[ Upstream commit 686140a1a9c41d85a4212a1c26d671139b76404b ]
Implement CPU alternatives, which allows to optionally patch newer
instructions at runtime, based on CPU facilities availability.
A new kernel boot parameter "noaltinstr" disables patching.
Current implementation is derived from x86 alternatives. Although
ideal instructions padding (when altinstr is longer then oldinstr)
is added at compile time, and no oldinstr nops optimization has to be
done at runtime. Also couple of compile time sanity checks are done:
1. oldinstr and altinstr must be <= 254 bytes long,
2. oldinstr and altinstr must not have an odd length.
alternative(oldinstr, altinstr, facility);
alternative_2(oldinstr, altinstr1, facility1, altinstr2, facility2);
Both compile time and runtime padding consists of either 6/4/2 bytes nop
or a jump (brcl) + 2 bytes nop filler if padding is longer then 6 bytes.
.altinstructions and .altinstr_replacement sections are part of
__init_begin : __init_end region and are freed after initialization.
Signed-off-by: Vasily Gorbik <gor@linux.vnet.ibm.com>
definition
commit 0ea66f76ba17a4b229caaadd77de694111b21769 upstream.
GPIO7 is configured in POWERHOLD mode which has higher priority
over DEV_ON bit and keeps the PMIC supplies on even after the DEV_ON
bit is turned off. This property enables driver to over ride the
POWERHOLD value to GPIO7 so as to turn off the PMIC in power off
scenarios.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Acked-by: Rob Herring <robh@kernel.org>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit b18cb64ead400c01bf1580eeba330ace51f8087d upstream.
This reverts more of:
b76437579d13 ("procfs: mark thread stack correctly in proc/<pid>/maps")
... which was partially reverted by:
65376df58217 ("proc: revert /proc/<pid>/maps [stack:TID] annotation")
Originally, /proc/PID/task/TID/maps was the same as /proc/TID/maps.
In current kernels, /proc/PID/maps (or /proc/TID/maps even for
threads) shows "[stack]" for VMAs in the mm's stack address range.
In contrast, /proc/PID/task/TID/maps uses KSTK_ESP to guess the
target thread's stack's VMA. This is racy, probably returns garbage
and, on arches with CONFIG_TASK_INFO_IN_THREAD=y, is also crash-prone:
KSTK_ESP is not safe to use on tasks that aren't known to be running
ordinary process-context kernel code.
This patch removes the difference and just shows "[stack]" for VMAs
in the mm's stack range. This is IMO much more sensible -- the
actual "stack" address really is treated specially by the VM code,
and the current thread stack isn't even well-defined for programs
that frequently switch stacks on their own.
Reported-by: Jann Horn <jann@thejh.net>
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Linux API <linux-api@vger.kernel.org>
Cc: Tycho Andersen <tycho.andersen@canonical.com>
Link: http://lkml.kernel.org/r/3e678474ec14e0a0ec34c611016753eea2e1b8ba.1475257877.git.luto@kernel.org
(cherry picked from commit 12c69f1e94c89d40696e83804dd2f0965b5250cd)
The 'noreplace-paravirt' option disables paravirt patching, leaving the
original pv indirect calls in place.
That's highly incompatible with retpolines, unless we want to uglify
paravirt even further and convert the paravirt calls to retpolines.
As far as I can tell, the option doesn't seem to be useful for much
other than introducing surprising corner cases and making the kernel
vulnerable to Spectre v2. It was probably a debug option from the early
paravirt days. So just remove it.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
Cc: Ashok Raj <ashok.raj@intel.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: Jun Nakajima <jun.nakajima@intel.com>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Asit Mallick <asit.k.mallick@intel.com>
Cc: Jason Baron <jbaron@akamai.com>
Cc: Alok Kataria <akataria@vmware.com>
Cc: Arjan Van De Ven <arjan.van.de.ven@intel.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Link: https://lkml.kernel.org/r/20180131041333.2x6blhxirc2kclrq@treble
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
[jwang: chery pick to 4.4]
Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com>
(cherry picked from commit f84a56f73dddaeac1dba8045b007f742f61cd2da)
Document the rationale and usage of the new array_index_nospec() helper.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: gregkh@linuxfoundation.org
Cc: kernel-hardening@lists.openwall.com
Cc: torvalds@linux-foundation.org
Cc: alan@linux.intel.com
Link: https://lkml.kernel.org/r/151727413645.33451.15878817161436755393.stgit@dwillia2-desk3.amr.corp.intel.com
[jwang: cherry pick to 4.4]
commit 9f0372488cc9243018a812e8cfbf27de650b187b upstream.
The grpid option is currently described as being the same as nogrpid.
Signed-off-by: Ernesto A. Fernández <ernesto.mnd.fernandez@gmail.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Cc: stable@vger.kernel.org
commit cdd10409914184c7eee5ae3e11beb890c9c16c61 upstream.
