git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
Update with Intel Wired Ethernet public git trees.
This file pattern is not currently shown as maintained
by atheros. Perhaps it should be?
bonding-devel@lists.sourceforge.net seems only receive spam
and discussion seems to already occur on netdev@vger.kernel.org.
Signed-off-by: Simon Horman <horms@verge.net.au>
Add STMMAC to the list of supported Ethernet drivers
and myself as maintainer.
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6
* 'staging-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (38 commits)
Revert "staging: tidspbridge: replace iommu custom for opensource implementation"
Revert "staging: tidspbridge - move shared memory iommu maps to tiomap3430.c"
Revert "staging: tidspbridge - rename bridge_brd_mem_map/unmap to a proper name"
Revert "staging: tidspbridge - remove custom mmu code from tiomap3430.c"
Revert "staging: tidspbridge - fix mmufault support"
Revert "staging: tidspbridge - remove hw directory"
Revert "staging: tidspbridge - move all iommu related code to a new file"
Revert "staging: tidspbridge: remove dw_dmmu_base from cfg_hostres struct"
Revert "staging: tidspbridge - remove reserved memory clean up"
Revert "staging: tidspbridge - deprecate reserve/unreserve_memory funtions"
Revert "staging: tidspbridge - remove dmm custom module"
Revert "staging: tidspbridge - update Kconfig to select IOMMU module"
staging: tidspbridge: hardcode SCM macros while fix is upstreamed
Staging: keucr driver: fix uninitialized variable & proper memset length
omap: dsp: remove shm from normal memory
Staging: wlan-ng: Fix wrong #ifdef #endif sequence
Staging: Update parameters for cfg80211 key management operation
Staging: ath6kl: Fix pointer casts on 64-bit architectures
Staging: batman-adv: suppress false warning when changing the mac address
Staging: batman-adv: fix interface alternating and bonding reggression
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6
* 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (28 commits)
Revert "USB: xhci: Use GFP_ATOMIC under spin_lock"
USB: ohci-jz4740: Fix spelling in MODULE_ALIAS
UWB: Return UWB_RSV_ALLOC_NOT_FOUND rather than crashing on NULL dereference if kzalloc fails
usb: core: fix information leak to userland
usb: misc: iowarrior: fix information leak to userland
usb: misc: sisusbvga: fix information leak to userland
usb: subtle increased memory usage in u_serial
USB: option: fix when the driver is loaded incorrectly for some Huawei devices.
usb: gadget: goku_udc: add registered flag bit, fixing build
USB: ehci/mxc: compile fix
USB: Fix FSL USB driver on non Open Firmware systems
USB: the development of the usb tree is now in git
usb: musb: fail unaligned DMA transfers on v1.8 and above
USB: ftdi_sio: add device IDs for Milkymist One JTAG/serial
usb.h: fix ioctl kernel-doc info
usb: musb: gadget: kill duplicate code in musb_gadget_queue()
usb: musb: Fix handling of spurious SESSREQ
usb: musb: fix kernel oops when loading musb_hdrc module for the 2nd time
USB: musb: blackfin: push clkin value to platform resources
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6:
n_gsm: Fix length handling
n_gsm: Copy n2 over when configuring via ioctl interface
serial: bfin_5xx: grab port lock before making port termios changes
serial: bfin_5xx: disable CON_PRINTBUFFER for consoles
serial: bfin_5xx: remove redundant SSYNC to improve TX speed
serial: bfin_5xx: always include DMA headers
vcs: make proper usage of the poll flags
amiserial: Remove unused variable icount
8250: Fix tcsetattr to avoid ioctl(TIOCMIWAIT) hang
tty_ldisc: Fix BUG() on hangup
TTY: restore tty_ldisc_wait_idle
SERIAL: blacklist si3052 chip
drivers/serial/bfin_5xx.c: Fix line continuation defects
tty: prevent DOS in the flush_to_ldisc
8250: add support for Kouwell KW-L221N-2
nozomi: Fix warning from the previous TIOCGCOUNT changes
tty: fix warning in synclink driver
tty: Fix formatting in tty.h
tty: the development tree is now done in git
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
So properly mark it as such in the MAINTAINERS file.
The tree has moved to "staging-2.6" not "staging-next-2.6" as all of the
staging development is now done in git, not just for the next tree.
