The SWP instruction was deprecated in the ARMv6 architecture, superseded
by the LDREX/STREX family of instructions for
load-linked/store-conditional operations. The ARMv7 multiprocessing
extensions mandate that SWP/SWPB instructions are treated as undefined
from reset, with the ability to enable them through the System Control
Register SW bit.
This patch adds the alternative solution to emulate the SWP and SWPB
instructions using LDREX/STREX sequences, and log statistics to
/proc/cpu/swp_emulation. To correctly deal with copy-on-write, it also
modifies cpu_v7_set_pte_ext to change the mappings to priviliged RO when
user RO.
Signed-off-by: Leif Lindholm <leif.lindholm@arm.com>
Change-Id: I10616601fb05643561e5301064c115ee268846bf
(cherry picked from commit 81b437e0fabd3049f141bc5820970c325c478574)
Reviewed-on: http://git-master/r/10091
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Tested-by: Jonathan Mayo <jmayo@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
In kernel-2.6.32 some times softlockups are seen with cgroup file locking.
Some of the locking issues are fixed in kernel-34. Pulling the kernel-2.6.34
changes related to the cgroups and integrated with k32. With this change
soft lockups with cgroups file locking are not observed.
Bug 714293
Bug 703146
Change-Id: I8debb33d1edb34abdea3169e37a7b4f0ec302f40
cgroups: fix 2.6.32 regression causing BUG_ON() in cgroup_diput()
The LTP cgroup test suite generates a "kernel BUG at kernel/cgroup.c:790!"
here in cgroup_diput():
* if we're getting rid of the cgroup, refcount should ensure
* that there are no pidlists left.
BUG_ON(!list_empty(&cgrp->pidlists));
The cgroup pidlist rework in 2.6.32 generates the BUG_ON, which is caused
when pidlist_array_load() calls cgroup_pidlist_find():
(1) if a matching cgroup_pidlist is found, it down_write's the mutex of the
pre-existing cgroup_pidlist, and increments its use_count.
(2) if no matching cgroup_pidlist is found, then a new one is allocated, it
down_write's its mutex, and the use_count is set to 0.
(3) the matching, or new, cgroup_pidlist gets returned back to pidlist_array_load(),
which increments its use_count -- regardless whether new or pre-existing --
and up_write's the mutex.
So if a matching list is ever encountered by cgroup_pidlist_find() during
the life of a cgroup directory, it results in an inflated use_count value,
preventing it from ever getting released by cgroup_release_pid_array().
Then if the directory is subsequently removed, cgroup_diput() hits the
BUG_ON() when it finds that the directory's cgroup is still populated with
a pidlist.
The patch simply removes the use_count increment when a matching pidlist
is found by cgroup_pidlist_find(), because it gets bumped by the calling
pidlist_array_load() function while still protected by the list's mutex.
Signed-off-by: Dave Anderson <anderson@redhat.com>
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Ben Blum <bblum@andrew.cmu.edu>
Cc: Paul Menage <menage@google.com>
Cc: <stable@kernel.org>
cgroups: fix to return errno in a failure path
In cgroup_create(), if alloc_css_id() returns failure, the errno is not
propagated to userspace, so mkdir will fail silently.
To trigger this bug, we mount blkio (or memory subsystem), and create more
then 65534 cgroups. (The number of cgroups is limited to 65535 if a
subsystem has use_id == 1)
# mount -t cgroup -o blkio xxx /mnt
# for ((i = 0; i < 65534; i++)); do mkdir /mnt/$i; done
# mkdir /mnt/65534
(should return ENOSPC)
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Acked-by: Paul Menage <menage@google.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
sched, cgroups: Fix module export
I have exported it in d11c563 - but cgroups.c did not have module.h included ...
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
LKML-Reference: <1266887105-1528-6-git-send-email-paulmck@linux.vnet.ibm.com>
cgroup: introduce cancel_attach()
Add cancel_attach() operation to struct cgroup_subsys. cancel_attach()
can be used when can_attach() operation prepares something for the subsys,
but we should rollback what can_attach() operation has prepared if attach
task fails after we've succeeded in can_attach().
Change-Id: I04a834952591179843f925e7db719df4d82a69bf
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Acked-by: Li Zefan <lizf@cn.fujitsu.com>
Reviewed-by: Paul Menage <menage@google.com>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
cgroup: introduce coalesce css_get() and css_put()
Current css_get() and css_put() increment/decrement css->refcnt one by
one.
This patch add a new function __css_get(), which takes "count" as a arg
and increment the css->refcnt by "count". And this patch also add a new
arg("count") to __css_put() and change the function to decrement the
These coalesce version of __css_get()/__css_put() will be used to improve
performance of memcg's moving charge feature later, where instead of
calling css_get()/css_put() repeatedly, these new functions will be used.
No change is needed for current users of css_get()/css_put().
Cc: Li Zefan <lizf@cn.fujitsu.com>
cgroups: revamp subsys array
This patch series provides the ability for cgroup subsystems to be
compiled as modules both within and outside the kernel tree. This is
mainly useful for classifiers and subsystems that hook into components
that are already modules. cls_cgroup and blkio-cgroup serve as the
example use cases for this feature.
It provides an interface cgroup_load_subsys() and cgroup_unload_subsys()
which modular subsystems can use to register and depart during runtime.
The net_cls classifier subsystem serves as the example for a subsystem
which can be converted into a module using these changes.
