commit 4ada77e37a773168fea484899201e272ab44ba8b upstream.
Fix a typo in the TX DMA interrupt name for AUART4.
This patch makes AUART4 operational again.
Fixes: f30fb03d4d3a ("ARM: dts: add generic DMA device tree binding for mxs-dma")
Acked-by: Stefan Wahren <stefan.wahren@i2se.com>
commit 148e9a711e034e06310a8c36b64957934ebe30f2 upstream.
On some laptops, keyboard needs to be reset in order to successfully detect
touchpad (e.g., some Gigabyte laptop models with Elantech touchpads).
Without resettin keyboard touchpad pretends to be completely dead.
Based on the original patch by Mateusz Jończyk this version has been
expanded to include DMI based detection & application of the fix
automatically on the affected models of laptops. This has been confirmed to
fix problem by three users already on three different models of laptops.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=81331
Signed-off-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com>
Acked-by: Mateusz Jończyk <mat.jonczyk@o2.pl>
Tested-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com>
Tested by: Zakariya Dehlawi <zdehlawi@gmail.com>
Tested-by: Guillaum Bouchard <guillaum.bouchard@gmail.com>
commit 027bc8b08242c59e19356b4b2c189f2d849ab660 upstream.
On some ARMs the memory can be mapped pgprot_noncached() and still
be working for atomic operations. As pointed out by Colin Cross
<ccross@android.com>, in some cases you do want to use
pgprot_noncached() if the SoC supports it to see a debug printk
just before a write hanging the system.
On ARMs, the atomic operations on strongly ordered memory are
implementation defined. So let's provide an optional kernel parameter
for configuring pgprot_noncached(), and use pgprot_writecombine() by
default.
Cc: Rob Herring <robherring2@gmail.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Anton Vorontsov <anton@enomsg.org>
Cc: Colin Cross <ccross@android.com>
Cc: Olof Johansson <olof@lixom.net>
Signed-off-by: Tony Luck <tony.luck@intel.com>
commit d98a0526434d27e261f622cf9d2e0028b5ff1a00 upstream.
Add a complete description of the LZO format as processed by the
decompressor. I have not found a public specification of this format
hence this analysis, which will be used to better understand the code.
Cc: Willem Pinckaers <willem@lekkertech.net>
Cc: "Don A. Bailey" <donb@securitymouse.com>
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit f42bb22243d2ae264d721b055f836059fe35321f upstream.
Just add the PCI ID for the STX II. It appears to work the same as the
STX, except for the addition of the not-yet-supported daughterboard.
Tested-by: Mario <fugazzi99@gmail.com>
Tested-by: corubba <corubba@gmx.de>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit b76fc285337b6b256e9ba20a40cfd043f70c27af upstream.
Stable_kernel_rules should point submitters of network stable patches to the
netdev_FAQ.txt as requests for stable network patches should go to netdev
first.
Signed-off-by: Dave Chiluk <chiluk@canonical.com>
commit 3891a04aafd668686239349ea58f3314ea2af86b upstream.
The IRET instruction, when returning to a 16-bit segment, only
restores the bottom 16 bits of the user space stack pointer. This
causes some 16-bit software to break, but it also leaks kernel state
to user space. We have a software workaround for that ("espfix") for
the 32-bit kernel, but it relies on a nonzero stack segment base which
is not available in 64-bit mode.
In checkin:
b3b42ac2cbae x86-64, modify_ldt: Ban 16-bit segments on 64-bit kernels
we "solved" this by forbidding 16-bit segments on 64-bit kernels, with
the logic that 16-bit support is crippled on 64-bit kernels anyway (no
V86 support), but it turns out that people are doing stuff like
running old Win16 binaries under Wine and expect it to work.
This works around this by creating percpu "ministacks", each of which
is mapped 2^16 times 64K apart. When we detect that the return SS is
on the LDT, we copy the IRET frame to the ministack and use the
relevant alias to return to userspace. The ministacks are mapped
readonly, so if IRET faults we promote #GP to #DF which is an IST
vector and thus has its own stack; we then do the fixup in the #DF
handler.
(Making #GP an IST exception would make the msr_safe functions unsafe
in NMI/MC context, and quite possibly have other effects.)
Special thanks to:
- Andy Lutomirski, for the suggestion of using very small stack slots
and copy (as opposed to map) the IRET frame there, and for the
suggestion to mark them readonly and let the fault promote to #DF.
- Konrad Wilk for paravirt fixup and testing.
- Borislav Petkov for testing help and useful comments.
Reported-by: Brian Gerst <brgerst@gmail.com>
Link: http://lkml.kernel.org/r/1398816946-3351-1-git-send-email-hpa@linux.intel.com
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Andrew Lutomriski <amluto@gmail.com>
Cc: Dirk Hohndel <dirk@hohndel.org>
Cc: Arjan van de Ven <arjan.van.de.ven@intel.com>
Cc: comex <comexk@gmail.com>
Cc: Alexander van Heukelum <heukelum@fastmail.fm>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
commit 8401aa1f59975c03eeebd3ac6d264cbdfe9af5de upstream.