So change the MAINTAINERS file to properly reflect this.
While the 'xen-devel@lists.xen.org' is more apt, it is not yet
ready. Revert the name back to the old lists.xensource.com for
right now.
* 'for-linus' of git://www.jni.nu/cris:
CRIS: Add paths for CRISv10 serial driver
CRIS: Fix RS485 delay handling.
Add missing "struct" to in sizeof.
Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
and branch 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm
* 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm:
xen: register xen pci notifier
xen: initialize cpu masks for pv guests in xen_smp_init
xen: add a missing #include to arch/x86/pci/xen.c
xen: mask the MTRR feature from the cpuid
xen: make hvc_xen console work for dom0.
xen: add the direct mapping area for ISA bus access
xen: Initialize xenbus for dom0.
xen: use vcpu_ops to setup cpu masks
xen: map a dummy page for local apic and ioapic in xen_set_fixmap
xen: remap MSIs into pirqs when running as initial domain
xen: remap GSIs as pirqs when running as initial domain
xen: introduce XEN_DOM0 as a silent option
xen: map MSIs into pirqs
xen: support GSI -> pirq remapping in PV on HVM guests
xen: add xen hvm acpi_register_gsi variant
acpi: use indirect call to register gsi in different modes
xen: implement xen_hvm_register_pirq
xen: get the maximum number of pirqs from xen
xen: support pirq != irq
* 'stable/xen-pcifront-0.8.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: (27 commits)
X86/PCI: Remove the dependency on isapnp_disable.
xen: Update Makefile with CONFIG_BLOCK dependency for biomerge.c
MAINTAINERS: Add myself to the Xen Hypervisor Interface and remove Chris Wright.
x86: xen: Sanitse irq handling (part two)
swiotlb-xen: On x86-32 builts, select SWIOTLB instead of depending on it.
MAINTAINERS: Add myself for Xen PCI and Xen SWIOTLB maintainer.
xen/pci: Request ACS when Xen-SWIOTLB is activated.
xen-pcifront: Xen PCI frontend driver.
xenbus: prevent warnings on unhandled enumeration values
xenbus: Xen paravirtualised PCI hotplug support.
xen/x86/PCI: Add support for the Xen PCI subsystem
x86: Introduce x86_msi_ops
msi: Introduce default_[teardown|setup]_msi_irqs with fallback.
x86/PCI: Export pci_walk_bus function.
x86/PCI: make sure _PAGE_IOMAP it set on pci mappings
x86/PCI: Clean up pci_cache_line_size
xen: fix shared irq device passthrough
xen: Provide a variant of xen_poll_irq with timeout.
xen: Find an unbound irq number in reverse order (high to low).
xen: statically initialize cpu_evtchn_mask_p
Fix up trivial conflicts in drivers/pci/Makefile
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (39 commits)
Revert "namespace: add source file location exceptions"
Coccinelle: Add contextual message
Coccinelle: Fix documentation
Coccinelle: Find doubled arguments to boolean or bit operators.
Coccinelle: Find nested lock+irqsave functions that use the same flags variables.
scripts/extract-ikconfig: add support for bzip2, lzma and lzo
kbuild: check return value of asprintf()
scripts/namespace.pl: improve to get more correct results
scripts/namespace.pl: some bug fixes
scripts/namespace.pl: update file exclusion list
scripts/namespace.pl: fix wrong source path
Coccinelle: Use the -no_show_diff option for org and report mode
Coccinelle: Add a new mode named 'chain'
Coccinelle: Use new comment format to explain kfree.cocci
Coccinelle: Improve user information with a new kind of comment
Coccinelle: Update documentation
MAINTAINERS: Coccinelle: Update email address
Documentation/kbuild: modules.txt cleanup
Documentation/kbuild: major edit of modules.txt sections 5-8
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: (68 commits)
hwmon: (it87) Add support for the IT8721F/IT8758E
hwmon: (it87) Move conversion functions
hwmon: Remove many EXPERIMENTAL flags
hwmon: (lm85) Add support for ADT7468 high-frequency PWM mode
hwmon: (lm85) Document the ADT7468 as supported
hwmon: (lm85) Fix ADT7468 frequency table
hwmon: I2C addresses are constant
Move ams driver to macintosh
hwmon: (pcf8591) Don't attempt to detect devices
hwmon: (pcf8591) Register as a hwmon device
hwmon: (w83795) Use standard attributes for chassis intrusion
hwmon: (w83795) Exclude fan control feature by default
hwmon: (w83795) Add myself as co-author and maintainer
hwmon: (w83795) More style cleanups
hwmon: (w83795) Fix LSB reading of voltage limits
hwmon: (w83795) Use dev_get_drvdata() where possible
hwmon: (w83795) Delay reading pwm config registers
hwmon: (w83795) Delay reading limit registers
hwmon: (w83795) Move register reads to dedicated functions
hwmon: (w83795) Pack similar register reads
The ams driver isn't a hardware monitoring driver, so it shouldn't
live under driver/hwmon. drivers/macintosh seems much more
appropriate, as the driver is only useful on PowerBooks and iBooks.
