This handles the merge conflicts with the
drivers/staging/brcm80211/Kconfig file due to changes on the two
different branches.
Following a request from Russell King:
http://lists.infradead.org/pipermail/linux-arm-kernel/2011-June/055031.html
Add myself as the ARM PMU profiling and debugging maintainer. This
covers the ARM implementations of perf, oprofile and hw_breakpoint along
with the glue for this to work on different platforms.
Cc: Jean Pihet <j-pihet@ti.com>
Acked-by: Jamie Iles <jamie@jamieiles.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (24 commits)
usbnet: Remove over-broad module alias from zaurus.
MAINTAINERS: drop Michael from bfin_mac driver
net/can: activate bit-timing calculation and netlink based drivers by default
rionet: fix NULL pointer dereference in rionet_remove
net+crypto: Use vmalloc for zlib inflate buffers.
netfilter: Fix ip_route_me_harder triggering ip_rt_bug
ipv4: Fix IPsec slowpath fragmentation problem
ipv4: Fix packet size calculation in __ip_append_data
cxgb3: skb_record_rx_queue now records the queue index relative to the net_device.
bridge: Only flood unregistered groups to routers
qlge: Add maintainer.
MAINTAINERS: mark socketcan-core lists as subscribers-only
MAINTAINERS: Remove Sven Eckelmann from BATMAN ADVANCED
r8169: fix wrong register use.
net/usb/kalmia: signedness bug in kalmia_bind()
net/usb: kalmia: Various fixes for better support of non-x86 architectures.
rtl8192cu: Fix missing firmware load
udp/recvmsg: Clear MSG_TRUNC flag when starting over for a new packet
ipv6/udp: Use the correct variable to determine non-blocking condition
netconsole: fix build when CONFIG_NETCONSOLE_DYNAMIC is turned on
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6:
MAINTAINERS: update AVR32 and AT32AP maintainers
Signed-off-by: James Morris <jmorris@namei.org>
This alters the maintenance of the AVR32 architecture and the AT32AP machine
code to be shared between Haavard Skinnemoen and me. The status is also changed
to maintained, as we no longer are being paid to look after this architecture.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Acked-by: Haavard Skinnemoen <hskinnemoen@gmail.com>
Signed-off-by: Abhijeet Joglekar <abjoglek@cisco.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com>
We want people to just use the list now rather than hitting up people
who are no longer responsible for it.
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
Update MAINTAINERS to refelect new people working on myri10ge
Signed-off-by: Jon Mason <mason@myri.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6
* 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6:
MAINTAINERS: add myself as maintainer of USB/IP
usb: r8a66597-hcd: fix cannot detect low/full speed device
USB: ehci-ath79: fix a NULL pointer dereference
USB: Add new FT232H chip to drivers/usb/serial/ftdi_sio.c
usb/isp1760: Fix bug preventing the unlinking of control urbs
USB: Fix up URB error codes to reflect implementation.
xhci: Always set urb->status to zero for isoc endpoints.
xhci: Add reset on resume quirk for asrock p67 host
xHCI 1.0: Incompatible Device Error
USB: don't let errors prevent system sleep
USB: don't let the hub driver prevent system sleep
USB: change maintainership of ohci-hcd and ehci-hcd
xHCI 1.0: Force Stopped Event(FSE)
xhci: Don't warn about zeroed bMaxBurst descriptor field.
USB: Free bandwidth when usb_disable_device is called.
xhci: Reject double add of active endpoints.
USB: TI 3410/5052 USB Serial Driver: Fix mem leak when firmware is too big.
usb: musb: gadget: clear TXPKTRDY flag when set FLUSHFIFO
usb: musb: host: compare status for negative error values
This patch adds support for the Analog Devices ADAV801 and ADAV803 audio codec.
Acked-by: Liam Girdwood <lrg@ti.com>
Signed-off-by: matt mooney <mfm@muteddisk.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Signed-off-by: Ron Mercer <ron.mercer@qlogic.com>
The socketcan-core lists require subscription, so mark them as such.
