path: root/Documentation
2009-02-12PCI: return error on failure to read PCI ROMsTimothy S. Nelson
commit 97c44836cdec1ea713a15d84098a1a908157e68f upstream. This patch makes the ROM reading code return an error to user space if the size of the ROM read is equal to 0. The patch also emits a warnings if the contents of the ROM are invalid, and documents the effects of the "enable" file on ROM reading. Signed-off-by: Timothy S. Nelson <wayland@wayland.id.au> Acked-by: Alex Villacis-Lasso <a_villacis@palosanto.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-24ALSA: hda - make laptop-eapd model back for AD1986ATakashi Iwai
commit 1725b82a6e2721612a3572d0336f51f1f1c3cf54 upstream. The changes specific for Samsung laptops seem unapplicable to other hardware models like ASUS. The mic inputs are lost on such hardware by the change 5d5d5f43f1b835c375de9bd270cce030d16e2871. This patch adds back the old laptop-eapd model, and create a new model "samsung" for the new one specific to Samsung laptops with automatic mic selection feature. Reference: kernel bugzilla #12070 http://bugzilla.kernel.org/show_bug.cgi?id=12070 Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: Daniel Drake <dsd@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-18AMD IOMMU: enable device isolation per defaultJoerg Roedel
commit 3ce1f93c6d53c3f91c3846cf66b018276c8ac2e7 upstream. Impact: makes device isolation the default for AMD IOMMU Some device drivers showed double-free bugs of DMA memory while testing them with AMD IOMMU. If all devices share the same protection domain this can lead to data corruption and data loss. Prevent this by putting each device into its own protection domain per default. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-05epoll: introduce resource usage limitsDavide Libenzi
commit 7ef9964e6d1b911b78709f144000aacadd0ebc21 upstream. It has been thought that the per-user file descriptors limit would also limit the resources that a normal user can request via the epoll interface. Vegard Nossum reported a very simple program (a modified version attached) that can make a normal user to request a pretty large amount of kernel memory, well within the its maximum number of fds. To solve such problem, default limits are now imposed, and /proc based configuration has been introduced. A new directory has been created, named /proc/sys/fs/epoll/ and inside there, there are two configuration points: max_user_instances = Maximum number of devices - per user max_user_watches = Maximum number of "watched" fds - per user The current default for "max_user_watches" limits the memory used by epoll to store "watches", to 1/32 of the amount of the low RAM. As example, a 256MB 32bit machine, will have "max_user_watches" set to roughly 90000. That should be enough to not break existing heavy epoll users. The default value for "max_user_instances" is set to 128, that should be enough too. This also changes the userspace, because a new error code can now come out from EPOLL_CTL_ADD (-ENOSPC). The EMFILE from epoll_create() was already listed, so that should be ok. [akpm@linux-foundation.org: use get_current_user()] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Reported-by: Vegard Nossum <vegardno@ifi.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13cciss: new hardware supportMike Miller
commit 77ca7286d10b798e4907af941f29672bf484db77 upstream cciss: new hardware support Add support for 2 new SAS/SATA controllers. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-06i2c: The i2c mailing list is movingJean Delvare
commit 846557d3ceb6c7493e090921db5d6158ec237228 upstream Replace all references to the old i2c mailing list. This isn't a bug fix, but I would hate to miss bug reports because they're sent to a dead mailing list. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22DVB: au0828: add support for another USB id for Hauppauge HVR950QMichael Krufky