Update the SubmittingPatches process to include howto about the new
'Fixes:' tag to be used when a patch fixes an issue in a previous commit
(found by git-bisect for example).
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
commit 14c63f17b1fde5a575a28e96547a22b451c71fb5 upstream.
This patch keeps track of how long perf's NMI handler is taking,
and also calculates how many samples perf can take a second. If
the sample length times the expected max number of samples
exceeds a configurable threshold, it drops the sample rate.
This way, we don't have a runaway sampling process eating up the
CPU.
This patch can tend to drop the sample rate down to level where
perf doesn't work very well. *BUT* the alternative is that my
system hangs because it spends all of its time handling NMIs.
I'll take a busted performance tool over an entire system that's
busted and undebuggable any day.
BTW, my suspicion is that there's still an underlying bug here.
Using the HPET instead of the TSC is definitely a contributing
factor, but I suspect there are some other things going on.
But, I can't go dig down on a bug like that with my machine
hanging all the time.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: paulus@samba.org
Cc: acme@ghostprotocols.net
Cc: Dave Hansen <dave@sr71.net>
[ Prettified it a bit. ]
Cc: Weng Meiling <wengmeiling.weng@huawei.com>
commit e60cbeedc48d80689c249ab5dcc3c31ad0452dea upstream.
Prior to commit 4266129964b8 ("[media] DocBook: Move all media docbook
stuff into its own directory") it was possible to build only a single
(or more) book(s) by calling, for example
make htmldocs DOCBOOKS=80211.xml
This now fails:
cp: target `.../Documentation/DocBook//media_api' is not a directory
Ignore errors from that copy to make this possible again.
Fixes: 4266129964b8 ("[media] DocBook: Move all media docbook stuff into its own directory")
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
commit 36189cc3cd57ab0f1cd75241f93fe01de928ac06 upstream.
The hw_version 3 Elantech touchpad on the Gigabyte U2442 does not accept
0x0b as initialization value for r10, this stand-alone version of the
driver: http://planet76.com/drivers/elantech/psmouse-elantech-v6.tar.bz2
Uses 0x03 which does work, so this means not setting bit 3 of r10 which
sets: "Enable Real H/W Resolution In Absolute mode"
Which will result in half the x and y resolution we get with that bit set,
so simply not setting it everywhere is not a solution. We've been unable to
find a way to identify touchpads where setting the bit will fail, so this
patch uses a dmi based blacklist for this.
https://bugzilla.kernel.org/show_bug.cgi?id=61151
Reported-by: Philipp Wolfer <ph.wolfer@gmail.com>
Tested-by: Philipp Wolfer <ph.wolfer@gmail.com>
commit 1b31e9b76ef8c62291e698dfdb973499986a7f68 upstream.
Add Device ID of Intel BayTrail SMBus Controller.
Signed-off-by: Chew, Kean ho <kean.ho.chew@intel.com>
Signed-off-by: Chew, Chiau Ee <chiau.ee.chew@intel.com>
Reviewed-by: Jean Delvare <jdelvare@suse.de>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Cc: "Chang, Rebecca Swee Fun" <rebecca.swee.fun.chang@intel.com>
commit afc659241258b40b683998ec801d25d276529f43 upstream.
This patch adds the SMBus Device IDs for the Intel Wildcat Point-LP PCH.
Signed-off-by: James Ralston <james.d.ralston@intel.com>
commit 98b0f811aade1b7c6e7806c86aa0befd5919d65f upstream.
The English and Korean translations were updated, the Chinese and Japanese
weren't.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
commit 61f0319193c44adbbada920162d880b1fdb3aeb3 upstream.
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
commit f39901c1befa556bc91902516a3e2e460000b4a8 upstream.
This patch adds the i801 SMBus Controller DeviceIDs for the Intel Coleto Creek PCH.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
Cc: "Chan, Wei Sern" <wei.sern.chan@intel.com>
commit 778c14affaf94a9e4953179d3e13a544ccce7707 upstream.
A 3% of system memory bonus is sometimes too excessive in comparison to
other processes.
With commit a63d83f427fb ("oom: badness heuristic rewrite"), the OOM
killer tries to avoid killing privileged tasks by subtracting 3% of
overall memory (system or cgroup) from their per-task consumption. But
as a result, all root tasks that consume less than 3% of overall memory
are considered equal, and so it only takes 33+ privileged tasks pushing
the system out of memory for the OOM killer to do something stupid and
kill dhclient or other root-owned processes. For example, on a 32G
machine it can't tell the difference between the 1M agetty and the 10G
fork bomb member.
The changelog describes this 3% boost as the equivalent to the global
overcommit limit being 3% higher for privileged tasks, but this is not
the same as discounting 3% of overall memory from _every privileged task
individually_ during OOM selection.