I cannot speak on behalf of the batman-adv developers due to conflicts
in the opinion about the ongoing development. The batman-adv module is
still maintained by Marek Lindner and Simon Wunderlich. Those are the
main persons behind the visions of batman-adv. Therefore, the state of
module hasn't changed.
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Cc: b.a.t.m.a.n@lists.open-mesh.org
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (40 commits)
pxa168_eth: fix race in transmit path.
ipv4, ping: Remove duplicate icmp.h include
netxen: fix race in skb->len access
sgi-xp: fix a use after free
hp100: fix an skb->len race
netpoll: copy dev name of slaves to struct netpoll
ipv4: fix multicast losses
r8169: fix static initializers.
inet_diag: fix inet_diag_bc_audit()
gigaset: call module_put before restart of if_open()
farsync: add module_put to error path in fst_open()
net: rfs: enable RFS before first data packet is received
fs_enet: fix freescale FCC ethernet dp buffer alignment
netdev: bfin_mac: fix memory leak when freeing dma descriptors
vlan: don't call ndo_vlan_rx_register on hardware that doesn't have vlan support
caif: Bugfix - XOFF removed channel from caif-mux
tun: teach the tun/tap driver to support netpoll
dp83640: drop PHY status frames in the driver.
dp83640: fix phy status frame event parsing
phylib: Allow BCM63XX PHY to be selected only on BCM63XX.
Announce the new x86 MCE infrastructure maintainers.
Acked-by: Borislav Petkov <bp@amd64.org>
Acked-by: Tony Luck <tony.luck@intel.com>
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
Link: http://lkml.kernel.org/n/tip-8hs7yob6wib4vblmrmbpbav4@git.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid:
Revert "HID: magicmouse: ignore 'ivalid report id' while switching modes"
HID: hid-multitouch: fix broken eGalax
HID: MAINTAINERS: Update USB HID/HIDBP DRIVERS pattern
HID: hid-multitouch: add support for Chunghwa multi-touch panel
HID: hiddev: fix use after free in hiddev_release
HID: add quirk for HyperPen 10000U
HID: hiddev: fix potential use-after-free
It moved to netfilter-devel@vger.kernel.org.
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
I no longer work at Bluewater Systems. Update my email address accordingly. I
have deleted my email address from C files rather than change it. This
was suggested by several people, since the commit from my new email
address will cause scripts/get_maintainer.pl to function properly. I
have not added the .mailmap entry as suggested by Joe because I think
it is no longer necessary if I touch all the files which had my name
in them.
Signed-off-by: Ryan Mallon <rmallon@gmail.com>
Cc: Andre Renaud <andre@bluewatersys.com>
Cc: H Hartley Sweeten <hsweeten@visionengravers.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Andrew Victor <avictor.za@gmail.com>
Cc: Anton Vorontsov <cbou@mail.ru>
Cc: Liam Girdwood <lrg@ti.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Joe Perches <joe@perches.com>
Cc: Jesper Juhl <jj@chaosbits.net>
Cc: trivial@kernel.org
Reviewed-by: Jesper Juhl <jj@chaosbits.net>
I shall maintain the legacy eeprom driver, until we finally get rid of it.
Add maintainers for the videobuf2 V4L2 driver framework.
Signed-off-by: Pawel Osciak <pawel@osciak.com>
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Update my email address. Email will start to the old address bouncing
soon
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Balbir Singh <bsingharora@gmail.com>
Following the loss of David Brownell, I volunteer to maintain the
ohci-hcd and ehci-hcd drivers. This patch (as1472) makes it official.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq:
[CPUFREQ] Remove cpufreq_stats sysfs entries on module unload.
MAINTAINERS: Update CPU FREQUENCY patterns
Commit bb0a56ecc4ba ("[CPUFREQ] Move x86 drivers to drivers/cpufreq/")
moved the files, remove the old pattern.