(cherry picked from commit a636da6bab3307fc8c6e6a22a63b0b25ba0687be) DVB: au0828: add support for another USB id for Hauppauge HVR950Q Add autodetection support for a new revision of the Hauppauge HVR950Q (2040:721e) Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-09Merge branch 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: hwmon: (abituguru3) Enable DMI probing feature on Abit AT8 32X hwmon: (abituguru3) Enable reading from AUX3 fan on Abit AT8 32X hwmon: (adt7473) Fix some bogosity in documentation file hwmon: Define sysfs interface for energy consumption register hwmon: (it87) Prevent power-off on Shuttle SN68PT eeepc-laptop: Fix hwmon interface
2008-10-09[CPUFREQ] correct broken links and email addressesNémeth Márton
Replace the no longer working links and email address in the documentation and in source code. Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Dave Jones <davej@redhat.com>
2008-10-09hwmon: (adt7473) Fix some bogosity in documentation fileDarrick J. Wong
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-10-09hwmon: Define sysfs interface for energy consumption registerDarrick J. Wong
Describe the sysfs files that were introduced in the ibmaem driver. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-10-06Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (33 commits) V4L/DVB (9103): em28xx: HVR-900 B3C0 - fix audio clicking issue V4L/DVB (9099): em28xx: Add detection for K-WORLD DVB-T 310U V4L/DVB (9092): gspca: Bad init values for sonixj ov7660. V4L/DVB (9080): gspca: Add a delay after writing to the sonixj sensors. V4L/DVB (9075): gspca: Bad check of returned status in i2c_read() spca561. V4L/DVB (9053): fix buffer overflow in uvc-video V4L/DVB (9043): S5H1420: Fix size of shadow-array to avoid overflow V4L/DVB (9037): Fix support for Hauppauge Nova-S SE V4L/DVB (9029): Fix deadlock in demux code V4L/DVB (8979): sms1xxx: Add new USB product ID for Hauppauge WinTV MiniStick V4L/DVB (8978): sms1xxx: fix product name for Hauppauge WinTV MiniStick V4L/DVB (8967): Use correct XC3028L firmware for AMD ATI TV Wonder 600 V4L/DVB (8963): s2255drv field count fix V4L/DVB (8961): zr36067: Fix RGBR pixel format V4L/DVB (8960): drivers/media/video/cafe_ccic.c needs mm.h V4L/DVB (8958): zr36067: Return proper bytes-per-line value V4L/DVB (8957): zr36067: Restore the default pixel format V4L/DVB (8955): bttv: Prevent NULL pointer dereference in radio_open V4L/DVB (8935): em28xx-cards: Remove duplicate entry (EM2800_BOARD_KWORLD_USB2800) V4L/DVB (8933): gspca: Disable light frquency for zc3xx cs2102 Kokom. ...
2008-10-04V4L/DVB (9099): em28xx: Add detection for K-WORLD DVB-T 310UDarron Broad
Correct firmware type to MTS Correct audio routing for composite/s-video Add DVB-T detection. This patch uses the eeprom hash method for detection as the vendor/product ids are also used for the DIGIVOX_AD. This may be a clone of the same product. Explanatory text has been added prior to the hask look-up in anticipation that it may help others. The following has been tested to work: Analogue TV (PAL-I) Composite In DVB-T (UK Crystal Palace) USB AUDIO The following has not been tested but probably works: S-Video In Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Douglas Schilling Landgraf <dougsland@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-03Documentation/HOWTO: info about interface changes should CC linux-api@vgerMichael Kerrisk
The "Documentation" section of this file mentions that when an interface change is made, I should be CCed with info about the change (so that man-pages can document it). Additionally request that this info be CCed to the new linux-api@vger.kernel.org list. Signed-off-by: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-03SubmitChecklist: interfaces changes should CC linux-api@Michael Kerrisk
Mention that patches that change the kernel-userland interface should be CCed to the new list linux-api@vger.kernel.org. Signed-off-by: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-29V4L/DVB (8909): gspca: PAC 7302 webcam 093a:262a added.Hans de Goede
Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-09-27cdrom: update ioctl documentationMárton Németh
