path: root/MAINTAINERS
2011-01-21MAINTAINERS: Update Roland Dreier's email addressRoland Dreier
The cisco.com address will stop working soon, and besides no one can remember the second "d" in "rolandd" or how to spell "rdreier." Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-20Merge branch 'akpm'Linus Torvalds
* akpm: kernel/smp.c: consolidate writes in smp_call_function_interrupt() kernel/smp.c: fix smp_call_function_many() SMP race memcg: correctly order reading PCG_USED and pc->mem_cgroup backlight: fix 88pm860x_bl macro collision drivers/leds/ledtrig-gpio.c: make output match input, tighten input checking MAINTAINERS: update Atmel AT91 entry mm: fix truncate_setsize() comment memcg: fix rmdir, force_empty with THP memcg: fix LRU accounting with THP memcg: fix USED bit handling at uncharge in THP memcg: modify accounting function for supporting THP better fs/direct-io.c: don't try to allocate more than BIO_MAX_PAGES in a bio mm: compaction: prevent division-by-zero during user-requested compaction mm/vmscan.c: remove duplicate include of compaction.h memblock: fix memblock_is_region_memory() thp: keep highpte mapped until it is no longer needed kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERT
2011-01-20MAINTAINERS: update Atmel AT91 entryNicolas Ferre
Add two co-maintainers and update the entry with new information. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-20Merge branch 'tty-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: tty: update MAINTAINERS file due to driver movement tty: move drivers/serial/ to drivers/tty/serial/ tty: move hvc drivers to drivers/tty/hvc/
2011-01-15Update Pekka's email address in MAINTAINERSPekka Enberg
Signed-off-by: Pekka Enberg <penberg@kernel.org>
2011-01-14Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] MAINTAINERS: Update zcrypt driver entry [S390] Randomize PIEs [S390] Randomise the brk region [S390] Add is_32bit_task() helper function [S390] Randomize lower bits of stack address [S390] Randomize mmap start address [S390] Rearrange mmap.c [S390] Enable flexible mmap layout for 64 bit processes [S390] vdso: dont map at mmap_base [S390] reduce miminum gap between stack and mmap_base [S390] mmap: consider stack address randomization [S390] Update default configuration [S390] cio: path_event overindication after resume
2011-01-13MAINTAINERS: update entries affecting VIA TechnologiesBruce Chang
Since the original maintainer-Joseph Chan (josephchan@via.com.tw) doesn't handle the Linux driver for VIA now, I would like to request to update the maintainer for the SD/MMC CARD CONTROLLER DRIVER and VIA UNICHROME(PRO)/CHROME9 FRAMEBUFFER DRIVER before we find a better one. Signed-off-by: Bruce Chang <brucechang@via.com.tw> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Joseph Chan <JosephChan@via.com.tw> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Harald Welte <HaraldWelte@viatech.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13tty: update MAINTAINERS file due to driver movementGreg Kroah-Hartman
This fixes up the MAINTAINERS file due to moving the serial drivers to the drivers/tty/ directory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (348 commits) ALSA: hda - Fix NULL-derefence with a single mic in STAC auto-mic detection ALSA: hda - Add missing NID 0x19 fixup for Sony VAIO ALSA: hda - Fix ALC275 enable hardware EQ for SONY VAIO ALSA: oxygen: fix Xonar DG input ALSA: hda - Fix EAPD on Lenovo NB ALC269 to low ALSA: hda - Fix missing EAPD for Acer 4930G ALSA: hda: Disable 4/6 channels on some NVIDIA GPUs. ALSA: hda - Add static_hdmi_pcm option to HDMI codec parser ALSA: hda - Don't refer ELD when unplugged ASoC: tpa6130a2: Fix compiler warning ASoC: tlv320dac33: Add DAPM selection for LOM invert ASoC: DMIC codec: Adding a generic DMIC codec ALSA: snd-usb-us122l: Fix missing NULL checks ALSA: snd-usb-us122l: Fix MIDI output ASoC: soc-cache: Fix invalid memory access during snd_soc_lzo_cache_sync() ASoC: Fix section mismatch in wm8995.c ALSA: oxygen: add S/PDIF source selection for Claro cards ALSA: oxygen: fix CD/MIDI for X-Meridian (2G) ASoC: fix migor audio build ALSA: include delay.h for msleep in Xonar DG support ...
