git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"All small fixes in random various drivers, mostly for ASoC at this
time, which look reasonable for a high rc number"
* tag 'sound-3.17-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ASoC: rockchip-i2s: dt: swap tx and rx channed request number in example
ASoC: rockchip-i2s: fix registers' property of rockchip i2s controller
ASoC: rockchip-i2s: fix master mode set bit error
ASoC: cs4265: Fix register address to set the proper data type.
ALSA: hda - Fix invalid pin powermap without jack detection
ASoC: soc-pcm: fix dpcm_path_get error handling
ASoC: samsung-i2s: Check secondary DAI exists before referencing
ASoC: Update email id of the author
ASoC: dwc: Update email id of the author
ASoC: davinci-mcasp: Correct rx format unit configuration
ASoC: tlv320aic31xx: Fix 24bit samples with I2S format and 12MHz mclk
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi fixes from Mark Brown:
"A few driver specific fixes for v3.17:
- Fix davinci so that GPIO chip selects work with deferred probe of
GPIOs (which could happen in production depending on kernel config)
plus one incremental stylistic fix to that.
- Several fixes for the newly introduced rockchip driver that came up
in wider testing of the device.
- A couple of small things in the sirf driver, one bug that would
stop DMA transfers working and another update to follow the
documented procedure in the datasheet.
- Fix some memory leaks with devm_kzalloc() being used outside of the
device bind path"
* tag 'spi-v3.17-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi:
spi: davinci: remove empty function davinci_spi_cleanup
spi: davinci: request cs_gpio's from probe
spi/pl022: Fix error message
spi/rockchip: Mark DMA as optional
spi/rockchip: Don't warn if SPI is busy but disabled
spi/rockchip: Fix the wait_for_idle() timeout
spi: sirf: add fifo reset/start for cmd transfer
spi: sirf: enable RX_IO_DMA_INT interrupt
spi: dw: Don't use devm_kzalloc in master->setup callback
spi: fsl: Don't use devm_kzalloc in master->setup callback
'spi/fix/fsl', 'spi/fix/pl022', 'spi/fix/rockchip' and 'spi/fix/sirf' into spi-linus
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"A few quirks for i8042/AT keyboards and a small device tree doc fix
for Atmel Touchscreens"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: atmel_mxt_ts - fix merge in DT documentation
Input: i8042 - also set the firmware id for MUXed ports
Input: i8042 - add nomux quirk for Avatar AVIU-145A6
Input: i8042 - add Fujitsu U574 to no_timeout dmi table
Input: atkbd - do not try 'deactivate' keyboard on any LG laptops
'asoc/fix/rockchip', 'asoc/fix/samsung' and 'asoc/fix/tlv320aic31xx' into asoc-linus
Reference to RK3288 TRM, fix an error channel id for i2s tx and rx
Table 10-1 DMAC_BUS Request Mapping Table
Req number Source Polarity
0 I2S tx High level
1 I2S rx High level
Tested on RK3288 board.
Signed-off-by: Jianqun <jay.xu@rock-chips.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are some USB and PHY fixes for 3.17-rc5.
Nothing major here, just a number of tiny fixes for reported issues,
and some new device ids as well.
All have been tested in linux-next"
* tag 'usb-3.17-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (46 commits)
xhci: fix oops when xhci resumes from hibernate with hw lpm capable devices
usb: xhci: Fix OOPS in xhci error handling code
xhci: Fix null pointer dereference if xhci initialization fails
storage: Add single-LUN quirk for Jaz USB Adapter
uas: Add missing le16_to_cpu calls to asm1051 / asm1053 usb-id check
usb: chipidea: msm: Initialize PHY on reset event
usb: chipidea: msm: Use USB PHY API to control PHY state
usb: hub: take hub->hdev reference when processing from eventlist
uas: Disable uas on ASM1051 devices
usb: dwc2/gadget: avoid disabling ep0
usb: dwc2/gadget: delay enabling irq once hardware is configured properly
usb: dwc2/gadget: do not call disconnect method in pullup
usb: dwc2/gadget: break infinite loop in endpoint disable code
usb: dwc2/gadget: fix phy initialization sequence
usb: dwc2/gadget: fix phy disable sequence
uwb: init beacon cache entry before registering uwb device
USB: ftdi_sio: Add support for GE Healthcare Nemo Tracker device
USB: document the 'u' flag for usb-storage quirks parameter
usb: host: xhci: fix compliance mode workaround
usb: dwc3: fix TRB completion when multiple TRBs are started
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull fbdev fixes from Tomi Valkeinen:
"Minor fixes for amba-clcd and video DT bindings"
* tag 'fbdev-fixes-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux:
video: ARM CLCD: Fix color model capabilities for DT platforms
video: fix composite video connector compatible string
Something went a bit wrong in merging f5940231a - there's a bit of repeated
text that's been introduced.