The "dmas" cells for the designware DMA controller need to have only 3
properties apart from the phandle: request line, src master and
destination master. But the commit 6e8887f60f60 updated it incorrectly
while moving from platform code to DT. Fix it.
Cc: stable@vger.kernel.org # v3.10+
Fixes: 6e8887f60f60 ("ARM: SPEAr13xx: Pass generic DW DMAC platform data from DT")
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
commit 98f0fceec7f84d80bc053e49e596088573086421 upstream.
In section <2. Runtime Cost>, fix wrong index.
Signed-off-by: zhenwei.pi <zhenwei.pi@youruncloud.com>
Cc: dave.hansen@linux.intel.com
Link: https://lkml.kernel.org/r/1516237492-27739-1-git-send-email-zhenwei.pi@youruncloud.com
commit da285121560e769cc31797bba6422eea71d473e0 upstream.
Add a spectre_v2= option to select the mitigation used for the indirect
branch speculation vulnerability.
Currently, the only option available is retpoline, in its various forms.
This will be expanded to cover the new IBRS/IBPB microcode features.
The RETPOLINE_AMD feature relies on a serializing LFENCE for speculation
control. For AMD hardware, only set RETPOLINE_AMD if LFENCE is a
serializing instruction, which is indicated by the LFENCE_RDTSC feature.
[ tglx: Folded back the LFENCE/AMD fixes and reworked it so IBRS
integration becomes simple ]
Cc: gnomes@lxorguk.ukuu.org.uk
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: thomas.lendacky@amd.com
Cc: Jiri Kosina <jikos@kernel.org>
Cc: Kees Cook <keescook@google.com>
Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org>
Cc: Paul Turner <pjt@google.com>
Link: https://lkml.kernel.org/r/1515707194-20531-5-git-send-email-dwmw@amazon.co.uk
commit 9ecccfaa7cb5249bd31bdceb93fcf5bedb8a24d8 upstream.
Fixes: 87590ce6e ("sysfs/cpu: Add vulnerability folder")
commit 87590ce6e373d1a5401f6539f0c59ef92dd924a9 upstream.
As the meltdown/spectre problem affects several CPU architectures, it makes
sense to have common way to express whether a system is affected by a
particular vulnerability or not. If affected the way to express the
mitigation should be common as well.
Create /sys/devices/system/cpu/vulnerabilities folder and files for
meltdown, spectre_v1 and spectre_v2.
Allow architectures to override the show function.
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Linus Torvalds <torvalds@linuxfoundation.org>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Link: https://lkml.kernel.org/r/20180107214913.096657732@linutronix.de
commit 01c9b17bf673b05bb401b76ec763e9730ccf1376 upstream.
Add some details about how PTI works, what some of the downsides
are, and how to debug it when things go wrong.
Also document the kernel parameter: 'pti/nopti'.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Reviewed-by: Randy Dunlap <rdunlap@infradead.org>
Cc: Moritz Lipp <moritz.lipp@iaik.tugraz.at>
Cc: Daniel Gruss <daniel.gruss@iaik.tugraz.at>
Cc: Michael Schwarz <michael.schwarz@iaik.tugraz.at>
Cc: Richard Fellner <richard.fellner@student.tugraz.at>
Cc: Andi Lutomirsky <luto@kernel.org>
Link: https://lkml.kernel.org/r/20180105174436.1BC6FA2B@viggo.jf.intel.com
AMD (and possibly other vendors) are not affected by the leak
KAISER is protecting against.
Keep the "nopti" for traditional reasons and add pti=<on|off|auto>
like upstream.
Concentrate it in arch/x86/mm/kaiser.c and use the upstream string "nopti".
Added "nokaiser" boot option: an early param like "noinvpcid".
Most places now check int kaiser_enabled (#defined 0 when not
CONFIG_KAISER) instead of #ifdef CONFIG_KAISER; but entry_64.S
and entry_64_compat.S are using the ALTERNATIVE technique, which
patches in the preferred instructions at runtime. That technique
is tied to x86 cpu features, so X86_FEATURE_KAISER is fabricated.
Prior to "nokaiser", Kaiser #defined _PAGE_GLOBAL 0: revert that,
but be careful with both _PAGE_GLOBAL and CR4.PGE: setting them when
nokaiser like when !CONFIG_KAISER, but not setting either when kaiser -
neither matters on its own, but it's hard to be sure that _PAGE_GLOBAL
won't get set in some obscure corner, or something add PGE into CR4.
By omitting _PAGE_GLOBAL from __supported_pte_mask when kaiser_enabled,
all page table setup which uses pte_pfn() masks it out of the ptes.
It's slightly shameful that the same declaration versus definition of
kaiser_enabled appears in not one, not two, but in three header files
(asm/kaiser.h, asm/pgtable.h, asm/tlbflush.h). I felt safer that way,
than with #including any of those in any of the others; and did not
feel it worth an asm/kaiser_enabled.h - kernel/cpu/common.c includes
them all, so we shall hear about it if they get out of synch.
