path: root/MAINTAINERS
2010-05-18Merge branch 'oprofile-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'oprofile-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (24 commits) oprofile/x86: make AMD IBS hotplug capable oprofile/x86: notify cpus only when daemon is running oprofile/x86: reordering some functions oprofile/x86: stop disabled counters in nmi handler oprofile/x86: protect cpu hotplug sections oprofile/x86: remove CONFIG_SMP macros oprofile/x86: fix uninitialized counter usage during cpu hotplug oprofile/x86: remove duplicate IBS capability check oprofile/x86: move IBS code oprofile/x86: return -EBUSY if counters are already reserved oprofile/x86: moving shutdown functions oprofile/x86: reserve counter msrs pairwise oprofile/x86: rework error handler in nmi_setup() oprofile: update file list in MAINTAINERS file oprofile: protect from not being in an IRQ context oprofile: remove double ring buffering ring-buffer: Add lost event count to end of sub buffer tracing: Show the lost events in the trace_pipe output ring-buffer: Add place holder recording of dropped events tracing: Fix compile error in module tracepoints when MODULE_UNLOAD not set ...
2010-05-18[SCSI] Merge scsi-misc-2.6 into scsi-rc-fixes-2.6James Bottomley
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-17Merge branch 'devel-stable' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/include/asm/system.h arch/arm/mm/Kconfig
2010-05-14hughd: update email addressHugh Dickins
My old address will shut down in a couple of weeks: update the tree. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-14Merge branch 'master' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/nico/orion into devel-stable
2010-05-13Merge branch 'devel' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel-stable
2010-05-12MAINTAINERS: add MSM mailing listDaniel Walker
Just adds a mailing list to the MSM maintainer entry. Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
2010-05-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wireless/ath/ar9170/usb.c drivers/scsi/iscsi_tcp.c net/ipv4/ipmr.c
2010-05-11MAINTAINERS: New MAINTAINERS entries for Zipit Z2 and Voipac PXA270Marek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-05-10Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/mtd/mtdcore.c Pull in the bdi fixes and ARM platform changes that other outstanding patches depend on.
2010-05-10Merge commit 'v2.6.34-rc7' into oprofileIngo Molnar
Merge reason: Update to Linus's latest -rc. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-05MAINTAINERS: Add cxgb4 and iw_cxgb4 entriesRoland Dreier
Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-05-05Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/libertas_tf/cmd.c drivers/net/wireless/libertas_tf/main.c
2010-05-03oprofile: update file list in MAINTAINERS fileRobert Richter
File list now catches: $ xargs | eval ls -d $(cat) | sort -u arch/*/include/asm/oprofile*.h arch/*/oprofile/ drivers/oprofile/ include/linux/oprofile.h arch/alpha/oprofile/ arch/arm/oprofile/ arch/avr32/oprofile/ arch/blackfin/oprofile/ arch/ia64/oprofile/ arch/m32r/oprofile/ arch/microblaze/oprofile/ arch/mips/oprofile/ arch/mn10300/oprofile/ arch/parisc/oprofile/ arch/powerpc/include/asm/oprofile_impl.h arch/powerpc/oprofile/ arch/s390/oprofile/ arch/sh/oprofile/ arch/sparc/oprofile/ arch/x86/oprofile/ drivers/oprofile/ include/linux/oprofile.h Signed-off-by: Robert Richter <robert.richter@amd.com>
2010-05-03update MAINTAINERS fileNicolas Pitre
I'm no longer at Marvell. Ditto for Lennert. I don't hack on SMC91x much either these days. Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-05-02[SCSI] Adding MAINTAINERS for qla4xxx iSCSI driver.Ravi Anand
Signed-off-by: Ravi Anand <ravi.anand@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-02ARM: cns3xxx: Add basic support for Cavium Networks CNS3xxx processorsAnton Vorontsov
This patch adds very basic support for ECONA CNS3xxx ARM11 MPcore (ARMv6) dual-core processors. Note that SMP is not yet supported, as well as many peripheral devices. Support for these features will be added later. Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
2010-04-30Merge commit 'v2.6.34-rc6' into perf/coreIngo Molnar
Merge reason: update to the latest -rc. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-29Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/ps3: Update ps3_defconfig powerpc/ps3: Update platform maintainer powerpc/pseries: Flush lazy kernel mappings after unplug operations powerpc/numa: Add form 1 NUMA affinity powerpc/fsl-booke: Fix CONFIG_RELOCATABLE support on FSL Book-E ppc32 powerpc: 2.6.34 update of defconfigs for embedded 6xx/7xxx, 8xx, 8xxx powerpc/mpc8xxx defconfigs - turn off SYSFS_DEPRECATED powerpc/83xx: configure SIL SATA driver in 83xx-wide defconfig powerpc/83xx: enable EPOLL syscall in defconfig powerpc/83xx: add RTC drivers in 83xx defconfig powerpc/fsl-cpm: Configure clock correctly for SCC powerpc/fsl_booke: Correct test for MMU_FTR_BIG_PHYS powerpc/85xx/86xx: Fix build w/ CONFIG_PCI=n
2010-04-28powerpc/ps3: Update platform maintainerGeoff Levand
Update the PS3 entries in the MAINTAINERS file. Signed-off-by: Geoff Levand <geoff@infradead.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-04-27MAINTAINERS: add entry for include/linux/iw_handler.hJohn W. Linville
2010-04-23Merge branch 'linus' into perf/coreIngo Molnar
Merge reason: merge the latest fixes, update to latest -rc. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-23Merge branch 'master' into for-nextJiri Kosina
2010-04-22dri-devel mailing list moved - update MAINTAINERSValdis.Kletnieks@vt.edu