Signed-off-by: Nick Dyer <nick.dyer@itdev.co.uk>
Pull dmaengine fixes from Vinod Koul:
"Two minor fixes.
First one from Kuninori clarifying dmas bindings and second from Lars
for fixing dma descriptor completion in non cyclic case"
* 'fixes' of git://git.infradead.org/users/vkoul/slave-dma:
dmaengine: jz4740: Fix non-cyclic descriptor completion
dt/bindings: rcar-audmapp: tidyup dmas explanation
Commit d24d481b7d36 (usb-storage: Modify and export adjust_quirks so
that it can be used by uas) added the 'u' flag to the quirks module
parameter for usb-storage, but neglected to update the
documentation. This patch adds the documentation.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Cc: stable <stable@vger.kernel.org> # 3.15+
Pull networking fixes from David Miller:
1) Fix skb leak in mac802154, from Martin Townsend
2) Use select not depends on NF_NAT for NFT_NAT, from Pablo Neira
Ayuso
3) Fix union initializer bogosity in vxlan, from Gerhard Stenzel
4) Fix RX checksum configuration in stmmac driver, from Giuseppe
CAVALLARO
5) Fix TSO with non-accelerated VLANs in e1000, e1000e, bna, ehea,
i40e, i40evf, mvneta, and qlge, from Vlad Yasevich
6) Fix capability checks in phy_init_eee(), from Giuseppe CAVALLARO
7) Try high order allocations more sanely for SKBs, specifically if a
high order allocation fails, fall back directly to zero order pages
rather than iterating down one order at a time. From Eric Dumazet
8) Fix a memory leak in openvswitch, from Li RongQing
9) amd-xgbe initializes wrong spinlock, from Thomas Lendacky
10) RTNL locking was busted in setsockopt for anycast and multicast, fix
from Sabrina Dubroca
11) Fix peer address refcount leak in ipv6, from Nicolas Dichtel
12) DocBook typo fixes, from Masanari Iida
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (101 commits)
ipv6: restore the behavior of ipv6_sock_ac_drop()
amd-xgbe: Enable interrupts for all management counters
amd-xgbe: Treat certain counter registers as 64 bit
greth: moved TX ring cleaning to NAPI rx poll func
cnic : Cleanup CONFIG_IPV6 & VLAN check
net: treewide: Fix typo found in DocBook/networking.xml
bnx2x: Fix link problems for 1G SFP RJ45 module
3c59x: avoid panic in boomerang_start_xmit when finding page address:
netfilter: add explicit Kconfig for NETFILTER_XT_NAT
ipv6: use addrconf_get_prefix_route() to remove peer addr
ipv6: fix a refcnt leak with peer addr
net-timestamp: only report sw timestamp if reporting bit is set
drivers/net/fddi/skfp/h/skfbi.h: Remove useless PCI_BASE_2ND macros
l2tp: fix race while getting PMTU on PPP pseudo-wire
ipv6: fix rtnl locking in setsockopt for anycast and multicast
VMXNET3: Check for map error in vmxnet3_set_mc
openvswitch: distinguish between the dropped and consumed skb
amd-xgbe: Fix initialization of the wrong spin lock
openvswitch: fix a memory leak
netfilter: fix missing dependencies in NETFILTER_XT_TARGET_LOG
new link for - How to piss off a Linux kernel subsystem maintainer
Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org>
The NFS/RDMA Kconfig symbol was split into separate options for client
and server in commit 2e8c12e1b765 ("xprtrdma: add separate Kconfig
options for NFSoRDMA client and server support").
Update the documentation to reflect this split.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Cc: "J. Bruce Fields" <bfields@redhat.com>
hpfall.c was renamed to freefall.c in 3.16, but this file still refer to
hpfall.c instead of freefall.c
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
The example code provided with the i2c device interface documentation
won't compile since it uses the reserved word "register" to name a
variable.