Signed-off-by: Dave Jones <davej@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (55 commits)
ISDN, hfcsusb: Don't leak in hfcsusb_ph_info()
netpoll: call dev_put() on error in netpoll_setup()
net: ep93xx_eth: fix DMA API violations
net: ep93xx_eth: drop GFP_DMA from call to dma_alloc_coherent()
net: ep93xx_eth: allocate buffers using kmalloc()
net: ep93xx_eth: pass struct device to DMA API functions
ep93xx: set DMA masks for the ep93xx_eth
vlan: Fix the ingress VLAN_FLAG_REORDER_HDR check
dl2k: EEPROM CRC calculation wrong endianess on bigendian machine
NET: am79c961: fix assembler warnings
NET: am79c961: ensure multicast filter is correctly set at open
NET: am79c961: ensure asm() statements are marked volatile
ethtool.h: fix typos
ep93xx_eth: Update MAINTAINERS
ipv4: Fix packet size calculation for raw IPsec packets in __ip_append_data
netpoll: prevent netpoll setup on slave devices
net: pmtu_expires fixes
gianfar:localized filer table
iwlegacy: fix channel switch locking
mac80211: fix IBSS teardown race
Lennert stated that he has been short on time lately. Since I'm maintaining
the ep93xx core stuff, I'm willing to also take over maintaining the Ethernet
driver.
Acked-by: Mika Westerberg <mika.westerberg@iki.fi>
Acked-by: Lennert Buytenhek <kernel@wantstofly.org>
This was done to resolve the conflicts that were in a number of files
due to changes done upstream with others done in the staging-next
branch.
The patch moves rtc driver for PKUnity-v3 SoC from arch/unicore32/kernel/
to drivers/rtc/, with renaming it to rtc-puv3.c.
Also, Kconfig, Makefile, and MAINTAINERS are modified correspondingly.
Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
I'll be continuing the amazing work Dave has
done with the Gadget Framework.
Signed-off-by: Felipe Balbi <balbi@ti.com>
We had to say goodbye when David passed away recently. David had a
huge impact on our community, both personally in the lives of the
people he worked with, and technically in the design and maintenance
of several subsystems. He is greatly missed.
He also leaves behind a number of much loved subsystems now orphaned.
This patch updates the MAINTAINERS file for the areas that David was
responsible for and adds an entry for him to the CREDITS file.
Acked-by: Harry Wei <harryxiyou@gmail.com>
README now only contains a link to the brcm80211 driver page. Two maintainers
have been added, one deleted. TODO file has also been updated.
Signed-off-by: Roland Vossen <rvossen@broadcom.com>
Reviewed-by: Arend van Spriel <arend@broadcom.com>
It was moved by commit 1a978c50c6cf
("HID: Move hiddev.txt to the new Documentation/hid directory")
so update the MAINTAINERS pattern too.
cc: Jiri Kosina <jkosina@suse.cz>
cc: Alan Ott <alan@signal11.us>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (33 commits)
x86: poll waiting for I/OAT DMA channel status
maintainers: add dma engine tree details
dmaengine: add TODO items for future work on dma drivers
dmaengine: Add API documentation for slave dma usage
dmaengine/dw_dmac: Update maintainer-ship
dmaengine: move link order
dmaengine/dw_dmac: implement pause and resume in dwc_control
dmaengine/dw_dmac: Replace spin_lock* with irqsave variants and enable submission from callback
dmaengine/dw_dmac: Divide one sg to many desc, if sg len is greater than DWC_MAX_COUNT
dmaengine/dw_dmac: set residue as total len in dwc_tx_status if status is !DMA_SUCCESS
dmaengine/dw_dmac: don't call callback routine in case dmaengine_terminate_all() is called
dmaengine: at_hdmac: pause: no need to wait for FIFO empty
pch_dma: modify pci device table definition
pch_dma: Support new device ML7223 IOH
pch_dma: Support I2S for ML7213 IOH
pch_dma: Fix DMA setting issue