Cc: Guenter Roeck <guenter.roeck@ericsson.com>
Cc: Stelian Pop <stelian@popies.net>
Cc: Michael Hanselmann <linux-kernel@hansmi.ch>
Cc: Grant Likely <grant.likely@secretlab.ca>
I've made so many changes to the w83795 driver that it's only fair to
list myself as a co-author. I'll also maintain the driver for some
time. There's more work needed on the driver for sure.
Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
This merges the staging-next tree to Linus's tree and resolves
some conflicts that were present due to changes in other trees that were
affected by files here.
Update to be able to fix a recent change to scripts/basic/docproc.c
(commit eda603f).
Implement the Panasonic MN10300 AM34 CPU subarch and implement SMP support for
MN10300. Also implement support for the MN2WS0060 processor and the ASB2364
evaluation board which are AM34 based.
Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com>
Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (476 commits)
vmwgfx: Implement a proper GMR eviction mechanism
drm/radeon/kms: fix r6xx/7xx 1D tiling CS checker v2
drm/radeon/kms: properly compute group_size on 6xx/7xx
drm/radeon/kms: fix 2D tile height alignment in the r600 CS checker
drm/radeon/kms/evergreen: set the clear state to the blit state
drm/radeon/kms: don't poll dac load detect.
gpu: Add Intel GMA500(Poulsbo) Stub Driver
drm/radeon/kms: MC vram map needs to be >= pci aperture size
drm/radeon/kms: implement display watermark support for evergreen
drm/radeon/kms/evergreen: add some additional safe regs v2
drm/radeon/r600: fix tiling issues in CS checker.
drm/i915: Move gpu_write_list to per-ring
drm/i915: Invalidate the to-ring, flush the old-ring when updating domains
drm/i915/ringbuffer: Write the value passed in to the tail register
agp/intel: Restore valid PTE bit for Sandybridge after bdd3072
drm/i915: Fix flushing regression from 9af90d19f
drm/i915/sdvo: Remove unused encoding member
i915: enable AVI infoframe for intel_hdmi.c [v4]
drm/i915: Fix current fb blocking for page flip
drm/i915: IS_IRONLAKE is synonymous with gen == 5
Fix up conflicts in
- drivers/gpu/drm/i915/{i915_gem.c, i915/intel_overlay.c}: due to the
new simplified stack-based kmap_atomic() interface
- drivers/gpu/drm/vmwgfx/vmwgfx_drv.c: added .llseek entry due to BKL
removal cleanups.
