path: root/MAINTAINERS
2008-06-09MAINTAINERS: update PPPoE maintainer addressChris Wright
Cc: Michal Ostrowski <mostrows@earthlink.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/ipath: Fix SM trap forwarding IB/ehca: Reject send WRs only for RESET, INIT and RTR state MAINTAINERS: Update NetEffect (iw_nes) entry IB/ipath: Fix device capability flags IB/ipath: Avoid test_bit() on u64 SDMA status value
git://git.kernel.org/pub/scm/linux/kernel/git/chrisw/lsm-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/chrisw/lsm-2.6: capabilities: remain source compatible with 32-bit raw legacy capability support. LSM: remove stale web site from MAINTAINERS
2008-06-06MAINTAINERS: reiserfs entry is out of dateAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Cc: Edward Shishkin <edward.shishkin@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-03bridge: update URLAdrian Bunk
This patch updates the URL of the bridge homepage. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-27LSM: remove stale web site from MAINTAINERSChris Wright
Pointed out by Adrian Bunk. Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2008-05-26MAINTAINERS: Update NetEffect (iw_nes) entryChien Tung
Add Chien and remove Nishi from maintainers list for NetEffect. Signed-off-by: Chien Tung <ctung@neteffect.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-24MAINTAINERS: add util-linux-ng packageKarel Zak
(akpm: we often deal with util-linux and I (at least) can never remember where they hang out). Signed-off-by: Karel Zak <kzak@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/mad: Fix kernel crash when .process_mad() returns SUCCESS|CONSUMED IPoIB: Test for NULL broadcast object in ipiob_mcast_join_finish() MAINTAINERS: Add cxgb3 and iw_cxgb3 NIC and iWARP driver entries IB/mlx4: Fix creation of kernel QP with max number of send s/g entries IB/mthca: Fix max_sge value returned by query_device RDMA/cxgb3: Fix uninitialized variable warning in iwch_post_send() IB/mlx4: Fix uninitialized-var warning in mlx4_ib_post_send() IB/ipath: Fix UC receive completion opcode for RDMA WRITE with immediate IB/ipath: Fix printk format for ipath_sdma_status
2008-05-20Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: iop-adma: fixup some kzalloc/memset confusions fsldma: update the fsldma driver MAINTAINERS info
2008-05-20MAINTAINERS: Add cxgb3 and iw_cxgb3 NIC and iWARP driver entriesSteve Wise
Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-20fsldma: update the fsldma driver MAINTAINERS infoZhang Wei
Add Li Yang as the new maintainer for fsldma driver and update my email address. Acked-by: Li Yang <leoli@freescale.com> Signed-off-by: Zhang Wei <zw@zh-kernel.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: correct mailing list address PCI: Correct last two HP entries in the bfsort whitelist
2008-05-20Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] Update defconfigs for desktop/server systems [POWERPC] Fix mpc8377_mds.dts DMA nodes to match spec [POWERPC] Update arch/powerpc/boot/.gitignore [POWERPC] Remove generated files on make clean [POWERPC] powerpc/mm/hash_low_32.S: Remove CVS keyword [POWERPC] Update Cell MAINTAINERS entry, add spufs entry lmb: Fix compile warning
2008-05-19Add maintainers for myri10ge driverBrice Goglin
Add a MAINTAINERS entry for the myri10ge driver. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-19MAINTAINERS needs further order fixingAlan Cox
2008-05-20[POWERPC] Update Cell MAINTAINERS entry, add spufs entryArnd Bergmann
The MAINTAINERS file entry for the cell platform is outdated, even the name of the platform changed since the early days when it was initially submitted. The SPU file system is now maintained by Jeremy Kerr. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-19PCI: correct mailing list addressJesse Barnes
Forgot to update the PCI error handling address with the new @vger one. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-05-19Merge branch 'kvm-updates-2.6.26' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm * 'kvm-updates-2.6.26' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm: KVM: LAPIC: ignore pending timers if LVTT is disabled KVM: Update MAINTAINERS for new mailing lists KVM: Fix kvm_vcpu_block() task state race KVM: ia64: Set KVM_IOAPIC_NUM_PINS to 48 KVM: ia64: fix GVMM module including position-dependent objects KVM: ia64: Define new kvm_fpreg struture to replace ia64_fpreg KVM: PIT: take inject_pending into account when emulating hlt s390: KVM guest: fix compile error KVM: x86 emulator: fix writes to registers with modrm encodings
2008-05-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: Don't clean bounds.h and asm-offsets.h kconfig: incorrect 'len' field initialisation ? kernel-doc: allow unnamed bit-fields kbuild: filter away debug symbols from kernel symbols Remove *.rej pattern from .gitignore MAINTAINERS: document names of new kbuild trees kbuild: disable modpost warnings for linkonce sections kbuild: escape meta characters in regular expression in make TAGS
