path: root/MAINTAINERS
2013-01-23MAINTAINERS: Someone needs to watch over the serial driversGreg Kroah-Hartman
2013-01-23MAINTAINERS: remove meAlan Cox
Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-16MAINTAINERS: update email address for Timur TabiTimur Tabi
Timur Tabi no longer works for Freescale, so update the email address and status for all of his maintained projects. Also mark the QE library as orphaned, for lack of interest in maintaining it. The CS4270 driver is marked as "Odd Fixes" because appropriate hardware is no longer available. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix regression allowing IP_TTL setting of zero, fix from Cong Wang. 2) Fix leak regressions in tunap, from Jason Wang. 3) be2net driver always returns IRQ_HANDLED in INTx handler, fix from Sathya Perla. 4) qlge doesn't really support NETIF_F_TSO6, don't set that flag. Fix from Amerigo Wang. 5) Add 802.11ad Atheros wil6210 driver, from Vladimir Kondratiev. 6) Fix MTU calculations in mac80211 layer, from T Krishna Chaitanya. 7) Station info layer of mac80211 needs to use del_timer_sync(), from Johannes Berg. 8) tcp_read_sock() can loop forever, because we don't immediately stop when recv_actor() returns zero. Fix from Eric Dumazet. 9) Fix WARN_ON() in tcp_cleanup_rbuf(). We have to use sk_eat_skb() in tcp_recv_skb() to handle the case where a large GRO packet is split up while it is use by a splice() operation. Fix also from Eric Dumazet. 10) addrconf_get_prefix_route() in ipv6 tests flags incorrectly, it does: if (X && (p->flags & Y) != 0) when it really meant to go: if (X && (p->flags & X) != 0) fix from Romain Kuntz. 11) Fix lost Kconfig dependency for bfin_mac driver hardware timestamping. From Lars-Peter Clausen. 12) Fix regression in handling of RST without ACK in TCP, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (37 commits) be2net: fix unconditionally returning IRQ_HANDLED in INTx tuntap: fix leaking reference count tuntap: forbid calling TUNSETIFF when detached tuntap: switch to use rtnl_dereference() net, wireless: overwrite default_ethtool_ops qlge: remove NETIF_F_TSO6 flag tcp: accept RST without ACK flag net: ethernet: xilinx: Do not use NO_IRQ in axienet net: ethernet: xilinx: Do not use axienet on PPC bnx2x: Allow management traffic after boot from SAN bnx2x: Fix fastpath structures when memory allocation fails bfin_mac: Restore hardware time-stamping dependency on BF518 tun: avoid owner checks on IFF_ATTACH_QUEUE bnx2x: move debugging code before the return tuntap: refuse to re-attach to different tun_struct ipv6: use addrconf_get_prefix_route for prefix route lookup [v2] ipv6: fix the noflags test in addrconf_get_prefix_route tcp: fix splice() and tcp collapsing interaction tcp: splice: fix an infinite loop in tcp_read_sock() net: prevent setting ttl=0 via IP_TTL ...