Cleanups while in the area: removed the silly #ifdef CONFIG_KAISER
from kaiser.c; removed the unused native_get_normal_pgd(); removed
the spurious reg clutter from SWITCH_*_CR3 macro stubs; corrected some
comments. But more interestingly, set CR4.PSE in secondary_startup_64:
the manual is clear that it does not matter whether it's 0 or 1 when
4-level-pts are enabled, but I was distracted to find cr4 different on
BSP and auxiliaries - BSP alone was adding PSE, in probe_page_size_mask().
Acked-by: Jiri Kosina <jkosina@suse.cz>
commit 0790c9aad84901ca1bdc14746175549c8b5da215 upstream.
The parameter is only present on x86_64 systems to save a few bytes,
as PCID is always disabled on x86_32.
Reviewed-by: Nadav Amit <nadav.amit@gmail.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/8bbb2e65bcd249a5f18bfb8128b4689f08ac2b60.1498751203.git.luto@kernel.org
commit d12a72b844a49d4162f24cefdab30bed3f86730e upstream.
This adds a chicken bit to turn off INVPCID in case something goes
wrong. It's an early_param() because we do TLB flushes before we
parse __setup() parameters.
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Luis R. Rodriguez <mcgrof@suse.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Link: http://lkml.kernel.org/r/f586317ed1bc2b87aee652267e515b90051af385.1454096309.git.luto@kernel.org
This reverts commit 11bf4a8e1d5a300b38ca4bbe1156716b0174f2da which is
commit 2e644be30fcc08c736f66b60f4898d274d4873ab upstream.
Ben pointed out that there is no driver or device trees referencing this
device in 4.4-stable, so the patch should not be present there.
Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Cc: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Rob Herring <robh@kernel.org>
Cc: Archit Taneja <architt@codeaurora.org>
Cc: Sasha Levin <alexander.levin@verizon.com>
[ Upstream commit ff1293f67734da68e23fecb6ecdae7112b8c43f9 ]
Add DT bindings for avia,hx711
Add vendor avia to vendor list
Signed-off-by: Andreas Klinger <ak@it-klinger.de>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
[ Upstream commit 2e644be30fcc08c736f66b60f4898d274d4873ab ]
THS8135 is a configurable video DAC. Add DT bindings for this chip.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Archit Taneja <architt@codeaurora.org>
Link: http://patchwork.freedesktop.org/patch/msgid/1481623759-12786-3-git-send-email-bgolaszewski@baylibre.com
commit 41662f5cc55335807d39404371cfcbb1909304c4 upstream.
SYSCTL_WRITES_WARN was added in commit f4aacea2f5d1 ("sysctl: allow for
strict write position handling"), and released in v3.16 in August of
2014. Since then I can find only 1 instance of non-zero offset
writing[1], and it was fixed immediately in CRIU[2]. As such, it
appears safe to flip this to the strict state now.
[1] https://www.google.com/search?q="when%20file%20position%20was%20not%200"
[2] http://lists.openvz.org/pipermail/criu/2015-April/019819.html
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Sumit Semwal <sumit.semwal@linaro.org>
commit 1be7107fbe18eed3e319a6c3e83c78254b693acb upstream.
Stack guard page is a useful feature to reduce a risk of stack smashing
into a different mapping. We have been using a single page gap which
is sufficient to prevent having stack adjacent to a different mapping.
But this seems to be insufficient in the light of the stack usage in
userspace. E.g. glibc uses as large as 64kB alloca() in many commonly
used functions. Others use constructs liks gid_t buffer[NGROUPS_MAX]
which is 256kB or stack strings with MAX_ARG_STRLEN.
This will become especially dangerous for suid binaries and the default
no limit for the stack size limit because those applications can be
tricked to consume a large portion of the stack and a single glibc call
could jump over the guard page. These attacks are not theoretical,
unfortunatelly.
Make those attacks less probable by increasing the stack guard gap
to 1MB (on systems with 4k pages; but make it depend on the page size
because systems with larger base pages might cap stack allocations in
the PAGE_SIZE units) which should cover larger alloca() and VLA stack
allocations. It is obviously not a full fix because the problem is
somehow inherent, but it should reduce attack space a lot.
One could argue that the gap size should be configurable from userspace,
but that can be done later when somebody finds that the new 1MB is wrong
for some special case applications. For now, add a kernel command line
option (stack_guard_gap) to specify the stack gap size (in page units).
Implementation wise, first delete all the old code for stack guard page:
because although we could get away with accounting one extra page in a
stack vma, accounting a larger gap can break userspace - case in point,
a program run with "ulimit -S -v 20000" failed when the 1MB gap was
counted for RLIMIT_AS; similar problems could come with RLIMIT_MLOCK
and strict non-overcommit mode.