Replace the 3% of system memory bonus with a 3% of current memory usage
bonus.
By giving root tasks a bonus that is proportional to their actual size,
they remain comparable even when relatively small. In the example
above, the OOM killer will discount the 1M agetty's 256 badness points
down to 179, and the 10G fork bomb's 262144 points down to 183500 points
and make the right choice, instead of discounting both to 0 and killing
agetty because it's first in the task list.
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Johannes Weiner <hannes@cmpxchg.org>
commit b1f5c73bd5a4752efb7d7af019034044b08aafe9 upstream.
The sata_mv driver supports the SATA IP found in several Marvell SoCs.
As some new SATA registers have been introduced with the Armada 370/XP
SoCs, a way to identify them is needed.
This patch introduces a new compatible string for the SATA IP found in
Armada 370/XP SoCs.
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Lior Amsalem <alior@marvell.com>
Acked-by: Jason Cooper <jason@lakedaemon.net>
[ Upstream commit 66e56cd46b93ef407c60adcac62cf33b06119d50 ]
Commit e40526cb20b5 introduced a cached dev pointer, that gets
hooked into register_prot_hook(), __unregister_prot_hook() to
update the device used for the send path.
We need to fix this up, as otherwise this will not work with
sockets created with protocol = 0, plus with sll_protocol = 0
passed via sockaddr_ll when doing the bind.
So instead, assign the pointer directly. The compiler can inline
these helper functions automagically.
While at it, also assume the cached dev fast-path as likely(),
and document this variant of socket creation as it seems it is
not widely used (seems not even the author of TX_RING was aware
of that in his reference example [1]). Tested with reproducer
from e40526cb20b5.
[1] http://wiki.ipxwarzone.com/index.php5?title=Linux_packet_mmap#Example
Fixes: e40526cb20b5 ("packet: fix use after free race in send path when dev is released")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Tested-by: Salam Noureddine <noureddine@aristanetworks.com>
Tested-by: Jesper Dangaard Brouer <brouer@redhat.com>
commit b8bd6dc36186fe99afa7b73e9e2d9a98ad5c4865 upstream.
A user on StackExchange had a failing SSD that's soldered directly
onto the motherboard of his system. The BIOS does not give any option
to disable it at all, so he can't just hide it from the OS via the
BIOS.
The old IDE layer had hdX=noprobe override for situations like this,
but that was never ported to the libata layer.
This patch implements a disable flag for libata.force.
Example use:
libata.force=2.0:disable
[v2 of the patch, removed the nodisable flag per Tejun Heo]
Signed-off-by: Robin H. Johnson <robbat2@gentoo.org>
Link: http://unix.stackexchange.com/questions/102648/how-to-tell-linux-kernel-3-0-to-completely-ignore-a-failing-disk
Link: http://askubuntu.com/questions/352836/how-can-i-tell-linux-kernel-to-completely-ignore-a-disk-as-if-it-was-not-even-co
Link: http://superuser.com/questions/599333/how-to-disable-kernel-probing-for-drive
commit 966fbe193f47c68e70a80ec9991098e88e7959cb upstream.
Some device require DMADIR to be enabled, but are not detected as such
by atapi_id_dmadir. One such example is "Asus Serillel 2"
SATA-host-to-PATA-device bridge: the bridge itself requires DMADIR,
even if the bridged device does not.
As atapi_dmadir module parameter can cause problems with some devices
(as per Tejun Heo's memory), enabling it globally may not be possible
depending on the hardware.
This patch adds atapi_dmadir in the form of a "force" horkage value,
allowing global, per-bus and per-device control.
Signed-off-by: Vincent Pelletier <plr.vincent@gmail.com>
[ Upstream commit 98e09386c0ef4dfd48af7ba60ff908f0d525cdee ]
After commit c9eeec26e32e ("tcp: TSQ can use a dynamic limit"), several
users reported throughput regressions, notably on mvneta and wifi
adapters.
802.11 AMPDU requires a fair amount of queueing to be effective.
This patch partially reverts the change done in tcp_write_xmit()
so that the minimal amount is sysctl_tcp_limit_output_bytes.
It also remove the use of this sysctl while building skb stored
in write queue, as TSO autosizing does the right thing anyway.
Users with well behaving NICS and correct qdisc (like sch_fq),
can then lower the default sysctl_tcp_limit_output_bytes value from
128KB to 8KB.
This new usage of sysctl_tcp_limit_output_bytes permits each driver
authors to check how their driver performs when/if the value is set
to a minimum of 4KB.
Normally, line rate for a single TCP flow should be possible,
but some drivers rely on timers to perform TX completion and
too long TX completion delays prevent reaching full throughput.
