path: root/MAINTAINERS
2009-12-09Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (72 commits) [S390] 3215/3270 console: remove wrong comment [S390] dasd: remove BKL from extended error reporting code [S390] vmlogrdr: remove BKL [S390] vmur: remove BKL [S390] zcrypt: remove BKL [S390] 3270: remove BKL [S390] vmwatchdog: remove lock_kernel() from open() function [S390] monwriter: remove lock_kernel() from open() function [S390] monreader: remove lock_kernel() from open() function [S390] s390: remove unused nfsd #includes [S390] ftrace: build ftrace.o when CONFIG_FTRACE_SYSCALLS is set for s390 [S390] etr/stp: put correct per cpu variable [S390] tty3270: move keyboard compat ioctls [S390] sclp: improve servicability setting [S390] s390: use change recording override for kernel mapping [S390] MAINTAINERS: Add s390 drivers block [S390] use generic sockios.h header file [S390] use generic termbits.h header file [S390] smp: remove unused typedef and defines [S390] cmm: free pages on hibernate. ...
2009-12-09hwmon: (adt7475) Add an entry in MAINTAINERSJean Delvare
As I've just done a lot of changes to the adt7475 driver, I volunteer to maintain it for the year to come. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: "Darrick J. Wong" <djwong@us.ibm.com>
2009-12-09hwmon: New driver for the National Semiconductor LM73Adrien Demarez
The National Semiconductor LM73 is a single temperature sensor, much like the famous LM75. Signed-off-by: Adrien Demarez <adrien.demarez@bolloretelecom.eu> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-12-09MAINTAINERS: Add missing hwmon filesJean Delvare
Add missing documentation and header files to the hardware monitoring subsystem section. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-12-09MAINTAINERS: Add OMAP2/3 DSS and OMAPFB maintainerTomi Valkeinen
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
2009-12-09Merge commit 'origin/master' into nextBenjamin Herrenschmidt
Conflicts: include/linux/kvm.h
2009-12-09MAINTAINERS: Add PowerPC patternsJoe Perches
On Fri, 2009-12-04 at 20:59 +1100, Benjamin Herrenschmidt wrote: > On Fri, 2009-12-04 at 10:34 +0100, Jean Delvare wrote: > > I've sent it to linuxppc-dev@ozlabs.org on October 14th. This is the > > address which is listed 22 times in MAINTAINERS. If it isn't correct, > > then please update MAINTAINERS. > No it's fine both shoul work. Your patches are there, just waiting for > me to pick them up, I was just firing a reminder to the rest of the CC > list :-) (and I do remember fwd'ing a couple of your patches to the > list, for some reason they didn't make it to patchwork back then, that > was a few month ago). > Anyways, I've been stretched thin with all sort of stuff lately, so bear > with me if I'm a bit slow at taking or testing stuff, I'm doing my best. Adding patterns to the PowerPC sections of MAINTAINERS is useful. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-12-08MAINTAINERS: add SPI co-maintainer.Grant Likely
Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Andrew Morton <akpm@linux-foundation.org>
2009-12-08Merge branch 'for-2.6.33' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.33' of git://git.kernel.dk/linux-2.6-block: (113 commits) cfq-iosched: Do not access cfqq after freeing it block: include linux/err.h to use ERR_PTR cfq-iosched: use call_rcu() instead of doing grace period stall on queue exit blkio: Allow CFQ group IO scheduling even when CFQ is a module blkio: Implement dynamic io controlling policy registration blkio: Export some symbols from blkio as its user CFQ can be a module block: Fix io_context leak after failure of clone with CLONE_IO block: Fix io_context leak after clone with CLONE_IO cfq-iosched: make nonrot check logic consistent io controller: quick fix for blk-cgroup and modular CFQ cfq-iosched: move IO controller declerations to a header file cfq-iosched: fix compile problem with !CONFIG_CGROUP blkio: Documentation blkio: Wait on sync-noidle queue even if rq_noidle = 1 blkio: Implement group_isolation tunable blkio: Determine async workload length based on total number of queues blkio: Wait for cfq queue to get backlogged if group is empty blkio: Propagate cgroup weight updation to cfq groups blkio: Drop the reference to queue once the task changes cgroup blkio: Provide some isolation between groups ...
