The latest trace about usage of this driver I found was an (unanswered)
request for help by a user trying to get it working reliably five years
ago with kernel 2.4 .
And even if it was still working the use cases of this driver (requiring
both the hardware and someone providing this kind of wireless network)
have become practically nonexisting.
This patch therefore removes the strip driver.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
* 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6:
hwmon: (lm75) sensor reading bugfix
hwmon: (abituguru3) update driver detection
hwmon: (w83791d) new maintainer
hwmon: (abituguru3) Identify Abit AW8D board as such
hwmon: Update the sysfs interface documentation
hwmon: (adt7473) Initialize max_duty_at_overheat before use
hwmon: (lm85) Fix function RANGE_TO_REG()
Signed-off-by: Charles Spirakis <bezaur@gmail.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
Add PJ Waskiewicz to the list of maintainers for Intel 10/100/1000/10GbE
adapters.
Signed-off-by: PJ Waskiewicz <peter.p.waskiewicz.jr@intel.com>
The arch/ppc sub-tree has been removed in the powerpc git tree. The old
ibm_emac driver is no longer used by anything as a result of this. This
removes it, leaving the ibm_newemac driver as the proper driver to use for
PowerPC boards with the EMAC hardware.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
upstream-next
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6:
parisc: update my email address
parisc: fix miscompilation of ip_fast_csum with gcc >= 4.3
parisc: fix off by one in setup_sigcontext32
parisc: export empty_zero_page
parisc: export copy_user_page_asm
parisc: move head.S to head.text section
Revert "parisc: fix trivial section name warnings"
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
tcp: Revert 'process defer accept as established' changes.
ipv6: Fix duplicate initialization of rawv6_prot.destroy
bnx2x: Updating the Maintainer
net: Eliminate flush_scheduled_work() calls while RTNL is held.
drivers/net/r6040.c: correct bad use of round_jiffies()
fec_mpc52xx: MPC52xx_MESSAGES_DEFAULT: 2nd NETIF_MSG_IFDOWN => IFUP
ipg: fix receivemode IPG_RM_RECEIVEMULTICAST{,HASH} in ipg_nic_set_multicast_list()
netfilter: nf_conntrack: fix ctnetlink related crash in nf_nat_setup_info()
netfilter: Make nflog quiet when no one listen in userspace.
ipv6: Fail with appropriate error code when setting not-applicable sockopt.
ipv6: Check IPV6_MULTICAST_LOOP option value.
ipv6: Check the hop limit setting in ancillary data.
ipv6 route: Fix route lifetime in netlink message.
ipv6 mcast: Check address family of gf_group in getsockopt(MS_FILTER).
dccp: Bug in initial acknowledgment number assignment
dccp ccid-3: X truncated due to type conversion
dccp ccid-3: TFRC reverse-lookup Bug-Fix
dccp ccid-2: Bug-Fix - Ack Vectors need to be ignored on request sockets
dccp: Fix sparse warnings
dccp ccid-3: Bug-Fix - Zero RTT is possible
Signed-off-by: Eric Miao <eric.miao@marvell.com>
Acked-by: Russell King <rmk@arm.linux.org.uk>
Acked-by: Nicolas Pitre <nico@marvell.com>
Add URL for another CPUSETS web page to the MAINTAINERS file.
This URL provides links to major LGPL user level C libraries supporting
cpuset usage and user level cpu and node masks.
Signed-off-by: Paul Jackson <pj@sgi.com>
I would like to thank Eliezer Tamir for writing and maintaining the
driver for the past two years. I will take over maintaining the bnx2x
driver from now on.
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
Signed-off-by: Eliezer Tamir <eliezert@broadcom.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 into linux-next
Signed-off-by: Dale Farnsworth <dale@farnsworth.org>
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
This patch updates the location of the ACPI homepage in MAINTAINERS.
Signed-off-by: Len Brown <len.brown@intel.com>
Just concentrate PCI traffic at linux-pci@vger rather than splitting it between
vger and a sf.net moderated (!) mailing list.