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-13rtc: delete legacy MAINTAINERS entryPaul Gortmaker
People stumble across the entry for the legacy PC specific RTC driver entry in MAINTAINERS when they really want the multi-arch, multi-driver RTC subsystem. So just delete the old entry that is causing the confusion. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13MAINTAINERS: remove Stelian from the AMS driver recordStelian Pop
This driver is PPC only, and I am no longer able to test it. Signed-off-by: Stelian Pop <stelian@popies.net> Cc: Michael Hanselmann <linux-kernel@hansmi.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13MAINTAINERS: orphan the meye driverStelian Pop
I don't even remember when it was that I sold this laptop, but it has been a few years... Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13MAINTAINERS: openwrt-devel@ is subscribers-onlyLennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Florian Fainelli <florian@openwrt.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Merge branch 'topic/asoc' into for-linusTakashi Iwai
2011-01-13Merge branch 'topic/misc' into for-linusTakashi Iwai
2011-01-12NTFS: writev() fix and maintenance/contact details updateAnton Altaparmakov
Fix writev() to not keep writing the first segment over and over again instead of moving onto subsequent segments and update the NTFS entry in MAINTAINERS to reflect that Tuxera Inc. now supports the NTFS driver. Signed-off-by: Anton Altaparmakov <anton@tuxera.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-12[S390] MAINTAINERS: Update zcrypt driver entryHolger Dengler
Holger will take over the zcrypt driver maintainer work. Update the MAINTAINERS entry accordingly. Signed-off-by: Holger Dengler <hd@linux.vnet.ibm.com> Signed-off-by: Felix Beck <felix.beck@de.ibm.com>
2011-01-11Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: (22 commits) MAINTAINERS: Update Joel Becker's email address ocfs2: Remove unused truncate function from alloc.c ocfs2/cluster: dereferencing before checking in nst_seq_show() ocfs2: fix build for OCFS2_FS_STATS not enabled ocfs2/cluster: Show o2net timing statistics ocfs2/cluster: Track process message timing stats for each socket ocfs2/cluster: Track send message timing stats for each socket ocfs2/cluster: Use ktime instead of timeval in struct o2net_sock_container ocfs2/cluster: Replace timeval with ktime in struct o2net_send_tracking ocfs2: Add DEBUG_FS dependency ocfs2/dlm: Hard code the values for enums ocfs2/dlm: Minor cleanup ocfs2/dlm: Cleanup dlmdebug.c ocfs2: Release buffer_head in case of error in ocfs2_double_lock. ocfs2/cluster: Pin the local node when o2hb thread starts ocfs2/cluster: Show pin state for each o2hb region ocfs2/cluster: Pin/unpin o2hb regions ocfs2/cluster: Remove dropped region from o2hb quorum region bitmap ocfs2/cluster: Pin the remote node item in configfs ocfs2/dlm: make existing convertion precedent over new lock ...
2011-01-10Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c: Constify i2c_client where possible i2c-algo-bit: Complain about masters which can't read SCL i2c-algo-bit: Refactor adapter registration i2c: Add generic I2C multiplexer using GPIO API i2c-nforce2: Remove unnecessary cast of pci_get_drvdata i2c-i801: Include <linux/slab.h>
2011-01-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: (52 commits) Blackfin: encode cpu-rev into uImage name Blackfin: bf54x: don't ack GPIO ints when unmasking them Blackfin: sram_free_with_lsl: do not ignore return value of sram_free Blackfin: boards: add missing "static" to peripheral lists Blackfin: DNP5370: new board port Blackfin: bf518f-ezbrd: fix dsa resources Blackfin: move "-m elf32bfin" to general LDFLAGS Blackfin: kgdb_test: make sure to initialize num2 Blackfin: kgdb: disable preempt schedule when running single step in kgdb Blackfin: kgdb: disable interrupt when single stepping in ADEOS Blackfin: SMP: kgdb: apply anomaly 257 work around Blackfin: fix building IPIPE code when XIP is enabled Blackfin: SMP: kgdb: flush core internal write buffer before flushinv Blackfin: sport_uart resources: remove unused secondary RX/TX pins Blackfin: tll6527m: fix spelling in unused code (struct name) Blackfin: bf527-ezkit: add adau1373 chip address Blackfin: no-mpu: fix masking of small uncached dma region Blackfin: pm: drop irq save/restore in standby and suspend to mem callback MAINTAINERS: update Analog Devices support info Blackfin: dpmc.h: pull in new pll.h ...