Correct copy-paste problem: CDROMCLOSETRAY is about closing the tray, not opening it. Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-09-23USB: update of Documentation/usb/anchors.txtOliver Neukum
The extended anchor API is documented Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23Documentation/sysctl/kernel.txt: fix softlockup_thresh descriptionAndrew Morton
- s/s/seconds/ - s/10 seconds/60 seconds/ - Mention the zero-disables-it feature. Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-23Documentation/DMA-mapping.txt: update for pci_dma_mapping_error() changesMarin Mitov
Make the example code consistent with changed API. Signed-off-by: Marin Mitov <mitov@ispp.bas.bg> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-13Documentation/ABI: /sys/class/gpioDavid Brownell
Provide summary ABI docs about the /sys/class/gpio files. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-13coredump_filter: add description of bit 4Hidehiro Kawai
There is no description of bit 4 of coredump_filter in the documentation. This patch adds it. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Roland McGrath <roland@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-13cpuset: hotplug documentation fixLi Zefan
If all the cpus in a cpuset are offlined, the tasks in it will be moved to the nearest ancestor with non-empty cpus. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Jackson <pj@sgi.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-10add deprecated ide-scsi to feature-removal-schedule.txtFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-09-09update Documentation/filesystems/Locking for 2.6.27 changesChristoph Hellwig
In the 2.6.27 circle ->fasync lost the BKL, and the last remaining ->open variant that takes the BKL is also gone. ->get_sb and ->kill_sb didn't have BKL forever, so updated the entries while we're at that. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-05Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (98 commits) V4L/DVB (8881): gspca: After 'while (retry--) {...}', retry will be -1 but not 0. V4L/DVB (8880): PATCH: Fix parents on some webcam drivers V4L/DVB (8877): b2c2 and bt8xx: udelay to mdelay V4L/DVB (8876): budget: udelay changed to mdelay V4L/DVB (8874): gspca: Adjust hstart for sn9c103/ov7630 and update usb-id's. V4L/DVB (8873): gspca: Bad image offset with rev012a of spca561 and adjust exposure. V4L/DVB (8872): gspca: Bad image format and offset with rev072a of spca561. V4L/DVB (8870): gspca: Fix dark room problem with sonixb. V4L/DVB (8869): gspca: Move the Sonix webcams with TAS5110C1B from sn9c102 to gspca. V4L/DVB (8868): gspca: Support for vga modes with sif sensors in sonixb. V4L/DVB (8844): dabusb_fpga_download(): fix a memory leak V4L/DVB (8843): tda10048_firmware_upload(): fix a memory leak V4L/DVB (8842): vivi_release(): fix use-after-free V4L/DVB (8840): dib0700: add basic support for Hauppauge Nova-TD-500 (84xxx) V4L/DVB (8839): dib0700: add comment to identify 35th USB id pair V4L/DVB (8837): dvb: fix I2C adapters name size V4L/DVB (8835): gspca: Same pixfmt as the sn9c102 driver and raw Bayer added in sonixb. V4L/DVB (8834): gspca: Have a bigger buffer for sn9c10x compressed images. V4L/DVB (8833): gspca: Cleanup the sonixb code. V4L/DVB (8832): gspca: Bad pixelformat of vc0321 webcams. ...
2008-09-05Merge branch 'release-2.6.27' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-acpi-2.6 * 'release-2.6.27' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-acpi-2.6: acer-wmi: remove debugfs entries upon unloading ACPI: Avoid bogus timeout about SMbus check fujitsu-laptop: fix regression for P8010 in 2.6.27-rc ACPI: Make Len Brown the ACPI maintainer again ACPI: thinkpad-acpi: wan radio control is not experimental PNPACPI: ignore the producer/consumer bit for extended IRQ descriptors acpi: add checking for NULL early param ACPI: Fix typo in "Disable MWAIT via DMI on broken Compal board" ACPI: Fix now signed module parameter. ACPI: Change package length error to warning ACPI: Fix now signed module parameter.