The compiler fails with this error message:
error: expected identifier or '(' before '=' token
__u8 register = 0x20; /* Device register to access */
Rename the variable "register" to simply "reg" in the example code.
Another couple of typos has been fixed as well.
[Change "! =" to "!=".]
Signed-off-by: Jose Alarcon Roldan <jose.alarcon.roldan@gmail.com>
Acked-by: Wolfram Sang <wsa@the-dreams.de>
Despite the fact that these functions have been around for years, they
are little used (only 15 uses in 13 files at the preseht time) even
though many other files use work-arounds to achieve the same result.
By documenting them, hopefully they will become more widely used.
Signed-off-by: Rob Jones <rob.jones@codethink.co.uk>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator
Pull regulator documentation fixes from Mark Brown:
"All the fixes people have found for the regulator API have been
documentation fixes, avoiding warnings while building the kerneldoc,
fixing some errors in one of the DT bindings documents and fixing some
typos in the header"
* tag 'regulator-v3.17-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator:
regulator: fix kernel-doc warnings in header files
regulator: Proofread documentation
regulator: tps65090: Fix tps65090 typos in example
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO fixes from Linus Walleij:
- some documentation sync
- resource leak in the bt8xx driver
- again fix the way varargs are used to handle the optional flags on
the gpiod_* accessors. Now hopefully nailed the entire problem.
* tag 'gpio-v3.17-3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio:
gpio: move varargs hack outside #ifdef GPIOLIB
gpio: bt8xx: fix release of managed resources
Documentation: gpio: documentation for optional getters functions
'regulator/fix/tps65090' into regulator-linus
The Rockchip SPI controller works fine without DMA (aside from a few
warnings). The DMA property even implies this, saying:
DMA request names should include "tx" and "rx" if present.
Officially mark the properties as optional.
Signed-off-by: Doug Anderson <dianders@chromium.org>
"This time it contains a bunch of small ASoC fixes that slipped from in
previous updates, in addition to the usual HD-audio fixes and the
regression fixes for FireWire updates in 3.17.
All commits are reasonably small fixes"
* tag 'sound-3.17-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda - Fix COEF setups for ALC1150 codec
ASoC: simple-card: Fix bug of wrong decrement DT node's refcount
ALSA: hda - Fix digital mic on Acer Aspire 3830TG
ASoC: omap-twl4030: Fix typo in 2nd dai link's platform_name
ALSA: firewire-lib/dice: add arrangements of PCM pointer and interrupts for Dice quirk
ALSA: dice: fix wrong channel mappping at higher sampling rate
ASoC: cs4265: Fix setting of functional mode and clock divider
ASoC: cs4265: Fix clock rates in clock map table
ASoC: rt5677: correct mismatch widget name
ASoC: rt5640: Do not allow regmap to use bulk read-write operations
ASoC: tegra: Fix typo in include guard
ASoC: da732x: Fix typo in include guard
ASoC: core: fix .info for SND_SOC_BYTES_TLV
ASoC: rcar: Use && instead of & for boolean expressions
ASoC: Use dev_set_name() instead of init_name
ASoC: axi: Fix ADI AXI SPDIF specification
Pull input subsystem updates from Dmitry Torokhov:
"A fix for MT breakage, enhancement to Elantech PS/2 driver and a
couple of assorted fixes"
Input: elantech - add support for trackpoint found on some v3 models
Input: elantech - reset the device when elantech probe fails
Input: ALPS - suppress message about 'Unknown touchpad'
Input: fix used slots detection breakage
Input: sparc - i8042-sparcio.h: fix unused kbd_res warning
Input: atmel_mxt_ts - improve description of gpio-keymap property
Add compatible string for imx6sx-usbphy.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
The quite-recently-added analog-tv-connector bindings say that the
compatible string for composite video connector is
"composite-connector". That string is also used in the omap3-n900.dts
file. However, the connector driver uses "composite-video-connector", so
this has never worked.
While changing the driver's compatible string to "composite-connector"
would be safer, as published DT bindings should not be changed, I'd
rather fix the bindings in this case for two reasons:
* composite-connector is a bit too generic name, as it doesn't even hint
at video.
* it's clear that this has never worked, which means no one has used
those bindings, which should make it safe to change this.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
'asoc/fix/da732x', 'asoc/fix/omap', 'asoc/fix/rsnd', 'asoc/fix/rt5640', 'asoc/fix/rt5677', 'asoc/fix/simple' and 'asoc/fix/tegra' into asoc-linus
Pull ARM SoC fixes from Olof Johansson:
"Here's the weekly batch of fixes from arm-soc.