2011-01-10Merge branch 'staging-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6 * 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (510 commits) staging: speakup: fix failure handling staging: usbip: remove double giveback of URB Staging: batman-adv: Remove batman-adv from staging Staging: hv: Use only one txf buffer per channel and kmalloc/GFP_KERNEL on initialize staging: hv: remove unneeded osd_schedule_callback staging: hv: convert channel_mgmt.c to not call osd_schedule_callback staging: hv: convert vmbus_on_msg_dpc to not call osd_schedule_callback staging: brcm80211: Fix WL_<type> logging macros Staging: IIO: DDS: AD9833 / AD9834 driver Staging: IIO: dds.h convenience macros Staging: IIO: Direct digital synthesis abi documentation staging: brcm80211: Convert ETHER_TYPE_802_1X to ETH_P_PAE staging: brcm80211: Remove unused ETHER_TYPE_<foo> #defines staging: brcm80211: Remove ETHER_HDR_LEN, use ETH_HLEN staging: brcm80211: Convert ETHER_ADDR_LEN to ETH_ALEN staging: brcm80211: Convert ETHER_IS<FOO> to is_<foo>_ether_addr staging: brcm80211: Remove unused ether_<foo> #defines and struct staging: brcm80211: Convert ETHER_IS_MULTI to is_multicast_ether_addr staging: brcm80211: Remove unused #defines ETHER_<foo>_LOCALADDR Staging: comedi: Fix checkpatch.pl issues in file s526.c ... Fix up trivial conflict in drivers/video/udlfb.c
2011-01-10Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86: (36 commits) sony-laptop: support new hotkeys on the P, Z and EC series platform/x86: Consistently select LEDS Kconfig options sony-laptop: fix sparse non-ANSI function warning intel_ips: fix sparse non-ANSI function warning Support KHLB2 in the compal laptop driver acer-wmi: Enabled Acer Launch Manager mode [PATCH] intel_pmic_gpio: modify EOI handling following change of kernel irq subsystem ACPI Thinkpad: We must always call va_end() after va_start() but do not do so in thinkpad_acpi.c::acpi_evalf() acer-wmi: Initialize wlan/bluetooth/wwan rfkill software block state acer-wmi: Detect the WiFi/Bluetooth/3G devices available acer-wmi: Add 3G rfkill sysfs file acer-wmi: Add acer wmi hotkey events support platform/x86: Kconfig: Replace select by depends on ACPI_WMI ideapad: pass ideapad_priv as argument (part 2) ideapad: pass ideapad_priv as argument (part 1) ideapad: add markups, unify comments and return result when init ideapad: add hotkey support ideapad: let camera power control entry under platform driver ideapad: add platform driver for ideapad fujitsu-laptop: fix compiler warning on pnp_ids ...
2011-01-10i2c: Add generic I2C multiplexer using GPIO APIPeter Korsgaard
Add an i2c mux driver providing access to i2c bus segments using a hardware MUX sitting on a master bus and controlled through gpio pins. E.G. something like: ---------- ---------- Bus segment 1 - - - - - | | SCL/SDA | |-------------- | | | |------------| | | | | | Bus segment 2 | | | Linux | GPIO 1..N | MUX |--------------- Devices | |------------| | | | | | | | Bus segment M | | | |---------------| | ---------- ---------- - - - - - SCL/SDA of the master I2C bus is multiplexed to bus segment 1..M according to the settings of the GPIO pins 1..N. Signed-off-by: Peter Korsgaard <peter.korsgaard@barco.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (30 commits) MAINTAINERS: Add tomoyo-dev-en ML. SELinux: define permissions for DCB netlink messages encrypted-keys: style and other cleanup encrypted-keys: verify datablob size before converting to binary trusted-keys: kzalloc and other cleanup trusted-keys: additional TSS return code and other error handling syslog: check cap_syslog when dmesg_restrict Smack: Transmute labels on specified directories selinux: cache sidtab_context_to_sid results SELinux: do not compute transition labels on mountpoint labeled filesystems This patch adds a new security attribute to Smack called SMACK64EXEC. It defines label that is used while task is running. SELinux: merge policydb_index_classes and policydb_index_others selinux: convert part of the sym_val_to_name array to use flex_array selinux: convert type_val_to_struct to flex_array flex_array: fix flex_array_put_ptr macro to be valid C SELinux: do not set automatic i_ino in selinuxfs selinux: rework security_netlbl_secattr_to_sid SELinux: standardize return code handling in selinuxfs.c SELinux: standardize return code handling in selinuxfs.c SELinux: standardize return code handling in policydb.c ...