Fixes: c9eeec26e32e ("tcp: TSQ can use a dynamic limit")
Reported-by: Sujith Manoharan <sujith@msujith.org>
Reported-by: Arnaud Ebalard <arno@natisbad.org>
Tested-by: Sujith Manoharan <sujith@msujith.org>
Cc: Felix Fietkau <nbd@openwrt.org>
commit 312b4e226951f707e120b95b118cbc14f3d162b2 upstream.
Some setuid binaries will allow reading of files which have read
permission by the real user id. This is problematic with files which
use %pK because the file access permission is checked at open() time,
but the kptr_restrict setting is checked at read() time. If a setuid
binary opens a %pK file as an unprivileged user, and then elevates
permissions before reading the file, then kernel pointer values may be
leaked.
This happens for example with the setuid pppd application on Ubuntu 12.04:
$ head -1 /proc/kallsyms
00000000 T startup_32
$ pppd file /proc/kallsyms
pppd: In file /proc/kallsyms: unrecognized option 'c1000000'
This will only leak the pointer value from the first line, but other
setuid binaries may leak more information.
Fix this by adding a check that in addition to the current process having
CAP_SYSLOG, that effective user and group ids are equal to the real ids.
If a setuid binary reads the contents of a file which uses %pK then the
pointer values will be printed as NULL if the real user is unprivileged.
Update the sysctl documentation to reflect the changes, and also correct
the documentation to state the kptr_restrict=0 is the default.
This is a only temporary solution to the issue. The correct solution is
to do the permission check at open() time on files, and to replace %pK
with a function which checks the open() time permission. %pK uses in
printk should be removed since no sane permission check can be done, and
instead protected by using dmesg_restrict.
Signed-off-by: Ryan Mallon <rmallon@gmail.com>
Cc: Joe Perches <joe@perches.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
[ Upstream commits 6d36824e730f247b602c90e8715a792003e3c5a7,
02cf4ebd82ff0ac7254b88e466820a290ed8289a, and parts of
7eec4174ff29cd42f2acfae8112f51c228545d40 ]
After hearing many people over past years complaining against TSO being
bursty or even buggy, we are proud to present automatic sizing of TSO
packets.
One part of the problem is that tcp_tso_should_defer() uses an heuristic
relying on upcoming ACKS instead of a timer, but more generally, having
big TSO packets makes little sense for low rates, as it tends to create
micro bursts on the network, and general consensus is to reduce the
buffering amount.
This patch introduces a per socket sk_pacing_rate, that approximates
the current sending rate, and allows us to size the TSO packets so
that we try to send one packet every ms.
This field could be set by other transports.
Patch has no impact for high speed flows, where having large TSO packets
makes sense to reach line rate.
For other flows, this helps better packet scheduling and ACK clocking.
This patch increases performance of TCP flows in lossy environments.
A new sysctl (tcp_min_tso_segs) is added, to specify the
minimal size of a TSO packet (default being 2).
A follow-up patch will provide a new packet scheduler (FQ), using
sk_pacing_rate as an input to perform optional per flow pacing.
This explains why we chose to set sk_pacing_rate to twice the current
rate, allowing 'slow start' ramp up.
sk_pacing_rate = 2 * cwnd * mss / srtt
v2: Neal Cardwell reported a suspect deferring of last two segments on
initial write of 10 MSS, I had to change tcp_tso_should_defer() to take
into account tp->xmit_size_goal_segs
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Van Jacobson <vanj@google.com>
Cc: Tom Herbert <therbert@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
commit 8bfd4a68ecc003c1a142f35551be846d6b13e822 upstream.
Fixes the last three errors of media_api DocBook validatation:
media_api.xml:414: element imagedata: validity error : Value "SVG" for attribute format of imagedata is not among the enumerated set
media_api.xml:432: element imagedata: validity error : Value "SVG" for attribute format of imagedata is not among the enumerated set
media_api.xml:452: element imagedata: validity error : Value "SVG" for attribute format of imagedata is not among the enumerated set
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
commit 30b146d1cb5e7560192057098eb705118bd5511f upstream.
The temperature reporting interface stays the same, so we just
add the PCI-ID to the list.
Verified on AMD Olive Hill.
Signed-off-by: Wei Hu <wei@aristanetworks.com>
Acked-by: Clemens Ladisch <clemens@ladisch.de>
commit b996ac90f595dda271cbd858b136b45557fc1a57 upstream.
To add AMD CZ SMBus controller device ID.
[bhelgaas: drop pci_ids.h update]
Signed-off-by: Shane Huang <shane.huang@amd.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Tejun Heo <tj@kernel.org>
Reviewed-by: Jean Delvare <khali@linux-fr.org>
commit a83f58bcb24003b9de2364de7c829a263423ead7 upstream.
Signed-off-by: Helge Deller <deller@gmx.de>
Pull networking fixes from David Miller:
1) Found via trinity:
If you connect up an ipv6 socket to an ipv4 mapped address then an
ipv6 one, sendmsg() can croak because ip6_sk_dst_check() assumes the
route cached in the socket is an ipv6 one. In this case there is an
ipv4 route attached, so it gets stomped on.