Acked-by: Matthew Wilcox <willy@linux.intel.com>
Acked-by: Scott Murray <scottm@somanetworks.com>
Acked-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
- maintainer has not been active for years
- URLs no longer exist
- covered by the IDE SUBSYSTEM entry
- maintainer email bounces
Cc: Lionel.Bouton@inet6.fr
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Cc: Michal Ostrowski <mostrows@earthlink.net>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IB/ipath: Fix SM trap forwarding
IB/ehca: Reject send WRs only for RESET, INIT and RTR state
MAINTAINERS: Update NetEffect (iw_nes) entry
IB/ipath: Fix device capability flags
IB/ipath: Avoid test_bit() on u64 SDMA status value
git://git.kernel.org/pub/scm/linux/kernel/git/chrisw/lsm-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/chrisw/lsm-2.6:
capabilities: remain source compatible with 32-bit raw legacy capability support.
LSM: remove stale web site from MAINTAINERS
Signed-off-by: Alan Cox <alan@redhat.com>
Cc: Edward Shishkin <edward.shishkin@gmail.com>
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Jan Kara <jack@ucw.cz>
This patch updates the URL of the bridge homepage.
Signed-off-by: Pau Oliva Fora <pau@eslack.org>
Pointed out by Adrian Bunk.
Add Chien and remove Nishi from maintainers list for NetEffect.
Signed-off-by: Chien Tung <ctung@neteffect.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
(akpm: we often deal with util-linux and I (at least) can never remember
where they hang out).
Signed-off-by: Karel Zak <kzak@redhat.com>
IB/mad: Fix kernel crash when .process_mad() returns SUCCESS|CONSUMED
IPoIB: Test for NULL broadcast object in ipiob_mcast_join_finish()
MAINTAINERS: Add cxgb3 and iw_cxgb3 NIC and iWARP driver entries
IB/mlx4: Fix creation of kernel QP with max number of send s/g entries
IB/mthca: Fix max_sge value returned by query_device
RDMA/cxgb3: Fix uninitialized variable warning in iwch_post_send()
IB/mlx4: Fix uninitialized-var warning in mlx4_ib_post_send()
IB/ipath: Fix UC receive completion opcode for RDMA WRITE with immediate
IB/ipath: Fix printk format for ipath_sdma_status
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
iop-adma: fixup some kzalloc/memset confusions
fsldma: update the fsldma driver MAINTAINERS info
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Add Li Yang as the new maintainer for fsldma driver and update
my email address.
Acked-by: Li Yang <leoli@freescale.com>
Signed-off-by: Zhang Wei <zw@zh-kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: correct mailing list address
PCI: Correct last two HP entries in the bfsort whitelist
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
[POWERPC] Update defconfigs for desktop/server systems
[POWERPC] Fix mpc8377_mds.dts DMA nodes to match spec
[POWERPC] Update arch/powerpc/boot/.gitignore
[POWERPC] Remove generated files on make clean
[POWERPC] powerpc/mm/hash_low_32.S: Remove CVS keyword
[POWERPC] Update Cell MAINTAINERS entry, add spufs entry
lmb: Fix compile warning
Add a MAINTAINERS entry for the myri10ge driver.
Signed-off-by: Brice Goglin <brice@myri.com>
The MAINTAINERS file entry for the cell platform is outdated,
even the name of the platform changed since the early days
when it was initially submitted.
The SPU file system is now maintained by Jeremy Kerr.
Forgot to update the PCI error handling address with the new @vger one.
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm
* 'kvm-updates-2.6.26' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm:
KVM: LAPIC: ignore pending timers if LVTT is disabled
KVM: Update MAINTAINERS for new mailing lists
KVM: Fix kvm_vcpu_block() task state race
KVM: ia64: Set KVM_IOAPIC_NUM_PINS to 48
KVM: ia64: fix GVMM module including position-dependent objects
KVM: ia64: Define new kvm_fpreg struture to replace ia64_fpreg
KVM: PIT: take inject_pending into account when emulating hlt
s390: KVM guest: fix compile error
KVM: x86 emulator: fix writes to registers with modrm encodings
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes:
Don't clean bounds.h and asm-offsets.h
kconfig: incorrect 'len' field initialisation ?
kernel-doc: allow unnamed bit-fields
kbuild: filter away debug symbols from kernel symbols
Remove *.rej pattern from .gitignore
MAINTAINERS: document names of new kbuild trees
kbuild: disable modpost warnings for linkonce sections
kbuild: escape meta characters in regular expression in make TAGS
Ben Dooks agreed to become my co-maintainer for the i2c subsystem. In
particular, Ben will help with drivers for embedded systems, of which
my experience is inexistent. Thanks Ben and welcome on board!