The delta is a largeish negative delta, due to revert of SMP support
for Broadcom's STB SoC -- it was accidentally merged before some
issues had been addressed, so they will make a new attempt for 3.18.
I didn't see a need for a full revert of the whole platform due to
this, we're keeping the rest enabled.
The rest is mostly:
- a handful of DT fixes for i.MX (Hummingboard/Cubox-i in particular)
- some MTD/NAND fixes for OMAP
- minor DT fixes for shmobile
- warning fix for UP builds on vexpress/spc
There's also a couple of patches that wires up hwmod on TI's DRA7 SoC
so it can boot. Drivers and the rest had landed for 3.17, and it's
small and isolated so it made sense to pick up now even if it's not a
bugfix"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits)
vexpress/spc: fix a build warning on array bounds
ARM: DRA7: hwmod: Add dra74x and dra72x specific ocp interface lists
ARM: DRA7: Add support for soc_is_dra74x() and soc_is_dra72x() variants
MAINTAINERS: catch special Rockchip code locations
ARM: dts: microsom-ar8035: MDIO pad must be set open drain
ARM: dts: omap54xx-clocks: Fix the l3 and l4 clock rates
ARM: brcmstb: revert SMP support
ARM: OMAP2+: hwmod: Rearm wake-up interrupts for DT when MUSB is idled
ARM: dts: Enable UART wake-up events for beagleboard
ARM: dts: Remove twl6030 clk32g "regulator"
ARM: OMAP2+: omap_device: remove warning that clk alias already exists
ARM: OMAP: fix %d confusingly prefixed with 0x in format string
ARM: dts: DRA7: fix interrupt-cells for GPIO
mtd: nand: omap: Fix 1-bit Hamming code scheme, omap_calculate_ecc()
ARM: dts: omap3430-sdp: Revert to using software ECC for NAND
ARM: OMAP2+: GPMC: Support Software ECC scheme via DT
mtd: nand: omap: Revert to using software ECC by default
ARM: dts: hummingboard/cubox-i: change SPDIF output to be more descriptive
ARM: dts: hummingboard/cubox-i: add USB OC pinctrl configuration
ARM: shmobile: r8a7791: add missing 0x0100 for SDCKCR
The PTP reference clock, used for setting the addend in the Timestamp Addend
Register, was erroneously hard-coded (as reported in the databook just as
example).
The patch removes the macro named: STMMAC_SYSCLOCK and allows to use a
reference clock (clk_ptp_ref_i) that can be passed from the platform.
If not passed, the main driver clock will be used as default; note that
this can be fine on some platforms.
Note that, prior this patch, using the old STMMAC_SYSCLOCK on some platforms,
as side effect, the ptp clock can move faster/slower than the system clock.
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Add arm specific parts to kdump kernel documentation.
Signed-off-by: Hu Keping <hukeping@huawei.com>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Cc: Haren Myneni <hbabu@us.ibm.com>
Cc: Rob Landley <rob@landley.net>
Add a mention about the _optional variants of (devm_)gpiod_get*().
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull mfd fixes from Lee Jones:
"Couple of simple fixes due for the 3.17 rcs
(and a sneaky document addition that slipped from the previous
pull-request)"
* tag 'mfd-fixes-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd:
mfd: twl4030-power: Fix PM idle pin configuration to not conflict with regulators
mfd: tc3589x: Add device tree bindings
mfd: ab8500-core: Use 'ifdef' for config options
mfd: htc-i2cpld: Fix %d confusingly prefixed with 0x in format string
mfd: omap-usb-host: Fix %d confusingly prefixed with 0x in format string
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin-control fixes from Linus Walleij:
"My first (a bit delayed) pack of pin control fixes for the v3.17
series, only driver fixes:
- SH-PFC (Renesas) r8a7791 CAN bus pin group problem
- Rockchip (GPIO0 configuration)
- Tegra-xusb (interrupt handling)
- Exynos (GPIO interrupt locking)
- Qualcomm (fix misleading example interrupts)
- minor non-critical fixes for abx500 and AT91 also sneaked in,
because I initially intended this pull for post RC-1, hope it's
still OK"
* tag 'pinctrl-v3.17-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl:
pinctrl: qcom: apq8064: Correct interrupts in example
pinctrl: exynos: Lock GPIOs as interrupts when used as EINTs
pinctrl: pinctrl-at91.c: fix decimal printf format specifiers prefixed with 0x
pinctrl: abx500: remove useless check
pinctrl: tegra-xusb: testing wrong variable in probe()
pinctrl: tegra-xusb: fix an off by one test
pinctrl: rockchip: fix rk3288 gpio0 configuration
sh-pfc: r8a7791: fix CAN pin groups
This defines the device tree bindings for the Toshiba TC3589x
series of multi-purpose expanders. Only the stuff I can test
is defined: GPIO and keypad. Others may implement more
subdevices further down the road.