Patch #1 sets up the subsys[] array so its contents can be dynamic as
modules appear and (eventually) disappear. Iterations over the array are
modified to handle when subsystems are absent, and the dynamic section of
the array is protected by cgroup_mutex.
Patch #2 implements an interface for modules to load subsystems, called
cgroup_load_subsys, similar to cgroup_init_subsys, and adds a module
pointer in struct cgroup_subsys.
Patch #3 adds a mechanism for unloading modular subsystems, which includes
a more advanced rework of the rudimentary reference counting introduced in
patch 2.
Patch #4 modifies the net_cls subsystem, which already had some module
declarations, to be configurable as a module, which also serves as a
simple proof-of-concept.
Part of implementing patches 2 and 4 involved updating css pointers in
each css_set when the module appears or leaves. In doing this, it was
discovered that css_sets always remain linked to the dummy cgroup,
regardless of whether or not any subsystems are actually bound to it
(i.e., not mounted on an actual hierarchy). The subsystem loading and
unloading code therefore should keep in mind the special cases where the
added subsystem is the only one in the dummy cgroup (and therefore all
css_sets need to be linked back into it) and where the removed subsys was
the only one in the dummy cgroup (and therefore all css_sets should be
unlinked from it) - however, as all css_sets always stay attached to the
dummy cgroup anyway, these cases are ignored. Any fix that addresses this
issue should also make sure these cases are addressed in the subsystem
loading and unloading code.
This patch:
Make subsys[] able to be dynamically populated to support modular
subsystems
This patch reworks the way the subsys[] array is used so that subsystems
can register themselves after boot time, and enables the internals of
cgroups to be able to handle when subsystems are not present or may
appear/disappear.
Signed-off-by: Ben Blum <bblum@andrew.cmu.edu>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
cgroups: subsystem module loading interface
Add interface between cgroups subsystem management and module loading
This patch implements rudimentary module-loading support for cgroups -
namely, a cgroup_load_subsys (similar to cgroup_init_subsys) for use as a
module initcall, and a struct module pointer in struct cgroup_subsys.
Several functions that might be wanted by modules have had EXPORT_SYMBOL
added to them, but it's unclear exactly which functions want it and which
won't.
cgroups: subsystem module unloading
Provides support for unloading modular subsystems.
This patch adds a new function cgroup_unload_subsys which is to be used
for removing a loaded subsystem during module deletion. Reference
counting of the subsystems' modules is moved from once (at load time) to
once per attached hierarchy (in parse_cgroupfs_options and
rebind_subsystems) (i.e., 0 or 1).
cgroups: clean up cgroup_pidlist_find() a bit
Don't call get_pid_ns() before we locate/alloc the ns.
Cc: Serge Hallyn <serue@us.ibm.com>
cgroup: implement eventfd-based generic API for notifications
This patchset introduces eventfd-based API for notifications in cgroups
and implements memory notifications on top of it.
It uses statistics in memory controler to track memory usage.
Output of time(1) on building kernel on tmpfs:
Root cgroup before changes:
make -j2 506.37 user 60.93s system 193% cpu 4:52.77 total
Non-root cgroup before changes:
make -j2 507.14 user 62.66s system 193% cpu 4:54.74 total
Root cgroup after changes (0 thresholds):
make -j2 507.13 user 62.20s system 193% cpu 4:53.55 total
Non-root cgroup after changes (0 thresholds):
make -j2 507.70 user 64.20s system 193% cpu 4:55.70 total
Root cgroup after changes (1 thresholds, never crossed):
make -j2 506.97 user 62.20s system 193% cpu 4:53.90 total
Non-root cgroup after changes (1 thresholds, never crossed):
make -j2 507.55 user 64.08s system 193% cpu 4:55.63 total
This patch:
Introduce the write-only file "cgroup.event_control" in every cgroup.
To register new notification handler you need:
- create an eventfd;
- open a control file to be monitored. Callbacks register_event() and
unregister_event() must be defined for the control file;
- write "<event_fd> <control_fd> <args>" to cgroup.event_control.
Interpretation of args is defined by control file implementation;
eventfd will be woken up by control file implementation or when the
cgroup is removed.
To unregister notification handler just close eventfd.
If you need notification functionality for a control file you have to
implement callbacks register_event() and unregister_event() in the
struct cftype.
[kamezawa.hiroyu@jp.fujitsu.com: Kconfig fix]
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Pavel Emelyanov <xemul@openvz.org>
Cc: Dan Malek <dan@embeddedalley.com>
Cc: Vladislav Buzov <vbuzov@embeddedalley.com>
Cc: Alexander Shishkin <virtuoso@slind.org>
Cc: Davide Libenzi <davidel@xmailserver.org>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Change-Id: I73060a6a951a86a6e2b5d03d36e1777aaf4f9fe2
cgroups: fix race between userspace and kernelspace
Notify userspace about cgroup removing only after rmdir of cgroup
directory to avoid race between userspace and kernelspace.
eventfd are used to notify about two types of event:
- control file-specific, like crossing memory threshold;
- cgroup removing.
To understand what really happen, userspace can check if the cgroup still
exists. To avoid race beetween userspace and kernelspace we have to
notify userspace about cgroup removing only after rmdir of cgroup
directory.
cgroups: remove duplicate include
commit e6a1105b ("cgroups: subsystem module loading interface") and commit
c50cc752 ("sched, cgroups: Fix module export") result in duplicate
including of module.h
cgroup: Fix an RCU warning in alloc_css_id()
With CONFIG_PROVE_RCU=y, a warning can be triggered:
# mount -t cgroup -o memory xxx /mnt
# mkdir /mnt/0
kernel/cgroup.c:4442 invoked rcu_dereference_check() without protection!