Instead of keeping gap inside the stack vma, maintain the stack guard
gap as a gap between vmas: using vm_start_gap() in place of vm_start
(or vm_end_gap() in place of vm_end if VM_GROWSUP) in just those few
places which need to respect the gap - mainly arch_get_unmapped_area(),
and and the vma tree's subtree_gap support for that.
Original-patch-by: Oleg Nesterov <oleg@redhat.com>
Original-patch-by: Michal Hocko <mhocko@suse.com>
Tested-by: Helge Deller <deller@gmx.de> # parisc
[wt: backport to 4.11: adjust context]
[wt: backport to 4.9: adjust context ; kernel doc was not in admin-guide]
[wt: backport to 4.4: adjust context ; drop ppc hugetlb_radix changes]
Signed-off-by: Willy Tarreau <w@1wt.eu>
[gkh: minor build fixes for 4.4]
commit f0e421b1bf7af97f026e1bb8bfe4c5a7a8c08f42 upstream.
Some kernel features don't currently work if a task puts a non-zero
address tag in its stack pointer, frame pointer, or frame record entries
(FP, LR).
For example, with a tagged stack pointer, the kernel can't deliver
signals to the process, and the task is killed instead. As another
example, with a tagged frame pointer or frame records, perf fails to
generate call graphs or resolve symbols.
For now, just document these limitations, instead of finding and fixing
everything that doesn't work, as it's not known if anyone needs to use
tags in these places anyway.
In addition, as requested by Dave Martin, generalize the limitations
into a general kernel address tag policy, and refactor
tagged-pointers.txt to include it.
Fixes: d50240a5f6ce ("arm64: mm: permit use of tagged pointers at EL0")
Reviewed-by: Dave Martin <Dave.Martin@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Kristina Martsenko <kristina.martsenko@arm.com>
commit 6e17b4181603d183d20c73f4535529ddf2a2a020 upstream.
This patch adds support for APB0 in H3. It seems to be compatible with
earlier SOCs. apb0 gates controls R_ block peripherals (R_PIO, R_IR,
etc).
Since this gates behave just like any Allwinner clock gate, add a generic
compatible that can be reused if we don't have any clock to protect.
Signed-off-by: Krzysztof Adamski <k@japko.eu>
[Maxime: Removed the H3 compatible from the simple-gates driver, reworked
the commit log a bit]
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Cc: Julia Lawall <julia.lawall@lip6.fr>
commit d29216842a85c7970c536108e093963f02714498 upstream.
CAI Qian <caiqian@redhat.com> pointed out that the semantics
of shared subtrees make it possible to create an exponentially
increasing number of mounts in a mount namespace.
mkdir /tmp/1 /tmp/2
mount --make-rshared /
for i in $(seq 1 20) ; do mount --bind /tmp/1 /tmp/2 ; done
Will create create 2^20 or 1048576 mounts, which is a practical problem
as some people have managed to hit this by accident.
As such CVE-2016-6213 was assigned.
Ian Kent <raven@themaw.net> described the situation for autofs users
as follows:
> The number of mounts for direct mount maps is usually not very large because of
> the way they are implemented, large direct mount maps can have performance
> problems. There can be anywhere from a few (likely case a few hundred) to less
> than 10000, plus mounts that have been triggered and not yet expired.
> Indirect mounts have one autofs mount at the root plus the number of mounts that
> The number of autofs indirect map entries can range from a few to the common
> case of several thousand and in rare cases up to between 30000 and 50000. I've
> not heard of people with maps larger than 50000 entries.
> The larger the number of map entries the greater the possibility for a large
> number of active mounts so it's not hard to expect cases of a 1000 or somewhat
> more active mounts.
So I am setting the default number of mounts allowed per mount
namespace at 100,000. This is more than enough for any use case I
know of, but small enough to quickly stop an exponential increase
in mounts. Which should be perfect to catch misconfigurations and
malfunctioning programs.
For anyone who needs a higher limit this can be changed by writing
to the new /proc/sys/fs/mount-max sysctl.
Tested-by: CAI Qian <caiqian@redhat.com>
[bwh: Backported to 4.4: adjust context]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit d1b4c689d4130bcfd3532680b64db562300716b6 upstream.
mmapped netlink has a number of unresolved issues:
- TX zerocopy support had to be disabled more than a year ago via
commit 4682a0358639b29cf ("netlink: Always copy on mmap TX.")
because the content of the mmapped area can change after netlink
attribute validation but before message processing.
- RX support was implemented mainly to speed up nfqueue dumping packet
payload to userspace. However, since commit ae08ce0021087a5d812d2
("netfilter: nfnetlink_queue: zero copy support") we avoid one copy
with the socket-based interface too (via the skb_zerocopy helper).
The other problem is that skbs attached to mmaped netlink socket
behave different from normal skbs:
- they don't have a shinfo area, so all functions that use skb_shinfo()
(e.g. skb_clone) cannot be used.
- reserving headroom prevents userspace from seeing the content as
it expects message to start at skb->head.