2008-05-18i2c: New co-maintainerJean Delvare
Ben Dooks agreed to become my co-maintainer for the i2c subsystem. In particular, Ben will help with drivers for embedded systems, of which my experience is inexistent. Thanks Ben and welcome on board! Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Ben Dooks <ben-linux@fluff.org>
2008-05-18KVM: Update MAINTAINERS for new mailing listsAvi Kivity
The KVM mailing lists are now hosted on vger.kernel.org. Also update the website URL. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-14V4L/DVB (7860a): Add MAINTAINERS for cx18Hans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-13Update Geode mailing list in MAINTAINERSJordan Crouse
Update the Geode list location in the MAINTAINERS file. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-11MAINTAINERS: document names of new kbuild treesSam Ravnborg
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-07[MAINTAINERS] New maintainer for Intel ethernet adaptersAuke Kok
I'm handing over maintainership to Jeff Kirsher and moving on to other Linux/Open Source work within Intel. Good luck to Jeff ;) Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-03[MAINTAINERS] PCI list movedJesse Barnes
Many thanks to Martin for his years of hosting. The pci list has moved to vger, along with what seems like the rest of the major Linux mailing lists. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-02USB: add Cypress c67x00 OTG controller core driverPeter Korsgaard
This patch add the core driver for the c67x00 USB OTG controller. The core driver is responsible for the platform bus binding and creating either USB HCD or USB Gadget instances for each of the serial interface engines on the chip. This driver does not directly implement the HCD or gadget behaviours; it just controls access to the chip. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-01Embedded Maintainer(s), linux-embedded@vger listDavid Woodhouse
Add Paul and myself, and the linux-embedded list, to MAINTAINERS. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01cpusets: update maintainersPaul Jackson
Update CPUSETS MAINTAINERS to reflect the more active role of Paul Menage (secondary to his work on cgroups) and the retirement of the original author of cpusets, Simon Derr. Thanks, Simon! Best of luck to you. Signed-off-by: Paul Jackson <pj@sgi.com> Acked-by: Paul Menage <menage@google.com> Acked-by: Simon Derr <simon.derr@bull.net> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (179 commits) ACPI: Fix acpi_processor_idle and idle= boot parameters interaction acpi: fix section mismatch warning in pnpacpi intel_menlo: fix build warning ACPI: Cleanup: Remove unneeded, multiple local dummy variables ACPI: video - fix permissions on some proc entries ACPI: video - properly handle errors when registering proc elements ACPI: video - do not store invalid entries in attached_array list ACPI: re-name acpi_pm_ops to acpi_suspend_ops ACER_WMI/ASUS_LAPTOP: fix build bug thinkpad_acpi: fix possible NULL pointer dereference if kstrdup failed ACPI: check a return value correctly in acpi_power_get_context() #if 0 acpi/bay.c:eject_removable_drive() eeepc-laptop: add hwmon fan control eeepc-laptop: add backlight eeepc-laptop: add base driver ACPI: thinkpad-acpi: bump up version to 0.20 ACPI: thinkpad-acpi: fix selects in Kconfig ACPI: thinkpad-acpi: use a private workqueue ACPI: thinkpad-acpi: fluff really minor fix ACPI: thinkpad-acpi: use uppercase for "LED" on user documentation ... Fixed conflicts in drivers/acpi/video.c and drivers/misc/intel_menlow.c manually.
2008-04-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (53 commits) tcp: Overflow bug in Vegas [IPv4] UFO: prevent generation of chained skb destined to UFO device iwlwifi: move the selects to the tristate drivers ipv4: annotate a few functions __init in ipconfig.c atm: ambassador: vcc_sf semaphore to mutex MAINTAINERS: The socketcan-core list is subscribers-only. netfilter: nf_conntrack: padding breaks conntrack hash on ARM ipv4: Update MTU to all related cache entries in ip_rt_frag_needed() sch_sfq: use del_timer_sync() in sfq_destroy() net: Add compat support for getsockopt (MCAST_MSFILTER) net: Several cleanups for the setsockopt compat support. ipvs: fix oops in backup for fwmark conn templates bridge: kernel panic when unloading bridge module bridge: fix error handling in br_add_if() netfilter: {nfnetlink,ip,ip6}_queue: fix skb_over_panic when enlarging packets netfilter: x_tables: fix net namespace leak when reading /proc/net/xxx_tables_names netfilter: xt_TCPOPTSTRIP: signed tcphoff for ipv6_skip_exthdr() retval tcp: Limit cwnd growth when deferring for GSO tcp: Allow send-limited cwnd to grow up to max_burst when gso disabled [netdrvr] gianfar: Determine TBIPA value dynamically ...