Reported by Dave Jones and Hannes Frederic Sowa, fixed by Eric
Dumazet.
2) AF_KEY notifications leak some kernel memory to userspace, fix from
Mathias Krause.
3) DLCI calls __dev_get_by_name() without proper locking, and dlci_del
doesn't validate that the device being deleted is actually a DLCI
one. Fixes from Li Zefan.
4) Length check on bluetooth l2cap information responses is wrong, each
response type has a different lenth, so we should make sure it's in
a given range rather than enforce one single valid length. From
Jaganath Kanakkassery.
5) Receive FIFO overflow is really easy to trigger in stress scenerios
in the sh_eth driver, but the event isn't being handled properly at
all. Specifically, the mask of error interrupts doesn't include the
event so we never clear it, resulting in the driver becomming wedged
processing an interrupt that never gets cleared.
Fix from Sergei Shtylyov.
6) qlcnic sleeps while holding a spinlock, use mdelay() instead of
msleep(). From Shahed Shaikh.
7) Missing curly braces causes SIP netfilter NAT module to always drop
packets. Fix from Balazs Peter Odor.
8) ipt_ULOG in netfilter passes the wrong value to timer setup, causing
the timer to dereference crap when it fires. Fix from Gao Feng.
9) Missing RCU protection around txq->axq_acq traversal in
ath_txq_schedule(). Fix from Felix Fietkau.
10) Idle state transition test in ath9k_htc_config() is reversed, fix
from Sujith Manoharan.
11) IPV6 forwarding handles unicast Router Alert packets incorrectly.
It tests the wrong option state. Previously opt->ra being non-zero
indicated a router alert marking in the SKB, but now it's indicated
by a bit in opt->flags. Fix from YOSHIFUJI Hideaki.
12) SKB leak in GRE tunnel GSO handling, from Eric Dumazet.
13) get_user_pages_fast() error handling in TUN and MACVTAP use the same
local variable for the base index and the loop iterator for page
traversal, oops! Fix from Michael S Tsirkin.
14) ipv6_get_lladdr() can fail, and we must therefore check it's return
value in inet6_set_iftoken(). For from Hannes Frederic Sowa.
15) If you change an interface name and meanwhile can sneak in something
that looks up the name (like SO_BINDTODEVICE or SIOCGIFNAME) we can
deadlock with CONFIG_PREEMPT=n. Fix this by providing a helper
function that properly uses raw_seqcount_begin(). From Nicolas
Schichan.
16) Chain noise calibration test is inverted in iwlwifi, fix from
Nikolay Martynov.
17) Properly set TX iwlwifi descriptor flags for back requests. Fix
from Emmanuel Grumbach.
18) We can't assume skb_transport_header() is set in xt_TCPOPTSTRAP
module, fix from Pablo Neira Ayuso.
19) Some crummy APs don't provide the proper High Throughput info in
association response frames. Add a workaround by assume we'll use
whatever is in the beacon/probe. Fix from Johannes Berg.
20) mac80211 call to rate_idx_match_mask() swaps two arguments (mask and
channel width). Fix from Simon Wunderlich.
21) xt_TCPMSS (like xt_TCPOPTSTRAP) must not try to handle fragmented
frames. Fix from Phil Oester.
22) Fix rate control regression causing iwlwifi/iwlegacy chips to use
1Mbit/s on pre-11n networks. From Moshe Benji and Stanslaw Gruszka.
23) Disable brcmsmac power-save functions, they cause regressions. From
Arend van Spriel.
24) Enforce a sane minimum MTU in l2cap_build_cmd() otherwise we can
easily crash. Fix from Anderson Lizardo.
25) If a learning packet arrives during vxlan_stop() we crash, easily
fixed by checking netif_running(). From Stephen Hemminger.
26) Static vxlan FDB entries should not be migrated, also from Stephen.
27) skb_clone() failures not handled in vxlan_xmit(), oops. Also from
Stephen.
28) Add minimal driver for AR816x/AR817x ethernet chips, from Johannes
Berg.
29) Fix regression in userspace VLAN acceleration control, added by the
802.1ad support changes. Fix from Fernando Luis Vazquez Cao.
30) Interval selection for MLD queries in the bridging code was
reversed. Fix from Linus Lüssing.
31) ipv6's ndisc_send_redirect() erroneously writes to the packet we
received not the packet we are building to send out. Fix from
Matthias Schiffer.
32) Don't free netdev before unregistering it, in usb_8dev can driver.
From Marc Kleine-Budde.
33) Fix nl80211 attribute buffer races, from Johannes Berg.
34) Although netlink_diag.h is under uapi/ it isn't present in Kbuild.
35) Wrong address and family passed to MD5 key lookups in TCP, from
Aydin Arik.
36) phy_type attribute created by SFC driver should not be writable.
From Ben Hutchings.