This is to complement
commit a435ae1d51e2f18414f2a87219fdbe068231e692
"mfd: Enable the tc3589x for Device Tree" which left off
the definition of the device tree bindings.
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Update some descriptions for API arguments and descriptions.
Signed-off-by: Gioh Kim <gioh.kim@lge.com>
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Mark Brown <broonie@linaro.org>
Update the description for per cpu operations to clarify use cases of
this_cpu operations and add considerations for remote access.
Signed-off-by: Pranith Kumar <bobby.prani@gmail.com>
Signed-off-by: Christoph Lameter <cl@linux.com>
For v3.14 and prior, 1-bit Hamming code ECC via software was the
default choice for some boards e.g. 3430sdp.
Commit ac65caf514ec in v3.15 changed the behaviour
to use 1-bit Hamming code via Hardware using a different ECC layout
i.e. (ROM code layout) than what is used by software ECC.
This ECC layout change causes NAND filesystems created in v3.14
and prior to be unusable in v3.15 and later. So don't mark "sw" scheme
as deperecated and support it.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Pull x86 fixes from Ingo Molnar:
"A couple of EFI fixes, plus misc fixes all around the map"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
efi/arm64: Store Runtime Services revision
firmware: Do not use WARN_ON(!spin_is_locked())
x86_32, entry: Clean up sysenter_badsys declaration
x86/doc: Fix the 'tlb_single_page_flush_ceiling' sysconfig path
x86/mm: Fix sparse 'tlb_single_page_flush_ceiling' warning and make the variable read-mostly
x86/mm: Fix RCU splat from new TLB tracepoints
git://git.kernel.org/pub/scm/linux/kernel/git/mfleming/efi into x86/urgent
Pull EFI fixes from Matt Fleming:
* WARN_ON(!spin_is_locked()) always triggers on non-SMP machines.
Swap it for the more canonical lockdep_assert_held() which always
does the right thing - Guenter Roeck
* Assign the correct value to efi.runtime_version on arm64 so that all
the runtime services can be invoked - Semen Protsenko
The example in the binding document indicates that interrupt 32 is used
for the TLMM summary IRQ. Correct this to reduce the confusion.
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
The below patch improves the documentation for the gpio-property. Stephen
Warren has a good example here:
https://github.com/swarren/linux-tegra/commit/09789801
trackpad@4b {
compatible = "atmel,maxtouch";
reg = <0x4b>;
interrupt-parent = <&gpio>;
interrupts = <TEGRA_GPIO(W, 3) IRQ_TYPE_LEVEL_LOW>;
linux,gpio-keymap = <0 0 0 BTN_LEFT>;
This maps BTN_LEFT to the 4th bit of the T19 message.
Current dmas explanation of SRC/DRS is confusable.
This patch clarifies it.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI changes from Bjorn Helgaas:
"Marvell MVEBU
- Remove ARCH_KIRKWOOD dependency (Andrew Lunn)
NVIDIA Tegra
- Add debugfs support (Thierry Reding)
Synopsys DesignWare
- Look for configuration space in 'reg', not 'ranges' (Kishon Vijay Abraham I)
- Program ATU with untranslated address (Kishon Vijay Abraham I)
- Add config access-related pcie_host_ops for v3.65 hardware (Murali Karicheri)
- Add MSI-related pcie_host_ops for v3.65 hardware (Murali Karicheri)
TI DRA7xx
- Add TI DR7xx PCIe driver (Kishon Vijay Abraham I)"
* tag 'pci-v3.17-changes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: designware: Add MSI-related pcie_host_ops for v3.65 hardware
PCI: designware: Add config access-related pcie_host_ops for v3.65 hardware
PCI: dra7xx: Add TI DRA7xx PCIe driver
PCI: designware: Program ATU with untranslated address
PCI: designware: Look for configuration space in 'reg', not 'ranges'
PCI: tegra: Add debugfs support
PCI: mvebu: Remove ARCH_KIRKWOOD dependency
Pull devicetree fixes from Grant Likely:
"Three more commits needed for v3.17: A bug fix for reserved regions
based at address zero, a clarification on how to interpret existence
of both interrupts and interrupts-extended properties, and a fix to
allow device tree testcases to run on any platform"
* tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux:
of/irq: Fix lookup to use 'interrupts-extended' property first
Enabling OF selftest to run without machine's devicetree
of: Allow mem_reserve of memory with a base address of zero
Pull x86 platform driver updates from Matthew Garrett:
"A moderate number of changes, but nothing awfully significant.