2011-01-10MAINTAINERS: add myselfClemens Ladisch
Add entries for the remaining drivers that I'm maintaining. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-01-10MAINTAINERS: update Analog Devices support infoMichael Hennerich
Add more Analog Devices driver entries and refine the differences between Blackfin-specific code and processor independent drivers. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-01-10MAINTAINERS: add nilfs2 git tree entryRyusuke Konishi
NILFS2 filesystem section of the MAINTAINERS file lacks an entry of scm tree. This adds it. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2011-01-10Merge branch 'master' into nextJames Morris
Conflicts: security/smack/smack_lsm.c Verified and added fix by Stephen Rothwell <sfr@canb.auug.org.au> Ok'd by Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-07MAINTAINERS: Update Joel Becker's email addressJoel Becker
My old address no longer works, so MAINTAINERS should have a working one. Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-01-07Merge branch 'for-2.6.38' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (30 commits) gameport: use this_cpu_read instead of lookup x86: udelay: Use this_cpu_read to avoid address calculation x86: Use this_cpu_inc_return for nmi counter x86: Replace uses of current_cpu_data with this_cpu ops x86: Use this_cpu_ops to optimize code vmstat: User per cpu atomics to avoid interrupt disable / enable irq_work: Use per cpu atomics instead of regular atomics cpuops: Use cmpxchg for xchg to avoid lock semantics x86: this_cpu_cmpxchg and this_cpu_xchg operations percpu: Generic this_cpu_cmpxchg() and this_cpu_xchg support percpu,x86: relocate this_cpu_add_return() and friends connector: Use this_cpu operations xen: Use this_cpu_inc_return taskstats: Use this_cpu_ops random: Use this_cpu_inc_return fs: Use this_cpu_inc_return in buffer.c highmem: Use this_cpu_xx_return() operations vmstat: Use this_cpu_inc_return for vm statistics x86: Support for this_cpu_add, sub, dec, inc_return percpu: Generic support for this_cpu_add, sub, dec, inc_return ... Fixed up conflicts: in arch/x86/kernel/{apic/nmi.c, apic/x2apic_uv_x.c, process.c} as per Tejun.
2011-01-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (58 commits) Input: wacom_w8001 - support pen or touch only devices Input: wacom_w8001 - use __set_bit to set keybits Input: bu21013_ts - fix misuse of logical operation in place of bitop Input: i8042 - add Acer Aspire 5100 to the Dritek list Input: wacom - add support for digitizer in Lenovo W700 Input: psmouse - disable the synaptics extension on OLPC machines Input: psmouse - fix up Synaptics comment Input: synaptics - ignore bogus mt packet Input: synaptics - add multi-finger and semi-mt support Input: synaptics - report clickpad property input: mt: Document interface updates Input: fix double equality sign in uevent Input: introduce device properties hid: egalax: Add support for Wetab (726b) Input: include MT library as source for kerneldoc MAINTAINERS: Update input-mt entry hid: egalax: Add support for Samsung NB30 netbook hid: egalax: Document the new devices in Kconfig hid: egalax: Add support for Wetab hid: egalax: Convert to MT slots ... Fixed up trivial conflict in drivers/input/keyboard/Kconfig
2011-01-07eeepc-wmi: claim eeepc-wmi maintainershipCorentin Chary