2013-01-11MAINTAINERS: Omar had movedChen Gang
Signed-off-by: Chen Gang <gang.chen@asianux.com> Cc: Omar Ramirez Luna <omar.ramirez@ti.com> Cc: Omar Ramirez Luna <omar.ramirez@copitl.com> Cc: David Miller <davem@davemloft.net> Cc: Greg KH <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-11MAINTAINERS: fix a status patternZhang Yanfei
Change MAINTAINED to Maintained. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-11MAINTAINERS: fix arch/arm/plat-omap/include/plat/omap_hwmod.hZhang Yanfei
This file was moved to arch/arm/mach-omap2/omap=5Fhwmod.h by commit 2a296c8f89bc ("ARM: OMAP: Make plat/omap=5Fhwmod.h local to mach-omap2"). Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-09Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2013-01-07Update MAINTAINERS entryMatthew Garrett
New job, new address. Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com>
2013-01-07MAINTAINERS: change the mail address of acer-wmi/msi-laptop maintainerLee, Chun-Yi
Due to I moved to use suse.com mail address, so, add patch to change the mail address in MAINTAINERS file. Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Lee, Chun-Yi <jlee@suse.com> Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com>
2013-01-04MAINTAINERS: fix drivers/staging/sm7xx/Cesar Eduardo Barros
This directory was moved to drivers/staging/sm7xxfb/ by commit 925aa6600cee ("staging: sm7xxfb: sm7xx becomes sm7xxfb"). Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Teddy Wang <teddy.wang@siliconmotion.com.cn> Acked-by: Javier Muñoz <jmunhoz@igalia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04MAINTAINERS: remove include/linux/of_pwm.hCesar Eduardo Barros
Added by commit 200efedd8766 ("pwm: Take over maintainership of the PWM subsystem"), but I could not find any trace of that file being ever added to the repository. Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Acked-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04MAINTAINERS: remove arch/*/lib/perf_event*.cCesar Eduardo Barros
This pattern only matched arch/frv/lib/perf_event.c, which was removed by commit e360adbe2924 ("irq_work: Add generic hardirq context callbacks"). Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04MAINTAINERS: remove drivers/mmc/host/imxmmc.*Cesar Eduardo Barros
This driver was removed by commit 6187fee46f4b ("mmc: remove imxmmc driver"). Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04MAINTAINERS: fix Documentation/mei/Cesar Eduardo Barros
The documentation was moved to Documentation/misc-devices/mei/ instead. Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Acked-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04MAINTAINERS: remove arch/x86/platform/mrst/pmu.*Cesar Eduardo Barros
These files were removed by commit 1a8359e411eb ("x86/mid: Remove Intel Moorestown"). Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Alan Cox <alan@linux.intel.com> Cc: Len Brown <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04MAINTAINERS: remove firmware/isci/Cesar Eduardo Barros
This directory was removed by commit 7d99b3abaf84 ("isci, firmware: Remove isci fallback parameter blob and generator"). Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Dan Williams <dan.j.williams@intel.com> Cc: James Bottomley <JBottomley@Parallels.com> Cc: Intel SCU Linux support <intel-linux-scu@intel.com> Cc: Lukasz Dorau <lukasz.dorau@intel.com> Cc: Maciej Patelczyk <maciej.patelczyk@intel.com> Cc: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04MAINTAINERS: fix drivers/ieee802154/Cesar Eduardo Barros
This directory was moved to drivers/net/ieee802154/ by commit 31d178bffcff ("drivers/ieee802154: move ieee802154 drivers to net folder"). Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04MAINTAINERS: fix .../plat-mxc/include/mach/imxfb.hCesar Eduardo Barros
This file was moved to include/linux/platform_data/video-imxfb.h by commit 82906b13a6f4 ("ARM: imx: move platform_data definitions"). Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04MAINTAINERS: remove drivers/video/epson1355fb.cCesar Eduardo Barros
This driver was removed by commit 1c3a918f78b7 ("ARM: clps711x: Remove board support for CEIVA"). Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Christopher Hoover <ch@murgatroid.com> Cc: Christopher Hoover <ch@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04MAINTAINERS: fix drivers/media/usb/dvb-usb/cxusb*Cesar Eduardo Barros
This driver was never at dvb-usb-v2, as far as I could see. Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04MAINTAINERS: adjust for UAPICesar Eduardo Barros
Several headers were moved or split to uapi/. Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04MAINTAINERS: fix drivers/media/platform/atmel-isi.cCesar Eduardo Barros