This is a false-positive. It's safe to directly access parent_css->id.
(cherry picked from commit cf6e8b67221b96d73c0a9dfb71856627ab4bd1b7)
Change-Id: Ibc9f6adcb55e37834ce030036c83b0405afc13f4
Reviewed-on: http://git-master/r/7823
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Tested-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
(cherry picked from afbcf7ab8d1bc8c2d04792f6d9e786e0adeb328d)
When we migrate a kvm guest that uses pvclock between two hosts, we may
suffer a large skew. This is because there can be significant differences
between the monotonic clock of the hosts involved. When a new host with
a much larger monotonic time starts running the guest, the view of time
will be significantly impacted.
Situation is much worse when we do the opposite, and migrate to a host with
a smaller monotonic clock.
This proposed ioctl will allow userspace to inform us what is the monotonic
clock value in the source host, so we can keep the time skew short, and
more importantly, never goes backwards. Userspace may also need to trigger
the current data, since from the first migration onwards, it won't be
reflected by a simple call to clock_gettime() anymore.
[marcelo: future-proof abi with a flags field]
[jan: fix KVM_GET_CLOCK by clearing flags field instead of checking it]
Signed-off-by: Glauber Costa <glommer@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
Signed-off-by: Mike Chan <mike@android.com>
commit 5bf583473813530c1bf82051a35fac8d5045f4f7 upstream.
If docs are being built in a separate directory, xmlto and xsltproc
can't find included sources. Make links back to the source directory.
I would much prefer to have xmlto and xsltproc look in the source
directory for included entities but couldn't see how to do that. This
needs to be solved in some way for 2.6.32, even if this patch isn't the
right way to do it.
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 49b14650ba5bf80234cb1984fd8396aff03430ce upstream.
The rule for %.html removes the output directory, so there is no point
in copying images before building HTML.
Documentation/DocBook/Makefile | 10 +++++-----
SubVendor ID: 0x1043 Device ID: 0x4847)
commit e3c6e1aaa5db7822524f5b1355960fd732910068 upstream.
Adds the device IDs and driver linking to allow the Asus Europa DVB-T
card to operate with these drivers.
The device has a SAA7134 chipset with a TD1316 Hybrid Tuner.
All inputs work on the card including switching between DVB-T and
Analogue TV, there is also no IR with this card.
[mchehab@redhat.com: CodingStyle fixes]
Signed-off-by: Danny Wood <danwood76@gmail.com>
commit 6d3b82f2d31f22085e5711b28dddcb9fb3d97a25 upstream.
Per commit 240799cd, the option name for readahead should be
inode_readahead_blks, not inode_readahead.
Signed-off-by: Fang Wenqi <antonf@turbolinux.com.cn>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 7a92263705435d046d37a0990d0edfcb517f7ad3 upstream.
For both .33 and .32-stable.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
commit 518c8df77c21b7d1690dd8b96eb0e54c4ec1c9c1 upstream.
Signed-off-by: Rafal Milecki <zajec5@gmail.com>
Signed-off-by: Jean-Francois Moine <moinejf@free.fr>
Cc: Surbhi Palande <surbhi.palande@canonical.com>
commit a0bb108112a872c0b0c4b3ef4974f95fb75b155d upstream.
This patch (as1311) fixes a problem in usb-storage: Some devices are
pretty broken when it comes to reporting sense data. The information
they send back indicates that they have more than 18 bytes of sense
data available, but when the system asks for more than 18 they fail or
hang. The symptom is that probing fails with multiple resets.
The patch adds a new BAD_SENSE flag to indicate that usb-storage
should never ask for more than 18 bytes of sense data. The flag can
be set in an unusual_devs entry or via the "quirks=" module parameter,
and it is set automatically whenever a REQUEST SENSE command for more
than 18 bytes fails or times out.
An unusual_devs entry is added for the Agfa photo frame, which uses a
Prolific chip having this bug.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Daniel Kukula <daniel.kuku@gmail.com>
(cherry picked from commit e3bb52ae2bb9573e84c17b8e3560378d13a5c798)
Users on the linux-ext4 list recently complained about differences
across filesystems w.r.t. how to mount without a journal replay.
In the discussion it was noted that xfs's "norecovery" option is
perhaps more descriptively accurate than "noload," so let's make
that an alias for ext4.
Also show this status in /proc/mounts
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
(cherry picked from commit 5328e635315734d42080de9a5a1ee87bf4cae0a4)
It is anticipated that when sb_issue_discard starts doing
real work on trim-capable devices, we may see issues. Make
this mount-time optional, and default it to off until we know
that things are working out OK.
Move slow_work's debugging proc file to debugfs.
Requested-and-acked-by: Ingo Molnar <mingo@elte.hu>
The fbdev mailing lists at SourceForge have been migrated to a single
mailing list at kernel.org: linux-fbdev@vger.kernel.org.