Since eeepc-wmi has currently no official maintainer, I claim maintainership of this driver, and add it to the acpi4asus project. Signed-off-by: Corentin Chary <corentincj@iksaif.net> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-01-06Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (243 commits) omap2: Make OMAP2PLUS select OMAP_DM_TIMER OMAP4: hwmod data: Fix alignment and end of line in structurefields OMAP4: hwmod data: Move the DMA structures OMAP4: hwmod data: Move the smartreflex structures OMAP4: hwmod data: Fix missing SIDLE_SMART_WKUP in smartreflexsysc arm: omap: tusb6010: add name for MUSB IRQ arm: omap: craneboard: Add USB EHCI support omap2+: Initialize serial port for dynamic remuxing for n8x0 omap2+: Add struct omap_board_data and use it for platform level serial init omap2+: Allow hwmod state changes to mux pads based on the state changes omap2+: Add support for hwmod specific muxing of devices omap2+: Add omap_mux_get_by_name OMAP2: PM: fix compile error when !CONFIG_SUSPEND MAINTAINERS: OMAP: hwmod: update hwmod code, data maintainership OMAP4: Smartreflex framework extensions OMAP4: hwmod: Add inital data for smartreflex modules. OMAP4: PM: Program correct init voltages for scalable VDDs OMAP4: Adding voltage driver support OMAP4: Register voltage PMIC parameters with the voltage layer OMAP3: PM: Program correct init voltages for VDD1 and VDD2 ... Fix up trivial conflict in arch/arm/plat-omap/Kconfig
2011-01-06Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (255 commits) [media] radio-aimslab.c: Fix gcc 4.5+ bug [media] cx25821: Fix compilation breakage due to BKL dependency [media] v4l2-compat-ioctl32: fix compile warning [media] zoran: fix compiler warning [media] tda18218: fix compile warning [media] ngene: fix compile warning [media] DVB: IR support for TechnoTrend CT-3650 [media] cx23885, cimax2.c: Fix case of two CAM insertion irq [media] ir-nec-decoder: fix repeat key issue [media] staging: se401 depends on USB [media] staging: usbvideo/vicam depends on USB [media] soc_camera: Add the ability to bind regulators to soc_camedra devices [media] V4L2: Add a v4l2-subdev (soc-camera) driver for OmniVision OV2640 sensor [media] v4l: soc-camera: switch to .unlocked_ioctl [media] v4l: ov772x: simplify pointer dereference [media] ov9640: fix OmniVision OV9640 sensor driver's priv data retrieving [media] ov9640: use macro to request OmniVision OV9640 sensor private data [media] ivtv-i2c: Fix two warnings [media] staging/lirc: Update lirc TODO files [media] cx88: Remove the obsolete i2c_adapter.id field ...
2011-01-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1436 commits) cassini: Use local-mac-address prom property for Cassini MAC address net: remove the duplicate #ifdef __KERNEL__ net: bridge: check the length of skb after nf_bridge_maybe_copy_header() netconsole: clarify stopping message netconsole: don't announce stopping if nothing happened cnic: Fix the type field in SPQ messages netfilter: fix export secctx error handling netfilter: fix the race when initializing nf_ct_expect_hash_rnd ipv4: IP defragmentation must be ECN aware net: r6040: Return proper error for r6040_init_one dcb: use after free in dcb_flushapp() dcb: unlock on error in dcbnl_ieee_get() net: ixp4xx_eth: Return proper error for eth_init_one include/linux/if_ether.h: Add #define ETH_P_LINK_CTL for HPNA and wlan local tunnel net: add POLLPRI to sock_def_readable() af_unix: Avoid socket->sk NULL OOPS in stream connect security hooks. net_sched: pfifo_head_drop problem mac80211: remove stray extern mac80211: implement off-channel TX using hw r-o-c offload mac80211: implement hardware offload for remain-on-channel ...