This file was moved to drivers/media/platform/soc_camera/atmel-isi.c by commit b47ff4a3ed42 ("[media] move soc_camera to its own directory"). Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04MAINTAINERS: fix arch/arm/mach-at91/include/mach/at_hdmac.hCesar Eduardo Barros
This file was moved to include/linux/platform_data/dma-atmel.h by commit 7cdc39eeadf1 ("ARM: at91: move platform_data definitions"). Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04MAINTAINERS: fix drivers/rtc/rtc-vt8500.cCesar Eduardo Barros
Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04MAINTAINERS: remove arch/arm/plat-s5p/Cesar Eduardo Barros
These files were merged into plat-samsung. Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04MAINTAINERS: remove arch/arm/common/time-acorn.cCesar Eduardo Barros
This file was moved to arch/arm/mach-rpc/time.c by commit a1be5d649699 ("ARM: riscpc: move time-acorn.c to mach-rpc"), and the pattern for arch/arm/mach-rpc/ already exists. Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04MAINTAINERS: remove drivers/platform/msm/Cesar Eduardo Barros
This subdirectory entry was added by commit 8a5700cd6754 ("MAINTAINERS: add drivers/platform/msm to MSM subsystem") back in 2011, but I could not find any trace of that directory being ever added to the repository. Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Kenneth Heitke <kheitke@codeaurora.org> Acked-by: David Brown <davidb@codeaurora.org> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04wireless: add new wil6210 802.11ad 60GHz driverVladimir Kondratiev
This adds support for the 60 GHz 802.11ad Wilocity card through a new driver, wil6210. Wilocity implemented the firmware, QCA maintains the device driver. Currently supported: - STA: with security - AP: limited to 1 connected STA, security disabled - Monitor: due to a hardware/firmware limitation either control or non-control frames are monitored Using a STA and AP with this drive, one can assemble a fully functional BSS. Throughput of 1.2Gbps is achieved with iperf. The wil6210 cards have on-board flash memory for the firmware, the cards comes pre-flashed and no firmware download is required. For more details see: http://wireless.kernel.org/en/users/Drivers/wil6210 Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com> Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-01-03Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs Pull f2fs bug fixes from Jaegeuk Kim: "This patch-set includes two major bug fixes: - incorrect IUsed provided by *df -i*, and - lookup failure of parent inodes in corner cases. [Other Bug Fixes] - Fix error handling routines - Trigger recovery process correctly - Resolve build failures due to missing header files [Etc] - Add a MAINTAINERS entry for f2fs - Fix and clean up variables, functions, and equations - Avoid warnings during compilation" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: f2fs: unify string length declarations and usage f2fs: clean up unused variables and return values f2fs: clean up the start_bidx_of_node function f2fs: remove unneeded variable from f2fs_sync_fs f2fs: fix fsync_inode list addition logic and avoid invalid access to memory f2fs: remove unneeded initialization of nr_dirty in dirty_seglist_info f2fs: handle error from f2fs_iget_nowait f2fs: fix equation of has_not_enough_free_secs() f2fs: add MAINTAINERS entry f2fs: return a default value for non-void function f2fs: invalidate the node page if allocation is failed f2fs: add missing #include <linux/prefetch.h> f2fs: do f2fs_balance_fs in front of dir operations f2fs: should recover orphan and fsync data f2fs: fix handling errors got by f2fs_write_inode f2fs: fix up f2fs_get_parent issue to retrieve correct parent inode number f2fs: fix wrong calculation on f_files in statfs f2fs: remove set_page_dirty for atomic f2fs_end_io_write
2012-12-30Merge tag 'omap-late-cleanups' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull late ARM cleanups for omap from Olof Johansson: "From Tony Lindgren: Here are few more patches to finish the omap changes for multiplatform conversion that are not strictly fixes, but were too complex to do with the dependencies during the merge window. Those are to move of serial-omap.h to platform_data, and the removal of remaining cpu_is_omap macro usage outside mach-omap2. Then there are several trivial fixes for typos and few minimal omap2plus_defconfig updates." * tag 'omap-late-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: arch/arm/mach-omap2/dpll3xxx.c: drop if around WARN_ON OMAP2: Fix a typo - replace regist with register. ARM/omap: use module_platform_driver macro ARM: OMAP2+: PMU: Remove unused header ARM: OMAP4: remove duplicated include from omap_hwmod_44xx_data.c ARM: OMAP2+: omap2plus_defconfig: enable twl4030 SoC audio ARM: OMAP2+: omap2plus_defconfig: Add tps65217 support ARM: OMAP2+: enable devtmpfs and devtmpfs automount ARM: OMAP2+: omap_twl: Change TWL4030_MODULE_PM_RECEIVER to TWL_MODULE_PM_RECEIVER ARM: OMAP2+: Drop plat/cpu.h for omap2plus ARM: OMAP: Split fb.c to remove last remaining cpu_is_omap usage MAINTAINERS: Add an entry for omap related .dts files