37) Receive/Transmit queue allocations in pxa168_eth and mv643xx_eth
should use kzalloc(). Otherwise if setup fails half-way, we'll
dereference garbage when trying to teardown the rings. From Lubomir
Rintel.
38) Fix double-allocation of dst (resulting in unfreeable net device) in
ipv6's init_loopback(). From Gao Feng.
39) Fix fragmentation handling SKB leak in netfilter conntrack, we were
freeing the wrong skb pointer. From Phil Oester.
40) Don't report "-1" (SPEED_UNKNOWN) in bond_miimon_commit(), from
Nikolay Aleksandrov.
41) davinci_cpdma doesn't check for DMA mapping errors, letting the
device scribble to random addresses. From Sebastian Siewior.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (69 commits)
dlci: validate the net device in dlci_del()
dlci: acquire rtnl_lock before calling __dev_get_by_name()
af_key: fix info leaks in notify messages
ipv6: ip6_sk_dst_check() must not assume ipv6 dst
net: fix kernel deadlock with interface rename and netdev name retrieval.
net/tg3: Avoid delay during MMIO access
ipv6: check return value of ipv6_get_lladdr
macvtap: fix recovery from gup errors
tun: fix recovery from gup errors
gre: fix a possible skb leak
ipv6: Process unicast packet with Router Alert by checking flag in skb.
ath9k_htc: Handle IDLE state transition properly
ath9k: fix an RCU issue in calling ieee80211_get_tx_rates
netfilter: ipt_ULOG: fix incorrect setting of ulog timer
netfilter: ctnetlink: send event when conntrack label was modified
netfilter: nf_nat_sip: fix mangling
qlcnic: Do not sleep while holding spinlock
drivers: net: cpsw: fix compilation error with cpsw driver
tcp: doc : fix the syncookies default value
sh_eth: fix misreporting of transmit abort
syncookies is on for default since in commit e994b7c901
(tcp: Don't make syn cookies initial setting depend on CONFIG_SYSCTL).
And fix a typo of CONFIG_SYN_COOKIES.
Signed-off-by: Shan Wei <davidshan@tencent.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Only driver/device-specific small fixes that are pretty safe to apply:
- USB-audio Android and Logitech webcam fixes
- HD-audio MacBook Air 4,2 quirk
- Complete Dell headset quirk entries that were introduced in 3.10"
* tag 'sound-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda - Add models for Dell headset jacks
ALSA: usb-audio: Fix invalid volume resolution for Logitech HD Webcam c310
ALSA: hda - Fix pin configurations for MacBook Air 4,2
ALSA: usb-audio: work around Android accessory firmware bug
ALSA: hda - Headset mic support for three more machines
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
"Series of fixes for 3.10. There are some usual driver fixes (mostly
on s5p/exynos playform drivers), plus some fixes at V4L2 core"
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (40 commits)
[media] soc_camera: error dev remove and v4l2 call
[media] sh_veu: fix the buffer size calculation
[media] sh_veu: keep power supply until the m2m context is released
[media] sh_veu: invoke v4l2_m2m_job_finish() even if a job has been aborted
[media] v4l2-ioctl: don't print the clips list
[media] v4l2-ctrls: V4L2_CTRL_CLASS_FM_RX controls are also valid radio controls
[media] cx88: fix NULL pointer dereference
[media] DocBook/media/v4l: update version number
[media] exynos4-is: Remove "sysreg" clock handling
[media] exynos4-is: Fix reported colorspace at FIMC-IS-ISP subdev
[media] exynos4-is: Ensure fimc-is clocks are not enabled until properly configured
[media] exynos4-is: Prevent NULL pointer dereference when firmware isn't loaded
[media] s5p-mfc: Add NULL check for allocated buffer
[media] s5p-mfc: added missing end-of-lines in debug messages
[media] s5p-mfc: v4l2 controls setup routine moved to initialization code
[media] s5p-mfc: separate encoder parameters for h264 and mpeg4
[media] s5p-mfc: Remove special clock usage in driver
[media] s5p-mfc: Remove unused s5p_mfc_get_decoded_status_v6() function
[media] v4l2: mem2mem: save irq flags correctly
[media] coda: v4l2-compliance fix: add VIDIOC_CREATE_BUFS support
These headset jacks keep coming in on more and more platforms, and
it's possible I don't catch them all. Make it easier to test and
verify by making models.
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
Pull block layer fixes from Jens Axboe:
"Outside of bcache (which really isn't super big), these are all
few-liners. There are a few important fixes in here:
- Fix blk pm sleeping when holding the queue lock
- A small collection of bcache fixes that have been done and tested
since bcache was included in this merge window.
- A fix for a raid5 regression introduced with the bio changes.
- Two important fixes for mtip32xx, fixing an oops and potential data
corruption (or hang) due to wrong bio iteration on stacked devices."