See for instance
commit aa3a022094fa ("netlink: not trim skb for mmaped socket when dump").
- skbs handed e.g. to netlink_ack must have non-NULL skb->sk, else we
crash because it needs the sk to check if a tx ring is attached.
Also not obvious, leads to non-intuitive bug fixes such as 7c7bdf359
("netfilter: nfnetlink: use original skbuff when acking batches").
mmaped netlink also didn't play nicely with the skb_zerocopy helper
used by nfqueue and openvswitch. Daniel Borkmann fixed this via
commit 6bb0fef489f6 ("netlink, mmap: fix edge-case leakages in nf queue
zero-copy")' but at the cost of also needing to provide remaining
length to the allocation function.
nfqueue also has problems when used with mmaped rx netlink:
- mmaped netlink doesn't allow use of nfqueue batch verdict messages.
Problem is that in the mmap case, the allocation time also determines
the ordering in which the frame will be seen by userspace (A
allocating before B means that A is located in earlier ring slot,
but this also means that B might get a lower sequence number then A
since seqno is decided later. To fix this we would need to extend the
spinlocked region to also cover the allocation and message setup which
isn't desirable.
- nfqueue can now be configured to queue large (GSO) skbs to userspace.
Queing GSO packets is faster than having to force a software segmentation
in the kernel, so this is a desirable option. However, with a mmap based
ring one has to use 64kb per ring slot element, else mmap has to fall back
to the socket path (NL_MMAP_STATUS_COPY) for all large packets.
To use the mmap interface, userspace not only has to probe for mmap netlink
support, it also has to implement a recv/socket receive path in order to
handle messages that exceed the size of an rx ring element.
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Ken-ichirou MATSUZAWA <chamaken@gmail.com>
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Shi Yuejie <shiyuejie@outlook.com>
commit 6bee835dd54e279f3d3ae2eca92a9c394b4fd028 upstream.
Move mic/mpssd examples to samples and remove it from Documentation
Makefile. Create a new Makefile to build mic/mpssd. It can be built
from top level directory or from mic/mpssd directory:
Run make -C samples/mic/mpssd or cd samples/mic/mpssd; make
Acked-by: Jonathan Corbet <corbet@lwn.net>
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
[backported to 4.4-stable as this code is broken on newer versions of
gcc and we don't want to break the build for a Documentation sample.
- gregkh]
commit 47512cfd0d7a8bd6ab71d01cd89fca19eb2093eb upstream.
The goldfish platform code registers the platform device unconditionally
which causes havoc in several ways if the goldfish_pdev_bus driver is
enabled:
- Access to the hardcoded physical memory region, which is either not
available or contains stuff which is completely unrelated.
- Prevents that the interrupt of the serial port can be requested
- In case of a spurious interrupt it goes into a infinite loop in the
interrupt handler of the pdev_bus driver (which needs to be fixed
seperately).
Add a 'goldfish' command line option to make the registration opt-in when
the platform is compiled in.
I'm seriously grumpy about this engineering trainwreck, which has seven
SOBs from Intel developers for 50 lines of code. And none of them figured
out that this is broken. Impressive fail!
Fixes: ddd70cf93d78 ("goldfish: platform device for x86")
Reported-by: Gabriel C <nix.or.die@gmail.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
commit 2e575cbc930901718cc18e084566ecbb9a4b5ebb upstream.
The type of AVIC interrupt controller found on i.MX31 is one-cell,
namely 31 for CCM DVFS and 53 for CCM, however for clock control
module its interrupts are specified as 3-cells, fix it.
Fixes: ef0e4a606fb6 ("ARM: mx31: Replace clk_register_clkdev with clock DT lookup")
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
commit 0d808df06a44200f52262b6eb72bcb6042f5a7c5 upstream.
When switching from/to a guest that has a transaction in progress,
we need to save/restore the checkpointed register state. Although
XER is part of the CPU state that gets checkpointed, the code that
does this saving and restoring doesn't save/restore XER.
This fixes it by saving and restoring the XER. To allow userspace
to read/write the checkpointed XER value, we also add a new ONE_REG
specifier.
The visible effect of this bug is that the guest may see its XER
value being corrupted when it uses transactions.
Fixes: e4e38121507a ("KVM: PPC: Book3S HV: Add transactional memory support")
Fixes: 0a8eccefcb34 ("KVM: PPC: Book3S HV: Add missing code for transaction reclaim on guest exit")
Signed-off-by: Paul Mackerras <paulus@ozlabs.org>
Reviewed-by: Thomas Huth <thuth@redhat.com>
This reverts commit fcf5e5198b447969ed2a56ec335dae3c695a6b46 which is
548acf19234dbda5a52d5a8e7e205af46e9da840 upstream.
Cc: Borislav Petkov <bp@suse.de>
commit 548acf19234dbda5a52d5a8e7e205af46e9da840 upstream.