2012-12-28f2fs: add MAINTAINERS entryJaegeuk Kim
This patch adds myself to MAINTAINERS entry for the f2fs file system. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-17MAINTAINERS: add LP855x backlight driver entryKim, Milo
Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17MAINTAINERS: adjust for UAPI: firewireStefan Richter
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17Corentin has movedCorentin Chary
Signed-off-by: Corentin Chary <corentin.chary@gmail.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17MAINTAINERS: remove include/linux/ext3*Cesar Eduardo Barros
Moved to fs/ext3/ext3.h by commit 4613ad180d19 ("ext3: move headers to fs/ext3/"). Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17MAINTAINERS: CHINESE MAINTAINERS mailing list is subscribers onlyJoe Perches
Mark it so. Signed-off-by: Joe Perches <joe@perches.com> Cc: Harry Wei <harryxiyou@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17MAINTAINERS: Add an entry for omap related .dts filesTony Lindgren
All your omap .dts files are belong to us. Benoît has been doing a good job picking up most of the omap .dts files so far. Let's make sure we both get cc:ed for the related patches. The .dts patches need to be queued by us as separate patches from drivers and other code changes to avoid pointless merge conflists like we saw with v3.8 networking changes. Cc: Benoît Cousson <b-cousson@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-12-17Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull DRM updates from Dave Airlie: "This is the one and only next pull for 3.8, we had a regression we found last week, so I was waiting for that to resolve itself, and I ended up with some Intel fixes on top as well. Highlights: - new driver: nvidia tegra 20/30/hdmi support - radeon: add support for previously unused DMA engines, more HDMI regs, eviction speeds ups and fixes - i915: HSW support enable, agp removal on GEN6, seqno wrapping - exynos: IPP subsystem support (image post proc), HDMI - nouveau: display class reworking, nv20->40 z compression - ttm: start of locking fixes, rcu usage for lookups, - core: documentation updates, docbook integration, monotonic clock usage, move from connector to object properties" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (590 commits) drm/exynos: add gsc ipp driver drm/exynos: add rotator ipp driver drm/exynos: add fimc ipp driver drm/exynos: add iommu support for ipp drm/exynos: add ipp subsystem drm/exynos: support device tree for fimd radeon: fix regression with eviction since evict caching changes drm/radeon: add more pedantic checks in the CP DMA checker drm/radeon: bump version for CS ioctl support for async DMA drm/radeon: enable the async DMA rings in the CS ioctl drm/radeon: add VM CS parser support for async DMA on cayman/TN/SI drm/radeon/kms: add evergreen/cayman CS parser for async DMA (v2) drm/radeon/kms: add 6xx/7xx CS parser for async DMA (v2) drm/radeon: fix htile buffer size computation for command stream checker drm/radeon: fix fence locking in the pageflip callback drm/radeon: make indirect register access concurrency-safe drm/radeon: add W|RREG32_IDX for MM_INDEX|DATA based mmio accesss drm/exynos: support extended screen coordinate of fimd drm/exynos: fix x, y coordinates for right bottom pixel drm/exynos: fix fb offset calculation for plane ...
2012-12-16MAINTAINERS: Fix drivers/i2c/busses/i2c-stub.cCesar Eduardo Barros
This file was moved to drivers/i2c/i2c-stub.c by commit 31d178b (i2c-stub: Move to drivers/i2c). Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-12-15Merge tag 'fbdev-for-3.8' of git://gitorious.org/linux-omap-dss2/linuxLinus Torvalds