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (63 commits)
IB/qib: clean up properly if pci_set_consistent_dma_mask() fails
IB/qib: Allow driver to load if PCIe AER fails
IB/qib: Fix uninitialized pointer if CONFIG_PCI_MSI not set
IB/qib: Fix extra log level in qib_early_err()
RDMA/cxgb4: Remove unnecessary KERN_<level> use
RDMA/cxgb3: Remove unnecessary KERN_<level> use
IB/core: Add link layer type information to sysfs
IB/mlx4: Add VLAN support for IBoE
IB/core: Add VLAN support for IBoE
IB/mlx4: Add support for IBoE
mlx4_en: Change multicast promiscuous mode to support IBoE
mlx4_core: Update data structures and constants for IBoE
mlx4_core: Allow protocol drivers to find corresponding interfaces
IB/uverbs: Return link layer type to userspace for query port operation
IB/srp: Sync buffer before posting send
IB/srp: Use list_first_entry()
IB/srp: Reduce number of BUSY conditions
IB/srp: Eliminate two forward declarations
IB/mlx4: Signal node desc changes to SM by using FW to generate trap 144
IB: Replace EXTRA_CFLAGS with ccflags-y
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (53 commits)
ACPI: install ACPI table handler before any dynamic tables being loaded
ACPI / PM: Blacklist another machine that needs acpi_sleep=nonvs
ACPI: Page based coalescing of I/O remappings optimization
ACPI: Convert simple locking to RCU based locking
ACPI: Pre-map 'system event' related register blocks
ACPI: Add interfaces for ioremapping/iounmapping ACPI registers
ACPI: Maintain a list of ACPI memory mapped I/O remappings
ACPI: Fix ioremap size for MMIO reads and writes
ACPI / Battery: Return -ENODEV for unknown values in get_property()
ACPI / PM: Fix reference counting of power resources
Subject: [PATCH] ACPICA: Fix Scope() op in module level code
ACPI battery: support percentage battery remaining capacity
ACPI: Make Embedded Controller command timeout delay configurable
ACPI dock: move some functions to .init.text
ACPI: thermal: remove unused limit code
ACPI: static sleep_states[] and acpi_gts_bfs_check
ACPI: remove dead code
ACPI: delete dedicated MAINTAINERS entries for ACPI EC and BATTERY drivers
ACPI: Only processor needs CPU_IDLE
ACPICA: Update version to 20101013
Add missing git as a prefix for git repositories in the few places it
wasn't already used.
Convert a space delimiter to a tab.
Removed by commit 0d58cef664e01f ("V4L/DVB: Remove obsolete zc0301 v4l
driver").
Acked-by: Amerigo Wang <amwang@redhat.com>
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
Removed by commit 7373ab3669aec93 ("V4L/DVB: Remove obsolete ov511
driver").
Removed by commit 431107ea5b680a24a ("ARM: S3C64XX: Merge mach-s3c6400 and
mach-s3c6410").
Acked-by: Ben Dooks <ben-linux@fluff.org>
Removed by commit 70556b143ae4c ("ARM: S3C24XX: Remove old mach-s3c2442").
Removed by commit dcd925f95194da4 ("pxa: merge stargate2 and imote2 board
files").
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
The original commit 403d29713e0a ("pxa/income: Add Income SBC support")
started with the wrong file pattern.
Acked-by: Marek Vasut <marek.vasut@gmail.com>
'misc', 'mlx4', 'nes', 'qib' and 'srp' into for-next
This driver adds support for Linear Technology LTC4261 I2C Negative
Voltage Hot Swap Controller.
Reviewed-by: Ira W. Snyder <iws@ovro.caltech.edu>
Reviewed-by: Tom Grennan <tom.grennan@ericsson.com>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci
* 'davinci-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci: (50 commits)
davinci: fix remaining board support after io_pgoffst removal
davinci: mityomapl138: make file local data static
arm/davinci: remove duplicated include
davinci: Initial support for Omapl138-Hawkboard
davinci: MityDSP-L138/MityARM-1808 read MAC address from I2C Prom
davinci: add tnetv107x touchscreen platform device
input: add driver for tnetv107x touchscreen controller
davinci: add keypad config for tnetv107x evm board
davinci: add tnetv107x keypad platform device
input: add driver for tnetv107x on-chip keypad controller
net: davinci_emac: cleanup unused cpdma code
net: davinci_emac: switch to new cpdma layer
net: davinci_emac: separate out cpdma code
net: davinci_emac: cleanup unused mdio emac code
omap: cleanup unused davinci mdio arch code
davinci: cleanup mdio arch code and switch to phy_id
net: davinci_emac: switch to new mdio
omap: add mdio platform devices
davinci: add mdio platform devices
net: davinci_emac: separate out davinci mdio
Fix up trivial conflict in drivers/input/keyboard/Kconfig (two entries
added next to each other - one from the davinci merge, one from the
input merge)
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb
* 'for-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb:
uwb: Orphan the UWB and WUSB subsystems
uwb: Remove the WLP subsystem and drivers
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86: (44 commits)
eeepc-wmi: Add cpufv sysfs interface
eeepc-wmi: add additional hotkeys
panasonic-laptop: Simplify calls to acpi_pcc_retrieve_biosdata
panasonic-laptop: Handle errors properly if they happen
intel_pmic_gpio: fix off-by-one value range checking
IBM Real-Time "SMI Free" mode driver -v7
Add OLPC XO-1 rfkill driver
Move hdaps driver to platform/x86
ideapad-laptop: Fix Makefile
intel_pmic_gpio: swap the bits and mask args for intel_scu_ipc_update_register
ideapad: Add param: no_bt_rfkill
ideapad: Change the driver name to ideapad-laptop
ideapad: rewrite the sw rfkill set
ideapad: rewrite the hw rfkill notify
ideapad: use EC command to control camera
ideapad: use return value of _CFG to tell if device exist or not
ideapad: make sure we bind on the correct device
ideapad: check VPC bit before sync rfkill hw status
ideapad: add ACPI helpers
dell-laptop: Add debugfs support
I'm no longer in a position to be the maintainer for the Ultra-Wide
Band (UWB) and Ceritified Wireless USB (WUSB) subsystems and no one else
has volunteered to take over.