I posted to dri-devel@lists.sourceforge.net, and got a bounce back: The dri-devel list has moved to freedesktop.org (see http://lists.freedesktop.org/mailman/listinfo/dri-devel). If you were subscribed to the list here, the subscription should have been transferred to the new location. Please only post to the new list. Fix MAINTAINERS to correspond. Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] bnx2i: Bug fixes related to MTU change issue when there are active iscsi sessions [SCSI] ibmvscsi: fix DMA API misuse [SCSI] wd7000: fix reset handler typo spin_unlock_irq() => spin_lock_irq() [SCSI] zfcp: Fix tracing of requests with error status [SCSI] zfcp: Update MAINTAINERS entry [SCSI] iscsi_tcp: fix relogin/shutdown hang [SCSI] qla2xxx: fix lock imbalance [SCSI] lpfc: fix lock imbalances [SCSI] be2iscsi: fix lock imbalance [SCSI] dpt_i2o: several use after free issues
2010-04-21Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-6000.c net/core/dev.c
2010-04-14hwmon: (applesmc) Switch maintainersHenrik Rydberg
Nicolas has expressed a wish to be relieved from the maintenance of applesmc, so we simply switch maintainer with this patch. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Acked-by: Nicolas Boichat <nicolas@boichat.ch> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-04-14ARM: 6018/1: ST SPEAr: Updated Maintainers and added Documentation/arm/SPEArviresh kumar
Reviewed-by: Linus Walleij <linux.walleij@stericsson.com> Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-04-12Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (21 commits) ARM: Fix ioremap_cached()/ioremap_wc() for SMP platforms ARM: 6043/1: AT91 slow-clock resume: Don't wait for a disabled PLL to lock ARM: 6031/1: fix Thumb-2 decompressor ARM: 6029/1: ep93xx: gpio.c: local functions should be static ARM: 6028/1: ARM: add MAINTAINERS for U300 ARM: 6024/1: bcmring: fix missing down on semaphore in dma.c MXC: mach_armadillo5x0: Add USB Host support. ARM mach-mx3: duplicated include ARM mach-mx3: duplicated include imx31: add watchdog device on litekit board. imx3: Add watchdog platform device support MXC: mach-mx31_3ds: add support for freescale mc13783 power management device. MXC: mach-mx31_3ds: Add SPI1 device support. MXC: mach-mx31_3ds: Add support for on board NAND Flash. MXC: mach-mx31_3ds: Update variable names over recent mach name modification. imx31: fix parent clock for rtc i.MX51: remove NFC AXI static mapping i.MX51: determine silicon revision dynamically i.MX51: map TZIC dynamically i.MX51: Use correct clock for gpt ...
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-11[SCSI] zfcp: Update MAINTAINERS entryChristof Schmitt
Martin no longer works on zfcp, remove his entry from the MAINTAINERS file and add Swen as co-maintainer. Also remove the reference to the zfcpdump.txt file, zfcpdump is not part of the zfcp device driver. Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Acked-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] 3ware maintainers updateadam radford
This patch updates the 3ware maintainers in the MAINTAINERS file. Signed-off-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-08Merge branch 'linus' into perf/coreIngo Molnar
Semantic conflict: arch/x86/kernel/cpu/perf_event_intel_ds.c Merge reason: pick up latest fixes, fix the conflict Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-08MAINTAINERS: Put the virtio-console entry in correct alphabetical orderAmit Shah
Move around the entry for virtio-console to keep the file sorted. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-04-07ARM: 6028/1: ARM: add MAINTAINERS for U300Linus Walleij
This adds myself as maintainer of the U300 machine and associated system-on-chip drivers. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-04-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bonding/bond_main.c drivers/net/via-velocity.c drivers/net/wireless/iwlwifi/iwl-agn.c
2010-04-02Merge branch 'perf/urgent' into perf/coreIngo Molnar
Conflicts: arch/x86/kernel/cpu/perf_event.c Merge reason: Resolve the conflict, pick up fixes Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-30MAINTAINERS: ipg: Jesse Huang's email address bouncesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30KEYS: Add MAINTAINERS recordDavid Howells
Add a MAINTAINERS record for the key management facility. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-29vxge: Updating Maintainer list of S2IO 10GbE drivers (xframe / vxge).Sreenivasa Honnur
- updating Maintainer list of S2IO 10GbE drivers (xframe / vxge). Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (28 commits) ceph: update discussion list address in MAINTAINERS ceph: some documentations fixes ceph: fix use after free on mds __unregister_request ceph: avoid loaded term 'OSD' in documention ceph: fix possible double-free of mds request reference ceph: fix session check on mds reply ceph: handle kmalloc() failure ceph: propagate mds session allocation failures to caller ceph: make write_begin wait propagate ERESTARTSYS ceph: fix snap rebuild condition ceph: avoid reopening osd connections when address hasn't changed ceph: rename r_sent_stamp r_stamp ceph: fix connection fault con_work reentrancy problem ceph: prevent dup stale messages to console for restarting mds ceph: fix pg pool decoding from incremental osdmap update ceph: fix mds sync() race with completing requests ceph: only release unused caps with mds requests ceph: clean up handle_cap_grant, handle_caps wrt session mutex ceph: fix session locking in handle_caps, ceph_check_caps ceph: drop unnecessary WARN_ON in caps migration ...
