the compatible string of the kirkwood-i2s driver ASoC: atmel: disable error interrupt ASoC: fsl: imx-audmux: Do not call imx_audmux_parse_dt_defaults() on non-dt kernel
2013-09-12Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management updates from Zhang Rui: "We have a lot of SOC changes and a few thermal core fixes this time. The biggest change is about exynos thermal driver restructure. The patch set adds TMU (Thermal management Unit) driver support for exynos5440 platform. There are 3 instances of the TMU controllers so necessary cleanup/re-structure is done to handle multiple thermal zone. The next biggest change is the introduction of the imx thermal driver. It adds the imx thermal support using Temperature Monitor (TEMPMON) block found on some Freescale i.MX SoCs. The driver uses syscon regmap interface to access TEMPMON control registers and calibration data, and supports cpufreq as the cooling device. Highlights: - restructure exynos thermal driver. - introduce new imx thermal driver. - fix a bug in thermal core, which powers on the fans unexpectedly after resume from suspend" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (46 commits) drivers: thermal: add check when unregistering cpu cooling thermal: thermal_core: allow binding with limits on bind_params drivers: thermal: make usage of CONFIG_THERMAL_HWMON optional drivers: thermal: parent virtual hwmon with thermal zone thermal: hwmon: move hwmon support to single file thermal: exynos: Clean up non-DT remnants thermal: exynos: Fix potential NULL pointer dereference thermal: exynos: Fix typos in Kconfig thermal: ti-soc-thermal: Ensure to compute thermal trend thermal: ti-soc-thermal: Set the bandgap mask counter delay value thermal: ti-soc-thermal: Initialize counter_delay field for TI DRA752 sensors thermal: step_wise: return instance->target by default thermal: step_wise: cdev only needs update on a new target state Thermal/cpu_cooling: Return directly for the cpu out of allowed_cpus in the cpufreq_thermal_notifier() thermal: exynos_tmu: fix wrong error check for mapped memory thermal: imx: implement thermal alarm interrupt handling thermal: imx: dynamic passive and SoC specific critical trip points Documentation: thermal: Explain the exynos thermal driver model ARM: dts: thermal: exynos: Add documentation for Exynos SoC thermal bindings thermal: exynos: Support for TMU regulator defined at device tree ...
2013-09-12Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "CIFS update including case insensitive file name matching improvements for UTF-8 to Unicode, various small cifs fixes, SMB2/SMB3 leasing improvements, support for following SMB2 symlinks, SMB3 packet signing improvements" * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: (25 commits) CIFS: Respect epoch value from create lease context v2 CIFS: Add create lease v2 context for SMB3 CIFS: Move parsing lease buffer to ops struct CIFS: Move creating lease buffer to ops struct CIFS: Store lease state itself rather than a mapped oplock value CIFS: Replace clientCanCache* bools with an integer [CIFS] quiet sparse compile warning cifs: Start using per session key for smb2/3 for signature generation cifs: Add a variable specific to NTLMSSP for key exchange. cifs: Process post session setup code in respective dialect functions. CIFS: convert to use le32_add_cpu() CIFS: Fix missing lease break CIFS: Fix a memory leak when a lease break comes cifs: add winucase_convert.pl to Documentation/ directory cifs: convert case-insensitive dentry ops to use new case conversion routines cifs: add new case-insensitive conversion routines that are based on wchar_t's [CIFS] Add Scott to list of cifs contributors cifs: Move and expand MAX_SERVER_SIZE definition cifs: Expand max share name length to 256 cifs: Move string length definitions to uapi ...
2013-09-11Merge tag 'for-3.12' of git://git.linaro.org/people/sumitsemwal/linux-dma-bufLinus Torvalds
Pull dma-buf updates from Sumit Semwal: "Yet another small one - dma-buf framework now supports size discovery of the buffer via llseek" * tag 'for-3.12' of git://git.linaro.org/people/sumitsemwal/linux-dma-buf: dma-buf: Expose buffer size to userspace (v2) dma-buf: Check return value of anon_inode_getfile
2013-09-11Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge first patch-bomb from Andrew Morton: - Some pidns/fork/exec tweaks - OCFS2 updates - Most of MM - there remain quite a few memcg parts which depend on pending core cgroups changes. Which might have been already merged - I'll check tomorrow... - Various misc stuff all over the place - A few block bits which I never got around to sending to Jens - relatively minor things. - MAINTAINERS maintenance - A small number of lib/ updates - checkpatch updates - epoll - firmware/dmi-scan - Some kprobes work for S390 - drivers/rtc updates - hfsplus feature work - vmcore feature work - rbtree upgrades - AOE updates - pktcdvd cleanups - PPS - memstick - w1 - New "inittmpfs" feature, which does the obvious - More IPC work from Davidlohr. * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (303 commits) lz4: fix compression/decompression signedness mismatch ipc: drop ipc_lock_check ipc, shm: drop shm_lock_check ipc: drop ipc_lock_by_ptr ipc, shm: guard against non-existant vma in shmdt(2) ipc: document general ipc locking scheme ipc,msg: drop msg_unlock ipc: rename ids->rw_mutex ipc,shm: shorten critical region for shmat ipc,shm: cleanup do_shmat pasta ipc,shm: shorten critical region for shmctl ipc,shm: make shmctl_nolock lockless ipc,shm: introduce shmctl_nolock ipc: drop ipcctl_pre_down ipc,shm: shorten critical region in shmctl_down ipc,shm: introduce lockless functions to obtain the ipc object initmpfs: use initramfs if rootfstype= or root= specified initmpfs: make rootfs use tmpfs when CONFIG_TMPFS enabled initmpfs: move rootfs code from fs/ramfs/ to init/ initmpfs: move bdi setup from init_rootfs to init_ramfs ...