Signed-off-by: David Vrabel <david.vrabel@csr.com>
The only Wimedia LLC Protocol (WLP) hardware was an Intel i1480 chip
with a beta release of firmware that was never commercially available as
a product. This hardware and firmware is no longer available as Intel
sold their UWB/WLP IP. I also see little prospect of other WLP
capable hardware ever being available.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/edac
* 'devel' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/edac: (25 commits)
i7300_edac: Properly initialize per-csrow memory size
V4L/DVB: i7300_edac: better initialize page counts
MAINTAINERS: Add maintainer for i7300-edac driver
i7300-edac: CodingStyle cleanup
i7300_edac: Improve comments
i7300_edac: Cleanup: reorganize the file contents
i7300_edac: Properly detect channel on CE errors
i7300_edac: enrich FBD error info for corrected errors
i7300_edac: enrich FBD error info for fatal errors
i7300_edac: pre-allocate a buffer used to prepare err messages
i7300_edac: Fix MTR x4/x8 detection logic
i7300_edac: Make the debug messages coherent with the others
i7300_edac: Cleanup: remove get_error_info logic
i7300_edac: Add a code to cleanup error registers
i7300_edac: Add support for reporting FBD errors
i7300_edac: Properly detect the type of error correction
i7300_edac: Detect if the device is on single mode
i7300_edac: Adds detection for enhanced scrub mode on x8
i7300_edac: Clear the error bit after reading
i7300_edac: Add error detection code for global errors
* 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
i2c-viapro: Don't log nacks
i2c/pca954x: Remove __devinit and __devexit from probe and remove functions
MAINTAINERS: Add maintainer for PCA9541 I2C bus master selector driver
i2c/mux: Driver for PCA9541 I2C Master Selector
i2c: Optimize function i2c_detect()
i2c: Discard warning message on device instantiation from user-space
i2c-amd8111: Add proper error handling
i2c: Change to new flag variable
i2c: Remove unneeded inclusions of <linux/i2c-id.h>
i2c: Let i2c_parent_is_i2c_adapter return the parent adapter
i2c: Simplify i2c_parent_is_i2c_adapter
i2c-pca-platform: Change device name of request_irq
i2c: Fix Kconfig dependencies
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: Makefile - replace the use of <module>-objs with <module>-y
crypto: hifn_795x - use cancel_delayed_work_sync()
crypto: talitos - sparse check endian fixes
crypto: talitos - fix checkpatch warning
crypto: talitos - fix warning: 'alg' may be used uninitialized in this function
crypto: cryptd - Adding the AEAD interface type support to cryptd
crypto: n2_crypto - Niagara2 driver needs to depend upon CRYPTO_DES
crypto: Kconfig - update broken web addresses
crypto: omap-sham - Adjust DMA parameters
crypto: fips - FIPS requires algorithm self-tests
crypto: omap-aes - OMAP2/3 AES hw accelerator driver
crypto: updates to enable omap aes
padata: add missing __percpu markup in include/linux/padata.h
MAINTAINERS: Add maintainer entries for padata/pcrypt
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits)
bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL.
vlan: Calling vlan_hwaccel_do_receive() is always valid.