Pull fbdev changes from Tomi Valkeinen: "OMAPDSS changes, including: - use dynanic debug prints - OMAP platform dependency removals - Creation of compat-layer, helping us to improve omapdrm - Misc cleanups, aiming to make omadss more in line with the upcoming common display framework Exynos DP changes for the 3.8 merge window: - Device Tree support for Samsung Exynos DP - SW Link training is cleaned up. - HPD interrupt is supported. Samsung Framebuffer changes for the 3.8 merge window: - The bit definitions of header file are updated. - Some minor typos are fixed. - Some minor bugs of s3c_fb_check_var() are fixed. FB related changes for SH Mobile, Freescale DIU Add support for the Solomon SSD1307 OLED Controller" * tag 'fbdev-for-3.8' of git://gitorious.org/linux-omap-dss2/linux: (191 commits) OMAPDSS: fix TV-out issue with DSI PLL Revert "OMAPFB: simplify locking" OMAPFB: remove silly loop in fb2display() OMAPFB: fix error handling in omapfb_find_best_mode() OMAPFB: use devm_kzalloc to allocate omapfb2_device OMAPDSS: DISPC: remove dispc fck uses OMAPDSS: DISPC: get dss clock rate from dss driver drivers/video/console/softcursor.c: remove redundant NULL check before kfree() drivers/video: add support for the Solomon SSD1307 OLED Controller OMAPDSS: use omapdss_compat_init() in other drivers OMAPDSS: export dispc functions OMAPDSS: export dss_feat functions OMAPDSS: export dss_mgr_ops functions OMAPDSS: separate compat files in the Makefile OMAPDSS: move display sysfs init to compat layer OMAPDSS: DPI: use dispc's check_timings OMAPDSS: DISPC: add dispc_ovl_check() OMAPDSS: move irq handling to dispc-compat OMAPDSS: move omap_dispc_wait_for_irq_interruptible_timeout to dispc-compat.c OMAPDSS: move blocking mgr enable/disable to compat layer ... Conflicts: arch/arm/mach-davinci/devices-da8xx.c arch/arm/plat-omap/common.c drivers/media/platform/omap/omap_vout.c
2012-12-14Merge tag 'mvebu' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC updates for Marvell mvebu/kirkwood from Olof Johansson: "This is a branch with updates for Marvell's mvebu/kirkwood platforms. They came in late-ish, and were heavily interdependent such that it didn't make sense to split them up across the cross-platform topic branches. So here they are (for the second release in a row) in a branch on their own." * tag 'mvebu' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (88 commits) arm: l2x0: add aurora related properties to OF binding arm: mvebu: add Aurora L2 Cache Controller to the DT arm: mvebu: add L2 cache support dma: mv_xor: fix error handling path dma: mv_xor: fix error checking of irq_of_parse_and_map() dma: mv_xor: use request_irq() instead of devm_request_irq() dma: mv_xor: clear the window override control registers arm: mvebu: fix address decoding armada_cfg_base() function ARM: mvebu: update defconfig with I2C and RTC support ARM: mvebu: Add SATA support for OpenBlocks AX3-4 ARM: mvebu: Add support for the RTC in OpenBlocks AX3-4 ARM: mvebu: Add support for I2C on OpenBlocks AX3-4 ARM: mvebu: Add support for I2C controllers in Armada 370/XP arm: mvebu: Add hardware I/O Coherency support arm: plat-orion: Add coherency attribute when setup mbus target arm: dma mapping: Export a dma ops function arm_dma_set_mask arm: mvebu: Add SMP support for Armada XP arm: mm: Add support for PJ4B cpu and init routines arm: mvebu: Add IPI support via doorbells arm: mvebu: Add initial support for power managmement service unit ...
2012-12-14Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "The MIPS bits for 3.8. This also includes a bunch fixes that were sitting in the linux-mips.org git tree for a long time. This pull request contains updates to several OCTEON drivers and the board support code for BCM47XX, BCM63XX, XLP, XLR, XLS, lantiq, Loongson1B, updates to the SSB bus support, MIPS kexec code and adds support for kdump. When pulling this, there are two expected merge conflicts in include/linux/bcma/bcma_driver_chipcommon.h which are trivial to resolve, just remove the conflict markers and keep both alternatives." * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (90 commits) MIPS: PMC-Sierra Yosemite: Remove support. VIDEO: Newport Fix console crashes MIPS: wrppmc: Fix build of PCI code. MIPS: IP22/IP28: Fix build of EISA code. MIPS: RB532: Fix build of prom code. MIPS: PowerTV: Fix build. MIPS: IP27: Correct fucked grammar in ops-bridge.c MIPS: Highmem: Fix build error if CONFIG_DEBUG_HIGHMEM is disabled MIPS: Fix potencial corruption MIPS: Fix for warning from FPU emulation code MIPS: Handle COP3 Unusable exception as COP1X for FP emulation MIPS: Fix poweroff failure when HOTPLUG_CPU configured. MIPS: MT: Fix build with CONFIG_UIDGID_STRICT_TYPE_CHECKS=y MIPS: Remove unused smvp.h MIPS/EDAC: Improve OCTEON EDAC support. MIPS: OCTEON: Add definitions for OCTEON memory contoller registers. MIPS: OCTEON: Add OCTEON family definitions to octeon-model.h ata: pata_octeon_cf: Use correct byte order for DMA in when built little-endian. MIPS/OCTEON/ata: Convert pata_octeon_cf.c to use device tree. MIPS: Remove usage of CEVT_R4K_LIB config option. ...