Acked-by: Jean Delvare <khali@linux-fr.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-fscache: (31 commits)
FS-Cache: Provide nop fscache_stat_d() if CONFIG_FSCACHE_STATS=n
SLOW_WORK: Fix GFS2 to #include <linux/module.h> before using THIS_MODULE
SLOW_WORK: Fix CIFS to pass THIS_MODULE to slow_work_register_user()
CacheFiles: Don't log lookup/create failing with ENOBUFS
CacheFiles: Catch an overly long wait for an old active object
CacheFiles: Better showing of debugging information in active object problems
CacheFiles: Mark parent directory locks as I_MUTEX_PARENT to keep lockdep happy
CacheFiles: Handle truncate unlocking the page we're reading
CacheFiles: Don't write a full page if there's only a partial page to cache
FS-Cache: Actually requeue an object when requested
FS-Cache: Start processing an object's operations on that object's death
FS-Cache: Make sure FSCACHE_COOKIE_LOOKING_UP cleared on lookup failure
FS-Cache: Add a retirement stat counter
FS-Cache: Handle pages pending storage that get evicted under OOM conditions
FS-Cache: Handle read request vs lookup, creation or other cache failure
FS-Cache: Don't delete pending pages from the page-store tracking tree
FS-Cache: Fix lock misorder in fscache_write_op()
FS-Cache: The object-available state can't rely on the cookie to be available
FS-Cache: Permit cache retrieval ops to be interrupted in the initial wait phase
FS-Cache: Use radix tree preload correctly in tracking of pages to be stored
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2:
ocfs2: Trivial cleanup of jbd compatibility layer removal
ocfs2: Refresh documentation
ocfs2: return f_fsid info in ocfs2_statfs()
ocfs2: duplicate inline data properly during reflink.
ocfs2: Move ocfs2_complete_reflink to the right place.
ocfs2: Return -EINVAL when a device is not ocfs2.
Catch an overly long wait for an old, dying active object when we want to
replace it with a new one. The probability is that all the slow-work threads
are hogged, and the delete can't get a look in.
What we do instead is:
(1) if there's nothing in the slow work queue, we sleep until either the dying
object has finished dying or there is something in the slow work queue
behind which we can queue our object.
(2) if there is something in the slow work queue, we return ETIMEDOUT to
fscache_lookup_object(), which then puts us back on the slow work queue,
presumably behind the deletion that we're blocked by. We are then
deferred for a while until we work our way back through the queue -
without blocking a slow-work thread unnecessarily.
A backtrace similar to the following may appear in the log without this patch:
INFO: task kslowd004:5711 blocked for more than 120 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
kslowd004 D 0000000000000000 0 5711 2 0x00000080
ffff88000340bb80 0000000000000046 ffff88002550d000 0000000000000000
ffff88002550d000 0000000000000007 ffff88000340bfd8 ffff88002550d2a8
000000000000ddf0 00000000000118c0 00000000000118c0 ffff88002550d2a8
Call Trace:
[<ffffffff81058e21>] ? trace_hardirqs_on+0xd/0xf
[<ffffffffa011c4d8>] ? cachefiles_wait_bit+0x0/0xd [cachefiles]
[<ffffffffa011c4e1>] cachefiles_wait_bit+0x9/0xd [cachefiles]
[<ffffffff81353153>] __wait_on_bit+0x43/0x76
[<ffffffff8111ae39>] ? ext3_xattr_get+0x1ec/0x270
[<ffffffff813531ef>] out_of_line_wait_on_bit+0x69/0x74
[<ffffffff8104c125>] ? wake_bit_function+0x0/0x2e
[<ffffffffa011bc79>] cachefiles_mark_object_active+0x203/0x23b [cachefiles]
[<ffffffffa011c209>] cachefiles_walk_to_object+0x558/0x827 [cachefiles]
[<ffffffffa011a429>] cachefiles_lookup_object+0xac/0x12a [cachefiles]
[<ffffffffa00aa1e9>] fscache_lookup_object+0x1c7/0x214 [fscache]
[<ffffffffa00aafc5>] fscache_object_state_machine+0xa5/0x52d [fscache]
[<ffffffffa00ab4ac>] fscache_object_slow_work_execute+0x5f/0xa0 [fscache]
[<ffffffff81082093>] slow_work_execute+0x18f/0x2d1
[<ffffffff8108239a>] slow_work_thread+0x1c5/0x308
[<ffffffff8104c0f1>] ? autoremove_wake_function+0x0/0x34
[<ffffffff810821d5>] ? slow_work_thread+0x0/0x308
[<ffffffff8104be91>] kthread+0x7a/0x82
[<ffffffff8100beda>] child_rip+0xa/0x20
[<ffffffff8100b87c>] ? restore_args+0x0/0x30
[<ffffffff8104be17>] ? kthread+0x0/0x82
[<ffffffff8100bed0>] ? child_rip+0x0/0x20
1 lock held by kslowd004/5711:
#0: (&sb->s_type->i_mutex_key#7/1){+.+.+.}, at: [<ffffffffa011be64>] cachefiles_walk_to_object+0x1b3/0x827 [cachefiles]
Start processing an object's operations when that object moves into the DYING
state as the object cannot be destroyed until all its outstanding operations
have completed.
Furthermore, make sure that read and allocation operations handle being woken
up on a dead object. Such events are recorded in the Allocs.abt and
Retrvls.abt statistics as viewable through /proc/fs/fscache/stats.
The code for waiting for object activation for the read and allocation
operations is also extracted into its own function as it is much the same in
all cases, differing only in the stats incremented.
Handle netfs pages that the vmscan algorithm wants to evict from the pagecache
under OOM conditions, but that are waiting for write to the cache. Under these
conditions, vmscan calls the releasepage() function of the netfs, asking if a
page can be discarded.