2008-04-30Char: moxa, update creditsJiri Slaby
- update version - update maintainers - copyright the stuff Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30MAINTAINERS: sort orderingAlan Cox
Seems we have various confused entries around S and T. Sort them all out and also add myself as tty maintainer (which is how I noticed it). Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Merge branch 'audit.b50' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current * 'audit.b50' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: [PATCH] new predicate - AUDIT_FILETYPE [patch 2/2] Use find_task_by_vpid in audit code [patch 1/2] audit: let userspace fully control TTY input auditing [PATCH 2/2] audit: fix sparse shadowed variable warnings [PATCH 1/2] audit: move extern declarations to audit.h Audit: MAINTAINERS update Audit: increase the maximum length of the key field Audit: standardize string audit interfaces Audit: stop deadlock from signals under load Audit: save audit_backlog_limit audit messages in case auditd comes back Audit: collect sessionid in netlink messages Audit: end printk with newline
2008-04-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (21 commits) pciehp: fix error message about getting hotplug control pci/irq: let pci_device_shutdown to call pci_msi_shutdown v2 pci/irq: restore mask_bits in msi shutdown -v3 doc: replace yet another dev with pdev for consistency in DMA-mapping.txt PCI: don't expose struct pci_vpd to userspace doc: fix an incorrect suggestion to pass NULL for PCI like buses Consistently use pdev as the variable of type struct pci_dev *. pciehp: Fix command write shpchp: fix slot name make pciehp_acpi_get_hp_hw_control_from_firmware() pciehp: Clean up pcie_init() pciehp: Mask hotplug interrupt at controller release pciehp: Remove useless hotplug interrupt enabling pciehp: Fix wrong slot capability check pciehp: Fix wrong slot control register access pciehp: Add missing memory barrier pciehp: Fix interrupt event handlig pciehp: fix slot name Update MAINTAINERS with location of PCI tree PCI: Add Intel SCH PCI IDs ...
2008-04-29MAINTAINERS: clarify status of MN10300 mailing list as moderatedRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29eeepc-laptop: add base driverEric Cooper
This patch is based on Eric Cooper's work to clean the original asus_acpi given by Asus. It's a platform driver (/sys/devices/platform/eeepc/) wich support: - hotkeys - wlan on/off - camera on/off - cardr on/off Signed-off-by: Corentin Chary <corentincj@iksaif.net> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29MAINTAINERS: The socketcan-core list is subscribers-only.Pavel Emelyanov
When I posted a copy_to_user fixes, the list daemon refused to accept the Cc: <this-list>, because I was not a subscriber. I found, that other lists with such a feature are marked respectively in the MAINTAINERS file. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-29New driver "sfc" for Solarstorm SFC4000 controller.Ben Hutchings
The driver supports the 10Xpress PHY and XFP modules on our reference designs SFE4001 and SFE4002 and the SMC models SMC10GPCIe-XFP and SMC10GPCIe-10BT. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-28Audit: MAINTAINERS updateEric Paris
Change maintainers to include me and al viro Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-27KVM: Add MAINTAINERS entry for PowerPC KVMHollis Blanchard
Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: s390: update maintainersChristian Borntraeger
This patch adds an entry for kvm on s390 to the MAINTAINERS file :-). We intend to push all patches regarding this via Avi's kvm.git. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-25Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (49 commits) [POWERPC] Add zImage.iseries to arch/powerpc/boot/.gitignore [POWERPC] bootwrapper: fix build error on virtex405-head.S [POWERPC] 4xx: Fix 460GT support to not enable FPU [POWERPC] 4xx: Add NOR FLASH entries to Canyonlands and Glacier dts [POWERPC] Xilinx: of_serial support for Xilinx uart 16550. [POWERPC] Xilinx: boot support for Xilinx uart 16550. [POWERPC] celleb: Add support for PCI Express [POWERPC] celleb: Move miscellaneous files for Beat [POWERPC] celleb: Move a file for SPU on Beat [POWERPC] celleb: Move files for Beat mmu and iommu [POWERPC] celleb: Move files for Beat hvcall interfaces [POWERPC] celleb: Move the SCC related code for celleb [POWERPC] celleb: Move the files for celleb base support [POWERPC] celleb: Consolidate io-workarounds code [POWERPC] cell: Generalize io-workarounds code [POWERPC] Add CONFIG_PPC_PSERIES_DEBUG to enable debugging for platforms/pseries [POWERPC] Convert from DBG() to pr_debug() in platforms/pseries/ [POWERPC] Register udbg console early on pseries LPAR [POWERPC] Mark udbg console as CON_ANYTIME, ie. callable early in boot [POWERPC] Set udbg_console index to 0 ...