2012-12-13Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - Missing MAINTAINERS entries were added for several drivers - Adds V4L2 support for DMABUF handling, allowing zero-copy buffer sharing between V4L2 devices and GPU - Got rid of all warnings when compiling with W=1 on x86 - Add a new driver for Exynos hardware (s3c-camif) - Several bug fixes, cleanups and driver improvements * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (243 commits) [media] omap3isp: Replace cpu_is_omap3630() with ISP revision check [media] omap3isp: Prepare/unprepare clocks before/after enable/disable [media] omap3isp: preview: Add support for 8-bit formats at the sink pad [media] omap3isp: Replace printk with dev_* [media] omap3isp: Find source pad from external entity [media] omap3isp: Configure CSI-2 phy based on platform data [media] omap3isp: Add PHY routing configuration [media] omap3isp: Add CSI configuration registers from control block to ISP resources [media] omap3isp: Remove unneeded module memory address definitions [media] omap3isp: Use monotonic timestamps for statistics buffers [media] uvcvideo: Fix control value clamping for unsigned integer controls [media] uvcvideo: Mark first output terminal as default video node [media] uvcvideo: Add VIDIOC_[GS]_PRIORITY support [media] uvcvideo: Return -ENOTTY for unsupported ioctls [media] uvcvideo: Set device_caps in VIDIOC_QUERYCAP [media] uvcvideo: Don't fail when an unsupported format is requested [media] uvcvideo: Return -EACCES when trying to access a read/write-only control [media] uvcvideo: Set error_idx properly for extended controls API failures [media] rtl28xxu: add NOXON DAB/DAB+ USB dongle rev 2 [media] fc2580: write some registers conditionally ...
2012-12-13Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull first round of SCSI updates from James Bottomley: "This patch set includes two large new drivers: mpt3sas (for the next gen fusion SAS hardware) and csiostor a FCoE offload driver for the Chelsio converged network cards (this includes some net changes which I've OK'd with DaveM). The rest of the patch is driver updates (qla2xxx, lpfc, hptiop, be2iscsi) plus a few assorted updates and bug fixes. We also have a Power Management rework in the Upper Layer Drivers preparatory to doing ACPI zero power optical devices, but the actual enabler is still being worked on. Signed-off-by: James Bottomley <JBottomley@Parallels.com>" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (72 commits) [SCSI] mpt3sas: add new driver supporting 12GB SAS [SCSI] scsi_transport_sas: add 12GB definitions for mpt3sas [SCSI] miscdevice: Adding support for MPT3SAS_MINOR(222) [SCSI] csiostor: remove unneeded memset() [SCSI] csiostor: Fix sparse warnings. [SCSI] qla2xxx: Display that driver is operating in legacy interrupt mode. [SCSI] qla2xxx: Dont clear drv active on iospace config failure. [SCSI] qla2xxx: Fix typo in qla2xxx driver. [SCSI] qla2xxx: Update ql2xextended_error_logging parameter description with new option. [SCSI] qla2xxx: Parameterize the link speed of hba rather than fcport. [SCSI] qla2xxx: Add 16Gb/s case to get port speed capability. [SCSI] qla2xxx: Move marking fcport online ahead of setting iiDMA speed. [SCSI] qla2xxx: Add acquiring of risc semaphore before doing ISP reset. [SCSI] qla2xxx: Ignore driver ack bit if corresponding presence bit is not set. [SCSI] qla2xxx: Fix typo in qla83xx_fw_dump function. [SCSI] qla2xxx: Add Gen3 PCIe speed 8GT/s to the log message. [SCSI] qla2xxx: Use correct Request-Q-Out register during bidirectional request processing [SCSI] qla2xxx: Move noisy Start scsi failed messages to verbose logging level. [SCSI] qla2xxx: Fix coccinelle warnings in qla2x00_relogin. [SCSI] qla2xxx: No fcport FC-4 type assignment in GA_NXT response. ...