tproxy: use the interface primary IP address as a default value for --on-ip
tproxy: added IPv6 support to the socket match
cxgb3: function namespace cleanup
tproxy: added IPv6 support to the TPROXY target
tproxy: added IPv6 socket lookup function to nf_tproxy_core
be2net: Changes to use only priority codes allowed by f/w
tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled
tproxy: added tproxy sockopt interface in the IPV6 layer
tproxy: added udp6_lib_lookup function
tproxy: added const specifiers to udp lookup functions
tproxy: split off ipv6 defragmentation to a separate module
l2tp: small cleanup
nf_nat: restrict ICMP translation for embedded header
can: mcp251x: fix generation of error frames
can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set
can-raw: add msg_flags to distinguish local traffic
9p: client code cleanup
rds: make local functions/variables static
Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and
drivers/net/wireless/ath/ath9k/debug.c as per David
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (141 commits)
USB: mct_u232: fix broken close
USB: gadget: amd5536udc.c: fix error path
USB: imx21-hcd - fix off by one resource size calculation
usb: gadget: fix Kconfig warning
usb: r8a66597-udc: Add processing when USB was removed.
mxc_udc: add workaround for ENGcm09152 for i.MX35
USB: ftdi_sio: add device ids for ScienceScope
USB: musb: AM35x: Workaround for fifo read issue
USB: musb: add musb support for AM35x
USB: AM35x: Add musb support
usb: Fix linker errors with CONFIG_PM=n
USB: ohci-sh - use resource_size instead of defining its own resource_len macro
USB: isp1362-hcd - use resource_size instead of defining its own resource_len macro
USB: isp116x-hcd - use resource_size instead of defining its own resource_len macro
USB: xhci: Fix compile error when CONFIG_PM=n
USB: accept some invalid ep0-maxpacket values
USB: xHCI: PCI power management implementation
USB: xHCI: bus power management implementation
USB: xHCI: port remote wakeup implementation
USB: xHCI: port power management implementation
Manually fix up (non-data) conflict: the SCSI merge gad renamed the
'hw_sector_size' member to 'physical_block_size', and the USB tree
brought a new use of it.
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (49 commits)
serial8250: ratelimit "too much work" error
serial: bfin_sport_uart: speed up sport RX sample rate to be 3% faster
serial: abstraction for 8250 legacy ports
serial/imx: check that the buffer is non-empty before sending it out
serial: mfd: add more baud rates support
jsm: Remove the uart port on errors
Alchemy: Add UART PM methods.
8250: allow platforms to override PM hook.
altera_uart: Don't use plain integer as NULL pointer
altera_uart: Fix missing prototype for registering an early console
altera_uart: Fixup type usage of port flags
altera_uart: Make it possible to use Altera UART and 8250 ports together
altera_uart: Add support for different address strides
altera_uart: Add support for getting mapbase and IRQ from resources
altera_uart: Add support for polling mode (IRQ-less)
serial: Factor out uart_poll_timeout() from 8250 driver
serial: mark the 8250 driver as maintained
serial: 8250: Don't delay after transmitter is ready.
tty: MAINTAINERS: add drivers/serial/jsm/ as maintained driver
vcs: invoke the vt update callback when /dev/vcs* is written to
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (31 commits)
driver core: Display error codes when class suspend fails
Driver core: Add section count to memory_block struct
Driver core: Add mutex for adding/removing memory blocks
Driver core: Move find_memory_block routine
hpilo: Despecificate driver from iLO generation
driver core: Convert link_mem_sections to use find_memory_block_hinted.
driver core: Introduce find_memory_block_hinted which utilizes kset_find_obj_hinted.
kobject: Introduce kset_find_obj_hinted.
driver core: fix build for CONFIG_BLOCK not enabled
driver-core: base: change to new flag variable
sysfs: only access bin file vm_ops with the active lock
sysfs: Fail bin file mmap if vma close is implemented.
FW_LOADER: fix kconfig dependency warning on HOTPLUG
uio: Statically allocate uio_class and use class .dev_attrs.
uio: Support 2^MINOR_BITS minors
uio: Cleanup irq handling.
uio: Don't clear driver data
uio: Fix lack of locking in init_uio_class
SYSFS: Allow boot time switching between deprecated and modern sysfs layout
driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devices