* 'for-linus' of git://git.kernel.dk/linux-block:
scatterlist: sg_set_buf() argument must be in linear mapping
raid5: Initialize bi_vcnt
pktcdvd: silence static checker warning
block: remove refs to XD disks from documentation
blkpm: avoid sleep when holding queue lock
mtip32xx: Correctly handle bio->bi_idx != 0 conditions
mtip32xx: Fix NULL pointer dereference during module unload
bcache: Fix error handling in init code
bcache: clarify free/available/unused space
bcache: drop "select CLOSURES"
bcache: Fix incompatible pointer type warning
Add support for the at91sam9x5-family which must use the shadow
interrupt mask due to a hardware issue (causing RTC_IMR to always be
zero).
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Douglas Gilbert <dgilbert@interlog.com>
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Cc: Ludovic Desroches <ludovic.desroches@atmel.com>
Cc: Robert Nelson <Robert.Nelson@digikey.com>
The version number was still 3.9: update to 3.10.
Pull slave-dmaengine fixes from Vinod Koul:
"Fix from Andy is for dmatest regression reported by Will and Rabin has
fixed runtime ref counting for st_dma40"
* 'fixes' of git://git.infradead.org/users/vkoul/slave-dma:
dmatest: do not allow to interrupt ongoing tests
dmaengine: ste_dma40: fix pm runtime ref counting
When user interrupts ongoing transfers the dmatest may end up with console
lockup, oops, or data mismatch. This patch prevents user to abort any ongoing
test.
Documentation is updated accordingly.
Reported-by: Will Deacon <will.deacon@arm.com>
Tested-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Pull more xfs updates from Ben Myers:
"Here are several fixes for filesystems with CRC support turned on:
fixes for quota, remote attributes, and recovery. There is also some
feature work related to CRCs: the implementation of CRCs for the inode
unlinked lists, disabling noattr2/attr2 options when appropriate, and
bumping the maximum number of ACLs.
I would have preferred to defer this last category of items to 3.11.
This would require setting a feature bit for the on-disk changes, so
there is some pressure to get these in 3.10. I believe this
represents the end of the CRC related queue.
- Rework of dquot CRCs
- Fix for remote attribute invalidation of a leaf
- Fix ordering of transaction replay in recovery
- Implement CRCs for inode unlinked list
- Disable noattr2/attr2 mount options when CRCs are enabled
- Bump the limitation of ACL entries for v5 superblocks"
* tag 'for-linus-v3.10-rc5' of git://oss.sgi.com/xfs/xfs:
xfs: increase number of ACL entries for V5 superblocks
xfs: disable noattr2/attr2 mount options for CRC enabled filesystems
xfs: inode unlinked list needs to recalculate the inode CRC
xfs: fix log recovery transaction item reordering
xfs: fix remote attribute invalidation for a leaf
xfs: rework dquot CRCs
attr2 format is always enabled for v5 superblock filesystems, so the
mount options to enable or disable it need to be cause mount errors.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
(cherry picked from commit d3eaace84e40bf946129e516dcbd617173c1cf14)
transactions
When in an active transaction that takes a signal, we need to be careful with
the stack. It's possible that the stack has moved back up after the tbegin.
The obvious case here is when the tbegin is called inside a function that
returns before a tend. In this case, the stack is part of the checkpointed
transactional memory state. If we write over this non transactionally or in
suspend, we are in trouble because if we get a tm abort, the program counter
and stack pointer will be back at the tbegin but our in memory stack won't be
valid anymore.
To avoid this, when taking a signal in an active transaction, we need to use
the stack pointer from the checkpointed state, rather than the speculated
state. This ensures that the signal context (written tm suspended) will be
written below the stack required for the rollback. The transaction is aborted
becuase of the treclaim, so any memory written between the tbegin and the
signal will be rolled back anyway.
For signals taken in non-TM or suspended mode, we use the
normal/non-checkpointed stack pointer.
Tested with 64 and 32 bit signals
Signed-off-by: Michael Neuling <mikey@neuling.org>
Cc: <stable@vger.kernel.org> # v3.9
If we are emulating an instruction inside an active user transaction that
touches memory, the kernel can't emulate it as it operates in transactional
suspend context. We need to abort these transactions and send them back to
userspace for the hardware to rollback.
We can service these if the user transaction is in suspend mode, since the
kernel will operate in the same suspend context.
This adds a check to all alignment faults and to specific instruction
emulations (only string instructions for now). If the user process is in an
active (non-suspended) transaction, we abort the transaction go back to
userspace allowing the HW to roll back the transaction and tell the user of the
failure. This also adds new tm abort cause codes to report the reason of the
persistent error to the user.
Crappy test case here http://neuling.org/devel/junkcode/aligntm.c
Cc: <stable@vger.kernel.org> # 3.9 only
Merge fixes from Andrew Morton:
"A bunch of fixes and one simple fbdev driver which missed the merge
window because people will still talking about it (to no great
effect)."