The problem is typified by the following trace of a stuck process:
kslowd005 D 0000000000000000 0 4253 2 0x00000080
ffff88001b14f370 0000000000000046 ffff880020d0d000 0000000000000007
0000000000000006 0000000000000001 ffff88001b14ffd8 ffff880020d0d2a8
000000000000ddf0 00000000000118c0 00000000000118c0 ffff880020d0d2a8
Call Trace:
[<ffffffffa00782d8>] __fscache_wait_on_page_write+0x8b/0xa7 [fscache]
[<ffffffffa0078240>] ? __fscache_check_page_write+0x63/0x70 [fscache]
[<ffffffffa00b671d>] nfs_fscache_release_page+0x4e/0xc4 [nfs]
[<ffffffffa00927f0>] nfs_release_page+0x3c/0x41 [nfs]
[<ffffffff810885d3>] try_to_release_page+0x32/0x3b
[<ffffffff81093203>] shrink_page_list+0x316/0x4ac
[<ffffffff8109372b>] shrink_inactive_list+0x392/0x67c
[<ffffffff813532fa>] ? __mutex_unlock_slowpath+0x100/0x10b
[<ffffffff81058df0>] ? trace_hardirqs_on_caller+0x10c/0x130
[<ffffffff8135330e>] ? mutex_unlock+0x9/0xb
[<ffffffff81093aa2>] shrink_list+0x8d/0x8f
[<ffffffff81093d1c>] shrink_zone+0x278/0x33c
[<ffffffff81052d6c>] ? ktime_get_ts+0xad/0xba
[<ffffffff81094b13>] try_to_free_pages+0x22e/0x392
[<ffffffff81091e24>] ? isolate_pages_global+0x0/0x212
[<ffffffff8108e743>] __alloc_pages_nodemask+0x3dc/0x5cf
[<ffffffff81089529>] grab_cache_page_write_begin+0x65/0xaa
[<ffffffff8110f8c0>] ext3_write_begin+0x78/0x1eb
[<ffffffff81089ec5>] generic_file_buffered_write+0x109/0x28c
[<ffffffff8103cb69>] ? current_fs_time+0x22/0x29
[<ffffffff8108a509>] __generic_file_aio_write+0x350/0x385
[<ffffffff8108a588>] ? generic_file_aio_write+0x4a/0xae
[<ffffffff8108a59e>] generic_file_aio_write+0x60/0xae
[<ffffffff810b2e82>] do_sync_write+0xe3/0x120
[<ffffffff810b18e1>] ? __dentry_open+0x1a5/0x2b8
[<ffffffff810b1a76>] ? dentry_open+0x82/0x89
[<ffffffffa00e693c>] cachefiles_write_page+0x298/0x335 [cachefiles]
[<ffffffffa0077147>] fscache_write_op+0x178/0x2c2 [fscache]
[<ffffffffa0075656>] fscache_op_execute+0x7a/0xd1 [fscache]
[<ffffffff8102ef83>] ? tg_shares_up+0x171/0x227
In the above backtrace, the following is happening:
(1) A page storage operation is being executed by a slow-work thread
(fscache_write_op()).
(2) FS-Cache farms the operation out to the cache to perform
(cachefiles_write_page()).
(3) CacheFiles is then calling Ext3 to perform the actual write, using Ext3's
standard write (do_sync_write()) under KERNEL_DS directly from the netfs
page.
(4) However, for Ext3 to perform the write, it must allocate some memory, in
particular, it must allocate at least one page cache page into which it
can copy the data from the netfs page.
(5) Under OOM conditions, the memory allocator can't immediately come up with
a page, so it uses vmscan to find something to discard
(try_to_free_pages()).
(6) vmscan finds a clean netfs page it might be able to discard (possibly the
one it's trying to write out).
(7) The netfs is called to throw the page away (nfs_release_page()) - but it's
called with __GFP_WAIT, so the netfs decides to wait for the store to
complete (__fscache_wait_on_page_write()).
(8) This blocks a slow-work processing thread - possibly against itself.
The system ends up stuck because it can't write out any netfs pages to the
cache without allocating more memory.
To avoid this, we make FS-Cache cancel some writes that aren't in the middle of
actually being performed. This means that some data won't make it into the
cache this time. To support this, a new FS-Cache function is added
fscache_maybe_release_page() that replaces what the netfs releasepage()
functions used to do with respect to the cache.
The decisions fscache_maybe_release_page() makes are counted and displayed
through /proc/fs/fscache/stats on a line labelled "VmScan". There are four
counters provided: "nos=N" - pages that weren't pending storage; "gon=N" -
pages that were pending storage when we first looked, but weren't by the time
we got the object lock; "bsy=N" - pages that we ignored as they were actively
being written when we looked; and "can=N" - pages that we cancelled the storage
of.
What I'd really like to do is alter the behaviour of the cancellation
heuristics, depending on how necessary it is to expel pages. If there are
plenty of other pages that aren't waiting to be written to the cache that
could be ejected first, then it would be nice to hold up on immediate
cancellation of cache writes - but I don't see a way of doing that.