2008-09-04Merge branch 'fixes_stg' of ../git_old into fixesMauro Carvalho Chehab
2008-09-03V4L/DVB (8826): gspca: Webcam Labtec 2200 (093a:2626) added in pac7311.Jean-Francois Moine
2008-09-03V4L/DVB (8825): gspca: More controls for pac73xx and new webcam 093a:2624.Hans de Goede
-Add usb id for 093a:2624 (pac7302) -Report some controls to userspace with 7302 only, as they are 7302 only -Add gain and exposure controls -Add autogain -Fix 7302 imaged being mirrored by default Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-09-03V4L/DVB (8715): gspca: Change the name of some webcam in the gspca doc.Jean-Francois Moine
2008-09-03V4L/DVB (8663): gspca: Webcam 0c45:6128 added in sonixj.Jean-Francois Moine
Patch adapted from a patch to gspcav1 made by the google microdia group. Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-09-03V4L/DVB (8556): au0828: add support for Hauppauge WoodburyMichael Krufky
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-09-02sysfs: document files in /sys/firmware/sgi_uv/Russ Anderson
Document files in /sys/firmware/sgi_uv/. Signed-off-by: Russ Anderson <rja@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02ipc: document the new auto_msgmni proc fileNadia Derbey
Update Documentation/filesystems/proc.txt: it describes the file auto_msgmni intoduced to enable/disable msgmni automatic recomputing upon memory add/remove (see thread http://lkml.org/lkml/2008/7/4/27). Also added a description for msgmni (this filex is only listed in Documentation/sysctl/kernel.txt). Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02NTFS: update homepageAdrian Bunk
Update the location of the NTFS homepage in several files. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02don't diff generated firmware filesArjan van de Ven
With the new firmware infrastructure in 2.6.27, some files are generated and shouldn't be diffed; add these 2 to the "dontdiff" file Signed-off-by: Arjan van de Ven <arjan@Linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-28Merge branch 'wan' into release-2.6.27Andi Kleen
2008-08-28ACPI: thinkpad-acpi: wan radio control is not experimentalJeremy Fitzhardinge
The WWAN radio control has been working well for over three years, and is no longer experimental. Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-08-26lguest: update commentryRusty Russell
2008-08-22Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: Update documentation to remind users to update mke2fs.conf ext4: Fix small file fragmentation ext4: Initialize writeback_index to 0 when allocating a new inode ext4: make sure ext4_has_free_blocks returns 0 for ENOSPC ext4: journal credit fix for the delayed allocation's writepages() function ext4: Rework the ext4_da_writepages() function ext4: journal credits reservation fixes for DIO, fallocate ext4: journal credits reservation fixes for extent file writepage ext4: journal credits calulation cleanup and fix for non-extent writepage ext4: Fix bug where we return ENOSPC even though we have plenty of inodes ext4: don't try to resize if there are no reserved gdt blocks left ext4: Use ext4_discard_reservations instead of mballoc-specific call ext4: Fix ext4_dx_readdir hash collision handling ext4: Fix delalloc release block reservation for truncate ext4: Fix potential truncate BUG due to i_prealloc_list being non-empty ext4: Handle unwritten extent properly with delayed allocation
2008-08-22Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: [libata] pata_it821x: fix warning libata: Fix a large collection of DMA mode mismatches ahci: sis controllers actually can do PMP pata_via: clean up recent tf_load changes libata: restore SControl on detach libata: use ata_link_printk() when printing SError libata: always do follow-up SRST if hardreset returned -EAGAIN libata: fix EH action overwriting in ata_eh_reset() sata_mv: add the Gen IIE flag to the SoC devices. ata_piix: IDE Mode SATA patch for Intel Ibex Peak DeviceIDs ahci: RAID mode SATA patch for Intel Ibex Peak DeviceIDs sata_mv: don't issue two DMA commands concurrently libata: implement no[hs]rst force params
2008-08-22libata: implement no[hs]rst force paramsTejun Heo
Implement force params nohrst, nosrst and norst. This is to work around reset related problems and ease debugging. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-21Documentation: HOWTO-ja_JP-sync patchTsugikazu Shibata
Here is a patch for Documentation/ja_JP/HOWTO sync with latest Documentation/HOWTO. It includes translation of changes done by Jon Corbet,Jiri Pirko and me: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=history;f=Documentation/HOWTO;h=c2371c5a98f99b5eaa785bd0affd6c40187e84e3;hb=HEAD Singed-off-by: Tsugikazu Shibata <tshibata@ab.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-21Japanese translation of Documentation/SubmitChecklistTakenori Nagano