2009-12-08Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (272 commits) Fix soc_common PCMCIA configuration ARM: 5827/1: SA1100: h3100/h3600: emit messages on failed gpio_request ARM: 5826/1: SA1100: h3100/h3600: always build htc-egpio driver ARM: 5825/1: SA1100: h3600: update defconfig ARM: 5824/1: SA1100: reuse h3600 PCMCIA driver on h3100 ARM: 5823/1: SA1100: h3100/h3600: add support for gpio-keys ARM: 5822/1: SA1100: h3100/h3600: clean up #includes ARM: 5821/1: SA1100: h3100/h3600: revise copyright boilerplates ARM: 5820/1: SA1100: h3100/h3600: split h3600.c ARM: 5819/1: SA1100: h3100/h3600: merge h3600.h and h3600_gpio.h into h3xxx.h ARM: 5818/1: SA1100: h3100/h3600: drop old GPIO definitions ARM: 5817/1: SA1100: h3100/h3600: configure all unused gpios as inputs ARM: 5816/1: SA1100: h3600: remove IRQ_GPIO_* definitions ARM: 5815/1: SA1100: h3100/h3600: remove now unused assign_h3600_egpio handlers ARM: 5814/1: SA1100: h3100/h3600: convert all users of assign_h3600_egpio to gpiolib ARM: 5813/1: SA1100: h3100/h3600: add htc-egpio driver ARM: 5812/1: SA1100: h3100/h3600: separate machine-specific LCD helpers ARM: 5811/2: pcmcia: convert sa1100_h3600 driver to gpiolib ARM: 5799/1: SA1100: h3600: stop setting direction for LCD pins ARM: 5798/1: SA1100: h3600: remove unused cruft from h3600.h ...
2009-12-07Input: appletouch - give up maintainershipJohannes Berg
I no longer have a machine with this, and as such am not really able to help out with this driver any more. Remove the entire appletouch section and let the driver fall under the general input subsystem. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-12-07[S390] MAINTAINERS: Add s390 drivers blockJoe Perches
There are currently 4 directories in drivers/s390 (block, char, cio, kvm) without maintainers. Add drivers/s390/ to the s390 kvm section. Add the rest to the default s390 section. Add a W: link for drivers/s390/crypto/ Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-06Merge branch 'sa1100' into develRussell King
2009-12-05Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/net/pcmcia/fmvj18x_cs.c drivers/net/pcmcia/nmclan_cs.c drivers/net/pcmcia/xirc2ps_cs.c drivers/net/wireless/ray_cs.c
2009-12-05Merge branch 'devel-stable' into develRussell King
2009-12-05Merge branches 'at91', 'ep93xx', 'etm', 'ks8695', 'nuc', 'u300' and 'u8500' ↵Russell King
into devel
2009-12-04Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2009-12-04[SCSI] vmw_pvscsi: SCSI driver for VMware's virtual HBA.Alok Kataria
This is a driver for VMware's paravirtualized SCSI device, which should improve disk performance for guests running under control of VMware hypervisors that support such devices. Signed-off-by: Alok N Kataria <akataria@vmware.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] pm8001: add SAS/SATA HBA driverjack wang
This driver supports PMC-Sierra PCIe SAS/SATA 8x6G SPC 8001 chip based host adapters. Signed-off-by: Jack Wang <jack_wang@usish.com> Signed-off-by: Lindar Liu <lindar_liu@usish.com> Signed-off-by: Tom Peng <tom_peng@usish.com> Signed-off-by: Kevin Ao <aoqingyun@usish.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04Merge branch 'for-rmk' of git://git.pengutronix.de/git/imx/linux-2.6 into ↵Russell King
devel-stable
2009-12-04Merge branch 'pending-misc' (early part) into develRussell King
2009-12-03ARM: 5846/1: MAINTAINERS: Add arm Nomadik supportAlessandro Rubini
Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-03Merge branch 'master' into for-2.6.33Jens Axboe
2009-12-03MAINTAINERS: add tree and file pattern for ARM IMXUwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-12-01Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/ht.c
2009-12-01kbuild: stepping down as maintainerSam Ravnborg
It has been fun but the last year or more it has been a duty and a burden. So I leave it open for others to take over. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Anibal Monsalve Salazar <anibal@debian.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-01ARM: 5836/1: add MAINTAINERS entrySrinidhi Kasagar
Add MAINTAINERS entry for U8500 SoC Signed-off-by: srinidhi kasagar <srinidhi.kasagar@stericsson.com> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-11-30Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: at24: Use timeout also for read i2c: Fix userspace_device list corruption MAINTAINERS: Add missing i2c files i2c/tsl2550: Fix lux value in extended mode
2009-11-30Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] Update mach-types ARM: 5793/1: ARM: Check put_user fail in do_signal when enable OABI_COMPAT MAINTAINERS: add maintainer information for AMBA primecell drivers [ARM] pxa/spitz: fix compile regression on spitz ARM: PNX4008: i2c-pnx: use the same dev_id for request_irq and free_irq [ARM] pxa/cpufreq: fix index assignments for end marker ARM: PNX4008: fix watchdog device driver name [ARM] kmap: fix build errors with DEBUG_HIGHMEM enabled