FS-Cache doesn't correctly handle the netfs requesting a read from the cache
on an object that failed or was withdrawn by the cache. A trace similar to
the following might be seen:
CacheFiles: Lookup failed error -105
[exe ] unexpected submission OP165afe [OBJ6cac OBJECT_LC_DYING]
[exe ] objstate=OBJECT_LC_DYING [OBJECT_LC_DYING]
[exe ] objflags=0
[exe ] objevent=9 [fffffffffffffffb]
[exe ] ops=0 inp=0 exc=0
Pid: 6970, comm: exe Not tainted 2.6.32-rc6-cachefs #50
Call Trace:
[<ffffffffa0076477>] fscache_submit_op+0x3ff/0x45a [fscache]
[<ffffffffa0077997>] __fscache_read_or_alloc_pages+0x187/0x3c4 [fscache]
[<ffffffffa00b6480>] ? nfs_readpage_from_fscache_complete+0x0/0x66 [nfs]
[<ffffffffa00b6388>] __nfs_readpages_from_fscache+0x7e/0x176 [nfs]
[<ffffffff8108e483>] ? __alloc_pages_nodemask+0x11c/0x5cf
[<ffffffffa009d796>] nfs_readpages+0x114/0x1d7 [nfs]
[<ffffffff81090314>] __do_page_cache_readahead+0x15f/0x1ec
[<ffffffff81090228>] ? __do_page_cache_readahead+0x73/0x1ec
[<ffffffff810903bd>] ra_submit+0x1c/0x20
[<ffffffff810906bb>] ondemand_readahead+0x227/0x23a
[<ffffffff81090762>] page_cache_sync_readahead+0x17/0x19
[<ffffffff8108a99e>] generic_file_aio_read+0x236/0x5a0
[<ffffffffa00937bd>] nfs_file_read+0xe4/0xf3 [nfs]
[<ffffffff810b2fa2>] do_sync_read+0xe3/0x120
[<ffffffff81354cc3>] ? _spin_unlock_irq+0x2b/0x31
[<ffffffff811848e5>] ? selinux_file_permission+0x5d/0x10f
[<ffffffff81352bdb>] ? thread_return+0x3e/0x101
[<ffffffff8117d7b0>] ? security_file_permission+0x11/0x13
[<ffffffff810b3b06>] vfs_read+0xaa/0x16f
[<ffffffff810b3c84>] sys_read+0x45/0x6c
[<ffffffff8100ae2b>] system_call_fastpath+0x16/0x1b
The object state might also be OBJECT_DYING or OBJECT_WITHDRAWING.
This should be handled by simply rejecting the new operation with ENOBUFS.
There's no need to log an error for it. Events of this type now appear in the
stats file under Ops:rej.
FS-Cache has two structs internally for keeping track of the internal state of
a cached file: the fscache_cookie struct, which represents the netfs's state,
and fscache_object struct, which represents the cache's state. Each has a
pointer that points to the other (when both are in existence), and each has a
spinlock for pointer maintenance.
Since netfs operations approach these structures from the cookie side, they get
the cookie lock first, then the object lock. Cache operations, on the other
hand, approach from the object side, and get the object lock first. It is not
then permitted for a cache operation to get the cookie lock whilst it is
holding the object lock lest deadlock occur; instead, it must do one of two
things:
(1) increment the cookie usage counter, drop the object lock and then get both
locks in order, or
(2) simply hold the object lock as certain parts of the cookie may not be
altered whilst the object lock is held.
It is also not permitted to follow either pointer without holding the lock at
the end you start with. To break the pointers between the cookie and the
object, both locks must be held.
fscache_write_op(), however, violates the locking rules: It attempts to get the
cookie lock without (a) checking that the cookie pointer is a valid pointer,
and (b) holding the object lock to protect the cookie pointer whilst it follows
it. This is so that it can access the pending page store tree without
interference from __fscache_write_page().
This is fixed by splitting the cookie lock, such that the page store tracking
tree is protected by its own lock, and checking that the cookie pointer is
non-NULL before we attempt to follow it whilst holding the object lock.
The new lock is subordinate to both the cookie lock and the object lock, and so
should be taken after those.
Permit the operations to retrieve data from the cache or to allocate space in
the cache for future writes to be interrupted whilst they're waiting for
permission for the operation to proceed. Typically this wait occurs whilst the
cache object is being looked up on disk in the background.
If an interruption occurs, and the operation has not yet been given the
go-ahead to run, the operation is dequeued and cancelled, and control returns
to the read operation of the netfs routine with none of the requested pages
having been read or in any way marked as known by the cache.
This means that the initial wait is done interruptibly rather than
uninterruptibly.
In addition, extra stats values are made available to show the number of ops
cancelled and the number of cache space allocations interrupted.
Count entries to and exits from cache operation table functions. Maintain
these as a single counter that's added to or removed from as appropriate.
Allow the current state of all fscache objects to be dumped by doing:
cat /proc/fs/fscache/objects
By default, all objects and all fields will be shown. This can be restricted
by adding a suitable key to one of the caller's keyrings (such as the session
keyring):
keyctl add user fscache:objlist "<restrictions>" @s
The <restrictions> are:
K Show hexdump of object key (don't show if not given)
A Show hexdump of object aux data (don't show if not given)
And paired restrictions:
C Show objects that have a cookie
c Show objects that don't have a cookie
B Show objects that are busy
b Show objects that aren't busy
W Show objects that have pending writes
w Show objects that don't have pending writes
R Show objects that have outstanding reads
r Show objects that don't have outstanding reads
S Show objects that have slow work queued
s Show objects that don't have slow work queued
If neither side of a restriction pair is given, then both are implied. For
example:
keyctl add user fscache:objlist KB @s
shows objects that are busy, and lists their object keys, but does not dump
their auxiliary data. It also implies "CcWwRrSs", but as 'B' is given, 'b' is
not implied.