2011-01-06Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: MAINTAINERS: Update timer related entries timers: Use this_cpu_read timerqueue: Make timerqueue_getnext() static inline hrtimer: fix timerqueue conversion flub hrtimers: Convert hrtimers to use timerlist infrastructure timers: Fixup allmodconfig build issue timers: Rename timerlist infrastructure to timerqueue timers: Introduce timerlist infrastructure. hrtimer: Remove stale comment on curr_timer timer: Warn when del_timer_sync() is called in hardirq context timer: Del_timer_sync() can be used in softirq context timer: Make try_to_del_timer_sync() the same on SMP and UP posix-timers: Annotate lock_timer() timer: Permit statically-declared work with deferrable timers time: Use ARRAY_SIZE macro in timecompare.c timer: Initialize the field slack of timer_list timer_list: Remove alignment padding on 64 bit when CONFIG_TIMER_STATS time: Compensate for rounding on odd-frequency clocksources Fix up trivial conflict in MAINTAINERS
2011-01-05Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: net/bluetooth/Makefile
2011-01-05Merge commit 'v2.6.37' into perf/coreIngo Molnar
Merge reason: Add the final .37 tree. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-04Merge commit 'v2.6.37-rc8' into perf/coreIngo Molnar
Merge reason: pick up latest -rc. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-03Merge branch 'fix' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6
2011-01-03netdev: Update status of 8390 based drivers in MAINTAINERSPaul Gortmaker
With the original 8 bit ISA ne1000 card being over 20 years old, it only makes sense to consider ne.c and all the other toplevel 8390 based driver files as legacy for obsolete hardware. The most recent thing made in large quantities that was 8390 based were those crazy PCI ne2k clones - and even they are now 10+ years old. Also remove myself as maintainer, since the only changes to these drivers going forward will be the generic API type changes that touch all drivers. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-29[media] cpia, stradis: remove deprecated V4L1 driversHans Verkuil
Nobody stepped in to convert these drivers to V4L2, so they are now removed from the kernel. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/fib_frontend.c
2010-12-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits) ipv4: dont create routes on down devices epic100: hamachi: yellowfin: Fix skb allocation size sundance: Fix oopses with corrupted skb_shared_info Revert "ipv4: Allow configuring subnets as local addresses" USB: mcs7830: return negative if auto negotiate fails irda: prevent integer underflow in IRLMP_ENUMDEVICES tcp: fix listening_get_next() atl1c: Do not use legacy PCI power management mac80211: fix mesh forwarding MAINTAINERS: email address change net: Fix range checks in tcf_valid_offset(). net_sched: sch_sfq: fix allot handling hostap: remove netif_stop_queue from init mac80211/rt2x00: add ieee80211_tx_status_ni() typhoon: memory corruption in typhoon_get_drvinfo() net: Add USB PID for new MOSCHIP USB ethernet controller MCS7832 variant net_sched: always clone skbs ipv6: Fragment locally generated tunnel-mode IPSec6 packets as needed. netlink: fix gcc -Wconversion compilation warning asix: add USB ID for Logitec LAN-GTJ U2A ...
2010-12-24ARM: 6537/1: update Nomadik, U300 and Ux500 maintainersLinus Walleij
Adding in self as maintainer for Nomadik and Ux500, I'm running an active -next tree for that stuff now. Extend file matchers to cover a few more relevant drivers and add git references. Cc: Alessandro Rubini <rubini@unipv.it> Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22MAINTAINERS: update geode entryAndres Salomon
Remove Jordan as the geode maintainer (he's not been interested in geode for some time), and add myself as the maintainer. Signed-off-by: Andres Salomon <dilinger@queued.net> Cc: Daniel Drake <dsd@laptop.org> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: Chris Ball <cjb@laptop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-22MAINTAINERS: OMAP: hwmod: update hwmod code, data maintainershipPaul Walmsley
Add myself and Benoît as co-maintainers of the OMAP hwmod core code. (The OMAP hwmod code manages the integration of IP blocks on the OMAP SoC family.) Add Benoît as the maintainer of OMAP4-based SoC hwmod mode. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Benoît Cousson <b-cousson@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-22Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/iwlwifi/iwl-1000.c drivers/net/wireless/iwlwifi/iwl-6000.c drivers/net/wireless/iwlwifi/iwl-core.h
2010-12-22rtl818x: move rtl8180 and rtl8187 to separate subdirectoriesJohn W. Linville
These drivers share one header file, but nothing else. Worse, both drivers use the rtl8225 part with different register settings. The results has been some ugly naming -- let's simplify that. Signed-off-by: John W. Linville <linville@tuxdriver.com> Acked-by: Hin-Tak Leung <htl10@users.sourceforge.net> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Acked-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