pch_dma: modify for checkpatch
pch_dma: fix dma direction issue for ML7213 IOH video-in
dmaengine: at_hdmac: use descriptor chaining help function
dmaengine: at_hdmac: implement pause and resume in atc_control
Fix up trivial conflict in drivers/dma/dw_dmac.c
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (60 commits)
[SCSI] lpfc 8.3.24: Extend BSG infrastructure and add link diagnostics
[SCSI] lpfc 8.3.24: Add resource extent support
[SCSI] lpfc 8.3.24: Add request-firmware support
[SCSI] lpfc 8.3.24: Add SR-IOV control
[SCSI] lpfc 8.3.24: Extended hardware support and support dump images
[SCSI] lpfc 8.3.24: Miscellaneous Fixes and Corrections
[SCSI] libsas: Add option for SATA soft reset
[SCSI] libsas: check dev->gone before submitting sata i/o
[SCSI] libsas: fix/amend device gone notification in sas_deform_port()
[SCSI] MAINTAINERS update for SCSI (new email address)
[SCSI] Fix Ultrastor asm snippet
[SCSI] osst: fix warning
[SCSI] osst: wrong index used in inner loop
[SCSI] aic94xx: world-writable sysfs update_bios file
[SCSI] MAINTAINERS: Add drivers/target/ entry
[SCSI] target: Convert TASK_ATTR to scsi_tcq.h definitions
[SCSI] target: Convert REPORT_LUNs to use int_to_scsilun
[SCSI] target: Fix task->task_execute_queue=1 clear bug + LUN_RESET OOPs
[SCSI] target: Fix bug with task_sg chained transport_free_dev_tasks release
[SCSI] target: Fix interrupt context bug with stats_lock and core_tmr_alloc_req
git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6:
MAINTAINERS: Update eCryptfs mailing list
eCryptfs: Allow 2 scatterlist entries for encrypted filenames
eCryptfs: Clear i_nlink in rmdir
git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs
* 'docs-move' of git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs:
Create Documentation/security/, move LSM-, credentials-, and keys-related files from Documentation/ to Documentation/security/, add Documentation/security/00-INDEX, and update all occurrences of Documentation/<moved_file> to Documentation/security/<moved_file>.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (26 commits)
ASoC: Fix power down for widgetless per-card DAPM context case
ASoC: wm1250-ev1: Define "WM1250 Output" with SND_SOC_DAPM_OUTPUT
ASoC: Remove duplicate linux/delay.h inclusion.
ASoC: sam9g20_wm8731: use the proper SYSCKL value
ASoC: wm8731: fix wm8731_check_osc() connected condition
ALSA: hda - Reorganize controller quriks with bit flags
ALSA: hda - Use snd_printd() in snd_hda_parse_pin_def_config()
ALSA: core: remove unused variables.
ALSA: HDA: Increase MAX_HDMI_PINS
ALSA: PCM - Don't check DMA time-out too shortly
MAINTAINERS: add FireWire audio maintainer
ALSA: usb-audio: more control quirks for M-Audio FastTrack devices
ALSA: usb-audio: add new quirk type QUIRK_AUDIO_STANDARD_MIXER
ALSA: usb-audio: export snd_usb_feature_unit_ctl
ALSA: usb-audio: rework add_control_to_empty()
ALSA: usb-audio: move assignment of chip->ctrl_intf
ALSA: hda - Use model=auto for Lenovo G555
ALSA: HDA: Unify HDMI hotplug handling.
ALSA: hda - Force AD1988_6STACK_DIG for Asus M3N-HT Deluxe
ASoC: core - remove superfluous new line.
The eCryptfs mailing list has moved from lists.launchpad.net to
vger.kernel.org.
Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
I don't have the time or much interest these days in maintaining acer-wmi, as I
don't have access to newer Acer hardware. As he's been doing most of the work
these days anyway, Joey Lee has kindly agreed to take over.
Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk>
Cc: Joey Lee <jlee@novell.com>
I no longer have the time to work on this, and haven't really been doing any
work to this either. Time to let someone else take the reins.