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (30 commits)
aio: fix kioctx not being freed after cancellation at exit time
mm/pagewalk.c: walk_page_range should avoid VM_PFNMAP areas
drivers/rtc/rtc-max8998.c: check for pdata presence before dereferencing
ocfs2: goto out_unlock if ocfs2_get_clusters_nocache() failed in ocfs2_fiemap()
random: fix accounting race condition with lockless irq entropy_count update
drivers/char/random.c: fix priming of last_data
mm/memory_hotplug.c: fix printk format warnings
nilfs2: fix issue of nilfs_set_page_dirty() for page at EOF boundary
drivers/block/brd.c: fix brd_lookup_page() race
fbdev: FB_GOLDFISH should depend on HAS_DMA
drivers/rtc/rtc-pl031.c: pass correct pointer to free_irq()
auditfilter.c: fix kernel-doc warnings
aio: fix io_getevents documentation
revert "selftest: add simple test for soft-dirty bit"
drivers/leds/leds-ot200.c: fix error caused by shifted mask
mm/THP: use pmd_populate() to update the pmd with pgtable_t pointer
linux/kernel.h: fix kernel-doc warning
mm compaction: fix of improper cache flush in migration code
rapidio/tsi721: fix bug in MSI interrupt handling
hfs: avoid crash in hfs_bnode_create
A simple frame-buffer describes a raw memory region that may be rendered
to, with the assumption that the display hardware has already been set
up to scan out from that buffer.
This is useful in cases where a bootloader exists and has set up the
display hardware, but a Linux driver doesn't yet exist for the display
hardware.
Examples use-cases include:
* The built-in LCD panels on the Samsung ARM chromebook, and Tegra
devices, and likely many other ARM or embedded systems. These cannot
yet be supported using a full graphics driver, since the panel control
should be provided by the CDF (Common Display Framework), which has been
stuck in design/review for quite some time. One could support these
panels using custom SoC-specific code, but there is a desire to use
common infra-structure rather than having each SoC vendor invent their
own code, hence the desire to wait for CDF.
* Hardware for which a full graphics driver is not yet available, and
the path to obtain one upstream isn't yet clear. For example, the
Raspberry Pi.
* Any hardware in early stages of upstreaming, before a full graphics
driver has been tackled. This driver can provide a graphical boot
console (even full X support) much earlier in the upstreaming process,
thus making new SoC or board support more generally useful earlier.
[akpm@linux-foundation.org: make simplefb_formats[] static]
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: Olof Johansson <olof@lixom.net>
Cc: Rob Clark <robclark@gmail.com>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Tomasz Figa <tomasz.figa@gmail.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Update RapidIO documentation to reflect changes made to
enumeration/discovery build configuration and user space triggering
mechanism.
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Li Yang <leoli@freescale.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Andre van Herk <andre.van.herk@Prodrive.nl>
Cc: Micha Nelissen <micha.nelissen@Prodrive.nl>
Ensure the compatible property for FIMC-LITE IP blocks is properly
documented, a cut&paste error fix.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
The Codec section in the V4L2 specification was marked as 'suspended', even
though codec support has been around for quite some time. Update this
section, explaining a bit about memory-to-memory devices and pointing to
the MPEG controls section.
Acked-by: Kamil Debski <k.debski@samsung.com>
From Nicolas Ferre:
An important revert on at91rm9200 platform related
to timers that prevented the platform to boot properly.
Then one pinctrl adjustments for SPI CS and a couple of
trivial typos.
* tag 'at91-fixes' of git://github.com/at91linux/linux-at91:
ARM: at91: rm9200 fix time support
ARM: at91: dts: request only spi cs-gpios used on sama5d3x cpu module
ARM: at91/trivial: typo in GEM compatible string
ARM: at91/trivial: fix model name for SAM9X25-EK
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
Pull Xen fixes from Konrad Rzeszutek Wilk:
- Regression fix in xen privcmd fixing a memory leak.
- Add Documentation for tmem driver.
- Simplify and remove code in the tmem driver.
- Cleanups.
* tag 'stable/for-linus-3.10-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: Fixed assignment error in if statement
xen/xenbus: Fixed over 80 character limit issue
xen/xenbus: Fixed indentation error in switch case
xen/tmem: Don't use self[ballooning|shrinking] if frontswap is off.
xen/tmem: Remove the usage of '[no|]selfballoon' and use 'tmem.selfballooning' bool instead.
xen/tmem: Remove the usage of 'noselfshrink' and use 'tmem.selfshrink' bool instead.
xen/tmem: Remove the boot options and fold them in the tmem.X parameters.
xen/tmem: s/disable_// and change the logic.
xen/tmem: Fix compile warning.
xen/tmem: Split out the different module/boot options.
xen/tmem: Move all of the boot and module parameters to the top of the file.
xen/tmem: Cleanup. Remove the parts that say temporary.
xen/privcmd: fix condition in privcmd_close()