Huge amounts of help from Andy Lutomirski and Borislav Petkov to
produce this. Andy provided the inspiration to add classes to the
exception table with a clever bit-squeezing trick, Boris pointed
out how much cleaner it would all be if we just had a new field.
Linus Torvalds blessed the expansion with:
' I'd rather not be clever in order to save just a tiny amount of space
in the exception table, which isn't really criticial for anybody. '
The third field is another relative function pointer, this one to a
handler that executes the actions.
We start out with three handlers:
1: Legacy - just jumps the to fixup IP
2: Fault - provide the trap number in %ax to the fixup code
3: Cleaned up legacy for the uaccess error hack
Signed-off-by: Tony Luck <tony.luck@intel.com>
Link: http://lkml.kernel.org/r/f6af78fcbd348cf4939875cfda9c19689b5e50b8.1455732970.git.tony.luck@intel.com
commit 930e19248e9b61da36c967687ca79c4d5f977919 upstream.
On suspend/resume cycle, selftest is executed to reset i8042 controller.
But when this is done in Asus devices, subsequent calls to detect/init
functions to elantech driver fails. Skipping selftest fixes this problem.
An easier step to reproduce this problem is adding i8042.reset=1 as a
kernel parameter. On Asus laptops, it'll make the system to start with the
touchpad already stuck, since psmouse_probe forcibly calls the selftest
function.
This patch was inspired by John Hiesey's change[1], but, since this problem
affects a lot of models of Asus, let's avoid running selftests on them.
All models affected by this problem:
A455LD
K401LB
K501LB
K501LX
R409L
V502LX
X302LA
X450LCP
X450LD
X455LAB
X455LDB
X455LF
Z450LA
[1]: https://marc.info/?l=linux-input&m=144312209020616&w=2
Fixes: "ETPS/2 Elantech Touchpad dies after resume from suspend"
(https://bugzilla.kernel.org/show_bug.cgi?id=107971)
Signed-off-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com>
commit 93bfe79b03365f410aa91caf04263173c008ecdf upstream.
The mvs1 and mvs2 switches are actually called 5vs1 and 5vs2 on
some datasheets. Let's rename them to match the datasheets and
also match the RPM based regulator driver which calls these by
their 5vs names (see qcom_smd-regulator.c). There aren't any
users of these regulators so far, so there aren't any concerns of
DT ABI breakage here. While we're here making updates to the
switches, also mandate usage of the OCP irq for these switches
too.
Cc: Bjorn Andersson <bjorn.andersson@linaro.org>
Fixes: e92a4047419c ("regulator: Add QCOM SPMI regulator driver")
Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit c333dfe8dba7d3e47e97e1cee3c38123e19ae73c upstream.
The S4 supply is sometimes called the boost regulator because it
outputs 5V. Typically it's connected to the 5vs1 and 5vs2
switches for use in USB OTG and HDMI applications. Add support
for this regulator which was mistakenly left out from the initial
submission of this driver.
commit 7440926ed9623dceca3310c5f437d06c859dc02b upstream.
Documentation incorrectly refers to struct pinctrl_desc, where no such flag is
available. Replace the name of the struct.
Fixes: commit 8c4c2016345f ("pinctrl: move strict option to pinmux_ops")
commit 3610a2add39365a0f153154c60169a66c616d50f upstream.
The compilation emits a warning in function ‘snprintf’,
inlined from ‘set_cmdline’ at
../Documentation/mic/mpssd/mpssd.c:1541:9:
/usr/include/x86_64-linux-gnu/bits/stdio2.h:64:10:
warning: call to __builtin___snprintf_chk will always overflow
destination buffer
This was introduced in commit f4a66c204482 ("misc: mic: Update MIC host
daemon with COSM changes") and is fixed by reverting the changes to the
size argument of these snprintf statements.
Cc: Ashutosh Dixit <ashutosh.dixit@intel.com>
Signed-off-by: Mike Danese <mikedanese@google.com>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
commit 543852af8e5902aee8f7c72c89e1513663e0f696 upstream.
SARADC controller needs to be reset before programming it, otherwise
it will not function properly.
Signed-off-by: Caesar Wang <wxt@rock-chips.com>
Cc: Jonathan Cameron <jic23@kernel.org>
Cc: Heiko Stuebner <heiko@sntech.de>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: linux-iio@vger.kernel.org
Cc: linux-rockchip@lists.infradead.org
Tested-by: Guenter Roeck <linux@roeck-us.net>
[ Upstream commit 65376df582174ffcec9e6471bf5b0dd79ba05e4a ]
Commit b76437579d13 ("procfs: mark thread stack correctly in
proc/<pid>/maps") added [stack:TID] annotation to /proc/<pid>/maps.
Finding the task of a stack VMA requires walking the entire thread list,
turning this into quadratic behavior: a thousand threads means a
thousand stacks, so the rendering of /proc/<pid>/maps needs to look at a
million combinations.
The cost is not in proportion to the usefulness as described in the
patch.