A lot of const cleanups, some reworking and additions to the rfkill
quirks in the asus driver, a new driver for generating falling laptop
events on Toshibas and some misc fixes.
Maybe vendors have stopped inventing things"
* 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: (41 commits)
platform/x86: Enable build support for toshiba_haps
Documentation: Add file about toshiba_haps module
platform/x86: Toshiba HDD Active Protection Sensor
asus-nb-wmi: Add wapf4 quirk for the U32U
alienware-wmi: make hdmi_mux enabled on case-by-case basis
ideapad-laptop: Constify DMI table and other r/o variables
asus-nb-wmi.c: Rename x401u quirk to wapf4
compal-laptop: correct invalid hwmon name
toshiba_acpi: Add Qosmio X75-A to the alt keymap dmi list
toshiba_acpi: Add extra check to backlight code
Fix log message about future removal of interface
ideapad-laptop: Disable touchpad interface on Yoga models
asus-nb-wmi: Add wapf4 quirk for the X550CC
intel_ips: Make ips_mcp_limits variables static
thinkpad_acpi: Mark volume_alsa_control_{vol,mute} as __initdata
fujitsu-laptop: Mark fujitsu_dmi_table[] DMI table as __initconst
hp-wmi: Add missing __init annotations to initialization code
hp_accel: Constify ACPI and DMI tables
fujitsu-tablet: Mark DMI callbacks as __init code
dell-laptop: Mark dell_quirks[] DMI table as __initconst
Pull file locking bugfixes from Jeff Layton:
"Most of these patches are to fix a long-standing regression that crept
in when the BKL was removed from the file-locking code. The code was
converted to use a conventional spinlock, but some fl_release_private
ops can block and you can end up sleeping inside the lock.
There's also a patch to make /proc/locks show delegations as 'DELEG'"
* tag 'locks-v3.17-2' of git://git.samba.org/jlayton/linux:
locks: update Locking documentation to clarify fl_release_private behavior
locks: move locks_free_lock calls in do_fcntl_add_lease outside spinlock
locks: defer freeing locks in locks_delete_lock until after i_lock has been dropped
locks: don't reuse file_lock in __posix_lock_file
locks: don't call locks_release_private from locks_copy_lock
locks: show delegations as "DELEG" in /proc/locks
The specification requires compatible = "adi,axi-spdif-1.00.a" but
driver and example and file name indicate "adi,axi-spdif-tx-1.00.a".
Change the specification to match the implementation.
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
Reviewed-by: Michal Simek <michal.simek@xilinx.com>
Fixes: d7b528eff927 ("dt: Add bindings documentation for the ADI AXI-SPDIF audio controller")
Signed-off-by: Andreas Färber <afaerber@suse.de>
This patch provides information about the Toshiba HDD
Active Protection Sensor driver module toshiba_haps.
Signed-off-by: Azael Avalos <coproscefalo@gmail.com>
Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com>
In case the Device Tree blob passed by the boot agent supplies both an
'interrupts-extended' and an 'interrupts' property in order to allow for
older kernels to be usable, prefer the new-style 'interrupts-extended'
property which conveys a lot more information.
This allows us to have bootloaders willingly maintaining backwards
compatibility with older kernels without entirely deprecating the
'interrupts' property.
Update the bindings documentation to describe a situation where both the
'interrupts-extended' and the 'interrupts' property are present, and
which one takes precedence over the other.
Cc: stable@vger.kernel.org # 3.13+
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Commit 21d70354bba9 ("drm: move drm_stub.c to drm_drv.c") moves the code
from drm_stub.c into drm_drv.c. Update DocBook to include that instead.
This also came in via other people, but all the same.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