2008-04-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (40 commits) Input: wacom - add support for Cintiq 20WSX Input: ucb1400_ts - IRQ probe fix Input: at32psif - update MODULE_AUTHOR with new email Input: mac_hid - add lockdep annotation to emumousebtn Input: i8042 - fix incorrect usage of strncpy and strncat Input: bf54x-keys - add infrastructure for keypad wakeups Input: add MODULE_ALIAS() to hotpluggable platform modules Input: drivers/char/keyboard.c - use time_after Input: fix ordering in joystick Makefile Input: wm97xx-core - support use as a wakeup source Input: wm97xx-core - use IRQF_SAMPLE_RANDOM Input: wm97xx-core - only schedule interrupt handler if not already scheduled Input: add Zhen Hua driver Input: aiptek - add support for Genius G-PEN 560 tablet Input: wacom - implement suspend and autosuspend Input: xpad - set proper buffer length for outgoing requests Input: omap-keypad - fix build warning Input: gpio_keys - irq handling cleanup Input: add PS/2 serio driver for AVR32 devices Input: put ledstate in the keyboard notifier ...
2008-04-25Update MAINTAINERS with location of PCI treeJesse Barnes
The PCI tree is now in git at kernel.org:/pub/scm/linux/kernel/git/jbarnes/pci-2.6.git; add that info to MAINTAINERS.
2008-04-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (22 commits) tun: Multicast handling in tun_chr_ioctl() needs proper locking. [NET]: Fix heavy stack usage in seq_file output routines. [AF_UNIX] Initialise UNIX sockets before general device initcalls [RTNETLINK]: Fix bogus ASSERT_RTNL warning iwlwifi: Fix built-in compilation of iwlcore (part 2) tun: Fix minor race in TUNSETLINK ioctl handling. ppp_generic: use stats from net_device structure iwlwifi: Don't unlock priv->mutex if it isn't locked wireless: rndis_wlan: modparam_workaround_interval is never below 0. prism54: prism54_get_encode() test below 0 on unsigned index mac80211: update mesh EID values b43: Workaround DMA quirks mac80211: fix use before check of Qdisc length net/mac80211/rx.c: fix off-by-one mac80211: Fix race between ieee80211_rx_bss_put and lookup routines. ath5k: Fix radio identification on AR5424/2424 ssb: Fix all-ones boardflags b43: Add more btcoexist workarounds b43: Fix HostFlags data types b43: Workaround invalid bluetooth settings ...
2008-04-24[POWERPC] Add Timur Tabi to the MAINTAINERS fileTimur Tabi
Add Timur Tabi as the maintainer for the Freescale QE library, the Freescale QE UART device driver, the Freescale SOC sound drivers, and the Crystal Semiconductor CS4270 device driver. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-23mac80211: MAINTAINERS updateJohannes Berg
This updates the mac80211 maintainers entry to  1) remove Jiri 2) put me first Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Michael Wu <flamingice@sourmilk.net> Cc: Jiri Benc <jbenc@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial: (24 commits) DOC: A couple corrections and clarifications in USB doc. Generate a slightly more informative error msg for bad HZ fix typo "is" -> "if" in Makefile ext*: spelling fix prefered -> preferred DOCUMENTATION: Use newer DEFINE_SPINLOCK macro in docs. KEYS: Fix the comment to match the file name in rxrpc-type.h. RAID: remove trailing space from printk line DMA engine: typo fixes Remove unused MAX_NODES_SHIFT MAINTAINERS: Clarify access to OCFS2 development mailing list. V4L: Storage class should be before const qualifier (sn9c102) V4L: Storage class should be before const qualifier sonypi: Storage class should be before const qualifier intel_menlow: Storage class should be before const qualifier DVB: Storage class should be before const qualifier arm: Storage class should be before const qualifier ALSA: Storage class should be before const qualifier acpi: Storage class should be before const qualifier firmware_sample_driver.c: fix coding style MAINTAINERS: Add ati_remote2 driver ... Fixed up trivial conflicts in firmware_sample_driver.c