Drop the [stack:TID] annotation to make /proc/<pid>/maps (and
/proc/<pid>/numa_maps) usable again for higher thread counts.
The [stack] annotation inside /proc/<pid>/task/<tid>/maps is retained, as
identifying the stack VMA there is an O(1) operation.
Siddesh said:
"The end users needed a way to identify thread stacks programmatically and
there wasn't a way to do that. I'm afraid I no longer remember (or have
access to the resources that would aid my memory since I changed
employers) the details of their requirement. However, I did do this on my
own time because I thought it was an interesting project for me and nobody
really gave any feedback then as to its utility, so as far as I am
concerned you could roll back the main thread maps information since the
information is available in the thread-specific files"
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Siddhesh Poyarekar <siddhesh.poyarekar@gmail.com>
Cc: Shaohua Li <shli@fb.com>
commit b8612e517c3c9809e1200b72c474dbfd969e5a83 upstream.
Signing a module should only make it trusted by the specific kernel it
was built for, not anything else. If a module signing key is used for
multiple ABI-incompatible kernels, the modules need to include enough
version information to distinguish them.
commit b6350c21cfe8aa9d65e189509a23c0ea4b8362c2 upstream.
Update PAT documentation to describe how PAT is initialized under
various configurations.
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: elliott@hpe.com
Cc: konrad.wilk@oracle.com
Cc: paul.gortmaker@windriver.com
Cc: xen-devel@lists.xenproject.org
Link: http://lkml.kernel.org/r/1458769323-24491-8-git-send-email-toshi.kani@hpe.com
commit 72d8c36ec364c82bf1bf0c64dfa1041cfaf139f7 upstream.
sas_ata_strategy_handler() adds the works of the ata error handler to
system_unbound_wq. This workqueue asynchronously runs work items, so the
ata error handler will be performed concurrently on different CPUs. In
this case, ->host_failed will be decreased simultaneously in
scsi_eh_finish_cmd() on different CPUs, and become abnormal.
It will lead to permanently inequality between ->host_failed and
->host_busy, and scsi error handler thread won't start running. IO
errors after that won't be handled.
Since all scmds must have been handled in the strategy handler, just
remove the decrement in scsi_eh_finish_cmd() and zero ->host_busy after
the strategy handler to fix this race.
Fixes: 50824d6c5657 ("[SCSI] libsas: async ata-eh")
Signed-off-by: Wei Fang <fangwei1@huawei.com>
Reviewed-by: James Bottomley <jejb@linux.vnet.ibm.com>
commit 5138806f16c74c7cb8ac3e408a859c79eb7c9567 upstream.
IIO_CHAN_INFO_RAW was returning processed data which was incorrect.
This also adds the IIO_CHAN_INFO_SCALE value to convert to a processed value.
Signed-off-by: Matt Ranostay <mranostay@gmail.com>
commit 759c01142a5d0f364a462346168a56de28a80f52 upstream.
On no-so-small systems, it is possible for a single process to cause an
OOM condition by filling large pipes with data that are never read. A
typical process filling 4000 pipes with 1 MB of data will use 4 GB of
memory. On small systems it may be tricky to set the pipe max size to
prevent this from happening.
This patch makes it possible to enforce a per-user soft limit above
which new pipes will be limited to a single page, effectively limiting
them to 4 kB each, as well as a hard limit above which no new pipes may
be created for this user. This has the effect of protecting the system
against memory abuse without hurting other users, and still allowing
pipes to work correctly though with less data at once.
The limit are controlled by two new sysctls : pipe-user-pages-soft, and
pipe-user-pages-hard. Both may be disabled by setting them to zero. The
default soft limit allows the default number of FDs per process (1024)
to create pipes of the default size (64kB), thus reaching a limit of 64MB
before starting to create only smaller pipes. With 256 processes limited
to 1024 FDs each, this results in 1024*64kB + (256*1024 - 1024) * 4kB =
1084 MB of memory allocated for a user. The hard limit is disabled by
default to avoid breaking existing applications that make intensive use
of pipes (eg: for splicing).
Reported-by: socketpair@gmail.com
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Mitigates: CVE-2013-4312 (Linux 2.0+)
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Moritz Muehlenhoff <moritz@wikimedia.org>
commit 3397c2c45b1b6f54834dfeae30a73046f33ca943 upstream.
A new element got inserted into enum mx35_clks with commit 3713e3f5e927
("clk: imx35: define two clocks for rtc"). This insertion shifted most
nummerical clock assignments to a new nummerical value which in turn
rendered most hardcoded nummeric values in imx35.dtsi incorrect.
Restore the existing order by moving the newly introduced clock to the
end of the enum. Update the dts documentation accordingly.
Signed-off-by: Alexander Kurz <akurz@blala.de>
Fixes: 3713e3f5e927 ("clk: imx35: define two clocks for rtc")
commit 0f40fbbcc34e093255a2b2d70b6b0fb48c3f39aa upstream.