2009-11-30Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: V4L/DVB (13372): staging/go7007: fix mutex function usage for s2250 staging/go7007: Fix compilation by re-adding the missing s2250-loader.h V4L/DVB (13530): Fix wrong parameter order in memset V4L/DVB (13481): sh_mobile_ceu_camera: fix compile warning V4L/DVB (13436): cxusb: Fix hang on DViCO FusionHDTV DVB-T Dual Digital 4 (rev 1) V4L/DVB (13412): SMS_SIANO_MDTV should depend on HAS_DMA V4L/DVB (13372a): MAINTAINERS: addition of gspca_gl860 driver V4L/DVB (13371): davinci: remove stray duplicate config pointer V4L/DVB (13366): em28xx: fix Reddo DVB-C USB TV Box GPIO V4L/DVB (13345): soc-camera: sh_mobile_ceu_camera: call pm_runtime_disable V4L/DVB (13344): soc-camera: properly initialise the device object when reusing V4L/DVB (13343): v4l: add more missing linux/sched.h includes V4L/DVB (13321): radio-gemtek-pci: fix double mutex_lock
2009-11-30fbdev: Migrate mailing lists to vgerGeert Uytterhoeven
The fbdev mailing lists at SourceForge have been migrated to a single mailing list at kernel.org: linux-fbdev@vger.kernel.org. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-30MAINTAINERS: Add entries for IMote 2 and Stargate 2Jonathan Cameron
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-11-28MAINTAINERS: Add iwmc3200wifi entrySamuel Ortiz
Update MAINTAINERS with the Intel supported iwmc3200wifi entry. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-26V4L/DVB (13372a): MAINTAINERS: addition of gspca_gl860 driverOlivier Lorin
MAINTAINERS: addition of gspca_gl860 driver - addition of gspca_gl860 driver Signed-off-by: Olivier Lorin <o.lorin@laposte.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-11-26MAINTAINERS: Add missing i2c filesJean Delvare
Add missing header files to the i2c subsystem section. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-11-24MAINTAINERS: change e-mail of Artem BityutskiyArtem Bityutskiy
Nowadays I have all my comunity-related stuff at gmail, so update my e-mail address. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2009-11-22MAINTAINERS: add maintainer information for AMBA primecell driversRussell King
2009-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sfc/sfe4001.c drivers/net/wireless/libertas/cmd.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/rtl8187se/Kconfig drivers/staging/rtl8192e/Kconfig
2009-11-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits) cxgb3: fix premature page unmap ibm_newemac: Fix EMACx_TRTR[TRT] bit shifts vlan: Fix register_vlan_dev() error path gro: Fix illegal merging of trailer trash sungem: Fix Serdes detection. net: fix mdio section mismatch warning ppp: fix BUG on non-linear SKB (multilink receive) ixgbe: Fixing EEH handler to handle more than one error net: Fix the rollback test in dev_change_name() Revert "isdn: isdn_ppp: Use SKB list facilities instead of home-grown implementation." TI Davinci EMAC : Fix Console Hang when bringing the interface down smsc911x: Fix Console Hang when bringing the interface down. mISDN: fix error return in HFCmulti_init() forcedeth: mac address fix r6040: fix version printing Bluetooth: Fix regression with L2CAP configuration in Basic Mode Bluetooth: Select Basic Mode as default for SOCK_SEQPACKET Bluetooth: Set general bonding security for ACL by default r8169: Fix receive buffer length when MTU is between 1515 and 1536 can: add the missing netlink get_xstats_size callback ...
2009-11-17MAINTAINERS: KMEMCHECK: add file patterns, use M: for Pekka's name and addressJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: Vegard Nossum <vegardno@ifi.uio.no> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/can/Kconfig
2009-11-15netxen: update MAINTAINERSAmit Kumar Salecha
Changing MAINTAINERS for netxen nic driver. Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-13MAINTAINERS: RFKILL - Fix pattern entry missing colonJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-13rt2x00: Update MAINTAINERSGertjan van Wingerde
Add myself to the list of maintainers for the rt2x00 driver. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-12MAINTAINERS: correct SECURITY SUBSYSTEM git entryJoe Perches
Use git.kernel.org not www.kernel.org Signed-off-by: Joe Perches <joe@perches.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12MAINTAINERS: correct NETFILTER git entry formatJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12MAINTAINERS: correct 9P FILE SYSTEM git entryJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12MAINTAINERS: openipmi list is moderatedRandy Dunlap
openipmi list is moderated. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12MAINTAINERS: VMWARE VMXNET3 - Quote name with comma and period, use tabsJoe Perches
Names with periods or commas need to be quoted Use tab not spaces Signed-off-by: Joe Perches <joe@perches.com> Cc: Shreyas Bhatewara <sbhatewara@vmware.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12MAINTAINERS: SERVER ENGINES 10Gbps iSCSI - Use single line M:Joe Perches
Integrate P:/M: lines to single M: Use tabs not spaces Signed-off-by: Joe Perches <joe@perches.com> Cc: Jayamohan Kallickal <jayamohank@serverengines.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