2010-03-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (33 commits) r8169: offical fix for CVE-2009-4537 (overlength frame DMAs) ipv6: Don't drop cache route entry unless timer actually expired. tulip: Add missing parens. r8169: fix broken register writes pcnet_cs: add new id bonding: fix broken multicast with round-robin mode drivers/net: Fix continuation lines e1000: do not modify tx_queue_len on link speed change net: ipmr/ip6mr: prevent out-of-bounds vif_table access ixgbe: Do not run all Diagnostic offline tests when VFs are active igb: use correct bits to identify if managability is enabled benet: Fix compile warnnings in drivers/net/benet/be_ethtool.c net: Add MSG_WAITFORONE flag to recvmmsg e1000e: do not modify tx_queue_len on link speed change igbvf: do not modify tx_queue_len on link speed change ipv4: Restart rt_intern_hash after emergency rebuild (v2) ipv4: Cleanup struct net dereference in rt_intern_hash net: fix netlink address dumping in IPv4/IPv6 tulip: Fix null dereference in uli526x_rx_packet() gianfar: fix undo of reserve() ...
2010-03-29ceph: update discussion list address in MAINTAINERSSage Weil
Signed-off-by: Sage Weil <sage@newdream.net>
2010-03-26Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/mtd/nand/sh_flctl.c Maxim's patch to initialise sysfs attributes depends on the patch which actually adds sysfs_attr_init().
2010-03-25isdn: Add netdev to lists in MAINTAINERS entry.David S. Miller
2010-03-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (25 commits) TIPC: Removed inactive maintainer isdn: Cleanup Sections in PCMCIA driver elsa isdn: Cleanup Sections in PCMCIA driver avma1 isdn: Cleanup Sections in PCMCIA driver teles isdn: Cleanup Sections in PCMCIA driver sedlbauer via-velocity: Fix FLOW_CNTL_TX_RX handling in set_mii_flow_control() netfilter: xt_hashlimit: IPV6 bugfix netfilter: ip6table_raw: fix table priority netfilter: xt_hashlimit: dl_seq_stop() fix af_key: return error if pfkey_xfrm_policy2msg_prep() fails skbuff: remove unused dma_head & dma_maps fields vlan: updates vlan real_num_tx_queues vlan: adds vlan_dev_select_queue igb: only use vlan_gro_receive if vlans are registered igb: do not modify tx_queue_len on link speed change igb: count Rx FIFO errors correctly bnx2: Use proper handler during netpoll. bnx2: Fix netpoll crash. ksz884x: fix return value of netdev_set_eeprom cgroups: net_cls as module ...
2010-03-25TIPC: Removed inactive maintainerJon Maloy
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-24MAINTAINERS: use tab not spaces for delimiterJoe Perches
Keeps MAINTAINERS a bit more consistent. done via sed -r -i -e 's/^([A-Z]):[ \t]+/\1:\t/g' MAINTAINERS Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-22Merge commit 'v2.6.34-rc2' into perf/coreIngo Molnar
Merge reason: Pick up latest perf fixes from upstream. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-19x86, tboot: Add support for S3 memory integrity protectionShane Wang
This patch adds support for S3 memory integrity protection within an Intel(R) TXT launched kernel, for all kernel and userspace memory. All RAM used by the kernel and userspace, as indicated by memory ranges of type E820_RAM and E820_RESERVED_KERN in the e820 table, will be integrity protected. The MAINTAINERS file is also updated to reflect the maintainers of the TXT-related code. All MACing is done in tboot, based on a complexity analysis and tradeoff. v3: Compared with v2, this patch adds a check of array size in tboot.c, and a note to specify which c/s of tboot supports this kind of MACing in intel_txt.txt. Signed-off-by: Shane Wang <shane.wang@intel.com> LKML-Reference: <4B973DDA.6050902@intel.com> Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Acked-by: Pavel Machek <pavel@ucw.cz> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