Add a function to allow a requeueable work item to sleep till the thread
processing it is needed by the slow-work facility to perform other work.
Sometimes a work item can't progress immediately, but must wait for the
completion of another work item that's currently being processed by another
slow-work thread.
In some circumstances, the waiting item could instead - theoretically - put
itself back on the queue and yield its thread back to the slow-work facility,
thus waiting till it gets processing time again before attempting to progress.
This would allow other work items processing time on that thread.
However, this only works if there is something on the queue for it to queue
behind - otherwise it will just get a thread again immediately, and will end
up cycling between the queue and the thread, eating up valuable CPU time.
So, slow_work_sleep_till_thread_needed() is provided such that an item can put
itself on a wait queue that will wake it up when the event it is actually
interested in occurs, then call this function in lieu of calling schedule().
This function will then sleep until either the item's event occurs or another
work item appears on the queue. If another work item is queued, but the
item's event hasn't occurred, then the work item should requeue itself and
yield the thread back to the slow-work facility by returning.
This can be used by CacheFiles for an object that is being created on one
thread to wait for an object being deleted on another thread where there is
nothing on the queue for the creation to go and wait behind. As soon as an
item appears on the queue that could be given thread time instead, CacheFiles
can stick the creating object back on the queue and return to the slow-work
facility - assuming the object deletion didn't also complete.
Add a function (slow_work_is_queued()) to permit the owner of a work item to
determine if the item is queued or not.
The work item is counted as being queued if it is actually on the queue, not
just if it is pending. If it is executing and pending, then it is not on the
queue, but will rather be put back on the queue when execution finishes.
This permits a caller to quickly work out if it may be able to put another,
dependent work item on the queue behind it, or whether it will have to wait
till that is finished.
This can be used by CacheFiles to work out whether the creation a new object
can be immediately deferred when it has to wait for an old object to be
deleted, or whether a wait must take place. If a wait is necessary, then the
slow-work thread can otherwise get blocked, preventing the deletion from
taking place.
Allow the executing and queued work items to be viewed through a /proc file
for debugging purposes. The contents look something like the following:
THR PID ITEM ADDR FL MARK DESC
0 3005 ffff880023f52348 a 952ms FSC: OBJ17d3: LOOK
1 3006 ffff880024e33668 2 160ms FSC: OBJ17e5 OP60d3b: Write1/Store fl=2
2 3165 ffff8800296dd180 a 424ms FSC: OBJ17e4: LOOK
3 4089 ffff8800262c8d78 a 212ms FSC: OBJ17ea: CRTN
4 4090 ffff88002792bed8 2 388ms FSC: OBJ17e8 OP60d36: Write1/Store fl=2
5 4092 ffff88002a0ef308 2 388ms FSC: OBJ17e7 OP60d2e: Write1/Store fl=2
6 4094 ffff88002abaf4b8 2 132ms FSC: OBJ17e2 OP60d4e: Write1/Store fl=2
7 4095 ffff88002bb188e0 a 388ms FSC: OBJ17e9: CRTN
vsq - ffff880023d99668 1 308ms FSC: OBJ17e0 OP60f91: Write1/EnQ fl=2
vsq - ffff8800295d1740 1 212ms FSC: OBJ16be OP4d4b6: Write1/EnQ fl=2
vsq - ffff880025ba3308 1 160ms FSC: OBJ179a OP58dec: Write1/EnQ fl=2
vsq - ffff880024ec83e0 1 160ms FSC: OBJ17ae OP599f2: Write1/EnQ fl=2
vsq - ffff880026618e00 1 160ms FSC: OBJ17e6 OP60d33: Write1/EnQ fl=2
vsq - ffff880025a2a4b8 1 132ms FSC: OBJ16a2 OP4d583: Write1/EnQ fl=2
vsq - ffff880023cbe6d8 9 212ms FSC: OBJ17eb: LOOK
vsq - ffff880024d37590 9 212ms FSC: OBJ17ec: LOOK
vsq - ffff880027746cb0 9 212ms FSC: OBJ17ed: LOOK
vsq - ffff880024d37ae8 9 212ms FSC: OBJ17ee: LOOK
vsq - ffff880024d37cb0 9 212ms FSC: OBJ17ef: LOOK
vsq - ffff880025036550 9 212ms FSC: OBJ17f0: LOOK
vsq - ffff8800250368e0 9 212ms FSC: OBJ17f1: LOOK
vsq - ffff880025036aa8 9 212ms FSC: OBJ17f2: LOOK
In the 'THR' column, executing items show the thread they're occupying and
queued threads indicate which queue they're on. 'PID' shows the process ID of
a slow-work thread that's executing something. 'FL' shows the work item flags.
'MARK' indicates how long since an item was queued or began executing. Lastly,
the 'DESC' column permits the owner of an item to give some information.
This adds support for starting slow work with a delay, similar
to the functionality we have for workqueues.
Add support for cancellation of queued slow work and delayed slow work items.
The cancellation functions will wait for items that are pending or undergoing
execution to be discarded by the slow work facility.
Attempting to enqueue work that is in the process of being cancelled will
result in ECANCELED.
Make the ability for the slow-work facility to take references on a work item
optional as not everyone requires this.
Even the internal slow-work stubs them out, so those can be got rid of too.