Hi, This patch adds SubmitChecklist translated into Japanese to Documentation/ja_JP directory. The translated SubmitChecklist has already been reviewed by JF project. SubmitChecklist is one of the important policy documents. So, I would like to merge into 2.6.27. Signed-off-by: Takenori Nagano <t-nagano@ah.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-20documentation: describe bootmem_debug kernel parameterAndreas Herrmann
"bootmem_debug" is not mentioned in kernel-parameters.txt. Recently I had to use that kernel option and I think it should be documented. Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Johannes Weiner <hannes@saeurebad.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: (22 commits) [SCSI] ibmvfc: Driver version 1.0.2 [SCSI] ibmvfc: Add details to async event log [SCSI] ibmvfc: Sanitize response lengths [SCSI] ibmvfc: Fix for lost async events [SCSI] ibmvfc: Fixup host state during reinit [SCSI] ibmvfc: Fix another hang on module removal [SCSI] ibmvscsi: Fixup desired DMA value for shared memory partitions [SCSI] megaraid_sas: remove sysfs dbg_lvl world writeable permissions [SCSI] qla2xxx: Update version number to 8.02.01-k7. [SCSI] qla2xxx: Explicitly tear-down vports during PCI remove_one(). [SCSI] qla2xxx: Reference proper ha during SBR handling. [SCSI] qla2xxx: Set npiv_supported flag for FCoE HBAs. [SCSI] qla2xxx: Don't leak SG-DMA mappings while aborting commands. [SCSI] qla2xxx: Correct vport-state management issues during ISP-ABORT. [SCSI] qla2xxx: Correct synchronization of software/firmware fcport states. [SCSI] scsi_dh: Initialize lun_state in check_ownership() [SCSI] scsi_dh: Do not use scsilun in rdac hardware handler [SCSI] megaraid_sas: version and Documentation Update [SCSI] megaraid_sas: add new controllers (0x78 0x79) [SCSI] megaraid_sas: add the shutdown DCMD cmd to driver shutdown routine ...
2008-08-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (94 commits) pkt_sched: Prevent livelock in TX queue running. Revert "pkt_sched: Add BH protection for qdisc_stab_lock." Revert "pkt_sched: Protect gen estimators under est_lock." pkt_sched: remove bogus block (cleanup) nf_nat: use secure_ipv4_port_ephemeral() for NAT port randomization netfilter: ctnetlink: sleepable allocation with spin lock bh netfilter: ctnetlink: fix sleep in read-side lock section netfilter: ctnetlink: fix double helper assignation for NAT'ed conntracks netfilter: ipt_addrtype: Fix matching of inverted destination address type dccp: Fix panic caused by too early termination of retransmission mechanism pkt_sched: Don't hold qdisc lock over qdisc_destroy(). pkt_sched: Add lockdep annotation for qdisc locks pkt_sched: Never schedule non-root qdiscs. removed unused #include <version.h> rt2x00: Fix txdone_entry_desc_flags b43: Fix for another Bluetooth Coexistence SPROM Programming error for BCM4306 mac80211: remove kdoc references to IEEE80211_HW_HOST_GEN_BEACON_TEMPLATE p54u: reset skb's data/tail pointer on requeue p54: move p54_vdcf_init to the right place. iwlwifi: fix printk newlines ...
2008-08-18rfkill: protect suspended rfkill controllersHenrique de Moraes Holschuh
Guard rfkill controllers attached to a rfkill class against state changes after class suspend has been issued. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-16Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (38 commits) [ARM] 5191/1: ARM: remove CVS keywords [ARM] pxafb: fix the warning of incorrect lccr when lcd_conn is specified [ARM] pxafb: add flag to specify output format on LDD pins when base is RGBT16 [ARM] pxafb: fix the incorrect configuration of GPIO77 as ACBIAS for TFT LCD [ARM] 5198/1: PalmTX: PCMCIA fixes [ARM] Fix a pile of broken watchdog drivers [ARM] update mach-types [ARM] 5196/1: fix inline asm constraints for preload [ARM] 5194/1: update .gitignore [ARM] add proc-macros.S include to proc-arm940 and proc-arm946 [ARM] 5192/1: ARM TLB: add v7wbi_{possible,always}_flags to {possible,always}_tlb_flags [ARM] 5193/1: Wire up missing syscalls [ARM] traps: don't call undef hook functions with spinlock held [ARM] 5183/2: Provide Poodle LoCoMo GPIO names [ARM] dma-mapping: provide sync_range APIs [ARM] dma-mapping: improve type-safeness of DMA translations [ARM] Kirkwood: instantiate the orion_spi driver in the platform code [ARM] prevent crashing when too much RAM installed [ARM] Kirkwood: Instantiate mv_xor driver [ARM] Orion: Instantiate mv_xor driver for 5182 ...