Acked-by: Ben Dooks <ben-linux@fluff.org>
The KVM mailing lists are now hosted on vger.kernel.org. Also update
the website URL.
Signed-off-by: Avi Kivity <avi@qumranet.com>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Andy Walls <awalls@radix.net>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Update the Geode list location in the MAINTAINERS file.
Signed-off-by: Jordan Crouse <jordan.crouse@amd.com>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
I'm handing over maintainership to Jeff Kirsher and moving on
to other Linux/Open Source work within Intel. Good luck to Jeff ;)
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Many thanks to Martin for his years of hosting. The pci list has moved to
vger, along with what seems like the rest of the major Linux mailing lists.
This patch add the core driver for the c67x00 USB OTG controller. The core
driver is responsible for the platform bus binding and creating either
USB HCD or USB Gadget instances for each of the serial interface engines
on the chip.
This driver does not directly implement the HCD or gadget behaviours; it
just controls access to the chip.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Add Paul and myself, and the linux-embedded list, to MAINTAINERS.
Update CPUSETS MAINTAINERS to reflect the more active role of Paul Menage
(secondary to his work on cgroups) and the retirement of the original author
of cpusets, Simon Derr. Thanks, Simon! Best of luck to you.
Acked-by: Paul Menage <menage@google.com>
Acked-by: Simon Derr <simon.derr@bull.net>
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (179 commits)
ACPI: Fix acpi_processor_idle and idle= boot parameters interaction
acpi: fix section mismatch warning in pnpacpi
intel_menlo: fix build warning
ACPI: Cleanup: Remove unneeded, multiple local dummy variables
ACPI: video - fix permissions on some proc entries
ACPI: video - properly handle errors when registering proc elements
ACPI: video - do not store invalid entries in attached_array list
ACPI: re-name acpi_pm_ops to acpi_suspend_ops
ACER_WMI/ASUS_LAPTOP: fix build bug
thinkpad_acpi: fix possible NULL pointer dereference if kstrdup failed
ACPI: check a return value correctly in acpi_power_get_context()
#if 0 acpi/bay.c:eject_removable_drive()
eeepc-laptop: add hwmon fan control
eeepc-laptop: add backlight
eeepc-laptop: add base driver
ACPI: thinkpad-acpi: bump up version to 0.20
ACPI: thinkpad-acpi: fix selects in Kconfig
ACPI: thinkpad-acpi: use a private workqueue
ACPI: thinkpad-acpi: fluff really minor fix
ACPI: thinkpad-acpi: use uppercase for "LED" on user documentation
Fixed conflicts in drivers/acpi/video.c and drivers/misc/intel_menlow.c
manually.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (53 commits)
tcp: Overflow bug in Vegas
[IPv4] UFO: prevent generation of chained skb destined to UFO device
iwlwifi: move the selects to the tristate drivers
ipv4: annotate a few functions __init in ipconfig.c
atm: ambassador: vcc_sf semaphore to mutex
MAINTAINERS: The socketcan-core list is subscribers-only.
netfilter: nf_conntrack: padding breaks conntrack hash on ARM
ipv4: Update MTU to all related cache entries in ip_rt_frag_needed()
sch_sfq: use del_timer_sync() in sfq_destroy()
net: Add compat support for getsockopt (MCAST_MSFILTER)
net: Several cleanups for the setsockopt compat support.
ipvs: fix oops in backup for fwmark conn templates
bridge: kernel panic when unloading bridge module
bridge: fix error handling in br_add_if()
netfilter: {nfnetlink,ip,ip6}_queue: fix skb_over_panic when enlarging packets
netfilter: x_tables: fix net namespace leak when reading /proc/net/xxx_tables_names
netfilter: xt_TCPOPTSTRIP: signed tcphoff for ipv6_skip_exthdr() retval
tcp: Limit cwnd growth when deferring for GSO
tcp: Allow send-limited cwnd to grow up to max_burst when gso disabled
[netdrvr] gianfar: Determine TBIPA value dynamically