2012-12-13Merge tag 'kvm-3.8-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Marcelo Tosatti: "Considerable KVM/PPC work, x86 kvmclock vsyscall support, IA32_TSC_ADJUST MSR emulation, amongst others." Fix up trivial conflict in kernel/sched/core.c due to cross-cpu migration notifier added next to rq migration call-back. * tag 'kvm-3.8-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (156 commits) KVM: emulator: fix real mode segment checks in address linearization VMX: remove unneeded enable_unrestricted_guest check KVM: VMX: fix DPL during entry to protected mode x86/kexec: crash_vmclear_local_vmcss needs __rcu kvm: Fix irqfd resampler list walk KVM: VMX: provide the vmclear function and a bitmap to support VMCLEAR in kdump x86/kexec: VMCLEAR VMCSs loaded on all cpus if necessary KVM: MMU: optimize for set_spte KVM: PPC: booke: Get/set guest EPCR register using ONE_REG interface KVM: PPC: bookehv: Add EPCR support in mtspr/mfspr emulation KVM: PPC: bookehv: Add guest computation mode for irq delivery KVM: PPC: Make EPCR a valid field for booke64 and bookehv KVM: PPC: booke: Extend MAS2 EPN mask for 64-bit KVM: PPC: e500: Mask MAS2 EPN high 32-bits in 32/64 tlbwe emulation KVM: PPC: Mask ea's high 32-bits in 32/64 instr emulation KVM: PPC: e500: Add emulation helper for getting instruction ea KVM: PPC: bookehv64: Add support for interrupt handling KVM: PPC: bookehv: Remove GET_VCPU macro from exception handler KVM: PPC: booke: Fix get_tb() compile error on 64-bit KVM: PPC: e500: Silence bogus GCC warning in tlb code ...
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) Allow to dump, monitor, and change the bridge multicast database using netlink. From Cong Wang. 2) RFC 5961 TCP blind data injection attack mitigation, from Eric Dumazet. 3) Networking user namespace support from Eric W. Biederman. 4) tuntap/virtio-net multiqueue support by Jason Wang. 5) Support for checksum offload of encapsulated packets (basically, tunneled traffic can still be checksummed by HW). From Joseph Gasparakis. 6) Allow BPF filter access to VLAN tags, from Eric Dumazet and Daniel Borkmann. 7) Bridge port parameters over netlink and BPDU blocking support from Stephen Hemminger. 8) Improve data access patterns during inet socket demux by rearranging socket layout, from Eric Dumazet. 9) TIPC protocol updates and cleanups from Ying Xue, Paul Gortmaker, and Jon Maloy. 10) Update TCP socket hash sizing to be more in line with current day realities. The existing heurstics were choosen a decade ago. From Eric Dumazet. 11) Fix races, queue bloat, and excessive wakeups in ATM and associated drivers, from Krzysztof Mazur and David Woodhouse. 12) Support DOVE (Distributed Overlay Virtual Ethernet) extensions in VXLAN driver, from David Stevens. 13) Add "oops_only" mode to netconsole, from Amerigo Wang. 14) Support set and query of VEB/VEPA bridge mode via PF_BRIDGE, also allow DCB netlink to work on namespaces other than the initial namespace. From John Fastabend. 15) Support PTP in the Tigon3 driver, from Matt Carlson. 16) tun/vhost zero copy fixes and improvements, plus turn it on by default, from Michael S. Tsirkin. 17) Support per-association statistics in SCTP, from Michele Baldessari. And many, many, driver updates, cleanups, and improvements. Too numerous to mention individually. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) net/mlx4_en: Add support for destination MAC in steering rules net/mlx4_en: Use generic etherdevice.h functions. net: ethtool: Add destination MAC address to flow steering API bridge: add support of adding and deleting mdb entries bridge: notify mdb changes via netlink ndisc: Unexport ndisc_{build,send}_skb(). uapi: add missing netconf.h to export list pkt_sched: avoid requeues if possible solos-pci: fix double-free of TX skb in DMA mode bnx2: Fix accidental reversions. bna: Driver Version Updated to 3.1.2.1 bna: Firmware update bna: Add RX State bna: Rx Page Based Allocation bna: TX Intr Coalescing Fix bna: Tx and Rx Optimizations bna: Code Cleanup and Enhancements ath9k: check pdata variable before dereferencing it ath5k: RX timestamp is reported at end of frame ath9k_htc: RX timestamp is reported at end of frame ...