Wait for outstanding slow work items belonging to a module to clear when
unregistering that module as a user of the facility. This prevents the put_ref
code of a work item from being taken away before it returns.
git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc
* 'hostprogs-wmissing-prototypes' of git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc:
Makefile: Add -Wmising-prototypes to HOSTCFLAGS
oss: Mark loadhex static in hex2hex.c
dtc: Mark various internal functions static
dtc: Set "noinput" in the lexer to avoid an unused function
drm: radeon: Mark several functions static in mkregtable
arch/sparc/boot/*.c: Mark various internal functions static
arch/powerpc/boot/addRamDisk.c: Mark several internal functions static
arch/alpha/boot/tools/objstrip.c: Mark "usage" static
Documentation/vm/page-types.c: Declare checked_open static
genksyms: Mark is_reserved_word static
kconfig: Mark various internal functions static
kconfig: Make zconf.y work with current bison
Nothing outside of Documentation/vm/page-types.c references
checked_open.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com>
Signed-off-by: Joel Becker <joel.becker@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
i2c: Add an interface to lock/unlock an I2C bus segment
i2c-piix4: Modify code name SB900 to Hudson-2
Change SB900 to its formal code name Hudson-2.
Signed-off-by: Crane Cai <crane.cai@amd.com>
Signed-off-by: Frans Pop <elendil@planet.nl>
Acked-by: Zhang Rui <rui.zhang@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
The document currently uses large indentations which make the text
too wide for easy readability. Also improve general consistency.
This reverts commit d0646f7b636d067d715fab52a2ba9c6f0f46b0d7, as
requested by Eric Sandeen.
It can basically cause an ext4 filesystem to miss recovery (and thus get
mounted with errors) if the journal checksum does not match.
Quoth Eric:
"My hand-wavy hunch about what is happening is that we're finding a
bad checksum on the last partially-written transaction, which is
not surprising, but if we have a wrapped log and we're doing the
initial scan for head/tail, and we abort scanning on that bad
checksum, then we are essentially running an unrecovered filesystem.
But that's hand-wavy and I need to go look at the code.
We lived without journal checksums on by default until now, and at
this point they're doing more harm than good, so we should revert
the default-changing commit until we can fix it and do some good
power-fail testing with the fixes in place."
See
http://bugzilla.kernel.org/show_bug.cgi?id=14354
for all the gory details.
Requested-by: Eric Sandeen <sandeen@redhat.com>
Cc: Theodore Tso <tytso@mit.edu>
Cc: Alexey Fisher <bug-track@fisher-privat.net>
Cc: Maxim Levitsky <maximlevitsky@gmail.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Mathias Burén <mathias.buren@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: hda - Don't check invalid HP pin
ALSA: dummy - Fix descriptions of pcm_substreams parameter
ALSA: pcmcia: use dynamic debug infrastructure, deprecate CS_CHECK (sound)
ALSA: hda: Use quirk mask for Dell Inspiron Mini9/Vostro A90 using ALC268
sound: via82xx: deactivate DXS controls of inactive streams
ALSA: snd-usb-caiaq: Bump version number to 1.3.20
ALSA: snd-usb-caiaq: Lock on stream start/unpause
ALSA: snd-usb-caiaq: Missing lock around use of buffer positions
ALSA: sound/parisc: Move dereference after NULL test
ALSA: sound: Move dereference after NULL test and drop unnecessary NULL tests
ALSA: hda_intel: Add the Linux device ID for NVIDIA HDA controller
ALSA: pcsp - Fix nforce workaround
ALSA: SND_CS5535AUDIO: Remove the X86 platform dependency
ASoC: Amstrad Delta: add info about the line discipline requirement to Kconfig help text
ASoC: Fix possible codec_dai->ops NULL pointer problems
ALSA: hda - Fix capture source checks for ALC662/663 codecs
ASoC: Serialize access to dapm_power_widgets()
* 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
tracing: Remove cpu arg from the rb_time_stamp() function
tracing: Fix comment typo and documentation example
tracing: Fix trace_seq_printf() return value
tracing: Update *ppos instead of filp->f_pos
Now up to 128 substreams are supported.
Reported-by: Adrian Bridgett <adrian@smop.co.uk>
Describe NUMA node symlink created for CPUs when CONFIG_NUMA is set.
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Signed-off-by: Alex Chiang <achiang@hp.com>
Document cpuidle sysfs attributes by reading code, Documentation/cpuidle/,
and git logs.
Cc: Venki Pallipadi <venkatesh.pallipadi@intel.com>
Cc: Len Brown <lenb@kernel.org>
Document sched_[mc|smt]_power_savings by reading existing code and
git logs.
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Add brief descriptions for the following sysfs files:
/sys/devices/system/cpu/cpu#/topology/core_id
/sys/devices/system/cpu/cpu#/topology/core_siblings
/sys/devices/system/cpu/cpu#/topology/core_siblings_list
/sys/devices/system/cpu/cpu#/topology/physical_package_id
/sys/devices/system/cpu/cpu#/topology/thread_siblings
/sys/devices/system/cpu/cpu#/topology/thread_siblings_list
The descriptions in Documentation/cputopology.txt weren't very
informative, so I attempted a better description based on code
reading and hopeful guessing.
Updated Documentation/cputopology.txt with the better descriptions and
fixed some style issues.
Cc: Mike Travis <travis@sgi.com>
/sys/devices/system/cpu/kernel_max
/sys/devices/system/cpu/offline
/sys/devices/system/cpu/online
/sys/devices/system/cpu/possible
/sys/devices/system/cpu/present
Excerpted the relevant information from Documentation/cputopology.txt
and pointed back to cputopology.txt as the authoritative source of
information.