OpenSSH expects the (non-blocking) read() of pty master to return
EAGAIN only if it has received all of the slave-side output after
it has received SIGCHLD. This used to work on pre-3.12 kernels.
This fix effectively forces non-blocking read() and poll() to
block for parallel i/o to complete for all ttys. It also unwinds
these changes:
1) f8747d4a466ab2cafe56112c51b3379f9fdb7a12
tty: Fix pty master read() after slave closes
2) 52bce7f8d4fc633c9a9d0646eef58ba6ae9a3b73
pty, n_tty: Simplify input processing on final close
3) 1a48632ffed61352a7810ce089dc5a8bcd505a60
pty: Fix input race when closing
Inspired by analysis and patch from Marc Aurele La France <tsi@tuyoix.net>
Reported-by: Volth <openssh@volth.com>
Reported-by: Marc Aurele La France <tsi@tuyoix.net>
BugLink: https://bugzilla.mindrot.org/show_bug.cgi?id=52
BugLink: https://bugzilla.mindrot.org/show_bug.cgi?id=2492
Signed-off-by: Brian Bloniarz <brian.bloniarz@gmail.com>
Reviewed-by: Peter Hurley <peter@hurleysoftware.com>
commit 17dcc37e3e847bc0e67a5b1ec52471fcc6c18682 upstream.
On some SOCs PORTS_IMPL register value is never programmed by the
firmware and left at zero value. Which means that no sata ports are
available for software. AHCI driver used to cope up with this by
fabricating the port_map if the PORTS_IMPL register is read zero,
but recent patch broke this workaround as zero value was valid for
NVMe disks.
This patch adds ports-implemented DT bindings as workaround for this issue
in a way that DT can can override the PORTS_IMPL register in cases where
the firmware did not program it already.
Fixes: 566d1827df2e ("libata: disable forced PORTS_IMPL for >= AHCI 1.3")
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Acked-by: Tejun Heo <tj@kernel.org>
Reviewed-by: Andy Gross <andy.gross@linaro.org>
commit e9adb336d0bf391be23e820975ca5cd12c31d781 upstream.
mfio 84 to 89 are described wrongly, fix it to describe
the right pin and add them to right pin-mux group.
The correct order is:
pll1_lock => mips_pll -- MFIO_83
pll2_lock => audio_pll -- MFIO_84
pll3_lock => rpu_v_pll -- MFIO_85
pll4_lock => rpu_l_pll -- MFIO_86
pll5_lock => sys_pll -- MFIO_87
pll6_lock => wifi_pll -- MFIO_88
pll7_lock => bt_pll -- MFIO_89
Cc: linux-gpio@vger.kernel.org
Cc: devicetree@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: James Hartley <James.Hartley@imgtec.com>
Fixes: cefc03e5995e("pinctrl: Add Pistachio SoC pin control driver")
Signed-off-by: Govindraj Raja <Govindraj.Raja@imgtec.com>
Acked-by: Andrew Bresticker <abrestic@chromium.org>
commit 1363074667a6b7d0507527742ccd7bbed5e3ceaa upstream.
Add a new NO_REPORT_LUNS quirk and set it for Seagate drives with
an usb-id of: 0bc2:331a, as these will fail to respond to a
REPORT_LUNS command.
Reported-and-tested-by: David Webb <djw@noc.ac.uk>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 844a5fe219cf472060315971e15cbf97674a3324 upstream.
Yes, all of these are needed. :) This is admittedly a bit odd, but
kvm-unit-tests access.flat tests this if you run it with "-cpu host"
and of course ept=0.
KVM runs the guest with CR0.WP=1, so it must handle supervisor writes
specially when pte.u=1/pte.w=0/CR0.WP=0. Such writes cause a fault
when U=1 and W=0 in the SPTE, but they must succeed because CR0.WP=0.
When KVM gets the fault, it sets U=0 and W=1 in the shadow PTE and
restarts execution. This will still cause a user write to fault, while
supervisor writes will succeed. User reads will fault spuriously now,
and KVM will then flip U and W again in the SPTE (U=1, W=0). User reads
will be enabled and supervisor writes disabled, going back to the
originary situation where supervisor writes fault spuriously.
When SMEP is in effect, however, U=0 will enable kernel execution of
this page. To avoid this, KVM also sets NX=1 in the shadow PTE together
with U=0. If the guest has not enabled NX, the result is a continuous
stream of page faults due to the NX bit being reserved.
The fix is to force EFER.NX=1 even if the CPU is taking care of the EFER
switch. (All machines with SMEP have the CPU_LOAD_IA32_EFER vm-entry
control, so they do not use user-return notifiers for EFER---if they did,
EFER.NX would be forced to the same value as the host).
There is another bug in the reserved bit check, which I've split to a
separate patch for easier application to stable kernels.
Reviewed-by: Xiao Guangrong <guangrong.xiao@linux.intel.com>
Fixes: f6577a5fa15d82217ca73c74cd2dcbc0f6c781dd