2012-12-12Merge tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC updates from Olof Johansson: "This contains the bulk of new SoC development for this merge window. Two new platforms have been added, the sunxi platforms (Allwinner A1x SoCs) by Maxime Ripard, and a generic Broadcom platform for a new series of ARMv7 platforms from them, where the hope is that we can keep the platform code generic enough to have them all share one mach directory. The new Broadcom platform is contributed by Christian Daudt. Highbank has grown support for Calxeda's next generation of hardware, ECX-2000. clps711x has seen a lot of cleanup from Alexander Shiyan, and he's also taken on maintainership of the platform. Beyond this there has been a bunch of work from a number of people on converting more platforms to IRQ domains, pinctrl conversion, cleanup and general feature enablement across most of the active platforms." Fix up trivial conflicts as per Olof. * tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (174 commits) mfd: vexpress-sysreg: Remove LEDs code irqchip: irq-sunxi: Add terminating entry for sunxi_irq_dt_ids clocksource: sunxi_timer: Add terminating entry for sunxi_timer_dt_ids irq: versatile: delete dangling variable ARM: sunxi: add missing include for mdelay() ARM: EXYNOS: Avoid early use of of_machine_is_compatible() ARM: dts: add node for PL330 MDMA1 controller for exynos4 ARM: EXYNOS: Add support for secondary CPU bring-up on Exynos4412 ARM: EXYNOS: add UART3 to DEBUG_LL ports ARM: S3C24XX: Add clkdev entry for camif-upll clock ARM: SAMSUNG: Add s3c24xx/s3c64xx CAMIF GPIO setup helpers ARM: sunxi: Add missing sun4i.dtsi file pinctrl: samsung: Do not initialise statics to 0 ARM i.MX6: remove gate_mask from pllv3 ARM i.MX6: Fix ethernet PLL clocks ARM i.MX6: rename PLLs according to datasheet ARM i.MX6: Add pwm support ARM i.MX51: Add pwm support ARM i.MX53: Add pwm support ARM: mx5: Replace clk_register_clkdev with clock DT lookup ...
2012-12-12Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC cleanups on various subarchitectures from Olof Johansson: "Cleanup patches for various ARM platforms and some of their associated drivers. There's also a branch in here that enables Freescale i.MX to be part of the multiplatform support -- the first "big" SoC that is moved over (more multiplatform work comes in a separate branch later during the merge window)." Conflicts fixed as per Olof, including a silent semantic one in arch/arm/mach-omap2/board-generic.c (omap_prcm_restart() was renamed to omap3xxx_restart(), and a new user of the old name was added). * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (189 commits) ARM: omap: fix typo on timer cleanup ARM: EXYNOS: Remove unused regs-mem.h file ARM: EXYNOS: Remove unused non-dt support for dwmci controller ARM: Kirkwood: Use hw_pci.ops instead of hw_pci.scan ARM: OMAP3: cm-t3517: use GPTIMER for system clock ARM: OMAP2+: timer: remove CONFIG_OMAP_32K_TIMER ARM: SAMSUNG: use devm_ functions for ADC driver ARM: EXYNOS: no duplicate mask/unmask in eint0_15 ARM: S3C24XX: SPI clock channel setup is fixed for S3C2443 ARM: EXYNOS: Remove i2c0 resource information and setting of device names ARM: Kirkwood: checkpatch cleanups ARM: Kirkwood: Fix sparse warnings. ARM: Kirkwood: Remove unused includes ARM: kirkwood: cleanup lsxl board includes ARM: integrator: use BUG_ON where possible ARM: integrator: push down SC dependencies ARM: integrator: delete static UART1 mapping ARM: integrator: delete SC mapping on the CP ARM: integrator: remove static CP syscon mapping ARM: integrator: remove static AP syscon mapping ...
